  4. docker container startet nicht unter proxmox 9
    6.5k
12 Beiträge 4 Kommentatoren 977 Aufrufe 4 Beobachtet
  • A astrakid
    hier das komplette startlog:
    iobroker  | --------------------------------------------------------------------------------
    iobroker  | -------------------------     2025-09-24 16:42:38      -------------------------
    iobroker  | -----        -----
    iobroker  | ----- ██╗  ██████╗  ██████╗  ██████╗   ██████╗  ██╗  ██╗ ███████╗ ██████╗  -----
    iobroker  | ----- ██║ ██╔═══██╗ ██╔══██╗ ██╔══██╗ ██╔═══██╗ ██║ ██╔╝ ██╔════╝ ██╔══██╗ -----
    iobroker  | ----- ██║ ██║   ██║ ██████╔╝ ██████╔╝ ██║   ██║ █████╔╝  █████╗   ██████╔╝ -----
    iobroker  | ----- ██║ ██║   ██║ ██╔══██╗ ██╔══██╗ ██║   ██║ ██╔═██╗  ██╔══╝   ██╔══██╗ -----
    iobroker  | ----- ██║ ╚██████╔╝ ██████╔╝ ██║  ██║ ╚██████╔╝ ██║  ██╗ ███████╗ ██║  ██║ -----
    iobroker  | ----- ╚═╝  ╚═════╝  ╚═════╝  ╚═╝  ╚═╝  ╚═════╝  ╚═╝  ╚═╝ ╚══════╝ ╚═╝  ╚═╝ -----
    iobroker  | -----              Welcome to your ioBroker Docker container!              -----
    iobroker  | -----                    Startupscript is now running!                     -----
    iobroker  | -----                          Please be patient!                          -----
    iobroker  |
    iobroker  | -----                          System Information                          -----
    iobroker  | -----                    arch:                x86_64                       -----
    iobroker  | -----                    hostname:            iobroker                     -----
    iobroker  | -----                          Version Information                         -----
    iobroker  | -----                    image:               v11.0.0                      -----
    iobroker  | -----                    build:               20250912.234259              -----
    iobroker  | -----                    node:                v22.19.0                     -----
    iobroker  | -----                    npm:                 10.9.3                       -----
    iobroker  | -----                        Environment Variables                         -----
    iobroker  | -----                    DEBUG:               yes                          -----
    iobroker  | -----                    SETGID:              1000                         -----
    iobroker  | -----                    SETUID:              1000                         -----
    iobroker  |
    iobroker  | -----                   Step 1 of 5: Preparing Container                   -----
    iobroker  |
    iobroker  |
    iobroker  |
    iobroker  | -----             Step 2 of 5: Detecting ioBroker Installation             -----
    iobroker  |
    iobroker  | Existing installation of ioBroker detected in "/opt/iobroker".
    iobroker  |
    iobroker  | -----             Step 3 of 5: Checking ioBroker Installation              -----
    iobroker  |
    iobroker  | (Re)setting permissions (This might take a while! Please be patient!)... Done.
    iobroker  |
    iobroker  | Checking database connection... Done.
    iobroker  |
    iobroker  | Hostname in ioBroker matches the hostname of this container.
    iobroker  | No action required.
    iobroker  |
    iobroker  | -----                Step 4 of 5: Applying Special Settings                -----
    iobroker  |
    iobroker  | Some adapters have special requirements/ settings which can be activated by the use of environment variables.
    iobroker  | For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs/).
    iobroker  |
    iobroker  | -----                    Step 5 of 5: ioBroker Startup                     -----
    iobroker  |
    iobroker  | Starting ioBroker...
    iobroker  |
    iobroker  | ##### #### ### ## # iobroker.js-controller log output # ## ### #### #####
    iobroker  | Error while calling "getconf CLK_TCK" Error: spawn /bin/sh EACCES
    iobroker  |     at ChildProcess._handle.onexit (node:internal/child_process:285:19)
    iobroker  |     at onErrorNT (node:internal/child_process:483:16)
    iobroker  |     at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
    iobroker  |   errno: -13,
    iobroker  |   code: 'EACCES',
    iobroker  |   syscall: 'spawn /bin/sh',
    iobroker  |   path: '/bin/sh',
    iobroker  |   spawnargs: [ '-c', 'getconf CLK_TCK' ],
    iobroker  |   cmd: 'getconf CLK_TCK'
    iobroker  | }
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    @astrakid sagte in docker container startet nicht unter proxmox 9:
    das liegt höchst wahrscheinlich daran, das du dadurch eine verschachtelte virtualisierung erzeugst. also die virtualisierung in einer virtualisierung hat weniger rechte.
    schau mal ob du da was dazu in proxmox konfigurieren kannst.
    Meine Adapter und Widgets
    Links im Profil
    A MartinPM 2 Antworten Letzte Antwort
    • OliverIOO OliverIO
      astrakid
      @oliverio sagte in docker container startet nicht unter proxmox 9:
      innerhalb des OS habe ich docker direkt installiert und gestartet, nicht in einem LXC oder einer VM. und als benutzer root (ich weiß, nicht optimal).
