  4. Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten
    6.6k
28 Beiträge 5 Kommentatoren 2.6k Aufrufe 5 Beobachtet
  • K Krys
    bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-11-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     13:03:39 up 22:06,  2 users,  load average: 0.26, 0.45, 0.60
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
    y               Local time: Sun 2025-08-10 13:03:39 CEST
               Universal time: Sun 2025-08-10 11:03:39 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    s
    *** Users and Groups ***
    User that called 'iob diag':
    krystian
    HOME=/home/krystian
    GROUPS=krystian dialout sudo iobroker
    iobroker
    [sudo] password for krystian:
    Sorry, try again.
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             10G        3.0G        6.8G         94K        809M        7.6G
    Swap:           1.1G         20K        1.1G
    Total:           11G        3.0G        7.8G
    Active iob-Instances:   17
            10124 M total memory
             2904 M used memory
              862 M active memory
             2633 M inactive memory
             6446 M free memory
                0 M buffer memory
              772 M swap cache
             1024 M total swap
                0 M used swap
             1023 M free swap
    top - 13:03:48 up 22:06,  2 users,  load average: 0.22, 0.43, 0.59
    Tasks:  65 total,   4 running,  61 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  10124.0 total,   6445.0 free,   2906.7 used,    772.4 buff/cache
    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7217.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    3 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4       30G   13G   16G  44% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  100K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
    /var:
    1.3G    /var/
    779M    /var/log
    774M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
    355M    /var/cache
    Archived and active journals take up 190.7M in the file system.
    /opt/iobroker/backups:
    237M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    829M    /opt/iobroker/iobroker-data/
    453M    /opt/iobroker/iobroker-data/files
    186M    /opt/iobroker/iobroker-data/files/vis-2
    167M    /opt/iobroker/iobroker-data/history-data
    149M    /opt/iobroker/iobroker-data/backup-objects
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.4
    /usr/bin/node           v20.19.4
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 20.19.4-1nodesource1
      Candidate: 20.19.4-1nodesource1
      Version table:
     *** 20.19.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 79603)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     10
    +-- iobroker.ankersolix2@2.2.0 (git+ssh://git@github.com/ronny130286/ioBroker.ankersolix2.git#feb2ace0252fbd8cf30684f2f962d52d30b80d03)
    +-- iobroker.devices@1.1.5 (git+ssh://git@github.com/ioBroker/ioBroker.devices.git#9c60a66913c1aee57658cf845db655f13c144ebe)
    +-- iobroker.geofency@1.2.4 (git+ssh://git@github.com/ioBroker/ioBroker.geofency.git#cf9ccab32a4c8896a90f645e41c3a665ac0d6b0f)
    +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
    +-- iobroker.homeconnect@1.4.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.homeconnect.git#1c0ea50d8814e21bfa238db6bfcd5300846ffe9d)
    +-- iobroker.sayit@5.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.sayit.git#d15c2954b01673c5ac3697c3747bd904f99ad3e2)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
    +-- iobroker.yahka@1.1.5 (git+ssh://git@github.com/jensweigele/ioBroker.yahka.git#33608f7a2cc3ee5397a08980c5e03384be7dda27)
    +-- iobroker.zigbee@3.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#dc37fdcbd64b52258cf6b44a6b703954796a844b)
    `-- nodejieba@3.4.3 (git+ssh://git@github.com/yanyiwu/nodejieba.git#7b93462d7e8eff6f2939202a0abbfcbf64c9ec01)
    Adapter State
      system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
      system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
    + system.adapter.geofency.0               : geofency              : ioBroker                                 -  enabled, port: 7999, bind: 0.0.0.0
    + system.adapter.google-sharedlocations.0 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.1 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.2 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.3 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
    + system.adapter.hmip.1                   : hmip                  : ioBroker                                 -  enabled
      system.adapter.homeconnect.1            : homeconnect           : ioBroker                                 -  enabled
      system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
      system.adapter.nuki.0                   : nuki                  : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      system.adapter.openweathermap.1         : openweathermap        : ioBroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
      system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
      system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
      system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ 1       │ 'latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "adguard"      : 1.0.1    , installed 1.0.1
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "ankersolix2"  : 2.2.0    , installed 2.2.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "hue"          : 3.16.1   , installed 3.16.1
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "notification-manager": 1.2.1, installed 1.2.1
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "yahka"        : 1.0.3    , installed 1.1.5
    Adapter    "zigbee"       : 2.0.5    , installed 3.0.3
    Objects and States
    Objects:        30300
    States:         27642
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Reading package lists...
