  3. Einsteigerfragen
  4. Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.
    5.3k
54 Beiträge 7 Kommentatoren 4.4k Aufrufe 5 Beobachtet
    @duffy dann steht bestimmt was passendes im log
    DuffyD Offline
    DuffyD Offline
    Duffy
    schrieb am zuletzt editiert von Duffy
    zigbee.0
    	2025-09-09 19:03:35.040	warn	Zigbee autostart option not set - omitting start of zigbee substystem!
    zigbee.0
    	2025-09-09 19:03:35.040	info	--- creating device debug ---
    zigbee.0
    	2025-09-09 19:03:35.036	info	delete old Backup files. keep only last 10
    zigbee.0
    	2025-09-09 19:03:34.958	info	init localConfig
    zigbee.0
    	2025-09-09 19:03:34.956	info	Adapter ready - starting subsystems. Adapter is running in info mode.
    zigbee.0
    	2025-09-09 19:03:34.914	info	starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7
    zigbee.0
    	2025-09-09 19:02:58.916	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    	2025-09-09 19:02:58.913	info	terminating
    zigbee.0
    	2025-09-09 19:02:58.912	info	cleanup successful
    zigbee.0
    	2025-09-09 19:02:58.911	info	zigbecontroller stopped successfully
    zigbee.0
    	2025-09-09 19:02:58.900	info	Saved local configuration data
    zigbee.0
    	2025-09-09 19:02:58.896	info	cleaning everything up...
    zigbee.0
    	2025-09-09 19:02:58.895	info	Halting zigbee adapter. Restart delay is at least 30 seconds.
    zigbee.0
    	2025-09-09 19:02:58.891	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    	2025-09-09 19:01:09.431	error	Error herdsman start
    zigbee.0
    	2025-09-09 19:01:09.431	error	Starting zigbee-herdsman problem : Error Resource temporarily unavailable Cannot lock port
    zigbee.0
    	2025-09-09 19:01:09.425	info	Unable to obtain herdsman settings
    zigbee.0
    	2025-09-09 19:01:09.240	info	Starting Zigbee-Herdsman
    zigbee.0
    	2025-09-09 19:01:09.239	info	configured transmit power : normal
    zigbee.0
    	2025-09-09 19:01:09.238	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
    zigbee.0
    	2025-09-09 19:01:09.225	info	Starting Adapter npm ...
    zigbee.0
    	2025-09-09 19:01:02.442	error	Error herdsman start
    zigbee.0
    	2025-09-09 19:01:02.441	error	Starting zigbee-herdsman problem : Error Resource temporarily unavailable Cannot lock port
    zigbee.0
    	2025-09-09 19:01:02.436	info	Unable to obtain herdsman settings
    zigbee.0
    	2025-09-09 19:01:02.246	info	Starting Zigbee-Herdsman
    zigbee.0
    	2025-09-09 19:01:02.245	info	configured transmit power : normal
    zigbee.0
    	2025-09-09 19:01:02.244	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
    zigbee.0
    	2025-09-09 19:01:02.228	info	Starting Adapter npm ...
    zigbee.0
    	2025-09-09 18:54:30.660	error	Error herdsman start
    zigbee.0
    	2025-09-09 18:54:30.660	error	Starting zigbee-herdsman problem : startup failed - configuration-adapter mismatch - see logs above for more information
    zigbee.0
    	2025-09-09 18:54:30.651	warn	Network parameters on Coordinator: panID=9041 channel=11 extendedPanID=21272f2a004b1200
    zigbee.0
    	2025-09-09 18:54:30.650	warn	Network parameters in Config : panID=8702 channel=11 extendedPanID=
    zigbee.0
    	2025-09-09 18:54:30.273	info	Starting Zigbee-Herdsman
    zigbee.0
    	2025-09-09 18:54:30.272	info	configured transmit power : normal
    zigbee.0
    	2025-09-09 18:54:30.269	info	Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
    zigbee.0
    	2025-09-09 18:54:30.260	info	Starting Adapter npm ...
