  4. eCharts - Nach update auf 2.0.7 startet Instanz nicht mehr
    6.1k
28 Beiträge 10 Kommentatoren 3.0k Aufrufe 9 Beobachtet
  • C Offline
    CommanderXXL
    Hier mal mein "iob diag" output:
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: IObrokerPi5
           Icon name: computer
              Kernel: Linux 6.12.34+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     11:55:24 up  3:44,  2 users,  load average: 0.36, 0.69, 0.48
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2025-08-22 11:55:24 CEST
               Universal time: Fri 2025-08-22 09:55:24 UTC
                     RTC time: Fri 2025-08-22 09:55:24
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    admin
    HOME=/home/admin
    GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.5G        2.3G        4.9G        5.5M        1.3G        6.1G
    Swap:           209M          0B        209M
    Total:          8.7G        2.3G        5.1G
    Active iob-Instances:   24
             8063 M total memory
             2218 M used memory
             2010 M active memory
              834 M inactive memory
             4675 M free memory
              261 M buffer memory
             1001 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 11:55:24 up  3:44,  2 users,  load average: 0.36, 0.69, 0.48
    Tasks: 213 total,   1 running, 212 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.2 total,   4674.1 free,   2219.9 used,   1262.3 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5843.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    151 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     1.6G  5.3M  1.6G   1% /run
    /dev/mmcblk0p2 ext4       59G   17G   39G  31% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
    [Fri Aug 22 08:10:26 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:33:7E:48 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1773a755-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Fri Aug 22 08:10:29 2025] EXT4-fs (mmcblk0p2): mounted filesystem 7909438b-2884-423e-aa05-577fdea75c97 ro with ordered data mode. Quota mode: none.
    [Fri Aug 22 08:10:30 2025] EXT4-fs (mmcblk0p2): re-mounted 7909438b-2884-423e-aa05-577fdea75c97 r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.2G    /var/
    613M    /var/log
    612M    /var/log/journal/e004c5c494f24635be857afd2b9c7aee
    221M    /var/cache
    Archived and active journals take up 611.9M in the file system.
    /opt/iobroker/backups:
    76M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    803M    /opt/iobroker/iobroker-data/
    456M    /opt/iobroker/iobroker-data/history
    252M    /opt/iobroker/iobroker-data/files
    79M     /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/vis-2
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    15M     /opt/iobroker/iobroker-data/objects.jsonl
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CjzUbllv.js
    8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.18.0
    /usr/bin/node           v22.18.0
    /usr/bin/npm            11.5.2
    /usr/bin/npx            11.5.2
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 22.18.0-1nodesource1
      Candidate: 22.18.0-1nodesource1
      Version table:
     *** 22.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IObrokerPi5         IObrokerPi5 (version: 7.0.7, hostname: IObrokerPi5   , alive, uptime: 376)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     9.0.11
    nodejs modules from github:     1
    +-- iobroker.deconz@2.0.7 (git+ssh://git@github.com/Jey-Cee/ioBroker.deconz.git#8af7464adc2de2241a4d0136e2189a9825d38105)
    Adapter State
    + system.adapter.admin.0                  : admin                 : IObrokerPi5                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : IObrokerPi5                              -  enabled
    + system.adapter.backitup.0               : backitup              : IObrokerPi5                              -  enabled
    + system.adapter.cloud.0                  : cloud                 : IObrokerPi5                              -  enabled
    + system.adapter.deconz.0                 : deconz                : IObrokerPi5                              -  enabled, port: 80
      system.adapter.devices.0                : devices               : IObrokerPi5                              - disabled
    + system.adapter.discovery.0              : discovery             : IObrokerPi5                              -  enabled
      system.adapter.echarts.0                : echarts               : IObrokerPi5                              - disabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IObrokerPi5                              - disabled
    + system.adapter.email.0                  : email                 : IObrokerPi5                              -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : IObrokerPi5                              -  enabled
      system.adapter.eusec.0                  : eusec                 : IObrokerPi5                              - disabled
      system.adapter.feiertage.0              : feiertage             : IObrokerPi5                              -  enabled
    + system.adapter.history.0                : history               : IObrokerPi5                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : IObrokerPi5                              -  enabled
      system.adapter.ical.0                   : ical                  : IObrokerPi5                              -  enabled
    + system.adapter.iot.0                    : iot                   : IObrokerPi5                              -  enabled
    + system.adapter.javascript.0             : javascript            : IObrokerPi5                              -  enabled
    + system.adapter.matter.0                 : matter                : IObrokerPi5                              -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : IObrokerPi5                              -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : IObrokerPi5                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.pvforecast.0             : pvforecast            : IObrokerPi5                              -  enabled
