  4. sourceanalytix Erkennung der Rücksetzung des Gerätes
    6.5k
12 Beiträge 3 Kommentatoren 739 Aufrufe 2 Beobachtet
    Snopy_16
    Hallo
    Ich verstehe die Funktion noch nicht wirklich, insbesondere warum ich solche Fehler bekomme.
    sourceanalytix.0
    2025-11-05 11:49:28.126	warn	[Cannot enable SourceAnalytix for 0_userdata.0.GEA.PV-Überschuss, check settings and error messages
    sourceanalytix.0
    2025-11-05 11:49:28.126	error	Cannot handle calculations for 0_userdata.0.GEA.PV-Überschuss, check log messages and adjust settings!
    sourceanalytix.0
    2025-11-05 11:49:28.126	error	Troubleshoot Data 0_userdata.0.GEA.PV-Überschuss custom Data : {"common":{"name":"PV-Überschuss","desc":"Manuell erzeugt","role":"state","type":"number","unit":"kW","read":true,"write":true,"def":0,"color":"#34d115","custom":{"history.0":{"enabled":true,"aliasId":"PV-Überschuss","debounceTime":0,"blockTime":3000,"changesOnly":false,"changesRelogInterval":"0","changesMinDelta":"0","ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":"31536000","customRetentionDuration":365,"maxLength":"960","enableDebugLogs":false,"debounce":"1000","chartStep":""},"influxdb.0":{"enabled":true,"storageType":"","aliasId":"PV-Überschuss","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.0":{"enabled":true,"selectedUnit":"kW","deviceResetLogicEnabled":false,"threshold":1,"start_day":0,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"role":"value.power","alias":"PV-Überschuss","selectedPrice":"ElectricityDay","meter_values":true,"consumption":true}}},"type":"state","native":{},"_id":"0_userdata.0.GEA.PV-Überschuss","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1762339768120}
    sourceanalytix.0
    2025-11-05 11:49:28.126	error	Check settings for 0_userdata.0.GEA.PV-Überschuss ! Known valueAtDeviceReset : (null) > known cumulative value (-659.5707572222217) cannot proceed
    sourceanalytix.0
    2025-11-05 11:49:28.123	info	Enable SourceAnalytix for : 0_userdata.0.GEA.PV-Überschuss
    Gibt es eine Abhilfe, ohne den Datenpunkt aus sourceanalytix zu entfernen und dann wieder neu anzulegen. Es sind doch Einige mit diesem Fehler.
    Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
    LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
    iobroker auf Proxmox VM
    Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
    FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
    HomoranH crunchipC 2 Antworten Letzte Antwort
    • S Snopy_16
      Hallo
      sourceanalytix.0
      sourceanalytix.0
      sourceanalytix.0
      sourceanalytix.0
      sourceanalytix.0
      @snopy_16 sagte in sourceanalytix Erkennung der Rücksetzung des Gerätes:
      wie ist denn der Wert jetzt?
      ist das so?
      welcher "Fehler"?
      • S Snopy_16
        Hallo
        sourceanalytix.0
        sourceanalytix.0
        sourceanalytix.0
        sourceanalytix.0
        sourceanalytix.0
        crunchipC Offline
        crunchipC Offline
        Zeig mal das Raw von 0_userdata.0.GEA.PV-Überschuss
          ist das so?
          welcher "Fehler"?
          Snopy_16
          @homoran so ist der LOG nach Neustart des Adapters
          sourceanalytix.0
          2025-11-05 17:46:32.916	info	Initialization of 0_userdata.0.GEA.PV-GEA successfully
          sourceanalytix.0
          2025-11-05 17:46:32.462	info	Initialising "0_userdata.0.GEA.PV-GEA" | (40 of 47)
          sourceanalytix.0
          2025-11-05 17:46:32.462	error	Initialization of 0_userdata.0.GEA.PV-Überschuss failed, check warn messages !
          sourceanalytix.0
          2025-11-05 17:46:32.462	error	Cannot handle calculations for 0_userdata.0.GEA.PV-Überschuss, check log messages and adjust settings!