    Pending Updates: 7
    *** Listening Ports ***
    tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       174727430  659/io.nuki.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       174716667  125/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       174718586  125/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          174726954  924/master
    tcp        0      0 127.0.0.1:42889         0.0.0.0:*               LISTEN      1001       176332756  764/io.yahka.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          174717495  1/init
    tcp        0      0 0.0.0.0:44189           0.0.0.0:*               LISTEN      1001       174727733  764/io.yahka.0
    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       174777843  1068/io.upnp.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       174719641  155/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       174731478  1074/io.web.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          174726955  924/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          174719463  1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          174717497  1/init
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       174728246  749/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       174728247  749/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       174721314  277/io.broadlink2.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          174717496  1/init
    udp        0      0 0.0.0.0:58271           0.0.0.0:*                           1001       174730450  1068/io.upnp.0
    udp        0      0 0.0.0.0:58680           0.0.0.0:*                           1001       177658529  277/io.broadlink2.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       174730719  1068/io.upnp.0
    udp        0      0 0.0.0.0:51166           0.0.0.0:*                           1001       174721317  277/io.broadlink2.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       174725302  637/io.mihome-vacuu
    udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       174728146  956/io.mihome-vacuu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       174727730  764/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       174720456  296/io.chromecast.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       174725560  719/io.shelly.0
    udp6       0      0 :::111                  :::*                                0          174717498  1/init
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) Device Ende
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Wäschetrockner"]: Auswertung gestartet
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Wäschetrockner"]: WERTE für START: 0W; Schwelle Start: 15W; gestartet: false
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Wäschetrockner"]: value status: end
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Spülmaschine"]: Auswertung gestartet
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Spülmaschine"]: WERTE für START: 0W; Schwelle Start: 1W; gestartet: false
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Spülmaschine"]: value status: end
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) Device Ende
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit"]: Auswertung gestartet
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit"]: WERTE für START: 0W; Schwelle Start: 1W; gestartet: false
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit"]: value status: end
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit Nacht"]: Auswertung gestartet
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit Nacht"]: WERTE für START: 0W; Schwelle Start: 1W; gestartet: false
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit Nacht"]: value status: end
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Waschmaschine"]: Auswertung beendet
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Wäschetrockner"]: Auswertung beendet
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Spülmaschine"]: Auswertung beendet
    2025-08-10 13:04:20.312  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit"]: Auswertung beendet
    2025-08-10 13:04:20.312  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit Nacht"]: Auswertung beendet
    2025-08-10 13:04:21.028  - debug: lgtv.0 (949) TV is off
    2025-08-10 13:04:27.154  - debug: lgtv.0 (949) Connecting to WebOS TV: wss://192.168.178.30:3001
    2025-08-10 13:04:29.090  - debug: lgtv.0 (949) TV is off
    @krys sagte in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
    13 Logeinträge in einer Millisekunde sind aber auch nicht gerade ressourcenschonend
      @homoran sagte in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
      Stimmt, hab ich gar nicht gesehen...
      @Krys Stell das Log nicht auf DEBUG ein.
        Krys
        @thomas-braun Updates habe ich erledigt
          Krys
          schrieb am zuletzt editiert von Krys
          @thomas-braun von debug umgestellt habe ich ebenfalls nun.
          • K Krys
            @krys
            Dann starte den Container jetzt mal durch und zeig dann nochmal
            iob diag
              @krys
              iob diag
              Krys
              ```bash
              Script v.2025-03-08
              *** BASE SYSTEM ***
                Virtualization: lxc
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
               14:16:14 up 3 min,  2 users,  load average: 3.45, 2.21, 1.16
              CPU threads: 4
                             Local time: Sun 2025-08-10 14:16:15 CEST
                         Universal time: Sun 2025-08-10 12:16:15 UTC
                               RTC time: n/a
                        RTC in local TZ: no
              krystian
              HOME=/home/krystian
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:             10G        2.8G        7.2G        110K        634M        7.8G
              Swap:           1.1G          0B        1.1G
              Total:           11G        2.8G        8.3G
              Active iob-Instances:   41
                       2639 M used memory
                       2589 M active memory
                        474 M inactive memory
                       6879 M free memory
                          0 M buffer memory
                        604 M swap cache
                       1024 M total swap
                          0 M used swap
                       1024 M free swap
              top - 14:16:15 up 3 min,  2 users,  load average: 3.45, 2.21, 1.16
              Tasks:  65 total,   1 running,  64 sleeping,   0 stopped,   0 zombie
              MiB Mem :  10124.0 total,   6878.5 free,   2640.9 used,    604.7 buff/cache
              MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7483.1 avail Mem
              *** FILESYSTEM ***
              /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  43% /
              /var:
              1.3G    /var/
              787M    /var/log
              782M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
              355M    /var/cache
              Archived and active journals take up 182.7M in the file system.
