  4. [ESPHome] Beta release 0.5.0-beta.1 ready
adapter entwicklungadapter updateesphome
134 Beiträge 17 Kommentatoren 21.3k Aufrufe 17 Beobachtet
  • R Offline
    Rogni
    #103
    Moin Moin,
    wenn ich das Dashboard einschalte kommt diese Fehlermeldung. Phyton3 ist installiert, Ubuntu 24.04
    Wenn ich -m pip install eintippe kommt invalid option. bei Upgrade diese Warnung..., wie kann ich Phyton so intallieren das es von ESPhome genutzt werden kann??
    ~$ pip install --upgrade pip / pip3 install --upgrade pip
    error: externally-managed-environment
    × This environment is externally managed
    ╰─> To install Python packages system-wide, try apt install
        python3-xyz, where xyz is the package you are trying to
        install.
        If you wish to install a non-Debian-packaged Python package,
        create a virtual environment using python3 -m venv path/to/venv.
        Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
        sure you have python3-full installed.
        If you wish to install a non-Debian packaged Python application,
        it may be easiest to use pipx install xyz, which will manage a
        virtual environment for you. Make sure you have pipx installed.
        See /usr/share/doc/python3.12/README.venv for more information.
    2025-12-20 17:41:27.653	error	Fatal error starting ESPHomeDashboard | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install esphome==2025.12.1 pillow==10.4.0 ERROR: Cannot install esphome==2025.12.1 and pillow==10.4.0 because these package versions have conflicting dependencies. [notice] A new release of pip is available: 24.3.1 -> 25.3 [notice] To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts Collecting esphome==2025.12.1 Downloading esphome-2025.12.1-py3-none-any.whl.metadata (3.6 kB) Collecting pillow==10.4.0 Using cached pillow-10.4.0-cp313-cp313-manylinux_2_28_x86_64.whl.metadata (9.2 kB) Collecting cryptography==45.0.1 (from esphome==2025.12.1) Using cached cryptography-45.0.1-cp311-abi3-manylinux_2_34_x86_64.whl.metadata (5.7 kB) Collecting voluptuous==0.15.2 (from esphome==2025.12.1) Using cached voluptuous-0.15.2-py3-none-any.whl.metadata (20 kB) Collecting PyYAML==6.0.3 (from esphome==2025.12.1) Using cached pyyaml-6.0.3-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.4 kB) Collecting paho-mqtt==1.6.1 (from esphome==2025.12.1) Using cached paho-mqtt-1.6.1.tar.gz (99 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting colorama==0.4.6 (from esphome==2025.12.1) Using cached colorama-0.4.6-py2.py3-none-any.whl.metadata (17 kB) Collecting icmplib==3.0.4 (from esphome==2025.12.1) Using cached icmplib-3.0.4-py3-none-any.whl.metadata (19 kB) Collecting tornado==6.5.2 (from esphome==2025.12.1) Using cached tornado-6.5.2-cp39-abi3-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.8 kB) Collecting tzlocal==5.3.1 (from esphome==2025.12.1) Using cached tzlocal-5.3.1-py3-none-any.whl.metadata (7.6 kB) Collecting tzdata>=2021.1 (from esphome==2025.12.1) Using cached tzdata-2025.3-py2.py3-none-any.whl.metadata (1.4 kB) Collecting pyserial==3.5 (from esphome==2025.12.1) Using cached pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB) Collecting platformio==6.1.18 (from esphome==2025.12.1) Using cached platformio-6.1.18-py3-none-any.whl.metadata (7.1 kB) Collecting esptool==5.1.0 (from esphome==2025.12.1) Using cached esptool-5.1.0.tar.gz (383 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting click==8.1.7 (from esphome==2025.12.1) Using cached click-8.1.7-py3-none-any.whl.metadata (3.0 kB) Collecting esphome-dashboard==20251013.0 (from esphome==2025.12.1) Using cached esphome_dashboard-20251013.0-py3-none-any.whl.metadata (1.2 kB) Collecting aioesphomeapi==43.2.1 (from esphome==2025.12.1) Using cached aioesphomeapi-43.2.1-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (5.2 kB) Collecting zeroconf==0.148.0 (from esphome==2025.12.1) Using cached zeroconf-0.148.0-cp313-cp313-manylinux_2_36_x86_64.whl.metadata (6.3 kB) Collecting puremagic==1.30 (from esphome==2025.12.1) Using cached puremagic-1.30-py3-none-any.whl.metadata (5.8 kB) Collecting ruamel.yaml==0.18.16 (from esphome==2025.12.1) Using cached ruamel.yaml-0.18.16-py3-none-any.whl.metadata (25 kB) Collecting ruamel.yaml.clib==0.2.15 (from esphome==2025.12.1) Using cached ruamel_yaml_clib-0.2.15-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (3.5 kB) Collecting esphome-glyphsets==0.2.0 (from esphome==2025.12.1) Using cached esphome_glyphsets-0.2.0-py3-none-any.whl.metadata (3.9 kB) INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements. This could take a while. The conflict is caused by: The user requested pillow==10.4.0 esphome 2025.12.1 depends on pillow==11.3.0 To fix this you could try to: 1. loosen the range of package versions you've specified 2. remove package versions to allow pip to attempt to solve the dependency conflict | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install esphome==2025.12.1 pillow==10.4.0 ERROR: Cannot install esphome==2025.12.1 and pillow==10.4.0 because these package versions have conflicting dependencies. [notice] A new release of pip is available: 24.3.1 -> 25.3 [notice] To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflicts Collecting esphome==2025.12.1 Downloading esphome-2025.12.1-py3-none-any.whl.metadata (3.6 kB) Collecting pillow==10.4.0 Using cached pillow-10.4.0-cp313-cp313-manylinux_2_28_x86_64.whl.metadata (9.2 kB) Collecting cryptography==45.0.1 (from esphome==2025.12.1) Using cached cryptography-45.0.1-cp311-abi3-manylinux_2_34_x86_64.whl.metadata (5.7 kB) Collecting voluptuous==0.15.2 (from esphome==2025.12.1) Using cached voluptuous-0.15.2-py3-none-any.whl.metadata (20 kB) Collecting PyYAML==6.0.3 (from esphome==2025.12.1) Using cached pyyaml-6.0.3-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.4 kB) Collecting paho-mqtt==1.6.1 (from esphome==2025.12.1) Using cached paho-mqtt-1.6.1.tar.gz (99 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting colorama==0.4.6 (from esphome==2025.12.1) Using cached colorama-0.4.6-py2.py3-none-any.whl.metadata (17 kB) Collecting icmplib==3.0.4 (from esphome==2025.12.1) Using cached icmplib-3.0.4-py3-none-any.whl.metadata (19 kB) Collecting tornado==6.5.2 (from esphome==2025.12.1) Using cached tornado-6.5.2-cp39-abi3-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.8 kB) Collecting tzlocal==5.3.1 (from esphome==2025.12.1) Using cached tzlocal-5.3.1-py3-none-any.whl.metadata (7.6 kB) Collecting tzdata>=2021.1 (from esphome==2025.12.1) Using cached tzdata-2025.3-py2.py3-none-any.whl.metadata (1.4 kB) Collecting pyserial==3.5 (from esphome==2025.12.1) Using cached pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB) Collecting platformio==6.1.18 (from esphome==2025.12.1) Using cached platformio-6.1.18-py3-none-any.whl.metadata (7.1 kB) Collecting esptool==5.1.0 (from esphome==2025.12.1) Using cached esptool-5.1.0.tar.gz (383 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done' Collecting click==8.1.7 (from esphome==2025.12.1) Using cached click-8.1.7-py3-none-any.whl.metadata (3.0 kB) Collecting esphome-dashboard==20251013.0 (from esphome==2025.12.1) Using cached esphome_dashboard-20251013.0-py3-none-any.whl.metadata (1.2 kB) Collecting aioesphomeapi==43.2.1 (from esphome==2025.12.1) Using cached aioesphomeapi-43.2.1-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (5.2 kB) Collecting zeroconf==0.148.0 (from esphome==2025.12.1) Using cached zeroconf-0.148.0-cp313-cp313-manylinux_2_36_x86_64.whl.metadata (6.3 kB) Collecting puremagic==1.30 (from esphome==2025.12.1) Using cached puremagic-1.30-py3-none-any.whl.metadata (5.8 kB) Collecting ruamel.yaml==0.18.16 (from esphome==2025.12.1) Using cached ruamel.yaml-0.18.16-py3-none-any.whl.metadata (25 kB) Collecting ruamel.yaml.clib==0.2.15 (from esphome==2025.12.1) Using cached ruamel_yaml_clib-0.2.15-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (3.5 kB) Collecting esphome-glyphsets==0.2.0 (from esphome==2025.12.1) Using cached esphome_glyphsets-0.2.0-py3-none-any.whl.metadata (3.9 kB) INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements. This could take a while. The conflict is caused by: The user requested pillow==10.4.0 esphome 2025.12.1 depends on pillow==11.3.0 To fix this you could try to: 1. loosen the range of package versions you've specified 2. remove package versions to allow pip to attempt to solve the dependency conflict at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at processTicksAndRejections (node:internal/process/task_queues:105:5) at $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/src/index.ts:257:13) at Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:180:16) at Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)