          sourceanalytix.0
          2025-11-05 17:46:32.462	error	Troubleshoot Data 0_userdata.0.GEA.PV-Überschuss custom Data : {"common":{"name":"PV-Überschuss","desc":"Manuell erzeugt","role":"state","type":"number","unit":"kW","read":true,"write":true,"def":0,"color":"#34d115","custom":{"history.0":{"enabled":true,"aliasId":"PV-Überschuss","debounceTime":0,"blockTime":3000,"changesOnly":false,"changesRelogInterval":"0","changesMinDelta":"0","ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":"31536000","customRetentionDuration":365,"maxLength":"960","enableDebugLogs":false,"debounce":"1000","chartStep":""},"influxdb.0":{"enabled":true,"storageType":"","aliasId":"PV-Überschuss","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.0":{"enabled":true,"selectedUnit":"kW","deviceResetLogicEnabled":false,"threshold":1,"start_day":0,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"role":"value.power","alias":"PV-Überschuss","selectedPrice":"ElectricityDay","meter_values":true,"consumption":true}}},"type":"state","native":{},"_id":"0_userdata.0.GEA.PV-Überschuss","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1762339768120}
          sourceanalytix.0
          2025-11-05 17:46:32.462	error	Check settings for 0_userdata.0.GEA.PV-Überschuss ! Known valueAtDeviceReset : (null) > known cumulative value (-659.5707572222217) cannot proceed
          sourceanalytix.0
          2025-11-05 17:46:32.418	info	Initialising "0_userdata.0.GEA.PV-Überschuss" | (39 of 47)
          sourceanalytix.0
          2025-11-05 17:46:32.418	info	Initialization of 0_userdata.0.GEA.PV-Erzeugung successfully
          sourceanalytix.0
          2025-11-05 17:46:31.940	info	Initialising "0_userdata.0.GEA.PV-Erzeugung" | (38 of 47)
          sourceanalytix.0
          2025-11-05 17:46:31.940	info	Initialization of 0_userdata.0.GEA.PV-Hausverbrauch successfully
          sourceanalytix.0
          2025-11-05 17:46:31.496	info	Initialising "0_userdata.0.GEA.PV-Hausverbrauch" | (37 of 47)
          sourceanalytix.0
          2025-11-05 17:46:31.496	info	Initialization of 0_userdata.0.GEA.Zählerstand successfully
          sourceanalytix.0
          2025-11-05 17:46:30.898	info	Initialising "0_userdata.0.GEA.Zählerstand" | (36 of 47)
          sourceanalytix.0
          2025-11-05 17:46:30.898	error	Initialization of 0_userdata.0.GEA.Netz failed, check warn messages !
          sourceanalytix.0
          2025-11-05 17:46:30.898	error	Cannot handle calculations for 0_userdata.0.GEA.Netz, check log messages and adjust settings!
