  4. Test Adapter smartfriends v2.0.x Latest
    6.8k
132 Beiträge 14 Kommentatoren 14.4k Aufrufe 13 Beobachtet
  • Black ThunderB Black Thunder
    @tony63526 Kannst du mir bitte dazu ein Debug-Log posten, wenn du die Rollläden bewegst, aber die Position nicht aktualisiert wird?
    Eigentlich sollte das schon funktionieren, sofern die neue Position vom Gerät gemeldet wird.
    tony63526
    @Black-Thunder ```
    code_text
    1341698	2025-12-28 19:41:22.889	info	Processed 25 device(s), created 4 master device(s).
    smartfriends.0
    1341698	2025-12-28 19:41:22.885	info	Device created: ${Position} (ID: 17243)
    smartfriends.0
    1341698	2025-12-28 19:41:22.883	info	Device created: ${Motor} (ID: 19969)
    smartfriends.0
    1341698	2025-12-28 19:41:22.878	info	Device created: ${Position} (ID: 19154)
    smartfriends.0
    1341698	2025-12-28 19:41:22.876	info	Device created: ${Motor} (ID: 2072)
    smartfriends.0
    1341698	2025-12-28 19:41:22.870	info	Device created: ${Position} (ID: 8566)
    smartfriends.0
    1341698	2025-12-28 19:41:22.868	info	Device created: ${Motor} (ID: 14361)
    smartfriends.0
    1341698	2025-12-28 19:41:22.860	info	Device created: ${SchellenbergBlind.Steps} (ID: 19986)
    smartfriends.0
    1341698	2025-12-28 19:41:22.858	info	Device created: ${Position} (ID: 10331)
    smartfriends.0
    1341698	2025-12-28 19:41:22.856	info	Device created: ${SchellenbergBlind} (ID: 5908)
    smartfriends.0
    1341698	2025-12-28 19:41:19.745	info	Querying all devices...
    smartfriends.0
    1341698	2025-12-28 19:41:19.523	info	Connecting to gateway and retrieving data...
    smartfriends.0
    1341698	2025-12-28 19:41:19.493	info	starting. Version 1.1.0-alpha.0 (non-npm: Black-Thunder/ioBroker.smartfriends#8fb15c92740f1b88005ac022b5fd76a6c1b8ffff) in /opt/iobroker/node_modules/iobroker.smartfriends, node: v22.21.0, js-controller: 7.0.7
    smartfriends.0
    1341618	2025-12-28 19:41:14.971	info	terminating
    smartfriends.0
    1341618	2025-12-28 19:41:14.471	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    smartfriends.0
    1341618	2025-12-28 19:41:14.470	info	terminating
    smartfriends.0
    1341618	2025-12-28 19:41:14.470	info	onUnload(): Cleaned everything up...
    smartfriends.0
    1341618	2025-12-28 19:41:14.470	debug	Handle Disconnect was called. Rejecting all queued promises and stopping keep alive.
    smartfriends.0
    1341618	2025-12-28 19:41:14.469	info	Got terminate signal TERMINATE_YOURSELF
    smartfriends.0
    1341618	2025-12-28 19:41:09.643	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:41:09.642	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:41:04.642	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:41:04.642	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:59.641	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:59.641	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:54.641	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:54.641	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:50.031	debug	Updated timestamp to Wed Jan 28 2026 19:40:50 GMT+0100 (Central European Standard Time)
    smartfriends.0
    1341618	2025-12-28 19:40:50.031	debug	Message received: newDeviceValue (code: 2)
    smartfriends.0
    1341618	2025-12-28 19:40:50.030	debug	Received data: { "currentTimestamp" : 20251228194050, "response" : { "counter" : 3885, "debugName" : "Schlafzimmer rollladen links:${Position}", "deviceID" : 19154, "masterDeviceID" : 15190, "value" : 0, "valueTarget" : 0, "valueTimestamp" : 20251228194050 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
    smartfriends.0
    1341618	2025-12-28 19:40:49.641	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:49.640	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:47.878	debug	Updated timestamp to Wed Jan 28 2026 19:40:47 GMT+0100 (Central European Standard Time)
    smartfriends.0
    1341618	2025-12-28 19:40:47.878	debug	Message received: newDeviceValue (code: 2)
    smartfriends.0
    1341618	2025-12-28 19:40:47.878	debug	Received data: { "currentTimestamp" : 20251228194047, "response" : { "counter" : 2295, "debugName" : "Schlafzimmer rollladen links:${Motor}", "deviceID" : 2072, "masterDeviceID" : 15190, "value" : 0, "valueTimestamp" : 20251228194047 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
    smartfriends.0
    1341618	2025-12-28 19:40:44.641	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:44.640	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:39.641	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:39.641	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:34.641	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:34.640	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:29.640	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:29.640	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:24.640	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:24.639	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:24.092	debug	Updated timestamp to Wed Jan 28 2026 19:40:24 GMT+0100 (Central European Standard Time)
    smartfriends.0
    1341618	2025-12-28 19:40:24.092	debug	Message received: newDeviceValue (code: 2)
    smartfriends.0
    1341618	2025-12-28 19:40:24.092	debug	Received data: { "currentTimestamp" : 20251228194024, "response" : { "counter" : 2294, "debugName" : "Schlafzimmer rollladen links:${Motor}", "deviceID" : 2072, "masterDeviceID" : 15190, "value" : 1, "valueTimestamp" : 20251228194024 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
    smartfriends.0
    1341618	2025-12-28 19:40:19.640	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:19.639	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:16.188	debug	Updated timestamp to Wed Jan 28 2026 19:40:16 GMT+0100 (Central European Standard Time)
    smartfriends.0
    1341618	2025-12-28 19:40:16.188	debug	Message received: newDeviceValue (code: 2)
    smartfriends.0
    1341618	2025-12-28 19:40:16.187	debug	Received data: { "currentTimestamp" : 20251228194016, "response" : { "counter" : 3884, "debugName" : "Schlafzimmer rollladen links:${Position}", "deviceID" : 19154, "masterDeviceID" : 15190, "value" : 100, "valueTarget" : 100, "valueTimestamp" : 20251228194016 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
    smartfriends.0
    1341618	2025-12-28 19:40:14.640	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:14.639	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:14.033	debug	Updated timestamp to Wed Jan 28 2026 19:40:14 GMT+0100 (Central European Standard Time)
    smartfriends.0
    1341618	2025-12-28 19:40:14.033	debug	Message received: newDeviceValue (code: 2)
    smartfriends.0
    1341618	2025-12-28 19:40:14.032	debug	Received data: { "currentTimestamp" : 20251228194014, "response" : { "counter" : 2293, "debugName" : "Schlafzimmer rollladen links:${Motor}", "deviceID" : 2072, "masterDeviceID" : 15190, "value" : 0, "valueTimestamp" : 20251228194014 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
    smartfriends.0
    1341618	2025-12-28 19:40:09.639	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:09.639	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:40:04.639	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:40:04.638	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:39:59.638	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:39:59.638	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:39:54.637	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:39:54.637	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:39:50.658	debug	Updated timestamp to Wed Jan 28 2026 19:39:50 GMT+0100 (Central European Standard Time)
    smartfriends.0
    1341618	2025-12-28 19:39:50.657	debug	Message received: newDeviceValue (code: 2)
    smartfriends.0
    1341618	2025-12-28 19:39:50.657	debug	Received data: { "currentTimestamp" : 20251228193950, "response" : { "counter" : 2292, "debugName" : "Schlafzimmer rollladen links:${Motor}", "deviceID" : 2072, "masterDeviceID" : 15190, "value" : 2, "valueTimestamp" : 20251228193950 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
    smartfriends.0
    1341618	2025-12-28 19:39:49.636	debug	Send JSON: {"command":"keepalive"}
    smartfriends.0
    1341618	2025-12-28 19:39:49.636	debug	Sending command with method: keepalive
    smartfriends.0
    1341618	2025-12-28 19:39:47.938	debug	Device 17243: Updated position = 100
    smartfriends.0
    1341618	2025-12-28 19:39:47.895	debug	Device 8566: Updated position = 100
    smartfriends.0
    1341618	2025-12-28 19:39:47.854	debug	Device 10331: Updated position = 100
    smartfriends.0
    1341618	2025-12-28 19:39:47.854	debug	Device 19154: Updated position = 0
    smartfriends.0
    1341618	2025-12-28 19:39:47.843	debug	Received value for unknown device 18346, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.843	debug	Device value update: deviceID=18346, value=2
    smartfriends.0
    1341618	2025-12-28 19:39:47.843	debug	Device value update: deviceID=17243, value=100
