  4. Test Adapter BMW/Mini v4.x.x
    6.8k
1.1k Beiträge 103 Kommentatoren 377.9k Aufrufe 89 Beobachtet
    manny4566
    schrieb am zuletzt editiert von manny4566
    #817
    hi,
    diese Fehler kommen aktuell noch bei mir nach Adapter Neustart.
    bmw.0
    2025-10-03 12:03:31.450	info	API quota: 35/50 calls remaining for static data. Updates via MQTT do not count against quota.
    bmw.0
    2025-10-03 12:03:31.450	info	MQTT streaming: enabled
    bmw.0
    2025-10-03 12:03:31.450	info	BMW CarData adapter startup complete
    bmw.0
    2025-10-03 12:03:31.450	info	Setting up periodic updates for static data every 30 minutes for 2 vehicle(s)
    bmw.0
    2025-10-03 12:03:27.546	error	Response data: {"exveErrorId":"CU-500","exveErrorMsg":"Internal server error","exveErrorRef":"YKr#j8uGqZkBn6O0bCEU","exveNote":"The server encountered an unexpected condition which prevented it from fulfilling the request."}
    bmw.0
    2025-10-03 12:03:27.546	error	Response status: 500
    bmw.0
    2025-10-03 12:03:27.546	error	fetch locationBasedChargingSettings for XXX failed: Request failed with status code 500
    bmw.0
    2025-10-03 12:03:27.462	error	Response data: {"exveErrorId":"CU-400","exveErrorMsg":"Not Acceptable","exveErrorRef":null,"exveNote":"This error is raised when the request is wrong."}
    bmw.0
    2025-10-03 12:03:27.462	error	Response status: 406
    bmw.0
    2025-10-03 12:03:27.462	error	fetch image for XXX failed: Request failed with status code 406
    bmw.0
    2025-10-03 12:03:23.073	error	Response data: {"exveErrorId":"CU-127","exveErrorMsg":"No LBCS data found","exveErrorRef":"eEX#yLmGqZkBMlwwSwGT","exveNote":"This application error is raised if no LBCS data is available for the given VIN. "}
    bmw.0
    2025-10-03 12:03:23.073	error	Response status: 404
    bmw.0
    2025-10-03 12:03:23.073	error	fetch locationBasedChargingSettings for XXX failed: Request failed with status code 404
    bmw.0
    2025-10-03 12:03:22.915	error	Response data: {"exveErrorId":"CU-400","exveErrorMsg":"Not Acceptable","exveErrorRef":null,"exveNote":"This error is raised when the request is wrong."}
    bmw.0
    2025-10-03 12:03:22.915	error	Response status: 406
    bmw.0
    2025-10-03 12:03:22.915	error	fetch image for XXX failed: Request failed with status code 406
    • F Offline
      frank11
      #818
      Thanks for updating the Adapter. Works for me.
      Now I have to check my Database fields to match the new data into them.
      • JB_SullivanJ JB_Sullivan
        @manny4566 sagte in Test Adapter BMW/Mini v4.x.x:
        Kann natürlich sein, dass BMW auch noch nicht ganz fertig ist mit der neuen API.
        Das vermute ich auch, denn ich hatte eben folgendes Phänomen.
        ioBroker zeigt 73% SoC an (von 60% bis auf 73% konnte man Live mit zugucken) . Danach ist er dann bei 73% eingefroren.
        In der BMW App wurde mir zu dem Zeitpunkt 92% angezeigt.
        Ich habe also über die App fernentriegelt. In dem Moment ist er in ioB auf 85% SoC gesprungen und in der App von 92% auf 86% zurück gegangen - durch das entriegeln wird ja der Ladevorgang gestoppt.
        Nach dem verriegeln hat er dann bei 86% weiter geladen. Ich bin gespannt wann er fertig ist mit laden - zur ursprünglich berechneten Zeit, oder jetzt mit dem Rücksetzer ein paar Stunden später.
        S Nicht stören
        S Nicht stören
        stenmic
        #819
        @jb_sullivan @smass
        Heute das erste mal geladen.
        Bei mir wird
        .stream.vehicle.drivetrain.batteryManagement.header.value
        .stream.vehicle.drivetrain.electricEngine.kombiRemainingElectricRange.value
        .stream.vehicle.drivetrain.lastRemainingRange.value
        ca. alle 20 min aktualisiert ohne das ich ihn "aufwecken" muss. Ist ein X1 Hyprid.