          sourceanalytix.0
          2025-11-05 17:46:30.898	error	Troubleshoot Data 0_userdata.0.GEA.Netz custom Data : {"common":{"name":"Netz","desc":"Manuell erzeugt","role":"state","type":"number","unit":"kWh","read":true,"write":true,"def":0,"custom":{"influxdb.0":{"enabled":true,"storageType":"","aliasId":"GEA_Netz","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":52877386.99999999,"start_week":52877386.99999999,"start_month":52877386.99999999,"start_quarter":52870555,"start_year":51618,"alias":"GEA_Netz","selectedPrice":"ElectricityDay","consumption":true,"meter_values":true,"costs":true,"valueAtDeviceReset":211797945,"valueAtDeviceInit":-21798,"cumulativeValue":52877386.99999999}}},"type":"state","native":{},"_id":"0_userdata.0.GEA.Netz","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1759772902455}
          sourceanalytix.0
          2025-11-05 17:46:30.897	error	Check settings for 0_userdata.0.GEA.Netz ! Known valueAtDeviceReset : (211797945) > known cumulative value (159482457) cannot proceed
          sourceanalytix.0
          2025-11-05 17:46:30.852	info	Initialising "0_userdata.0.GEA.Netz" | (35 of 47)
          sourceanalytix.0
          2025-11-05 17:46:30.852	info	Initialization of 0_userdata.0.GEA.Hubi_Netzbezug successfully
          sourceanalytix.0
          2025-11-05 17:46:30.405	info	Initialising "0_userdata.0.GEA.Hubi_Netzbezug" | (34 of 47)
          sourceanalytix.0
          2025-11-05 17:46:30.405	info	Initialization of 0_userdata.0.GEA.Hubi_GEABezug successfully
          sourceanalytix.0
          2025-11-05 17:46:29.793	info	Initialising "0_userdata.0.GEA.Hubi_GEABezug" | (33 of 47)
          sourceanalytix.0
          2025-11-05 17:46:29.793	info	Initialization of modbus.0.holdingRegisters.1790_Momentanleistung successfully
          sourceanalytix.0
          2025-11-05 17:46:29.342	info	Initialising "modbus.0.holdingRegisters.1790_Momentanleistung" | (32 of 47)
          sourceanalytix.0
          2025-11-05 17:46:29.342	error	Initialization of modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz failed, check warn messages !
          sourceanalytix.0
          2025-11-05 17:46:29.341	error	Cannot handle calculations for modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz, check log messages and adjust settings!
          sourceanalytix.0
          2025-11-05 17:46:29.341	error	Troubleshoot Data modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz custom Data : {"_id":"modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz","type":"state","common":{"name":"Wärmemenge Elektroheizstab","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"kWh","custom":{"influxdb.0":{"enabled":true,"storageType":"","aliasId":"WP_Wärmemenge_Elektroheizstab","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":0,"start_week":0,"start_month":0,"start_quarter":0,"start_year":0,"alias":"WP_Wärmemenge_Elektroheizstab","selectedPrice":"ElectricityDay","consumption":true,"meter_values":true,"valueAtDeviceReset":0,"valueAtDeviceInit":-1000}}},"native":{"regType":"holdingRegs","address":1762,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.modbus.0","user":"system.user.admin","ts":1762339458407}
          sourceanalytix.0
          2025-11-05 17:46:29.341	error	Check settings for modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz ! Known valueAtDeviceReset : (0) > known cumulative value (-1000) cannot proceed
          sourceanalytix.0
          2025-11-05 17:46:29.297	info	Initialising "modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz" | (31 of 47)
          sourceanalytix.0
          2025-11-05 17:46:29.296	info	Initialization of modbus.0.holdingRegisters.1756_Wärmemenge_Abtauung successfully
          sourceanalytix.0