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Device value update: deviceID=19969, value=0
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Received value for unknown device 9988, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Device value update: deviceID=9988, value=2
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Device value update: deviceID=8566, value=100
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Device value update: deviceID=14361, value=0
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Received value for unknown device 17101, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Device value update: deviceID=17101, value=3
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Device value update: deviceID=19986, value=0
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Received value for unknown device 4771, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Device value update: deviceID=4771, value=0
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Device value update: deviceID=10331, value=100
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Device value update: deviceID=5908, value=0
    smartfriends.0
    1341618	2025-12-28 19:39:47.842	debug	Received value for unknown device 2654, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Device value update: deviceID=2654, value=3
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Device value update: deviceID=19154, value=0
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Device value update: deviceID=2072, value=0
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Received value for unknown device 11959, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Device value update: deviceID=11959, value=
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Received value for unknown device 2711, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Device value update: deviceID=2711, value=2
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Received value for unknown device 7195, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Device value update: deviceID=7195, value=
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Received value for unknown device 17547, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Device value update: deviceID=17547, value=
    smartfriends.0
    1341618	2025-12-28 19:39:47.841	debug	Received value for unknown device 9985, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Device value update: deviceID=9985, value=
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Received value for unknown device 5250, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Device value update: deviceID=5250, value=17:42
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Received value for unknown device 1367, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Device value update: deviceID=1367, value=16:16
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Received value for unknown device 14120, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Device value update: deviceID=14120, value=12:19
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Received value for unknown device 733, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Device value update: deviceID=733, value=08:22
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Received value for unknown device 5200, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Device value update: deviceID=5200, value=06:56
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Received value for unknown device 13530, ignoring.
    smartfriends.0
    1341618	2025-12-28 19:39:47.840	debug	Device value update: deviceID=13530, value=${Dusk}
    smartfriends.0
    1341618	2025-12-28 19:39:47.839	info	Processed 25 device(s), created 4 master device(s).
    smartfriends.0
    1341618	2025-12-28 19:39:47.839	debug	Skipping device Hub (pushNotification) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.839	debug	Skipping device Smart friendsbox (pushNotification) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.839	debug	Created and saved device 17243 (${Position})
    smartfriends.0
    1341618	2025-12-28 19:39:47.833	debug	Created and saved device 19969 (${Motor})
    smartfriends.0
    1341618	2025-12-28 19:39:47.829	debug	Skipping device ${RssiDevice} (${SchellenbergRssi}) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.829	info	Device created: ${Position} (ID: 17243)
    smartfriends.0
    1341618	2025-12-28 19:39:47.829	debug	Created and saved device 17243 (${Position})
    smartfriends.0
    1341618	2025-12-28 19:39:47.827	info	Device created: ${Motor} (ID: 19969)
    smartfriends.0
    1341618	2025-12-28 19:39:47.827	debug	Created and saved device 19969 (${Motor})
    smartfriends.0
    1341618	2025-12-28 19:39:47.824	debug	Created and saved device 19154 (${Position})
    smartfriends.0
    1341618	2025-12-28 19:39:47.823	debug	Created and saved device 2072 (${Motor})
    smartfriends.0
    1341618	2025-12-28 19:39:47.820	debug	Skipping device ${RssiDevice} (${SchellenbergRssi}) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.819	info	Device created: ${Position} (ID: 19154)
    smartfriends.0
    1341618	2025-12-28 19:39:47.819	debug	Created and saved device 19154 (${Position})
    smartfriends.0
    1341618	2025-12-28 19:39:47.816	info	Device created: ${Motor} (ID: 2072)
    smartfriends.0
    1341618	2025-12-28 19:39:47.816	debug	Created and saved device 2072 (${Motor})
    smartfriends.0
    1341618	2025-12-28 19:39:47.812	debug	Skipping device ${DevicePushNotification} (pushNotificationChain) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.812	debug	Created and saved device 8566 (${Position})
    smartfriends.0
    1341618	2025-12-28 19:39:47.809	debug	Created and saved device 14361 (${Motor})
    smartfriends.0
    1341618	2025-12-28 19:39:47.804	debug	Skipping device ${RssiDevice} (${SchellenbergRssi}) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.804	info	Device created: ${Position} (ID: 8566)
    smartfriends.0
    1341618	2025-12-28 19:39:47.804	debug	Created and saved device 8566 (${Position})
    smartfriends.0
    1341618	2025-12-28 19:39:47.800	info	Device created: ${Motor} (ID: 14361)
    smartfriends.0
    1341618	2025-12-28 19:39:47.799	debug	Created and saved device 14361 (${Motor})
    smartfriends.0
    1341618	2025-12-28 19:39:47.791	debug	Skipping device ${ServerStatus} (${ServerStatus}) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.791	debug	Created and saved device 19986 (${SchellenbergBlind.Steps})
    smartfriends.0
    1341618	2025-12-28 19:39:47.788	debug	Created and saved device 10331 (${Position})
    smartfriends.0
    1341618	2025-12-28 19:39:47.781	debug	Created and saved device 5908 (${SchellenbergBlind})
    smartfriends.0
    1341618	2025-12-28 19:39:47.775	debug	Skipping device ${Status} (${SchellenbergRssi}) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.774	info	Device created: ${SchellenbergBlind.Steps} (ID: 19986)
    smartfriends.0
    1341618	2025-12-28 19:39:47.774	debug	Created and saved device 19986 (${SchellenbergBlind.Steps})
    smartfriends.0
    1341618	2025-12-28 19:39:47.771	debug	Skipping device ${SchellenbergBlind.StepConfiguration} (${SchellenbergBlind.StepConfiguration}) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.771	info	Device created: ${Position} (ID: 10331)
    smartfriends.0
    1341618	2025-12-28 19:39:47.771	debug	Created and saved device 10331 (${Position})
    smartfriends.0
    1341618	2025-12-28 19:39:47.769	info	Device created: ${SchellenbergBlind} (ID: 5908)
    smartfriends.0
    1341618	2025-12-28 19:39:47.769	debug	Created and saved device 5908 (${SchellenbergBlind})
    smartfriends.0
    1341618	2025-12-28 19:39:47.748	debug	Skipping device ${Dusk} (AstrofunktionStr) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.748	debug	Skipping device UZB Z-Wave USB Adapter (${ZwaveController}) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.747	debug	Skipping device ${Sunset} (AstrofunktionStr) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.747	debug	Skipping device ${Sunrise} (AstrofunktionStr) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.747	debug	Skipping device ${Dawn} (AstrofunktionStr) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.747	debug	Skipping device ${SolarNoon} (AstrofunktionStr) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.747	debug	Skipping device ${LastStatus} (Astrofunktion) – no definable control states found
    smartfriends.0
    1341618	2025-12-28 19:39:47.746	debug	Loaded 195 device definitions
    smartfriends.0
    1341618	2025-12-28 19:39:47.743	debug	Updated timestamp to Wed Jan 28 2026 19:39:44 GMT+0100 (Central European Standard Time)
    smartfriends.0
    1341618	2025-12-28 19:39:47.743	debug	Message received: success (code: 1)
      tony63526
      schrieb am zuletzt editiert von tony63526
      @Black-Thunder
      Moment jetzt hat sich der Wert geändert.