    Erik :mrgreen: :mrgreen:
      Tontechniker
      schrieb am zuletzt editiert von Tontechniker
      #104
      Dein Tip war goldrichtig! Auf der Seite war ich schon einmal, hatte mich aber nicht getraut die angegenbenen files zu löschen.
      Danke!
      Gruß und schöne Weihnachten
      Hans
      • R Rogni
        Moin Moin,
            install.
        #105
        @Rogni sagte in [ESPHome] Beta release 0.5.0-beta.1 ready:
        Du musst die aktuelle (Beta)-Version des Adapters verwenden.
        €dit: Kann auch sein, dass der Code noch nicht gemerged ist. Dann abwarten...
        Siehe auch:
        https://github.com/DrozmotiX/ioBroker.esphome/issues/343
        • R Offline
          Rogni
          #106
          okay, 0.6.3 ist installiert, also warten ;) Danke für die schnelle antwort.
          • simonf04S Offline
            simonf04S Offline
            simonf04
            #107
            @rogni kannst zum testen auch direkt per url installieren: https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/343
            • R Offline
              Rogni
              #108
              @simonf04
              Hat leider nicht geklappt,oder mache ich was falsch??
              So wurde installiert:
              ![Bild Text](Bildschirmfoto 2025-12-21 um 15.24.44.png Bild Link)
              dann kam:
              $ iobroker upgrade esphome@https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/343 --debug
              Can not check version information to display upgrade infos: Invalid Version: https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/343
              Could not uninstall npm packet "iobroker.esphome": Invalid Version: https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/343
              NPM version: 10.9.4
              Installing iobroker.esphome@https://github.com/SimonFischer04/ioBroker.esphome/tree/fix/343... (System call)
              npm error code 1npm error The git reference could not be foundnpm error command git --no-replace-objects checkout fixnpm error error: pathspec 'fix' did not match any file(s) known to git
              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-21T14_21_44_346Z-debug-0.log
              Updating objects from io-package.json for adapter "esphome" with version "0.6.3"
              Update "system.adapter.esphome.0"
              upload [26] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/admin.d.ts admin.d.ts video/mp2t
              upload [18] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              upload [17] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              upload [16] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              upload [15] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              upload [14] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              upload [13] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/ESPHomeDashboardUrl.png img/ESPHomeDashboardUrl.png image/png
              upload [12] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/ESPhomeDashboardIP.png img/ESPhomeDashboardIP.png image/png
              upload [11] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/connectionIssue.png img/connectionIssue.png image/png
              upload [10] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/connectionOK.png img/connectionOK.png image/png
              upload [9] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/dashboard.png img/dashboard.png image/png
              upload [8] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/deviceTabEmpty.png img/deviceTabEmpty.png image/png
              upload [7] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/deviceTree.png img/deviceTree.png image/png
              upload [6] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/flashFromThisComputer.png img/flashFromThisComputer.png image/png