        • S stenmic
          @jb_sullivan @smass
          Bei mir wird
          smass
          #820
          @stenmic
          Danke für die Info. Hast du am Adapter was anders konfiguriert? Ich lade gerade und das letzte StreamUpdate war vor 35 min. Das ist Mist wenn man nach SoC laden möchte. Da steht aber auch MQTT liefert Echtzeitdaten. Mhhhhh
          Steffe.S.S 1 Antwort Letzte Antwort
          • S smass
            @stenmic
            Steffe.S.S Offline
            Steffe.S.S Offline
            Steffe.S.
            schrieb am zuletzt editiert von Steffe.S.
            #821
            @smass
            Ich lade hier auch gerade unseren Mini. Angesteckt um 12:45 Uhr bis jetzt 13:17 Uhr keine Aktualisierung des SOC bzw der Reichweite..
            Ich habe nicht wirklich gezwungen nichts anzuklicken bzw händisch zu aktualisieren
            • Steffe.S.S Steffe.S.
              @smass
              smass
              schrieb am zuletzt editiert von smass
              #822
              jepp keine Aktualisierung. So ein Sch...! Da kann man nicht mehr SoC gesteuert laden.
              bmw.0
              2025-10-03 13:04:20.768	info	BMW MQTT stream connected
              bmw.0
              2025-10-03 13:04:20.718	info	API quota: 41/50 calls remaining for static data. Updates via MQTT do not count against quota.
              bmw.0
              2025-10-03 13:04:20.718	info	MQTT streaming: enabled
              bmw.0
              2025-10-03 13:04:20.717	info	BMW CarData adapter startup complete
              jetzt ist es 13:32 Uhr.
              Update:
              13:49 Uhr war das nächste StreamData Update.
              bmw.0
              2025-10-03 13:49:23.366	info	BMW MQTT stream connected
              bmw.0
              2025-10-03 13:49:21.315	info	MQTT connection closed
              bmw.0
              • S smass
                bmw.0
                bmw.0
                bmw.0
                bmw.0
                Update:
                bmw.0
                bmw.0
                bmw.0
                Steffe.S.S Offline
                Steffe.S.S Offline
                Steffe.S.
                #823
                @smass
                zumindest rechnet EVCC den SOC bei mir ziemlich genau hoch.
                Die einzige Idee, die schon @lobomau erwähnt hat, ist den Ladevorgang alle 20 min für 1 min zu unterbrechen. Dann wird auch der SOC aktualisiert.
                  @tombox
                  Den Datenpunkt gibt es bei mir nicht. Wie ich schon oben geschrieben hatte - Es sind sehr viele DP`s (zwar unter anderer Bezeichnung) in der Liste mit drin, welche unter der alten API auch bei meinem Auto entsprechende Werte geliefert hatten.
                  Jetzt werden diese DP`s zumindest für den BMW i3S nicht mehr in den ioBroker geschrieben und somit auch nicht mit Daten gefüllt.
                  tombox
                  #824
                  @jb_sullivan ich habe die api Nutzung geändert und api container hinzugefügt bitte mal die GitHub version testen und oben man über remote.fetchViaAPI vielleicht Daten während des Ladens bekommt
                  Steffe.S.S S 3 Antworten Letzte Antwort
                  • T tombox
                    Steffe.S.S Offline
                    Steffe.S.S Offline
                    Steffe.S.
                    #825
                    @tombox sagte in Test Adapter BMW/Mini v4.x.x:
                    👍 neue Version geladen, Ladevorgang um 14:02Uhr gestartet mit 85% --> Rückmeldung folgt
                    Danke für die schnelle und unermüdliche Aktualisierung des Adapters
                    S Steffe.S.S 2 Antworten Letzte Antwort
                      smass
                      #826
                      @steffe-s
                      wie läd man die Version aus GitHub? einfach npm install iobroker.bmw? Danke... :-)
                      • S smass
                        @steffe-s
                        Steffe.S.S Offline
                        Steffe.S.S Offline
                        Steffe.S.
                        #827
                        @smass
                        ich mach es so ......
