  4. OpenKNX Adapter startet nicht mehr nach System-Update
    6.1k
23 Beiträge 3 Kommentatoren 2.0k Aufrufe 2 Beobachtet
    @rsw2004
    cd /opt/iobroker
    npm ls ipaddr.js
    Und die Ausgabe von
    iob diag
    rsw2004
    @thomas-braun said in OpenKNX Adapter startet nicht mehr nach System-Update:
    cd /opt/iobroker
    npm ls ipaddr.js
    robin@raspberrypi4:~ $ cd /opt/iobroker
    npm ls ipaddr.js
    iobroker.inst@3.0.0 /opt/iobroker
    ├─┬ iobroker.admin@6.13.16
    │ └─┬ express@4.18.2
    │   └─┬ proxy-addr@2.0.7
    │     └── ipaddr.js@1.9.1
    └─┬ iobroker.openknx@0.7.2
      └─┬ knx@2.5.2
        └── ipaddr.js@1.2.0
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi4
           Icon name: computer
              Kernel: Linux 6.6.20+rpt-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     11:36:17 up  2:42,  2 users,  load average: 0.36, 0.40, 0.36
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Sat 2024-03-30 11:36:17 CET
               Universal time: Sat 2024-03-30 10:36:17 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    robin
    /home/robin
    robin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            4.0G        1.6G        1.3G        1.2M        1.2G        2.4G
    Swap:           104M          0B        104M
    Total:          4.1G        1.6G        1.4G
             3791 M total memory
             1482 M used memory
             1717 M active memory
              664 M inactive memory
             1207 M free memory
              118 M buffer memory
             1058 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  378M   1% /run
    /dev/sda2      ext4      459G  5.7G  430G   2% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   63M  448M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Mar 30 08:53:19 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=9e253307-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Mar 30 08:53:22 2024] EXT4-fs (sda2): mounted filesystem 7909438b-2884-423e-aa05-577fdea75c97 ro with ordered data mode. Quota mode: none.
    [Sat Mar 30 08:53:23 2024] EXT4-fs (sda2): re-mounted 7909438b-2884-423e-aa05-577fdea75c97 r/w. Quota mode: none.
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.3G    /var/
    660M    /var/log
    659M    /var/log/journal/1752ab92354a4fbe8ab5b2bd3f56c61e
    369M    /var/cache
    Archived and active journals take up 658.3M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    385M    /opt/iobroker/iobroker-data/
    286M    /opt/iobroker/iobroker-data/files
    142M    /opt/iobroker/iobroker-data/files/vis-2
    81M     /opt/iobroker/iobroker-data/files/vis-2/static
    80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/376.1862d3de.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231007205057-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.0
    /usr/bin/node           v18.20.0
    /usr/bin/npm            10.5.0
    /usr/bin/npx            10.5.0
    /usr/bin/corepack       0.25.2
    nodejs:
      Installed: 18.20.0-1nodesource1
      Candidate: 18.20.0-1nodesource1
      Version table:
     *** 18.20.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.19.1-1nodesource1 500
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 500
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.19
    admin:          6.13.16
    javascript:     7.8.0
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi4                             -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi4                             -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
      system.adapter.openknx.0                : openknx               : raspberrypi4                             -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : raspberrypi4                             -  enabled
    + system.adapter.solax.0                  : solax                 : raspberrypi4                             -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi4                             -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi4                             -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi4                             -  enabled
      system.adapter.vis-2.0                  : vis-2                 : raspberrypi4                             - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : raspberrypi4                             -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231007205057-if00
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.13.16  , installed 6.13.16
    Adapter    "backitup"     : 2.10.11  , installed 2.10.11
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 7.8.0    , installed 7.8.0
    Controller "js-controller": 5.0.19   , installed 5.0.19
    Adapter    "openknx"      : 0.7.2    , installed 0.7.2
    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
    Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
    Adapter    "socketio"     : 6.6.1    , installed 6.6.1
    Adapter    "solax"        : 0.9.6    , installed 0.9.6
    Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
    Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
    Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
