  4. Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten
    6.6k
28 Beiträge 5 Kommentatoren 2.6k Aufrufe 5 Beobachtet
    @krys
    Gib mal die vollständige Ausgabe von
    iob diag
    zum Besten.
    Krys
    bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-11-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     13:03:39 up 22:06,  2 users,  load average: 0.26, 0.45, 0.60
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
    y               Local time: Sun 2025-08-10 13:03:39 CEST
               Universal time: Sun 2025-08-10 11:03:39 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    s
    *** Users and Groups ***
    User that called 'iob diag':
    krystian
    HOME=/home/krystian
    GROUPS=krystian dialout sudo iobroker
    iobroker
    [sudo] password for krystian:
    Sorry, try again.
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:             10G        3.0G        6.8G         94K        809M        7.6G
    Swap:           1.1G         20K        1.1G
    Total:           11G        3.0G        7.8G
    Active iob-Instances:   17
            10124 M total memory
             2904 M used memory
              862 M active memory
             2633 M inactive memory
             6446 M free memory
                0 M buffer memory
              772 M swap cache
             1024 M total swap
                0 M used swap
             1023 M free swap
    top - 13:03:48 up 22:06,  2 users,  load average: 0.22, 0.43, 0.59
    Tasks:  65 total,   4 running,  61 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  10124.0 total,   6445.0 free,   2906.7 used,    772.4 buff/cache
    MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7217.3 avail Mem
    *** FAILED SERVICES ***
      UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
    * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
    * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
    3 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--1 ext4       30G   13G   16G  44% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  7.7G     0  7.7G   0% /dev/tty
    tmpfs                            tmpfs     7.7G     0  7.7G   0% /dev/shm
    tmpfs                            tmpfs     3.1G  100K  3.1G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--1 ext4   rw,relatime,stripe=16
    /var:
    1.3G    /var/
    779M    /var/log
    774M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
    355M    /var/cache
    Archived and active journals take up 190.7M in the file system.
    /opt/iobroker/backups:
    237M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    829M    /opt/iobroker/iobroker-data/
    453M    /opt/iobroker/iobroker-data/files
    186M    /opt/iobroker/iobroker-data/files/vis-2
    167M    /opt/iobroker/iobroker-data/history-data
    149M    /opt/iobroker/iobroker-data/backup-objects
    46M     /opt/iobroker/iobroker-data/objects.jsonl
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.4
    /usr/bin/node           v20.19.4
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 20.19.4-1nodesource1
      Candidate: 20.19.4-1nodesource1
      Version table:
     *** 20.19.4-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 79603)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     10
    +-- iobroker.ankersolix2@2.2.0 (git+ssh://git@github.com/ronny130286/ioBroker.ankersolix2.git#feb2ace0252fbd8cf30684f2f962d52d30b80d03)
    +-- iobroker.devices@1.1.5 (git+ssh://git@github.com/ioBroker/ioBroker.devices.git#9c60a66913c1aee57658cf845db655f13c144ebe)
    +-- iobroker.geofency@1.2.4 (git+ssh://git@github.com/ioBroker/ioBroker.geofency.git#cf9ccab32a4c8896a90f645e41c3a665ac0d6b0f)
    +-- iobroker.google-sharedlocations@2.2.1 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#0db73d57d00aa5dff22ff22e853f1231ce141dc1)
    +-- iobroker.homeconnect@1.4.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.homeconnect.git#1c0ea50d8814e21bfa238db6bfcd5300846ffe9d)
    +-- iobroker.sayit@5.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.sayit.git#d15c2954b01673c5ac3697c3747bd904f99ad3e2)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
    +-- iobroker.yahka@1.1.5 (git+ssh://git@github.com/jensweigele/ioBroker.yahka.git#33608f7a2cc3ee5397a08980c5e03384be7dda27)
    +-- iobroker.zigbee@3.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#dc37fdcbd64b52258cf6b44a6b703954796a844b)
    `-- nodejieba@3.4.3 (git+ssh://git@github.com/yanyiwu/nodejieba.git#7b93462d7e8eff6f2939202a0abbfcbf64c9ec01)
    Adapter State
      system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : ioBroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
      system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
    + system.adapter.geofency.0               : geofency              : ioBroker                                 -  enabled, port: 7999, bind: 0.0.0.0
    + system.adapter.google-sharedlocations.0 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.1 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.2 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.google-sharedlocations.3 : google-sharedlocations: ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
    + system.adapter.hmip.0                   : hmip                  : ioBroker                                 -  enabled
    + system.adapter.hmip.1                   : hmip                  : ioBroker                                 -  enabled
      system.adapter.homeconnect.1            : homeconnect           : ioBroker                                 -  enabled
      system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
      system.adapter.nuki.0                   : nuki                  : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      system.adapter.openweathermap.1         : openweathermap        : ioBroker                                 -  enabled
      system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
      system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
      system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
      system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
      system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ 1       │ 'latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "adguard"      : 1.0.1    , installed 1.0.1
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "ankersolix2"  : 2.2.0    , installed 2.2.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "hue"          : 3.16.1   , installed 3.16.1
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "notification-manager": 1.2.1, installed 1.2.1
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "yahka"        : 1.0.3    , installed 1.1.5
    Adapter    "zigbee"       : 2.0.5    , installed 3.0.3
    Objects and States
    Objects:        30300
    States:         27642
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
    Reading package lists...
