  3. Einsteigerfragen
  4. Alexa Adapter-Fehler bei Anmeldung im Alexa Konto
    5.3k
37 Beiträge 4 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • B Babu242
    und bitte
    iob logs --watch
    code_text
    ```========== Start marking the full check here ===========
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     19:54:04 up  1:17,  2 users,  load average: 0.37, 0.32, 0.35
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-10-21 19:54:05 CEST
               Universal time: Tue 2025-10-21 17:54:05 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        1.7G        1.8G        1.2M        524M        2.3G
    Swap:           536M          0B        536M
    Total:          4.5G        1.7G        2.3G
    Active iob-Instances:   17
             3795 M total memory
             1650 M used memory
             1787 M active memory
              155 M inactive memory
             1719 M free memory
               43 M buffer memory
              456 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 19:54:05 up  1:17,  2 users,  load average: 0.37, 0.32, 0.35
    Tasks: 192 total,   1 running, 191 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.9 total,   1719.3 free,   1650.3 used,    500.2 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2145.5 avail Mem
    *** FAILED SERVICES ***
      UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
    * NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  1.2M  759M   1% /run
    /dev/sda2      ext4      110G  5.8G  100G   6% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Tue Oct 21 18:36:45 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:59:72:FC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=e12e16cb-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Tue Oct 21 18:36:46 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Tue Oct 21 18:36:47 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.7G    /var/
    570M    /var/log
    566M    /var/log/journal/a81e89c245434f208844b59db739f6a9
    411M    /var/cache
    Archived and active journals take up 565.9M in the file system.
    /opt/iobroker/backups:
    140M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    267M    /opt/iobroker/iobroker-data/
    145M    /opt/iobroker/iobroker-data/files
    89M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
    7.5M    /opt/iobroker/iobroker-data/states.jsonl
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    3.7M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/assets/index-DS28Nms8.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 4640)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     1
    +-- iobroker.connector-local-control@0.0.3 (git+ssh://git@github.com/ConnectorGit/ioBroker.connector-local-control.git#16883762689caa1cbfe39d5db0c2eeb4202d10ea)
    Adapter State
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.connector-local-control.0: connector-local-control: raspberrypi                              - disabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
    + system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.178.79
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.tradfri.0                : tradfri               : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "dysonairpurifier": 3.2.7 , installed 3.2.7
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "iot"          : 3.3.0    , installed 4.1.3
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "shelly"       : 10.2.0   , installed 10.2.0
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Objects and States
    Objects:        6132
    States:         6794
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       7397       862/io.shelly.1
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5768       583/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1895       583/iobroker.js-con
    tcp        0      0 0.0.0.0:33373           0.0.0.0:*               LISTEN      1001       33311      1252/io.alexa2.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          735        601/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6810       964/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       807        673/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          737        601/sshd: /usr/sbin
    udp        0      0 0.0.0.0:48291           0.0.0.0:*                           1001       39301      1273/io.broadlink2.
    udp        0      0 0.0.0.0:40121           0.0.0.0:*                           1001       9245       930/io.tradfri.0
    udp        0      0 0.0.0.0:40148           0.0.0.0:*                           1001       55535      802/io.onkyo.0
    udp        0      0 192.168.178.79:5353     0.0.0.0:*                           1001       6052       847/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3053       460/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       937        832/io.shelly.0
    udp        0      0 0.0.0.0:38638           0.0.0.0:*                           1001       46398      1273/io.broadlink2.
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       37218      1273/io.broadlink2.
    udp        0      0 0.0.0.0:37536           0.0.0.0:*                           104        3055       460/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        3054       460/avahi-daemon: r
    udp6       0      0 :::52946                :::*                                104        3056       460/avahi-daemon: r
    udp6       0      0 fe80::ee7f:45f6:989:546 :::*                                0          6279       532/NetworkManager
    2025-10-21 19:35:44.661  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
    2025-10-21 19:35:44.670  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
    2025-10-21 19:35:49.031  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
    2025-10-21 19:35:49.038  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
    2025-10-21 19:35:57.555  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
    2025-10-21 19:35:57.562  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
    2025-10-21 19:38:37.923  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
    2025-10-21 19:38:47.030  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
    2025-10-21 19:38:47.032  - info: broadlink2.0 (1273) discover  [ '192.168.178.49' ] from 0.0.0.0:59289
    2025-10-21 19:39:58.984  - info: admin.0 (673) <== Disconnect system.user.admin from ::ffff:192.168.178.32
    2025-10-21 19:40:28.447  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
    2025-10-21 19:45:43.898  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
    2025-10-21 19:45:43.907  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
    2025-10-21 19:45:46.006  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
    2025-10-21 19:45:46.012  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
    2025-10-21 19:45:49.859  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
    2025-10-21 19:45:49.881  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
    2025-10-21 19:45:57.455  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
    2025-10-21 19:45:57.461  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
    2025-10-21 19:46:44.068  - info: admin.0 (673) <== Disconnect system.user.admin from ::ffff:192.168.178.32
    2025-10-21 19:46:47.054  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
    2025-10-21 19:46:47.057  - info: broadlink2.0 (1273) discover  [ '192.168.178.49' ] from 0.0.0.0:38638
    2025-10-21 19:53:40.818  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
    iob diag has finished.
    oadlink2.0 (2546) discover [ '192.168.178.49' ] from 0.0.0.0:41771
    @babu242 sagte in Alexa 2 meldet immer error 401 unauthorized:
    • NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
    Ich hatte schon die Vermutung, dass es in Richtung 'Netzwerk' geht.
    Irgendwas klemmt da bei dir.
    systemctl status NetworkManager-wait-online.service
    sagt?
    Und setz den netatmo-crawler vom debug-LogLevel runter. Der interessiert nicht. Und deine shellies scheinen ein falsche mqtt-PW zu haben.
