  3. Einsteigerfragen
  4. Installation
  5. nach node js Update - npm bad error EBADENGINE
    2.7k
    2.9k
10 Beiträge 3 Kommentatoren 444 Aufrufe 3 Beobachtet
  • R Offline
    Rainman
    nach einem (überfälligen) update meines Raspberry kann ich nicht mehr alle Adapter aktualisieren. Bei 7 Adaptern kommt immer die gleiche Fehlermeldung:
    $ iobroker upgrade backitup@3.3.10 --debug
    Update backitup from @3.3.5 to @3.3.10
    host.iobroker Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 11.6.2
    Installing iobroker.backitup@3.3.10... (System call)
    npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: hap-nodejs@1.1.2
    npm error notsup Not compatible with your version of node/npm: hap-nodejs@1.1.2npm error notsup Required: {"node":"^18 || ^20 || ^22"}npm error notsup Actual: {"npm":"11.6.2","node":"v24.11.1"}
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-29T10_12_02_776Z-debug-0.log
    $ iobroker upgrade eusec@2.0.3 --debug
    Update eusec from @1.3.3 to @2.0.3
    NPM version: 11.6.2
    Installing iobroker.eusec@2.0.3... (System call)
    npm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: hap-nodejs@1.1.2npm error notsup Not compatible with your version of node/npm: hap-nodejs@1.1.2npm error notsup Required: {"node":"^18 || ^20 || ^22"}npm error notsup Actual: {"npm":"11.6.2","node":"v24.11.1"}
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-29T10_20_23_949Z-debug-0.log
    $ iobroker upgrade javascript@9.0.11 --debug
    Update javascript from @8.9.2 to @9.0.11
    NPM version: 11.6.2
    Installing iobroker.javascript@9.0.11... (System call)
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-29T10_21_27_258Z-debug-0.log
    $ iobroker upgrade notification-manager@1.3.0 --debug
    Update notification-manager from @1.2.1 to @1.3.0
    NPM version: 11.6.2
    Installing iobroker.notification-manager@1.3.0... (System call)
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-29T10_22_20_225Z-debug-0.log
    $ iobroker upgrade shelly@10.4.1 --debug
    Update shelly from @10.1.0 to @10.4.1
    NPM version: 11.6.2
    Installing iobroker.shelly@10.4.1... (System call)
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-29T10_23_18_506Z-debug-0.log
    $ iobroker upgrade vis-2@2.13.4 --debug
    Update vis-2 from @2.12.12 to @2.13.4
    host.iobroker Adapter "system.adapter.vis-2.0" is stopped.
    NPM version: 11.6.2
    Installing iobroker.vis-2@2.13.4... (System call)
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-11-29T10_23_54_489Z-debug-0.log
    Ich bin mit dem System insgesamt noch nicht so vertraut und habe nach Anleitung aktualisiert. Kann auch gut sein, dass ich was falsch gemacht habe.
    Kann mir jemand helfen, dass ich das wieder in Ordnung bringe?
    Vielen Dank schon mal!
    • R Rainman
      NPM version: 11.6.2
      NPM version: 11.6.2
      NPM version: 11.6.2
      NPM version: 11.6.2
      NPM version: 11.6.2
      NPM version: 11.6.2
      @Rainman sagte in nach node js Update - npm bad error EBADENGINE:
      Deine nodejs-Version ist zu hoch. Wer hat dir denn gesagt, dass du auf nodejs@24 gehen sollst?
      Korrigier das mit dem Befehl
      iob nodejs-update
      Der dürfte dir vorschlagen, die derzeitige Empfehlung nodejs@22 zu installieren. Tu das.
      • R Rainman
        NPM version: 11.6.2
        NPM version: 11.6.2
        NPM version: 11.6.2
        NPM version: 11.6.2
        NPM version: 11.6.2
        NPM version: 11.6.2
        Näwwah tatsch a runnink süstähm, was?
        Wie schaut die Kiste denn aktuell aus? Gib mal die vollständige Ausgabe von
        iob diag
        zum Besten.
        R 1 Antwort Letzte Antwort
          iob diag
          zum Besten.
