  3. Einsteigerfragen
  4. [GELÖST]Node.js update will nicht wie es soll
    5.3k
40 Beiträge 7 Kommentatoren 4.8k Aufrufe 5 Beobachtet
  • Michael SchmittM Michael Schmitt
    mir wird ein Node.js update angezeigt, aber es will nicht updaten.
    Ich hab wie immer den Raspi geupdatet und dabei sollte das ja mitlaufen =
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    dann hab ich mal den fixer laufen lassen, aber auch nix.
    Wo ist der Fehler begraben ?
    Hier ein iob diag
    ```bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
    Operating System: Raspbian GNU/Linux 12 (bookworm)
              Kernel: Linux 6.1.21-v8+
        Architecture: arm64
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     11:14:14 up 4 days, 16:12,  2 users,  load average: 0.36, 0.36, 0.36
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-07-16 11:14:15 CEST
               Universal time: Wed 2025-07-16 09:14:15 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        1.4G        1.5G        1.1M        1.2G        2.6G
    Swap:           209M          0B        209M
    Total:          4.2G        1.4G        1.7G
    Active iob-Instances:   20
             3793 M total memory
             1299 M used memory
             1329 M active memory
              723 M inactive memory
             1463 M free memory
              261 M buffer memory
              845 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 11:14:15 up 4 days, 16:12,  2 users,  load average: 0.36, 0.36, 0.36
    Tasks: 155 total,   1 running, 154 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3793.3 total,   1462.2 free,   1300.6 used,   1106.9 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2492.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4      220G  9.1G  202G   5% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  1.1M  758M   1% /run
    tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Fri Jul 11 19:01:58 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:05:E3:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=fae45d57-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Fri Jul 11 19:02:01 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Fri Jul 11 19:02:01 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Jul 11 19:02:05 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.6G    /var/
    1.1G    /var/log/journal/17d80a2ed91e4fbcb19dfd9141eb79e6
    1.1G    /var/log
    241M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    197M    /opt/iobroker/backups/
    908K    /opt/iobroker/backups/scripte
    904K    /opt/iobroker/backups/scripte/common
    124K    /opt/iobroker/backups/scripte/common/Licht_Wecker
    100K    /opt/iobroker/backups/scripte/common/Wichtig
    /opt/iobroker/iobroker-data:
    430M    /opt/iobroker/iobroker-data/
    243M    /opt/iobroker/iobroker-data/files
    140M    /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/iot.admin
    47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    26M     /opt/iobroker/iobroker-data/objects.jsonl
    8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
    8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2419780-if00
    *** ZigBee Settings ***
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.1
    /usr/bin/node           v20.19.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.1-1nodesource1
      Candidate: 20.19.1-1nodesource1
      Version table:
     *** 20.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2+rpi1 500
            500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 319165)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 192.168.178.42, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'stable'           │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 2       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Objects and States
    Objects:        5073
    States:         3901
    Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
    Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:3 https://phoscon.de/apt/deconz bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2162591    3021/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2162598    3021/iobroker.js-co
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        15484      549/redis-server 12
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13906      397/deCONZ
    tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       2165641    3734/io.socketio.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12861      568/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15483      397/deCONZ
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2167214    3656/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2164910    3076/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2166557    3806/io.simple-api.
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       2164443    3111/io.admin.1
    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        15485      549/redis-server 12
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12863      568/sshd: /usr/sbin
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2163664    3341/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13915      397/deCONZ
    udp        0      0 0.0.0.0:43889           0.0.0.0:*                           108        12758      392/avahi-daemon: r
    udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       2166347    3424/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12756      392/avahi-daemon: r
    udp6       0      0 :::40518                :::*                                108        12759      392/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       2163667    3341/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       2163666    3341/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       2163665    3341/io.deconz.0
    udp6       0      0 fe80::f396:6d7a:b9a:546 :::*                                0          15613      515/NetworkManager
    udp6       0      0 :::5353                 :::*                                108        12757      392/avahi-daemon: r
    2025-07-16 11:01:36.167  - info: host.raspberrypi iobroker upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
    2025-07-16 11:01:36.177  - info: host.raspberrypi iobroker upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
    2025-07-16 11:01:36.185  - info: host.raspberrypi iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
    2025-07-16 11:01:36.193  - info: host.raspberrypi iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
    2025-07-16 11:01:36.201  - info: host.raspberrypi iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
    2025-07-16 11:01:36.210  - info: host.raspberrypi iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
    2025-07-16 11:01:36.218  - info: host.raspberrypi iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    2025-07-16 11:01:36.226  - info: host.raspberrypi iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    2025-07-16 11:01:36.234  - info: host.raspberrypi iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    2025-07-16 11:01:36.242  - info: host.raspberrypi iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    2025-07-16 11:01:36.250  - info: host.raspberrypi iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
    2025-07-16 11:01:36.258  - info: host.raspberrypi iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    2025-07-16 11:01:36.269  - info: host.raspberrypi iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
    2025-07-16 11:01:36.277  - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.backitup.0" is started
    2025-07-16 11:01:36.357  - info: host.raspberrypi "system.adapter.backitup.0" enabled
    2025-07-16 11:01:37.604  - info: host.raspberrypi instance system.adapter.backitup.0 in version "3.3.5" started with pid 748
    2025-07-16 11:01:37.674  - info: host.raspberrypi iobroker exit 0
    2025-07-16 11:01:40.540  - info: javascript.0 (3147) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram['Michael']: backitup.0 is connected
    false
    Adapter NICHT erreichbar
    2025-07-16 11:01:41.044  - info: backitup.0 (748) starting. Version 3.3.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.1, js-controller: 7.0.6
    2025-07-16 11:01:41.151  - info: backitup.0 (748) [iobroker] backup will be activated at 03:35 every 1 day(s)
    2025-07-16 11:02:26.108  - info: javascript.0 (3147) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram['Michael']: backitup.0 is connected
    true
    Adapter ist wieder erreichbar
    @michael-schmitt sagte in Node.js update will nicht wie es soll:
    Userland : 32 bit
    Nicht direkt Problemursache, aber bring das auf ein reines 64Bit-System -> Neuinstallation, dann wird auch die Boot-Partition richtig eingehängt. Bei dir werden im Moment die aktuellen Kernel nicht geladen...