    • B Babu242
      teil 2
      code_text
      ```2025-10-21 20:01:05.747  - info: broadlink2.0 (2546) discover  [ '192.168.178.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:53405
      2025-10-21 20:01:05.766  - debug: netatmo-crawler.0 (2535) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761069472":[14.4,74]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761069494":[1000.6]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761069492":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:05.766  - debug: netatmo-crawler.0 (2535) Saving station data for station: 4
      2025-10-21 20:01:05.795  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
      2025-10-21 20:01:05.803  - debug: netatmo-crawler.0 (2535) Rounded value 14.4 to 14.4
      2025-10-21 20:01:05.809  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
      2025-10-21 20:01:05.818  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
      2025-10-21 20:01:05.858  - info: broadlink2.0 (2546) Device RM:BroadLink-WiFi-Device-3d-d2-34 detected: address=192.168.178.86, mac=ec:0b:ae:3d:d2:34, typ=RM4P, id=0x649b devtype=rm4p
      2025-10-21 20:01:06.009  - debug: netatmo-crawler.0 (2535) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.018838882446289062,"time_server":1761069665}
      2025-10-21 20:01:06.010  - debug: netatmo-crawler.0 (2535) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:06.013  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
      2025-10-21 20:01:06.020  - debug: netatmo-crawler.0 (2535) Saved rain_today for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:06.578  - debug: netatmo-crawler.0 (2535) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:06.579  - debug: netatmo-crawler.0 (2535) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:06.582  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
      2025-10-21 20:01:06.589  - debug: netatmo-crawler.0 (2535) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:06.726  - debug: netatmo-crawler.0 (2535) Body Rain_LastHour:[{"beg_time":1761066066,"value":[[0]]}]
      2025-10-21 20:01:06.726  - debug: netatmo-crawler.0 (2535) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:06.730  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
      2025-10-21 20:01:06.737  - debug: netatmo-crawler.0 (2535) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:06.745  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
      2025-10-21 20:01:06.753  - debug: netatmo-crawler.0 (2535) Rounded value 1000.6 to 1000.6
      2025-10-21 20:01:06.759  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
      2025-10-21 20:01:06.766  - debug: netatmo-crawler.0 (2535) Rounded value 74 to 74
      2025-10-21 20:01:06.772  - debug: netatmo-crawler.0 (2535) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      2025-10-21 20:01:06.773  - debug: netatmo-crawler.0 (2535) Going to get information for station: 5
      2025-10-21 20:01:06.773  - info: netatmo-crawler.0 (2535) Getting data for stationid:70:ee:50:33:4b:fc
      2025-10-21 20:01:10.961  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
      2025-10-21 20:01:10.963  - info: broadlink2.0 (2546) discover  [ '192.168.178.86' ] from 0.0.0.0:34728
      2025-10-21 20:01:13.041  - debug: netatmo-crawler.0 (2535) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:13.042  - debug: netatmo-crawler.0 (2535) Saving station data for station: 5
      2025-10-21 20:01:13.072  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
      2025-10-21 20:01:13.080  - debug: netatmo-crawler.0 (2535) Rounded value 15.1 to 15.1
      2025-10-21 20:01:13.086  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
      2025-10-21 20:01:13.094  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
      2025-10-21 20:01:13.365  - debug: netatmo-crawler.0 (2535) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.02626800537109375,"time_server":1761069673}
      2025-10-21 20:01:13.365  - debug: netatmo-crawler.0 (2535) Rain Today for Station 70:ee:50:33:4b:fc is: 1
      2025-10-21 20:01:13.369  - debug: netatmo-crawler.0 (2535) Rounded value 1 to 1
      2025-10-21 20:01:13.375  - debug: netatmo-crawler.0 (2535) Saved rain_today for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:13.624  - debug: netatmo-crawler.0 (2535) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:13.625  - debug: netatmo-crawler.0 (2535) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:13.628  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
      2025-10-21 20:01:13.634  - debug: netatmo-crawler.0 (2535) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:13.993  - debug: netatmo-crawler.0 (2535) Body Rain_LastHour:[{"beg_time":1761066073,"value":[[0]]}]
      2025-10-21 20:01:13.994  - debug: netatmo-crawler.0 (2535) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:13.997  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
      2025-10-21 20:01:14.003  - debug: netatmo-crawler.0 (2535) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:14.010  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
      2025-10-21 20:01:14.017  - debug: netatmo-crawler.0 (2535) Rounded value 1002.1 to 1002.1
      2025-10-21 20:01:14.027  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
      2025-10-21 20:01:14.035  - debug: netatmo-crawler.0 (2535) Rounded value 79 to 79
      2025-10-21 20:01:14.043  - debug: netatmo-crawler.0 (2535) all done, exiting
      2025-10-21 20:01:14.044  - info: netatmo-crawler.0 (2535) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
      2025-10-21 20:01:14.585  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 2535 terminated with code 0 (NO_ERROR)
      2025-10-21 20:01:15.032  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2566
      2025-10-21 20:01:15.252  - warn: broadlink2.0 (2546) device RM:RMPROPLUS-00-cd-a0 not found, please rescan later again or delete it! It was: 192.168.178.49,80,10141,智能遥控,0,[object Object],78:0f:77:00:cd:a0,RMP,RM:RMPROPLUS-00-cd-a0,0x279d,RM3 Pro Plus,RM:RMPROPLUS-00-cd-a0,RMPROPLUS-00-cd-a0,57
      2025-10-21 20:01:15.379  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
      2025-10-21 20:01:15.381  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:33333
      2025-10-21 20:01:17.327  - debug: netatmo-crawler.0 (2566) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2025-10-21 20:01:17.403  - debug: netatmo-crawler.0 (2566) Objects client ready ... initialize now
      2025-10-21 20:01:17.407  - debug: netatmo-crawler.0 (2566) Objects create System PubSub Client
      2025-10-21 20:01:17.409  - debug: netatmo-crawler.0 (2566) Objects create User PubSub Client
      2025-10-21 20:01:17.472  - debug: netatmo-crawler.0 (2566) Objects client initialize lua scripts
      2025-10-21 20:01:17.481  - debug: netatmo-crawler.0 (2566) Objects connected to redis: 127.0.0.1:9001
      2025-10-21 20:01:17.486  - silly: netatmo-crawler.0 (2566) redis psubscribe cfg.o.system.user.*
      2025-10-21 20:01:17.517  - silly: netatmo-crawler.0 (2566) redis psubscribe cfg.o.enum.*
      2025-10-21 20:01:17.521  - silly: netatmo-crawler.0 (2566) objectDB connected
      2025-10-21 20:01:17.525  - debug: netatmo-crawler.0 (2566) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-10-21 20:01:17.549  - debug: netatmo-crawler.0 (2566) States create System PubSub Client
      2025-10-21 20:01:17.550  - debug: netatmo-crawler.0 (2566) States create User PubSub Client
      2025-10-21 20:01:17.598  - info: broadlink2.0 (2546) Poll every 15 secods.
