  4. Nach Updates läuft alles instabil
    2.8k
    2.9k
13 Beiträge 4 Kommentatoren 596 Aufrufe 4 Beobachtet
  • Christian FuchsC Offline
    Christian Fuchs
    ich kenne mich absolut nicht damit aus.
    Nachdem alles sehr veraltet war, habe ich gestern alles auf den neusten Stand gebracht.
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: pi
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     07:42:03 up 3 min,  1 user,  load average: 2.26, 1.95, 0.85
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-12-11 07:42:03 CET
               Universal time: Thu 2025-12-11 06:42:03 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c        spi render input iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            950M        171M        641M        3.1M        197M        778M
    Swap:           950M         24M        925M
    Total:          1.9G        195M        1.6G
    Active iob-Instances:   1
              906 M total memory
              163 M used memory
               96 M active memory
               90 M inactive memory
              612 M free memory
               24 M buffer memory
              164 M swap cache
              905 M total swap
               22 M used swap
              883 M free swap
    top - 07:42:04 up 3 min,  1 user,  load average: 2.26, 1.95, 0.85
    Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  3.6 sy,  0.0 ni, 96.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    906.0 total,    612.1 free,    162.6 used,    189.4 buff/cache
    MiB Swap:    906.0 total,    883.1 free,     22.9 used.    743.4 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of S        UB.
            SUB    -> The low-level unit activation state, values depend on unit typ        e.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  317M     0  317M   0% /dev
    tmpfs          tmpfs     182M  4.1M  178M   3% /run
    /dev/mmcblk0p2 ext4       15G  5.1G  8.5G  38% /
    tmpfs          tmpfs     454M     0  454M   0% /dev/shm
    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald        .service
    tmpfs          tmpfs     454M  2.8M  451M   1% /tmp
    /dev/mmcblk0p1 vfat      510M   74M  437M  15% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.servi        ce
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@tty        S0.service
    tmpfs          tmpfs      91M  8.0K   91M   1% /run/user/1000
    [Thu Dec 11 07:38:16 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1        snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headph        ones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3e        c00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUU        ID=2726ff42-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdo        m=DE
    [Thu Dec 11 07:38:23 2025] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Thu Dec 11 07:38:23 2025] EXT4-fs (mmcblk0p2): mounted filesystem 21724cc6-e5a3        -48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Thu Dec 11 07:38:28 2025] EXT4-fs (mmcblk0p2): re-mounted 21724cc6-e5a3-48a1-86        43-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.3G    /var/
    231M    /var/cache
    225M    /var/cache/apt
    177M    /var/lib
    145M    /var/lib/apt
    Archived and active journals take up 2.9M in the file system.
    /opt/iobroker/backups:
    6.2M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    173M    /opt/iobroker/iobroker-data/
    144M    /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    19M     /opt/iobroker/iobroker-data/objects.jsonl
    8.1M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-BJ5wwkBW.js
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-DWwiPxYL.js
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    3.7M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/assets/index-CnpybLRW.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230830160800-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    pi                  pi (version: 7.1.0, hostname: pi            , alive, uptime: 101)
    Core adapters versions
    js-controller:  7.1.0
    admin:          7.7.20
    javascript:     9.0.13
    nodejs modules from github:     0
    Adapter State
      system.adapter.admin.0                  : admin                 : pi                                       -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : pi                                       -  enabled, compact disabled
      system.adapter.discovery.0              : discovery             : pi                                       -  enabled, compact disabled
      system.adapter.drag-indicator.0         : drag-indicator        : pi                                       -  enabled, compact disabled
      system.adapter.email.0                  : email                 : pi                                       -  enabled, compact disabled
      system.adapter.email.1                  : email                 : pi                                       -  enabled, compact disabled
      system.adapter.habpanel.0               : habpanel              : pi                                       - disabled