      Mhh komisch. Wann fragt er die Werte immer ab?
      Nachtrag:....Sobald ich den Adapter neu starte aktualisiert er erst die Werte.
      Black ThunderB 2 Antworten Letzte Antwort
      • T tony63526
        @Black-Thunder
        Black ThunderB Offline
        Black Thunder
        @tony63526 Ja, aktiv abgefragt werden die Werte nur einmal zum Start des Adapters. Danach werden neue Werte vom Gateway gepusht und der Adapter sollte darauf reagieren.
        Hattest du bei deinem geposteten Log auch einen Rollladenantrieb bewegt? Im Log sehe ich dazu keine passenden Einträge.
        • T tony63526
          @Black-Thunder
          Black Thunder
          @tony63526 Ach, warte kurz. Ich sehe gerade schon einen Fehler im Code. So kann es aktuell mit den Updates der Werten nicht funktionieren.
          Ich geb wieder Bescheid, sobald es eine neue Version gibt.
            tony63526
            @Black-Thunder
            Ja, ich habe den Adapter von Info auf Debug umgestellt und dann direkt am RolloDrive 75 Gurtwickler die Knöpfe hoch/runter gedrückt. Ich habe auch mittendrin noch einmal gedrückt, um ihn anzuhalten.
            Habe es nochmal versucht.
            smartfriends.0
            1342381	2025-12-28 19:57:25.860	info	Processed 25 device(s), created 4 master device(s).
            smartfriends.0
            1342381	2025-12-28 19:57:25.855	info	Device created: ${Position} (ID: 17243)
            smartfriends.0
            1342381	2025-12-28 19:57:25.853	info	Device created: ${Motor} (ID: 19969)
            smartfriends.0
            1342381	2025-12-28 19:57:25.847	info	Device created: ${Position} (ID: 19154)
            smartfriends.0
            1342381	2025-12-28 19:57:25.844	info	Device created: ${Motor} (ID: 2072)
            smartfriends.0
            1342381	2025-12-28 19:57:25.837	info	Device created: ${Position} (ID: 8566)
            smartfriends.0
            1342381	2025-12-28 19:57:25.834	info	Device created: ${Motor} (ID: 14361)
            smartfriends.0
            1342381	2025-12-28 19:57:25.824	info	Device created: ${SchellenbergBlind.Steps} (ID: 19986)
            smartfriends.0
            1342381	2025-12-28 19:57:25.821	info	Device created: ${Position} (ID: 10331)
            smartfriends.0
            1342381	2025-12-28 19:57:25.818	info	Device created: ${SchellenbergBlind} (ID: 5908)
            smartfriends.0
            1342381	2025-12-28 19:57:22.625	info	Querying all devices...
            smartfriends.0
            1342381	2025-12-28 19:57:22.402	info	Connecting to gateway and retrieving data...
            smartfriends.0
            1342381	2025-12-28 19:57:22.373	info	starting. Version 1.1.0-alpha.0 (non-npm: Black-Thunder/ioBroker.smartfriends#8fb15c92740f1b88005ac022b5fd76a6c1b8ffff) in /opt/iobroker/node_modules/iobroker.smartfriends, node: v22.21.0, js-controller: 7.0.7
            smartfriends.0
            1342070	2025-12-28 19:57:18.029	info	terminating
            smartfriends.0
            1342070	2025-12-28 19:57:17.528	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            smartfriends.0
            1342070	2025-12-28 19:57:17.527	info	terminating
            smartfriends.0
            1342070	2025-12-28 19:57:17.527	info	onUnload(): Cleaned everything up...
            smartfriends.0
            1342070	2025-12-28 19:57:17.527	debug	Handle Disconnect was called. Rejecting all queued promises and stopping keep alive.