                          @smass
                          smass
                          #828
                          @steffe-s
                          Vielen Dank für das ToDo. 👍
                          • T tombox
                            Steffe.S.S Offline
                            Steffe.S.S Offline
                            Steffe.S.
                            #829
                            @tombox
                            bmw.0
                            Zeit
                            debug
                            Nachricht
                            bmw.0
                            2025-10-03 14:37:02.559	info	BMW MQTT stream connected
                            bmw.0
                            2025-10-03 14:37:02.440	info	API quota: 46/50 calls remaining for static data. Updates via MQTT do not count against quota.
                            bmw.0
                            2025-10-03 14:37:02.440	info	MQTT streaming: enabled
                            bmw.0
                            2025-10-03 14:37:02.439	info	BMW CarData adapter startup complete
                            bmw.0
                            2025-10-03 14:37:02.116	error	Failed to setup telematic container
                            bmw.0
                            2025-10-03 14:37:02.116	error	Response data: {"exveErrorId":"CU-429","exveErrorMsg":"API rate limit reached","exveErrorRef":"","exveNote":"This application error is raised when the daily rate limit has been reached."}
                            bmw.0
                            2025-10-03 14:37:02.115	error	Response status: 429
                            bmw.0
                            2025-10-03 14:37:02.115	error	Failed to create telematic container: Request failed with status code 429
                            bmw.0
                            2025-10-03 14:37:02.114	error	Response data: {"exveErrorId":"CU-429","exveErrorMsg":"API rate limit reached","exveErrorRef":"","exveNote":"This application error is raised when the daily rate limit has been reached."}
                            bmw.0
                            2025-10-03 14:37:02.113	error	Response status: 429
                            bmw.0
                            2025-10-03 14:37:02.111	error	create telematic container failed: Request failed with status code 429
                            bmw.0
                            2025-10-03 14:37:02.055	info	Creating container with 294 technical identifiers from telematic.json
                            bmw.0
                            2025-10-03 14:37:02.043	info	Setting up telematic container...
                            API - Ordner ist nach Neuinstallation nicht vorhanden, nur der Streamordner (dieser wird auch befüllt)
                            Edit: anscheint habe ich mein Limit überschritten...
                              manny4566
                              #830
                              @steffe-s
                              Wie hast du den SOC in evcc bei dir eingebaut ? Evcc ist doch noch nicht angepasst für die neue API oder ?
                              • JB_SullivanJ Offline
                                JB_Sullivan
                                schrieb am zuletzt editiert von JB_Sullivan
                                #831
                                @tombox
                                Vielen Dank für die neue GIT Version. Diese kam für mich gerade passend, da das Auto an der Ladestation hing.
                                Es sind nun unglaublich viele neue DP`s unter dem Stream Register dazu gekommen. Für mich macht es den Eindruck als wenn das ALLE verfügbaren Datenpunkte sind die es gibt und nicht mehr über die FIN Fahrzeug spezifisch separiert wird.
                                Mit aktivem Ladevorgang und anschließender Testrunde durch den Ort, haben sich 95% der Datenpunkte NICHT mit Leben gefüllt. Ein Großteil der Datenpunkte beziehen sich auf Verbrenner und Funktionen die es bei meinem BMW i3S nie gab (z.B. Lenkradheizung, Sitzbelüftung, Benzinverbräuche usw.)
                                Fehlermeldungen während der Installation des neuen Adapter gab es keine.
                                PS: Jetzt habe ich im übrigen den DeepSleep Datenpunkt - der bleibt aber leer.
                                bmw.0
                                14760	2025-10-03 14:04:05.184	info	Container verification successful: Retrieved 293 telematic data points for WBxxxxxxxxxxx
                                bmw.0
                                14760	2025-10-03 14:04:05.936	info	Setting up periodic telematic data updates every 60 minutes for 1 vehicle(s)
                                bmw.0
                                14760	2025-10-03 14:04:05.937	info	BMW CarData adapter startup complete
                                bmw.0
                                14760	2025-10-03 14:04:05.937	info	MQTT streaming: enabled
                                bmw.0
                                14760	2025-10-03 14:04:05.938	info	API quota: 46/50 calls remaining for static data. Updates via MQTT do not count against quota.