              845M    /opt/iobroker/iobroker-data/
              42M     /opt/iobroker/iobroker-data/objects.jsonl
              36M     /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              HINT:
              /dev/ttyUSB0
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 233)
              admin:          7.6.17
              javascript:     8.9.2
              Adapter State
              + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
              + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
              + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
              + system.adapter.homeconnect.1            : homeconnect           : ioBroker                                 -  enabled
              + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
              + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
              + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
              + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
              + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
              + system.adapter.nuki.0                   : nuki                  : ioBroker                                 -  enabled
              + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
              + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
              + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
              + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
              + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
              + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
              + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
              + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
              + instance is alive
              Objects and States
              Objects:        30300
              States:         27699
              Pending Updates: 0
              tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       178002187  1032/io.nuki.0
              tcp        0      0 127.0.0.1:37867         0.0.0.0:*               LISTEN      1001       178004354  1803/io.yahka.0
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          177990009  1/init
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          178004999  1963/master
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       177989093  127/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       177988369  127/iobroker.js-con
              tcp        0      0 0.0.0.0:36969           0.0.0.0:*               LISTEN      1001       178002394  1803/io.yahka.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          177990917  1/init
              tcp6       0      0 :::111                  :::*                    LISTEN      0          177990011  1/init
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       178006856  2166/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       177990413  155/io.admin.0
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          178005000  1963/master
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       178003747  1788/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       178003748  1788/io.tuya.0
              udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       177991515  353/io.broadlink2.0
              udp        0      0 0.0.0.0:56427           0.0.0.0:*                           1001       178006835  2159/io.upnp.0
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          177990010  1/init
              udp        0      0 0.0.0.0:42078           0.0.0.0:*                           1001       177993846  353/io.broadlink2.0
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       178007757  2159/io.upnp.0
              udp        0      0 0.0.0.0:53341           0.0.0.0:*                           1001       177993161  353/io.broadlink2.0
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       177997732  1021/io.mihome-vacu
              udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       178005438  1995/io.mihome-vacu
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178002391  1803/io.yahka.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       177991544  379/io.chromecast.0
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       178004066  1750/io.shelly.0
              udp6       0      0 :::111                  :::*                                0          177990012  1/init
              2025-08-10 14:16:01.635  - debug: lgtv.0 (1982) TV is off
              2025-08-10 14:16:02.913  - info: alexa2.0 (394) Initialization Done ...
              2025-08-10 14:16:03.470  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
                  at TLSWrap.onStreamRead (node:internal/stream_base_commons:218:20)
              2025-08-10 14:16:03.471  - info: chromecast.0 (379) Chromecast - client disconnected
              2025-08-10 14:16:03.472  - info: chromecast.0 (379) Chromecast - Detached player
              2025-08-10 14:16:03.645  - info: chromecast.0 (379) Chromecast - Connected client
              2025-08-10 14:16:03.665  - info: chromecast.0 (379) Chromecast - Try to join player
              2025-08-10 14:16:03.666  - info: chromecast.0 (379) Chromecast - Connected player
              2025-08-10 14:16:03.666  - info: chromecast.0 (379) Chromecast - Player joint
              2025-08-10 14:16:03.721  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
              2025-08-10 14:16:04.170  - info: tuya.0 (1788) bfc89472838729ae991dfh: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.34:6668
              2025-08-10 14:16:07.763  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
              2025-08-10 14:16:09.700  - debug: lgtv.0 (1982) TV is off
              2025-08-10 14:16:15.827  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
              2025-08-10 14:16:17.764  - debug: lgtv.0 (1982) TV is off
              2025-08-10 14:16:23.890  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
              2025-08-10 14:16:25.828  - debug: lgtv.0 (1982) TV is off
              2025-08-10 14:16:31.954  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
              2025-08-10 14:16:33.892  - debug: lgtv.0 (1982) TV is off
              2025-08-10 14:16:40.019  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
              2025-08-10 14:16:41.955  - debug: lgtv.0 (1982) TV is off
              2025-08-10 14:16:48.081  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
              2025-08-10 14:16:50.020  - debug: lgtv.0 (1982) TV is off
              • K Krys
                ```bash
                Script v.2025-03-08
                *** BASE SYSTEM ***
                  Virtualization: lxc
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                CPU threads: 4
                                 RTC time: n/a
                          RTC in local TZ: no
                krystian
                HOME=/home/krystian
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:
                *** MEMORY ***
                Swap:           1.1G          0B        1.1G
                         2639 M used memory
                         6879 M free memory
                            0 M buffer memory
                          604 M swap cache
                         1024 M total swap
                            0 M used swap
                         1024 M free swap
                *** FILESYSTEM ***
                /var:
                1.3G    /var/
                787M    /var/log
                355M    /var/cache
                USB-Devices by-id:
                HINT:
                /dev/ttyUSB0
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.6.17
                javascript:     8.9.2
                Adapter State
                + instance is alive
                Objects and States
                Objects:        30300
                States:         27699
                Pending Updates: 0
                @krys
                Da läuft doch immer noch Zeuch auf Debug. Der lgtv.0 z.B.