          2025-11-05 17:46:28.828	info	Initialising "modbus.0.holdingRegisters.1756_Wärmemenge_Abtauung" | (30 of 47)
          sourceanalytix.0
          2025-11-05 17:46:28.827	info	Initialization of modbus.0.holdingRegisters.1754__Wärmemenge_Warmwasser successfully
          sourceanalytix.0
          2025-11-05 17:46:28.375	info	Initialising "modbus.0.holdingRegisters.1754__Wärmemenge_Warmwasser" | (29 of 47)
          sourceanalytix.0
          2025-11-05 17:46:28.375	info	Initialization of modbus.0.holdingRegisters.4122_Aktuelle_Leistungsaufnahme_Wärmepumpe successfully
          sourceanalytix.0
          2025-11-05 17:46:27.908	info	Initialising "modbus.0.holdingRegisters.4122_Aktuelle_Leistungsaufnahme_Wärmepumpe" | (28 of 47)
          sourceanalytix.0
          2025-11-05 17:46:27.908	info	Initialization of 0_userdata.0.Wärmepumpe.WP-Gesamt_E successfully
          sourceanalytix.0
          2025-11-05 17:46:27.453	info	Initialising "0_userdata.0.Wärmepumpe.WP-Gesamt_E" | (27 of 47)
          sourceanalytix.0
          2025-11-05 17:46:27.453	info	Initialization of 0_userdata.0.Wärmepumpe.WP-Gesamt_P successfully
          sourceanalytix.0
          2025-11-05 17:46:26.941	info	Initialising "0_userdata.0.Wärmepumpe.WP-Gesamt_P" | (26 of 47)
          sourceanalytix.0
          2025-11-05 17:46:26.941	info	Initialization of shelly.0.shelly3em63g3#28372f367114#1.EMData0.TotalActiveEnergy successfully
          sourceanalytix.0
          2025-11-05 17:46:26.499	info	Initialising "shelly.0.shelly3em63g3#28372f367114#1.EMData0.TotalActiveEnergy" | (25 of 47)
          sourceanalytix.0
          2025-11-05 17:46:26.499	info	Initialization of shelly.0.shelly3em63g3#28372f367528#1.EMData0.TotalActiveEnergy successfully
          sourceanalytix.0
          2025-11-05 17:46:26.013	info	Initialising "shelly.0.shelly3em63g3#28372f367528#1.EMData0.TotalActiveEnergy" | (24 of 47)
          sourceanalytix.0
          2025-11-05 17:46:26.013	info	Initialization of shelly.0.shellypmminig3#5432045c0d78#1.PM1:0.Energy successfully
          sourceanalytix.0
          2025-11-05 17:46:25.522	info	Initialising "shelly.0.shellypmminig3#5432045c0d78#1.PM1:0.Energy" | (23 of 47)
          sourceanalytix.0
          2025-11-05 17:46:25.521	info	Initialization of zigbee.0.a4c138756ad7095e.energy successfully
          sourceanalytix.0
          2025-11-05 17:46:25.087	info	Initialising "zigbee.0.a4c138756ad7095e.energy" | (22 of 47)
          sourceanalytix.0
          2025-11-05 17:46:25.087	info	Initialization of zigbee.0.a4c138512b5dec69.energy successfully
          sourceanalytix.0
          2025-11-05 17:46:24.648	info	Initialising "zigbee.0.a4c138512b5dec69.energy" | (21 of 47)
          sourceanalytix.0
          2025-11-05 17:46:24.648	info	Initialization of upnp.0.WANDevice_-_FRITZ!Box_7530.WANDevice.WANCommonInterfaceConfig.TotalBytesSent successfully
          sourceanalytix.0
          2025-11-05 17:46:24.213	info	Initialising "upnp.0.WANDevice_-_FRITZ!Box_7530.WANDevice.WANCommonInterfaceConfig.TotalBytesSent" | (20 of 47)
          sourceanalytix.0
          2025-11-05 17:46:24.212	info	Initialization of upnp.0.WANDevice_-_FRITZ!Box_7530.WANDevice.WANCommonInterfaceConfig.TotalBytesReceived successfully
          sourceanalytix.0
          2025-11-05 17:46:23.770	info	Initialising "upnp.0.WANDevice_-_FRITZ!Box_7530.WANDevice.WANCommonInterfaceConfig.TotalBytesReceived" | (19 of 47)
          sourceanalytix.0
          2025-11-05 17:46:23.770	error	Initialization of tuya.0.703384143c6105ebb2c8.19 failed, check warn messages !
          sourceanalytix.0
          2025-11-05 17:46:23.770	error	Cannot handle calculations for tuya.0.703384143c6105ebb2c8.19, check log messages and adjust settings!
