  4. Test Adapter NSPanel-lovelace-ui v1.x.x
    6.5k
1.3k Beiträge 36 Kommentatoren 310.7k Aufrufe 36 Beobachtet
    danny_v1
    #782
    Ich hab die Zigbee Variante der Tados
    Hier eine Seite die geht:
        const Hauptseite_Kueche: PageType = {
            type: 'cardThermo2',
            uniqueName:'Hauptseite_Kueche',
            subPage: true,
            heading: 'egal wird eh nicht angezeigt',
            thermoItems:[
                {name: 'Kueche',
                set:'alias.0.Kueche.Temperaturen.Thermostat.Thermostat.SET', // Der Einstellwert der Heizung
                    thermoId1:'alias.0.Kueche.Temperaturen.Thermostat.Thermostat.ACTUAL', // Aktuelle Raumtemperatur (oberer Wert in der Anzeige)
                    thermoId2:'alias.0.Kueche.Temperaturen.Thermostat.Thermostat.HUMIDITY',
                    modeId:'alias.0.Kueche.Temperaturen.Thermostat.Thermostat.MODE', modeList:['OFF', 'AUTO', 'COOL', 'HEAT', 'ECO', 'FAN', 'DRY']}],
            //    {name: 'test2', modeList:['aus','kaputt', 'falsch'], modeId:'0_userdata.0.Einzelne_Geräte.Thermostat.MODE' ,iconHeatCycle:'home', iconHeatCycleOffColor:Red, thermoId1:'alias.0.Wohnzimmer.Temperaturen.Thermostat.ACTUAL', set:'alias.0.Wohnzimmer.Temperaturen.Thermostat.SET', thermoId2:'alias.0.Wohnzimmer.Temperaturen.Thermostat.HUMIDITY'}],
            items:[
                    { id: "alias.0.Kueche.Deckenlampe.Panel_Tisch",
                            name: "Panel Tisch", icon: "ceiling-light", icon2: "ceiling-light-outline",
                            minValueBrightness: 0, maxValueBrightness: 100, minValueColorTemp: 150, maxValueColorTemp: 500,
                            colormode: "hex", modeList: ['Aus','Hell','Mittel','Dunkel','Blau','Grün','Rot'], inSel_ChoiceState: true},
                    { id: "alias.0.Kueche.Deckenlampe.Panel_Spuele",
                            name: "Panel Spüle", icon: "ceiling-light", icon2: "ceiling-light-outline",
                    { id: "alias.0.Kueche.Deckenlampe.Gruppe",
                            name: "Panel Grupper", icon: "ceiling-light-multiple", icon2: "ceiling-light-multiple-outline",
                    { id: "alias.0.Kueche.Rollo_Kueche.Rollo", onColor: White, name: "Rollo", secondRow: "Küche", minValueLevel: 100, maxValueLevel: 0,},
                {navigate: true, targetPage: 'Kueche_Lampen', icon: 'lamp'},
                {navigate: true, targetPage: 'Kueche_Status', icon: 'state-machine'},
                {navigate: true, targetPage: 'Kueche_Szenen', icon: 'palette-swatch-variant'},
                {navigate: true, targetPage: 'Kueche_Alexa', icon: 'music'},
                {id: 'alias.0.Kueche.Temperaturen.Thermostat.Thermostat.LOWBAT'}
    und hier die Seite vom Thermostat welches nicht geht:
        const Hauptseite_Edda: PageType = {
            uniqueName:'Hauptseite_Edda',
            subPage: true,
            thermoItems:[
                 {name: 'Edda', id:'alias.0.Kinderzimmer_Edda.Temperatur.Thermostat.Thermostat'}
    //            {name: 'Edda',
    //            set:'alias.0.Kinderzimmer_Edda.Temperatur.Thermostat.Thermostat.SET', // Der Einstellwert der Heizung