                  @krys
                  Krys
                  @thomas-braun Habs im Nachgang auch gemerkt und direkt geändert.
                  ```bash
                  Script v.2025-03-08
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   14:26:01 up 13 min,  2 users,  load average: 0.57, 0.74, 0.88
                  CPU threads: 4
                                 Local time: Sun 2025-08-10 14:26:01 CEST
                             Universal time: Sun 2025-08-10 12:26:01 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  krystian
                  HOME=/home/krystian
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:             10G        2.7G        7.3G        110K        638M        7.9G
                  Swap:           1.1G          0B        1.1G
                  Total:           11G        2.7G        8.3G
                           2583 M used memory
                           2534 M active memory
                            478 M inactive memory
                           6931 M free memory
                              0 M buffer memory
                            608 M swap cache
                           1024 M total swap
                              0 M used swap
                           1024 M free swap
                  top - 14:26:01 up 13 min,  2 users,  load average: 0.57, 0.74, 0.88
                  MiB Mem :  10124.0 total,   6929.6 free,   2585.7 used,    608.8 buff/cache
                  MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7538.3 avail Mem
                  *** FILESYSTEM ***
                  /var:
                  1.3G    /var/
                  787M    /var/log
                  355M    /var/cache
                  849M    /opt/iobroker/iobroker-data/
                  43M     /opt/iobroker/iobroker-data/objects.jsonl
                  38M     /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyUSB0
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 818)
                  admin:          7.6.17
                  javascript:     8.9.2
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        30300
                  States:         27699
                  Hit:1 http://security.debian.org bookworm-security InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Pending Updates: 0
                  2025-08-10 14:22:06.854  - info: chromecast.0 (379) Chromecast - Connected player
                  2025-08-10 14:22:06.855  - info: chromecast.0 (379) Chromecast - Player joint
                  2025-08-10 14:22:06.867  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
                  2025-08-10 14:24:06.467  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
                  2025-08-10 14:24:06.467  - info: chromecast.0 (379) Chromecast - client disconnected
                  2025-08-10 14:24:06.468  - info: chromecast.0 (379) Chromecast - Detached player
                  2025-08-10 14:24:06.542  - info: chromecast.0 (379) Chromecast - Connected client
                  2025-08-10 14:24:06.647  - info: chromecast.0 (379) Chromecast - Try to join player
                  2025-08-10 14:24:06.648  - info: chromecast.0 (379) Chromecast - Connected player
                  2025-08-10 14:24:06.648  - info: chromecast.0 (379) Chromecast - Player joint
                  2025-08-10 14:24:06.661  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
                  2025-08-10 14:24:07.138  - info: nuki.0 (1032) Bridge Info requested: http://192.168.178.43:8080/info?ts=2025-08-10T12:24:06Z&rnr=51748&hash=bd97abd6fc36232b0a8173c26cd18fdd2db40f1303dc72fba2a933ce7401abff
                  2025-08-10 14:24:10.147  - info: nuki.0 (1032) Lock list requested: http://192.168.178.43:8080/list?ts=2025-08-10T12:24:09Z&rnr=57691&hash=a8b330db2e5ae9097aa7c08d37e4380d8110d1812ccf8ec2263eeddb8a91f7c4
                  2025-08-10 14:26:09.565  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
                  2025-08-10 14:26:09.566  - info: chromecast.0 (379) Chromecast - client disconnected
                  2025-08-10 14:26:09.567  - info: chromecast.0 (379) Chromecast - Detached player
                  2025-08-10 14:26:09.881  - info: chromecast.0 (379) Chromecast - Connected client
                  2025-08-10 14:26:10.262  - info: chromecast.0 (379) Chromecast - Try to join player
                  2025-08-10 14:26:10.264  - info: chromecast.0 (379) Chromecast - Connected player
                  2025-08-10 14:26:10.264  - info: chromecast.0 (379) Chromecast - Player joint
                  2025-08-10 14:26:10.665  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
                  • K Krys
                    ```bash
                    Script v.2025-03-08
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 4
                                     RTC time: n/a
                              RTC in local TZ: no
                    krystian
                    HOME=/home/krystian
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           1.1G          0B        1.1G
                             2583 M used memory
                             6931 M free memory
                                0 M buffer memory
                              608 M swap cache
                             1024 M total swap
                                0 M used swap
                             1024 M free swap
                    *** FILESYSTEM ***