            smartfriends.0
            1342070	2025-12-28 19:57:17.526	info	Got terminate signal TERMINATE_YOURSELF
            smartfriends.0
            1342070	2025-12-28 19:57:16.295	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:57:16.294	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:57:11.295	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:57:11.294	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:57:06.295	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:57:06.294	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:57:01.294	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:57:01.294	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:56.293	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:56.293	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:51.293	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:51.292	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:46.293	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:46.293	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:41.292	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:41.291	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:40.913	debug	Updated timestamp to Wed Jan 28 2026 19:56:40 GMT+0100 (Central European Standard Time)
            smartfriends.0
            1342070	2025-12-28 19:56:40.913	debug	Message received: newDeviceValue (code: 2)
            smartfriends.0
            1342070	2025-12-28 19:56:40.913	debug	Received data: { "currentTimestamp" : 20251228195640, "response" : { "counter" : 3889, "debugName" : "Schlafzimmer rollladen links:${Position}", "deviceID" : 19154, "masterDeviceID" : 15190, "value" : 100, "valueTarget" : 100, "valueTimestamp" : 20251228195640 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
            smartfriends.0
            1342070	2025-12-28 19:56:38.761	debug	Updated timestamp to Wed Jan 28 2026 19:56:38 GMT+0100 (Central European Standard Time)
            smartfriends.0
            1342070	2025-12-28 19:56:38.761	debug	Message received: newDeviceValue (code: 2)
            smartfriends.0
            1342070	2025-12-28 19:56:38.761	debug	Received data: { "currentTimestamp" : 20251228195638, "response" : { "counter" : 2303, "debugName" : "Schlafzimmer rollladen links:${Motor}", "deviceID" : 2072, "masterDeviceID" : 15190, "value" : 0, "valueTimestamp" : 20251228195638 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
            smartfriends.0
            1342070	2025-12-28 19:56:36.291	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:36.291	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:31.290	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:31.290	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:26.541	debug	Updated timestamp to Wed Jan 28 2026 19:56:26 GMT+0100 (Central European Standard Time)
            smartfriends.0
            1342070	2025-12-28 19:56:26.541	debug	Message received: newDeviceValue (code: 2)
            smartfriends.0
            1342070	2025-12-28 19:56:26.540	debug	Received data: { "currentTimestamp" : 20251228195626, "response" : { "counter" : 2302, "debugName" : "Schlafzimmer rollladen links:${Motor}", "deviceID" : 2072, "masterDeviceID" : 15190, "value" : 2, "valueTimestamp" : 20251228195626 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
            smartfriends.0
            1342070	2025-12-28 19:56:26.290	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:26.290	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:21.289	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:21.289	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:16.288	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:16.287	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:11.287	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:11.286	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:06.286	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:06.286	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:56:05.536	debug	Updated timestamp to Wed Jan 28 2026 19:56:05 GMT+0100 (Central European Standard Time)
            smartfriends.0
            1342070	2025-12-28 19:56:05.536	debug	Message received: newDeviceValue (code: 2)
            smartfriends.0
            1342070	2025-12-28 19:56:05.536	debug	Received data: { "currentTimestamp" : 20251228195605, "response" : { "counter" : 3888, "debugName" : "Schlafzimmer rollladen links:${Position}", "deviceID" : 19154, "masterDeviceID" : 15190, "value" : 48, "valueTarget" : 48, "valueTimestamp" : 20251228195605 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
            smartfriends.0
            1342070	2025-12-28 19:56:03.384	debug	Updated timestamp to Wed Jan 28 2026 19:56:03 GMT+0100 (Central European Standard Time)
            smartfriends.0
            1342070	2025-12-28 19:56:03.384	debug	Message received: newDeviceValue (code: 2)
            smartfriends.0
            1342070	2025-12-28 19:56:03.384	debug	Received data: { "currentTimestamp" : 20251228195603, "response" : { "counter" : 2301, "debugName" : "Schlafzimmer rollladen links:${Motor}", "deviceID" : 2072, "masterDeviceID" : 15190, "value" : 0, "valueTimestamp" : 20251228195603 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
            smartfriends.0
            1342070	2025-12-28 19:56:01.286	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:56:01.286	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:55:56.285	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:55:56.284	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:55:51.284	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:55:51.284	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:55:50.782	debug	Updated timestamp to Wed Jan 28 2026 19:55:50 GMT+0100 (Central European Standard Time)
            smartfriends.0
            1342070	2025-12-28 19:55:50.782	debug	Message received: newDeviceValue (code: 2)
            smartfriends.0
            1342070	2025-12-28 19:55:50.782	debug	Received data: { "currentTimestamp" : 20251228195550, "response" : { "counter" : 2300, "debugName" : "Schlafzimmer rollladen links:${Motor}", "deviceID" : 2072, "masterDeviceID" : 15190, "value" : 1, "valueTimestamp" : 20251228195550 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
            smartfriends.0
            1342070	2025-12-28 19:55:46.284	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:55:46.283	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:55:41.283	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:55:41.282	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:55:36.283	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:55:36.282	debug	Sending command with method: keepalive
            smartfriends.0
            1342070	2025-12-28 19:55:31.282	debug	Send JSON: {"command":"keepalive"}
            smartfriends.0
            1342070	2025-12-28 19:55:31.282	debug	Sending command with method: keepalive
            Black ThunderB 1 Antwort Letzte Antwort
            • T tony63526
              @Black-Thunder
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              smartfriends.0
              Black Thunder
              @tony63526 Probier es bitte mit 1.1.0-alpha.1. Damit sollten jetzt die Updates der Werte korrekt verarbeitet werden. Und bitte davon auch sicherheitshalber nochmal ein Log.
                tony63526
                @Black-Thunder
                Ja Mega :-)
                Jetzt klappt es.
                Vielen lieben dank nochmal. Wenn ich noch etwas testen soll,sag mir gerne bescheid.
                smartfriends.0
                1345019	2025-12-28 20:54:48.880	debug	Device 8566: Updated position = 100
                smartfriends.0
                1345019	2025-12-28 20:54:48.873	debug	Device value update: deviceID=8566, value=100
                smartfriends.0
                1345019	2025-12-28 20:54:48.873	debug	Updated timestamp to Wed Jan 28 2026 20:54:48 GMT+0100 (Central European Standard Time)
                smartfriends.0
                smartfriends.0
                1345019	2025-12-28 20:54:48.872	debug	Message received: newDeviceValue (code: 2)
                smartfriends.0
                1345019	2025-12-28 20:54:48.872	debug	Received data: { "currentTimestamp" : 20251228205448, "response" : { "counter" : 5548, "debugName" : "Kinderzimmer rollladen links:${Position}", "deviceID" : 8566, "masterDeviceID" : 11304, "value" : 100, "valueTarget" : 100, "valueTimestamp" : 20251228205448 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
                smartfriends.0
                1345019	2025-12-28 20:54:47.861	debug	Send JSON: {"command":"keepalive"}
                smartfriends.0
                1345019	2025-12-28 20:54:47.861	debug	Sending command with method: keepalive
                smartfriends.0
                1345019	2025-12-28 20:54:46.721	debug	Device value update: deviceID=14361, value=0
                smartfriends.0
                1345019	2025-12-28 20:54:46.721	debug	Updated timestamp to Wed Jan 28 2026 20:54:46 GMT+0100 (Central European Standard Time)
                smartfriends.0
                smartfriends.0
                1345019	2025-12-28 20:54:46.721	debug	Message received: newDeviceValue (code: 2)
                smartfriends.0
                1345019	2025-12-28 20:54:46.720	debug	Received data: { "currentTimestamp" : 20251228205446, "response" : { "counter" : 4392, "debugName" : "Kinderzimmer rollladen links:${Motor}", "deviceID" : 14361, "masterDeviceID" : 11304, "value" : 0, "valueTimestamp" : 20251228205446 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