    + system.adapter.shelly.0                 : shelly                : IObrokerPi5                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartmeter.0             : smartmeter            : IObrokerPi5                              -  enabled
    + system.adapter.telegram.0               : telegram              : IObrokerPi5                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : IObrokerPi5                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : IObrokerPi5                              -  enabled
      system.adapter.twinkly.0                : twinkly               : IObrokerPi5                              - disabled
    + system.adapter.vis-2.0                  : vis-2                 : IObrokerPi5                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : IObrokerPi5                              -  enabled
    + system.adapter.web.0                    : web                   : IObrokerPi5                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "deconz"       : 1.6.4    , installed 2.0.7
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "echarts"      : 2.0.8    , installed 2.0.8
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "eusec"        : 1.3.3    , installed 1.3.3
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "iot"          : 3.6.0    , installed 3.6.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "matter"       : 0.5.2    , installed 0.5.2
    Adapter    "mielecloudservice": 6.5.11, installed 6.5.11
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
    Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.9    , installed 7.0.9
    Adapter    "ws"           : 3.0.19   , installed 3.0.19
    Objects and States
    Objects:        7118
    States:         5656
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       94899      5398/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       94905      5398/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6392       795/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       98428      5744/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       100534     6160/io.shelly.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       98429      5744/io.mqtt.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96036      5416/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       102630     7035/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6394       795/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105124     7067/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105114     7067/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105109     7067/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6127       664/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       102576     6970/io.deconz.0
    udp        0      0 0.0.0.0:44612           0.0.0.0:*                           1001       105120     7067/io.matter.0
    udp        0      0 0.0.0.0:49878           0.0.0.0:*                           104        6129       664/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                1001       105125     7067/io.matter.0
    udp6       0      0 :::5353                 :::*                                1001       105115     7067/io.matter.0
    udp6       0      0 :::5353                 :::*                                1001       105110     7067/io.matter.0
    udp6       0      0 :::5353                 :::*                                104        6128       664/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       102579     6970/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       102578     6970/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       102577     6970/io.deconz.0
    udp6       0      0 :::56347                :::*                                104        6130       664/avahi-daemon: r
    udp6       0      0 :::44612                :::*                                1001       105119     7067/io.matter.0
    udp6       0      0 fe80::e5be:3ac1:ac2:546 :::*                                0          6476       755/NetworkManager
    2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.erdgeschoss.command.rollosrauf"
    2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.hobbyraum.dimmer.licht"
    2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.schrank.switch.licht"
    2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.bastelzimmer.switch.licht"
    2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.gästebad.dimmer.licht"
    2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.gästebad.dimmer.spiegellicht"
    2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]: node:internal/modules/cjs/loader:1846
    2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
    2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]:                  ^
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object..node (node:internal/modules/cjs/loader:1846:18)
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1423:32)
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1246:12)
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1445:12)
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at require (node:internal/modules/helpers:135:16)
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1688:14)
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object..js (node:internal/modules/cjs/loader:1820:10) {
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: }
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: Node.js v22.18.0
    2025-08-22 11:54:20.396  - error: host.IObrokerPi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-08-22 11:54:20.396  - info: host.IObrokerPi5 Do not restart adapter system.adapter.echarts.0 because disabled or deleted
    Eduard77E 1 Antwort Letzte Antwort
    • Eduard77E Eduard77
      @amgxda
      Dann gib uns die Ausgabe von
      iob diag
      Edit: hast du die Code oben ausprobiert?