          sourceanalytix.0
          2025-11-05 17:46:23.769	error	Troubleshoot Data tuya.0.703384143c6105ebb2c8.19 custom Data : {"type":"state","common":{"type":"number","unit":"W","scale":1,"min":0,"max":5000,"read":true,"write":false,"name":"cur_power","role":"value","custom":{"history.0":{"enabled":true,"aliasId":"Poolpumpe_Leistung","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":"0","changesMinDelta":"0","ignoreBelowNumber":"","disableSkippedValueLogging":false,"retention":"31536000","customRetentionDuration":365,"maxLength":"960","enableDebugLogs":false,"debounce":"1000"},"influxdb.0":{"enabled":true,"storageType":"","aliasId":"Poolpumpe_Leistung","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Wh","deviceResetLogicEnabled":true,"threshold":1,"start_day":171227.99999999997,"start_week":158030.49999999988,"start_month":156189.39999999988,"start_quarter":6671.2999999999965,"start_year":6671.2999999999965,"alias":"Poolpumpe","selectedPrice":"ElectricityDay","valueAtDeviceReset":171227.99999999997,"valueAtDeviceInit":199.2,"cumulativeValue":171227.99999999997}}},"native":{"mode":"ro","code":"cur_power","name":"当前功率","property":{"unit":"W","min":0,"max":50000,"scale":1,"step":1,"type":"value"},"iconname":"icon-dp_tool","id":19,"type":"obj","defaultValue":"","canTrigger":true,"executable":true,"defaultRecommend":false,"editPermission":false,"subType":"value"},"_id":"tuya.0.703384143c6105ebb2c8.19","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.tuya.0","user":"system.user.admin","ts":1761156600976}
          sourceanalytix.0
          2025-11-05 17:46:23.769	error	Check settings for tuya.0.703384143c6105ebb2c8.19 ! Known valueAtDeviceReset : (171227.99999999997) > known cumulative value (171226.3) cannot proceed
          sourceanalytix.0
          2025-11-05 17:46:23.726	info	Initialising "tuya.0.703384143c6105ebb2c8.19" | (18 of 47)
          sourceanalytix.0
          2025-11-05 17:46:23.725	info	Initialization of sonoff.0.Steckdose 9.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:23.253	info	Initialising "sonoff.0.Steckdose 9.ENERGY_Total" | (17 of 47)
          sourceanalytix.0
          2025-11-05 17:46:23.253	info	Initialization of sonoff.0.Steckdose 8.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:22.738	info	Initialising "sonoff.0.Steckdose 8.ENERGY_Total" | (16 of 47)
          sourceanalytix.0
          2025-11-05 17:46:22.738	info	Initialization of sonoff.0.Steckdose 7.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:22.291	info	Initialising "sonoff.0.Steckdose 7.ENERGY_Total" | (15 of 47)
          sourceanalytix.0
          2025-11-05 17:46:22.290	info	Initialization of sonoff.0.Steckdose 6.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:21.847	info	Initialising "sonoff.0.Steckdose 6.ENERGY_Total" | (14 of 47)
          sourceanalytix.0
          2025-11-05 17:46:21.847	info	Initialization of sonoff.0.Steckdose 5.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:21.382	info	Initialising "sonoff.0.Steckdose 5.ENERGY_Total" | (13 of 47)
          sourceanalytix.0
          2025-11-05 17:46:21.382	error	Initialization of sonoff.0.Steckdose 4.ENERGY_Total failed, check warn messages !
          sourceanalytix.0
          2025-11-05 17:46:21.382	error	Cannot handle calculations for sonoff.0.Steckdose 4.ENERGY_Total, check log messages and adjust settings!