                smartfriends.0
                1345019	2025-12-28 20:54:42.860	debug	Send JSON: {"command":"keepalive"}
                smartfriends.0
                1345019	2025-12-28 20:54:42.860	debug	Sending command with method: keepalive
                smartfriends.0
                1345019	2025-12-28 20:54:41.474	debug	Device value update: deviceID=14361, value=2
                smartfriends.0
                1345019	2025-12-28 20:54:41.474	debug	Updated timestamp to Wed Jan 28 2026 20:54:41 GMT+0100 (Central European Standard Time)
                smartfriends.0
                1345019	2025-12-28 20:54:41.473	debug	Updated timestamp to Wed Jan 28 2026 20:54:41 GMT+0100 (Central European Standard Time)
                smartfriends.0
                1345019	2025-12-28 20:54:41.473	debug	Message received: newDeviceValue (code: 2)
                smartfriends.0
                1345019	2025-12-28 20:54:41.473	debug	Received data: { "currentTimestamp" : 20251228205441, "response" : { "counter" : 4391, "debugName" : "Kinderzimmer rollladen links:${Motor}", "deviceID" : 14361, "masterDeviceID" : 11304, "value" : 2, "valueTimestamp" : 20251228205441 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
                smartfriends.0
                1345019	2025-12-28 20:54:37.859	debug	Send JSON: {"command":"keepalive"}
                smartfriends.0
                1345019	2025-12-28 20:54:37.859	debug	Sending command with method: keepalive
                smartfriends.0
                1345019	2025-12-28 20:54:37.355	debug	Device 8566: Updated position = 79
                smartfriends.0
                1345019	2025-12-28 20:54:37.351	debug	Device value update: deviceID=8566, value=79
                smartfriends.0
                1345019	2025-12-28 20:54:37.351	debug	Updated timestamp to Wed Jan 28 2026 20:54:37 GMT+0100 (Central European Standard Time)
                smartfriends.0
                smartfriends.0
                1345019	2025-12-28 20:54:37.351	debug	Message received: newDeviceValue (code: 2)
                smartfriends.0
                1345019	2025-12-28 20:54:37.351	debug	Received data: { "currentTimestamp" : 20251228205437, "response" : { "counter" : 5547, "debugName" : "Kinderzimmer rollladen links:${Position}", "deviceID" : 8566, "masterDeviceID" : 11304, "value" : 79, "valueTarget" : 79, "valueTimestamp" : 20251228205437 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
                smartfriends.0
                1345019	2025-12-28 20:54:35.198	debug	Device value update: deviceID=14361, value=0
                smartfriends.0
                1345019	2025-12-28 20:54:35.198	debug	Updated timestamp to Wed Jan 28 2026 20:54:35 GMT+0100 (Central European Standard Time)
                smartfriends.0
                smartfriends.0
                1345019	2025-12-28 20:54:35.198	debug	Message received: newDeviceValue (code: 2)
                smartfriends.0
                1345019	2025-12-28 20:54:35.197	debug	Received data: { "currentTimestamp" : 20251228205435, "response" : { "counter" : 4390, "debugName" : "Kinderzimmer rollladen links:${Motor}", "deviceID" : 14361, "masterDeviceID" : 11304, "value" : 0, "valueTimestamp" : 20251228205435 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
                smartfriends.0
                1345019	2025-12-28 20:54:32.859	debug	Send JSON: {"command":"keepalive"}
                smartfriends.0
                1345019	2025-12-28 20:54:32.858	debug	Sending command with method: keepalive
                smartfriends.0
                1345019	2025-12-28 20:54:30.235	debug	Device value update: deviceID=14361, value=1
                smartfriends.0
                1345019	2025-12-28 20:54:30.234	debug	Updated timestamp to Wed Jan 28 2026 20:54:30 GMT+0100 (Central European Standard Time)
                smartfriends.0
                smartfriends.0
                1345019	2025-12-28 20:54:30.234	debug	Message received: newDeviceValue (code: 2)
                smartfriends.0
                1345019	2025-12-28 20:54:30.234	debug	Received data: { "currentTimestamp" : 20251228205430, "response" : { "counter" : 4389, "debugName" : "Kinderzimmer rollladen links:${Motor}", "deviceID" : 14361, "masterDeviceID" : 11304, "value" : 1, "valueTimestamp" : 20251228205430 }, "responseCode" : 2, "responseMessage" : "newDeviceValue" }
                smartfriends.0
                1345019	2025-12-28 20:54:27.858	debug	Send JSON: {"command":"keepalive"}
                smartfriends.0
                1345019	2025-12-28 20:54:27.857	debug	Sending command with method: keepalive
                smartfriends.0
                1345019	2025-12-28 20:54:26.186	debug	Device 17243: Updated position = 100
                smartfriends.0
                1345019	2025-12-28 20:54:26.186	debug	Device 8566: Updated position = 100
                smartfriends.0
                1345019	2025-12-28 20:54:26.185	debug	Device 10331: Updated position = 100
                smartfriends.0
                1345019	2025-12-28 20:54:26.181	debug	Device 19154: Updated position = 100
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Received value for unknown device 18346, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Device value update: deviceID=18346, value=2
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Device value update: deviceID=17243, value=100
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Device value update: deviceID=19969, value=0
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Received value for unknown device 9988, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Device value update: deviceID=9988, value=2
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Device value update: deviceID=8566, value=100
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Device value update: deviceID=14361, value=0
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Received value for unknown device 17101, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Device value update: deviceID=17101, value=3
                smartfriends.0
                1345019	2025-12-28 20:54:26.130	debug	Device value update: deviceID=19986, value=0
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Received value for unknown device 4771, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Device value update: deviceID=4771, value=0
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Device value update: deviceID=10331, value=100
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Device value update: deviceID=5908, value=0
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Received value for unknown device 2654, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Device value update: deviceID=2654, value=3
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Device value update: deviceID=19154, value=100
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Device value update: deviceID=2072, value=0
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Received value for unknown device 11959, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Device value update: deviceID=11959, value=
                smartfriends.0
                1345019	2025-12-28 20:54:26.129	debug	Received value for unknown device 2711, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Device value update: deviceID=2711, value=2
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Received value for unknown device 7195, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Device value update: deviceID=7195, value=
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Received value for unknown device 17547, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Device value update: deviceID=17547, value=
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Received value for unknown device 9985, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Device value update: deviceID=9985, value=
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Received value for unknown device 5250, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Device value update: deviceID=5250, value=17:42
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Received value for unknown device 1367, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Device value update: deviceID=1367, value=16:16
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Received value for unknown device 14120, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Device value update: deviceID=14120, value=12:19
                smartfriends.0
                1345019	2025-12-28 20:54:26.128	debug	Received value for unknown device 733, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.127	debug	Device value update: deviceID=733, value=08:22
                smartfriends.0
                1345019	2025-12-28 20:54:26.127	debug	Received value for unknown device 5200, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.127	debug	Device value update: deviceID=5200, value=06:56
                smartfriends.0
                1345019	2025-12-28 20:54:26.127	debug	Received value for unknown device 13530, ignoring.
                smartfriends.0
                1345019	2025-12-28 20:54:26.127	debug	Device value update: deviceID=13530, value=${Dusk}
                smartfriends.0
                1345019	2025-12-28 20:54:26.127	info	Processed 25 device(s), created 4 master device(s).