                    /var:
                    1.3G    /var/
                    787M    /var/log
                    355M    /var/cache
                    USB-Devices by-id:
                    HINT:
                    /dev/ttyUSB0
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.6.17
                    javascript:     8.9.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        30300
                    States:         27699
                    Pending Updates: 0
                    warum sind alle diese Instanzen über github installiert?
                    da gibt's bestimmt einige in offiziellen Repos.
                    sourceanalytix auf jeden Fall
                      Krys
                      Sollte nun i.O. sein.
                      ```bash
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                        Virtualization: lxc
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       19:35:34 up 43 min,  2 users,  load average: 1.13, 0.94, 0.97
                      CPU threads: 4
                                     Local time: Sun 2025-08-10 19:35:34 CEST
                                 Universal time: Sun 2025-08-10 17:35:34 UTC
                                       RTC time: n/a
                                RTC in local TZ: no
                      krystian
                      HOME=/home/krystian
                      iobroker
                      HOME=/home/iobroker
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:
                      *** MEMORY ***
                      Mem:             10G        2.8G        7.3G        106K        507M        7.8G
                      Swap:           1.1G          0B        1.1G
                               2709 M used memory
                               2728 M active memory
                                319 M inactive memory
                               6931 M free memory
                                  0 M buffer memory
                                483 M swap cache
                               1024 M total swap
                                  0 M used swap
                               1024 M free swap
                      top - 19:35:35 up 43 min,  2 users,  load average: 1.13, 0.94, 0.97
                      %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :  10124.0 total,   6928.9 free,   2711.3 used,    483.9 buff/cache
                      MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7412.7 avail Mem
                      *** FILESYSTEM ***
                      /var:
                      1.3G    /var/
                      779M    /var/log
                      355M    /var/cache
                      825M    /opt/iobroker/iobroker-data/
                      455M    /opt/iobroker/iobroker-data/files
                      35M     /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      HINT:
                      /dev/ttyUSB0
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 2631)
                      admin:          7.6.17
                      javascript:     8.9.2
                      nodejs modules from github:     2
                      Adapter State
                      + instance is alive
                      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
                      Objects and States
                      Objects:        30300
                      States:         27641
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       178894137  125/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       178894132  125/iobroker.js-con
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          178899939  816/master
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          178892112  1/init
                      tcp        0      0 127.0.0.1:35471         0.0.0.0:*               LISTEN      1001       178906235  656/io.yahka.0
                      tcp        0      0 0.0.0.0:35257           0.0.0.0:*               LISTEN      1001       178900327  656/io.yahka.0
                      tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       178898901  551/io.nuki.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          178891524  1/init
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          178892114  1/init
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          178899940  816/master
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       178905344  989/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       178894361  155/io.admin.0
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       178902337  641/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       178902338  641/io.tuya.0
                      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       178894660  273/io.broadlink2.0
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          178892113  1/init
                      udp        0      0 0.0.0.0:42485           0.0.0.0:*                           1001       178894667  273/io.broadlink2.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       178905612  970/io.upnp.0
                      udp        0      0 0.0.0.0:35019           0.0.0.0:*                           1001       178905269  970/io.upnp.0
                      udp        0      0 0.0.0.0:45068           0.0.0.0:*                           1001       178894782  273/io.broadlink2.0