    zigbee.0
    	2025-09-09 18:54:25.692	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"}]
    zigbee.0
    	2025-09-09 18:53:04.681	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"}]
    Das hier. Kam gerade noch ein Updaze rein
    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
    Node.js: v22.23.1
    NPM: 10.9.4
    js-controller 7.1.2
    Linux: Trixie
    • DuffyD Duffy
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @duffy sagte in Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.:
      Dumme frage ? Hast du den Haken bei 'zigbee automatisch starten wieder (oder immer noch) gesetzt ?
      Wenn Nein, warum nutzt du dann nicht die 'start' und 'stop' Funktion innerhalb der Zigbee Konfiguration ? (der nette play/stop) button ?
      Da kannst du versuchen zu starten, dann versuchen anzuhalten, und hast direkt auch das Log dazu. Und das noch so das man es hier besser lesen kann (siehe Screenshot)
      Wenn ja - raus damit, und alles in der Oberfläche des Admin machen - da geht deutlich mehr als mit 'start adapter / stop adapter'
      A.
      Nachtrag 2: wir können da gemeinsam auf Discord drauf schauen, wenn du mic und ton hast. Ich sitz da im 2 user only
      DuffyD 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        A.
        DuffyD Offline
        DuffyD Offline
        Duffy
        @asgothian
        Autostart ist noch nicht aktiviert.
        Du meinst diesen
        nicht diesen
        beim druck auf diesen
        kommt das
        overriding zigbee options with:
        extPanID : 602b3cc4c9e55067
        panID : 8702
        channel : 11
        port : /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
        adapterType : zstack
        baudRate : 115200
        precfgkey : 01030507090B0D0F000xxxxxxx
        flowCTRL : false
        Starting zigbee-herdsman...
        Network parameters in Config     : panID=8702 channel=11 extendedPanID=602b3cc4c9exxxxxxxxxxx
        Network parameters on Coordinator: panID=9041 channel=11 extendedPanID=21272f2xxxxxxxxxxx
        Muss nur kurz zum Essen sonst kann ich mir heute Nacht einen Schlafplatz unter der Brücke suchen. Melde mich gleich noch mal.
        Node.js: v22.23.1
        NPM: 10.9.4
        js-controller 7.1.2
        Linux: Trixie
        • DuffyD Duffy
          @asgothian
          Du meinst diesen
          nicht diesen
          kommt das
          panID : 8702
          channel : 11
          baudRate : 115200
          flowCTRL : false
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          Und da steht was nicht passt. Also nvram read, damit es passt, und dann nochmal versuchen zu starten (mit dem start-stop button). Die Zigbee Einstellungen nie verlassen.
          A.
            A.
            DuffyD Offline
            DuffyD Offline
            Duffy
            @asgothian
            NVram gedrückt
            dann
            gedrückt
            extPanID : 21272f2a004b1200
            panID : 9041
            channel : 11
            baudRate : 115200
            precfgkey : 01030507090b0d0f00020406080a0c0d
            flowCTRL : false
            aus zweiter iob Session den Log ausgelesen, sollte die Einstellungen ja nicht verlassen:
            02
            Log-Größe: 41.7 KB
            Zeit
            zigbee.0
            	2025-09-09 19:11:41.523	info	Device '0xbc026efffe00466f' announced itself
            zigbee.0
            	2025-09-09 19:08:24.187	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Silicon Labs","serialNumber":"0001","pnpId":"usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0","vendorId":"10c4","productId":"ea60"}]
            Aber leider bleibt der Adapter gelb:
            Node.js: v22.23.1
            NPM: 10.9.4
            js-controller 7.1.2
            Linux: Trixie
            • DuffyD Duffy
              @asgothian
              NVram gedrückt
              dann
              gedrückt
              panID : 9041
              channel : 11
              baudRate : 115200
              flowCTRL : false
              02
              Log-Größe: 41.7 KB
              Zeit
              zigbee.0
              zigbee.0
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @asgothian
              Klar - steht da ja auch.