                                bmw.0
                                14760	2025-10-03 14:04:06.074	info	BMW MQTT stream connected
                                • M manny4566
                                  @steffe-s
                                  Steffe.S.S Offline
                                  Steffe.S.S Offline
                                  Steffe.S.
                                  #832
                                  @manny4566
                                  per MQTT schicke ich diese Daten zu EVCC rüber:
                                  Angemeldet als : Benutzerdefiniertes Gerät
                                  title: EVE
                                  icon: car
                                  capacity: 28.9 # kWh
                                  ## required attributes
                                  soc: # battery soc (%)
                                    source: mqtt
                                    topic: evcc_meters/mini_soc
                                  range: # optional electric range (km)
                                    source: mqtt
                                    topic: evcc_meters/mini_range
                                  odometer: # optional odometer (km)
                                    source: mqtt
                                    topic: evcc_meters/mini_odometer
                                  status: # status [A..F]
                                    source: mqtt
                                    topic: evcc_meters/mini_charge_status
                                  Die Datenpunkte befülle ich mit einem Blockly
                                    @manny4566
                                    title: EVE
                                    icon: car
                                      source: mqtt
                                      source: mqtt
                                      source: mqtt
                                      source: mqtt
                                    manny4566
                                    #833
                                    @steffe-s
                                    evcc muss ja eh umgestellt werden entweder auf deine Lösung oder das pullen der Daten aus iobroker raus; so mache ich das aktuell.
                                    Der BMW Stream lässt ja glaube ich nur eine Verbindung zu. Von daher kann man ja nicht den Adapter und evcc zusammen gegen den Stream anmelden.
                                    Danke für die Info. Bei dir sind das aber nur die Daten, die du im evcc als Objekt dann darstellst ? Oder nutzt du den Soc dann auch für die Berechnung der Ladedauer etc. im evcc ?
                                    Steffe.S.S B 2 Antworten Letzte Antwort
                                    • M manny4566
                                      @steffe-s
                                      Steffe.S.S Offline
                                      Steffe.S.S Offline
                                      Steffe.S.
                                      #834
                                      @manny4566
                                      EVCC rechnet selber den SOC hoch, ich liefere quasi den SOC bei Beginn und den Rest macht EVCC. DIE Reichweite wird nicht mit berechnet.
                                      Wenn sich die Wallbox abschaltet (z.B. wenn zu wenig Sonne da ist) aktualisiert sich der SOC und Range wieder auf den BMW / MINI Wert über MQTT.
                                        @manny4566
                                        manny4566
                                        #835
                                        @steffe-s Ja stimmt, stand gerade auf dem Schlauch :D
                                        • M manny4566
                                          sticks
                                          schrieb am zuletzt editiert von sticks
                                          #836
                                          Ich hab den neuen 4.x Adapter nun auch seit gestern am Laufen, zusammen mit meinem BMW ix3 von 2024.
                                          Grundsätzlich kommen alle Werte die ich brauche, jetzt über den neuen 4.0.5 Adapter, aber wirklich nachteilig das der SOC der Batterie wirklich nur alle 20 Minuten mal aktualisiert wird, während das Auto lädt. Genauso die "verbleibende Ladezeit" (remainingchargetime), auch nur alle 20 Minuten kommt. - Das ist echt bitter, von wegen MQTT Echtzeitdaten. - Ich hoffe da arbeitet BMW noch dran, so ist das aktuell nicht wirklich brauchbar im SmartHome.
                                          Aber nicht missverstehen: Großen Respekt an den Adapter-Autor für die schnelle Reaktion !!!
                                          Blöd auch, dass man nicht mehr direkt über diesen Adapter steuern kann. Aber kleiner Tipp: Teilweise kann man den "BMW Alexa-Skill" für die Steuerung missbrauchen. Man kann beispielsweise von iobroker die gesprochenen Kommandos in Textform an einen Alexa-Speaker übergeben, z.B. den Text "Sage BMW starte Klimatisierung" und dann kann iobroker immer noch die standheizung anschalten/ausschalten. - Man kann Alexa ja auch nach dem Ladestand fragen, beispielsweise "sage bmw wie ist der ladestand" und Alexa Antwortet dann mit dem Echtzeitwert, der über MQTT noch nicht da ist. - Ob man diese Antwort wohl weiterverarbeiten könnte :-)