    Pending Updates: 7
    *** Listening Ports ***
    tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       174727430  659/io.nuki.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       174716667  125/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       174718586  125/iobroker.js-con
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          174726954  924/master
    tcp        0      0 127.0.0.1:42889         0.0.0.0:*               LISTEN      1001       176332756  764/io.yahka.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          174717495  1/init
    tcp        0      0 0.0.0.0:44189           0.0.0.0:*               LISTEN      1001       174727733  764/io.yahka.0
    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       174777843  1068/io.upnp.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       174719641  155/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       174731478  1074/io.web.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          174726955  924/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          174719463  1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          174717497  1/init
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       174728246  749/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       174728247  749/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       174721314  277/io.broadlink2.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          174717496  1/init
    udp        0      0 0.0.0.0:58271           0.0.0.0:*                           1001       174730450  1068/io.upnp.0
    udp        0      0 0.0.0.0:58680           0.0.0.0:*                           1001       177658529  277/io.broadlink2.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       174730719  1068/io.upnp.0
    udp        0      0 0.0.0.0:51166           0.0.0.0:*                           1001       174721317  277/io.broadlink2.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       174725302  637/io.mihome-vacuu
    udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       174728146  956/io.mihome-vacuu
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       174727730  764/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       174720456  296/io.chromecast.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       174725560  719/io.shelly.0
    udp6       0      0 :::111                  :::*                                0          174717498  1/init
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) Device Ende
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Wäschetrockner"]: Auswertung gestartet
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Wäschetrockner"]: WERTE für START: 0W; Schwelle Start: 15W; gestartet: false
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Wäschetrockner"]: value status: end
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Spülmaschine"]: Auswertung gestartet
    2025-08-10 13:04:20.310  - debug: device-reminder.0 (1140) ["Spülmaschine"]: WERTE für START: 0W; Schwelle Start: 1W; gestartet: false
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Spülmaschine"]: value status: end
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) Device Ende
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit"]: Auswertung gestartet
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit"]: WERTE für START: 0W; Schwelle Start: 1W; gestartet: false
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit"]: value status: end
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit Nacht"]: Auswertung gestartet
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit Nacht"]: WERTE für START: 0W; Schwelle Start: 1W; gestartet: false
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit Nacht"]: value status: end
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Waschmaschine"]: Auswertung beendet
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Wäschetrockner"]: Auswertung beendet
    2025-08-10 13:04:20.311  - debug: device-reminder.0 (1140) ["Spülmaschine"]: Auswertung beendet
    2025-08-10 13:04:20.312  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit"]: Auswertung beendet
    2025-08-10 13:04:20.312  - debug: device-reminder.0 (1140) ["Maja Schlafenszeit Nacht"]: Auswertung beendet
    2025-08-10 13:04:21.028  - debug: lgtv.0 (949) TV is off
    2025-08-10 13:04:27.154  - debug: lgtv.0 (949) Connecting to WebOS TV: wss://192.168.178.30:3001
    2025-08-10 13:04:29.090  - debug: lgtv.0 (949) TV is off
    • K Krys
      bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      s
      krystian
      HOME=/home/krystian
      iobroker
      Sorry, try again.
      HOME=/home/iobroker
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           1.1G         20K        1.1G
               2904 M used memory
                862 M active memory
               6446 M free memory
                  0 M buffer memory
                772 M swap cache
               1024 M total swap
                  0 M used swap
               1023 M free swap
      *** FILESYSTEM ***
      /var:
      1.3G    /var/
      779M    /var/log
      355M    /var/cache
      USB-Devices by-id:
      HINT:
      /dev/ttyUSB0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        30300
      States:         27642
      Pending Updates: 7
      @krys sagte in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
      • systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
      Ich vermute, da klemmt was mit deinem Netzwerk.
      Pending Updates: 7
      Hau die schon mal drauf...
      • K Krys
        bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
                         RTC time: n/a
                  RTC in local TZ: no
        s
        krystian
        HOME=/home/krystian
        iobroker
        Sorry, try again.
        HOME=/home/iobroker
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           1.1G         20K        1.1G
                 2904 M used memory
                  862 M active memory
                 6446 M free memory
                    0 M buffer memory
                  772 M swap cache
                 1024 M total swap
                    0 M used swap
                 1023 M free swap
        *** FILESYSTEM ***
        /var:
        1.3G    /var/
        779M    /var/log
        355M    /var/cache
        USB-Devices by-id:
        HINT:
        /dev/ttyUSB0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.17
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        30300
        States:         27642
        Pending Updates: 7
        13 Logeinträge in einer Millisekunde sind aber auch nicht gerade ressourcenschonend
          @homoran sagte in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
          Stimmt, hab ich gar nicht gesehen...