    Adapter    "vis-2-widgets-material": 1.3.18, installed 1.3.18
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.2.3    , installed 6.2.3
    Adapter    "ws"           : 2.5.11   , installed 2.5.11
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
    Objects and States
    Objects:        2579
    States:         2188
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:40331           0.0.0.0:*               LISTEN      1001       29572      9139/io.yahka.0
    tcp        0      0 127.0.0.1:43343         0.0.0.0:*               LISTEN      1001       32228      9139/io.yahka.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       29544      9102/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6464       684/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31136      8646/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31129      8646/iobroker.js-co
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        4759       753/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31196      8664/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31589      9005/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6466       684/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        6538       800/grafana
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1929       533/avahi-daemon: r
    udp        0      0 0.0.0.0:50513           0.0.0.0:*                           104        1931       533/avahi-daemon: r
    udp6       0      0 :::33890                :::*                                104        1932       533/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        1930       533/avahi-daemon: r
    2024-03-30 11:35:25.899  - error: host.raspberrypi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
    2024-03-30 11:35:25.899  - error: host.raspberrypi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
    2024-03-30 11:35:25.900  - error: host.raspberrypi4 Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    2024-03-30 11:35:25.900  - error: host.raspberrypi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
    2024-03-30 11:35:25.900  - error: host.raspberrypi4 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
    2024-03-30 11:35:25.905  - error: host.raspberrypi4 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
    2024-03-30 11:35:25.905  - error: host.raspberrypi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
    2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
    2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
    2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
    2024-03-30 11:35:25.907  - error: host.raspberrypi4 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19) {
    2024-03-30 11:35:25.908  - error: host.raspberrypi4 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2024-03-30 11:35:25.908  - error: host.raspberrypi4 Caught by controller[0]:   requireStack: [
    2024-03-30 11:35:25.908  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
    2024-03-30 11:35:25.912  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
    2024-03-30 11:35:25.913  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
    2024-03-30 11:35:25.913  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/main.js'
    2024-03-30 11:35:25.914  - error: host.raspberrypi4 Caught by controller[0]:   ]
    2024-03-30 11:35:25.914  - error: host.raspberrypi4 Caught by controller[0]: }
    2024-03-30 11:35:25.915  - error: host.raspberrypi4 Caught by controller[0]: Node.js v18.20.0
    2024-03-30 11:35:25.915  - error: host.raspberrypi4 instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-03-30 11:35:25.916  - info: host.raspberrypi4 Rebuild for adapter system.adapter.openknx.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    2024-03-30 11:35:56.805  - info: solax.0 (8803) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
    2024-03-30 11:36:57.902  - info: solax.0 (8803) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
    code_text
    • R rsw2004
      cd /opt/iobroker
      npm ls ipaddr.js
      npm ls ipaddr.js
        └─┬ knx@2.5.2
          └── ipaddr.js@1.2.0
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      robin
      /home/robin
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               3791 M total memory
               1482 M used memory
               1207 M free memory
                118 M buffer memory
               1058 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1.3G    /var/
      660M    /var/log
      369M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.13.16
      javascript:     7.8.0
      Adapter State
      + instance is alive
      Objects and States
      Objects:        2579
      States:         2188
      Pending Updates: 0
      code_text
      @rsw2004
      Nichts auffälliges.
      Installier den openknx nochmal frisch darüber.
      R 1 Antwort Letzte Antwort
        @rsw2004
        Nichts auffälliges.
        rsw2004
        wie gesagt, hatte bereits eine neue Instanz installiert, brachte aber den gleichen Fehler.
        • R rsw2004
          @rsw2004
          Den ganzen Adapter, keine Instanz installieren.