              upload [5] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/img/proxy.png img/proxy.png image/png
              upload [4] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/index_m.html index_m.html text/html
              upload [3] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/jsonConfig.json5 jsonConfig.json5 application/json5
              upload [2] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/style.css style.css text/css
              upload [1] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/tsconfig.json tsconfig.json application/json
              upload [0] esphome.admin /opt/iobroker/node_modules/iobroker.esphome/admin/words.js words.js application/javascript
              Process exited with code 0
              und der Fehler ist gleich:
              Log-Größe: 43.1 KB
              Zeit
              esphome.0
              	2025-12-21 15:22:56.354	error	Fatal error starting ESPHomeDashboard | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install esphome==2025.12.1 pillow==10.4.0ERROR: Cannot install esphome==2025.12.1 and pillow==10.4.0 because these package versions have conflicting dependencies.[notice] A new release of pip is available: 24.3.1 -> 25.3[notice] To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pipERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflictsCollecting esphome==2025.12.1 Using cached esphome-2025.12.1-py3-none-any.whl.metadata (3.6 kB)Collecting pillow==10.4.0 Using cached pillow-10.4.0-cp313-cp313-manylinux_2_28_x86_64.whl.metadata (9.2 kB)Collecting cryptography==45.0.1 (from esphome==2025.12.1) Using cached cryptography-45.0.1-cp311-abi3-manylinux_2_34_x86_64.whl.metadata (5.7 kB)Collecting voluptuous==0.15.2 (from esphome==2025.12.1) Using cached voluptuous-0.15.2-py3-none-any.whl.metadata (20 kB)Collecting PyYAML==6.0.3 (from esphome==2025.12.1) Using cached pyyaml-6.0.3-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.4 kB)Collecting paho-mqtt==1.6.1 (from esphome==2025.12.1) Using cached paho-mqtt-1.6.1.tar.gz (99 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done'Collecting colorama==0.4.6 (from esphome==2025.12.1) Using cached colorama-0.4.6-py2.py3-none-any.whl.metadata (17 kB)Collecting icmplib==3.0.4 (from esphome==2025.12.1) Using cached icmplib-3.0.4-py3-none-any.whl.metadata (19 kB)Collecting tornado==6.5.2 (from esphome==2025.12.1) Using cached tornado-6.5.2-cp39-abi3-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.8 kB)Collecting tzlocal==5.3.1 (from esphome==2025.12.1) Using cached tzlocal-5.3.1-py3-none-any.whl.metadata (7.6 kB)Collecting tzdata>=2021.1 (from esphome==2025.12.1) Using cached tzdata-2025.3-py2.py3-none-any.whl.metadata (1.4 kB)Collecting pyserial==3.5 (from esphome==2025.12.1) Using cached pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB)Collecting platformio==6.1.18 (from esphome==2025.12.1) Using cached platformio-6.1.18-py3-none-any.whl.metadata (7.1 kB)Collecting esptool==5.1.0 (from esphome==2025.12.1) Using cached esptool-5.1.0.tar.gz (383 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done'Collecting click==8.1.7 (from esphome==2025.12.1) Using cached click-8.1.7-py3-none-any.whl.metadata (3.0 kB)Collecting esphome-dashboard==20251013.0 (from esphome==2025.12.1) Using cached esphome_dashboard-20251013.0-py3-none-any.whl.metadata (1.2 kB)Collecting aioesphomeapi==43.2.1 (from esphome==2025.12.1) Using cached aioesphomeapi-43.2.1-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (5.2 kB)Collecting zeroconf==0.148.0 (from esphome==2025.12.1) Using cached zeroconf-0.148.0-cp313-cp313-manylinux_2_36_x86_64.whl.metadata (6.3 kB)Collecting puremagic==1.30 (from esphome==2025.12.1) Using cached puremagic-1.30-py3-none-any.whl.metadata (5.8 kB)Collecting ruamel.yaml==0.18.16 (from esphome==2025.12.1) Using cached ruamel.yaml-0.18.16-py3-none-any.whl.metadata (25 kB)Collecting ruamel.yaml.clib==0.2.15 (from esphome==2025.12.1) Using cached ruamel_yaml_clib-0.2.15-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (3.5 kB)Collecting esphome-glyphsets==0.2.0 (from esphome==2025.12.1) Using cached esphome_glyphsets-0.2.0-py3-none-any.whl.metadata (3.9 kB)INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements. This could take a while.The conflict is caused by: The user requested pillow==10.4.0 esphome 2025.12.1 depends on pillow==11.3.0To fix this you could try to:1. loosen the range of package versions you've specified2. remove package versions to allow pip to attempt to solve the dependency conflict | Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install esphome==2025.12.1 pillow==10.4.0ERROR: Cannot install esphome==2025.12.1 and pillow==10.4.0 because these package versions have conflicting dependencies.