    6.5k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.4m Aufrufe 260 Beobachtet
  • T Nicht stören
    T Nicht stören
    ticaki
    #7834
    Das letzte Log sieht aus als wenn es jetzt gehen würde.
    Spenden
    • T timredlich
      00:00:00.003 HDW: ESP32-D0WD-V3 v3.0 (PSRAM)
      00:00:00.035 UFS: FlashFS mounted with 288 kB free
      00:00:00.045 CFG: Loaded from File, Count 1108
      00:00:00.052 QPC: Count 1
      00:00:00.112 BRY: Berry initialized, RAM used 3766 bytes
      00:00:00.132 Project tasmota - Tasmota Version 15.2.0(release-nspanel)-3.3.4(2025-12-12T11:01:02)
      00:00:00.330 NXP: Initializing Driver
      00:00:00.337 BRY: Successfully loaded 'autoexec.be'
      00:00:01.199 WIF: Connecting to AP1 Dreamnet Channel 1 BSSId 9C:C7:A6:5C:51:11 in mode HT40 as NSPanel-2488...
      00:00:03.858 WIF: Connected
      11:25:40.073 HTP: Web server active on NSPanel-2488 with IP address 192.168.2.22
      11:25:41.068 MQT: Attempting connection...
      11:25:41.101 MQT: Connected
      11:25:41.105 MQT: SmartHome/NSPanel/tele/LWT = Online (retained)
      11:25:41.107 MQT: SmartHome/NSPanel/cmnd/POWER =
      11:25:41.112 MQT: SmartHome/NSPanel/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.2.0(release-nspanel)","FallbackTopic":"cmnd/NSPanel_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
      11:25:41.127 MQT: SmartHome/NSPanel/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-2488","IPAddress":"192.168.2.22","IP6Global":"","IP6Local":"fe80::3ee9:eff:fe85:e9b8%st1"}}
      11:25:41.156 MQT: SmartHome/NSPanel/tele/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":145}}
      11:25:41.160 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
      11:25:41.172 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
      11:25:41.173 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER2":"OFF"}
      11:25:41.175 MQT: SmartHome/NSPanel/stat/POWER2 = OFF
      11:25:41.458 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
      11:25:41.463 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
      11:25:41.537 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
      11:25:41.559 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
      11:25:41.564 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
      11:25:41.626 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
      11:25:41.658 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
      11:25:41.660 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
      11:25:41.731 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
      11:25:43.285 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
      11:25:43.289 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
      11:25:43.380 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
      11:25:43.953 QPC: Reset
      11:25:46.064 MQT: SmartHome/NSPanel/tele/STATE = {"Time":"2025-12-26T11:25:46","Uptime":"0T00:00:10","UptimeSec":10,"Heap":128,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":37,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":220},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Dreamnet","BSSId":"9C:C7:A6:5C:51:11","Channel":1,"Mode":"HT40","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"NSPanel-2488","IPAddress":"192.168.2.22"}
      11:25:46.115 MQT: SmartHome/NSPanel/tele/SENSOR = {"Time":"2025-12-26T11:25:46","Switch1":"OFF","Switch2":"OFF","ANALOG":{"Temperature1":-0.2},"TempUnit":"C"}
      11:25:59.690 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
      11:26:59.695 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
      11:27:59.484 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
      11:28:59.474 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
      ilovegymI Offline
      ilovegymI Offline
      ilovegym
      #7835
      @timredlich sagte in SONOFF NSPanel mit Lovelace UI:
      Genau, so soll es aussehen, MQTT connected und LWT online - damit ist die Verbindung da, und das Panel sollte wieder funktionieren..zumindest steht die Kommunikation zum Server jetzt :)
        timredlich
        #7836
        JA , aber leider steht immer noch im Display " Waiting for Content" . Strom weg, Tasmota neustart, IoBroker Neustart. Script neustart. Nix funktioniert.
        • T timredlich
          TT-Tom
          #7837
          @timredlich
          Pack deine Log Meldungen bitte in die Code Tags. das liest sich besser.
          so sieht der richtige Start aus.
          00:00:00.002 HDW: ESP32-D0WD-V3 v3.0
          00:00:00.042 UFS: FlashFS mounted with 272 kB free
          00:00:00.055 CFG: Loaded from File, Anzahl 627
          00:00:00.064 QPC: Count 1
          00:00:00.113 BRY: Berry initialized, RAM used 3493 bytes
          00:00:00.134 Projekt tasmota - NSPanelFlur Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16)
          00:00:00.164 TAP: Loaded Tasmota App '/Partition_Wizard.tapp'
          00:00:00.749 NXP: Initializing Driver
          00:00:00.753 BRY: Successfully loaded 'autoexec.be'
          00:00:01.667 WIF: verbinden mit AP1 TomTom24 Channel 1 BSSId B0:F2:08:43:C1:5B in Modus HT40 als NSPanelFlur...
