  3. Einsteigerfragen
  4. Alexa Adapter-Fehler bei Anmeldung im Alexa Konto
    5.3k
37 Beiträge 4 Kommentatoren 2.1k Aufrufe 3 Beobachtet
    @babu242
    Vielleicht aber andere...
    Babu242
    code_text
    ```pi@raspberrypi:~ $ systemctl status NetworkManager-wait-online.service
    × NetworkManager-wait-online.service - Network Manager Wait Online
         Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; en>
         Active: failed (Result: exit-code) since Tue 2025-10-21 18:37:50 CEST; 2h >
           Docs: man:nm-online(1)
        Process: 580 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=1/FAIL>
       Main PID: 580 (code=exited, status=1/FAILURE)
            CPU: 135ms
    Oct 21 18:36:37 raspberrypi systemd[1]: Starting NetworkManager-wait-online.ser>
    Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Mai>
    Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Fai>
    Oct 21 18:37:50 raspberrypi systemd[1]: Failed to start NetworkManager-wait-onl>
    lines 1-12/12 (END)...skipping...
         Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; enabled; preset: enabled)
         Active: failed (Result: exit-code) since Tue 2025-10-21 18:37:50 CEST; 2h 28min ago
        Process: 580 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=1/FAILURE)
            CPU: 135ms
    Oct 21 18:36:37 raspberrypi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
    Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Main process exited, code=exited, status=1/FAILURE
    Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Failed with result 'exit-code'.
    Oct 21 18:37:50 raspberrypi systemd[1]: Failed to start NetworkManager-wait-online.service - Network Manager Wait Online.
    • B Babu242
      code_text
              CPU: 135ms
              CPU: 135ms
      @babu242
      Mach das Terminalfenster größer. Da fehlt rechts was. Vollständig sieht das so aus:
      echad@chet:~ $ systemctl status NetworkManager-wait-online.service
      ● NetworkManager-wait-online.service - Network Manager Wait Online
           Loaded: loaded (/usr/lib/systemd/system/NetworkManager-wait-online.service; enabled; preset: enabled)
           Active: active (exited) since Fri 2025-10-17 19:18:37 CEST; 4 days ago
       Invocation: 0d12bc9b8d424505b4cbbcd301f66b88
             Docs: man:NetworkManager-wait-online.service(8)
          Process: 800 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=0/SUCCESS)
         Main PID: 800 (code=exited, status=0/SUCCESS)
              CPU: 77ms
      Oct 17 19:18:33 chet systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
      Oct 17 19:18:37 chet systemd[1]: Finished NetworkManager-wait-online.service - Network Manager Wait Online.
      echad@chet:~ $
        @babu242
                CPU: 77ms
        echad@chet:~ $
        Babu242
        Hmm
        also mein Terminalfenster ist max. groß und ich sehe auch nicht mehr.
        • B Babu242
          Hmm
          @babu242
          Du hast das ja auch zweimal aufgerufen...
          Bitte immer inkl. LogIn Prompt posten, dann sieht man was wo anfängt und wo was aufhört. Und man sieht auch wo du da im Dateibaum gerade herumstehst. Das kann wichtig sein.
          sudo systemctl restart NetworkManager-wait-online.service
            @babu242
            Babu242
            @thomas-braun sagte in Alexa 2 meldet immer error 401 unauthorized:
            code_text
            ```pi@raspberrypi:~ $ sudo systemctl restart NetworkManager-wait-online.service
                 Active: active (exited) since Tue 2025-10-21 21:22:55 CEST; 23s ago
                Process: 3062 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=0/SUCCESS)
               Main PID: 3062 (code=exited, status=0/SUCCESS)
                    CPU: 36ms
            Oct 21 21:22:55 raspberrypi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
            Oct 21 21:22:55 raspberrypi systemd[1]: Finished NetworkManager-wait-online.service - Network Manager Wait Online.
            • B Babu242
              code_text
                      CPU: 36ms
              @babu242
              Dann läuft jetzt der Service schon mal wieder.
              Nicht das der zwingend was mit deinem Alexa-Proxy zu tun hat, könnte aber sein.
              Versuch jetzt nochmal den Adapter einzuloggen, vielleicht auch mal das Cookie neuziehen lassen.
              B 2 Antworten Letzte Antwort
                @babu242 sagte in Alexa 2 meldet immer error 401 unauthorized:
                Wie erstelle ich den das nötige Log?
                Terminal auf,
                iob logs --watch
                aufrufen, mit dem Adapter herumhantieren, Output hier reinkopieren, in </> CodeTags eingebettet. Die Ausgabe von
                iob diag
                kannste aber auch mal dazu geben. Schadet nicht.
                @Homoran Bitte Thread splitten, das wird was anderes als im OP.
                @thomas-braun sagte in Neier Arbeitstitel:
                erledigt!
                typischer Fall von eben nicht
                @babu242 sagte in Neier Arbeitstitel:
                die gleiche Herausforderung.
                @Babu242
                Bitte Threadtitel anpassen
                  erledigt!
                  @Babu242
                  Babu242
                  Danke für denn neuen Thread.
                  Wie oder wo benenne ich den denn Neu?
                    @babu242
                    Babu242
                    Hi erst mall viele dank für deine Unterstützung.
                    Wollte ich schon gestern Abend sagen, konnte aber keine Nachricht mehr versenden habe dauernd eine Fehlermeldung bekommen.
                    hab ich schon gestern aber auch heute versucht geht nicht.
                    • B Babu242
                      @babu242 ersten Post editieren und Titel ändern
                      • B Babu242
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @babu242 said in Neier Arbeitstitel:
                        Wenn du das Posten im Forum meinst:
                        Einfach F5 / Refresh drücken und dann gehts
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • mcm1957M mcm1957
                          Babu242
                          @mcm1957
                          ah nein Sorry ich hab das versucht:
                            Babu242
                            Danke hab es geändert
                              @babu242
                              Babu242
                              so ich habe jetzt den Alexa Adapter neu installiert als eine zweite Instanz.
                              Wenn ich dort jetzt auf den link gehe könnte ich mich wohl einloggen .
                              Hab ich aber noch nicht.
                              Macht doch aber kein sinn, oder?
                              • B Babu242
                                @babu242 sagte in Alexa Adapter-Fehler bei Anmeldung im Alexa Konto:
                                Warum nicht?
                                  Warum nicht?
                                  Babu242
                                  Kann ich mir da nix zerschießen ich weis es halt nicht ?
                                  • B Babu242
                                    @babu242
                                    Was willste denn da 'zerschießen'?
                                      @babu242
                                      Babu242
                                      Ok Hab es gemacht und er Adapter ist grün und läuft.
                                      Soll ich jetzt die andre Instanz löschen? Oder erstmal nur pausieren.
                                      • B Babu242
                                        @babu242
                                        Pausier das Ding erstmal, wenn alles läuft kannst du die hinkende Instanz löschen.
                                          @babu242
                                          Babu242
                                          Top! So wird es gemacht und einen schönen Abend dir.
                                          Vielen dank für deine Geduld.