              Cannot lock port bedeutet dass der Prozess der die serielle Schnittstelle belegt nicht sauber beendet wurde. Die Lösung dazu ist:
              • stick abziehen
              • 20 s warten
              • stick einstecken
              • nochmal start drücken
              Das OS gibt den Port nicht frei.
              Wenn ich das irgendwann mal stabil im debugger habe wird der Adapter das auch erkennen und beheben.
              A.
                @asgothian
                • stick abziehen
                • 20 s warten
                • stick einstecken
                A.
                DuffyD Offline
                DuffyD Offline
                Duffy
                @asgothian
                Es läuft endlich vielen Dank für deinen Support.
                Ich hatte den Testpi einfach neu gestartet wodurch vermutlich der Port wieder freigegeben wurde.
                Jetzt habe ich auch den "start the Zigbee network" hacken gesetzt.
                Ein Fenstersensor ist Testhalber auch gekoppelt. (funktioniert)
                Vielleicht noch zur Erklärung für mich. Was macht des NVRam lesen bzw löschen?
                Greift das direkt auf den USB Stick zu was beim löschen auch zur folge hätte das alle angelernten Geräte gelöscht wrerden?
                Das war jetzt eine schwere Geburt; jetzt schnell aus machen bevor wieder was in die Hosen geht.
                Danke noch mal und VG
                Duffy
                Node.js: v22.23.1
                NPM: 10.9.4
                js-controller 7.1.2
                Linux: Trixie
                • DuffyD Duffy
                  @asgothian
                  Duffy
                  HomoranH Offline
                  HomoranH Offline
                  ja
                    ja
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @homoran sagte in Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.:
                    ja
                    Jein. - ja, man muss zumeist neu anlernen, nein, es greift nicht auf den USB Stick zu - geht also auch wenn man da keinen Zugriff drauf hat.
                    Die Bezeichnung ist etwas verwirrend - eigentlich ist es 'nvram backup lesen' und 'nvram backup löschen'
                    Es geht dabei um eine Datei nvbackup.json, die je nach Koordinator existiert oder nicht.
                    Beim Lesen werden die Werte aus der nvbackup in die Konfiguration übertragen. Dann kann testweise gestartet werden, ohne die Parameter zu speichern. Wenn es geht, gut.
                    Beim nvbackup löschen wird diese Datei gelöscht. Damit wird dann das Zigbee-Netzwerk als neues Netzwerk aufgesetzt - ggf. auch mit anderen Parametern als zuvor.
                    Diese Meldungen vergleichen das was der Adapter versucht zu setzen und was entweder auf dem Koordinator oder in der nvbackup.json gespeichert ist. Das macht der Zigbee-Herdsman, nicht der Adapter.
                    in config is tads was du eingestellt hast, on coordinator ist das was via nvram oder nvbackup existiert.
                    Solange das nicht überein stimmt verweigert der Adapter den Start. Das kann man durch den Haken 'mit inkonsistenter Konfiguration starten' umgehen - soll man aber nicht.
                    An dieser Stelle wird es jetzt etwas kompliziert.
                    Je nach Parameter, Koordinator, Geräten bedeutet ein löschen des nvbackup das auch die Geräte auf dem Koordinator gelöscht werden. Aber halt nicht immer. Insbesondere haben einige Netzwerk-Koordinatoren echtes nvRam - das wird nicht gelöscht. Die meisten USB Sticks haben kein nvram - deswegen das Backup. Bedeutet auch das man (sofern man den gleichen typ nutzt, und den richtig konfiguriert hat) den Stick einfach gegen einen anderen ersetzen kann. Das mach ich hier immer mal wieder mit 1 von 4 TI-Based Koordinatoren :)
                    Neu anlernen muss man zumeist trotzdem, weil sich die Netzwerk Verschlüsselung ändert (durch andere PanID / ExtPanID)
                    A.
