  4. javascript.0 bricht ab
    2.9k
    5.0k
    4.1k
javascript
23 Beiträge 6 Kommentatoren 1.7k Aufrufe 4 Beobachtet
    Digi-Bit
    schrieb am zuletzt editiert von Digi-Bit
    Ich habe hier einen merkwürdigen fehler und komm da mit nicht weiter.
    Der javascript Adapter startet dauernd neu ich komm da irgend wie seit 3 Tagen nicht weiter
    Vieleieicht weis hier ja jemand weiter.
    javascript.0
    2025-11-04 17:32:22.619	info	received all states
    javascript.0
    2025-11-04 17:32:20.661	info	received all objects
    javascript.0
    2025-11-04 17:32:15.874	info	requesting all objects
    javascript.0
    2025-11-04 17:32:15.874	info	requesting all states
    javascript.0
    2025-11-04 17:32:14.668	warn	Cannot install custom npm package "setObject@latest"
    javascript.0
    2025-11-04 17:31:53.283	info	starting. Version 8.9.2 in /opt/iobroker/node_modules/iobroker.javascript, node: v22.21.0, js-controller: 7.0.7
    host.debianIOB1
    2025-11-04 17:31:51.602	info	instance system.adapter.javascript.0 in version "8.9.2" started with pid 385701
    tuya.0
    2025-11-04 17:31:50.102	info	33031685500291bdfd1f Init with IP=10.10.136.100, Key=.=N`6!or>A!wti=}, Version=3.3
    tuya.0
    2025-11-04 17:31:50.102	info	33031685500291bdfd1f: Connect locally to device
    host.debianIOB1
    2025-11-04 17:31:50.090	info	Restart adapter system.adapter.javascript.0 because enabled
    host.debianIOB1
    2025-11-04 17:31:50.090	info	instance system.adapter.javascript.0 terminated with code null ()
    host.debianIOB1
    2025-11-04 17:31:50.090	warn	instance system.adapter.javascript.0 terminated due to SIGABRT
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[6]: 8: 0x1cba291 [io.javascript.0]
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[5]: 7: 0x1454428 [io.javascript.0]
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[4]: 6: 0x145125a [io.javascript.0]
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[3]: 5: 0x1438183 [io.javascript.0]
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[2]: 4: 0x1438155 [io.javascript.0]
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[2]: 3: 0x120a877 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0]
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[2]: 2: 0x120a5a0 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [io.javascript.0]
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[1]: 1: 0xe38a0e node::OOMErrorHandler(char const*, v8::OOMDetails const&) [io.javascript.0]
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[1]: ----- Native stack trace -----
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[1]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[1]: <--- JS stacktrace --->
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[1]: [375565:0x2fc25000] 1789588 ms: Mark-Compact 4022.8 (4137.0) -> 4008.5 (4138.8) MB, pooled: 0 MB, 2652.31 / 0.00 ms (average mu = 0.061, current mu = 0.030) allocation failure; scavenge might not succeed
    host.debianIOB1
    2025-11-04 17:31:50.090	error	Caught by controller[1]: [375565:0x2fc25000] 1786855 ms: Mark-Compact 4020.4 (4134.3) -> 4006.1 (4136.3) MB, pooled: 0 MB, 2748.47 / 0.00 ms (average mu = 0.090, current mu = 0.028) allocation failure; scavenge might not succeed
    host.debianIOB1
    2025-11-04 17:31:50.089	error	Caught by controller[1]: <--- Last few GCs --->
    Ich weiss nicht genau was man braucht um zu helfen aber iob diag kann ja nicht falsch sein oder ?