          sourceanalytix.0
          2025-11-05 17:46:21.382	error	Troubleshoot Data sonoff.0.Steckdose 4.ENERGY_Total custom Data : {"_id":"sonoff.0.Steckdose 4.ENERGY_Total","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Steckdose 4 ENERGY Total","custom":{"statistics.0":{"enabled":true,"count":false,"fiveMin":false,"sumCount":false,"impUnitPerImpulse":1,"impUnit":"","timeCount":false,"avg":true,"minmax":false,"sumDelta":true,"sumIgnoreMinus":false,"groupFactor":1,"logName":"4* EDV"},"influxdb.0":{"enabled":true,"storageType":"","aliasId":"Steckdose4","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":1,"start_day":190827,"start_week":189537,"start_month":163228,"start_quarter":121484,"start_year":104456,"alias":"Steckdose4","selectedPrice":"ElectricityDay","consumption":true,"meter_values":true,"valueAtDeviceReset":191575,"valueAtDeviceInit":103242,"cumulativeValue":190827}}},"native":{},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1758630128955}
          sourceanalytix.0
          2025-11-05 17:46:21.382	error	Check settings for sonoff.0.Steckdose 4.ENERGY_Total ! Known valueAtDeviceReset : (191575) > known cumulative value (103264) cannot proceed
          sourceanalytix.0
          2025-11-05 17:46:21.337	info	Initialising "sonoff.0.Steckdose 4.ENERGY_Total" | (12 of 47)
          sourceanalytix.0
          2025-11-05 17:46:21.337	info	Initialization of sonoff.0.Steckdose 3.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:20.896	info	Initialising "sonoff.0.Steckdose 3.ENERGY_Total" | (11 of 47)
          sourceanalytix.0
          2025-11-05 17:46:20.896	info	Initialization of sonoff.0.Steckdose 2.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:20.466	info	Initialising "sonoff.0.Steckdose 2.ENERGY_Total" | (10 of 47)
          sourceanalytix.0
          2025-11-05 17:46:20.466	info	Initialization of sonoff.0.Steckdose 12.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:19.810	info	Initialising "sonoff.0.Steckdose 12.ENERGY_Total" | (9 of 47)
          sourceanalytix.0
          2025-11-05 17:46:19.810	info	Initialization of sonoff.0.Steckdose 11.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:19.350	info	Initialising "sonoff.0.Steckdose 11.ENERGY_Total" | (8 of 47)
          sourceanalytix.0
          2025-11-05 17:46:19.350	info	Initialization of sonoff.0.Steckdose 10.ENERGY_Total successfully
          sourceanalytix.0
          2025-11-05 17:46:18.875	info	Initialising "sonoff.0.Steckdose 10.ENERGY_Total" | (7 of 47)
          sourceanalytix.0
          2025-11-05 17:46:18.875	error	Initialization of sonoff.0.Steckdose 1.ENERGY_Total failed, check warn messages !
          sourceanalytix.0
          2025-11-05 17:46:18.874	error	Cannot handle calculations for sonoff.0.Steckdose 1.ENERGY_Total, check log messages and adjust settings!
          sourceanalytix.0
          2025-11-05 17:46:18.874	error	Troubleshoot Data sonoff.0.Steckdose 1.ENERGY_Total custom Data : {"_id":"sonoff.0.Steckdose 1.ENERGY_Total","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Steckdose 1 ENERGY Total","custom":{"statistics.0":{"enabled":true,"count":false,"fiveMin":false,"sumCount":false,"impUnitPerImpulse":1,"impUnit":"","timeCount":false,"avg":false,"minmax":false,"sumDelta":true,"sumIgnoreMinus":false,"groupFactor":1,"logName":"1* Backrohr"},"influxdb.0":{"enabled":true,"storageType":"","aliasId":"Steckdose1","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":1,"start_day":273429,"start_week":272358,"start_month":262240,"start_quarter":263469,"start_year":60038,"alias":"Steckdose1","selectedPrice":"ElectricityDay","consumption":true,"meter_values":true,"valueAtDeviceReset":273434,"valueAtDeviceInit":58536,"cumulativeValue":273429}}},"native":{},"type":"state","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1756362142813}
          sourceanalytix.0
          2025-11-05 17:46:18.873	error	Check settings for sonoff.0.Steckdose 1.ENERGY_Total ! Known valueAtDeviceReset : (273434) > known cumulative value (253035) cannot proceed
          sourceanalytix.0
          2025-11-05 17:46:18.831	info	Initialising "sonoff.0.Steckdose 1.ENERGY_Total" | (6 of 47)
            Snopy_16
            @crunchip Ist das, was du sehen willst?