          Rainman
          @Thomas-Braun sagte in nach node js Update - npm bad error EBADENGINE:
          iob diag
          zum Besten.
          :-D Das ist eigentlich nicht mein Motto, die grauen Zellen lassen mich nur viel vergessen.
          Updates haben funktioniert, vielen Dank. Aber das EoL macht es auch nicht besser....
          Script v.2025-08-09
          *** BASE SYSTEM ***
          Operating System: Debian GNU/Linux 11 (bullseye)
             Static hostname: iobroker
                   Icon name: computer
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           11:44:23 up 2 days, 12:16,  1 user,  load average: 2.38, 1.08, 0.62
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Sat 2025-11-29 11:44:23 CET
                     Universal time: Sat 2025-11-29 10:44:23 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          Ra1nman
          HOME=/home/Ra1nman
          GROUPS=Ra1nman adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          *** DISPLAY-SERVER SETUP ***
          Display-Server:         false
          Unit display-manager.service could not be found.
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:            7.8G        1.6G        4.2G        1.0M        2.0G        6.1G
          Swap:            99M          0B         99M
          Total:          7.9G        1.6G        4.3G
          Active iob-Instances:   9
                   7811 M total memory
                   1584 M used memory
                   1676 M active memory
                   1656 M inactive memory
                   4239 M free memory
                    151 M buffer memory
                   1836 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          top - 11:44:24 up 2 days, 12:16,  1 user,  load average: 2.38, 1.08, 0.62
          Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  2.9 us,  2.9 sy,  0.0 ni, 94.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7811.3 total,   4238.8 free,   1584.0 used,   1988.5 buff/cache
          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6104.5 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          /dev/root      ext4       56G  5.7G   48G  11% /
          devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
          /dev/sda1      vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
          [Wed Nov 26 23:27:25 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:FD:B9:8E vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=52510db9-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GE
          [Wed Nov 26 23:27:27 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Nov 26 23:27:27 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Wed Nov 26 23:27:28 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.7G    /var/
          1.3G    /var/log/journal/b741e8f8772549608ef992fc5da67892
          1.3G    /var/log
          150M    /var/lib
          Archived and active journals take up 1.2G in the file system.
          /opt/iobroker/backups:
          49M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          278M    /opt/iobroker/iobroker-data/
          202M    /opt/iobroker/iobroker-data/files
          53M     /opt/iobroker/iobroker-data/backup-objects
          47M     /opt/iobroker/iobroker-data/files/admin.admin
          46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
          22M     /opt/iobroker/iobroker-data/objects.jsonl
          9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
          9.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js
          8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
          5.9M    /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** ZigBee Settings ***
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v22.21.0
          /usr/bin/node           v22.21.0
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          /usr/bin/corepack       0.34.0
          nodejs:
            Installed: 22.21.0-1nodesource1
            Candidate: 22.21.0-1nodesource1
            Version table:
           *** 22.21.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
               22.20.0-1nodesource1 1001
               22.19.0-1nodesource1 1001
               22.18.0-1nodesource1 1001
               22.17.1-1nodesource1 1001
               22.17.0-1nodesource1 1001
               22.16.0-1nodesource1 1001
               22.15.1-1nodesource1 1001
               22.15.0-1nodesource1 1001
               22.14.0-1nodesource1 1001
               22.13.1-1nodesource1 1001
               22.13.0-1nodesource1 1001
               22.12.0-1nodesource1 1001
               22.11.0-1nodesource1 1001
               22.10.0-1nodesource1 1001
               22.9.0-1nodesource1 1001
               22.8.0-1nodesource1 1001
               22.7.0-1nodesource1 1001
               22.6.0-1nodesource1 1001
               22.5.1-1nodesource1 1001
               22.5.0-1nodesource1 1001
               22.4.1-1nodesource1 1001
               22.4.0-1nodesource1 1001
               22.3.0-1nodesource1 1001
               22.2.0-1nodesource1 1001
               22.1.0-1nodesource1 1001
               22.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u7 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 93)
          Core adapters versions
          js-controller:  7.0.7
          admin:          7.7.19
          javascript:     8.9.2
          nodejs modules from github:     1
          +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
          Adapter State
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
            system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
            system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 - disabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
            system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
            system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