            @rsw2004
            rsw2004
            also wie folgt?
            cd /opt/iobroker
            iobroker stop adapterName
            npm install iobroker.adapterName
            iobroker upload adapterName
            iobroker start adapterName
            Ändert sich nix
            • R rsw2004
              also wie folgt?
              cd /opt/iobroker
              Ändert sich nix
              @rsw2004
              Jein
              iobroker update
              iobroker upgrade openknx@0.7.2
              Rückmeldungen im Terminal hier bekannt machen.
                @rsw2004
                Jein
                iobroker update
                rsw2004
                robin@raspberrypi4:~ $ iobroker update
                Would you like to reinstall version 0.7.2 of openknx now? [(y)es, (n)o]: y
                Update openknx from @0.7.2 to @0.7.2
                NPM version: 10.5.0
                Installing iobroker.openknx@0.7.2... (System call)
                up to date in 7s
                102 packages are looking for funding
                  run `npm fund` for details
                upload [16] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/busload.png busload.png image/png
                upload [15] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/exportGA.png exportGA.png image/png
                upload [14] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                upload [13] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                upload [12] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                upload [11] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                upload [10] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                upload [9] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                upload [8] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                upload [7] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                upload [6] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                upload [5] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                upload [4] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                upload [3] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/index_m.html index_m.html text/html
                upload [2] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/openknx.png openknx.png image/png
                upload [1] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/style.css style.css text/css
                upload [0] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/words.js words.js application/javascript
                • R rsw2004
                  NPM version: 10.5.0
                  up to date in 7s
                  rsw2004
                  @rsw2004
                  Also ich denke, das hat mit dem Update des Adapter angefangen, unabhängig von JS oder NPM oder was auch immer.
                  Kann ich einfach die ältere Version das drüberbügeln?
                  Einfach die Versionsnummer ändern?
                  • R rsw2004
                    @rsw2004
                    @rsw2004 sagte in OpenKNX Adapter startet nicht mehr nach System-Update:
                    Dann mach ein Issue dazu auf, wenn du dir sicher bist.
                    Wie schaut denn ein Adapter-Neustart im Log nun aus? Immer noch ein rebuild im Gange?
                    • R rsw2004
                      @rsw2004
                      @rsw2004
                      Wobei das auf meinem System direkt durchläuft:
                      echad@chet:~ $ iob add openknx
                      NPM version: 10.5.0
                      Installing iobroker.openknx@0.7.3... (System call)
                      added 15 packages in 12s
                      117 packages are looking for funding
                      host.chet install adapter openknx
                      host.chet object system.adapter.openknx created/updated
                      host.chet create instance openknx
                      host.chet object system.adapter.openknx.0.alive created
                      host.chet object system.adapter.openknx.0.connected created
                      host.chet object system.adapter.openknx.0.compactMode created
                      host.chet object system.adapter.openknx.0.cpu created
                      host.chet object system.adapter.openknx.0.cputime created
                      host.chet object system.adapter.openknx.0.memHeapUsed created
                      host.chet object system.adapter.openknx.0.memHeapTotal created
                      host.chet object system.adapter.openknx.0.memRss created
                      host.chet object system.adapter.openknx.0.uptime created
                      host.chet object system.adapter.openknx.0.inputCount created
                      host.chet object system.adapter.openknx.0.outputCount created
                      host.chet object system.adapter.openknx.0.eventLoopLag created
                      host.chet object system.adapter.openknx.0.sigKill created
                      host.chet object system.adapter.openknx.0.logLevel created
                      host.chet object openknx.0.info created
                      host.chet object openknx.0.info.connection created
                      host.chet object openknx.0.info.busload created
                      host.chet object openknx.0.info.messagecount created
                      host.chet Set default value of openknx.0.info.connection: false
                      host.chet Set default value of openknx.0.info.busload: 0
                      host.chet Set default value of openknx.0.info.messagecount: 0
                      host.chet object system.adapter.openknx.0 created
                      echad@chet:~ $
                        rsw2004
                        es hat sich meiner Meinung nach nix geändert.