              "common": {
                "name": "PV-Überschuss",
                "desc": "Manuell erzeugt",
                "role": "state",
                "type": "number",
                "unit": "kW",
                "read": true,
                "write": true,
                "def": 0,
                "color": "#34d115",
                "custom": {
                  "history.0": {
                    "enabled": true,
                    "aliasId": "PV-Überschuss",
                    "debounceTime": 0,
                    "blockTime": 3000,
                    "changesOnly": false,
                    "changesRelogInterval": "0",
                    "changesMinDelta": "0",
                    "ignoreBelowNumber": "",
                    "disableSkippedValueLogging": false,
                    "retention": "31536000",
                    "customRetentionDuration": 365,
                    "maxLength": "960",
                    "enableDebugLogs": false,
                    "debounce": "1000",
                    "chartStep": ""
                  "influxdb.0": {
                    "enabled": true,
                    "storageType": "",
                    "debounceTime": 0,
                    "blockTime": 0,
                    "changesOnly": true,
                    "changesRelogInterval": 0,
                    "changesMinDelta": 0,
                    "debounce": 1000
                  "sourceanalytix.0": {
                    "enabled": true,
                    "selectedUnit": "kW",
                    "deviceResetLogicEnabled": false,
                    "threshold": 1,
                    "start_day": 0,
                    "start_week": 0,
                    "start_month": 0,
                    "start_quarter": 0,
                    "start_year": 0,
                    "role": "value.power",
                    "alias": "PV-Überschuss",
                    "selectedPrice": "ElectricityDay",
                    "meter_values": true,
                    "consumption": true
              "type": "state",
              "native": {},
              "_id": "0_userdata.0.GEA.PV-Überschuss",
              "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
              "user": "system.user.admin",
              "ts": 1762339768120
            • S Snopy_16
                "common": {
                  "role": "state",
                  "type": "number",
                  "unit": "kW",
                  "read": true,
                  "write": true,
                  "def": 0,
                  "color": "#34d115",
                  "custom": {
                    "history.0": {
                      "enabled": true,
                      "debounceTime": 0,
                      "blockTime": 3000,
                      "maxLength": "960",
                      "debounce": "1000",
                      "chartStep": ""
                    "influxdb.0": {
                      "enabled": true,
                      "storageType": "",
                      "debounceTime": 0,
                      "blockTime": 0,
                      "debounce": 1000
                      "enabled": true,
                      "threshold": 1,
                      "start_day": 0,
                      "start_week": 0,
                      "start_month": 0,
                      "start_quarter": 0,
                      "start_year": 0,
                      "consumption": true
                "type": "state",
                "native": {},
                "acl": {
                  "object": 1636,
                  "state": 1636,
                "ts": 1762339768120
              crunchipC Offline
              crunchipC Offline
              @snopy_16 ja das wollt ich sehen, da ist kein device reset hinterlegt, weil
              Deine Unit nicht übereinstimmt
              KW ist nicht gleich KWh
                Snopy_16
                @crunchip Unit hab ich mit kW bewusst so gesetzt, da es ein Leistungswert ist. dieser soll in sourceanalytix dann aufsummiert werden auf kWh. Oder steh ich auf dem Schlauch?
                • S Snopy_16
                  Snopy_16
                  @snopy_16 Noch so ein ähnlicher Fall, aber nun wirklich die Energie. Leider hat die noch nicht zu zählen angefangen und wird mit einem Wert von -1 kWh übertragen.