      2025-10-21 20:01:17.599  - info: broadlink2.0 (2546) broadlink2.0 started and found 1 devices named RM:BroadLink-WiFi-Device-3d-d2-34
      2025-10-21 20:01:17.599  - info: broadlink2.0 (2546) 1 were not found: RM:RMPROPLUS-00-cd-a0
      2025-10-21 20:01:17.600  - info: broadlink2.0 (2546) found macs: ec:0b:ae:3d:d2:34
      2025-10-21 20:01:17.631  - debug: netatmo-crawler.0 (2566) States connected to redis: 127.0.0.1:9000
      2025-10-21 20:01:17.632  - silly: netatmo-crawler.0 (2566) statesDB connected
      2025-10-21 20:01:17.791  - info: netatmo-crawler.0 (2566) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.21.0, js-controller: 7.0.7
      2025-10-21 20:01:17.815  - debug: netatmo-crawler.0 (2566) config stationUrls: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
      https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
      https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
      2025-10-21 20:01:17.815  - debug: netatmo-crawler.0 (2566) Going to save station information with: id
      2025-10-21 20:01:17.817  - debug: netatmo-crawler.0 (2566) Trying to get token from state
      2025-10-21 20:01:17.839  - silly: netatmo-crawler.0 (2566) States system redis pmessage system.adapter.netatmo-crawler.0.logLevel/system.adapter.netatmo-crawler.0.logLevel:{"val":"silly","ack":true,"ts":1761069677820,"q":0,"from":"system.adapter.netatmo-crawler.0","lc":1732447437255}
      2025-10-21 20:01:17.843  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      2025-10-21 20:01:17.845  - debug: netatmo-crawler.0 (2566) Going to get information for station: 1
      2025-10-21 20:01:17.848  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:33:4b:fc
      2025-10-21 20:01:18.059  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:18.061  - debug: netatmo-crawler.0 (2566) Saving station data for station: 1
      2025-10-21 20:01:18.105  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
      2025-10-21 20:01:18.114  - debug: netatmo-crawler.0 (2566) Rounded value 15.1 to 15.1
      2025-10-21 20:01:18.121  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
      2025-10-21 20:01:18.130  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:18.279  - debug: netatmo-crawler.0 (2566) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.03300189971923828,"time_server":1761069678}
      2025-10-21 20:01:18.280  - debug: netatmo-crawler.0 (2566) Rain Today for Station 70:ee:50:33:4b:fc is: 1
      2025-10-21 20:01:18.284  - debug: netatmo-crawler.0 (2566) Rounded value 1 to 1
      2025-10-21 20:01:18.291  - debug: netatmo-crawler.0 (2566) Saved rain_today for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:18.433  - debug: netatmo-crawler.0 (2566) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:18.433  - debug: netatmo-crawler.0 (2566) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:18.437  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:18.443  - debug: netatmo-crawler.0 (2566) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:18.615  - debug: netatmo-crawler.0 (2566) Body Rain_LastHour:[{"beg_time":1761066078,"value":[[0]]}]
      2025-10-21 20:01:18.616  - debug: netatmo-crawler.0 (2566) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:18.620  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:18.626  - debug: netatmo-crawler.0 (2566) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:18.633  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
      2025-10-21 20:01:18.640  - debug: netatmo-crawler.0 (2566) Rounded value 1002.1 to 1002.1
      2025-10-21 20:01:18.646  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
      2025-10-21 20:01:18.654  - debug: netatmo-crawler.0 (2566) Rounded value 79 to 79
      2025-10-21 20:01:18.660  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
      2025-10-21 20:01:18.660  - debug: netatmo-crawler.0 (2566) Going to get information for station: 2
      2025-10-21 20:01:18.662  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:17:9d:ba
      2025-10-21 20:01:19.857  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:17:9d:ba","place":{"location":[13.457895,52.523834],"timezone":"Europe/Berlin","country":"DE","altitude":48,"city":"Berlin","street":"Edith-Stein-Straße"},"mark":1,"measures":{"02:00:00:17:80:7a":{"res":{"1761069287":[14.3,74]},"type":["temperature","humidity"]},"70:ee:50:17:9d:ba":{"res":{"1761069298":[998.8]},"type":["pressure"]}}}]
      2025-10-21 20:01:19.858  - debug: netatmo-crawler.0 (2566) Saving station data for station: 2
      2025-10-21 20:01:19.886  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:17:9d:ba and measure: temperature
      2025-10-21 20:01:19.893  - debug: netatmo-crawler.0 (2566) Rounded value 14.3 to 14.3
      2025-10-21 20:01:19.900  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:17:9d:ba and measure: pressure
      2025-10-21 20:01:19.908  - debug: netatmo-crawler.0 (2566) Rounded value 998.8 to 998.8
      2025-10-21 20:01:19.914  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:17:9d:ba and measure: humidity
      2025-10-21 20:01:19.921  - debug: netatmo-crawler.0 (2566) Rounded value 74 to 74
      2025-10-21 20:01:19.927  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
      2025-10-21 20:01:19.928  - debug: netatmo-crawler.0 (2566) Going to get information for station: 3
      2025-10-21 20:01:19.929  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:00:c1:94
      2025-10-21 20:01:20.018  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:00:c1:94","place":{"location":[13.4704260000001,52.5162059412954],"timezone":"Europe/Berlin","country":"DE","altitude":46,"city":"Berlin","street":"Schreinerstraße"},"mark":10,"measures":{"02:00:00:00:c7:32":{"res":{"1761069052":[15.5,69]},"type":["temperature","humidity"]},"70:ee:50:00:c1:94":{"res":{"1761069405":[1000.2]},"type":["pressure"]},"05:00:00:00:19:9a":{"res":{"1761069405":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:20.019  - debug: netatmo-crawler.0 (2566) Saving station data for station: 3
      2025-10-21 20:01:20.048  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:00:c1:94 and measure: temperature
      2025-10-21 20:01:20.056  - debug: netatmo-crawler.0 (2566) Rounded value 15.5 to 15.5
      2025-10-21 20:01:20.062  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:00:c1:94 and measure: rain
      2025-10-21 20:01:20.070  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:20.251  - debug: netatmo-crawler.0 (2566) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0.6]]}],"status":"ok","time_exec":0.02898406982421875,"time_server":1761069680}
      2025-10-21 20:01:20.252  - debug: netatmo-crawler.0 (2566) Rain Today for Station 70:ee:50:00:c1:94 is: 0.6
      2025-10-21 20:01:20.256  - debug: netatmo-crawler.0 (2566) Rounded value 0.6 to 0.6
      2025-10-21 20:01:20.263  - debug: netatmo-crawler.0 (2566) Saved rain_today for station: 70:ee:50:00:c1:94
      2025-10-21 20:01:20.456  - debug: netatmo-crawler.0 (2566) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:20.457  - debug: netatmo-crawler.0 (2566) Rain Yesterday for Station 70:ee:50:00:c1:94 is: 0
      2025-10-21 20:01:20.463  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:20.478  - debug: netatmo-crawler.0 (2566) Saved rain_yesterday for station: 70:ee:50:00:c1:94
      2025-10-21 20:01:20.941  - debug: netatmo-crawler.0 (2566) Body Rain_LastHour:[{"beg_time":1761066080,"value":[[0]]}]
      2025-10-21 20:01:20.942  - debug: netatmo-crawler.0 (2566) Rain Last Hour for Station 70:ee:50:00:c1:94 is: 0
      2025-10-21 20:01:20.948  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:20.958  - debug: netatmo-crawler.0 (2566) Saved rain_lastHour for station: 70:ee:50:00:c1:94
      2025-10-21 20:01:20.969  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:00:c1:94 and measure: pressure
      2025-10-21 20:01:20.981  - debug: netatmo-crawler.0 (2566) Rounded value 1000.2 to 1000.2
      2025-10-21 20:01:20.990  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:00:c1:94 and measure: humidity
      2025-10-21 20:01:21.001  - debug: netatmo-crawler.0 (2566) Rounded value 69 to 69
      2025-10-21 20:01:21.010  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
      2025-10-21 20:01:21.011  - debug: netatmo-crawler.0 (2566) Going to get information for station: 4
      2025-10-21 20:01:21.012  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:52:e9:c2
      2025-10-21 20:01:21.148  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761069472":[14.4,74]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761069494":[1000.6]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761069492":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:21.153  - debug: netatmo-crawler.0 (2566) Saving station data for station: 4