    iob diag:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
    Static hostname: debianIOB1
          Icon name: computer-desktop
            Chassis: desktop 🖥️
             Kernel: Linux 6.12.48+deb13-amd64
       Architecture: x86-64
    Hardware Vendor: Intel_R_ Client Systems
     Hardware Model: NUC11PAHi5
    Firmware Version: PATGL357.0052.2023.0901.1439
      Firmware Date: Fri 2023-09-01
       Firmware Age: 2y 2month 4d
    OS is similar to:
    model name      : 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
    17:42:37 up 19:30,  1 user,  load average: 1.67, 1.12, 0.94
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                  Local time: Tue 2025-11-04 17:42:37 CET
              Universal time: Tue 2025-11-04 16:42:37 UTC
                    RTC time: Tue 2025-11-04 16:42:37
                 NTP service: active
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    digibit
    HOME=/home/digibit
    GROUPS=digibit cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/digibit
    GROUPS=iobroker tty dialout audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             50G        6.9G         38G        4.5M        5.8G         43G
    Swap:           1.0G          0B        1.0G
    Total:           51G        6.9G         39G
    Active iob-Instances:   59
           47807 M total memory
            6548 M used memory
            7540 M active memory
            3393 M inactive memory
           36291 M free memory
            1017 M buffer memory
            4508 M swap cache
             975 M total swap
               0 M used swap
             975 M free swap
    top - 17:42:37 up 19:30,  1 user,  load average: 1.67, 1.12, 0.94
    Tasks: 246 total,   1 running, 245 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 10.3 us,  1.1 sy,  0.0 ni, 87.4 id,  1.1 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  47808.0 total,  36297.7 free,   6542.8 used,   5526.6 buff/cache
    MiB Swap:    976.0 total,    976.0 free,      0.0 used.  41265.2 avail Mem
    *** FAILED SERVICES ***
     UNIT                LOAD   ACTIVE SUB    DESCRIPTION
    * nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
           ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
           SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs   24G     0   24G   0% /dev
    tmpfs          tmpfs     4.7G  1.2M  4.7G   1% /run
    /dev/sda2      ext4      456G   19G  415G   5% /
    tmpfs          tmpfs      24G     0   24G   0% /dev/shm
    efivarfs       efivarfs  192K  110K   78K  59% /sys/firmware/efi/efivars
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs      24G  2.9M   24G   1% /tmp
    /dev/sda1      vfat      511M  4.4M  507M   1% /boot/efi
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/telegraf.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     4.7G  8.0K  4.7G   1% /run/user/1000
    [Mon Nov  3 22:12:24 2025] EXT4-fs (sda2): mounted filesystem 2548fd25-8c0f-46fc-8ad3-8e65ada10bf7 ro with ordered data mode. Quota mode: none.
    [Mon Nov  3 22:12:25 2025] EXT4-fs (sda2): re-mounted 2548fd25-8c0f-46fc-8ad3-8e65ada10bf7 r/w.
    Show mounted filesystems:
    TARGET      SOURCE    FSTYPE OPTIONS
    /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    3.1G    /var/
    1.9G    /var/lib
    838M    /var/lib/influxdb
    837M    /var/lib/influxdb/engine
    827M    /var/lib/mysql
    Archived and active journals take up 289.9M in the file system.
    /opt/iobroker/backups:
    5.9G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.7G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/files
    323M    /opt/iobroker/iobroker-data/backup-objects
    227M    /opt/iobroker/iobroker-data/files/0_userdata.0
    226M    /opt/iobroker/iobroker-data/files/0_userdata.0/VIS
    135M    /opt/iobroker/iobroker-data/states.jsonl
    100M    /opt/iobroker/iobroker-data/objects.jsonl
    85M     /opt/iobroker/iobroker-data/files/0_userdata.0/VIS/Meine_Icons/Netzwerk/peugeot_update (1).exe
    41M     /opt/iobroker/iobroker-data/files/vis-2.0/Meine_Icons/Netzwerk/HeidiSQL_12.5.0.6677_Setup.exe
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.38__Embed_with_CMSIS-DAP_L430047T-if03
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.38__Embed_with_CMSIS-DAP_L430047T-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
     Installed: 22.21.0-1nodesource1
     Candidate: 22.21.0-1nodesource1
     Version table:
    *** 22.21.0-1nodesource1 1001
        22.20.0-1nodesource1 1001
        22.19.0-1nodesource1 1001
        22.18.0-1nodesource1 1001
        22.17.1-1nodesource1 1001
        22.17.0-1nodesource1 1001
        22.16.0-1nodesource1 1001
        22.15.1-1nodesource1 1001
        22.15.0-1nodesource1 1001
        22.14.0-1nodesource1 1001
        22.13.1-1nodesource1 1001
        22.13.0-1nodesource1 1001
        22.12.0-1nodesource1 1001
        22.11.0-1nodesource1 1001
        22.10.0-1nodesource1 1001
        22.9.0-1nodesource1 1001
        22.8.0-1nodesource1 1001
        22.7.0-1nodesource1 1001
        22.6.0-1nodesource1 1001
        22.5.1-1nodesource1 1001
        22.5.0-1nodesource1 1001
        22.4.1-1nodesource1 1001
        22.4.0-1nodesource1 1001
        22.3.0-1nodesource1 1001
        22.2.0-1nodesource1 1001
        22.1.0-1nodesource1 1001
        22.0.0-1nodesource1 1001
        20.19.2+dfsg-1 500
           500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    debianIOB1          debianIOB1 (version: 7.0.7, hostname: debianIOB1    , alive, uptime: 36607)
    raspberrypi-IOB     raspberrypi-IOB (version: 7.0.7, hostname: raspberrypi-IOB, alive, uptime: 70208)
    Core adapters versions
    admin:          7.7.19
    javascript:     8.9.2
    nodejs modules from github:     2
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
    Adapter State
    + system.adapter.admin.0                  : admin                 : debianIOB1                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