      system.adapter.history.0                : history               : pi                                       -  enabled, compact disabled
      system.adapter.javascript.0             : javascript            : pi                                       -  enabled, compact disabled
      system.adapter.modbus.0                 : modbus                : pi                                       -  enabled, compact disabled
      system.adapter.sonoff.0                 : sonoff                : pi                                       -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
      system.adapter.web.0                    : web                   : pi                                       -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : pi                                       - disabled, compact disabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.7.20   , installed 7.7.20
    Adapter    "backitup"     : 3.3.11   , installed 3.3.11
    Adapter    "drag-indicator": 2.5.0   , installed 2.5.0
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "javascript"   : 9.0.13   , installed 9.0.13
    Controller "js-controller": 7.1.0    , installed 7.1.0
    Adapter    "modbus"       : 7.0.6    , installed 7.0.6
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "web"          : 7.0.9    , installed 7.0.9
    Adapter    "ws"           : 3.0.19   , installed 3.0.19
    Adapter    "zigbee"       : 3.3.0    , installed 3.3.0
    Objects and States
    Objects:        742
    States:         492
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6137       955/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5156       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6139       955/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1158       1/init
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5113       1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6899       586/avahi-daemon: r
    udp        0      0 0.0.0.0:49157           0.0.0.0:*                           101        6901       586/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          5114       1/init
    udp6       0      0 :::5353                 :::*                                101        6900       586/avahi-daemon: r
    udp6       0      0 :::48053                :::*                                101        6902       586/avahi-daemon: r
    udp6       0      0 fe80::50ef:6afc:747:546 :::*                                0          9219       617/NetworkManager
        at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
        at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
        at ScanStream.Readable.read (node:internal/streams/readable:739:12)
        at resume_ (node:internal/streams/readable:1257:12)
        at processTicksAndRejections (node:internal/process/task_queues:90:21)
    2025-12-11 07:40:34.664  - info: host.pi stopInstance timeout system.adapter.email.0 killing pid 1125
    2025-12-11 07:40:34.671  - info: host.pi stopInstance timeout system.adapter.email.1 killing pid 1149
    2025-12-11 07:40:34.673  - info: host.pi stopInstance timeout system.adapter.modbus.0 killing pid 1085
    2025-12-11 07:40:34.675  - info: host.pi stopInstance timeout system.adapter.web.0 killing pid 1119
    2025-12-11 07:40:34.821  - info: host.pi instance system.adapter.sonoff.0 terminated with code 0 (NO_ERROR)
    2025-12-11 07:40:34.823  - info: host.pi instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
    2025-12-11 07:40:35.010  - info: host.pi instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
    2025-12-11 07:40:35.163  - warn: host.pi instance system.adapter.web.0 terminated due to SIGKILL
    2025-12-11 07:40:35.165  - info: host.pi instance system.adapter.web.0 terminated with code null ()
    2025-12-11 07:40:35.170  - warn: host.pi instance system.adapter.email.0 terminated due to SIGKILL
    2025-12-11 07:40:35.171  - info: host.pi instance system.adapter.email.0 terminated with code null ()
    2025-12-11 07:40:35.174  - warn: host.pi instance system.adapter.email.1 terminated due to SIGKILL
    2025-12-11 07:40:35.176  - info: host.pi instance system.adapter.email.1 terminated with code null ()
    2025-12-11 07:40:37.013  - info: history.0 (1156) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v22.21.0, js-controller: 7.1.0
    2025-12-11 07:40:37.328  - info: history.0 (1156) terminating
    2025-12-11 07:40:37.332  - info: history.0 (1156) terminating
    2025-12-11 07:40:37.335  - info: history.0 (1156) Terminated (NO_ERROR): Without reason
    2025-12-11 07:40:37.989  - info: host.pi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2025-12-11 07:40:37.990  - info: host.pi All instances are stopped.
    2025-12-11 07:40:38.192  - info: host.pi terminated
    • AsgothianA Offline
      AsgothianA Offline
      Asgothian
      Das ist ein wunderbares log vom Diag, aber - warum hast du die Code Tags die die Ausgabe gleich mitbringt nicht mit kopiert - dann wäre das auch lesbar.
      Ansonsten:
      Was heisst Instabil ?
      • Was genau passiert / passiert nicht ?
      • Wie ist die Speicherauslastung wenn es mal läuft ?
      Das system ist Instabil alleine ist als Fehlermeldung denkbar ungeeignet, weil viel zu generisch.