      2025-10-21 20:01:21.217  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
      2025-10-21 20:01:21.225  - debug: netatmo-crawler.0 (2566) Rounded value 14.4 to 14.4
      2025-10-21 20:01:21.231  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
      2025-10-21 20:01:21.239  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:21.866  - debug: netatmo-crawler.0 (2566) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.03335404396057129,"time_server":1761069681}
      2025-10-21 20:01:21.867  - debug: netatmo-crawler.0 (2566) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:21.870  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:21.877  - debug: netatmo-crawler.0 (2566) Saved rain_today for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:22.002  - debug: netatmo-crawler.0 (2566) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:22.003  - debug: netatmo-crawler.0 (2566) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:22.007  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:22.013  - debug: netatmo-crawler.0 (2566) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:22.352  - debug: netatmo-crawler.0 (2566) Body Rain_LastHour:[{"beg_time":1761066082,"value":[[0]]}]
      2025-10-21 20:01:22.353  - debug: netatmo-crawler.0 (2566) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:22.356  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:22.362  - debug: netatmo-crawler.0 (2566) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:22.368  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
      2025-10-21 20:01:22.376  - debug: netatmo-crawler.0 (2566) Rounded value 1000.6 to 1000.6
      2025-10-21 20:01:22.381  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
      2025-10-21 20:01:22.389  - debug: netatmo-crawler.0 (2566) Rounded value 74 to 74
      2025-10-21 20:01:22.396  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      2025-10-21 20:01:22.397  - debug: netatmo-crawler.0 (2566) Going to get information for station: 5
      2025-10-21 20:01:22.398  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:33:4b:fc
      2025-10-21 20:01:22.549  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:22.550  - debug: netatmo-crawler.0 (2566) Saving station data for station: 5
      2025-10-21 20:01:22.644  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
      2025-10-21 20:01:22.652  - debug: netatmo-crawler.0 (2566) Rounded value 15.1 to 15.1
      2025-10-21 20:01:22.658  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
      2025-10-21 20:01:22.666  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:22.881  - debug: netatmo-crawler.0 (2566) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.030659914016723633,"time_server":1761069682}
      2025-10-21 20:01:22.882  - debug: netatmo-crawler.0 (2566) Rain Today for Station 70:ee:50:33:4b:fc is: 1
      2025-10-21 20:01:22.886  - debug: netatmo-crawler.0 (2566) Rounded value 1 to 1
      2025-10-21 20:01:22.892  - debug: netatmo-crawler.0 (2566) Saved rain_today for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:23.064  - debug: netatmo-crawler.0 (2566) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:23.065  - debug: netatmo-crawler.0 (2566) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:23.069  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:23.077  - debug: netatmo-crawler.0 (2566) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:23.431  - debug: netatmo-crawler.0 (2566) Body Rain_LastHour:[{"beg_time":1761066083,"value":[[0]]}]
      2025-10-21 20:01:23.431  - debug: netatmo-crawler.0 (2566) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:23.435  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
      2025-10-21 20:01:23.441  - debug: netatmo-crawler.0 (2566) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:23.449  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
      2025-10-21 20:01:23.457  - debug: netatmo-crawler.0 (2566) Rounded value 1002.1 to 1002.1
      2025-10-21 20:01:23.464  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
      2025-10-21 20:01:23.472  - debug: netatmo-crawler.0 (2566) Rounded value 79 to 79
      2025-10-21 20:01:23.479  - debug: netatmo-crawler.0 (2566) all done, exiting
      2025-10-21 20:01:23.480  - info: netatmo-crawler.0 (2566) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
      2025-10-21 20:01:24.018  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 2566 terminated with code 0 (NO_ERROR)
      2025-10-21 20:01:30.051  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2581
      2025-10-21 20:01:32.286  - debug: netatmo-crawler.0 (2581) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2025-10-21 20:01:32.355  - debug: netatmo-crawler.0 (2581) Objects client ready ... initialize now
      2025-10-21 20:01:32.359  - debug: netatmo-crawler.0 (2581) Objects create System PubSub Client
      2025-10-21 20:01:32.361  - debug: netatmo-crawler.0 (2581) Objects create User PubSub Client
      2025-10-21 20:01:32.422  - debug: netatmo-crawler.0 (2581) Objects client initialize lua scripts
      2025-10-21 20:01:32.430  - debug: netatmo-crawler.0 (2581) Objects connected to redis: 127.0.0.1:9001
      2025-10-21 20:01:32.434  - silly: netatmo-crawler.0 (2581) redis psubscribe cfg.o.system.user.*
      2025-10-21 20:01:32.467  - silly: netatmo-crawler.0 (2581) redis psubscribe cfg.o.enum.*
      2025-10-21 20:01:32.472  - silly: netatmo-crawler.0 (2581) objectDB connected
      2025-10-21 20:01:32.477  - debug: netatmo-crawler.0 (2581) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-10-21 20:01:32.500  - debug: netatmo-crawler.0 (2581) States create System PubSub Client
      2025-10-21 20:01:32.501  - debug: netatmo-crawler.0 (2581) States create User PubSub Client
      2025-10-21 20:01:32.583  - debug: netatmo-crawler.0 (2581) States connected to redis: 127.0.0.1:9000
      2025-10-21 20:01:32.584  - silly: netatmo-crawler.0 (2581) statesDB connected
      2025-10-21 20:01:32.749  - info: netatmo-crawler.0 (2581) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.21.0, js-controller: 7.0.7
      2025-10-21 20:01:32.775  - debug: netatmo-crawler.0 (2581) config stationUrls: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      2025-10-21 20:01:32.776  - debug: netatmo-crawler.0 (2581) Going to save station information with: id
      2025-10-21 20:01:32.778  - debug: netatmo-crawler.0 (2581) Trying to get token from state
      2025-10-21 20:01:32.799  - silly: netatmo-crawler.0 (2581) States system redis pmessage system.adapter.netatmo-crawler.0.logLevel/system.adapter.netatmo-crawler.0.logLevel:{"val":"silly","ack":true,"ts":1761069692780,"q":0,"from":"system.adapter.netatmo-crawler.0","lc":1732447437255}
      2025-10-21 20:01:32.809  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      2025-10-21 20:01:32.811  - debug: netatmo-crawler.0 (2581) Going to get information for station: 1
      2025-10-21 20:01:32.815  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:33:4b:fc
      2025-10-21 20:01:33.003  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:33.004  - debug: netatmo-crawler.0 (2581) Saving station data for station: 1
      2025-10-21 20:01:33.041  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
      2025-10-21 20:01:33.050  - debug: netatmo-crawler.0 (2581) Rounded value 15.1 to 15.1
      2025-10-21 20:01:33.056  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
      2025-10-21 20:01:33.065  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:33.207  - debug: netatmo-crawler.0 (2581) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.03669309616088867,"time_server":1761069693}
      2025-10-21 20:01:33.207  - debug: netatmo-crawler.0 (2581) Rain Today for Station 70:ee:50:33:4b:fc is: 1
      2025-10-21 20:01:33.212  - debug: netatmo-crawler.0 (2581) Rounded value 1 to 1
      2025-10-21 20:01:33.218  - debug: netatmo-crawler.0 (2581) Saved rain_today for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:33.346  - debug: netatmo-crawler.0 (2581) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:33.346  - debug: netatmo-crawler.0 (2581) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:33.350  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:33.356  - debug: netatmo-crawler.0 (2581) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:33.487  - debug: netatmo-crawler.0 (2581) Body Rain_LastHour:[{"beg_time":1761066093,"value":[[0]]}]
      2025-10-21 20:01:33.488  - debug: netatmo-crawler.0 (2581) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:33.491  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:33.497  - debug: netatmo-crawler.0 (2581) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:33.504  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