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       178899133  536/io.mihome-vacuu
                      udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       178901842  865/io.mihome-vacuu
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178900324  656/io.yahka.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178894696  296/io.chromecast.0
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       178899569  611/io.shelly.0
                      udp6       0      0 :::111                  :::*                                0          178892115  1/init
                      2025-08-10 19:34:00.886  - info: host.ioBroker iobroker upload [5] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/readmeDocu/stateStartValues.png readmeDocu/stateStartValues.png image/png
                      2025-08-10 19:34:00.903  - info: host.ioBroker instance system.adapter.sourceanalytix.0 in version "0.4.14" started with pid 1411
                      2025-08-10 19:34:01.061  - info: host.ioBroker iobroker upload [4] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_details.png settings_details.png image/png
                      2025-08-10 19:34:01.227  - info: host.ioBroker iobroker upload [3] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_open.png settings_open.png image/png
                      2025-08-10 19:34:01.236  - info: host.ioBroker iobroker upload [2] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/sourceanalytix.png sourceanalytix.png image/png
                      2025-08-10 19:34:01.242  - info: host.ioBroker iobroker upload [1] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/style.css style.css text/css
                      2025-08-10 19:34:01.248  - info: host.ioBroker iobroker upload [0] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/words.js words.js application/javascript
                      2025-08-10 19:34:01.256  - info: host.ioBroker iobroker Updating objects from io-package.json for adapter "sourceanalytix" with version "0.4.14"
                      2025-08-10 19:34:02.418  - info: host.ioBroker iobroker exit 0
                      2025-08-10 19:35:22.864  - warn: chromecast.0 (296) Chromecast - Client error: Error: Device timeout
                          at fn.ontimeout (/opt/iobroker/node_modules/castv2-client/lib/senders/platform.js:56:26)
                          at Object.onceWrapper (node:events:638:28)
                          at fn.emit (node:events:524:28)
                          at fn.emit (node:domain:489:12)
                          at Timeout.ontimeout [as _onTimeout] (/opt/iobroker/node_modules/castv2-client/lib/controllers/heartbeat.js:44:10)
                          at listOnTimeout (node:internal/timers:581:17)
                          at processTimers (node:internal/timers:519:7)
                      2025-08-10 19:35:22.864  - info: chromecast.0 (296) Chromecast - client disconnected
                      2025-08-10 19:35:22.865  - info: chromecast.0 (296) Chromecast - Detached player
                      2025-08-10 19:35:22.929  - info: chromecast.0 (296) Chromecast - Connected client
                      2025-08-10 19:35:22.968  - info: chromecast.0 (296) Chromecast - Try to join player
                      2025-08-10 19:35:22.969  - info: chromecast.0 (296) Chromecast - Connected player
                      2025-08-10 19:35:22.970  - info: chromecast.0 (296) Chromecast - Player joint
                      2025-08-10 19:35:23.023  - info: chromecast.0 (296) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fd29bca0-aaaa-4b99-b18d-1df589d32b9a","statusText":"","transportId":"fd29bca0-aaaa-4b99-b18d-1df589d32b9a","universalAppId":"E8C28D3C"}
                      • K Krys
                        ```bash
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 4
                                         RTC time: n/a
                                  RTC in local TZ: no
                        krystian
                        HOME=/home/krystian
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:
                        *** MEMORY ***
                        Swap:           1.1G          0B        1.1G
                                 2709 M used memory
                                 6931 M free memory
                                    0 M buffer memory
                                  483 M swap cache
                                 1024 M total swap
                                    0 M used swap
                                 1024 M free swap
                        *** FILESYSTEM ***
                        /var:
                        1.3G    /var/
                        779M    /var/log
                        355M    /var/cache
                        USB-Devices by-id:
                        HINT:
                        /dev/ttyUSB0
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.6.17
                        javascript:     8.9.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        30300
                        States:         27641
                        Pending Updates: 0
                        @krys
                        Ich vermute da immer noch ein falsch eingestelltes Netzwerk.
                        systemctl status systemd-networkd-wait-online.service
                        sagt?
                          @krys
                          sagt?