        MartinPM Online
        MartinPM Online
        MartinP
        Da fehlt mir die Beschreibung des "Zwischenbaus"
        Auf einem Proxmox System sollte man nur LXC-Container und virtuelle Maschinen installieren...
        docker-ce direkt auf dem PVE Muttersystem installieren schafft Verdruss...
        Wenn Du eine VM aufgesetzt hast oder einen LXC Container, in dem dann wiederum docker läuft:
        Was ist denn die Ausgabe, wenn Du als normaler User in der VM / dem LXC dies hier eintippst:
        marrtin@iobroker-test-sicher:/opt/iobroker$ getconf CLK_TCK
        100
        • MartinPM MartinP
          100
          astrakid
          @martinp sagte in docker container startet nicht unter proxmox 9:
          getconf CLK_TCK
          funktioniert sogar aus dem iobroker-container heraus:
          • A astrakid
            getconf CLK_TCK
            MartinPM Online
            MartinPM Online
            MartinP
            @astrakid Du hast also docker direkt im Hypervisor installiert?
            Etwas direkt im Hypervisor installieren ist schlechter Stil ...
            https://www.reddit.com/r/Proxmox/comments/1cluao4/whats_the_best_way_to_run_docker_in_proxmox/
            EDIT: ich sehe gerade "root"
            Unter welchem User ist denn das Installationsskript gelaufen?
            OliverIOO A 2 Antworten Letzte Antwort
            • MartinPM MartinP
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              im link steht was von, das es die netzwerkfähigkeiten von proxmox zerstört.
              wahrscheinlich wenn man irgendwas mit macvlan oder ipvlan verwenden will, da dann ein eigener treiber genutzt wird.
              ich dachte proxmox sei ein geschlossenes system/betriebssystem. da dann noch was auf oberster ebene zu installieren dürfte doch dann beim nächsten update ebenfalls schwierigkeiten geben.
              Links im Profil
              • A astrakid
                CodierknechtC Offline
                Codierknecht
                Das ist mehr als nur "nicht optimal". Als root zerschießt Du Dir die Rechte.
                Darum fummelt mal niemals als root im System rum.
                Und was Docker auf Proxmox angeht, schließe ich mich den anderen an.
                Proxmox ist eine Virtualisierungslösung - Docker eine andere. Die beiden zu kombinieren ist vermutlich auch mehr als nur "schlechter Stil".
                Bei mir läuft ioBroker als LXC. Mit 2 Kernen und 8 GB RAM. Einwandfrei.
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                OliverIOO MartinPM 2 Antworten Letzte Antwort
                • CodierknechtC Codierknecht
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @codierknecht
                  Es funktioniert, von proxmox wird für Docker allerdings eine vm empfohlen, ein lxc Container soll aber auch funktionieren.
                  Alle virtualisierten Prozesse laufen im Endeffekt parallel auf dem Prozessor, egal wie tief verschachtelt wurde.
                  Links im Profil
                  • MartinPM MartinP
                    astrakid
                    schrieb am zuletzt editiert von astrakid
                    ich hab iobroker über ein docker compose File gebaut, alles als root. Der Rest läuft im docker Container ab.
                    Proxmox ist kein hypervisor, proxmox ist eigentlich nur eine Verwaltungsschicht, das OS ist Debian. Proxmox verwaltet lxc Container und kvm. Alles in einer schicken Oberfläche. Dass docker die Netzwerkkonfiguration von proxmox beeinflusst halte ich für ein Gerücht
                    Ich habe selbst proxmox 8 mit docker im Hostsystem laufen, u.a. auch iobroker. Reibungslos, inkl. Durchreichen eines zigbee USB Sticks.
                    Ich halte die containerisierung innerhalb eines Containers für widersinnig. Der Vorteil ist klar, dass man dann alles innerhalb der proxomox Verwaltung liegen hat.
                    Mir geht es jetzt nur darum, den Fehler zu beheben.
                    Unter root zu arbeiten ist unvernünftig, das weiss ich. Das ist aber ein Sicherheitsthema.
                      MartinPM Online
                      MartinPM Online
                      MartinP
                      @codierknecht sagte in docker container startet nicht unter proxmox 9:
                      Einige Sachen werden vom Maintainer primär als Docker Container gepflegt.
                      Da ich den Pflegeaufwand für geringer erachte, wenn man sich dem Mainstream anschließt, habe ich einige Werkzeuge als Docker-Container installiert...
                      Eine Docker Instanz auf einem unprivilegierten LXC Container, für Docker Images, die auf keine speziellen Hardwares zugreifen müssen.
                      Darauf dann in Docker Containern
                      • portainer,
                      • PiHole,
                      • Radicale,
                      • gitea
                      Eine weitere Docker Instanz auf einem privilegierten LXC.
                      Darauf
                      • portainer
                      • frigate (wg google coral usb stick im privilegierten container)
                      • zigbee2mqtt (wg conbee3 stick)
                      Funktioniert eigentlich ganz gut ... Nur der google coral stick wandert manchmal von device id zu device id.
                      Habe da noch keine udev Regel gefunden, deren Verlinkung frigate auch als Zugangspunkt akzeptiert...