     system.adapter.admin.1                  : admin                 : debianIOB1                               - disabled, port: 12081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : debianIOB1                               -  enabled
    + system.adapter.backitup.0               : backitup              : debianIOB1                               -  enabled
    + system.adapter.bambulab.0               : bambulab              : debianIOB1                               -  enabled, port: 8883
     system.adapter.ble.0                    : ble                   : debianIOB1                               - disabled
     system.adapter.cameras.0                : cameras               : debianIOB1                               - disabled, port: 8200, bind: 127.0.0.1
     system.adapter.daswetter.0              : daswetter             : debianIOB1                               -  enabled
    + system.adapter.denon.0                  : denon                 : debianIOB1                               -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi-IOB                          -  enabled
    + system.adapter.dysonairpurifier.0       : dysonairpurifier      : debianIOB1                               -  enabled
    + system.adapter.email.0                  : email                 : debianIOB1                               -  enabled
    + system.adapter.enigma2.0                : enigma2               : debianIOB1                               -  enabled
    + system.adapter.enigma2.1                : enigma2               : debianIOB1                               -  enabled
     system.adapter.flot.0                   : flot                  : debianIOB1                               - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : debianIOB1                               -  enabled
    + system.adapter.harmony.0                : harmony               : debianIOB1                               -  enabled
    + system.adapter.heos.0                   : heos                  : debianIOB1                               -  enabled
    + system.adapter.hikvision-alarmserver.0  : hikvision-alarmserver : debianIOB1                               -  enabled, port: 8089, bind: 10.10.50.100
    + system.adapter.hmip.0                   : hmip                  : debianIOB1                               -  enabled
     system.adapter.ical.0                   : ical                  : debianIOB1                               -  enabled
     system.adapter.icons-material-png.0     : icons-material-png    : debianIOB1                               - disabled
     system.adapter.icons-material-svg.0     : icons-material-svg    : debianIOB1                               - disabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : debianIOB1                               - disabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debianIOB1                               - disabled
     system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: debianIOB1                               - disabled
    + system.adapter.influxdb.0               : influxdb              : debianIOB1                               -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : debianIOB1                               -  enabled
    + system.adapter.iot.2                    : iot                   : debianIOB1                               -  enabled
    + system.adapter.javascript.0             : javascript            : debianIOB1                               -  enabled
    + system.adapter.linux-control.0          : linux-control         : debianIOB1                               -  enabled
    + system.adapter.logparser.0              : logparser             : debianIOB1                               -  enabled
     system.adapter.material.0               : material              : debianIOB1                               - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debianIOB1                               -  enabled, port: 54321
    + system.adapter.moma.0                   : moma                  : debianIOB1                               -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : debianIOB1                               -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.netatmo-energy.0         : netatmo-energy        : debianIOB1                               -  enabled
    + system.adapter.nut.0                    : nut                   : debianIOB1                               -  enabled
    + system.adapter.nut.1                    : nut                   : raspberrypi-IOB                          -  enabled
    + system.adapter.openligadb.0             : openligadb            : debianIOB1                               -  enabled
    + system.adapter.ping.0                   : ping                  : debianIOB1                               -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : debianIOB1                               -  enabled
    + system.adapter.radar2.0                 : radar2                : debianIOB1                               -  enabled
    + system.adapter.reolink.0                : reolink               : debianIOB1                               -  enabled
    + system.adapter.reolink.1                : reolink               : debianIOB1                               -  enabled
    + system.adapter.reolink.2                : reolink               : debianIOB1                               -  enabled
    + system.adapter.reolink.3                : reolink               : debianIOB1                               -  enabled
    + system.adapter.reolink.4                : reolink               : debianIOB1                               -  enabled
    + system.adapter.reolink.5                : reolink               : debianIOB1                               -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-IOB                          -  enabled
     system.adapter.samsung.0                : samsung               : debianIOB1                               - disabled
    + system.adapter.scenes.0                 : scenes                : debianIOB1                               -  enabled
    + system.adapter.simple-api.0             : simple-api            : debianIOB1                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