                          Krys
                          @thomas-braun said in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
                          krystian@ioBroker:~$ systemctl status systemd-networkd-wait-online.service
                          x systemd-networkd-wait-online.service - Wait for Network to be Configured
                               Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; preset: disabled)
                               Active: failed (Result: exit-code) since Sun 2025-08-10 18:53:51 CEST; 1h 17min ago
                                 Docs: man:systemd-networkd-wait-online.service(8)
                              Process: 105 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=1/FAILURE)
                             Main PID: 105 (code=exited, status=1/FAILURE)
                                  CPU: 12ms
                          • K Krys
                                    CPU: 12ms
                            @krys
                            Auf meiner Kiste schaut der so aus:
                            echad@chet:~ $ systemctl status systemd-networkd-wait-online.service
                            ○ systemd-networkd-wait-online.service - Wait for Network to be Configured
                                 Loaded: loaded (/usr/lib/systemd/system/systemd-networkd-wait-online.service; disabled; preset: enabled)
                                 Active: inactive (dead)
                            echad@chet:~ $
                            Aber zu LXCs und Netzwerk kann ich nichts sagen.
                            R 1 Antwort Letzte Antwort
                              @krys
                              echad@chet:~ $
                              Ralf 2
                              Das sieht bei einem previligiertem LXC genauso aus wie bei dir:
                              ralf@Home-Server:~$ systemctl status systemd-networkd-wait-online.service
                              * systemd-networkd-wait-online.service - Wait for Network to be Configured
                                   Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; disabled; preset: disabled)
                              ralf@Home-Server:~$
                              Gruß Ralf
                              • R Ralf 2
                                ralf@Home-Server:~$
                                TT-Tom
                                @ralf-2
                                bei einem unpreviligierten auch so
                                tom@iobDev:~$ systemctl status systemd-networkd-wait-online.service
                                Gruß Tom
                                Public Transport
                                NSPanel Adapter Wiki
                                  Krys
                                  So Leute, nach langem rumgefummel folgendes Ergebnis.
                                  was kurios war, mein iobroker hatte plötzlich zwei IP-Adressen, was offensichtlich auch zu zusätzlichen Problemen führte.
                                  Könnt ihr nochmal mit eurem geschulten Auge drüber schauen, ob euch noch was auffällt?
                                  ```bash
                                  Script v.2025-08-09
                                  *** BASE SYSTEM ***
                                    Virtualization: lxc
                                            Kernel: Linux 6.8.12-13-pve
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                   10:32:36 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
                                  CPU threads: 4
                                                 Local time: Tue 2025-08-12 10:32:37 CEST
                                             Universal time: Tue 2025-08-12 08:32:37 UTC
                                                   RTC time: n/a
                                            RTC in local TZ: no
                                  krystian
                                  HOME=/home/krystian
                                  iobroker
                                  HOME=/home/iobroker
                                  Display-Manager:
                                  Desktop:
                                  Session:
                                  *** MEMORY ***
                                  Mem:             10G        2.6G        7.4G        114K        570M        8.0G
                                  Swap:           1.1G          0B        1.1G
                                  Total:           11G        2.6G        8.5G
                                           2478 M used memory
                                           2438 M active memory
                                            410 M inactive memory
                                           7101 M free memory
                                              0 M buffer memory
                                            544 M swap cache
                                           1024 M total swap
                                              0 M used swap
                                           1024 M free swap
                                  top - 10:32:37 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
                                  %Cpu(s): 25.0 us,  0.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :  10124.0 total,   7100.1 free,   2479.8 used,    544.3 buff/cache
                                  MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7644.2 avail Mem
                                  2 loaded units listed.