      Als letzets - meine Kristallkugel sagt mir: Dir geht der Speicher aus. 1 GB Arbeitsspeicher bei einem 64bit OS mit Redis und den ganzen Adaptern - das wird eng.
      Das ging ggf. mit dem 32 bit System noch, aber da könnte jetzt Ende sein.
      A.
      • AsgothianA Asgothian
        Ansonsten:
        A.
        HomoranH Offline
        HomoranH Offline
        @Asgothian sagte in Nach Updates läuft alles instabil:
        nur die am Anfang.
        Habe sie ergänzt.
        @christian-fuchs
        der Diag ist dazu wenig hilfreich, da
        @Christian-Fuchs sagte in Nach Updates läuft alles instabil:
        up 3 min
        der Raspi wohl gerade erst neu gestartet wurde.
        Daher ist der Swap
        Swap: 950M 24M 925M
        noch nicht ganz vollgelaufen.
        Wird er aber sehr wahrscheinlich noch machen.
        Außerdem hat dein Dateisystem einen Schuss!
        der Rest ist leider abgeschnitten
          Christian Fuchs
          Sorry, ich hab das einfach aus putty kopiert.
          Ich kenn mich leider echt nicht gut aus. Ich hab das alles mal zum laufen gebracht und nicht mehr angefasst.
          Nachdem dann einige Adapter nicht mehr gelaufen sind, wollte ich alles mal auf den neusten Stand bringen.
          Anschließend habe ich mein Backup vom backitup-Adapter eingespielt.
          Die Weboberfläche funktioniert nicht. Nach dem Anmelden kommt
          Cannot getRepository: Error: timeout
          Christian FuchsC 1 Antwort Letzte Antwort
            Christian Fuchs
            Sollte ich das OS Lite 32 bit verwenden?
            • Christian FuchsC Christian Fuchs
              *** BASE SYSTEM ***
               Static hostname: pi
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Swap:           950M         24M        925M
                        906 M total memory
                        163 M used memory
                         96 M active memory
                        612 M free memory
                         24 M buffer memory
                        164 M swap cache
                        905 M total swap
                         22 M used swap
                        883 M free swap
              *** FILESYSTEM ***
              /var:
              1.3G    /var/
              231M    /var/cache
              225M    /var/cache/apt
              177M    /var/lib
              145M    /var/lib/apt
              USB-Devices by-id:
              HINT:
              /dev/ttyACM0
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
                   20.19.2+dfsg-1 500
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.20
              javascript:     9.0.13
              Adapter State
              + instance is alive
              Objects and States
              Objects:        742
              States:         492
              Pending Updates: 0
              Spannungsversorgung okay? Original Netzteil verwendet?
              1GB RAM ist mittlerweile zu wenig, egal auf welcher Architektur.
              Das Dateisystem hat verwaiste Dateien.
              HINT:
              /dev/ttyACM0
              Würde ich anders einstellen und die 'links-by-id' verwenden.
              Für einen stabilen Betrieb, der weniger Aufmerksamkeit verlangt würde ich auch nicht den Beta-Kanal aktiv haben
                Christian Fuchs
                Ja ich habe das originale Netzteil dazu.
                Ich kann leider damit nicht viel anfangen.
                Was wäre denn eure Empfehlung?
                Ich würde jetzt ungern die Hardware tauschen.
                  Einen aktuellen Raspberry (4 oder 5) verwenden.
                  Ich würde dann da die Version mit 4GB RAM ins Auge fassen.
                    Christian Fuchs
                    Danke. Werde ich die nächste Zeit ins Auge fassen.
                    Gibt es eine kurzfriste Möglichkeit, da ich meine Ansteuerung der Wärmepumpe drüber laufen habe.
                      @Christian-Fuchs
                      iob start
                      wäre der Anfang.
                        Christian Fuchs
                        iob start
                        hatte ich natürlich gemacht.
                        Ich teste gerade mit der OS lite 32 bit Version.
                          iob start
                          Testen kannste das. Ist aber eine Sackgasse.
                            iob start
                            HomoranH Offline
                            HomoranH Offline
                            hoffentlich auf einer neuen SD Karte!
                            deine alte geht möglicherweise gerade über den Jordan