          @Krys Stell das Log nicht auf DEBUG ein.
            Krys
            @thomas-braun Updates habe ich erledigt
              Krys
              schrieb am zuletzt editiert von Krys
              @thomas-braun von debug umgestellt habe ich ebenfalls nun.
              • K Krys
                @krys
                Dann starte den Container jetzt mal durch und zeig dann nochmal
                iob diag
                  @krys
                  iob diag
                  Krys
                  ```bash
                  Script v.2025-03-08
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   14:16:14 up 3 min,  2 users,  load average: 3.45, 2.21, 1.16
                  CPU threads: 4
                                 Local time: Sun 2025-08-10 14:16:15 CEST
                             Universal time: Sun 2025-08-10 12:16:15 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  krystian
                  HOME=/home/krystian
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:             10G        2.8G        7.2G        110K        634M        7.8G
                  Swap:           1.1G          0B        1.1G
                  Total:           11G        2.8G        8.3G
                  Active iob-Instances:   41
                           2639 M used memory
                           2589 M active memory
                            474 M inactive memory
                           6879 M free memory
                              0 M buffer memory
                            604 M swap cache
                           1024 M total swap
                              0 M used swap
                           1024 M free swap
                  top - 14:16:15 up 3 min,  2 users,  load average: 3.45, 2.21, 1.16
                  Tasks:  65 total,   1 running,  64 sleeping,   0 stopped,   0 zombie
                  MiB Mem :  10124.0 total,   6878.5 free,   2640.9 used,    604.7 buff/cache
                  MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7483.1 avail Mem
                  *** FILESYSTEM ***
                  /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  43% /
                  /var:
                  1.3G    /var/
                  787M    /var/log
                  782M    /var/log/journal/e3a5ffae41b344e194b7be74a39a2845
                  355M    /var/cache
                  Archived and active journals take up 182.7M in the file system.
                  845M    /opt/iobroker/iobroker-data/
                  42M     /opt/iobroker/iobroker-data/objects.jsonl
                  36M     /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyUSB0
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 233)
                  admin:          7.6.17
                  javascript:     8.9.2
                  Adapter State
                  + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
                  + system.adapter.ankersolix2.0            : ankersolix2           : ioBroker                                 -  enabled
                  + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                  + system.adapter.homeconnect.1            : homeconnect           : ioBroker                                 -  enabled
                  + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
                  + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                  + system.adapter.lgtv.0                   : lgtv                  : ioBroker                                 -  enabled
                  + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                  + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                  + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
                  + system.adapter.nuki.0                   : nuki                  : ioBroker                                 -  enabled
                  + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
                  + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                  + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                  + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
                  + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
                  + instance is alive
                  Objects and States
                  Objects:        30300
                  States:         27699
                  Pending Updates: 0
                  tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       178002187  1032/io.nuki.0
                  tcp        0      0 127.0.0.1:37867         0.0.0.0:*               LISTEN      1001       178004354  1803/io.yahka.0
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          177990009  1/init
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          178004999  1963/master
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       177989093  127/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       177988369  127/iobroker.js-con
                  tcp        0      0 0.0.0.0:36969           0.0.0.0:*               LISTEN      1001       178002394  1803/io.yahka.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          177990917  1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          177990011  1/init
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       178006856  2166/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       177990413  155/io.admin.0
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          178005000  1963/master
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       178003747  1788/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       178003748  1788/io.tuya.0
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       177991515  353/io.broadlink2.0
                  udp        0      0 0.0.0.0:56427           0.0.0.0:*                           1001       178006835  2159/io.upnp.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          177990010  1/init
                  udp        0      0 0.0.0.0:42078           0.0.0.0:*                           1001       177993846  353/io.broadlink2.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       178007757  2159/io.upnp.0
                  udp        0      0 0.0.0.0:53341           0.0.0.0:*                           1001       177993161  353/io.broadlink2.0
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       177997732  1021/io.mihome-vacu
                  udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       178005438  1995/io.mihome-vacu
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178002391  1803/io.yahka.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       177991544  379/io.chromecast.0
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       178004066  1750/io.shelly.0
                  udp6       0      0 :::111                  :::*                                0          177990012  1/init
                  2025-08-10 14:16:01.635  - debug: lgtv.0 (1982) TV is off
                  2025-08-10 14:16:02.913  - info: alexa2.0 (394) Initialization Done ...