[notice] A new release of pip is available: 24.3.1 -> 25.3[notice] To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pipERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflictsCollecting esphome==2025.12.1 Using cached esphome-2025.12.1-py3-none-any.whl.metadata (3.6 kB)Collecting pillow==10.4.0 Using cached pillow-10.4.0-cp313-cp313-manylinux_2_28_x86_64.whl.metadata (9.2 kB)Collecting cryptography==45.0.1 (from esphome==2025.12.1) Using cached cryptography-45.0.1-cp311-abi3-manylinux_2_34_x86_64.whl.metadata (5.7 kB)Collecting voluptuous==0.15.2 (from esphome==2025.12.1) Using cached voluptuous-0.15.2-py3-none-any.whl.metadata (20 kB)Collecting PyYAML==6.0.3 (from esphome==2025.12.1) Using cached pyyaml-6.0.3-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (2.4 kB)Collecting paho-mqtt==1.6.1 (from esphome==2025.12.1) Using cached paho-mqtt-1.6.1.tar.gz (99 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done'Collecting colorama==0.4.6 (from esphome==2025.12.1) Using cached colorama-0.4.6-py2.py3-none-any.whl.metadata (17 kB)Collecting icmplib==3.0.4 (from esphome==2025.12.1) Using cached icmplib-3.0.4-py3-none-any.whl.metadata (19 kB)Collecting tornado==6.5.2 (from esphome==2025.12.1) Using cached tornado-6.5.2-cp39-abi3-manylinux_2_5_x86_64.manylinux1_x86_64.manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (2.8 kB)Collecting tzlocal==5.3.1 (from esphome==2025.12.1) Using cached tzlocal-5.3.1-py3-none-any.whl.metadata (7.6 kB)Collecting tzdata>=2021.1 (from esphome==2025.12.1) Using cached tzdata-2025.3-py2.py3-none-any.whl.metadata (1.4 kB)Collecting pyserial==3.5 (from esphome==2025.12.1) Using cached pyserial-3.5-py2.py3-none-any.whl.metadata (1.6 kB)Collecting platformio==6.1.18 (from esphome==2025.12.1) Using cached platformio-6.1.18-py3-none-any.whl.metadata (7.1 kB)Collecting esptool==5.1.0 (from esphome==2025.12.1) Using cached esptool-5.1.0.tar.gz (383 kB) Installing build dependencies: started Installing build dependencies: finished with status 'done' Getting requirements to build wheel: started Getting requirements to build wheel: finished with status 'done' Preparing metadata (pyproject.toml): started Preparing metadata (pyproject.toml): finished with status 'done'Collecting click==8.1.7 (from esphome==2025.12.1) Using cached click-8.1.7-py3-none-any.whl.metadata (3.0 kB)Collecting esphome-dashboard==20251013.0 (from esphome==2025.12.1) Using cached esphome_dashboard-20251013.0-py3-none-any.whl.metadata (1.2 kB)Collecting aioesphomeapi==43.2.1 (from esphome==2025.12.1) Using cached aioesphomeapi-43.2.1-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (5.2 kB)Collecting zeroconf==0.148.0 (from esphome==2025.12.1) Using cached zeroconf-0.148.0-cp313-cp313-manylinux_2_36_x86_64.whl.metadata (6.3 kB)Collecting puremagic==1.30 (from esphome==2025.12.1) Using cached puremagic-1.30-py3-none-any.whl.metadata (5.8 kB)Collecting ruamel.yaml==0.18.16 (from esphome==2025.12.1) Using cached ruamel.yaml-0.18.16-py3-none-any.whl.metadata (25 kB)Collecting ruamel.yaml.clib==0.2.15 (from esphome==2025.12.1) Using cached ruamel_yaml_clib-0.2.15-cp313-cp313-manylinux2014_x86_64.manylinux_2_17_x86_64.manylinux_2_28_x86_64.whl.metadata (3.5 kB)Collecting esphome-glyphsets==0.2.0 (from esphome==2025.12.1) Using cached esphome_glyphsets-0.2.0-py3-none-any.whl.metadata (3.9 kB)INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements. This could take a while.The conflict is caused by: The user requested pillow==10.4.0 esphome 2025.12.1 depends on pillow==11.3.0To fix this you could try to:1. loosen the range of package versions you've specified2. remove package versions to allow pip to attempt to solve the dependency conflict at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11) at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26) at processTicksAndRejections (node:internal/process/task_queues:105:5) at $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/src/index.ts:257:13) at Esphome.espHomeDashboard (/opt/iobroker/node_modules/iobroker.esphome/main.js:179:16) at Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:65:4)