                        host.raspberrypi4
                        2024-03-30 15:59:27.700	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.raspberrypi4
                        2024-03-30 15:59:27.700	error	Caught by controller[0]: Node.js v18.20.0
                        host.raspberrypi4
                        2024-03-30 15:59:27.699	error	Caught by controller[0]: }
                        host.raspberrypi4
                        2024-03-30 15:59:27.699	error	Caught by controller[0]: ]
                        host.raspberrypi4
                        2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
                        host.raspberrypi4
                        2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
                        host.raspberrypi4
                        2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
                        host.raspberrypi4
                        2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
                        host.raspberrypi4
                        2024-03-30 15:59:27.699	error	Caught by controller[0]: requireStack: [
                        host.raspberrypi4
                        2024-03-30 15:59:27.699	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                        host.raspberrypi4
                        2024-03-30 15:59:27.699	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                        host.raspberrypi4
                        2024-03-30 15:59:27.698	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
                        host.raspberrypi4
                        2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
                        host.raspberrypi4
                        2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
                        host.raspberrypi4
                        2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js
                        host.raspberrypi4
                        2024-03-30 15:59:27.697	error	Caught by controller[0]: Require stack:
                        host.raspberrypi4
                        2024-03-30 15:59:27.697	error	Caught by controller[0]: Error: Cannot find module 'ipaddr.js'
                        host.raspberrypi4
                        2024-03-30 15:59:27.697	error	Caught by controller[0]: ^
                        host.raspberrypi4
                        2024-03-30 15:59:27.697	error	Caught by controller[0]: throw err;
                        host.raspberrypi4
                        2024-03-30 15:59:27.696	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
                        host.raspberrypi4
                        2024-03-30 15:59:26.615	info	instance system.adapter.openknx.0 started with pid 5921
                          @rsw2004
                          NPM version: 10.5.0
                          echad@chet:~ $
                          rsw2004
                          bei dir wurde die 0.7.3 installiert.
                          Habe das nun auch mal manuell geupdatet.
                          Der Log bleibt gleich.
                          • R rsw2004
                            Ich fahre auch ein 'bleeding edge'-Betasystem hier.
                              rsw2004
                              Könnte das weiterhelfen?
                              Welches Verzeichnis wäre denn hier das richtige?
                              /opt/iobroker/iobroker-data/files/openknx.admin ?
                              • R rsw2004
                                @rsw2004
                                cd /opt/iobroker/node_modules/iobroker.openknx
                                npm install --omit=dev
                                müsste das sein. Der Befehl mit --production ist veraltet.
                                  @rsw2004
                                  rsw2004
                                  Habe zumindest fürs Erste eine Lösung gefunden, damit alles wieder läuft.
                                  Erst Downgrade auf die ursprüngliche Version (laut LOG)
                                  iobroker update
                                  iobroker upgrade openknx@0.6.3
                                  danach
                                  Mit der aktuellen 0.7.2 funktioniert das nicht.
                                  Ich danke dir für deine Mühe
                                  • R rsw2004
                                    iobroker update
                                    danach
                                    Meldungen?
                                      ak68
                                      Auch wenn der Thread schon etwas älter ist:
                                      Ich bekommen nach einen Update auf 0.9.0 den OpnenKNX-Adapter nicht mehr zum Laufen, auch ein Downgrade auf 0.8.0, 0.7.3, 0.6.3 kann den Adapter nicht mehr erwecken:
                                      Hier die Fehlerbreschreibung:
                                      https://github.com/iobroker-community-adapters/ioBroker.openknx/issues/653
                                      Um Hilfe wäre ich dankbar :)
                                      ioBroker auf QNAP TVS-473
                                      Visu und Logiken mit node-red
                                      Anbindung an KNX per openKNX
                                      • A ak68
                                        @ak68
                                        Setz dein nodesource-Repo wieder auf das Gleis:
                                        iob nodejs-update 22
                                        Rückfragen bejahen.
                                          ak68
                                          Nach dem Neustart des KNX-Gateways läuft wieder Alles- ohne weitere Änderungen :)
                                          Vielen Dank
