  4. Gelöst: system.adapter.javascript.0.lastSync
    2.9k
    3.0k
11 Beiträge 4 Kommentatoren 759 Aufrufe 2 Beobachtet
  • Mike77M Offline
    Mike77M Offline
    Mike77
    schrieb am zuletzt editiert von Mike77
    Ich bekomme den Fehler vermutlich ein paar Tausend mal am Tag.
    javascript.0
    2025-09-28 11:30:16.251	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:16.179	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:16.124	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:16.101	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:16.019	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.922	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.901	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.849	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.794	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.746	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.696	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.618	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.591	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.537	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.441	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
    javascript.0
    2025-09-28 11:30:15.392	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions"
    Ich habe das einmal im Forum gefunden, hat sich bei demjenigen behoben, als er den Adapter auf 8.9.2 gedowngraded hat.
    Ich habe nun schon diverse Versionen bis 8.0 runter ausprobiert, ich bekomme den Datenpunkt leider nicht.
    Gibt es da irgendeinen Trick?
    Mike
    mcm1957M HomoranH paul53P 3 Antworten Letzte Antwort
    • Mike77M Mike77
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      Mike
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @mike77
      Ich gehe mal davon aus, dass du den javascript Adapter schon mal neu gestartet hast.
      Zusätzlich kannst du versuchen deine gaze ioBroker Instanz neu zu starten.
      An sich sollten States beim Starten des Adapters jedenfalls angelegt werden. Da der javascript Adapter wohl kein Exote ist ist es eher unwahrscheinlich (wenn auch nicht ausgeschlossen) dass hier ein Bug vorliegt.
      Sicherheitshalber mach auch mal ein iob fix bzw. schau ob iob diag irgendwelche Probleme meldet.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • Mike77M Mike77
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        Mike
        HomoranH Offline
        HomoranH Offline
        @mike77 sagte in system.adapter.javascript.0.lastSync" has no existing object:
        @mcm1957
        ich habe ihn auch nicht!
        aber auch keine Fehlermeldung
          @mcm1957
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @Mike77
          Bist du sicher dass der State nicht zu einem DEINER Scripts gehört?
          Wenn du den State beschreibst musst du ihn auch selbts anlegen.
          • Mike77M Mike77
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            Mike
            @mike77 sagte: "system.adapter.javascript.0.lastSync" has no existing object
            Bei mir ist er in Ordnung:
              "_id": "system.adapter.javascript.0.lastSync",
              "common": {
                "name": "Last sync time",
                "type": "number",
                "role": "timestamp",
                "write": false,
                "min": 0,
                "read": true
              "type": "state",
              "from": "system.adapter.javascript.0",
              "user": "system.user.admin",
              "ts": 1619529978901,
              "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
            • Mike77M Offline
              Mike77M Offline
              Mike77
              Ich habe das ganze im Docker von Buanet laufen... Auf dem Host wegen Matter.
              Die Diagnose hat keine Fehler geliefert, ist aber wohl nicht ganz durchgelaufen.... Ab der Abfrage zur Vulerability, ging es ewig nicht weiter...
              Iobroker Fix hat keine Fehler gebracht, die es zu korrigieren gab.
              Neustarts hatte ich schon viele seither.... allein beim Wechsel der Versionen, aber auch den ganzen Container... (Fehler ist bei mir schon ein paar Wochen vorhanden)
              Fehler hatte ich hier noch entdeckt.
              @paul53 bei mir ist er nicht defekt, sondern gar nicht vorhanden.
              @mcm1957 nein ich habe kein Script, das auf system.adapter zugreift. Kann ich den überhaupt selber anlegen dort ? dann hätte ich den Fehler auch vielleicht weg.... dachte da geht das nicht.
              • Mike77M Mike77
                @mike77 sagte: bei mir ist er nicht defekt, sondern gar nicht vorhanden.
                Version? Mach mal einen Upload vom Javascript-Adapter.
                iob upload javascript
                Mike77M 1 Antwort Letzte Antwort
                  Mike77M Offline
                  Mike77M Offline
                  Mike77
                  @paul53 sauber durchgelaufen.... aber dennoch fehlt der Datenpunkt weiterhin.
                  Updating objects from io-package.json for adapter "javascript" with version "9.0.11"
                  Mittlerweile wieder auf 9.0.11 nachdem ich andere probiert hatte...
                  Bin gleich im Hotel. Kann erst heute Abend weiterprobieren
                      "common": {
                        "type": "number",
                        "write": false,
                        "min": 0,
                        "read": true
                      "type": "state",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    HomoranH Offline
                    HomoranH Offline
                    @paul53 sagte in system.adapter.javascript.0.lastSync" has no existing object:
                    wie bereits gesagt ist er auch bei mir
                    es gibt überhaupt keinen DP mit lastSync im Expertenmodus zu sehen. bei lastS ist noch Tradfri mit lastSeen, und dann ist Schluss
                    • Mike77M Mike77
                      @mike77 sagte: dennoch fehlt der Datenpunkt weiterhin.
                      Hast du in der Konfiguration einen Mirror-Pfad angegeben?
                      Ich vermute, dass der DP dann erstellt wird.
                        Mike77M Offline
                        Mike77M Offline
                        Mike77
                        @paul53 Danke Paul. Ich hatte zwar einen Pfad eingetragen, aber mit einem Schreibfehler, der jahrelang nicht aufgefallen ist, weil ich das Backup auch nie benötigt hatte....
                        Das Verzeichnis wurde dann wohl nicht erstellt, sondern hat den Fehler verursacht.
                        Nun habe ich den Datenpunkt und auch einen entsprechenden Eintrag.
                        Liebe Grüße aus Südtirol
                        Mike