            system.adapter.switchbot-hub.0          : switchbot-hub         : iobroker                                 -  enabled
            system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            system.adapter.vis-homekittiles.0       : vis-homekittiles      : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
            system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
          + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
            system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.7.19   , installed 7.7.19
          Adapter    "backitup"     : 3.3.10   , installed 3.3.5  [Updatable]
          Adapter    "email"        : 2.0.4    , installed 2.0.4
          Adapter    "eusec"        : 2.0.3    , installed 1.3.3  [Updatable]
          Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
          Adapter    "homekit-controller": 0.5.11, installed 0.5.11
          Adapter    "javascript"   : 9.0.11   , installed 8.9.2  [Updatable]
          Controller "js-controller": 7.0.7    , installed 7.0.7
          Adapter    "notification-manager": 1.3.0, installed 1.2.1 [Updatable]
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "shelly"       : 10.4.1   , installed 10.1.0 [Updatable]
          Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
          Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
          Adapter    "vis-2"        : 2.13.4   , installed 2.12.12 [Updatable]
          Adapter    "vis-homekittiles": 0.4.6 , installed 0.4.6
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "yahka"        : 1.1.5    , installed 1.1.5
          Adapter    "zigbee"       : 3.1.5    , installed 2.0.5  [Updatable]
          Objects and States
          Objects:        4183
          States:         3393
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       922170     58368/iobroker.js-c
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       922175     58368/iobroker.js-c
          tcp        0      0 0.0.0.0:45803           0.0.0.0:*               LISTEN      1001       921587     58583/io.yahka.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14435      526/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:34961         0.0.0.0:*               LISTEN      1001       921590     58583/io.yahka.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14437      526/sshd: /usr/sbin
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       925758     58693/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       923121     58396/io.admin.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13260      701/dhcpcd
          udp        0      0 0.0.0.0:45424           0.0.0.0:*                           108        3811       394/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       925861     58757/io.wled.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        3809       394/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       924709     58558/io.shelly.0
          udp6       0      0 :::33278                :::*                                108        3812       394/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        3810       394/avahi-daemon: r
          2025-11-29 11:43:58.415  - info: web.0 (58693) socket.io server listening on port 8082
          2025-11-29 11:43:58.423  - info: web.0 (58693) http server listening on port 8082
          2025-11-29 11:43:58.888  - info: host.iobroker instance system.adapter.vis-2.0 in version "2.12.12" started with pid 58712
          2025-11-29 11:44:01.455  - info: vis-2.0 (58712) starting. Version 2.12.12 in /opt/iobroker/node_modules/iobroker.vis-2, node: v22.21.0, js-controller: 7.0.7
          2025-11-29 11:44:01.705  - info: vis-2.0 (58712) vis-2 license is OK.
          2025-11-29 11:44:05.021  - info: vis.0 (58727) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v22.21.0, js-controller: 7.0.7
          2025-11-29 11:44:05.688  - info: vis.0 (58727) Terminated (NO_ERROR): Without reason
          2025-11-29 11:44:06.254  - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
          2025-11-29 11:44:06.948  - info: host.iobroker instance system.adapter.switchbot-hub.0 in version "0.1.2" (non-npm: DrozmotiX/ioBroker.switchbot-hub#7a05fa59dfc5e3ce8d73018badc4e420996452f8) started with pid 58742
          2025-11-29 11:44:09.535  - info: switchbot-hub.0 (58742) starting. Version 0.1.2 (non-npm: DrozmotiX/ioBroker.switchbot-hub#7a05fa59dfc5e3ce8d73018badc4e420996452f8) in /opt/iobroker/node_modules/iobroker.switchbot-hub, node: v22.21.0, js-controller: 7.0.7
          2025-11-29 11:44:09.821  - info: switchbot-hub.0 (58742) Connected to SwitchBot API found 14 devices
          2025-11-29 11:44:10.958  - info: host.iobroker instance system.adapter.wled.0 in version "0.7.2" started with pid 58757
          2025-11-29 11:44:12.944  - info: switchbot-hub.0 (58742) All devices and values loaded, adapter ready
          2025-11-29 11:44:13.997  - info: wled.0 (58757) starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.wled, node: v22.21.0, js-controller: 7.0.7
          2025-11-29 11:44:14.099  - info: wled.0 (58757) Try to contact 1 known devices
          2025-11-29 11:44:14.100  - info: wled.0 (58757) Try to contact : "WLED" on IP : 192.168.20.196
          2025-11-29 11:44:14.893  - info: host.iobroker instance system.adapter.smartgarden.0 in version "2.0.1" started with pid 58772
          2025-11-29 11:44:16.816  - info: cloud.0 (58604) Trying to connect as system.user.admin to cloud
          2025-11-29 11:44:16.935  - info: cloud.0 (58604) Connection changed: connect
          2025-11-29 11:44:17.138  - info: wled.0 (58757) Bonjour service started, new  devices  will  be detected automatically
          2025-11-29 11:44:17.501  - info: smartgarden.0 (58772) starting. Version 2.0.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v22.21.0, js-controller: 7.0.7
          2025-11-29 11:44:27.146  - info: wled.0 (58757) WLED initialisation finalized, ready to do my job have fun !