      2025-10-21 20:01:33.512  - debug: netatmo-crawler.0 (2581) Rounded value 1002.1 to 1002.1
      2025-10-21 20:01:33.518  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
      2025-10-21 20:01:33.525  - debug: netatmo-crawler.0 (2581) Rounded value 79 to 79
      2025-10-21 20:01:33.532  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
      2025-10-21 20:01:33.533  - debug: netatmo-crawler.0 (2581) Going to get information for station: 2
      2025-10-21 20:01:33.534  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:17:9d:ba
      2025-10-21 20:01:33.679  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:17:9d:ba","place":{"location":[13.457895,52.523834],"timezone":"Europe/Berlin","country":"DE","altitude":48,"city":"Berlin","street":"Edith-Stein-Straße"},"mark":1,"measures":{"02:00:00:17:80:7a":{"res":{"1761069287":[14.3,74]},"type":["temperature","humidity"]},"70:ee:50:17:9d:ba":{"res":{"1761069298":[998.8]},"type":["pressure"]}}}]
      2025-10-21 20:01:33.681  - debug: netatmo-crawler.0 (2581) Saving station data for station: 2
      2025-10-21 20:01:33.715  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:17:9d:ba and measure: temperature
      2025-10-21 20:01:33.725  - debug: netatmo-crawler.0 (2581) Rounded value 14.3 to 14.3
      2025-10-21 20:01:33.734  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:17:9d:ba and measure: pressure
      2025-10-21 20:01:33.745  - debug: netatmo-crawler.0 (2581) Rounded value 998.8 to 998.8
      2025-10-21 20:01:33.751  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:17:9d:ba and measure: humidity
      2025-10-21 20:01:33.758  - debug: netatmo-crawler.0 (2581) Rounded value 74 to 74
      2025-10-21 20:01:33.764  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
      2025-10-21 20:01:33.765  - debug: netatmo-crawler.0 (2581) Going to get information for station: 3
      2025-10-21 20:01:33.765  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:00:c1:94
      2025-10-21 20:01:33.863  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:00:c1:94","place":{"location":[13.4704260000001,52.5162059412954],"timezone":"Europe/Berlin","country":"DE","altitude":46,"city":"Berlin","street":"Schreinerstraße"},"mark":10,"measures":{"02:00:00:00:c7:32":{"res":{"1761069052":[15.5,69]},"type":["temperature","humidity"]},"70:ee:50:00:c1:94":{"res":{"1761069405":[1000.2]},"type":["pressure"]},"05:00:00:00:19:9a":{"res":{"1761069405":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:33.864  - debug: netatmo-crawler.0 (2581) Saving station data for station: 3
      2025-10-21 20:01:33.895  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:00:c1:94 and measure: temperature
      2025-10-21 20:01:33.903  - debug: netatmo-crawler.0 (2581) Rounded value 15.5 to 15.5
      2025-10-21 20:01:33.909  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:00:c1:94 and measure: rain
      2025-10-21 20:01:33.917  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:34.145  - debug: netatmo-crawler.0 (2581) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0.6]]}],"status":"ok","time_exec":0.03744912147521973,"time_server":1761069694}
      2025-10-21 20:01:34.146  - debug: netatmo-crawler.0 (2581) Rain Today for Station 70:ee:50:00:c1:94 is: 0.6
      2025-10-21 20:01:34.149  - debug: netatmo-crawler.0 (2581) Rounded value 0.6 to 0.6
      2025-10-21 20:01:34.155  - debug: netatmo-crawler.0 (2581) Saved rain_today for station: 70:ee:50:00:c1:94
      2025-10-21 20:01:34.339  - debug: netatmo-crawler.0 (2581) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:34.339  - debug: netatmo-crawler.0 (2581) Rain Yesterday for Station 70:ee:50:00:c1:94 is: 0
      2025-10-21 20:01:34.343  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:34.359  - debug: netatmo-crawler.0 (2581) Saved rain_yesterday for station: 70:ee:50:00:c1:94
      2025-10-21 20:01:34.563  - debug: netatmo-crawler.0 (2581) Body Rain_LastHour:[{"beg_time":1761066094,"value":[[0]]}]
      2025-10-21 20:01:34.564  - debug: netatmo-crawler.0 (2581) Rain Last Hour for Station 70:ee:50:00:c1:94 is: 0
      2025-10-21 20:01:34.568  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:34.575  - debug: netatmo-crawler.0 (2581) Saved rain_lastHour for station: 70:ee:50:00:c1:94
      2025-10-21 20:01:34.582  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:00:c1:94 and measure: pressure
      2025-10-21 20:01:34.589  - debug: netatmo-crawler.0 (2581) Rounded value 1000.2 to 1000.2
      2025-10-21 20:01:34.595  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:00:c1:94 and measure: humidity
      2025-10-21 20:01:34.602  - debug: netatmo-crawler.0 (2581) Rounded value 69 to 69
      2025-10-21 20:01:34.609  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
      2025-10-21 20:01:34.610  - debug: netatmo-crawler.0 (2581) Going to get information for station: 4
      2025-10-21 20:01:34.610  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:52:e9:c2
      2025-10-21 20:01:34.754  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761069472":[14.4,74]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761069494":[1000.6]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761069492":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:34.755  - debug: netatmo-crawler.0 (2581) Saving station data for station: 4
      2025-10-21 20:01:34.783  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
      2025-10-21 20:01:34.790  - debug: netatmo-crawler.0 (2581) Rounded value 14.4 to 14.4
      2025-10-21 20:01:34.796  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
      2025-10-21 20:01:34.812  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:34.949  - debug: netatmo-crawler.0 (2581) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.026121139526367188,"time_server":1761069694}
      2025-10-21 20:01:34.949  - debug: netatmo-crawler.0 (2581) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:34.952  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:34.958  - debug: netatmo-crawler.0 (2581) Saved rain_today for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:35.090  - debug: netatmo-crawler.0 (2581) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:35.091  - debug: netatmo-crawler.0 (2581) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:35.094  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:35.102  - debug: netatmo-crawler.0 (2581) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:35.238  - debug: netatmo-crawler.0 (2581) Body Rain_LastHour:[{"beg_time":1761066095,"value":[[0]]}]
      2025-10-21 20:01:35.238  - debug: netatmo-crawler.0 (2581) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:35.243  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:35.250  - debug: netatmo-crawler.0 (2581) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:35.258  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
      2025-10-21 20:01:35.268  - debug: netatmo-crawler.0 (2581) Rounded value 1000.6 to 1000.6
      2025-10-21 20:01:35.276  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
      2025-10-21 20:01:35.286  - debug: netatmo-crawler.0 (2581) Rounded value 74 to 74
      2025-10-21 20:01:35.293  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      2025-10-21 20:01:35.294  - debug: netatmo-crawler.0 (2581) Going to get information for station: 5
      2025-10-21 20:01:35.295  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:33:4b:fc
      2025-10-21 20:01:35.437  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:35.437  - debug: netatmo-crawler.0 (2581) Saving station data for station: 5
      2025-10-21 20:01:35.478  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
      2025-10-21 20:01:35.489  - debug: netatmo-crawler.0 (2581) Rounded value 15.1 to 15.1
      2025-10-21 20:01:35.497  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
      2025-10-21 20:01:35.508  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:35.654  - debug: netatmo-crawler.0 (2581) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.02826094627380371,"time_server":1761069695}
      2025-10-21 20:01:35.655  - debug: netatmo-crawler.0 (2581) Rain Today for Station 70:ee:50:33:4b:fc is: 1
      2025-10-21 20:01:35.658  - debug: netatmo-crawler.0 (2581) Rounded value 1 to 1
      2025-10-21 20:01:35.664  - debug: netatmo-crawler.0 (2581) Saved rain_today for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:35.907  - debug: netatmo-crawler.0 (2581) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:35.907  - debug: netatmo-crawler.0 (2581) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:35.910  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:35.924  - debug: netatmo-crawler.0 (2581) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:36.098  - debug: netatmo-crawler.0 (2581) Body Rain_LastHour:[{"beg_time":1761066095,"value":[[0]]}]