                  2025-08-10 14:16:03.470  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
                      at TLSWrap.onStreamRead (node:internal/stream_base_commons:218:20)
                  2025-08-10 14:16:03.471  - info: chromecast.0 (379) Chromecast - client disconnected
                  2025-08-10 14:16:03.472  - info: chromecast.0 (379) Chromecast - Detached player
                  2025-08-10 14:16:03.645  - info: chromecast.0 (379) Chromecast - Connected client
                  2025-08-10 14:16:03.665  - info: chromecast.0 (379) Chromecast - Try to join player
                  2025-08-10 14:16:03.666  - info: chromecast.0 (379) Chromecast - Connected player
                  2025-08-10 14:16:03.666  - info: chromecast.0 (379) Chromecast - Player joint
                  2025-08-10 14:16:03.721  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
                  2025-08-10 14:16:04.170  - info: tuya.0 (1788) bfc89472838729ae991dfh: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.34:6668
                  2025-08-10 14:16:07.763  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
                  2025-08-10 14:16:09.700  - debug: lgtv.0 (1982) TV is off
                  2025-08-10 14:16:15.827  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
                  2025-08-10 14:16:17.764  - debug: lgtv.0 (1982) TV is off
                  2025-08-10 14:16:23.890  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
                  2025-08-10 14:16:25.828  - debug: lgtv.0 (1982) TV is off
                  2025-08-10 14:16:31.954  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
                  2025-08-10 14:16:33.892  - debug: lgtv.0 (1982) TV is off
                  2025-08-10 14:16:40.019  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
                  2025-08-10 14:16:41.955  - debug: lgtv.0 (1982) TV is off
                  2025-08-10 14:16:48.081  - debug: lgtv.0 (1982) Connecting to WebOS TV: wss://192.168.178.30:3001
                  2025-08-10 14:16:50.020  - debug: lgtv.0 (1982) TV is off
                  • K Krys
                    ```bash
                    Script v.2025-03-08
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 4
                                     RTC time: n/a
                              RTC in local TZ: no
                    krystian
                    HOME=/home/krystian
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           1.1G          0B        1.1G
                             2639 M used memory
                             6879 M free memory
                                0 M buffer memory
                              604 M swap cache
                             1024 M total swap
                                0 M used swap
                             1024 M free swap
                    *** FILESYSTEM ***
                    /var:
                    1.3G    /var/
                    787M    /var/log
                    355M    /var/cache
                    USB-Devices by-id:
                    HINT:
                    /dev/ttyUSB0
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.6.17
                    javascript:     8.9.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        30300
                    States:         27699
                    Pending Updates: 0
                    @krys
                    Da läuft doch immer noch Zeuch auf Debug. Der lgtv.0 z.B.
                      @krys
                      Krys
                      @thomas-braun Habs im Nachgang auch gemerkt und direkt geändert.
                      ```bash
                      Script v.2025-03-08
                      *** BASE SYSTEM ***
                        Virtualization: lxc
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       14:26:01 up 13 min,  2 users,  load average: 0.57, 0.74, 0.88
                      CPU threads: 4
                                     Local time: Sun 2025-08-10 14:26:01 CEST
                                 Universal time: Sun 2025-08-10 12:26:01 UTC
                                       RTC time: n/a
                                RTC in local TZ: no
                      krystian
                      HOME=/home/krystian
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:
                      *** MEMORY ***
                      Mem:             10G        2.7G        7.3G        110K        638M        7.9G
                      Swap:           1.1G          0B        1.1G
                      Total:           11G        2.7G        8.3G
                               2583 M used memory
                               2534 M active memory
                                478 M inactive memory
                               6931 M free memory
                                  0 M buffer memory
                                608 M swap cache
                               1024 M total swap
                                  0 M used swap
                               1024 M free swap
                      top - 14:26:01 up 13 min,  2 users,  load average: 0.57, 0.74, 0.88
                      MiB Mem :  10124.0 total,   6929.6 free,   2585.7 used,    608.8 buff/cache
                      MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7538.3 avail Mem
                      *** FILESYSTEM ***
                      /var:
                      1.3G    /var/
                      787M    /var/log
                      355M    /var/cache
                      849M    /opt/iobroker/iobroker-data/
                      43M     /opt/iobroker/iobroker-data/objects.jsonl