      amgxda
      @eduard77
      Die Befehle von dir habe ich eingegeben, es hat sich aber nichts geändert. iob diag erspar ich uns jetzt mal (CommanderXXL hat seins schon gepostet), da ist nichts spannendes drin (Raspberry Pi OS Debian Bookworm, alles up-to-date, iobroker latest up-to-date, keine anderen Fehler im Protokoll), nur der e-Charts-Adapter wirft seit dem Upgrade auf Node 22 und Update von 2.0.6 auf 2.0.7/2.0.8 Fehler. Ein Downgrade auf 2.0.6 behebt den Fehler nicht mehr. CoPilot hat diverse Vorschläge zur Korrektur geliefert, die aber letztendlich nichts gebracht haben (Neubauen der libcairo2, canvas).
      Ich musste den Adapter deaktivieren und belasse es erst mal dabei, weil die Charts trotzdem angezeigt werden. Wahrscheinlich läuft es ohnehin darauf hinaus, dass mit Debian 13 das System neu aufgesetzt wird.
      2025-08-22 11:20:04.481 - info: host.pi5 instance system.adapter.echarts.0 in version "2.0.8" started with pid 336084
      2025-08-22 11:20:05.007 - error: host.pi5 Caught by controller[0]: node:internal/modules/cjs/loader:1846
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: ^
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Object..node (node:internal/modules/cjs/loader:1846:18)
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1423:32)
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1246:12)
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1445:12)
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at require (node:internal/modules/helpers:135:16)
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1688:14)
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1820:10) {
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: }
      2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: Node.js v22.18.0
      2025-08-22 11:20:05.008 - error: host.pi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      • C CommanderXXL
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        admin
        HOME=/home/admin
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 8063 M total memory
                 2218 M used memory
                 4675 M free memory
                  261 M buffer memory
                 1001 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        1.2G    /var/
        613M    /var/log
        221M    /var/cache
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            11.5.2
        /usr/bin/npx            11.5.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.2
        javascript:     9.0.11
        Adapter State
        + instance is alive
        Objects and States
        Objects:        7118
        States:         5656
        Pending Updates: 0
        Eduard77E Offline
        Eduard77E Offline
        Eduard77
        @commanderxxl
        na da hast du ein paar Baustellen, aber dazu kann @Thomas-Braun mehr sagen.
        ein paar davon:
        1.
        1. Wieso hast du bei NPM Version 11?
        /usr/bin/npm            11.5.2
        /usr/bin/npx            11.5.2
        C 1 Antwort Letzte Antwort
          @commanderxxl
          ein paar davon:
          1.
          /usr/bin/npm            11.5.2
          /usr/bin/npx            11.5.2
          CommanderXXL
          schrieb am zuletzt editiert von CommanderXXL
          @eduard77 sagte in eCharts - Nach update auf 2.0.7 startet Instanz nicht mehr:
          @commanderxxl
          ein paar davon:
          1.
          Ja, das fand ich auch komisch. Das sind alles "Undervoltage detected!"
          [Fr Aug 22 11:59:23 2025] hwmon hwmon2: Undervoltage detected!
          [Fr Aug 22 12:01:20 2025] hwmon hwmon2: Undervoltage detected!
          [Fr Aug 22 12:04:02 2025] hwmon hwmon2: Undervoltage detected!
          [Fr Aug 22 12:08:48 2025] hwmon hwmon2: Undervoltage detected!
          [Fr Aug 22 12:10:23 2025] hwmon hwmon2: Undervoltage detected!
          [Fr Aug 22 12:12:20 2025] hwmon hwmon2: Undervoltage detected!
          [Fr Aug 22 12:17:23 2025] hwmon hwmon2: Undervoltage detected!
          [Fr Aug 22 12:25:21 2025] hwmon hwmon2: Undervoltage detected!
          [Fr Aug 22 12:26:20 2025] hwmon hwmon2: Undervoltage detected!
          [Fr Aug 22 12:26:26 2025] hwmon hwmon2: Undervoltage detected!
          Kann ich mir nicht erklären, da hängt ein 30W USB-C Netzteil dran das noch nie Probleme gemacht hat.
          Ich hab jetzt ein original RasPi5 Netzteil mit 27Watt bestellt. Hänge ich morgen dran. Ich denke aber nicht dass das Problem mit eCharts daher kommt.
          /usr/bin/npm            11.5.2
          /usr/bin/npx            11.5.2
          Weil ich das NPM Update ausgeführt habe wie es NPM nach dem Node JS Update empfohlen hat.
          • C CommanderXXL
            @commanderxxl
            ein paar davon:
            1.
            /usr/bin/npm            11.5.2
            /usr/bin/npx            11.5.2
            Eduard77E Offline
            Eduard77E Offline
            Eduard77
            @commanderxxl
            ist nicht richtig. Node.js bringt immer passende NPM mit. Bei V22 mus npm v 10.9.3 aktuell sein.
            Du bist auch noch als beta Tester unterwegs und hast admin und javascript als beta Versionen.
              @commanderxxl
              amgxda
              schrieb am zuletzt editiert von amgxda
              @eduard77
              Bei meiner Installation bestehen diese beiden Probleme nicht und trotzdem tritt der Fehler auf. Also vermutlich hat das damit nichts zu tun. Ergänzung: Im Github-Issue haben sich ja noch ein paar mehr gemeldet, scheint schon öfters aufzutreten, ohne das der Nutzer etwas "falsch" gemacht hat.
              • rrov1R Offline
                rrov1R Offline
                rrov1
                @amgxda
                Ich habe das gleiche Problem nach dem Update auf eCharts 2.0.8. Ich betreibe meine ioBroker Instanz auf einem RPI5, Node.js auch nochv20.19.4 und bei mir hat erst mal geholfen in der:
                /boot/firmware/config.txt
                den Wert:
                kernel=kernel8.img
                einzutragen und den RPI neu zu starten.
                Vielleicht hilft es dem ein oder anderen.
                ESP8266E A 2 Antworten Letzte Antwort
                • rrov1R rrov1
                  @amgxda
                  den Wert:
                  kernel=kernel8.img
                  ESP8266E Offline
                  ESP8266E Offline
                  ESP8266
                  @rrov1 sagte in eCharts - Nach update auf 2.0.7 startet Instanz nicht mehr:
                  kernel=kernel8.img
                  Danke, das wars.👍 😊
                  • rrov1R rrov1
                    @amgxda
                    den Wert:
                    kernel=kernel8.img
                    amgxda
                    @rrov1 Damit nutzt der Pi5 dann den Kernel der auch für den Pi4 genutzt wird und ein paar "Optimierungen für den Pi5" (laut Doku) gehen verloren.
                    • A amgxda
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      Hat da eigentlich wer ein Issue beim Adaptzer erstellt?
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      rrov1R 1 Antwort Letzte Antwort
                      • mcm1957M mcm1957
                        rrov1R Offline
                        rrov1R Offline
                        rrov1
                        @mcm1957 Ja, ein paar Einträge weiter oben:
                        https://github.com/ioBroker/ioBroker.echarts/issues/927
                        Ich für mich kann erst mal mit den fehlenden Optimierungen leben, das muss jeder für sich entscheiden. Ich brauchte erst mal eine schnelle Lösung :-)