    //                thermoId1:'alias.0.Kinderzimmer_Edda.Temperaturen.Thermostat.Thermostat.ACTUAL', // Aktuelle Raumtemperatur (oberer Wert in der Anzeige)
    //                thermoId2:'alias.0.Kinderzimmer_Edda.Temperaturen.Thermostat.Thermostat.HUMIDITY',
    //                modeId:'alias.0.Kinderzimmer_Edda.Temperaturen.Thermostat.Thermostat.MODE', modeList:['OFF', 'AUTO', 'COOL', 'HEAT', 'ECO', 'FAN', 'DRY']}],
            items:[
                {id: 'alias.0.Kinderzimmer_Edda.Deckenlampen.DeckenlampeRGB',
                    name: 'Deckenlampe', icon: 'ceiling-light', minValueBrightness: 0, maxValueBrightness: 100,
                    onColor: White, offColor: Gray, colorScale: {'val_min': 0, 'val_max': 100}},
                {id: 'alias.0.Kinderzimmer_Edda.Sensoren.Fenster', name: 'Fenster', icon2: 'window-open', icon: 'window-closed', onColor: White, offColor: Red},
                {id: 'alias.0.Kinderzimmer_Edda.Sensoren.KinderzimmerTuer_Edda', name: 'Tuer', icon2: 'door-open', icon: 'door-closed', onColor: White, offColor: Red},
                {navigate: true, targetPage: 'WZ_Lampen', icon: 'lamp'},
                {navigate: true, targetPage: 'WZ_Status', icon: 'state-machine'},
                {navigate: true, targetPage: 'WZ_Szenen', icon: 'palette-swatch-variant'},
                {navigate: true, targetPage: 'WZ_Alexa', icon: 'music'},
                {id: 'alias.0.Kinderzimmer_Edda.Temperaturen.Thermostat.Thermostat.LOWBAT'}
    Aber wie gesagt die Batterie anzeige bekomme ich nicht hin.
    • D danny_v1
      Vielen dank, für die schnelle Hilfe, werde ich gleich mal testen. Ich hatte es nur mit minValue versucht da hat es nicht funktioniert.
      Ich habe auch noch ein Thermostat, wenn ich das in eine Thermo2Page einfüge wird mir ein Sonos Player angezeigt. Aber nur wenn ich die Werte Set und so einzeln eingebe, wenn ich den ganzen Ordner einfüge wird es dargestellt. Aber da ich die Power und Party Symbole usw nicht brauche, würde ich es gern einzeln machen und die linke Seite für andere Icons nutzen. Bekomme mit meinen Tado Thermostaten auch die Batterie anzeige nicht hin. Die zeigen aber auch nur NORMAL und LOW an.
      TT-Tom
      #783
      @danny_v1
      Du kannst dein Alias doch selber bestimmen, welche Datenpunkte er darstellen soll. Lass die weg, die du nicht benötigst. Bei der Batterie wäre interessant welche Rolle dahinter steht.
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
        danny_v1
        schrieb am zuletzt editiert von danny_v1
        #784
        Wenn ich den Ordner vom Thermostat, so wie hier :
        eintrage, sind die Symbloe auf der linken automatisch da und ich kann die Seite dann nach unten durchblättern, und die neun möglichen Symbloe werden alle rechts dargestellt.
        Die Batterienanzeige hat die Rolle: indicator.lowbat.
        • D danny_v1
          TT-Tom
          #785
          @danny_v1
          Kannst du mal den Alias zeigen, das man die Datenpunkte und Rollen sieht.
          Kann deine Aussage mit der Anzeige noch nicht ganz nachvollziehen bzw. noch nicht verstanden.