                      38M     /opt/iobroker/iobroker-data/states.jsonl
                      USB-Devices by-id:
                      HINT:
                      /dev/ttyUSB0
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 818)
                      admin:          7.6.17
                      javascript:     8.9.2
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        30300
                      States:         27699
                      Hit:1 http://security.debian.org bookworm-security InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Pending Updates: 0
                      2025-08-10 14:22:06.854  - info: chromecast.0 (379) Chromecast - Connected player
                      2025-08-10 14:22:06.855  - info: chromecast.0 (379) Chromecast - Player joint
                      2025-08-10 14:22:06.867  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
                      2025-08-10 14:24:06.467  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
                      2025-08-10 14:24:06.467  - info: chromecast.0 (379) Chromecast - client disconnected
                      2025-08-10 14:24:06.468  - info: chromecast.0 (379) Chromecast - Detached player
                      2025-08-10 14:24:06.542  - info: chromecast.0 (379) Chromecast - Connected client
                      2025-08-10 14:24:06.647  - info: chromecast.0 (379) Chromecast - Try to join player
                      2025-08-10 14:24:06.648  - info: chromecast.0 (379) Chromecast - Connected player
                      2025-08-10 14:24:06.648  - info: chromecast.0 (379) Chromecast - Player joint
                      2025-08-10 14:24:06.661  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
                      2025-08-10 14:24:07.138  - info: nuki.0 (1032) Bridge Info requested: http://192.168.178.43:8080/info?ts=2025-08-10T12:24:06Z&rnr=51748&hash=bd97abd6fc36232b0a8173c26cd18fdd2db40f1303dc72fba2a933ce7401abff
                      2025-08-10 14:24:10.147  - info: nuki.0 (1032) Lock list requested: http://192.168.178.43:8080/list?ts=2025-08-10T12:24:09Z&rnr=57691&hash=a8b330db2e5ae9097aa7c08d37e4380d8110d1812ccf8ec2263eeddb8a91f7c4
                      2025-08-10 14:26:09.565  - warn: chromecast.0 (379) Chromecast - Client error: Error: read ECONNRESET
                      2025-08-10 14:26:09.566  - info: chromecast.0 (379) Chromecast - client disconnected
                      2025-08-10 14:26:09.567  - info: chromecast.0 (379) Chromecast - Detached player
                      2025-08-10 14:26:09.881  - info: chromecast.0 (379) Chromecast - Connected client
                      2025-08-10 14:26:10.262  - info: chromecast.0 (379) Chromecast - Try to join player
                      2025-08-10 14:26:10.264  - info: chromecast.0 (379) Chromecast - Connected player
                      2025-08-10 14:26:10.264  - info: chromecast.0 (379) Chromecast - Player joint
                      2025-08-10 14:26:10.665  - info: chromecast.0 (379) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fba66ebb-b93a-4fb3-914f-964924ada70a","statusText":"","transportId":"fba66ebb-b93a-4fb3-914f-964924ada70a","universalAppId":"E8C28D3C"}
                      • K Krys
                        ```bash
                        Script v.2025-03-08
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 4
                                         RTC time: n/a
                                  RTC in local TZ: no
                        krystian
                        HOME=/home/krystian
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Swap:           1.1G          0B        1.1G
                                 2583 M used memory
                                 6931 M free memory
                                    0 M buffer memory
                                  608 M swap cache
                                 1024 M total swap
                                    0 M used swap
                                 1024 M free swap
                        *** FILESYSTEM ***
                        /var:
                        1.3G    /var/
                        787M    /var/log
                        355M    /var/cache
                        USB-Devices by-id:
                        HINT:
                        /dev/ttyUSB0
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.6.17
                        javascript:     8.9.2
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        30300
                        States:         27699
                        Pending Updates: 0
                        warum sind alle diese Instanzen über github installiert?
                        da gibt's bestimmt einige in offiziellen Repos.
                        sourceanalytix auf jeden Fall
                          Krys
                          Sollte nun i.O. sein.
                          ```bash
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                            Virtualization: lxc
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           19:35:34 up 43 min,  2 users,  load average: 1.13, 0.94, 0.97
                          CPU threads: 4
                                         Local time: Sun 2025-08-10 19:35:34 CEST
                                     Universal time: Sun 2025-08-10 17:35:34 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          krystian
                          HOME=/home/krystian
                          iobroker
                          HOME=/home/iobroker
                          Unit display-manager.service could not be found.
