  3. Off Topic
  4. Proxmox
  5. Proxmox ioBroker LXC - Login, Nutzer, Rechte Fragen
    2.7k
    4.7k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
userrechteautologin
30 Beiträge 4 Kommentatoren 2.5k Aufrufe 2 Beobachtet
    @rushmed sagte in Proxmox ioBroker LXC - Login, Nutzer, Rechte Fragen:
    Jetzt kann ich iob diag ausführen. Danke!
    Zeig mal den Output.
    Vielleicht sehe ich ja noch was.
    Rushmed
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.8-2-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-9600T CPU @ 2.30GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     20:55:18 up 23 min,  1 user,  load average: 0.13, 0.13, 0.18
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-08-28 20:55:18 CEST
               Universal time: Thu 2025-08-28 18:55:18 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    master
    HOME=/home/master
    GROUPS=master adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/master
    GROUPS=iobroker tty dialout sudo audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             12G        785M         11G        3.0M        768M         11G
    Swap:             0B          0B          0B
    Total:           12G        785M         11G
    Active iob-Instances:   5
            12000 M total memory
              750 M used memory
              861 M active memory
              462 M inactive memory
            10519 M free memory
                0 M buffer memory
              733 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 20:55:18 up 23 min,  1 user,  load average: 0.13, 0.13, 0.18
    Tasks:  37 total,   1 running,  36 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  12000.0 total,  10518.8 free,    750.9 used,    733.1 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.  11249.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    /dev/loop2     ext4      7.8G  4.1G  3.4G  55% /
    none           tmpfs     492K  4.0K  488K   1% /dev
    udev           devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs          tmpfs      32G     0   32G   0% /dev/shm
    tmpfs          tmpfs      13G  132K   13G   1% /run
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs      32G  2.8M   32G   1% /tmp
    tmpfs          tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
    Show mounted filesystems:
    TARGET SOURCE     FSTYPE OPTIONS
    /      /dev/loop2 ext4   rw,relatime
    /var:
    811M    /var/
    625M    /var/cache
    621M    /var/cache/apt
    531M    /var/cache/apt/archives
    156M    /var/lib
    Archived and active journals take up 27.8M in the file system.
    /opt/iobroker/backups:
    8.8M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    241M    /opt/iobroker/iobroker-data/
    206M    /opt/iobroker/iobroker-data/files
    48M     /opt/iobroker/iobroker-data/files/iot.admin
    47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-_Yus88Xv.js
    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
    8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.18.0
    /usr/bin/node           v22.18.0
    /usr/bin/npm            11.5.2
    /usr/bin/npx            11.5.2
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 22.18.0-1nodesource1
      Candidate: 22.18.0-1nodesource1
      Version table:
     *** 22.18.0-1nodesource1 500
         22.17.1-1nodesource1 500
         22.17.0-1nodesource1 500
         22.16.0-1nodesource1 500
         22.15.1-1nodesource1 500
         22.15.0-1nodesource1 500
         22.14.0-1nodesource1 500
         22.13.1-1nodesource1 500
         22.13.0-1nodesource1 500
         22.12.0-1nodesource1 500
         22.11.0-1nodesource1 500
         22.10.0-1nodesource1 500
         22.9.0-1nodesource1 500
         22.8.0-1nodesource1 500
         22.7.0-1nodesource1 500
         22.6.0-1nodesource1 500
         22.5.1-1nodesource1 500
         22.5.0-1nodesource1 500
         22.4.1-1nodesource1 500
         22.4.0-1nodesource1 500
         22.3.0-1nodesource1 500
         22.2.0-1nodesource1 500
         22.1.0-1nodesource1 500
         22.0.0-1nodesource1 500
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 856)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     1
    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : ioBroker                                 - disabled
      system.adapter.artnet.0                 : artnet                : ioBroker                                 - disabled, port: 6454
      system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 - disabled
      system.adapter.awtrix-light.1           : awtrix-light          : ioBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      system.adapter.denon.0                  : denon                 : ioBroker                                 - disabled
      system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 - disabled
      system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 - disabled, port: 8899
      system.adapter.habpanel.0               : habpanel              : ioBroker                                 - disabled
      system.adapter.hass.0                   : hass                  : ioBroker                                 - disabled, port: 8123