      2025-10-21 20:01:36.099  - debug: netatmo-crawler.0 (2581) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:36.103  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
      2025-10-21 20:01:36.111  - debug: netatmo-crawler.0 (2581) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:36.118  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
      2025-10-21 20:01:36.126  - debug: netatmo-crawler.0 (2581) Rounded value 1002.1 to 1002.1
      2025-10-21 20:01:36.132  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
      2025-10-21 20:01:36.141  - debug: netatmo-crawler.0 (2581) Rounded value 79 to 79
      2025-10-21 20:01:36.151  - debug: netatmo-crawler.0 (2581) all done, exiting
      2025-10-21 20:01:36.153  - info: netatmo-crawler.0 (2581) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
      2025-10-21 20:01:36.697  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 2581 terminated with code 0 (NO_ERROR)
      2025-10-21 20:01:45.036  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2596
      2025-10-21 20:01:47.315  - debug: netatmo-crawler.0 (2596) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2025-10-21 20:01:47.392  - debug: netatmo-crawler.0 (2596) Objects client ready ... initialize now
      2025-10-21 20:01:47.397  - debug: netatmo-crawler.0 (2596) Objects create System PubSub Client
      2025-10-21 20:01:47.400  - debug: netatmo-crawler.0 (2596) Objects create User PubSub Client
      2025-10-21 20:01:47.467  - debug: netatmo-crawler.0 (2596) Objects client initialize lua scripts
      2025-10-21 20:01:47.476  - debug: netatmo-crawler.0 (2596) Objects connected to redis: 127.0.0.1:9001
      2025-10-21 20:01:47.480  - silly: netatmo-crawler.0 (2596) redis psubscribe cfg.o.system.user.*
      2025-10-21 20:01:47.514  - silly: netatmo-crawler.0 (2596) redis psubscribe cfg.o.enum.*
      2025-10-21 20:01:47.519  - silly: netatmo-crawler.0 (2596) objectDB connected
      2025-10-21 20:01:47.524  - debug: netatmo-crawler.0 (2596) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-10-21 20:01:47.552  - debug: netatmo-crawler.0 (2596) States create System PubSub Client
      2025-10-21 20:01:47.553  - debug: netatmo-crawler.0 (2596) States create User PubSub Client
      2025-10-21 20:01:47.635  - debug: netatmo-crawler.0 (2596) States connected to redis: 127.0.0.1:9000
      2025-10-21 20:01:47.636  - silly: netatmo-crawler.0 (2596) statesDB connected
      2025-10-21 20:01:47.652  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
      2025-10-21 20:01:47.655  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:51758
      2025-10-21 20:01:47.793  - info: netatmo-crawler.0 (2596) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.21.0, js-controller: 7.0.7
      2025-10-21 20:01:47.818  - debug: netatmo-crawler.0 (2596) config stationUrls: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      2025-10-21 20:01:47.819  - debug: netatmo-crawler.0 (2596) Going to save station information with: id
      2025-10-21 20:01:47.820  - debug: netatmo-crawler.0 (2596) Trying to get token from state
      2025-10-21 20:01:47.842  - silly: netatmo-crawler.0 (2596) States system redis pmessage system.adapter.netatmo-crawler.0.logLevel/system.adapter.netatmo-crawler.0.logLevel:{"val":"silly","ack":true,"ts":1761069707823,"q":0,"from":"system.adapter.netatmo-crawler.0","lc":1732447437255}
      2025-10-21 20:01:47.846  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      2025-10-21 20:01:47.848  - debug: netatmo-crawler.0 (2596) Going to get information for station: 1
      2025-10-21 20:01:47.852  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:33:4b:fc
      2025-10-21 20:01:48.341  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:48.342  - debug: netatmo-crawler.0 (2596) Saving station data for station: 1
      2025-10-21 20:01:48.378  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
      2025-10-21 20:01:48.387  - debug: netatmo-crawler.0 (2596) Rounded value 15.1 to 15.1
      2025-10-21 20:01:48.393  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
      2025-10-21 20:01:48.402  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:48.919  - debug: netatmo-crawler.0 (2596) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.023617029190063477,"time_server":1761069708}
      2025-10-21 20:01:48.920  - debug: netatmo-crawler.0 (2596) Rain Today for Station 70:ee:50:33:4b:fc is: 1
      2025-10-21 20:01:48.924  - debug: netatmo-crawler.0 (2596) Rounded value 1 to 1
      2025-10-21 20:01:48.930  - debug: netatmo-crawler.0 (2596) Saved rain_today for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:50.166  - debug: netatmo-crawler.0 (2596) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:50.166  - debug: netatmo-crawler.0 (2596) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:50.170  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:50.176  - debug: netatmo-crawler.0 (2596) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:50.382  - debug: netatmo-crawler.0 (2596) Body Rain_LastHour:[{"beg_time":1761066110,"value":[[0]]}]
      2025-10-21 20:01:50.383  - debug: netatmo-crawler.0 (2596) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:50.386  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:50.392  - debug: netatmo-crawler.0 (2596) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:50.399  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
      2025-10-21 20:01:50.406  - debug: netatmo-crawler.0 (2596) Rounded value 1002.1 to 1002.1
      2025-10-21 20:01:50.412  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
      2025-10-21 20:01:50.420  - debug: netatmo-crawler.0 (2596) Rounded value 79 to 79
      2025-10-21 20:01:50.426  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
      2025-10-21 20:01:50.426  - debug: netatmo-crawler.0 (2596) Going to get information for station: 2
      2025-10-21 20:01:50.427  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:17:9d:ba
      2025-10-21 20:01:51.433  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:17:9d:ba","place":{"location":[13.457895,52.523834],"timezone":"Europe/Berlin","country":"DE","altitude":48,"city":"Berlin","street":"Edith-Stein-Straße"},"mark":1,"measures":{"02:00:00:17:80:7a":{"res":{"1761069287":[14.3,74]},"type":["temperature","humidity"]},"70:ee:50:17:9d:ba":{"res":{"1761069298":[998.8]},"type":["pressure"]}}}]
      2025-10-21 20:01:51.434  - debug: netatmo-crawler.0 (2596) Saving station data for station: 2
      2025-10-21 20:01:51.470  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:17:9d:ba and measure: temperature
      2025-10-21 20:01:51.480  - debug: netatmo-crawler.0 (2596) Rounded value 14.3 to 14.3
      2025-10-21 20:01:51.487  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:17:9d:ba and measure: pressure
      2025-10-21 20:01:51.495  - debug: netatmo-crawler.0 (2596) Rounded value 998.8 to 998.8
      2025-10-21 20:01:51.501  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:17:9d:ba and measure: humidity
      2025-10-21 20:01:51.511  - debug: netatmo-crawler.0 (2596) Rounded value 74 to 74
      2025-10-21 20:01:51.528  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
      2025-10-21 20:01:51.528  - debug: netatmo-crawler.0 (2596) Going to get information for station: 3
      2025-10-21 20:01:51.529  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:00:c1:94
      2025-10-21 20:01:51.715  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:00:c1:94","place":{"location":[13.4704260000001,52.5162059412954],"timezone":"Europe/Berlin","country":"DE","altitude":46,"city":"Berlin","street":"Schreinerstraße"},"mark":10,"measures":{"02:00:00:00:c7:32":{"res":{"1761069052":[15.5,69]},"type":["temperature","humidity"]},"70:ee:50:00:c1:94":{"res":{"1761069405":[1000.2]},"type":["pressure"]},"05:00:00:00:19:9a":{"res":{"1761069405":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:51.716  - debug: netatmo-crawler.0 (2596) Saving station data for station: 3
      2025-10-21 20:01:51.766  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:00:c1:94 and measure: temperature
      2025-10-21 20:01:51.778  - debug: netatmo-crawler.0 (2596) Rounded value 15.5 to 15.5
      2025-10-21 20:01:51.786  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:00:c1:94 and measure: rain
      2025-10-21 20:01:51.796  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:51.988  - debug: netatmo-crawler.0 (2596) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0.6]]}],"status":"ok","time_exec":0.029054880142211914,"time_server":1761069711}
