  4. Zigbee Adapter zeigt keine Geräte mehr an
    6.6k
64 Beiträge 5 Kommentatoren 6.6k Aufrufe 5 Beobachtet
  • C chris25
    @asgothian
    ja ich hatte es ausversehen eine der "alten" Gruppen zugewiesen. Habe die Gruppe 1 mit der GroupID 1 angelegt und das Gerät dort zugewiesen. Beim Wechseln der Gruppe für das Gerät crasht der Adapter
    zigbee.0
    2025-08-25 21:57:17.202	error	Cannot read properties of undefined (reading 'deleteObj')
    zigbee.0
    2025-08-25 21:57:17.202	error	TypeError: Cannot read properties of undefined (reading 'deleteObj') at /opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:360:51 at Array.forEach (<anonymous>) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:356:29) at processImmediate (node:internal/timers:487:21)
    zigbee.0
    2025-08-25 21:57:17.202	error	uncaught exception: Cannot read properties of undefined (reading 'deleteObj')
    zigbee.0
    2025-08-25 21:57:17.183	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    zigbee.0
    2025-08-25 21:57:16.961	error	id.match is not a function
    zigbee.0
    2025-08-25 21:57:16.961	error	TypeError: id.match is not a function at StatesController.getDefaultGroupIcon (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:764:32) at Groups.updateGroupMembership (/opt/iobroker/node_modules/iobroker.zigbee/lib/groups.js:176:56)
    zigbee.0
    2025-08-25 21:57:16.961	error	unhandled promise rejection: id.match is not a function
    zigbee.0
    2025-08-25 21:57:16.961	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Beim einschalten über die Gruppe gibts ebenfalls einen Crash
    zigbee.0
    2025-08-25 21:59:22.603	error	device.ieeeAddr.substr is not a function
    zigbee.0
    2025-08-25 21:59:22.603	error	TypeError: device.ieeeAddr.substr is not a function at StatesController.onZigbeeEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/statescontroller.js:1115:39) at ZigbeeController.emit (node:events:518:28) at ZigbeeController.emit (node:domain:489:12) at ZigbeeController.event (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:345:14) at ZigbeeController.handleMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:909:14)
    zigbee.0
    2025-08-25 21:59:22.603	error	unhandled promise rejection: device.ieeeAddr.substr is not a function
    zigbee.0
    2025-08-25 21:59:22.603	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @chris25 Ok.. da ist also etwas mit den Gruppen nicht ok. Kannst du bitte als letztes versuchen alle Gruppen zu löschen (einfach über die Kachel) ?Dann sollten die Meldungen weg sein.
    A.
    C 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      chris25
      @asgothian
      Okay... das ist jetzt sehr komisch, ich habe alle 4 Gruppen gelöscht und den Adapter neu gestartet. Die 2 von mir angelegten Gruppen sind weg. Die Gruppen 28 & 170 kommen allerdings von alleine wieder :(
      • AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @chris25 sagte in Zigbee Adapter zeigt keine Geräte mehr an:
        @asgothian
        Das ist leider nicht so komisch wie es scheint. die genauen Hintergründe habe ich noch nicht vollständig heraus bekommen, aber es scheint so das bestimmte Geräte selbstständig Gruppen anlegen. Manche beim Pairing, manche bei der Konfiguration, andere immer wenn die Gruppe nicht existiert.
        Da der Adapter selber keine Liste von Gruppen verwaltet, sondern immer alle vom Herdsman gemeldeten Gruppen verwaltet kommen diese wieder. Bei den Geräten die ich im Einsatz habe passiert das immer dann wenn ich eine Ikea Fernbedienung anlerne - dann bekomme ich die Ikea Gruppe (901)
        Ich bin sowieso dabei das Thema Gruppen zu überarbeiten - das kommt dann mit der 3.1. Vielleicht finde ich da eine entsprechend passende Lösung.
        Kannst du bitte nochmal einen (letzten) Test machen - bitte genau in dieser Reihenfolge:
        • per JS Skriptstub die beiden Gruppen löschen (Skript ist beiliegend)
        • Adapter anhalten
        • shepherd.db ueberpruefen ob die Gruppen wirklich weg sind
        • Adapter starten
        Wichtig ist das in diesem gesamten Ablauf weder das Zigbee-Tab noch die Zigbee-EInstellungen geöffnet werden / sind.
        sendTo('zigbee.0', 'deleteGroup', '28');
        sendTo('zigbee.0', 'deleteGroup', '170');
        A.
          @asgothian
          • Adapter anhalten
          • Adapter starten
          A.
          chris25
          schrieb am zuletzt editiert von chris25
          @asgothian
          Ikea Fernbedienungen habe ich auch im Einsatz, vielleicht kommen die Gruppen davon ?
          Ich habe die beiden Gruppen per JS gelöscht, in der shepherd.db sind sie ebenfalls weg. Nach einem Adapter Neustart tauchen sie weder in der Liste mit den Geräten noch in den Objekten von Zigbee auf. Der Fehler für die beiden Gruppen kommt allerdings leider immer noch wenn ich mir die Geräteliste anzeigen lasse :(
          Edit: die beiden Gruppen tauchen nach einem zweiten Neustart des Adapters wieder auf in der UI, in den Objekten und in der shepherd.db auf.
          • C chris25
            @asgothian
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @asgothian
            Nein, Ikea nutzt eigentlich immer die Gruppe 901
            Ärgerlich - irgendwer legt diese Gruppen also an.
            Damit weiss ich bescheid, aber noch nicht was zu tun ist - ich bräuchte dringend eines der Geräte welches dafür verantwortlich ist.
            A
              @asgothian
              A
              chris25
              @asgothian
              ich würde dir sehr gerne helfen und die Infos dazu liefern. Lässt sich das irgendwie rausfinden welche Geräte diese beiden Gruppen anlegen ? Das komische ist auch, dass keine Geräte den Gruppen zugeordnet sind.
              • C chris25
                @asgothian
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @asgothian
                Leider ist das nicht so einfach. Ich gehe im Moment davon aus das beliebige Fernbedienungen / Steuergeräte dieses Verhalten zeigen können. Kannst du mal eine Liste von Gerätetypen posten die bei Dir im Netz sind, wobei du Geräte der folgenden Hersteller erst einmal ausklammern kannst:
                • Ikea
                • Philips / Hue
                • Aqara
                • Innr
                Auch kannst du alle Leuchtmittel und Steckdosen auslassen - die sind eher nicht verantwortlich.
                Das kein Gerät der Gruppe zugeordnet ist ist soweit auch ok. Das ist bei allen automatisch generierten Gruppen der Fall.
                  @asgothian
                  • Ikea
                  • Philips / Hue
                  • Aqara
                  • Innr
                  chris25
                  @asgothian
                  anbei die Liste mit den Geräten
                  Ich vermute, dass LYWSD03MMC oder LYWSD03MMC-z die Probleme bereiten könnten ? Eins dieser Geräte hatte die in den vorherigen Logs auch Sorgen bereitet. Das sind Xiaomi BLE Thermometer auf Zigbee umgeflashed.
                  zigbee.0 2025-08-25 16:14:16.215 warn DeviceConfigure:0xa4c13888969a5dec LYWSD03MMC Failed to configure. --> Bind 0xa4c13888969a5dec/1 msTemperatureMeasurement from '0x00212effff053c18/1' failed (Status 'TABLE_FULL')
                  • C chris25
                    @asgothian
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @chris25 Hmm.. ich hab da eher den Tongou oder den Rauchmelder im Verdacht. die Thermometer haben eigentlich keinen Grund zu dem Gruppen-kram.
                    Mit dem Tongue könntest Du für mich noch etwas testen:
                    Lt. Beschreibung kann das poll-intervall eingestellt werden. Da wäre mal interessant ob das via den Options für das Gerät (analog zum BWM) geht. (via measurement_poll_intervall mit einer Zahl zwischen 1 und 60
                    Auch die anderen Optionen die bei Z2M angegeben sind können funktionieren - ich hab einfach zu wenig devices mit so Optionen.
                    A.
                    Nachtrag: Um die Option zu aktivieren müsstest du dem Gerät vom ioBroker einen Befehl senden, sprich in diesem Fall einfach mal den Anzeigemodus (indicator mode) umsetzen - dann schaltest Du deinen Stromkreis nicht ab :)
                    A.
                      A.
                      A.
                      chris25
                      @asgothian
                      Habe es mit einer Steckdose probiert die diese Option hat, leider lässt sich damit das Intervall nicht beeinflussen, die Daten werden unabhängig vom Wert nur jede Minute gezogen.
                      • C chris25
                        @asgothian
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @chris25 hattest du die Steckdose geschaltet nachdem du die Option eingetragen hast ?
                          chris25
                          @asgothian
                          Ja hatte den Wert von power_outage_memory hin und her gewechselt
                          • C chris25
                            @asgothian
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @chris25 welche Steckdose, welche option genau hast du gesetzt ?
                              chris25
                              @asgothian
                              Tuya TS011F_plug_3 mit der Option measurement_poll_interval
                              • C chris25
                                @asgothian
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @chris25 bitte folgendes Versuchen:
                                • das intervall via send_payload mit dem Wert `{'measurement_poll_intervall':30} setzen. Nachschauen ob es eine Meldung im Log gibt wenn du das machst.
                                • als weitere Option state_action mit dem Wert true eintragen
                                • die Steckdose auf Debug setzen (Bug icon aktivieren)
                                • Steckdose schalten - schauen ob es eine ELEVATED Meldung gibt wo die Steckdose ein action Sendet.
                                WIchtig - nach dem Test bitte das Bug icon wieder deaktivieren!
                                A.
                                  A.
                                  chris25
                                  @asgothian
                                  Habe die Punkte von dir versucht, leider auch ohne Erfolg.
                                  Den send_payload Wert musste ich auf {"measurement_poll_intervall":20 } ändern anders kam eine Fehlermeldung.
                                  Die Steckdose direkt über den Power state schalten kann ich nicht, da ansonsten der Server weg ist. Habe stattdessen wieder den Wert von power_outage_memory geändert.
                                  zigbee.0
                                  2025-08-27 08:29:32.897	warn	ELEVATED:I02 (a85e) value generated '227' from device 84ba20fffe6e78b8 for 'Measured electrical potential value'
                                  zigbee.0
                                  2025-08-27 08:29:32.897	warn	ELEVATED:I02 (a85e) value generated '0.166' from device 84ba20fffe6e78b8 for 'Instantaneous measured electrical current'
                                  zigbee.0
                                  2025-08-27 08:29:32.897	warn	ELEVATED:I02 (a85e) value generated '19' from device 84ba20fffe6e78b8 for 'Load power'
                                  zigbee.0
                                  2025-08-27 08:29:32.897	warn	ELEVATED:I01 (a85e) message received '{"power":19,"current":0.166,"voltage":227}' from device 84ba20fffe6e78b8 type 'TS011F_plug_3'
                                  zigbee.0
                                  2025-08-27 08:29:32.896	warn	ELEVATED:I02 (a85e) value generated '255' from device 84ba20fffe6e78b8 for 'Link quality'
                                  zigbee.0
                                  2025-08-27 08:29:32.896	warn	ELEVATED:I01 (a85e) message received '{"linkquality":255}' from device 84ba20fffe6e78b8 type 'TS011F_plug_3'
                                  zigbee.0
                                  2025-08-27 08:29:32.895	warn	ELEVATED:I01 (a85e) Zigbee Event of Type readResponse from device 0x84ba20fffe6e78b8, incoming event: {"type":"readResponse","data":{"rmsVoltage":227,"rmsCurrent":166,"activePower":19},"linkquality":255,"groupID":0,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":13,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-08-27 08:28:32.802	warn	ELEVATED:I02 (bda0) value generated '227' from device 84ba20fffe6e78b8 for 'Measured electrical potential value'
                                  zigbee.0
                                  2025-08-27 08:28:32.802	warn	ELEVATED:I02 (bda0) value generated '0.214' from device 84ba20fffe6e78b8 for 'Instantaneous measured electrical current'
                                  zigbee.0
                                  2025-08-27 08:28:32.802	warn	ELEVATED:I02 (bda0) value generated '23' from device 84ba20fffe6e78b8 for 'Load power'
                                  zigbee.0
                                  2025-08-27 08:28:32.802	warn	ELEVATED:I01 (bda0) message received '{"power":23,"current":0.214,"voltage":227}' from device 84ba20fffe6e78b8 type 'TS011F_plug_3'
                                  zigbee.0
                                  2025-08-27 08:28:32.802	warn	ELEVATED:I02 (bda0) value generated '255' from device 84ba20fffe6e78b8 for 'Link quality'
                                  zigbee.0
                                  2025-08-27 08:28:32.802	warn	ELEVATED:I01 (bda0) message received '{"linkquality":255}' from device 84ba20fffe6e78b8 type 'TS011F_plug_3'
                                  zigbee.0
                                  2025-08-27 08:28:32.800	warn	ELEVATED:I01 (bda0) Zigbee Event of Type readResponse from device 0x84ba20fffe6e78b8, incoming event: {"type":"readResponse","data":{"rmsVoltage":227,"rmsCurrent":214,"activePower":23},"linkquality":255,"groupID":0,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":3,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-08-27 08:27:48.220	warn	ELEVATED:I02 (0f7b) value generated '255' from device 84ba20fffe6e78b8 for 'Link quality'
                                  zigbee.0
                                  2025-08-27 08:27:48.220	warn	ELEVATED:I01 (0f7b) message received '{"linkquality":255}' from device 84ba20fffe6e78b8 type 'TS011F_plug_3'
                                  zigbee.0
                                  2025-08-27 08:27:48.219	warn	ELEVATED:I01 (0f7b) Zigbee Event of Type attributeReport from device 0x84ba20fffe6e78b8, incoming event: {"type":"attributeReport","data":{"moesStartUpOnOff":0},"linkquality":255,"groupID":0,"cluster":"genOnOff","meta":{"zclTransactionSequenceNumber":2,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-08-27 08:27:48.206	warn	ELEVATED:SUCCESS (0ee3) convert result {"state":{"power_outage_memory":"off"}} for device 0x84ba20fffe6e78b8
                                  zigbee.0
                                  2025-08-27 08:27:48.068	warn	ELEVATED:O04 (0ee3) convert power_outage_memory, "off", {} for device 0x84ba20fffe6e78b8 with Endpoint power_outage_memory
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  2025-08-27 08:27:48.068	warn	ELEVATED:O03 (0ee3) Publishing to 0x84ba20fffe6e78b8 of model TS011F_plug_3 with power_outage_memory
                                  zigbee.0
                                  2025-08-27 08:27:48.068	warn	ELEVATED:O02 (0ee3) Change state 'power_outage_memory' at device 0x84ba20fffe6e78b8 type 'TS011F_plug_3'
                                  zigbee.0
                                  2025-08-27 08:27:48.067	warn	ELEVATED:O01 (0ee3) User state change of state zigbee.0.84ba20fffe6e78b8.power_outage_memory with value off (ack: false) from system.adapter.admin.0
                                  Edit habe den Payload auch noch auf folgendes gesetzt, auch ohne Erfolg
                                    "measurement_poll_intervall": 20,
                                    "state_action": true
                                  Habe nur diese Meldung gefunden
                                  zigbee.0
                                  2025-08-27 08:37:14.992	info	No converter available for 'TS011F_plug_3' with key 'state_action'
                                  • C chris25
                                    @asgothian
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    zigbee.0
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    @chris25 zum measurement Intervall kam die ‘no converter for…’ Meldung nicht ?
                                    Und wegen dem State Action muss ich dann eine andere Steckdose finden 🤣. Ich hab aus meinem Netz alle pollenden devices verbannt.
                                    A.
                                      A.
                                      chris25
                                      @asgothian
                                      Doch die kam auch hatte es nur nicht gesehen, habe nochmal im Log geschaut
                                      2025-08-27 08:37:14.992 - info: zigbee.0 (669) No converter available for 'TS011F_plug_3' with key 'measurement_poll_intervall'
                                      2025-08-27 08:37:14.992 - info: zigbee.0 (669) No converter available for 'TS011F_plug_3' with key 'state_action'
                                      Soll ich es noch mit einer anderen Steckdose die ich schalten kann probieren ? Ich denke das Ergebnis wird das gleiche sein.