          Gruß Tom
          Public Transport
            danny_v1
            #786
            Das ist der Alias der Batterieanzeige:
              "type": "state",
              "common": {
                "modify": "",
                "name": "Battery State",
                "type": "string",
                "role": "indicator.lowbat",
                "read": true,
                "write": false
              "from": "system.adapter.tado.0",
              "user": "system.user.admin",
              "ts": 1760390415185,
              "_id": "tado.0.1724245.Rooms.4.devices.VA3682095872.batteryState",
              "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
            So sieht die Seite aus wenn ich den kompletten Thermostat Ordner angebe. Da kann ich die ersten 3 Icons auf der linken Seite nicht verwenden, die werden automatisch dargestellt.
            • D danny_v1
                "type": "state",
                "common": {
                  "modify": "",
                  "type": "string",
                  "read": true,
                  "write": false
                "acl": {
                  "object": 1636,
                  "state": 1636,
              TT-Tom
              #787
              @danny_v1 sagte in Betatest NSPanel-lovelace-ui v0.7.x:
              "type": "string",
              der type ist falsch, richtig ist boolean.
              die rolle ist indicator.maintenance.lowbat
              Wenn ich das richtig verstanden habe, bekommst du vom Tado aber ein String NORMAL und LOW. Wenn dem so ist, musst du im Alias noch eine Konvertierung durchführen.
              val == 'LOW' ? true : false
              ja das ist so im Adapter verankert. Bei Angabe der id wird erst das Thermostat dargestellten mit allen Datenpunkten die gefunden werde, danach kommen die "Items"
              hier fehlt bei thermoItems die id, mich wundert das du keine Fehlermeldung bekommen hast. übersehen, ist ja in der selben Zeile
                      subPage: true,
                      thermoItems:[
              //            {name: 'Edda',
                      items:[
              Gruß Tom
              Public Transport
                danny_v1
                #788
                Wo muss ich die Konvertierung einfügen?
                Wenn ich es nach type eintrage bekomme ich einen Fehler
                • D danny_v1
                          subPage: true,
                          thermoItems:[
                              {name: 'Kueche',
                          items:[
                          subPage: true,
                          thermoItems:[
                  //            {name: 'Edda',
                          items:[
                  TT-Tom
                  #789
                  zeige mal die Alias Channel mit seinen Datenpunkten und Rollen.
                  hier kannst du auch selber vergleichen, https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/wiki/ALIAS#thermostat was unterstützt wird. Wenn du einen Datenpunkt nutzt dann so wie in der Tabelle beschrieben
                  Gruß Tom
                  Public Transport
                  • D danny_v1
                    TT-Tom
                    #790
                    @danny_v1
                    sollte der Alias aussehen
                      "_id": "alias.0.example_string_boolean",
                      "type": "state",
                      "common": {
                        "name": "example_string",
                        "type": "boolean",
                        "alias": {
                          "id": "0_userdata.0.example_string",
                          "read": "val == 'LOW' ? true : false"
                        "desc": "Manuell erzeugt",
                        "role": "state",
                        "read": true,
                        "write": true
                      "native": {},
                      "ts": 1767631898178,
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    EDIT: hast du denn einen Alias erstellt von Lowbat bzw. von dem ganzen Thermostat?
                    Gruß Tom
                    Public Transport
                      danny_v1
                      #791
                        "_id": "alias.0.Wohnzimmer.Temperaturen.Thermostat.Thermostat.LOWBAT",
                        "native": {},
                        "type": "state",
                        "common": {
                          "alias": {
                            "id": "tado.0.1724245.Rooms.4.devices.VA3682095872.batteryState",
                          "name": "LOWBAT",
                          "role": "indicator.maintenance.lowbat",
                          "type": "boolean"
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                        "ts": 1767632183732
                      So sieht es aktuell aus.
                      • D danny_v1
                          "native": {},
                          "type": "state",
                          "common": {
                            "alias": {
                            "name": "LOWBAT",
                            "type": "boolean"
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "ts": 1767632183732
                        TT-Tom
                        #792
                        @danny_v1
                        passt, deine Batterie ist low zur Zeit
                        Gruß Tom
                        Public Transport
                          danny_v1
                          #793
                          nein aktuell normal, aber es wird nichts angezeigt. Hab die Werte vorhin mal händisch hin und her geschalten.