      2025-10-21 20:01:51.989  - debug: netatmo-crawler.0 (2596) Rain Today for Station 70:ee:50:00:c1:94 is: 0.6
      2025-10-21 20:01:51.999  - debug: netatmo-crawler.0 (2596) Rounded value 0.6 to 0.6
      2025-10-21 20:01:52.014  - debug: netatmo-crawler.0 (2596) Saved rain_today for station: 70:ee:50:00:c1:94
      2025-10-21 20:01:52.178  - debug: netatmo-crawler.0 (2596) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:52.179  - debug: netatmo-crawler.0 (2596) Rain Yesterday for Station 70:ee:50:00:c1:94 is: 0
      2025-10-21 20:01:52.183  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:52.191  - debug: netatmo-crawler.0 (2596) Saved rain_yesterday for station: 70:ee:50:00:c1:94
      2025-10-21 20:01:52.340  - debug: netatmo-crawler.0 (2596) Body Rain_LastHour:[{"beg_time":1761066112,"value":[[0]]}]
      2025-10-21 20:01:52.341  - debug: netatmo-crawler.0 (2596) Rain Last Hour for Station 70:ee:50:00:c1:94 is: 0
      2025-10-21 20:01:52.347  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:52.357  - debug: netatmo-crawler.0 (2596) Saved rain_lastHour for station: 70:ee:50:00:c1:94
      2025-10-21 20:01:52.366  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:00:c1:94 and measure: pressure
      2025-10-21 20:01:52.377  - debug: netatmo-crawler.0 (2596) Rounded value 1000.2 to 1000.2
      2025-10-21 20:01:52.385  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:00:c1:94 and measure: humidity
      2025-10-21 20:01:52.396  - debug: netatmo-crawler.0 (2596) Rounded value 69 to 69
      2025-10-21 20:01:52.404  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
      2025-10-21 20:01:52.404  - debug: netatmo-crawler.0 (2596) Going to get information for station: 4
      2025-10-21 20:01:52.405  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:52:e9:c2
      2025-10-21 20:01:52.500  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761069472":[14.4,74]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761069494":[1000.6]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761069492":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:52.501  - debug: netatmo-crawler.0 (2596) Saving station data for station: 4
      2025-10-21 20:01:52.543  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
      2025-10-21 20:01:52.554  - debug: netatmo-crawler.0 (2596) Rounded value 14.4 to 14.4
      2025-10-21 20:01:52.563  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
      2025-10-21 20:01:52.574  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:52.718  - debug: netatmo-crawler.0 (2596) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.03166007995605469,"time_server":1761069712}
      2025-10-21 20:01:52.718  - debug: netatmo-crawler.0 (2596) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:52.723  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:52.730  - debug: netatmo-crawler.0 (2596) Saved rain_today for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:52.909  - debug: netatmo-crawler.0 (2596) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:52.909  - debug: netatmo-crawler.0 (2596) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:52.912  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:52.918  - debug: netatmo-crawler.0 (2596) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:53.047  - debug: netatmo-crawler.0 (2596) Body Rain_LastHour:[{"beg_time":1761066112,"value":[[0]]}]
      2025-10-21 20:01:53.047  - debug: netatmo-crawler.0 (2596) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
      2025-10-21 20:01:53.051  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:53.057  - debug: netatmo-crawler.0 (2596) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
      2025-10-21 20:01:53.064  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
      2025-10-21 20:01:53.071  - debug: netatmo-crawler.0 (2596) Rounded value 1000.6 to 1000.6
      2025-10-21 20:01:53.077  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
      2025-10-21 20:01:53.084  - debug: netatmo-crawler.0 (2596) Rounded value 74 to 74
      2025-10-21 20:01:53.090  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
      2025-10-21 20:01:53.091  - debug: netatmo-crawler.0 (2596) Going to get information for station: 5
      2025-10-21 20:01:53.091  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:33:4b:fc
      2025-10-21 20:01:53.631  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
      2025-10-21 20:01:53.632  - debug: netatmo-crawler.0 (2596) Saving station data for station: 5
      2025-10-21 20:01:53.664  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
      2025-10-21 20:01:53.672  - debug: netatmo-crawler.0 (2596) Rounded value 15.1 to 15.1
      2025-10-21 20:01:53.678  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
      2025-10-21 20:01:53.685  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:54.179  - debug: netatmo-crawler.0 (2596) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.02421402931213379,"time_server":1761069713}
      2025-10-21 20:01:54.180  - debug: netatmo-crawler.0 (2596) Rain Today for Station 70:ee:50:33:4b:fc is: 1
      2025-10-21 20:01:54.184  - debug: netatmo-crawler.0 (2596) Rounded value 1 to 1
      2025-10-21 20:01:54.195  - debug: netatmo-crawler.0 (2596) Saved rain_today for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:54.329  - debug: netatmo-crawler.0 (2596) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
      2025-10-21 20:01:54.329  - debug: netatmo-crawler.0 (2596) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:54.332  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:54.338  - debug: netatmo-crawler.0 (2596) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:54.478  - debug: netatmo-crawler.0 (2596) Body Rain_LastHour:[{"beg_time":1761066114,"value":[[0]]}]
      2025-10-21 20:01:54.479  - debug: netatmo-crawler.0 (2596) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
      2025-10-21 20:01:54.482  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
      2025-10-21 20:01:54.488  - debug: netatmo-crawler.0 (2596) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
      2025-10-21 20:01:54.496  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
      2025-10-21 20:01:54.519  - debug: netatmo-crawler.0 (2596) Rounded value 1002.1 to 1002.1
      2025-10-21 20:01:54.526  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
      2025-10-21 20:01:54.535  - debug: netatmo-crawler.0 (2596) Rounded value 79 to 79
      2025-10-21 20:01:54.545  - debug: netatmo-crawler.0 (2596) all done, exiting
      2025-10-21 20:01:54.548  - info: netatmo-crawler.0 (2596) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
      2025-10-21 20:01:55.086  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 2596 terminated with code 0 (NO_ERROR)
      2025-10-21 20:02:47.655  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
      2025-10-21 20:02:47.657  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:46875
      2025-10-21 20:04:47.650  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
      2025-10-21 20:04:47.652  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:47746
      2025-10-21 20:05:13.225  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2025-10-21 20:05:19.127  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
      2025-10-21 20:05:45.053  - warn: backitup.0 (738) [iobroker/clean] No older backup files are deleted, because this backup was started manually
      2025-10-21 20:05:46.299  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
      2025-10-21 20:05:46.311  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
      2025-10-21 20:05:48.410  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
      2025-10-21 20:05:48.416  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
      2025-10-21 20:05:52.266  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
      2025-10-21 20:05:52.271  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
      2025-10-21 20:05:59.600  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
      2025-10-21 20:05:59.607  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
      2025-10-21 20:08:47.669  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
      2025-10-21 20:08:47.672  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:35207
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.12.47+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       19:54:04 up  1:17,  2 users,  load average: 0.37, 0.32, 0.35
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      @babu242
      Die aufzurufende URL steht auch im Log:
      2025-10-21 19:23:51.287  - error: alexa2.0 (1252) Error: Please open http://192.168.178.43:33373/ with your browser and login to Amazon. The cookie will be output here after successfull login.