     system.adapter.smartthings.0            : smartthings           : debianIOB1                               - disabled
    + system.adapter.snmp.0                   : snmp                  : debianIOB1                               -  enabled
    + system.adapter.sonoff.0                 : sonoff                : debianIOB1                               -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : debianIOB1                               -  enabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : debianIOB1                               -  enabled
    + system.adapter.tankerkoenig.1           : tankerkoenig          : debianIOB1                               -  enabled
    + system.adapter.telegram.0               : telegram              : debianIOB1                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : debianIOB1                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : debianIOB1                               -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : debianIOB1                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : debianIOB1                               -  enabled
     system.adapter.tuya.1                   : tuya                  : raspberrypi-IOB                          - disabled
    + system.adapter.unifi.0                  : unifi                 : debianIOB1                               -  enabled
     system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : debianIOB1                               - disabled
     system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : debianIOB1                               - disabled
     system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: debianIOB1                               - disabled
     system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: debianIOB1                               - disabled
    + system.adapter.vis-2.0                  : vis-2                 : debianIOB1                               -  enabled
     system.adapter.vis-history.0            : vis-history           : debianIOB1                               - disabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debianIOB1                               - disabled
     system.adapter.vis-icontwo.0            : vis-icontwo           : debianIOB1                               - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : debianIOB1                               -  enabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : debianIOB1                               - disabled
     system.adapter.vis-justgage.0           : vis-justgage          : debianIOB1                               - disabled
     system.adapter.vis-map.0                : vis-map               : debianIOB1                               - disabled
     system.adapter.vis-material.0           : vis-material          : debianIOB1                               - disabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : debianIOB1                               - disabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : debianIOB1                               - disabled
     system.adapter.vis.0                    : vis                   : debianIOB1                               -  enabled
    + system.adapter.web.0                    : web                   : debianIOB1                               -  enabled, port: 12085, bind: 0.0.0.0, run as: admin
     system.adapter.web.1                    : web                   : debianIOB1                               - disabled, port: 12090, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : debianIOB1                               -  enabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : debianIOB1                               -  enabled
    + system.adapter.wled.0                   : wled                  : debianIOB1                               -  enabled
    + system.adapter.zigbee.0                 : zigbee                : debianIOB1                               -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "dysonairpurifier": 3.2.7 , installed 3.2.7
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "heos"         : 2.2.1    , installed 2.2.4
    Adapter    "hikvision-alarmserver": 0.1.0, installed 0.1.0
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "ical"         : 1.17.0   , installed 1.17.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 5.0.7    , installed 5.0.5  [Updatable]
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "netatmo-energy": 2.8.0   , installed 2.8.2
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openligadb"   : 1.9.1    , installed 1.9.1
    Adapter    "ping"         : 1.6.2    , installed 1.7.9
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "snmp"         : 3.3.0    , installed 3.3.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.3.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 4.0.1
    Adapter    "tuya"         : 3.16.0   , installed 3.17.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.5
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.2
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.3.9
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.6.0
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.6.0
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "web"          : 7.0.8    , installed 7.0.9
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.3
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Objects and States
    Objects:        83729
    States:         74561
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    W: https://dlm.mariadb.com/repo/maxscale/latest/apt/dists/trixie/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://security.debian.org/debian-security trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:7 https://dlm.mariadb.com/repo/mariadb-server/12.rolling/repo/debian trixie InRelease
    Hit:8 https://dlm.mariadb.com/repo/maxscale/latest/apt trixie InRelease
    Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
    Reading package lists...