                smartfriends.0
                1345019	2025-12-28 20:54:26.127	debug	Skipping device Hub (pushNotification) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:26.127	debug	Skipping device Smart friendsbox (pushNotification) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:26.126	debug	Created and saved device 17243 (${Position})
                smartfriends.0
                1345019	2025-12-28 20:54:26.125	debug	Created and saved device 19969 (${Motor})
                smartfriends.0
                1345019	2025-12-28 20:54:26.122	debug	Skipping device ${RssiDevice} (${SchellenbergRssi}) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:26.121	info	Device created: ${Position} (ID: 17243)
                smartfriends.0
                1345019	2025-12-28 20:54:26.121	debug	Created and saved device 17243 (${Position})
                smartfriends.0
                1345019	2025-12-28 20:54:26.119	info	Device created: ${Motor} (ID: 19969)
                smartfriends.0
                1345019	2025-12-28 20:54:26.119	debug	Created and saved device 19969 (${Motor})
                smartfriends.0
                1345019	2025-12-28 20:54:26.109	debug	Created and saved device 19154 (${Position})
                smartfriends.0
                1345019	2025-12-28 20:54:26.103	debug	Created and saved device 2072 (${Motor})
                smartfriends.0
                1345019	2025-12-28 20:54:26.084	debug	Skipping device ${RssiDevice} (${SchellenbergRssi}) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:26.084	info	Device created: ${Position} (ID: 19154)
                smartfriends.0
                1345019	2025-12-28 20:54:26.084	debug	Created and saved device 19154 (${Position})
                smartfriends.0
                1345019	2025-12-28 20:54:26.077	info	Device created: ${Motor} (ID: 2072)
                smartfriends.0
                1345019	2025-12-28 20:54:26.076	debug	Created and saved device 2072 (${Motor})
                smartfriends.0
                1345019	2025-12-28 20:54:26.074	debug	Skipping device ${DevicePushNotification} (pushNotificationChain) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:26.074	debug	Created and saved device 8566 (${Position})
                smartfriends.0
                1345019	2025-12-28 20:54:26.072	debug	Created and saved device 14361 (${Motor})
                smartfriends.0
                1345019	2025-12-28 20:54:26.064	debug	Skipping device ${RssiDevice} (${SchellenbergRssi}) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:26.063	info	Device created: ${Position} (ID: 8566)
                smartfriends.0
                1345019	2025-12-28 20:54:26.063	debug	Created and saved device 8566 (${Position})
                smartfriends.0
                1345019	2025-12-28 20:54:26.060	info	Device created: ${Motor} (ID: 14361)
                smartfriends.0
                1345019	2025-12-28 20:54:26.060	debug	Created and saved device 14361 (${Motor})
                smartfriends.0
                1345019	2025-12-28 20:54:26.057	debug	Skipping device ${ServerStatus} (${ServerStatus}) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:26.056	debug	Created and saved device 19986 (${SchellenbergBlind.Steps})
                smartfriends.0
                1345019	2025-12-28 20:54:26.050	debug	Created and saved device 10331 (${Position})
                smartfriends.0
                1345019	2025-12-28 20:54:26.044	debug	Created and saved device 5908 (${SchellenbergBlind})
                smartfriends.0
                1345019	2025-12-28 20:54:26.031	debug	Skipping device ${Status} (${SchellenbergRssi}) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:26.030	info	Device created: ${SchellenbergBlind.Steps} (ID: 19986)
                smartfriends.0
                1345019	2025-12-28 20:54:26.030	debug	Created and saved device 19986 (${SchellenbergBlind.Steps})
                smartfriends.0
                1345019	2025-12-28 20:54:26.020	debug	Skipping device ${SchellenbergBlind.StepConfiguration} (${SchellenbergBlind.StepConfiguration}) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:26.020	info	Device created: ${Position} (ID: 10331)
                smartfriends.0
                1345019	2025-12-28 20:54:26.020	debug	Created and saved device 10331 (${Position})
                smartfriends.0
                1345019	2025-12-28 20:54:26.017	info	Device created: ${SchellenbergBlind} (ID: 5908)
                smartfriends.0
                1345019	2025-12-28 20:54:26.017	debug	Created and saved device 5908 (${SchellenbergBlind})
                smartfriends.0
                1345019	2025-12-28 20:54:25.986	debug	Skipping device UZB Z-Wave USB Adapter (${ZwaveController}) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:25.986	debug	Skipping device ${Dusk} (AstrofunktionStr) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:25.985	debug	Skipping device ${Sunset} (AstrofunktionStr) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:25.985	debug	Skipping device ${SolarNoon} (AstrofunktionStr) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:25.985	debug	Skipping device ${Sunrise} (AstrofunktionStr) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:25.985	debug	Skipping device ${Dawn} (AstrofunktionStr) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:25.985	debug	Skipping device ${LastStatus} (Astrofunktion) – no definable control states found
                smartfriends.0
                1345019	2025-12-28 20:54:25.984	debug	Loaded 195 device definitions
                smartfriends.0
                1345019	2025-12-28 20:54:25.980	debug	Updated timestamp to Wed Jan 28 2026 20:54:22 GMT+0100 (Central European Standard Time)
                smartfriends.0
                smartfriends.0
                1345019	2025-12-28 20:54:25.980	debug	Message received: success (code: 1)
                smartfriends.0
                1345019	2025-12-28 20:54:22.857	debug	Send and receive JSON: {"command":"getAllNewInfos","timestamp":"0","compatibilityConfigurationVersion":"0","languageTranslationVersion":"0","sessionID":"qm5UVwHsfZsshcevJiVS"}
                smartfriends.0
                1345019	2025-12-28 20:54:22.857	info	Querying all devices...
                smartfriends.0
                1345019	2025-12-28 20:54:22.856	debug	Connection and login to gateway SmartFriendsBox successful.