                          • D danny_v1
                            TT-Tom
                            #794
                            @danny_v1
                            achte erstmal auf den Alias, ob der schaltet. Wichtig ist auch die Schreibweise.
                            EDIT: hast du jetzt aucht den Alias eingebunden???
                            Gruß Tom
                            Public Transport
                              danny_v1
                              #795
                              Ja ist drin als Icon 9. Er schaltet auch wenn ich den Ursprungs DP schreibe
                              • D danny_v1
                                TT-Tom
                                #796
                                @danny_v1
                                okay muss jetzt erstmal weg. Melde mich ggf. nachher nochmal.
                                Gruß Tom
                                Public Transport
                                • 1 Offline
                                  1 Offline
                                  13patrick37
                                  #797
                                  vorab vielen Dank an @tt-tom für die Hilfe heute bei Discord. :)
                                  Ich baue mir gerade verschiedene Testseiten auf, allerdings komme ich bei der Rollo Steuerung nicht weiter. Vielleicht habt ihr eine Idee. Auf der Testseite ist ein Link zum "lichttest", die Steuerung vom Küchenlicht und die Rollosteuerung. Allerdings zeigt es mir die Rollo Steuerung nicht an, obwohl ich im Alias alles hinterlegt habe. Fehlt mir etwas?
                                  const Hauptseite: ScriptConfig.PageGrid = {
                                          type: 'cardGrid',
                                          uniqueName: 'main',
                                          subPage: true,
                                          heading: 'Testseite',
                                          alwaysOnDisplay: true,
                                          items: [
                                              { navigate: true, id: null, targetPage: 'lichttest', onColor: White, name: 'lichttest'},
                                                { id: 'alias.0.Küchenlicht',
                                                 targetPage: 'Küchenlicht',
                                                 icon: 'lightbulb-spot',
                                                 icon2: 'lightbulb-spot-off',
                                                 onColor: MSGreen,
                                                 offColor: MSRed
                                                { id: 'alias.0.Rolladen_Küche',
                                                 targetPage: 'Rollo_Küche',
                                                 icon: 'blinds-horizontal',
                                                 icon2: 'blinds-horizontal-closed',
                                                 onColor: MSGreen,
                                                 offColor: MSRed
                                    danny_v1
                                    #798
                                    Denk das targetPage kannst du weglassen das ist glaube ich ein PopUp.
                                    Und kleiner Tipp bei der Namensgebung Umlaute oder auch ß vermeiden das macht auch oft Probleme.
                                    • 1 Offline
                                      1 Offline
                                      13patrick37
                                      #799
                                      Hab es geändert, funktioniert trotzdem nicht. Vermute es liegt am Alias. Ist mein Alias falsch eingestellt? Nutze Somfy Tahoma.
                                      Hier noch die zweite Seite vom Rollo Alias:
                                      • 1 13patrick37
                                                type: 'cardGrid',
                                                uniqueName: 'main',
                                                subPage: true,
                                                items: [
                                                       onColor: MSGreen,
                                                       offColor: MSRed
                                                       onColor: MSGreen,
                                                       offColor: MSRed
                                        TT-Tom
                                        #800
                                        @13patrick37
                                        targetPage nur in Verbindung mit navigate: true nutzen.
                                        Bei den Blindes sind mal die Original Datenpunkte interessant. mal sehen, ob sie den Anforderungen entsprechend.
                                        Tilt fällt bei einem einfachen Rollo schon mal aus.
                                        Gruß Tom
                                        Public Transport
                                        • 1 Offline
                                          1 Offline
                                          13patrick37
                                          #801
                                          Anbei die originalen Datenpunkte. Läuft über den Tahoma Adapter. Skripte funktionieren wunderbar darüber.