    Pending Updates: 0
    Leider weis ich noch nicht mal in welcher Richtung ich suchen sollte um den Fehler zu finden ......
    mfg
    Digi-Bit
    Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
    7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
    • D Digi-Bit
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      host.debianIOB1
      tuya.0
      tuya.0
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      host.debianIOB1
      iob diag:
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
              Chassis: desktop 🖥️
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 8
                   NTP service: active
               RTC in local TZ: no
      digibit
      HOME=/home/digibit
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
      Total:           51G        6.9G         39G
              6548 M used memory
             36291 M free memory
              4508 M swap cache
               975 M total swap
                 0 M used swap
               975 M free swap
      *** FILESYSTEM ***
      /var:
      3.1G    /var/
      1.9G    /var/lib
      827M    /var/lib/mysql
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
       Version table:
          20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.19
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        83729
      States:         74561
      Pending Updates: 0
      mfg
      Digi-Bit
      crunchipC Abwesend
      crunchipC Abwesend
      @digi-bit sagte in javascript.0 bricht ab:
      vllt mal haken entfernen
      dab6f982-b323-47b9-935b-0b75bf8ea2fd-image.png ![0_1762276442446_411dfac0-c976-4867-b376-0455afe51cd9-image.png](Lade 100% hoch)
      alle scripte mal stoppen
        ticaki
        Das npm module setObjects gibts nicht, daher das aus dem npm custom install entfernen
        Alle Scripte stoppen und dann schauen welches da in einer Endlosschleife den Speicher vollschreibt.
        Spenden
        • T ticaki
          Digi-Bit
          Moin,
          Ich habe jetzt alle Skripte abgeschaltet aber wie kann es sein das da noch was passiert
          silly
          ⇥4499/↦2000
          1 3 * * *
          8192 MB
          1: Logikadapter
          debianIOB1
          Wenn alle Skripte auf Pause sind dann werden die doch nicht mehr beachtet oder ?
          mfg
          Digi-Bit
          • D Digi-Bit
            Moin,
            silly
            ⇥4499/↦2000
            1 3 * * *
            8192 MB
            1: Logikadapter
            debianIOB1
            mfg
            Digi-Bit
            ticaki
            @digi-bit
            Expert im Javascript-adapter aktivieren und mal in global gucken? Javascript-adapter stoppen 15 Sekunden warten und dann starten. Screenshot der Konfig zeigen.
            Spenden
            • T ticaki
              @digi-bit
              Digi-Bit
              @ticaki
              Moin,
              Also das mit dem Expert im Javascript-adapter finde ich nicht
              • D Digi-Bit
                @ticaki
                Moin,
                @digi-bit sagte: das mit dem Expert im Javascript-adapter finde ich nicht
                Im Javascript-Editor der Kopf (4. Symbol oben):
                Den Expertenmodus muss man aktivieren, wenn man die Gruppe "global" auswählen möchte.
                  Digi-Bit
                  Ah, ok ^^
                  Also in "Global" sind keine Skripte drin
                  • D Digi-Bit
                    Ah, ok ^^
                    ticaki
                    @digi-bit
                    Mache mal den script mirror aus.
                    EDIT: ich sehe das der Adapter auf debug steht - gib mal das Log von einem Restart bis zum Absturz - aber bitte aus dem Download-Log.
                    Spenden
                    • T ticaki
                      @digi-bit
                      Digi-Bit
                      @ticaki
                      welcher Restart ?
                      Vom IOB oder vom Java ?
                      • D Digi-Bit
                        @ticaki
                        welcher Restart ?
                        ticaki
                        @digi-bit
                        javascript-adapter
                        Ich meine das log von da:
                        Spenden
                          Digi-Bit
                          @ticaki
                          Hat etwas gedauert aber ich muss was tun um Leben zu können wie die meisten denke ich mal ^^
                          Hier das log:
                          iobroker.2025-11-05.html
                          Jetzt bin ich ja mal gespannt .....
                          mfg
                          Digi-Bit
                          crunchipC T 2 Antworten Letzte Antwort
                          • D Digi-Bit
                            @ticaki
                            Hier das log:
                            mfg
                            Digi-Bit
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @digi-bit für was soll das sein?
                            javascript.0 (43084) Schedule restart: 1 3 * * *
                            • D Digi-Bit
                              @ticaki
                              Hier das log:
                              mfg
                              Digi-Bit
                              ticaki
                              @digi-bit
                              Das da ist aber mit allen Skripten am laufen, ich wollte das log mit ausgeschalteten skripten.