                  Raw ist:
                    "_id": "modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz",
                    "type": "state",
                    "common": {
                      "name": "Wärmemenge Elektroheizstab",
                      "role": "level",
                      "type": "number",
                      "read": true,
                      "write": true,
                      "def": 0,
                      "unit": "kWh",
                      "custom": {
                        "influxdb.0": {
                          "enabled": true,
                          "storageType": "",
                          "aliasId": "WP_Wärmemenge_Elektroheizstab",
                          "debounceTime": 0,
                          "blockTime": 0,
                          "debounce": 1000
                          "enabled": true,
                          "selectedUnit": "kWh",
                          "deviceResetLogicEnabled": true,
                          "threshold": 1,
                          "start_day": "",
                          "start_week": "",
                          "start_month": "",
                          "start_quarter": "",
                          "start_year": 0,
                          "alias": "WP_Wärmemenge_Elektroheizstab",
                          "valueAtDeviceReset": 0,
                          "valueAtDeviceInit": -1000,
                          "consumption": true
                    "native": {
                      "regType": "holdingRegs",
                      "address": 1762,
                      "deviceId": 1,
                      "type": "floatsw",
                      "len": 2,
                      "offset": 0,
                      "factor": 1,
                      "poll": true
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                    "ts": 1762368594966
                  sourceanalytix.0
                  2025-11-05 19:49:54.973	warn	[Cannot enable SourceAnalytix for modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz, check settings and error messages
                  sourceanalytix.0
                  2025-11-05 19:49:54.972	error	Cannot handle calculations for modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz, check log messages and adjust settings!
                  sourceanalytix.0
                  2025-11-05 19:49:54.972	error	Troubleshoot Data modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz custom Data : {"_id":"modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz","type":"state","common":{"name":"Wärmemenge Elektroheizstab","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"kWh","custom":{"influxdb.0":{"enabled":true,"storageType":"","aliasId":"WP_Wärmemenge_Elektroheizstab","debounceTime":0,"blockTime":0,"changesOnly":true,"changesRelogInterval":0,"changesMinDelta":0,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false,"debounce":1000},"sourceanalytix.0":{"enabled":true,"selectedUnit":"kWh","deviceResetLogicEnabled":true,"threshold":1,"start_day":"","start_week":"","start_month":"","start_quarter":"","start_year":0,"alias":"WP_Wärmemenge_Elektroheizstab","selectedPrice":"ElectricityDay","valueAtDeviceReset":0,"valueAtDeviceInit":-1000,"meter_values":true,"consumption":true}}},"native":{"regType":"holdingRegs","address":1762,"deviceId":1,"type":"floatsw","len":2,"offset":0,"factor":1,"poll":true},"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1762368594966}
                  sourceanalytix.0
                  2025-11-05 19:49:54.972	error	Check settings for modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz ! Known valueAtDeviceReset : (0) > known cumulative value (-1000) cannot proceed
                  sourceanalytix.0
                  2025-11-05 19:49:54.969	info	Enable SourceAnalytix for : modbus.0.holdingRegisters.1762_Wärmemenge_Elektroheizeinsatz
                  • crunchipC Offline
                    crunchipC Offline
                    @snopy_16 in der Preisdefinition wird die Unit und der Preis hinterlegt
                    z.b.
                    beim jeweiligen Datenpunkt(Zahnrad rechts) nimmst du die eigentliche Einstellung vor, die individuell gilt, also in deinem Fall KW
                    bei den Startwerten muss dann entsprechend der tatsächliche Zählerstand eingetragen werden. Wenn dein Datenpunkt z.b. 555KW hat, trägst du die 555 bei start day ein, den Rest lässt du auf 0. Diese füllen sich dann automatisch nach erreichen der Zeit.
                    Außer du weißt die Werte zum jeweiligen Zeitpunkt, dann kannst du diese auch direkt mit eintragen.
                      z.b.
                      Snopy_16
                      @crunchip Danke mal für die Erklärung.
                      Ich habe noch eine Frage(n)
                      1. Wie geht man vor bei Leistungswert (kW) ist der einmal negativ und dann positiv zählt (Einspeisung/Bezug)
                      2. Bei der letzten Frage (anderer Datenpunkt) habe ich im Datenpunkt (Zähler) die kWh, die zum Zeitpunkt bei -1kWh steht. Diesen Startwert kann ich eben nicht eintrage, da es ein Minuswert ist. Soll man SA erst dann aktivieren, wenn der Zähler den ersten positiven Wert überträgt (also wenn er wirklich zum zählen beginnt)?
                      • S Snopy_16
                        per alias in zwei Datenpunkte mit jeweils positiven Werten splitten!
                          Snopy_16
                          @homoran Danke! Ich glaub das bekomm ich hin.