              esphome.0
              	2025-12-21 15:22:36.700	info	Native Integration of ESPHome Dashboard enabled, making environment ready
              esphome.0
              	2025-12-21 15:22:36.141	info	starting. Version 0.6.3 in /opt/iobroker/node_modules/iobroker.esphome, node: v22.21.0, js-controller: 7.1.0
              esphome.0
              	2025-12-21 15:19:53.143	info	terminating
              esphome.0
              esphome.0
              	2025-12-21 15:19:52.643	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              esphome.0
              	2025-12-21 15:19:52.641	info	terminating
              • simonf04S Offline
                simonf04S Offline
                simonf04
                #109
                @rogni im expertenmodus per url
                • R Offline
                  Rogni
                  #110
                  thanks @simonf04
                  ich bin ja auch depp, vor lauter Wald……..läuft anstandslos durch
                  simonf04S 1 Antwort Letzte Antwort
                  • R Rogni
                    thanks @simonf04
                    simonf04S Offline
                    simonf04S Offline
                    simonf04
                    #111
                    @Rogni kein Problem.
                    Gern geschehen.
                    • R Offline
                      Rogni
                      schrieb am zuletzt editiert von Rogni
                      #112
                      @simonf04
                      nur zur Info, diese Warn Meldung kommt ab und an beim Start:
                      admin.0
                      2025-12-22 08:45:04.926	warn	esphome has an invalid jsonConfig: [{"instancePath":"/items/devices/items/newDevicesTable","schemaPath":"#/patternProperties/%5E.%2B/allOf/27/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"doNotSave"},"message":"must NOT have additional properties"},{"instancePath":"/items/devices","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                      Mit dem Dashboard kämpfe ich noch ein bischen rum. Momentan lässt es sich noch nicht starten.
                      Cache ist geleert ;)
                      Edith sqgt, das Ganze nochmal sauber deinstaliert, iob fix, und dann wieder installiert, bewirkt Wunder ;)
                      • R Offline
                        Rogni
                        #113
                        Ist es möglich dieses Projekt auf IObroker zu adaptieren?? [Link Text]
                        (http://192.168.10.183:8123/reterminal-dashboard)
                        das ist für Home Assistant und ist sehr komfortabel für diese Art von Displays
                        • R Rogni
                          simonf04S Offline
                          simonf04S Offline
                          simonf04
                          #114
                          Mit einem link zu etwas bei dir lokal kann ich leider nicht viel anfangen.😉
                          Aber einfach mal probieren, 99% der yamls sollten 1zu1 gleich funktionieren.
                          • R Offline
                            Rogni
                            #115
                            😂😂😂wo Du recht hast, hast Du recht @simonf04 😂😂😂
                            kommt davon wenn man tausend Sachen gleichzeitig macht :)
                            hier der richtige
                            • R Rogni
                              hier der richtige
                              simonf04S Offline
                              simonf04S Offline
                              simonf04
                              #116
                              @Rogni ok, das ist etwas deutlich anderes.
                              Sorry, aber vermute mal das ist ziemlich low priority.