                              Der Heap läuft über - bedeutet, das du entweder endlos Daten hinzufügst oder mit zu großen Datenmengen arbeitest. Das dürfe ohne aktivierte Skripte nicht passieren. Deshalb will ich das log mit ausgeschalteten Skripten sehen.
                              Spenden
                                Digi-Bit
                                @crunchip sagte in javascript.0 bricht ab:
                                das weis ich auch nicht, ich weis nur das um 3 Uhr schon seit der ersten IOB Installation die Skripte neu starten.
                                mfg
                                Digi-Bit
                                • T ticaki
                                  @digi-bit
                                  Digi-Bit
                                  @ticaki sagte in javascript.0 bricht ab:
                                  @digi-bit
                                  mit Ausgeschalteten Skripten rannst der Adapter aber nicht ab, glaub ich, nur das da irgendwelche in und Output's angezeigt werden.
                                  Aber werde ich Morgen dann mal für eine weile mit Abgeschalteten Skripten laufen lassen für eins 2 Stunden mal sehen was passiert.
                                  mfg
                                  Digi-Bit
                                  paul53P T OliverIOO 3 Antworten Letzte Antwort
                                  • D Digi-Bit
                                    @digi-bit
                                    mfg
                                    Digi-Bit
                                    @digi-bit sagte: irgendwelche in und Output's angezeigt werden.
                                    Das passiert auch ohne laufende Skripte, da die Javascript-Instanz alle Zustände abonniert, also der JS-Puffer ständig synchronisiert wird.
                                    • D Digi-Bit
                                      @digi-bit
                                      mfg
                                      Digi-Bit
                                      ticaki
                                      @digi-bit
                                      Dann hab ich das falsch verstanden sorry - dann mußt du die Skripte durchprobieren - geht am schnellsten wenn du 50% an machst, wenns stabil läuft ist das problem in der anderen hälfte und das solange bist du es weißt :)
                                      Spenden
                                      • D Digi-Bit
                                        @digi-bit
                                        mfg
                                        Digi-Bit
                                        OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        @digi-bit
                                        Wie viele Datenpunkte hast du den insgesamt?
                                        und gibt es da viele, die sehr oft aktualisiert werden?
                                        ok, gefunden
                                        Objects and States
                                        Objects: 83729
                                        States: 74561
                                        ist auch nicht übermäßig viel, ausser du speicherst binär daten in den datenpunkten, aber das würde glaube ich den heap nicht betreffen.
                                        heap überlauf kommt meist von rekursiv aufgerufenen funktionen die kein endebegrenzer haben oder falsch programmierte event oder timer handler (was wieder memmory leaks erzeugt, die nicht aufgeräumt werden können)
                                        daher so wie geschrieben erstmal den adapter ohne skripte starten. dann dürfte das nicht mehr passieren.
                                        dann der reihe nach die skripte starten und jeweils eine weile warten.
                                        bewährte methode ist bei bspw 20 skripte
                                        zunächst 10 anschalten und dann eine weile warten (1-2h bzw je nachdem wie schnell sich das problem nach neustart bei dir aufgebaut hat)
                                        dann nach der wartezeit, weitere 50%, also 5 dazuschalten und so fort. wenn du ein segment an skripten gefunden hast was verrückt gespielt hat, dann nur das aktivieren und der reihe nach durchprobieren (wenn es immer noch sehr viele im segment sind, dann wieder die jeweils 50% methode anwenden, da es bei einzelnem zuschalten dann doch länger dauern kann, bis das böse skript identifiziert ist.
                                        ist das problem schon immer oder "plötzlich" nach einem update oder nachdem du skripte bearbeitet hast?
                                        problem ist auch, wenn der speicherzuwachs relativ langsam vorsich geht, dauert es auch länger wenn viele skripte abgeschaltet sind, da ja dann mehr speicher frei ist und es daher erst später zum problem kommt.
                                        Meine Adapter und Widgets
                                        Links im Profil
                                        CodierknechtC T 2 Antworten Letzte Antwort
                                        • OliverIOO OliverIO
                                          @digi-bit
                                          ok, gefunden
                                          Objects and States
                                          Objects: 83729
                                          States: 74561
                                          CodierknechtC Offline
                                          Codierknecht
                                          @oliverio sagte in javascript.0 bricht ab:
                                          Ja - z.B. der Kandidat #1: Trigger in Trigger
                                          HmIP|ZigBee|Tasmota|Unifi
                                          Zabbix Certified Specialist