          00:00:04.304 WIF: verbunden
          00:00:04.510 HTP: Web server active on NSPanelFlur with IP address 192.168.178.102
          12:46:44.126 RSL: RESULT = {"CustomRecv":"event,startup,61,eu,5.1.0"}
          12:46:44.665 MQT: Verbindungsversuch…
          12:46:44.687 MQT: verbunden
          12:46:44.690 MQT: SmartHome/NSPanelFlur/tele/LWT = Online (beibehalten)
          12:46:44.692 MQT: SmartHome/NSPanelFlur/cmnd/POWER =
          12:46:44.695 MQT: SmartHome/NSPanelFlur/tele/INFO1 = {"Info1":{"Module":"NSPanelFlur","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/NSPanelFlur_fb/","GroupTopic":"SmartHome/NSPanelFlur/cmnd/"}}
          12:46:44.723 MQT: SmartHome/NSPanelFlur/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanelFlur","IPAddress":"192.168.178.102","IP6Global":"","IP6Local":"fe80::c249:efff:fed3:b06c%st1"}}
          12:46:44.742 MQT: SmartHome/NSPanelFlur/tele/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":187}}
          12:46:44.749 MQT: SmartHome/NSPanelFlur/stat/RESULT = {"POWER1":"OFF"}
          12:46:44.750 MQT: SmartHome/NSPanelFlur/stat/POWER1 = OFF
          12:46:44.761 MQT: SmartHome/NSPanelFlur/stat/RESULT = {"POWER2":"OFF"}
          12:46:44.763 MQT: SmartHome/NSPanelFlur/stat/POWER2 = OFF
          12:46:44.016 MQT: SmartHome/NSPanelFlur/stat/RESULT = {"CustomSend":"Done"}
          12:46:44.024 RUL: CUSTOMSEND performs 'RuleTimer3 120'
          12:46:44.029 MQT: SmartHome/NSPanelFlur/stat/RESULT = {"T1":0,"T2":0,"T3":120,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
          12:46:44.416 MQT: SmartHome/NSPanelFlur/tele/RESULT = {"CustomRecv":"event,startup,61,eu,5.1.0"}
          12:46:45.974 QPC: Reset
          12:46:47.951 MQT: SmartHome/NSPanelFlur/tele/STATE = {"Time":"2025-12-26T12:46:47","Uptime":"0T00:00:08","UptimeSec":8,"Heap":118,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":27,"MqttCount":1,"Berry":{"HeapUsed":33,"Objects":448},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"TomTom24","BSSId":"B0:F2:08:43:C1:5B","Channel":1,"Mode":"HT40","RSSI":92,"Signal":-54,"LinkCount":1,"Downtime":"0T00:00:04"}}
          12:46:47.994 MQT: SmartHome/NSPanelFlur/tele/SENSOR = {"Time":"2025-12-26T12:46:47","ANALOG":{"Temperature1":20.7},"ESP32":{"Temperature":42.2},"TempUnit":"C"}
          12:46:50.381 MQT: SmartHome/NSPanelFlur/tele/RESULT = {"CustomRecv":"event,startup,61,eu,5.1.0"}
          12:46:56.369 MQT: SmartHome/NSPanelFlur/tele/RESULT = {"CustomRecv":"event,startup,61,eu,5.1.0"}
          12:47:02.528 MQT: SmartHome/NSPanelFlur/tele/RESULT = {"CustomRecv":"event,startup,61,eu,5.1.0"}
          es diese Sequnce
          12:48:27.168 MQT: SmartHome/NSPanelFlur/tele/RESULT = {"CustomRecv":"event,startup,61,eu,5.1.0"}
          darauf warte das Script zum Start.
          Stopp das Script nochmal und lass das Panel neu starten.
          zeig mal nochmal den Start.