                                  *** FILESYSTEM ***
                                  /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  41% /
                                  tmpfs                            tmpfs     3.1G  104K  3.1G   1% /run
                                  /var:
                                  1.3G    /var/
                                  781M    /var/log
                                  355M    /var/cache
                                  251M    /opt/iobroker/backups/
                                  660M    /opt/iobroker/iobroker-data/
                                  268M    /opt/iobroker/iobroker-data/files
                                  148M    /opt/iobroker/iobroker-data/backup-objects
                                  48M     /opt/iobroker/iobroker-data/files/iot.admin
                                  45M     /opt/iobroker/iobroker-data/states.jsonl
                                  33M     /opt/iobroker/iobroker-data/objects.jsonl
                                  8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                                  USB-Devices by-id:
                                  HINT:
                                  /dev/ttyUSB0
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 428)
                                  admin:          7.6.17
                                  javascript:     8.9.2
                                  nodejs modules from github:     4
                                  +-- iobroker.alexa2@3.27.3 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#1f026d3554d62693f1c785027d1e326cf6461998)
                                  +-- iobroker.cloudless-homeconnect@1.6.2 (git+ssh://git@github.com/eifel-tech/ioBroker.cloudless-homeconnect.git#2e5ef03576947db4490f99fe5b032ef5d0e216fe)
                                  Adapter State
                                  + system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : ioBroker                                 -  enabled
                                  + instance is alive
                                  Objects and States
                                  Objects:        29378
                                  States:         27132
                                  Pending Updates: 0
                                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          343600     295/master
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          341984     1/init
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       344427     126/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       344422     126/iobroker.js-con
                                  tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       349074     700/io.nuki.0
                                  tcp        0      0 127.0.0.1:45729         0.0.0.0:*               LISTEN      1001       353213     813/io.yahka.0
                                  tcp        0      0 0.0.0.0:37503           0.0.0.0:*               LISTEN      1001       352501     813/io.yahka.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          344254     1/init
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          341986     1/init
                                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          343601     295/master
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       346474     306/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       356415     992/io.web.0
                                  udp        0      0 0.0.0.0:36423           0.0.0.0:*                           1001       345845     428/io.broadlink2.0
                                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       348828     681/io.mihome-vacuu
                                  udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       353940     874/io.mihome-vacuu
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       352498     813/io.yahka.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       348185     443/io.chromecast.0
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       349155     760/io.shelly.0
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       353336     790/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       353337     790/io.tuya.0
                                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       346813     428/io.broadlink2.0
                                  udp        0      0 0.0.0.0:56183           0.0.0.0:*                           1001       355236     969/io.upnp.0
                                  udp        0      0 192.168.178.100:68      0.0.0.0:*                           103        345195     73/systemd-networkd
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          341985     1/init
                                  udp        0      0 0.0.0.0:41265           0.0.0.0:*                           1001       347378     428/io.broadlink2.0
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       357628     969/io.upnp.0
                                  udp6       0      0 :::111                  :::*                                0          341987     1/init
                                  udp6       0      0 fe80::be24:11ff:fe5:546 :::*                                103        345342     73/systemd-networkd
                                       Active: active (exited) since Tue 2025-08-12 10:25:35 CEST; 8min ago
                                      Process: 108 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=0/SUCCESS)
                                     Main PID: 108 (code=exited, status=0/SUCCESS)
                                          CPU: 13ms
                                  • K Krys
                                    ```bash
                                    Script v.2025-08-09
                                    *** BASE SYSTEM ***
                                      Virtualization: lxc
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                                     RTC time: n/a
                                              RTC in local TZ: no
                                    krystian
                                    HOME=/home/krystian
                                    iobroker
                                    HOME=/home/iobroker
                                    Display-Manager:
                                    Desktop:
                                    Session:
                                    *** MEMORY ***
                                    Swap:           1.1G          0B        1.1G
                                             2478 M used memory
                                             7101 M free memory
                                                0 M buffer memory
                                              544 M swap cache
                                             1024 M total swap
                                                0 M used swap
                                             1024 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.3G    /var/
                                    781M    /var/log
                                    355M    /var/cache
                                    USB-Devices by-id:
                                    HINT:
                                    /dev/ttyUSB0
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.6.17
                                    javascript:     8.9.2
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        29378
                                    States:         27132
                                    Pending Updates: 0
                                            CPU: 13ms
                                    @krys
                                    Ich sag ja, da klemmt beim Netzwerk was...
                                    Die üblichen Nicklichkeiten würde ich noch angehen.
                                    Bei Zigbee z. B. den Geräte Link 'by-id' verwenden usw.
                                    Ich würde auch jetzt auf nodejs@22 gehen:
                                    iob nodejs-update
                                    Und im Herbst würde ich das ganze Ding auf Debian 13 'Trixie' haben.
                                      Krys
                                      nodejs 22 ist erledigt.
                                      beim Zigbee-Adapter, wenn ich vom Anschlussnamen
                                      eintrage, habe ich ne Bootschleife und der Adapter wird nicht grün.
                                      • K Krys
                                        @krys
                                        Dann stell es wieder um. Liegt vermutlich am LXC. Die Dinger ticken tw. etwas anders als ein 'richtiges' System.
                                          @krys
                                          Krys
                                          @thomas-braun Ja, da scheint irgendwas mit den Rechten nicht zu passen. Kriege es aber anders auch nicht durchgeschleift.