                          Display-Manager:
                          Desktop:
                          Session:
                          *** MEMORY ***
                          Mem:             10G        2.8G        7.3G        106K        507M        7.8G
                          Swap:           1.1G          0B        1.1G
                                   2709 M used memory
                                   2728 M active memory
                                    319 M inactive memory
                                   6931 M free memory
                                      0 M buffer memory
                                    483 M swap cache
                                   1024 M total swap
                                      0 M used swap
                                   1024 M free swap
                          top - 19:35:35 up 43 min,  2 users,  load average: 1.13, 0.94, 0.97
                          %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  10124.0 total,   6928.9 free,   2711.3 used,    483.9 buff/cache
                          MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7412.7 avail Mem
                          *** FILESYSTEM ***
                          /var:
                          1.3G    /var/
                          779M    /var/log
                          355M    /var/cache
                          825M    /opt/iobroker/iobroker-data/
                          455M    /opt/iobroker/iobroker-data/files
                          35M     /opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyUSB0
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 2631)
                          admin:          7.6.17
                          javascript:     8.9.2
                          nodejs modules from github:     2
                          Adapter State
                          + instance is alive
                          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                          Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
                          Objects and States
                          Objects:        30300
                          States:         27641
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       178894137  125/iobroker.js-con
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       178894132  125/iobroker.js-con
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          178899939  816/master
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          178892112  1/init
                          tcp        0      0 127.0.0.1:35471         0.0.0.0:*               LISTEN      1001       178906235  656/io.yahka.0
                          tcp        0      0 0.0.0.0:35257           0.0.0.0:*               LISTEN      1001       178900327  656/io.yahka.0
                          tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       178898901  551/io.nuki.0
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          178891524  1/init
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          178892114  1/init
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          178899940  816/master
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       178905344  989/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       178894361  155/io.admin.0
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       178902337  641/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       178902338  641/io.tuya.0
                          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       178894660  273/io.broadlink2.0
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          178892113  1/init
                          udp        0      0 0.0.0.0:42485           0.0.0.0:*                           1001       178894667  273/io.broadlink2.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       178905612  970/io.upnp.0
                          udp        0      0 0.0.0.0:35019           0.0.0.0:*                           1001       178905269  970/io.upnp.0
                          udp        0      0 0.0.0.0:45068           0.0.0.0:*                           1001       178894782  273/io.broadlink2.0
                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       178899133  536/io.mihome-vacuu
                          udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       178901842  865/io.mihome-vacuu
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178900324  656/io.yahka.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       178894696  296/io.chromecast.0
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       178899569  611/io.shelly.0
                          udp6       0      0 :::111                  :::*                                0          178892115  1/init
                          2025-08-10 19:34:00.886  - info: host.ioBroker iobroker upload [5] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/readmeDocu/stateStartValues.png readmeDocu/stateStartValues.png image/png
                          2025-08-10 19:34:00.903  - info: host.ioBroker instance system.adapter.sourceanalytix.0 in version "0.4.14" started with pid 1411
                          2025-08-10 19:34:01.061  - info: host.ioBroker iobroker upload [4] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_details.png settings_details.png image/png
                          2025-08-10 19:34:01.227  - info: host.ioBroker iobroker upload [3] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_open.png settings_open.png image/png
                          2025-08-10 19:34:01.236  - info: host.ioBroker iobroker upload [2] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/sourceanalytix.png sourceanalytix.png image/png
                          2025-08-10 19:34:01.242  - info: host.ioBroker iobroker upload [1] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/style.css style.css text/css
                          2025-08-10 19:34:01.248  - info: host.ioBroker iobroker upload [0] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/words.js words.js application/javascript
                          2025-08-10 19:34:01.256  - info: host.ioBroker iobroker Updating objects from io-package.json for adapter "sourceanalytix" with version "0.4.14"
                          2025-08-10 19:34:02.418  - info: host.ioBroker iobroker exit 0
                          2025-08-10 19:35:22.864  - warn: chromecast.0 (296) Chromecast - Client error: Error: Device timeout
                              at fn.ontimeout (/opt/iobroker/node_modules/castv2-client/lib/senders/platform.js:56:26)
                              at Object.onceWrapper (node:events:638:28)
                              at fn.emit (node:events:524:28)
                              at fn.emit (node:domain:489:12)
                              at Timeout.ontimeout [as _onTimeout] (/opt/iobroker/node_modules/castv2-client/lib/controllers/heartbeat.js:44:10)
                              at listOnTimeout (node:internal/timers:581:17)
                              at processTimers (node:internal/timers:519:7)
                          2025-08-10 19:35:22.864  - info: chromecast.0 (296) Chromecast - client disconnected
                          2025-08-10 19:35:22.865  - info: chromecast.0 (296) Chromecast - Detached player
                          2025-08-10 19:35:22.929  - info: chromecast.0 (296) Chromecast - Connected client
                          2025-08-10 19:35:22.968  - info: chromecast.0 (296) Chromecast - Try to join player
                          2025-08-10 19:35:22.969  - info: chromecast.0 (296) Chromecast - Connected player
                          2025-08-10 19:35:22.970  - info: chromecast.0 (296) Chromecast - Player joint
                          2025-08-10 19:35:23.023  - info: chromecast.0 (296) {"appId":"E8C28D3C","appType":"WEB","displayName":"Backdrop","iconUrl":"","isIdleScreen":true,"launchedFromCloud":false,"namespaces":[{"name":"urn:x-cast:com.google.cast.debugoverlay"},{"name":"urn:x-cast:com.google.cast.cac"},{"name":"urn:x-cast:com.google.cast.sse"},{"name":"urn:x-cast:com.google.cast.remotecontrol"}],"sessionId":"fd29bca0-aaaa-4b99-b18d-1df589d32b9a","statusText":"","transportId":"fd29bca0-aaaa-4b99-b18d-1df589d32b9a","universalAppId":"E8C28D3C"}
                          • K Krys
                            ```bash
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                              Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 4
                                             RTC time: n/a
                                      RTC in local TZ: no
                            krystian
                            HOME=/home/krystian
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:
                            *** MEMORY ***
                            Swap:           1.1G          0B        1.1G
                                     2709 M used memory
                                     6931 M free memory
                                        0 M buffer memory
                                      483 M swap cache
                                     1024 M total swap
                                        0 M used swap
                                     1024 M free swap
                            *** FILESYSTEM ***
                            /var:
                            1.3G    /var/
                            779M    /var/log
                            355M    /var/cache
                            USB-Devices by-id:
                            HINT:
                            /dev/ttyUSB0
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.6.17
                            javascript:     8.9.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        30300
                            States:         27641
                            Pending Updates: 0
                            @krys
                            Ich vermute da immer noch ein falsch eingestelltes Netzwerk.