                smartfriends.0
                1345019	2025-12-28 20:54:22.856	debug	Message received: success (code: 1)
                smartfriends.0
                1345019	2025-12-28 20:54:22.855	debug	Received data: { "response" : { "environment" : { }, "hardware" : "SmartFriendsBox", "localSHServerTime" : "20251228205422+0100", "macAddress" : "8c:19:2d:60:13:4c", "ownerSetup" : true, "pushNotificationUrl" : "https://live.ergyserver.de/eif/pn/registry/D19033/154039763342156", "remoteHome" : { "activated" : true, "status" : "notConnected", "url" : "rhlive.ergyserver.de" }, "sessionID" : "qm5UVwHsfZsshcevJiVS", "shsVersion" : "4.4.1-release", "user" : { "administratorRights" : false, "email" : "", "emailValidated" : false, "firstName" : "Tony", "gender" : "none", "id" : 35729, "lastName" : "Smarthome", "loginAllowedUntil" : 0, "mobileNo" : "", "name" : "Iobroker", "passwordValidity" : 0, "username" : "Iobroker", "usertype" : "person", "wrappers" : [ 36371, 36002 ] }, "webshopUrl" : "https://shpportal.com/webshop-smartfriends.aspx?MAC=154039763342156" }, "responseCode" : 1, "responseMessage" : "success" }
                smartfriends.0
                1345019	2025-12-28 20:54:22.799	debug	Send and receive JSON: {"command":"login","username":"Iobroker","digest":"r8vdCHQpgwjEfWfphCCqxNBfRg8=","cSymbol":"D19033i","shcVersion":"3.7.4","shApiVersion":"3.4"}
                smartfriends.0
                1345019	2025-12-28 20:54:22.798	debug	Message received: success (code: 1)
                smartfriends.0
                1345019	2025-12-28 20:54:22.798	debug	Received data: { "response" : { "majorApiVersion" : "3", "salt" : "r/lSKTWFpIgq12YaythI+EfILEg=", "sessionSalt" : "eUt86TG7HlB3P/8YnmAfjyaLOQu=" }, "responseCode" : 1, "responseMessage" : "success" }
                smartfriends.0
                1345019	2025-12-28 20:54:22.791	debug	Send and receive JSON: {"command":"helo","username":"Iobroker"}
                smartfriends.0
                1345019	2025-12-28 20:54:22.791	debug	Setup socket successfully
                smartfriends.0
                1345019	2025-12-28 20:54:22.791	debug	Setting up socket events...
                smartfriends.0
                1345019	2025-12-28 20:54:22.790	debug	Cert issuer organization: enexoma AG
                smartfriends.0
                1345019	2025-12-28 20:54:22.631	debug	Setting up socket...
                smartfriends.0
                1345019	2025-12-28 20:54:22.631	debug	IP: 192.168.178.65 - Port: 4300 - CSymbol: D19033i - SHCVersion: 3.7.4 - SHAPIVersion: 3.4
                smartfriends.0
                1345019	2025-12-28 20:54:22.630	info	Connecting to gateway and retrieving data...
                smartfriends.0
                1345019	2025-12-28 20:54:22.630	debug	Checking adapter settings...
                smartfriends.0
                1345019	2025-12-28 20:54:22.609	debug	Initializing objects...
                smartfriends.0
                1345019	2025-12-28 20:54:22.596	info	starting. Version 1.1.0-alpha.1 (non-npm: Black-Thunder/ioBroker.smartfriends#e6a79150cd7c00ac62259ad689a566663e2e6b5b) in /opt/iobroker/node_modules/iobroker.smartfriends, node: v22.21.0, js-controller: 7.0.7
                smartfriends.0
                1344877	2025-12-28 20:54:18.184	info	terminating
                smartfriends.0
                1344877	2025-12-28 20:54:17.683	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                smartfriends.0
                1344877	2025-12-28 20:54:17.683	info	terminating
                smartfriends.0
                1344877	2025-12-28 20:54:17.683	info	onUnload(): Cleaned everything up...
                smartfriends.0
                1344877	2025-12-28 20:54:17.681	info	Got terminate signal TERMINATE_YOURSELF
                • T tony63526
                  @Black-Thunder
                  Ja Mega :-)
                  Jetzt klappt es.
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  smartfriends.0
                  Black Thunder
                  @tony63526 Wunderbar, das klingt doch hervorragend. Danke dir fürs schnelle Testen 👍
                  • U Offline
                    U Offline
                    User089
                    Mir ist aufgefallen, dass ich bei einer Dimmbaren Lampe on, off und toggle triggern kann, aber sich kein % Wert oder ähnliches zum bestimmen der Helligkeit angeben kann. Vielleicht fällt Dir da noch was ein. VG
                    • U User089
                      Black Thunder
                      @User089 Da bräuchte ich dann bitte wieder ein Debug-Log vom Adapterstart und am besten auch die Device-ID einer solchen Lampe. Dann schau ich mir an, wie ich das integrieren kann.
                      • U Offline
                        U Offline
                        User089
                        id ist 14541.
                        log3.txt
                        • U User089
                          id ist 14541.
                          log3.txt
                          Black Thunder
                          @User089 Danke, probier's bitte mit v1.2.0-alpha.0. Nach dem Update den ganzen "devices"-Ordner einmalig löschen und den Adapter neustarten, ich habe ein bisschen was an der Erstellung der States geändert.
                          • U Offline
                            U Offline
                            User089
                            mit v1.2.0-alpha.0 ist jetzt die Option da einen Wert für die Helligkeit zu setzten. Super!
                            Der Ordner Baum ist aber sehr zerpfückt. Vielleicht kannst Du das noch Optimieren. Ist aber auch so zweckmässig.
                            Ich hab Dir mal einen Screenshoot vom Baum und ein Log angehängt.
                            log4.txt
                            • U User089
                              log4.txt
                              Black Thunder
                              @User089 sagte in [Neuer Adapter] smartfriends:
                              Sehr schön. Nur sicherheitshalber nachgefragt: Die Option ist nicht nur da, sondern funktioniert auch?
                              Ja, dass der Objektbaum etwas zerpflückt wirkt, ist leider im Grunde technisch bedingt. Aus Sicht der SmartFriendsBox besteht ein physisches Gerät (in deinem Screenshot die Deckenlampe) aus potenziell vielen Subgeräten (Dimmer, State, Switch...) mit jeweils eigener ID, die für die jeweilige Funktionalität zuständig sind. Von daher können unter einer übergeordneten ID (Master-Device-ID) viele weitere Device-IDs mit eigenen States hängen.
                              Daher bietet es sich umso mehr an, mit Aliasen zu arbeiten und die zerpflückten States dadurch wieder unter einem (virtuellen) Gerät zu bündeln.
                              • U Offline
                                U Offline
                                User089
                                Die Option funktioniert bestens!
                                • H Offline
                                  HeiLuRa
                                  Hallo Black Thunder, vielen Danke erstmal für den tollen Adapter. Ich habe bisher immer mit der Version von LoPablo gearbeitet.
                                  Leider habe ich ein Problem Ich versuche die Schalter (unter ZigBee) ein- bzw. auszuschalten, indem ich diese alle 15s unter "setState(...)" ansprechen, aber funktioniert dieses nicht. Im Protokoll bekomme ich folgende Meldung: (Version: 1.2.0-alpha.0)
                                  2026-01-07 14:50:03.853 warn Object of state "smartfriends.0.devices.6597.13631.control" is missing the required property "common.type"
                                  2026-01-07 14:50:19.139 warn Object of state "smartfriends.0.devices.6597.13631.control" is missing the required property "common.type"
                                  2026-01-07 14:50:34.270 warn Object of state "smartfriends.0.devices.6597.13631.control" is missing the required property "common.type"
                                  2026-01-07 14:50:49.309 warn Object of state "smartfriends.0.devices.6597.13631.control" is missing the required property "common.type"
                                  Habe ich etwas falsch gemacht?
                                  • H HeiLuRa
                                    Black Thunder
                                    schrieb am zuletzt editiert von Black Thunder
                                    @HeiLuRa Sind denn unter "smartfriends.0.devices.6597.13631.control" überhaupt States angelegt worden? Da müsste es sowas wie "on", "off" und "toggle" geben. "control" ist ja erstmal nur der übergeordnete Channel und ist selbst nicht schaltbar.