          Gruß Tom
          Public Transport
          NSPanel Adapter Wiki
            timredlich
            schrieb am zuletzt editiert von timredlich
            #7838
            00:00:00.061 UFS: FlashFS mounted with 288 kB free
            00:00:00.077 CFG: Loaded from File, Count 1112
            00:00:00.084 QPC: Count 1
            00:00:00.159 BRY: Berry initialized, RAM used 3766 bytes
            00:00:00.182 Project tasmota - Tasmota Version 15.2.0(release-nspanel)-3.3.4(2025-12-12T11:01:02)
            00:00:00.446 NXP: Initializing Driver
            00:00:00.452 BRY: Successfully loaded 'autoexec.be'
            00:00:01.177 WIF: Connecting to AP1 Dreamnet Channel 1 BSSId 9C:C7:A6:5C:51:11 in mode HT40 as NSPanel-2488...
            00:00:03.829 WIF: Connected
            13:12:54.049 HTP: Web server active on NSPanel-2488 with IP address 192.168.2.22
            13:12:55.049 MQT: Attempting connection...
            13:12:55.079 MQT: Connected
            13:12:55.084 MQT: SmartHome/NSPanel/tele/LWT = Online (retained)
            13:12:55.086 MQT: SmartHome/NSPanel/cmnd/POWER =
            13:12:55.093 MQT: SmartHome/NSPanel/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.2.0(release-nspanel)","FallbackTopic":"cmnd/NSPanel_fb/","GroupTopic":"SmartHome/tasmotas/cmnd/"}}
            13:12:55.108 MQT: SmartHome/NSPanel/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanel-2488","IPAddress":"192.168.2.22","IP6Global":"","IP6Local":"fe80::3ee9:eff:fe85:e9b8%st1"}}
            13:12:55.122 MQT: SmartHome/NSPanel/tele/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":149}}
            13:12:55.137 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
            13:12:55.144 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
            13:12:55.147 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER2":"OFF"}
            13:12:55.148 MQT: SmartHome/NSPanel/stat/POWER2 = OFF
            13:12:55.432 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
            13:12:55.437 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
            13:12:55.508 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:12:55.534 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
            13:12:55.538 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
            13:12:55.597 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:12:55.632 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
            13:12:55.634 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
            13:12:55.700 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:12:57.288 MQT: SmartHome/NSPanel/stat/RESULT = {"POWER1":"OFF"}
            13:12:57.291 MQT: SmartHome/NSPanel/stat/POWER1 = OFF
            13:12:57.357 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:12:57.939 QPC: Reset
            13:12:59.961 MQT: SmartHome/NSPanel/tele/STATE = {"Time":"2025-12-26T13:12:59","Uptime":"0T00:00:09","UptimeSec":9,"Heap":130,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":220},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Dreamnet","BSSId":"9C:C7:A6:5C:51:11","Channel":1,"Mode":"HT40","RSSI":84,"Signal":-58,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"NSPanel-2488","IPAddress":"192.168.2.22"}
            13:13:00.012 MQT: SmartHome/NSPanel/tele/SENSOR = {"Time":"2025-12-26T13:12:59","Switch1":"OFF","Switch2":"OFF","ANALOG":{"Temperature1":-0.0},"TempUnit":"C"}
            13:13:49.734 MQT: SmartHome/NSPanel/stat/RESULT = {"DeviceName":"Tasmota"}
            13:13:49.837 MQT: SmartHome/NSPanel/stat/STATUS0 = {"Status":{"Module":0,"DeviceName":"Tasmota","FriendlyName":["Tasmota",""],"Topic":"NSPanel","ButtonTopic":"0","Power":"00","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[2,2,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-nspanel.bin","RestartReason":"Vbat power on reset","Uptime":"0T00:00:59","StartupUTC":"2025-12-26T12:12:50","Sleep":50,"CfgHolder":4617,"BootCount":149,"BCResetTime":"2023-09-19T11:22:59","SaveCount":1113},"StatusFWR":{"Version":"15.2.0(release-nspanel)","BuildDateTime":"2025-12-12T11:01:02","Core":"3.3.4","SDK":"5.3.4.251205","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.0","CR":"431/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["Dreamnet",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","00006000","00004000","00000000"]},"StatusMEM":{"ProgramSize":2082,"Free":797,"Heap":121,"StackLowMark":3,"PsrMax":2048,"PsrFree":2025,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["0809","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"NSPanel-2488","IPAddress":"192.168.2.22","Gateway":"192.168.0.1","Subnetmask":"255.255.252.0","DNSServer1":"192.168.0.1","DNSServer2":"fd10:b295:164b:0:3e37:12ff:fe21:7ba6","Mac":"3C:E9:0E:85:E9:B8","IP6Global":"fdcc:f120:56a7:0:3ee9:eff:fe85:e9b8","IP6Local":"fe80::3ee9:eff:fe85:e9b8%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.0.1","DNSServer2":"fd10:b295:164b:0:3e37:12ff:fe21:7ba6","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0},"StatusMQT":{"MqttHost":"192.168.0.12","MqttPort":1887,"MqttClientMask":"NSPanel","MqttClient":"NSPanel","MqttUser":"mqttredlich","MqttCount":1,"MqttTLS":0,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2025-12-26T12:13:49Z","Local":"2025-12-26T13:13:49","StartDST":"2025-03-30T02:00:00","EndDST":"2025-10-26T03:00:00","Timezone":"+01:00","Sunrise":"08:43","Sunset":"16:58"},"StatusSNS":{"Time":"2025-12-26T13:13:49","Switch1":"OFF","Switch2":"OFF","ANALOG":{"Temperature1":0.0},"TempUnit":"C"},"StatusSTS":{"Time":"2025-12-26T13:13:49","Uptime":"0T00:00:59","UptimeSec":59,"Heap":119,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":24,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":220},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Dreamnet","BSSId":"9C:C7:A6:5C:51:11","Channel":1,"Mode":"HT40","RSSI":86,"Signal":-57,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"NSPanel-2488","IPAddress":"192.168.2.22"}}
            13:13:50.258 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:13:50.394 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:13:50.439 MQT: SmartHome/NSPanel/tele/RESULT = {"nlui_driver_version":"10"}
            13:13:50.518 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:13:50.568 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:13:50.614 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:13:50.676 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
            13:13:59.378 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
              timredlich
              #7839
              Ich habe auch schon versucht die Firmware neu zu Flashen in der Console mit "FlashNextion http://nspanel.pky.eu/lui-release.tft" es gibt aber darauf keine Flash aktion.
              13:18:09.211 CMD: FlashNextion http://nspanel.pky.eu/lui-release.tft
              13:18:09.230 MQT: SmartHome/NSPanel/stat/RESULT = {"FlashNextion":"Done"}
              13:18:09.276 FLH: host: nspanel.pky.eu, port: 80, get: /lui-release.tft
              13:18:09.729 MQT: SmartHome/NSPanel/stat/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
              13:18:09.747 MQT: SmartHome/NSPanel/stat/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
              13:18:59.402 MQT: SmartHome/NSPanel/stat/RESULT = {"CustomSend":"Done"}
              • T timredlich
                TT-Tom
                #7840
                @timredlich
                Prüfe bitte den Berry Driver noch einmal, ggf neu schreiben.
                https://github.com/joBr99/nspanel-lovelace-ui/wiki/iobroker---Basisinstallation#3-berry-treiber-installieren
                Edit:
                flashpfad: FlashNextionAdv0 http://nspanel.de/nspanel-v5.0.2.tft
                Gruß Tom
                Public Transport
                  timredlich
                  #7841
                  Habe den Berry Driver neu installiert. Neu gestartet . Keine Verbesserung. Versucht den tft Treiber neu zu flashen. Keine reaktion. Habe dann ein Downgrade auf tasmota 12.1.1 gemacht. Berry Driver neu installiert. Versucht ein Downgrade des TFT Treibers auf 5.0.0 zu machen. keine Reaktion, kein Download, nichts. Gibt es die möglichkeit das Gerät komplett zu Reseten?
                  14:04:23.699 CMD: FlashNextionAdv0 http://nspanel.de/nspanel-v5.0.0.tft
                  14:04:23.715 MQT: SmartHome/NSPanel/stat/RESULT = {"FlashNextionAdv":"Done"}
                  14:04:23.772 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.0.tft
                  • ilovegymI Offline
                    ilovegymI Offline
                    ilovegym
                    #7842
                    gib mal in der console ein "reset 4" - da wird alles, bis auf die Netzwerksettings, zurueck gesetzt, danach nochmal von vorne anfangen.. ist aber schon komisch..
                      timredlich
                      #7843
                      So ich glaub jetzt ist das Panel ganz kaputt. Ich habe einen "Reset 4" gemacht, dazu nochmal die Reset Taste am Gerät selbst gedrückt. Danach blieb das Display Schwarz. Tasmota ist immer noch zu erreichen, also hab ich alles neu eingerichtet und habe erneut versucht den Display Treiber zu flashen. Aber dies macht er wieder nicht. Und wie gesagt, Display bleibt schwarz. Ich glaube ich hab hier nen neuen Briefbeschwerer.