      system.adapter.hue.0                    : hue                   : ioBroker                                 - disabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : ioBroker                                 - disabled
      system.adapter.javascript.0             : javascript            : ioBroker                                 - disabled
      system.adapter.kodi.0                   : kodi                  : ioBroker                                 - disabled, port: 9090
      system.adapter.logparser.0              : logparser             : ioBroker                                 - disabled
      system.adapter.matter.0                 : matter                : ioBroker                                 - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
      system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
      system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.philips-tv.0             : philips-tv            : ioBroker                                 - disabled
      system.adapter.ping.0                   : ping                  : ioBroker                                 - disabled
      system.adapter.pixelit.0                : pixelit               : ioBroker                                 - disabled
      system.adapter.pixelit.1                : pixelit               : ioBroker                                 - disabled
      system.adapter.pixelit.2                : pixelit               : ioBroker                                 - disabled
      system.adapter.proxmox.0                : proxmox               : ioBroker                                 - disabled, port: 8006
      system.adapter.reolink.0                : reolink               : ioBroker                                 - disabled
      system.adapter.reolink.1                : reolink               : ioBroker                                 - disabled
      system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
      system.adapter.simple-api.0             : simple-api            : ioBroker                                 - disabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 - disabled
      system.adapter.smartmeter.1             : smartmeter            : ioBroker                                 - disabled
      system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1884, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 - disabled
      system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.1               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 - disabled
      system.adapter.web.0                    : web                   : ioBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.windows-control.0        : windows-control       : ioBroker                                 - disabled
      system.adapter.wiobrowser.0             : wiobrowser            : ioBroker                                 - disabled, port: 5000
      system.adapter.wled.0                   : wled                  : ioBroker                                 - disabled
      system.adapter.zigbee.0                 : zigbee                : ioBroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
    + system.adapter.zigbee.1                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.42:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Upgrade policy: minor
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "artnet"       : 1.2.2    , installed 1.2.2
    Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "matter"       : 0.5.1    , installed 0.5.1
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "shuttercontrol": 2.0.3   , installed 2.0.3
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 2.0.5    , installed 3.0.1
    Objects and States
    Objects:        18888
    States:         17674
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://security.debian.org trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          707396     1/init
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       769395     1387/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       766858     1387/iobroker.js-co
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          710114     296/master
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          710115     296/master
    tcp6       0      0 :::111                  :::*                    LISTEN      0          707398     1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          708782     1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       769501     1412/io.admin.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          709765     109/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          707397     1/init
    udp6       0      0 :::111                  :::*                                0          707399     1/init
    2025-08-28 20:41:19.560  - info: zigbee.1 (1500) Zigbee-Herdsman started successfully with Coordinator firmware version: zStack3x0 : 20240710 (2-1.2.7.1)
    2025-08-28 20:41:19.560  - info: zigbee.1 (1500) Unable to disable LED, unsupported function.
    2025-08-28 20:41:19.585  - info: zigbee.1 (1500) 0x00158d0003a4b407 (addr 22720): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2025-08-28 20:41:19.587  - info: zigbee.1 (1500) 0x00158d00035388c1 (addr 5207): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2025-08-28 20:41:19.588  - info: zigbee.1 (1500) 0x00158d0002e32c4b (addr 8948): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2025-08-28 20:41:19.611  - info: zigbee.1 (1500) 0x00178801094009bc (addr 1293): 9290023349 - Philips Hue white A67 bulb E26 with Bluetooth (1600 Lumen) (Router)
    2025-08-28 20:41:19.612  - info: zigbee.1 (1500) 0x00158d000770df1d (addr 45338): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2025-08-28 20:41:19.675  - info: zigbee.1 (1500) 0xa4c138012453af11 (addr 49346): ZTH05 - Tuya Temperature and humidity sensor (EndDevice)
    2025-08-28 20:41:19.676  - info: zigbee.1 (1500) 0x54ef4410001c5a2f (addr 48527): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
    2025-08-28 20:41:19.677  - info: zigbee.1 (1500) 0x00158d00091b240e (addr 20204): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2025-08-28 20:41:19.677  - info: zigbee.1 (1500) 0x00158d0008d07e8a (addr 16064): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2025-08-28 20:41:19.684  - info: zigbee.1 (1500) 0x2c1165fffebea535 (addr 44336): E1812 - IKEA TRADFRI shortcut button (EndDevice)
    2025-08-28 20:41:19.686  - info: zigbee.1 (1500) 0xa4c138e58658a4ab (addr 8334): TS0601_soil - Tuya Soil sensor (EndDevice)
    2025-08-28 20:41:19.695  - info: zigbee.1 (1500) 0xa4c13806a707c4a5 (addr 8651): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
    2025-08-28 20:41:19.696  - info: zigbee.1 (1500) 0xa4c1388a0265f651 (addr 57431): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
    2025-08-28 20:41:19.698  - info: zigbee.1 (1500) 0xa4c1382c8738170e (addr 57453): TS0601_soil - Tuya Soil sensor (EndDevice)
    2025-08-28 20:41:19.700  - info: zigbee.1 (1500) 0xa4c138c7b3e4ec4d (addr 64790): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
    2025-08-28 20:41:19.701  - info: zigbee.1 (1500) 0xa4c13827928b74ce (addr 59985): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
    2025-08-28 20:41:19.703  - info: zigbee.1 (1500) 0xa4c138676454b1db (addr 11729): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
    2025-08-28 20:41:19.704  - info: zigbee.1 (1500) 0xa4c13875cd90235e (addr 37381): TS0601_soil_3 - Tuya Soil sensor (EndDevice)
    2025-08-28 20:41:19.705  - info: zigbee.1 (1500) 0xa4c1382c0fb9ec89 (addr 31931): NAS-AB06B2 - Neo Outdoor solar alarm (EndDevice)
    2025-08-28 20:41:19.706  - info: zigbee.1 (1500) 0x5cc7c1fffe88261d (addr 60589): E2201 - IKEA RODRET wireless dimmer/power switch (EndDevice)
    2025-08-28 20:41:19.706  - info: zigbee.1 (1500) Currently 20 devices are joined:
    2025-08-28 20:41:19.707  - info: zigbee.1 (1500) Zigbee started
    2025-08-28 20:41:20.109  - info: zigbee.1 (1500) debug devices set to []
    iob diag has finished.
    • R Rushmed
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      master
      HOME=/home/master
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:             0B          0B          0B
      Total:           12G        785M         11G
                750 M used memory
                861 M active memory
              10519 M free memory
                  0 M buffer memory
                733 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      811M    /var/
      625M    /var/cache
      621M    /var/cache/apt
      156M    /var/lib
      USB-Devices by-id:
      HINT:
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            11.5.2
      /usr/bin/npx            11.5.2
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        18888
      States:         17674
      Pending Updates: 0
      Swap: 0B
      Ich würde immer SWAP einrichten. Auch bei 12 GB RAM.
      {1}
      • run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      Steht in der Anleitung
      https://www.iobroker.net/#de/documentation/install/proxmox.md
      drin, wie man das noch beseitigen kann.
      Ansonsten schaut das gut aus.
      R 1 Antwort Letzte Antwort
        Swap: 0B
        {1}
        Rushmed
        Das hat mit:
        sudo systemctl mask run-rpc_pipefs.mount
        sudo systemctl mask var-lib-nfs-rpc_pipefs.mount
        leider nicht geklappt.
        • R Rushmed
          Das hat mit:
          @rushmed
          Auch das wirkt nur bei einem Neustart.
            @rushmed
            Rushmed
            @thomas-braun Check, hat geklappt.
            Vielen Dank!
            • R Rushmed
              ich habe mir einen ioBroker Proxmox LXC per "Helper Script" erstellt.
              Dann einen Nutzer "Master" angelegt.
              Wenn ich nun als Master versuche "iob diag" auszuführen kommt folgendes:
              ioBroker LXC Container
                  🌐   Provided by: community-scripts ORG | GitHub: https://github.com/community-scripts/ProxmoxVE
                  🖥️   OS: Debian GNU/Linux - Version: 12
                  🏠   Hostname: ioBroker
                  💡   IP Address: 192.168.178.10
              master@ioBroker:~$ iob diag
              [sudo] password for master:
              Sorry, user master is not allowed to execute '/usr/bin/curl -sLf https://iobroker.net/diag.sh --output /home/iobroker/.diag.sh' as iobroker on ioBroker.localdomain.
              Warum darf der Nutzer das nicht?
              Wäre es möglich und sinnvoll per SSH den vorhandenen Nutzer "iobroker" zu wählen?
              Kann ich das Autologind der LXC Konsole in der Proxmox WebUI von "root" auf "master" umstellen?
              Die Ergänzung von:
              # systemctl edit container-getty@.service
              mit
              [Service]
              ExecStart=
              ExecStart=-/sbin/agetty --autologin master --noclear --keep-baud tty%I 115200,38400,9600 $TERM
              hat nicht geklappt.
              Rushmed
              schrieb am zuletzt editiert von Rushmed
              Hat noch jemand eine Idee zu:
              Die Ergänzung von:
              mit
              [Service]
              ExecStart=
              hat nicht geklappt.
              Danke vorab!
              • R Rushmed
                @thomas-braun Danke.
                Jetzt ist der User in der Gruppe aber die Meldung bleibt.
                root@ioBroker:~# adduser master iobroker
                warn: The user `master' is already a member of `iobroker'.
                Ich muss auch immer das PW von master eingeben obwohl ich damit angemeldet bin.
                Noch ne Idee?
                SabineT
                Noch ne Idee?
                Wenn sudo verwendet wird, muss man immer sein PW eingeben, ausser, man passt die /etc/sudoers an, wird aber nicht empfohlen.
                • S SabineT
                  Noch ne Idee?
                  Rushmed
                  @sabinet Klar, aber ich habe kein sudo verwendet:
                  https://forum.iobroker.net/post/1291576
                  S WalW 2 Antworten Letzte Antwort
                  • R Rushmed
                    SabineT
                    @rushmed Du nicht, aber iob verwendet sudo für Befehle, die nur als root funktionieren.
                    • S SabineT
                      Genauer:
                      Ein User muss sich gegen sudo authentizifieren, wenn dieser User in die Rolle eines anderen users schlüpft. Das ist meist die root-Rolle, ein paar der iobroker-Skripte wechseln aber auch zum user 'iobroker'.
                      Und damit man das bei mehreren aufeinander folgenden ähnlichen Bedingungen nicht jedes Mal eingeben muss gibt es in der Regel ein Zeitfenster in dem das Passwort nicht erneut abgefragt wird.
                      • R Rushmed
                        WalW Offline
                        WalW Offline
                        Wal
                        @rushmed ,
                        nutze einen ssh-client(z.B. Bitvise ssh-client) anstatt die Konsole, da funktioniert es auch mit dem PW.
                        Die Web-Konsole nutze ich auch nur im Notfall, da es Einschränkungen gibt.
                        Walter
                        DoorIO-Adapter
                        • R Offline
                          Rushmed
                          OK, danke für die Antworten.