                                    Welche Version verwendest du? Nach einem Upgrade auf die aktuelle 1.2.0-alpha.0 solltest du einmalig den Objektbaum löschen, damit er korrekt neu angelegt werden kann.
                                    Ansonsten bitte ein vollständiges Debug-Log nach Adapterstart hochladen.
                                    H 1 Antwort Letzte Antwort
                                      icon
                                      Aktuelle Test Version 2.0.0
                                      Veröffentlichungsdatum 01.06.2026
                                      Github Link https://github.com/Black-Thunder/ioBroker.smartfriends
                                      ich möchte euch heute meinen neuen Adapter smartfriends vorstellen.
                                      Der Adapter integriert die SmartFriendsBox (bzw. kompatible Gateways) sowie die dazugehörigen Geräte von ABUS, Paulmann, Schellenberg und STEINEL in ioBroker. Dabei wird eine direkte lokale Verbindung zum Gateway aufgebaut – ganz ohne Nutzung der offiziellen Cloud.
                                      Der aktuelle Funktionsumfang sollte bereits recht stabil sein, da ich den Adapter schon seit einiger Zeit privat im Einsatz habe. Aufgrund der zwischenzeitlichen Insolvenz der Betreiber der offiziellen Cloud-/Remote-Home-Dienste habe ich mich entschlossen, den Adapter öffentlich zur Verfügung zu stellen, damit Betroffene ihre Geräte weiterhin smart steuern können.
                                      Der Adapter legt basierend auf den Daten vom Gateway automatisch die passenden States an. Grundsätzlich sollten daher alle Gerätetypen unterstützt werden.
                                      Falls States dennoch fehlerhaft sind, komplett fehlen oder sonstige Probleme auftauchen, bitte bei Anfragen immer ein vollständiges Debug-Log direkt ab Start des Adapters zur Verfügung stellen. Eine Anleitung dafür ist weiter unten zu finden.
                                      Hier könnt ihr euch über alle Fragen, Probleme und Hinweise zur Nutzung des Adapters austauschen. Konstruktives Feedback jeglicher Art ist immer willkommen.
                                      Die aktuelle Dokumentation findet ihr unter folgenden Links:
                                      • Deutsche Beschreibung
                                      • English Description
                                      Das Changelog ist immer an dieser Stelle zu finden.
                                      Versionshinweise
                                      • Nach einem Upgrade auf >=1.2.0-alpha.0, >=1.3.0-alpha.0 und >=1.3.3 sollte einmalig der Objektbaum gelöscht werden, damit er korrekt neu angelegt werden kann
                                      • Versionen =>2.0 erfordern mindestens Node.js 22
                                      Installationshinweise
                                      Inzwischen ist der Adapter regulär im latest und stable Repository gelistet. Bitte daher nur noch Alpha-Versionen von npm installieren.
                                      Aus Latest (Beta-Versionen)
                                      • 'Aktiver Verwahrungsort' in den iobroker.admin-Einstellungen muss auf 'Beta (latest)' stehen
                                      • Unter 'Adapter' nach 'smartfriends' filtern und ganz rechts auf das '+'-Symbol ('Instanz hinzufügen') klicken.
                                      • Unter 'Instanzen' die entsprechenden Adapter-Einstellungen eintragen.
                                      Von npm (Alpha-Versionen)
                                      • Expertenansicht des Admin-Adapters aktivieren
                                      • Unter 'Adapter' auf das GitHub-Icon ('Installieren aus eigener URL') klicken.
                                      • 'Benutzerdefiniert' auswählen, "iobroker.smartfriends@next" eingeben und auf 'Installieren' klicken.
                                      • Dann unter 'Adapter' den smartfriends-Adapter filtern und ganz rechts auf das '+'-Symbol ('Instanz hinzufügen') klicken.
                                      Aus Github (Entwicklungsstand)
                                      Bitte von hier nur nach Aufforderung installieren, da dies u.U. ein instabiler Entwicklungsstand sein kann!
                                      • 'Benutzerdefiniert' auswählen, als URL "https://github.com/Black-Thunder/ioBroker.smartfriends" eingeben und auf 'Installieren' klicken.
                                      Erzeugen eines Debug-Logs
                                      Hier eine kurze Anleitung, wie man das benötigte Debug-Log erstellt:
                                      1. In der Admin-GUI unter Instanzen die entsprechende smartfriends.X-Instanz aufklappen
                                      2. Dort das standardmäßig auf Info eingestellte Loglevel auf Debug ändern. Der Adapter startet automatisch neu.
                                      3. Solange warten, bis der Adapterneustart abgeschlossen und die Fehlersituation aufgetreten ist. Dann in der Admin-GUI über Protokolle -> Log herunterladen -> aktuelles Datum / current das Log anzeigen bzw. herunterladen und den relevanten Teil ab Adapterstart zur Verfügung stellen.
                                      4. Am Schluss das Loglevel wieder zurück auf Info stellen. Ansonsten werden dauerhaft sehr viele Einträge ins Log geschrieben.
                                      Viele Grüße
                                      Dominik
                                      W Offline
                                      W Offline
                                      wak
                                      @Black-Thunder
                                      Hallo Dominik,
                                      ich versuche gerade als "ioBroker-Beginner" Deinen SmartFriends Adapter zum Laufen zu bringen, scheitere aber leider schon am Anfang.
                                      Der Adapter läuft im ioBroker (wird als Status grün angezeigt), es werden aber keine Objekte aus der Smart Friends Box geladen und im Log werden Fehler gesetzt ?!
                                      Hast Du einen Tipp ?
                                      Mario
                                      MOD-Edit
                                      Link entfernt - Inhalt s. Post #34
                                      Samson71S Black ThunderB 2 Antworten Letzte Antwort
                                      • W wak
                                        @Black-Thunder
                                        Hallo Dominik,
                                        Mario
                                        MOD-Edit
                                        Samson71S Offline
                                        Samson71S Offline
                                        Samson71
                                        @wak
                                        Bitte entferne den Link (was immer Du darin zeigen willst) bzw. pack dessen Inhalt lesbar direkt in den Post.
                                        Markus
                                        Bitte beachten:
                                        • W wak
                                          @Black-Thunder
                                          Hallo Dominik,
                                          Mario
                                          MOD-Edit
                                          Black Thunder
                                          @wak Hallo Mario, auch hier bitte ein vollständiges Debug-Log (im Admin Expertenmodus aktivieren -> Instanzen -> smartfriends.0 aufklappen -> Log-Stufe von "Info" auf "Debug" stellen).
                                          So wie es aber bisher aussieht, schlägt einfach die Verbindung zur SmartFriendsBox fehl (Connection failed: "timeout"). Stimmt die IP-Adresse sicher, die im Adapter konfiguriert ist?
                                          W 1 Antwort Letzte Antwort