                      00:00:00.002 HDW: ESP32-D0WD-V3 v3.0 (PSRAM)
                      00:00:00.021 UFS: FlashFS mounted with 288 kB free
                      00:00:00.028 CFG: Loaded from File, Count 14
                      00:00:00.035 QPC: Count 3
                      00:00:00.085 BRY: Berry initialized, RAM used 3766 bytes
                      00:00:00.100 Project tasmota - Tasmota Version 15.2.0(release-nspanel)-3.3.4(2025-12-12T11:01:02)
                      00:00:00.261 NXP: Initializing Driver
                      00:00:00.268 BRY: Successfully loaded 'autoexec.be'
                      00:00:02.000 WIF: Connecting to AP1 Dreamnet Channel 1 BSSId 9C:C7:A6:5C:51:11 in mode HT40 as tasmota-85E9B8-2488...
                      00:00:04.852 WIF: Connected
                      15:38:47.076 HTP: Web server active on tasmota-85E9B8-2488 with IP address 192.168.3.33
                      15:38:48.087 MQT: Attempting connection...
                      15:38:48.537 MQT: Connected
                      15:38:48.541 MQT: tele/tasmota_85E9B8/LWT = Online (retained)
                      15:38:48.543 MQT: cmnd/tasmota_85E9B8/POWER =
                      15:38:48.548 MQT: tele/tasmota_85E9B8/INFO1 = {"Info1":{"Module":"ESP32-DevKit","Version":"15.2.0(release-nspanel)","FallbackTopic":"cmnd/DVES_85E9B8_fb/","GroupTopic":"cmnd/tasmotas/"}}
                      15:38:48.563 MQT: tele/tasmota_85E9B8/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-85E9B8-2488","IPAddress":"192.168.3.33","IP6Global":"2a03:7500:704:8c00:3ee9:eff:fe85:e9b8","IP6Local":"fe80::3ee9:eff:fe85:e9b8%st1"}}
                      15:38:48.587 MQT: tele/tasmota_85E9B8/INFO3 = {"Info3":{"RestartReason":"Vbat power on reset","BootCount":8}}
                      15:38:49.413 MQT: stat/tasmota_85E9B8/RESULT = {"Command":"Error","Input":"POWER NaN"}
                      15:38:49.487 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      15:38:49.513 MQT: stat/tasmota_85E9B8/RESULT = {"Command":"Error","Input":"POWER NaN"}
                      15:38:49.578 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      15:38:49.613 MQT: stat/tasmota_85E9B8/RESULT = {"Command":"Error","Input":"POWER NaN"}
                      15:38:49.684 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      15:38:49.964 QPC: Reset
                      15:38:50.665 MQT: stat/tasmota_85E9B8/RESULT = {"Command":"Error","Input":"POWER NaN"}
                      15:38:50.783 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      15:38:52.989 MQT: tele/tasmota_85E9B8/STATE = {"Time":"2025-12-26T15:38:52","Uptime":"0T00:00:10","UptimeSec":10,"Heap":130,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":220},"Wifi":{"AP":1,"SSId":"Dreamnet","BSSId":"9C:C7:A6:5C:51:11","Channel":1,"Mode":"HT40","RSSI":92,"Signal":-54,"LinkCount":1,"Downtime":"0T00:00:04"},"Hostname":"tasmota-85E9B8-2488","IPAddress":"192.168.3.33"}
                      15:38:59.226 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      15:39:54.517 CMD: FlashNextionAdv0 http://nspanel.de/nspanel-v5.0.2.tft
                      15:39:54.530 MQT: stat/tasmota_85E9B8/RESULT = {"FlashNextionAdv":"Done"}
                      15:39:54.571 FLH: host: nspanel.de, port: 80, get: /nspanel-v5.0.2.tft
                      15:39:55.534 MQT: stat/tasmota_85E9B8/RESULT = {"T1":0,"T2":0,"T3":0,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}
                      15:39:55.543 MQT: stat/tasmota_85E9B8/RESULT = {"Rule3":{"State":"OFF","Once":"OFF","StopOnError":"OFF","Length":0,"Free":511,"Rules":""}}
                      15:39:59.216 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      15:40:59.300 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      15:41:59.277 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      15:42:59.358 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      15:43:52.980 MQT: tele/tasmota_85E9B8/STATE = {"Time":"2025-12-26T15:43:52","Uptime":"0T00:05:10","UptimeSec":310,"Heap":119,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Berry":{"HeapUsed":22,"Objects":225},"Wifi":{"AP":1,"SSId":"Dreamnet","BSSId":"9C:C7:A6:5C:51:11","Channel":1,"Mode":"HT40","RSSI":92,"Signal":-54,"LinkCount":1,"Downtime":"0T00:00:04"},"Hostname":"tasmota-85E9B8-2488","IPAddress":"192.168.3.33"}
                      15:43:59.303 MQT: stat/tasmota_85E9B8/RESULT = {"CustomSend":"Done"}
                      • ilovegymI Offline
                        ilovegymI Offline
                        ilovegym
                        #7844
                        Da fehlt einfach nur der berry treiber und die firmware vom display.. hast du das panel dann wieder neu mit den options gesetzt damit es weiss, dass es auch nspanel ist? Bist du das Tutorial von Anfang an durchgegangen?
                        • T timredlich
                          T Nicht stören
                          T Nicht stören
                          ticaki
                          #7845
                          @timredlich
                          Könntest du deine Handlung auf das beschränken was empfohlen wird ohne auf z.B. eine fehlerhafte Tasmotaversion downzugraden... ist nur ein Vorschlag...
                          Es gibt ein Kommunikationsproblem - heißt Berry ist nicht da oder MQTT-Pfad im Skript ist falsch, oder Skript ist nicht aktiv.
                          EDIT: wobei Berry da sein müsste, von dem kommt das customsend: done im log
                          EDIT2:
                          Wobei das log vom Skript auf debug (skript auf debug stellen, nicht javascript adapter) helfen könnte das problem zu erkennen.
                          Spenden
                          • T ticaki
                            @timredlich
                            EDIT2:
                            TT-Tom
                            #7846
                            @ticaki
                            was mir fehlt ist die Start-Sequenz.
                            die kommt vom TFT, ohne die gehts nicht weiter.
                            Gruß Tom
                            Public Transport
                            • T TT-Tom
                              @ticaki
                              T Nicht stören
                              T Nicht stören
                              ticaki
                              #7847
                              @TT-Tom
                              Hm nachdem ich mir das log mal angesehen anstatt überflogen habe fällt mir
                              auf
                              Wieso ist da ein FlashNextionAdv0 als kommando
                              und wieso Power NaN
                              Der nan könnte durch fehlendes Template sein.
                              Spenden
                              • T ticaki
                                @TT-Tom
                                auf
                                und wieso Power NaN
                                TT-Tom
                                #7848
                                @ticaki
                                ich vermute mal, alles versucht ohne die Reihenfolge einzuhalten. Wie @ilovegym schon schrieb, mal einfach nach Anleitung neu installieren.
                                warten wir auf die Reaktion von @timredlich
                                Gruß Tom
                                Public Transport
                                  timredlich
                                  #7849
                                  OK morgen probiere ich es nochmal. Melde mich
                                    timredlich
                                    #7850
                                    Guten Morgen, tatsächlich hatte ich nach dem Reset vergessen das Template einzutragen. Dies habe ich nachgeholt. autoexec.de habe ich danach nochmal neu installiert. Habe dann versucht zu Flashen. Ging wieder nicht. Die TFT Firmware wurde anscheinend auch nicht beim Reset gelöscht und ist noch vorhanden. Das mein Display Schwarz war, war auf einen Wackelkontakt am Display zurückzuführen. Einmal anpressen hat hier wieder zum gewohnten "Waiting for Content" geführt. Ich hab die Pfade im Skript nochmal überprüft. müsste so stimmen. Im IObroker im Datenpunkt CustomSend wird die aktuelle Uhrzeit übergeben.
                                    00:00:00.038 UFS: FlashFS mounted with 288 kB free
                                    00:00:00.051 CFG: Loaded from File, Count 39
                                    00:00:00.058 QPC: Count 1
                                    00:00:00.120 BRY: Berry initialized, RAM used 3766 bytes
                                    00:00:00.140 Project tasmota - Tasmota Version 15.2.0(release-nspanel)-3.3.4(2025-12-12T11:01:02)
                                    00:00:00.345 NXP: Initializing Driver
                                    00:00:00.352 BRY: Successfully loaded 'autoexec.be'
                                    00:00:01.075 WIF: Connecting to AP1 Dreamnet Channel 1 BSSId 9C:C7:A6:5C:51:11 in mode HT40 as NSPanelK-che...
                                    00:00:03.727 WIF: Connected
                                    08:38:44.026 HTP: Web server active on NSPanelK-che with IP address 192.168.3.33
                                    08:38:44.938 MQT: Attempting connection...
                                    08:38:44.967 MQT: Connected
                                    08:38:44.971 MQT: mqttredlich/tele/LWT = Online (retained)
                                    08:38:44.973 MQT: mqttredlich/cmnd/POWER =
                                    08:38:44.977 MQT: mqttredlich/tele/INFO1 = {"Info1":{"Module":"NSPanel","Version":"15.2.0(release-nspanel)","FallbackTopic":"cmnd/NSPanelK_che-85E9B8_fb/","GroupTopic":"mqttredlich/cmnd/"}}
                                    08:38:44.992 MQT: mqttredlich/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NSPanelK-che","IPAddress":"192.168.3.33","IP6Global":"","IP6Local":"fe80::3ee9:eff:fe85:e9b8%st1"}}
                                    08:38:45.006 MQT: mqttredlich/tele/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":24}}
                                    08:38:45.023 MQT: mqttredlich/stat/RESULT = {"POWER1":"OFF"}
                                    08:38:45.026 MQT: mqttredlich/stat/POWER1 = OFF
                                    08:38:45.028 MQT: mqttredlich/stat/RESULT = {"POWER2":"OFF"}
                                    08:38:45.030 MQT: mqttredlich/stat/POWER2 = OFF
                                    08:38:45.296 MQT: mqttredlich/stat/RESULT = {"POWER1":"OFF"}
                                    08:38:45.298 MQT: mqttredlich/stat/POWER1 = OFF
                                    08:38:47.550 MQT: mqttredlich/stat/RESULT = {"POWER1":"OFF"}
                                    08:38:47.554 MQT: mqttredlich/stat/POWER1 = OFF
                                    08:38:48.021 QPC: Reset
                                    08:38:48.965 MQT: mqttredlich/tele/STATE = {"Time":"2025-12-27T08:38:48","Uptime":"0T00:00:08","UptimeSec":8,"Heap":129,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":28,"MqttCount":1,"Berry":{"HeapUsed":16,"Objects":225},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Dreamnet","BSSId":"9C:C7:A6:5C:51:11","Channel":1,"Mode":"HT40","RSSI":66,"Signal":-67,"LinkCount":1,"Downtime":"0T00:00:03"},"Hostname":"NSPanelK-che","IPAddress":"192.168.3.33"}
                                    08:38:49.014 MQT: mqttredlich/tele/SENSOR = {"Time":"2025-12-27T08:38:48","ANALOG":{"Temperature1":-2.8},"TempUnit":"C"}
                                      timredlich
                                      #7851
                                      Wenn ich das Skript auf Debugen stelle bekomme ich im IOBroker log folgend Meldung
                                      script.js.NSPanel.Panel_Kueche: setForeignState(id=0_userdata.0.NSPanel.1ScreensaverInfo.weatherForecast, state={"val":false,"ack":true,"ts":1766821216001,"q":0,"from":"system.adapter.javascript.0","lc":1766821216001,"c":"script.js.NSPanel.Panel_Kueche"}) - wurde nicht ausgeführt, während der Debug-Modus aktiv ist
                                        timredlich
                                        #7852
                                        2025-12-27 08:43:38.226 - info: admin.0 (693) ==> Connected system.user.tim from ::ffff:192.168.1.10
                                        2025-12-27 08:43:46.306 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Stopping script
                                        2025-12-27 08:43:48.048 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Compiling TypeScript source
                                        2025-12-27 08:43:48.372 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: source code did not change, using cached compilation result...
                                        2025-12-27 08:43:48.382 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: findLocaleServMenu: service_pages - de-DE -> Service Seiten
                                        2025-12-27 08:43:48.382 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function findLocaleServMenu: missing translation: Licht - de-DE
                                        2025-12-27 08:43:48.382 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function findLocaleServMenu: missing translation: Licht 2 - de-DE
                                        2025-12-27 08:43:48.383 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function findLocaleServMenu: missing translation: Licht 3 - de-DE
                                        2025-12-27 08:43:48.383 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function findLocaleServMenu: missing translation: Abfallkalender - de-DE
                                        2025-12-27 08:43:48.384 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function findLocaleServMenu: missing translation: Geräte - de-DE
                                        2025-12-27 08:43:48.384 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function findLocaleServMenu: missing translation: Photovoltaik Heute - de-DE
                                        2025-12-27 08:43:48.384 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function findLocaleServMenu: missing translation: Robi Wohnzimmer - de-DE
                                        2025-12-27 08:43:48.385 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function findLocaleServMenu: missing translation: Robi Dachgeschoss - de-DE
                                        2025-12-27 08:43:48.385 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function findLocaleServMenu: missing translation: Layout - de-DE
                                        2025-12-27 08:43:48.386 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: --- start of NsPanelTs: 0_userdata.0.NSPanel.1 ---
                                        2025-12-27 08:43:48.386 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Number of weatherAdapterInstance: 0
                                        2025-12-27 08:43:48.391 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: setObjects enabled - create Alias Channels possible
                                        2025-12-27 08:43:48.391 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: weather alias for pirate-weather.0. already exists
                                        2025-12-27 08:43:48.392 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function SendToPanel val-payload: dimmode~8~100~6371~65535
                                        2025-12-27 08:43:48.392 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function ScreensaverDimmode Background rgb_dec565: 6371
                                        2025-12-27 08:43:48.392 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function ScreensaverDimmode Dimmode=true
                                        2025-12-27 08:43:48.392 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function ScreensaverDimmode -> Day NSPanel.Payload: dimmode~8~100
                                        2025-12-27 08:43:48.392 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Requesting locales
                                        2025-12-27 08:43:48.394 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Requesting locales Service Menu
                                        2025-12-27 08:43:48.395 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: get_current_tasmota_ip_address: 192.168.3.33
                                        2025-12-27 08:43:48.396 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                        2025-12-27 08:43:48.398 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function ScreensaverDimmode Background rgb_dec565: 6371
                                        2025-12-27 08:43:48.398 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function ScreensaverDimmode Dimmode=true
                                        2025-12-27 08:43:48.398 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function SendToPanel val-payload: dimmode~8~100~6371~65535
                                        2025-12-27 08:43:48.398 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function ScreensaverDimmode -> Day NSPanel.Payload: dimmode~8~100
                                        2025-12-27 08:43:48.398 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function SendToPanel val-payload: time~08:43
                                        2025-12-27 08:43:48.398 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: function SendToPanel val-payload: date~Samstag, 27. Dezember 2025
                                        2025-12-27 08:43:48.398 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Requesting tasmota status0
                                        2025-12-27 08:43:48.399 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: get_current_tasmota_ip_address: 192.168.3.33
                                        2025-12-27 08:43:48.399 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Check-Updates
                                        2025-12-27 08:43:48.399 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Already the latest Tasmota version on NSPanel
                                        2025-12-27 08:43:48.399 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Already the latest Berry driver on NSPanel
                                        2025-12-27 08:43:48.399 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: No Updates for NSPanel available
                                        2025-12-27 08:43:48.410 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: 2.1 W
                                        2025-12-27 08:43:48.435 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Desired TFT Firmware: 59 / v5.0.2
                                        2025-12-27 08:43:48.456 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Debug mode disabled
                                        2025-12-27 08:43:49.082 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: hidden Cards disabled
                                        2025-12-27 08:43:50.093 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: Start MQTT-Port-Check -------------------------------------
                                        2025-12-27 08:43:50.093 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: -- admin.0 - 8081
                                        2025-12-27 08:43:50.093 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: -- deyeidc.0 - 8899
                                        2025-12-27 08:43:50.093 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: -- mihome-vacuum.0 - 5432
                                        2025-12-27 08:43:50.093 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: -- mihome-vacuum.1 - 5432
                                        2025-12-27 08:43:50.093 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: -- mqtt.0 - 1887
                                        2025-12-27 08:43:50.093 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: -- shelly.0 - 1882
                                        2025-12-27 08:43:50.094 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: -- sonoff.0 - 1883
                                        2025-12-27 08:43:50.094 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: -- web.0 - 8082
                                        2025-12-27 08:43:50.094 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: -- zigbee.0 - tcp
                                        2025-12-27 08:43:50.094 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1887
                                        2025-12-27 08:43:50.094 - info: javascript.0 (738) script.js.NSPanel.Panel_Kueche: End MQTT-Port-Check ---------------------------------------
                                        2025-12-27 08:43:52.185 - info: admin.0 (693) <== Disconnect system.user.tim from ::ffff:192.168.1.10 javascript
                                        • T timredlich
                                          TT-Tom
                                          #7853
                                          @timredlich
                                          nicht den Debug Modus vom Javascript Adapter, sondern vom Script.
                                          Also im Script die Zeile auf true setzen und neu starten.
                                          // DE: liefert bei true detailliertere Meldundgen im Log.
                                          // EN: if true, provides more detailed messages in the log.
                                          var Debug: boolean = false;
                                          hast du die TFT -Firmware mit den Befehl geflasht?
                                          Gruß Tom
                                          Public Transport