                              Designer ist auch online verfügbar: https://koosoli.github.io/ESPHomeDesigner/
                              Und dann kannst das yaml auch einfach ins dashboard copy pasten..
                                Tontechniker
                                #117
                                Liebe Komunity,
                                ich versuche ohne Erfolg die neue api-Verschlüsselung einzugeben. Habe im Programm den Schlüssel wie folgt eingetragen:
                                code_text
                                api:
                                  encryption:
                                    key: !secret api_pw_06
                                code_text
                                Das api_pw_06 in secrets ist z.B. "HYoIYihaDsXRuOyO236pMeMF/bDB8+Bd"
                                Den gleichen Schlüssel habe ich anschließend in das entsprechende Gerät in ESP-home eingegeben. (Das Programm wurde natürlich nach der Eingabe compiliert und in das Gerät geladen.)
                                Anschließend kommt die Nachricht, dass der Schlüssel nicht gefunden wurde.
                                Welcher Schlüssel muss in ESP-home, Allgemeine Einstellungen, "Standardschlüssel" eingeben werden?
                                Danke für eure Antworten!
                                Hans
                                EDIT:
                                Fehler tritt nicht mehr auf!
                                Maßnahme:
                                Gerät löschen und neu mit Schlüssel anlernen.
                                  Tontechniker
                                  #118
                                  Ich habe einen pipico-w in ESP-Home eingebunden. Alle Daten kommen, aber leider habe ich im Log immer wieder Fehlermeldungen. Vielleicht kann jemand von euch mir auf die Sprünge helfe, bzw. hat einen Tipp, warum die Fehlermeldungen auftauchen. Ich hänge euch mal einen Auszug des Log an.
                                  • T Tontechniker
                                    simonf04S Offline
                                    simonf04S Offline
                                    simonf04
                                    #119
                                    @Tontechniker welche version von adapter ubd dashboard hast installiert?
                                    Steht im iobroker log auch was?
                                    Alle Daten kommen
                                    Auch an den objekten im iobroker oder nur hier im log?
                                    • T Tontechniker
                                      @simon42 Danke für Deine Antwort!
                                      Vielleicht liegt es ja an der Berechtigung?
                                      Auf iob diag bekomme ich folgende Fehlermeldung:
                                      Bin nicht so firn mit Raspi - was muss ich ändern?
                                      Danke für Deine Mühe!
                                      Edit:
                                      Habe mit iob fix die Rechte angepasst. Kannst Du vielleicht etwas in der log-Datei erkennen?
                                      iob_diag.log
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #120
                                      @Tontechniker da wird die connection zu gemacht
                                      fügmal unter api
                                      reboot_timeout: 0s
                                      batch_delay: 100ms
                                      max_connections: 2
                                        Tontechniker
                                        #121
                                        simonf04: Ich nutze Dashboard 2026.2.1
                                        arteck: habe die Änderung eingegeben und gelogt (siehe unten).
                                        logs_rpipicow_run.txt
                                        Danke und Gruß
                                        Hans
                                        EDIT:
                                        Es funktioniert, die Meldungen erscheinen nicht mehr.
                                        Ich vermute, dass doch eine alte Version des Dashboards installiert war. das Problem war, dass das neu installierte Dashboard erst nach einem Neustart wirksam wurde.
                                        Vielen Dank für eure Mühe!
                                        EDIT EDIT:
                                        Habe nochmal rumprobiert und hatte plötzlich wieder den gleichen Effekt.
                                        Nach einem Neustart von IO-Broker war wieder alles O.K.! Ich werde das weiter beobachten und melde mich bei Abweichungen.
                                        Übrigens: es funktioniert dann auch ohne Änderung (Beitrag 120)
                                          Tontechniker
                                          #122
                                          Ich kann mal wieder das Dashboard nicht erreichen.
                                          Die Fehlermeldung sagt, die pip-Version (24.3.1) sei veraltet. Ich soll 26.0.1 installieren.
                                          Der dazu angegebene Pfad und updatebefehl lautet /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip
                                          Wenn ich diese Befehlszeile eingebe kommt die Meldung, ich hätte keine Berechtigung.
                                          Was mache ich falsch?