          2025-11-29 11:44:48.805  - info: solarwetter.0 (58619) force terminating adapter after 1 minute
          2025-11-29 11:44:48.859  - info: solarwetter.0 (58619) Terminated (NO_ERROR): Without reason
          2025-11-29 11:44:49.430  - info: host.iobroker instance system.adapter.solarwetter.0 terminated with code 0 (NO_ERROR)
          iob diag has finished.
          • R Rainman
            iob diag
            zum Besten.
            Script v.2025-08-09
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            Ra1nman
            HOME=/home/Ra1nman
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     7811 M total memory
                     1584 M used memory
                     4239 M free memory
                      151 M buffer memory
                     1836 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            /var:
            1.7G    /var/
            1.3G    /var/log
            150M    /var/lib
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.7.19
            javascript:     8.9.2
            Adapter State
            + instance is alive
            Objects and States
            Objects:        4183
            States:         3393
            Pending Updates: 0
            Richtig. Installier da NEU das aktuelle Release.
            In-line-Upgrades von RaspberryOS 11 aus funktionieren nicht.
            Also jetzt alles auf Stand bringen, davon ein Backup ziehen und mit dem dann in den Neubau umziehen.
            • R Offline
              Rainman
              schrieb am zuletzt editiert von Rainman
              @Thomas-Braun
              klingt erstmal einfach, wenn Du es schreibst... :-D
              Anleitungen dazu finde ich hier im Forum nehme ich an?
              • R Rainman
                @Thomas-Braun
                @Rainman
                https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                  @Rainman
                  Rainman
                  @Rainman
                  Vielen Dank für alles!
                  • mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    Der Vollstänsigkeit halber:
                    node.js 24 sollte eigentlich von den allermeisten Adaptern unterstützt werden. Derzeit sind aus Sicht core auch keine Probleme mit node.js 24 bekannt.
                    Die Fehlermeldung
                    erhältst du weil irgendein Adapter node.js 24 (noch) nicht unterstützt. Das ist jedenffalls sicher nicht backitup und auch nicht eusec. Node versucht bei jeder Installation die gesammte node Installation valide zu halten und daher triggern auch Updates anderer Adapter diese Fehlermeldung.
                    Ich weiß nicht welcher Adapter hap-nodejs verwendet (ev. als sub-sub-dependency.Via geeignetem npm ls ... sollte sich das aber rausfinden lassen. Ev. muss dieser Adapter als erstes Aktualisisert werden - oder du wartest bis dor t der Support gegeben ist. Ein heißer Kandidat für diese Dependency wäre z.B. yahka.
                    Siehe https://github.com/jensweigele/ioBroker.yahka/issues/541
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • mcm1957M mcm1957
                      Die Fehlermeldung
                      @mcm1957 sagte in nach node js Update - npm bad error EBADENGINE:
                      hap-nodejs
                      Und in aktueller Version ist das Modul auch mit aktuelleren nodejs-Versionen kompatibel.
                      Da war nur ein (indirektes) Update erforderlich.
                      Da muss man aber halt seine Adapter auch auf Stand halten...