      Das ist natürlich was anders als:
      Das ist die ip auf die zugegriffen werden soll, geht aber nicht. 192.168.178.79:8081/#tab-instances
      Seite nicht erreichbar
        @babu242
        Babu242
        @thomas-braun sagte in Alexa 2 meldet immer error 401 unauthorized:
        Sorry mein Fehler tatsächlich habe ich die falsche ip kopiert.
        Es wurde tatsächlich diese aufgerufen ohne Erfolg!
        • B Babu242
          @babu242
          Irgendwas klemmt da bei dir.
          systemctl status NetworkManager-wait-online.service
          sagt?
            @babu242
            sagt?
            Babu242
            Leider habe ich keine Ahnung was das bedeutet oder was das ein kann.
            Du vielleicht ?
            • B Babu242
              Du vielleicht ?
              @babu242
              Du sollst dir anschauen, warum der Service nicht startet. Steht in der Regel in der Ausgabe von
              drin.
                @babu242
                drin.
                Babu242
                Soll ich das hier posten weil ich kann damit leider nix anfangen?
                • B Babu242
                  @babu242
                  Vielleicht aber andere...
                    @babu242
                    Babu242
                    code_text
                    ```pi@raspberrypi:~ $ systemctl status NetworkManager-wait-online.service
                    × NetworkManager-wait-online.service - Network Manager Wait Online
                         Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; en>
                         Active: failed (Result: exit-code) since Tue 2025-10-21 18:37:50 CEST; 2h >
                           Docs: man:nm-online(1)
                        Process: 580 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=1/FAIL>
                       Main PID: 580 (code=exited, status=1/FAILURE)
                            CPU: 135ms
                    Oct 21 18:36:37 raspberrypi systemd[1]: Starting NetworkManager-wait-online.ser>
                    Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Mai>
                    Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Fai>
                    Oct 21 18:37:50 raspberrypi systemd[1]: Failed to start NetworkManager-wait-onl>
                    lines 1-12/12 (END)...skipping...
                         Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; enabled; preset: enabled)
                         Active: failed (Result: exit-code) since Tue 2025-10-21 18:37:50 CEST; 2h 28min ago
                        Process: 580 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=1/FAILURE)
                            CPU: 135ms
                    Oct 21 18:36:37 raspberrypi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                    Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Main process exited, code=exited, status=1/FAILURE
                    Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Failed with result 'exit-code'.
                    Oct 21 18:37:50 raspberrypi systemd[1]: Failed to start NetworkManager-wait-online.service - Network Manager Wait Online.
                    • B Babu242
                      code_text
                              CPU: 135ms
                              CPU: 135ms
                      @babu242
                      Mach das Terminalfenster größer. Da fehlt rechts was. Vollständig sieht das so aus:
                      echad@chet:~ $ systemctl status NetworkManager-wait-online.service
                      ● NetworkManager-wait-online.service - Network Manager Wait Online
                           Loaded: loaded (/usr/lib/systemd/system/NetworkManager-wait-online.service; enabled; preset: enabled)
                           Active: active (exited) since Fri 2025-10-17 19:18:37 CEST; 4 days ago
                       Invocation: 0d12bc9b8d424505b4cbbcd301f66b88
                             Docs: man:NetworkManager-wait-online.service(8)
                          Process: 800 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=0/SUCCESS)
                         Main PID: 800 (code=exited, status=0/SUCCESS)
                              CPU: 77ms
                      Oct 17 19:18:33 chet systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                      Oct 17 19:18:37 chet systemd[1]: Finished NetworkManager-wait-online.service - Network Manager Wait Online.
                      echad@chet:~ $
                        @babu242
                                CPU: 77ms
                        echad@chet:~ $
                        Babu242
                        Hmm
                        also mein Terminalfenster ist max. groß und ich sehe auch nicht mehr.
                        • B Babu242
                          Hmm
                          @babu242
                          Du hast das ja auch zweimal aufgerufen...
                          Bitte immer inkl. LogIn Prompt posten, dann sieht man was wo anfängt und wo was aufhört. Und man sieht auch wo du da im Dateibaum gerade herumstehst. Das kann wichtig sein.
                          sudo systemctl restart NetworkManager-wait-online.service
                            @babu242
                            Babu242
                            code_text
                            ```pi@raspberrypi:~ $ sudo systemctl restart NetworkManager-wait-online.service
                                 Active: active (exited) since Tue 2025-10-21 21:22:55 CEST; 23s ago
                                Process: 3062 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=0/SUCCESS)
                               Main PID: 3062 (code=exited, status=0/SUCCESS)
                                    CPU: 36ms
                            Oct 21 21:22:55 raspberrypi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                            Oct 21 21:22:55 raspberrypi systemd[1]: Finished NetworkManager-wait-online.service - Network Manager Wait Online.
                            • B Babu242
                              code_text
                                      CPU: 36ms
                              @babu242
                              Dann läuft jetzt der Service schon mal wieder.
                              Nicht das der zwingend was mit deinem Alexa-Proxy zu tun hat, könnte aber sein.
                              Versuch jetzt nochmal den Adapter einzuloggen, vielleicht auch mal das Cookie neuziehen lassen.
                              B 2 Antworten Letzte Antwort
                                @babu242 sagte in Alexa 2 meldet immer error 401 unauthorized:
                                Wie erstelle ich den das nötige Log?
                                Terminal auf,
                                iob logs --watch
                                aufrufen, mit dem Adapter herumhantieren, Output hier reinkopieren, in </> CodeTags eingebettet. Die Ausgabe von
                                iob diag
                                kannste aber auch mal dazu geben. Schadet nicht.
                                @Homoran Bitte Thread splitten, das wird was anderes als im OP.
                                @thomas-braun sagte in Neier Arbeitstitel:
                                erledigt!
                                typischer Fall von eben nicht
                                @babu242 sagte in Neier Arbeitstitel:
                                die gleiche Herausforderung.
                                @Babu242
                                Bitte Threadtitel anpassen
                                  erledigt!
                                  @Babu242
                                  Babu242
                                  Danke für denn neuen Thread.
                                  Wie oder wo benenne ich den denn Neu?
                                    @babu242
                                    Babu242
                                    Hi erst mall viele dank für deine Unterstützung.
                                    Wollte ich schon gestern Abend sagen, konnte aber keine Nachricht mehr versenden habe dauernd eine Fehlermeldung bekommen.
                                    hab ich schon gestern aber auch heute versucht geht nicht.
                                    • B Babu242
                                      @babu242 ersten Post editieren und Titel ändern
                                      • B Babu242
                                        mcm1957M Offline
                                        mcm1957M Offline
                                        mcm1957
                                        @babu242 said in Neier Arbeitstitel:
                                        Wenn du das Posten im Forum meinst:
                                        Einfach F5 / Refresh drücken und dann gehts
                                        Support Repositoryverwaltung.
                                        LESEN - gute Forenbeitrage
                                        • mcm1957M mcm1957
                                          Babu242
                                          @mcm1957
                                          ah nein Sorry ich hab das versucht:
