  4. Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten
    6.6k
28 Beiträge 5 Kommentatoren 2.6k Aufrufe 5 Beobachtet
    @krys
    Dann starte den Container jetzt mal durch und zeig dann nochmal
    iob diag
    Krys
    ```bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-11-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     14:16:14 up 3 min,  2 users,  load average: 3.45, 2.21, 1.16
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-08-10 14:16:15 CEST
               Universal time: Sun 2025-08-10 12:16:15 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    krystian
    HOME=/home/krystian
    GROUPS=krystian dialout sudo iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             10G        2.8G        7.2G        110K        634M        7.8G
    Swap:           1.1G          0B        1.1G
    Total:           11G        2.8G        8.3G
    Active iob-Instances:   41
            10124 M total memory
             2639 M used memory
             2589 M active memory
              474 M inactive memory
             6879 M free memory
                0 M buffer memory
              604 M swap cache
             1024 M total swap
                0 M used swap
             1024 M free swap
    top - 14:16:15 up 3 min,  2 users,  load average: 3.45, 2.21, 1.16
    Tasks:  65 total,   1 running,  64 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  10124.0 total,   6878.5 free,   2640.9 used,    604.7 buff/cache
    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7483.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    3 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  43% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  100K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
    /var:
    1.3G    /var/
    787M    /var/log
    782M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
    355M    /var/cache
    Archived and active journals take up 182.7M in the file system.
    /opt/iobroker/backups:
    237M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    845M    /opt/iobroker/iobroker-data/
    453M    /opt/iobroker/iobroker-data/files
    186M    /opt/iobroker/iobroker-data/files/vis-2
    167M    /opt/iobroker/iobroker-data/history-data
    149M    /opt/iobroker/iobroker-data/backup-objects
    42M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    36M     /opt/iobroker/iobroker-data/states.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.4
    /usr/bin/node           v20.19.4
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 20.19.4-1nodesource1
      Candidate: 20.19.4-1nodesource1
      Version table:
     *** 20.19.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 233)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     10
    +-- iobroker.ankersolix2@2.2.0 (git+ssh://git@github.com/ronny130286/ioBroker.ankersolix2.git#feb2ace0252fbd8cf30684f2f962d52d30b80d03)
    +-- iobroker.devices@1.1.5 (git+ssh://git@github.com/ioBroker/ioBroker.devices.git#9c60a66913c1aee57658cf845db655f13c144ebe)
    +-- iobroker.geofency@1.2.4 (git+ssh://git@github.com/ioBroker/ioBroker.geofency.git#cf9ccab32a4c8896a90f645e41c3a665ac0d6b0f)
    +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
    +-- iobroker.homeconnect@1.4.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.homeconnect.git#1c0ea50d8814e21bfa238db6bfcd5300846ffe9d)
    +-- iobroker.sayit@5.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.sayit.git#d15c2954b01673c5ac3697c3747bd904f99ad3e2)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
    +-- iobroker.yahka@1.1.5 (git+ssh://git@github.com/jensweigele/ioBroker.yahka.git#33608f7a2cc3ee5397a08980c5e03384be7dda27)
    +-- iobroker.zigbee@3.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#dc37fdcbd64b52258cf6b44a6b703954796a844b)
    `-- nodejieba@3.4.3 (git+ssh://git@github.com/yanyiwu/nodejieba.git#7b93462d7e8eff6f2939202a0abbfcbf64c9ec01)
    Adapter State
    + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
      system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
    + system.adapter.geofency.0               : geofency              : ioBroker                                 -  enabled, port: 7999, bind: 0.0.0.0
    + system.adapter.google-sharedlocations.0 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.1 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.2 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.3 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
    + system.adapter.hmip.1                   : hmip                  : ioBroker                                 -  enabled
    + system.adapter.homeconnect.1            : homeconnect           : ioBroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
    + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
    + system.adapter.nuki.0                   : nuki                  : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      system.adapter.openweathermap.1         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
    + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ 1       │ 'latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "adguard"      : 1.0.1    , installed 1.0.1
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "ankersolix2"  : 2.2.0    , installed 2.2.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "hue"          : 3.16.1   , installed 3.16.1
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "notification-manager": 1.2.1, installed 1.2.1
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "yahka"        : 1.0.3    , installed 1.1.5
    Adapter    "zigbee"       : 2.0.5    , installed 3.0.3
    Objects and States
    Objects:        30300
    States:         27699
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       178002187  1032/io.nuki.0
    tcp        0      0 127.0.0.1:37867         0.0.0.0:*               LISTEN      1001       178004354  1803/io.yahka.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          177990009  1/init
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          178004999  1963/master
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       177989093  127/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       177988369  127/iobroker.js-con
    tcp        0      0 0.0.0.0:36969           0.0.0.0:*               LISTEN      1001       178002394  1803/io.yahka.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          177990917  1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          177990011  1/init
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       178006856  2166/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       177990413  155/io.admin.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          178005000  1963/master
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       178003747  1788/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       178003748  1788/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       177991515  353/io.broadlink2.0
    udp        0      0 0.0.0.0:56427           0.0.0.0:*                           1001       178006835  2159/io.upnp.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          177990010  1/init
    udp        0      0 0.0.0.0:42078           0.0.0.0:*                           1001       177993846  353/io.broadlink2.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       178007757  2159/io.upnp.0
    udp        0      0 0.0.0.0:53341           0.0.0.0:*                           1001       177993161  353/io.broadlink2.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       177997732  1021/io.mihome-vacu
    udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       178005438  1995/io.mihome-vacu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178002391  1803/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       177991544  379/io.chromecast.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       178004066  1750/io.shelly.0
    udp6       0      0 :::111                  :::*                                0          177990012  1/init
    2025-08-10 14:16:01.635  - debug: lgtv.0 (1982) TV is off
    2025-08-10 14:16:02.913  - info: alexa2.0 (394) Initialization Done ...
    2025-08-10 14:16:03.470  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
        at TLSWrap.onStreamRead (node:internal/stream_base_commons:218:20)
    2025-08-10 14:16:03.471  - info: chromecast.0 (379) Chromecast - client disconnected
    2025-08-10 14:16:03.472  - info: chromecast.0 (379) Chromecast - Detached player
    2025-08-10 14:16:03.645  - info: chromecast.0 (379) Chromecast - Connected client
    2025-08-10 14:16:03.665  - info: chromecast.0 (379) Chromecast - Try to join player
    2025-08-10 14:16:03.666  - info: chromecast.0 (379) Chromecast - Connected player
    2025-08-10 14:16:03.666  - info: chromecast.0 (379) Chromecast - Player joint
    2025-08-10 14:16:03.721  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
    2025-08-10 14:16:04.170  - info: tuya.0 (1788) bfc89472838729ae991dfh: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.34:6668
    2025-08-10 14:16:07.763  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
    2025-08-10 14:16:09.700  - debug: lgtv.0 (1982) TV is off
    2025-08-10 14:16:15.827  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
    2025-08-10 14:16:17.764  - debug: lgtv.0 (1982) TV is off
    2025-08-10 14:16:23.890  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
    2025-08-10 14:16:25.828  - debug: lgtv.0 (1982) TV is off
    2025-08-10 14:16:31.954  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
    2025-08-10 14:16:33.892  - debug: lgtv.0 (1982) TV is off
    2025-08-10 14:16:40.019  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
    2025-08-10 14:16:41.955  - debug: lgtv.0 (1982) TV is off
    2025-08-10 14:16:48.081  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
    2025-08-10 14:16:50.020  - debug: lgtv.0 (1982) TV is off
    • K Krys
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      krystian
      HOME=/home/krystian
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           1.1G          0B        1.1G
               2639 M used memory
               6879 M free memory
                  0 M buffer memory
                604 M swap cache
               1024 M total swap
                  0 M used swap
               1024 M free swap
      *** FILESYSTEM ***
      /var:
      1.3G    /var/
      787M    /var/log
      355M    /var/cache
      USB-Devices by-id:
      HINT:
      /dev/ttyUSB0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        30300
      States:         27699
      Pending Updates: 0
      @krys
      Da läuft doch immer noch Zeuch auf Debug. Der lgtv.0 z.B.
        @krys
        Krys
        @thomas-braun Habs im Nachgang auch gemerkt und direkt geändert.
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
         14:26:01 up 13 min,  2 users,  load average: 0.57, 0.74, 0.88
        CPU threads: 4
                       Local time: Sun 2025-08-10 14:26:01 CEST
                   Universal time: Sun 2025-08-10 12:26:01 UTC
                         RTC time: n/a
                  RTC in local TZ: no
        krystian
        HOME=/home/krystian
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:             10G        2.7G        7.3G        110K        638M        7.9G
        Swap:           1.1G          0B        1.1G
        Total:           11G        2.7G        8.3G
                 2583 M used memory
                 2534 M active memory
                  478 M inactive memory
                 6931 M free memory
                    0 M buffer memory
                  608 M swap cache
                 1024 M total swap
                    0 M used swap
                 1024 M free swap
        top - 14:26:01 up 13 min,  2 users,  load average: 0.57, 0.74, 0.88
        MiB Mem :  10124.0 total,   6929.6 free,   2585.7 used,    608.8 buff/cache
        MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7538.3 avail Mem
        *** FILESYSTEM ***
        /var:
        1.3G    /var/
        787M    /var/log
        355M    /var/cache
        849M    /opt/iobroker/iobroker-data/
        43M     /opt/iobroker/iobroker-data/objects.jsonl
        38M     /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        HINT:
        /dev/ttyUSB0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 818)
        admin:          7.6.17
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        30300
        States:         27699
        Hit:1 http://security.debian.org bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Pending Updates: 0
        2025-08-10 14:22:06.854  - info: chromecast.0 (379) Chromecast - Connected player
        2025-08-10 14:22:06.855  - info: chromecast.0 (379) Chromecast - Player joint
        2025-08-10 14:22:06.867  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
        2025-08-10 14:24:06.467  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
        2025-08-10 14:24:06.467  - info: chromecast.0 (379) Chromecast - client disconnected
        2025-08-10 14:24:06.468  - info: chromecast.0 (379) Chromecast - Detached player
        2025-08-10 14:24:06.542  - info: chromecast.0 (379) Chromecast - Connected client
        2025-08-10 14:24:06.647  - info: chromecast.0 (379) Chromecast - Try to join player
        2025-08-10 14:24:06.648  - info: chromecast.0 (379) Chromecast - Connected player
        2025-08-10 14:24:06.648  - info: chromecast.0 (379) Chromecast - Player joint
        2025-08-10 14:24:06.661  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
        2025-08-10 14:24:07.138  - info: nuki.0 (1032) Bridge Info requested: http://192.168.178.43:8080/info?ts=2025-08-10T12:24:06Z&rnr=51748&hash=bd97abd6fc36232b0a8173c26cd18fdd2db40f1303dc72fba2a933ce7401abff
        2025-08-10 14:24:10.147  - info: nuki.0 (1032) Lock list requested: http://192.168.178.43:8080/list?ts=2025-08-10T12:24:09Z&rnr=57691&hash=a8b330db2e5ae9097aa7c08d37e4380d8110d1812ccf8ec2263eeddb8a91f7c4
        2025-08-10 14:26:09.565  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
        2025-08-10 14:26:09.566  - info: chromecast.0 (379) Chromecast - client disconnected
        2025-08-10 14:26:09.567  - info: chromecast.0 (379) Chromecast - Detached player
        2025-08-10 14:26:09.881  - info: chromecast.0 (379) Chromecast - Connected client
        2025-08-10 14:26:10.262  - info: chromecast.0 (379) Chromecast - Try to join player
        2025-08-10 14:26:10.264  - info: chromecast.0 (379) Chromecast - Connected player
        2025-08-10 14:26:10.264  - info: chromecast.0 (379) Chromecast - Player joint
        2025-08-10 14:26:10.665  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
        • K Krys
          ```bash
          Script v.2025-03-08
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                           RTC time: n/a
                    RTC in local TZ: no
          krystian
          HOME=/home/krystian
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           1.1G          0B        1.1G
                   2583 M used memory
                   6931 M free memory
                      0 M buffer memory
                    608 M swap cache
                   1024 M total swap
                      0 M used swap
                   1024 M free swap
          *** FILESYSTEM ***
          /var:
          1.3G    /var/
          787M    /var/log
          355M    /var/cache
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.6.17
          javascript:     8.9.2
          Adapter State
          + instance is alive
          Objects and States
          Objects:        30300
          States:         27699
          Pending Updates: 0
          @krys sagte in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
          warum sind alle diese Instanzen über github installiert?
          da gibt's bestimmt einige in offiziellen Repos.
          sourceanalytix auf jeden Fall
            Krys
            Sollte nun i.O. sein.
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
              Virtualization: lxc
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             19:35:34 up 43 min,  2 users,  load average: 1.13, 0.94, 0.97
            CPU threads: 4
                           Local time: Sun 2025-08-10 19:35:34 CEST
                       Universal time: Sun 2025-08-10 17:35:34 UTC
                             RTC time: n/a
                      RTC in local TZ: no
            krystian
            HOME=/home/krystian
            iobroker
            HOME=/home/iobroker
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:
            *** MEMORY ***
            Mem:             10G        2.8G        7.3G        106K        507M        7.8G
            Swap:           1.1G          0B        1.1G
                     2709 M used memory
                     2728 M active memory
                      319 M inactive memory
                     6931 M free memory
                        0 M buffer memory
                      483 M swap cache
                     1024 M total swap
                        0 M used swap
                     1024 M free swap
            top - 19:35:35 up 43 min,  2 users,  load average: 1.13, 0.94, 0.97
            %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  10124.0 total,   6928.9 free,   2711.3 used,    483.9 buff/cache
            MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7412.7 avail Mem
            *** FILESYSTEM ***
            /var:
            1.3G    /var/
            779M    /var/log
            774M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
            355M    /var/cache
            825M    /opt/iobroker/iobroker-data/
            455M    /opt/iobroker/iobroker-data/files
            35M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
            USB-Devices by-id:
            HINT:
            /dev/ttyUSB0
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 2631)
            admin:          7.6.17
            javascript:     8.9.2
            nodejs modules from github:     2
            Adapter State
            + instance is alive
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
            Objects and States
            Objects:        30300
            States:         27641
            Pending Updates: 0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       178894137  125/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       178894132  125/iobroker.js-con
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          178899939  816/master
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          178892112  1/init
            tcp        0      0 127.0.0.1:35471         0.0.0.0:*               LISTEN      1001       178906235  656/io.yahka.0
            tcp        0      0 0.0.0.0:35257           0.0.0.0:*               LISTEN      1001       178900327  656/io.yahka.0
            tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       178898901  551/io.nuki.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          178891524  1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          178892114  1/init
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          178899940  816/master
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       178905344  989/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       178894361  155/io.admin.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       178902337  641/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       178902338  641/io.tuya.0
            udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       178894660  273/io.broadlink2.0
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          178892113  1/init
            udp        0      0 0.0.0.0:42485           0.0.0.0:*                           1001       178894667  273/io.broadlink2.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       178905612  970/io.upnp.0
            udp        0      0 0.0.0.0:35019           0.0.0.0:*                           1001       178905269  970/io.upnp.0
            udp        0      0 0.0.0.0:45068           0.0.0.0:*                           1001       178894782  273/io.broadlink2.0
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       178899133  536/io.mihome-vacuu
            udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       178901842  865/io.mihome-vacuu
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178900324  656/io.yahka.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178894696  296/io.chromecast.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       178899569  611/io.shelly.0
            udp6       0      0 :::111                  :::*                                0          178892115  1/init
            2025-08-10 19:34:00.886  - info: host.ioBroker iobroker upload [5] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/readmeDocu/stateStartValues.png readmeDocu/stateStartValues.png image/png
            2025-08-10 19:34:00.903  - info: host.ioBroker instance system.adapter.sourceanalytix.0 in version "0.4.14" started with pid 1411
            2025-08-10 19:34:01.061  - info: host.ioBroker iobroker upload [4] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_details.png settings_details.png image/png
            2025-08-10 19:34:01.227  - info: host.ioBroker iobroker upload [3] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_open.png settings_open.png image/png
            2025-08-10 19:34:01.236  - info: host.ioBroker iobroker upload [2] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/sourceanalytix.png sourceanalytix.png image/png
            2025-08-10 19:34:01.242  - info: host.ioBroker iobroker upload [1] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/style.css style.css text/css
            2025-08-10 19:34:01.248  - info: host.ioBroker iobroker upload [0] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/words.js words.js application/javascript
            2025-08-10 19:34:01.256  - info: host.ioBroker iobroker Updating objects from io-package.json for adapter "sourceanalytix" with version "0.4.14"
            2025-08-10 19:34:02.418  - info: host.ioBroker iobroker exit 0
            2025-08-10 19:35:22.864  - warn: chromecast.0 (296) Chromecast - Client error: Error: Device timeout
                at fn.ontimeout (/opt/iobroker/node_modules/castv2-client/lib/senders/platform.js:56:26)
                at Object.onceWrapper (node:events:638:28)
                at fn.emit (node:events:524:28)
                at fn.emit (node:domain:489:12)
                at Timeout.ontimeout [as _onTimeout] (/opt/iobroker/node_modules/castv2-client/lib/controllers/heartbeat.js:44:10)
                at listOnTimeout (node:internal/timers:581:17)
                at processTimers (node:internal/timers:519:7)
            2025-08-10 19:35:22.864  - info: chromecast.0 (296) Chromecast - client disconnected
            2025-08-10 19:35:22.865  - info: chromecast.0 (296) Chromecast - Detached player
            2025-08-10 19:35:22.929  - info: chromecast.0 (296) Chromecast - Connected client
            2025-08-10 19:35:22.968  - info: chromecast.0 (296) Chromecast - Try to join player
            2025-08-10 19:35:22.969  - info: chromecast.0 (296) Chromecast - Connected player
            2025-08-10 19:35:22.970  - info: chromecast.0 (296) Chromecast - Player joint
            2025-08-10 19:35:23.023  - info: chromecast.0 (296) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fd29bca0-aaaa-4b99-b18d-1df589d32b9a","statusText":"","transportId":"fd29bca0-aaaa-4b99-b18d-1df589d32b9a","universalAppId":"E8C28D3C"}
            • K Krys
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
                Virtualization: lxc
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 4
                               RTC time: n/a
                        RTC in local TZ: no
              krystian
              HOME=/home/krystian
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:
              *** MEMORY ***
              Swap:           1.1G          0B        1.1G
                       2709 M used memory
                       6931 M free memory
                          0 M buffer memory
                        483 M swap cache
                       1024 M total swap
                          0 M used swap
                       1024 M free swap
              *** FILESYSTEM ***
              /var:
              1.3G    /var/
              779M    /var/log
              355M    /var/cache
              USB-Devices by-id:
              HINT:
              /dev/ttyUSB0
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.6.17
              javascript:     8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        30300
              States:         27641
              Pending Updates: 0
              @krys
              Ich vermute da immer noch ein falsch eingestelltes Netzwerk.
              systemctl status systemd-networkd-wait-online.service
              sagt?
                @krys
                sagt?
                Krys
                @thomas-braun said in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
                krystian@ioBroker:~$ systemctl status systemd-networkd-wait-online.service
                x systemd-networkd-wait-online.service - Wait for Network to be Configured
                     Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; preset: disabled)
                     Active: failed (Result: exit-code) since Sun 2025-08-10 18:53:51 CEST; 1h 17min ago
                       Docs: man:systemd-networkd-wait-online.service(8)
                    Process: 105 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=1/FAILURE)
                   Main PID: 105 (code=exited, status=1/FAILURE)
                        CPU: 12ms
                • K Krys
                          CPU: 12ms
                  @krys
                  Auf meiner Kiste schaut der so aus:
                  echad@chet:~ $ systemctl status systemd-networkd-wait-online.service
                  ○ systemd-networkd-wait-online.service - Wait for Network to be Configured
                       Loaded: loaded (/usr/lib/systemd/system/systemd-networkd-wait-online.service; disabled; preset: enabled)
                       Active: inactive (dead)
                  echad@chet:~ $
                  Aber zu LXCs und Netzwerk kann ich nichts sagen.
                  R 1 Antwort Letzte Antwort
                    @krys
                    echad@chet:~ $
                    Ralf 2
                    Das sieht bei einem previligiertem LXC genauso aus wie bei dir:
                    ralf@Home-Server:~$ systemctl status systemd-networkd-wait-online.service
                    * systemd-networkd-wait-online.service - Wait for Network to be Configured
                         Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; disabled; preset: disabled)
                    ralf@Home-Server:~$
                    Gruß Ralf
                    • R Ralf 2
                      ralf@Home-Server:~$
                      TT-Tom
                      @ralf-2
                      bei einem unpreviligierten auch so
                      tom@iobDev:~$ systemctl status systemd-networkd-wait-online.service
                      Gruß Tom
                      Public Transport
                      NSPanel Adapter Wiki
                        Krys
                        So Leute, nach langem rumgefummel folgendes Ergebnis.
                        was kurios war, mein iobroker hatte plötzlich zwei IP-Adressen, was offensichtlich auch zu zusätzlichen Problemen führte.
                        Könnt ihr nochmal mit eurem geschulten Auge drüber schauen, ob euch noch was auffällt?
                        ```bash
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                                  Kernel: Linux 6.8.12-13-pve
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         10:32:36 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
                        CPU threads: 4
                                       Local time: Tue 2025-08-12 10:32:37 CEST
                                   Universal time: Tue 2025-08-12 08:32:37 UTC
                                         RTC time: n/a
                                  RTC in local TZ: no
                        krystian
                        HOME=/home/krystian
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:
                        *** MEMORY ***
                        Mem:             10G        2.6G        7.4G        114K        570M        8.0G
                        Swap:           1.1G          0B        1.1G
                        Total:           11G        2.6G        8.5G
                                 2478 M used memory
                                 2438 M active memory
                                  410 M inactive memory
                                 7101 M free memory
                                    0 M buffer memory
                                  544 M swap cache
                                 1024 M total swap
                                    0 M used swap
                                 1024 M free swap
                        top - 10:32:37 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
                        %Cpu(s): 25.0 us,  0.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :  10124.0 total,   7100.1 free,   2479.8 used,    544.3 buff/cache
                        MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7644.2 avail Mem
                        2 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  41% /
                        tmpfs                            tmpfs     3.1G  104K  3.1G   1% /run
                        /var:
                        1.3G    /var/
                        781M    /var/log
                        355M    /var/cache
                        251M    /opt/iobroker/backups/
                        660M    /opt/iobroker/iobroker-data/
                        268M    /opt/iobroker/iobroker-data/files
                        148M    /opt/iobroker/iobroker-data/backup-objects
                        48M     /opt/iobroker/iobroker-data/files/iot.admin
                        45M     /opt/iobroker/iobroker-data/states.jsonl
                        33M     /opt/iobroker/iobroker-data/objects.jsonl
                        8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                        USB-Devices by-id:
                        HINT:
                        /dev/ttyUSB0
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 428)
                        admin:          7.6.17
                        javascript:     8.9.2
                        nodejs modules from github:     4
                        +-- iobroker.alexa2@3.27.3 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#1f026d3554d62693f1c785027d1e326cf6461998)
                        +-- iobroker.cloudless-homeconnect@1.6.2 (git+ssh://git@github.com/eifel-tech/ioBroker.cloudless-homeconnect.git#2e5ef03576947db4490f99fe5b032ef5d0e216fe)
                        Adapter State
                        + system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : ioBroker                                 -  enabled
                        + instance is alive
                        Objects and States
                        Objects:        29378
                        States:         27132
                        Pending Updates: 0
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          343600     295/master
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          341984     1/init
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       344427     126/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       344422     126/iobroker.js-con
                        tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       349074     700/io.nuki.0
                        tcp        0      0 127.0.0.1:45729         0.0.0.0:*               LISTEN      1001       353213     813/io.yahka.0
                        tcp        0      0 0.0.0.0:37503           0.0.0.0:*               LISTEN      1001       352501     813/io.yahka.0
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          344254     1/init
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          341986     1/init
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          343601     295/master
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       346474     306/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       356415     992/io.web.0
                        udp        0      0 0.0.0.0:36423           0.0.0.0:*                           1001       345845     428/io.broadlink2.0
                        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       348828     681/io.mihome-vacuu
                        udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       353940     874/io.mihome-vacuu
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       352498     813/io.yahka.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       348185     443/io.chromecast.0
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       349155     760/io.shelly.0
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       353336     790/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       353337     790/io.tuya.0
                        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       346813     428/io.broadlink2.0
                        udp        0      0 0.0.0.0:56183           0.0.0.0:*                           1001       355236     969/io.upnp.0
                        udp        0      0 192.168.178.100:68      0.0.0.0:*                           103        345195     73/systemd-networkd
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          341985     1/init
                        udp        0      0 0.0.0.0:41265           0.0.0.0:*                           1001       347378     428/io.broadlink2.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       357628     969/io.upnp.0
                        udp6       0      0 :::111                  :::*                                0          341987     1/init
                        udp6       0      0 fe80::be24:11ff:fe5:546 :::*                                103        345342     73/systemd-networkd
                             Active: active (exited) since Tue 2025-08-12 10:25:35 CEST; 8min ago
                            Process: 108 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=0/SUCCESS)
                           Main PID: 108 (code=exited, status=0/SUCCESS)
                                CPU: 13ms
                        • K Krys
                          ```bash
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                            Virtualization: lxc
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 4
                                           RTC time: n/a
                                    RTC in local TZ: no
                          krystian
                          HOME=/home/krystian
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:
                          *** MEMORY ***
                          Swap:           1.1G          0B        1.1G
                                   2478 M used memory
                                   7101 M free memory
                                      0 M buffer memory
                                    544 M swap cache
                                   1024 M total swap
                                      0 M used swap
                                   1024 M free swap
                          *** FILESYSTEM ***
                          /var:
                          1.3G    /var/
                          781M    /var/log
                          355M    /var/cache
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyUSB0
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.6.17
                          javascript:     8.9.2
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        29378
                          States:         27132
                          Pending Updates: 0
                                  CPU: 13ms
                          @krys
                          Ich sag ja, da klemmt beim Netzwerk was...
                          Die üblichen Nicklichkeiten würde ich noch angehen.
                          Bei Zigbee z. B. den Geräte Link 'by-id' verwenden usw.
                          Ich würde auch jetzt auf nodejs@22 gehen:
                          iob nodejs-update
                          Und im Herbst würde ich das ganze Ding auf Debian 13 'Trixie' haben.
                            Krys
                            nodejs 22 ist erledigt.
                            beim Zigbee-Adapter, wenn ich vom Anschlussnamen
                            eintrage, habe ich ne Bootschleife und der Adapter wird nicht grün.
                            • K Krys
                              @krys
                              Dann stell es wieder um. Liegt vermutlich am LXC. Die Dinger ticken tw. etwas anders als ein 'richtiges' System.
                                @krys
                                Krys
                                @thomas-braun Ja, da scheint irgendwas mit den Rechten nicht zu passen. Kriege es aber anders auch nicht durchgeschleift.
                                • K Krys
                                  @krys
                                  Welche Rechte brauchst du denn an dem Gerät?
                                  ls -l /dev/ttyUSB0
                                    @krys
                                    ls -l /dev/ttyUSB0
                                    Krys
                                    @thomas-braun so wie ich das jetzt verstanden habe, sind die Rechte beim Host. Wie und was für Rechte ich brauche, das weiß ich nicht :/. Ich meine, es läuft ja grundsätzlich so wie es aktuell ist.
                                    • K Krys
                                      @krys
                                      Aber dann nicht wundern, wenn ggfls. genau das passiert:
                                      https://forum.iobroker.net/topic/81899/raspi-vermeidung-der-usb-port-wechsel?_=1755000455669
                                        Krys
                                        Das ist tatsächlich in den letzten 4 Jahren nicht passiert.