                            systemctl status systemd-networkd-wait-online.service
                            sagt?
                              @krys
                              sagt?
                              Krys
                              @thomas-braun said in Probleme mit 4 Adaptern / Ausfall iobroker für paar Minuten:
                              krystian@ioBroker:~$ systemctl status systemd-networkd-wait-online.service
                              x systemd-networkd-wait-online.service - Wait for Network to be Configured
                                   Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; preset: disabled)
                                   Active: failed (Result: exit-code) since Sun 2025-08-10 18:53:51 CEST; 1h 17min ago
                                     Docs: man:systemd-networkd-wait-online.service(8)
                                  Process: 105 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=1/FAILURE)
                                 Main PID: 105 (code=exited, status=1/FAILURE)
                                      CPU: 12ms
                              • K Krys
                                        CPU: 12ms
                                @krys
                                Auf meiner Kiste schaut der so aus:
                                echad@chet:~ $ systemctl status systemd-networkd-wait-online.service
                                ○ systemd-networkd-wait-online.service - Wait for Network to be Configured
                                     Loaded: loaded (/usr/lib/systemd/system/systemd-networkd-wait-online.service; disabled; preset: enabled)
                                     Active: inactive (dead)
                                echad@chet:~ $
                                Aber zu LXCs und Netzwerk kann ich nichts sagen.
                                R 1 Antwort Letzte Antwort
                                  @krys
                                  echad@chet:~ $
                                  Ralf 2
                                  Das sieht bei einem previligiertem LXC genauso aus wie bei dir:
                                  ralf@Home-Server:~$ systemctl status systemd-networkd-wait-online.service
                                  * systemd-networkd-wait-online.service - Wait for Network to be Configured
                                       Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; disabled; preset: disabled)
                                  ralf@Home-Server:~$
                                  Gruß Ralf
                                  • R Ralf 2
                                    ralf@Home-Server:~$
                                    TT-Tom
                                    @ralf-2
                                    bei einem unpreviligierten auch so
                                    tom@iobDev:~$ systemctl status systemd-networkd-wait-online.service
                                    Gruß Tom
                                    Public Transport
                                    NSPanel Adapter Wiki
                                      Krys
                                      So Leute, nach langem rumgefummel folgendes Ergebnis.
                                      was kurios war, mein iobroker hatte plötzlich zwei IP-Adressen, was offensichtlich auch zu zusätzlichen Problemen führte.
                                      Könnt ihr nochmal mit eurem geschulten Auge drüber schauen, ob euch noch was auffällt?
                                      ```bash
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                        Virtualization: lxc
                                                Kernel: Linux 6.8.12-13-pve
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                       10:32:36 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
                                      CPU threads: 4
                                                     Local time: Tue 2025-08-12 10:32:37 CEST
                                                 Universal time: Tue 2025-08-12 08:32:37 UTC
                                                       RTC time: n/a
                                                RTC in local TZ: no
                                      krystian
                                      HOME=/home/krystian
                                      iobroker
                                      HOME=/home/iobroker
                                      Display-Manager:
                                      Desktop:
                                      Session:
                                      *** MEMORY ***
                                      Mem:             10G        2.6G        7.4G        114K        570M        8.0G
                                      Swap:           1.1G          0B        1.1G
                                      Total:           11G        2.6G        8.5G
                                               2478 M used memory
                                               2438 M active memory
                                                410 M inactive memory
                                               7101 M free memory
                                                  0 M buffer memory
                                                544 M swap cache
                                               1024 M total swap
                                                  0 M used swap
                                               1024 M free swap
                                      top - 10:32:37 up 7 min,  2 users,  load average: 0.93, 1.53, 1.49
                                      %Cpu(s): 25.0 us,  0.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :  10124.0 total,   7100.1 free,   2479.8 used,    544.3 buff/cache
                                      MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7644.2 avail Mem
                                      2 loaded units listed.