                    HomoranH DuffyD 2 Antworten Letzte Antwort
                      ja
                      A.
                      HomoranH Offline
                      HomoranH Offline
                      @asgothian Danke für diese erweiterte Schulung!
                      ich hielt die nvbackup immer für eine Sicherungskopie des nvram.
                      und nvram Auslesen dementsprechend für das Auslesen des echten nvRam
                        ja
                        A.
                        DuffyD Offline
                        DuffyD Offline
                        Duffy
                        @asgothian
                        Vielen Dank für deine ausführliche Erörterung.
                        Bisher konnte ich ja den Zigbee Adapter stoppen, den USB Koordinator abstecken und durch einen anderen frisch aufgesetzen Koordinator (Neue Firmware) wieder anstecken, den Adapter neu starten und es wurden alle Einstellungen wieder übernommen so das man nahtlos weitermachen konnt.
                        Ist das jetzt auch noch möglich weil du schreibst es müssten möglicherweise die Geräte neu angelernt werden?
                        VG Duffy
                        Node.js: v22.23.1
                        NPM: 10.9.4
                        js-controller 7.1.2
                        Linux: Trixie
                        • DuffyD Duffy
                          @asgothian
                          VG Duffy
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @asgothian
                          VG Duffy
                          Neue Firmware, gleicher Chipsatz => geht gleich weiter.
                          Neue Firmware, neuer Chipsatz => kann gehen, muss nicht
                          A.
                            @asgothian
                            VG Duffy
                            A.
                            DuffyD Offline
                            DuffyD Offline
                            Duffy
                            @asgothian
                            Vielen Dank
                            Node.js: v22.23.1
                            NPM: 10.9.4
                            js-controller 7.1.2
                            Linux: Trixie
                            • Sleepless135S Offline
                              Sleepless135
                              Moin,
                              ich hoffe ich bin hier richtig, hatte danach gesucht aber nichts wirklich gefunden.
                              Habe auf zwei Instanzen Zigbee Adapter 2.0.5 nach dem Upgrade auf 3.0.5 sind alle Geräte verschwunden.
                              Muss ich bei dem Upgrade alle Geräte neu Anlernen ? Habe gut 30 Stück in der Wohnung verteilt. Würde mir die Arbeit gerne Sparen.
                              Mit besten Grüßen aus dem halb Smart Home
                              Tim
                              FabioF 1 Antwort Letzte Antwort
                              • Sleepless135S Sleepless135
                                Moin,
                                Tim
                                FabioF Offline
                                FabioF Offline
                                Fabio
                                @sleepless135 sind die Adapter grün.Was sagt das Log.
                                Iobroker:
                                • Matter over Thread Hilfe
                                  Sleepless135
                                  Moin,
                                  nach dem Update startet der Adapter durch und läuft, es ist nur kein Gerät mehr aufgelistet.
                                  Gut das ich davor ein Snapshot gemacht hatte ;)
                                    Moin,
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @sleepless135 sagte in Zigbee 3.0.5 Installation missglückt, downgrade n. möglich.:
                                    Moin,
                                    Bist du sicher das der Adapter durchstartet ?
                                    Hast du den Haken bei start the Zigbee network automatically gesetzt ?
                                    Und wie schon @Fabio schrieb:
                                    Das Log vom start des Adapters hilft ungemein. Warum postest Du es nicht ?
                                    A.
                                    Sleepless135S 1 Antwort Letzte Antwort
                                      Moin,
                                      A.
                                      Sleepless135
                                      @asgothian
                                      ok ich bin ein Idiot -.- nächste Runde geht auf mich -.-
                                      Dachte mit Automatisch starten, das sich der Adapter nicht startet. Hacken rein alles wieder da.
                                      Nächste Runde geht auf mich, entschuldig für mein nicht Nachdenken.