                                      *** FILESYSTEM ***
                                      /dev/mapper/pve-vm--100--disk--1 ext4       30G   12G   17G  41% /
                                      tmpfs                            tmpfs     3.1G  104K  3.1G   1% /run
                                      /var:
                                      1.3G    /var/
                                      781M    /var/log
                                      355M    /var/cache
                                      251M    /opt/iobroker/backups/
                                      660M    /opt/iobroker/iobroker-data/
                                      268M    /opt/iobroker/iobroker-data/files
                                      148M    /opt/iobroker/iobroker-data/backup-objects
                                      48M     /opt/iobroker/iobroker-data/files/iot.admin
                                      45M     /opt/iobroker/iobroker-data/states.jsonl
                                      33M     /opt/iobroker/iobroker-data/objects.jsonl
                                      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
                                      USB-Devices by-id:
                                      HINT:
                                      /dev/ttyUSB0
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 428)
                                      admin:          7.6.17
                                      javascript:     8.9.2
                                      nodejs modules from github:     4
                                      +-- iobroker.alexa2@3.27.3 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#1f026d3554d62693f1c785027d1e326cf6461998)
                                      +-- iobroker.cloudless-homeconnect@1.6.2 (git+ssh://git@github.com/eifel-tech/ioBroker.cloudless-homeconnect.git#2e5ef03576947db4490f99fe5b032ef5d0e216fe)
                                      Adapter State
                                      + system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : ioBroker                                 -  enabled
                                      + instance is alive
                                      Objects and States
                                      Objects:        29378
                                      States:         27132
                                      Pending Updates: 0
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          343600     295/master
                                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          341984     1/init
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       344427     126/iobroker.js-con
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       344422     126/iobroker.js-con
                                      tcp        0      0 192.168.178.100:9092    0.0.0.0:*               LISTEN      1001       349074     700/io.nuki.0
                                      tcp        0      0 127.0.0.1:45729         0.0.0.0:*               LISTEN      1001       353213     813/io.yahka.0
                                      tcp        0      0 0.0.0.0:37503           0.0.0.0:*               LISTEN      1001       352501     813/io.yahka.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          344254     1/init
                                      tcp6       0      0 :::111                  :::*                    LISTEN      0          341986     1/init
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          343601     295/master
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       346474     306/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       356415     992/io.web.0
                                      udp        0      0 0.0.0.0:36423           0.0.0.0:*                           1001       345845     428/io.broadlink2.0
                                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       348828     681/io.mihome-vacuu
                                      udp        0      0 0.0.0.0:53425           0.0.0.0:*                           1001       353940     874/io.mihome-vacuu
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       352498     813/io.yahka.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       348185     443/io.chromecast.0
                                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       349155     760/io.shelly.0
                                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       353336     790/io.tuya.0
                                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       353337     790/io.tuya.0
                                      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       346813     428/io.broadlink2.0
                                      udp        0      0 0.0.0.0:56183           0.0.0.0:*                           1001       355236     969/io.upnp.0
                                      udp        0      0 192.168.178.100:68      0.0.0.0:*                           103        345195     73/systemd-networkd
                                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          341985     1/init
                                      udp        0      0 0.0.0.0:41265           0.0.0.0:*                           1001       347378     428/io.broadlink2.0
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       357628     969/io.upnp.0
                                      udp6       0      0 :::111                  :::*                                0          341987     1/init
                                      udp6       0      0 fe80::be24:11ff:fe5:546 :::*                                103        345342     73/systemd-networkd
                                           Active: active (exited) since Tue 2025-08-12 10:25:35 CEST; 8min ago
                                          Process: 108 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=0/SUCCESS)
                                         Main PID: 108 (code=exited, status=0/SUCCESS)
                                              CPU: 13ms
                                      • K Krys
                                        ```bash
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                          Virtualization: lxc
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        CPU threads: 4
                                                         RTC time: n/a
                                                  RTC in local TZ: no
                                        krystian
                                        HOME=/home/krystian
                                        iobroker
                                        HOME=/home/iobroker
                                        Display-Manager:
                                        Desktop:
                                        Session:
                                        *** MEMORY ***
                                        Swap:           1.1G          0B        1.1G
                                                 2478 M used memory
                                                 7101 M free memory
                                                    0 M buffer memory
                                                  544 M swap cache
                                                 1024 M total swap
                                                    0 M used swap
                                                 1024 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        1.3G    /var/
                                        781M    /var/log
                                        355M    /var/cache
                                        USB-Devices by-id:
                                        HINT:
                                        /dev/ttyUSB0
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        admin:          7.6.17
                                        javascript:     8.9.2
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        29378
                                        States:         27132
                                        Pending Updates: 0
                                                CPU: 13ms
                                        @krys
                                        Ich sag ja, da klemmt beim Netzwerk was...
                                        Die üblichen Nicklichkeiten würde ich noch angehen.
                                        Bei Zigbee z. B. den Geräte Link 'by-id' verwenden usw.
                                        Ich würde auch jetzt auf nodejs@22 gehen:
                                        iob nodejs-update
                                        Und im Herbst würde ich das ganze Ding auf Debian 13 'Trixie' haben.
                                          Krys
                                          nodejs 22 ist erledigt.
                                          beim Zigbee-Adapter, wenn ich vom Anschlussnamen
                                          eintrage, habe ich ne Bootschleife und der Adapter wird nicht grün.