    Zum Problem: Die 20.19.3 ist ganz frisch veröffentlicht und noch nicht von nodesource gepackt worden. Abwarten, kann bei der 32Bit-Version ein paar Tage dauern, da ist kein Fokus mehr drauf.
    Michael SchmittM Thomas BraunT 2 Antworten Letzte Antwort
      Userland : 32 bit
      Michael SchmittM Online
      Michael Schmitt
      @thomas-braun ok THX
        Userland : 32 bit
        @thomas-braun sagte in Node.js update will nicht wie es soll:
        Die 64Bit-Version ist nämlich schon als 20.19.4-1nodesource1 vorhanden:
        echad@chet:~ $ apt policy nodejs
        nodejs:
          Installed: 24.4.1-1nodesource1
          Candidate: 20.19.4-1nodesource1
          Version table:
         *** 24.4.1-1nodesource1 100
             20.19.4-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.19.3-1nodesource1 1001
        usw...
        Michael SchmittM 1 Antwort Letzte Antwort
          nodejs:
            Version table:
          usw...
          Michael Schmitt
          @thomas-braun Erledigt :)
          Hatte ein wenig bammel, aber ich hab das einfach auf einer neuen SSD probiert. Da noch Deconz mit dabei war, aber so wie es aussieht hat dass mit Iobroker neu und Backup einspielen + Deconz neu und Backup einspielen alles funktioniert. Schau mal bitte ob noch was zu tun ist !!
          Hier mal ein aktuelles iob diag
          ```bash
          Script v.2025-03-08
          *** BASE SYSTEM ***
                 Icon name: computer
                    Kernel: Linux 6.12.34+rpt-rpi-v8
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
           15:22:50 up  1:08,  2 users,  load average: 1.24, 1.12, 0.80
          CPU threads: 4
          Current issues:
                         Local time: Wed 2025-07-16 15:22:50 CEST
                     Universal time: Wed 2025-07-16 13:22:50 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.0G        1.7G        587M        6.2M        1.8G        2.3G
          Swap:           536M          0B        536M
          Total:          4.5G        1.7G        1.1G
                   3795 M total memory
                   1593 M used memory
                   1551 M active memory
                   1379 M inactive memory
                    561 M free memory
                    112 M buffer memory
                   1634 M swap cache
                    511 M total swap
                      0 M used swap
                    511 M free swap
          top - 15:22:51 up  1:08,  2 users,  load average: 1.24, 1.12, 0.80
          Tasks: 192 total,   1 running, 191 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3795.9 total,    561.6 free,   1593.2 used,   1746.9 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2202.7 avail Mem
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  5.9M  374M   2% /run
          /dev/sda2      ext4      220G  4.6G  204G   3% /
          tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
          /dev/sda1      vfat      510M   57M  454M  11% /boot/firmware
          [Wed Jul 16 14:14:26 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:05:E3:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=e74f749d-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Wed Jul 16 14:14:28 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
          [Wed Jul 16 14:14:29 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          891M    /var/
          205M    /var/cache
          200M    /var/cache/apt
          174M    /var/lib
          135M    /var/lib/apt/lists
          Archived and active journals take up 4.7M in the file system.
          5.0M    /opt/iobroker/backups/
          219M    /opt/iobroker/iobroker-data/
          200M    /opt/iobroker/iobroker-data/files
          47M     /opt/iobroker/iobroker-data/files/admin.admin
          46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
          18M     /opt/iobroker/iobroker-data/objects.jsonl
          8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
          4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/nodejs         v20.19.4
          /usr/bin/node           v20.19.4
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.32.0
          nodejs:
            Installed: 20.19.4-1nodesource1
            Version table:
           *** 20.19.4-1nodesource1 1001
               20.19.2-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main arm64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 379)
          admin:          7.6.17
          javascript:     8.9.2
          Adapter State
            system.adapter.devices.0                : devices               : raspberrypi                              - disabled
          + instance is alive
          Adapter    "iot"          : 3.3.0    , installed 3.6.0
          Adapter    "ws"           : 2.6.2    , installed 3.0.19
          Objects and States
          Objects:        5073
          States:         3980
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://phoscon.de/apt/deconz generic InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       64792      16532/iobroker.js-c
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       64797      16532/iobroker.js-c
          tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       66341      16990/io.socketio.0
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       50859      14146/deCONZ
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       50840      14146/deCONZ
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5323       609/sshd: /usr/sbin
          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       63963      16561/io.admin.1
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       62933      16550/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       63474      17031/io.web.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       65463      16975/io.simple-api
          tcp6       0      0 :::22                   :::*                    LISTEN      0          5325       609/sshd: /usr/sbin
          udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       65417      16809/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5271       470/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       64183      16760/io.deconz.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       50862      14146/deCONZ
          udp        0      0 0.0.0.0:57216           0.0.0.0:*                           104        5273       470/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        5272       470/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       64186      16760/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       64185      16760/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       64184      16760/io.deconz.0
          udp6       0      0 fe80::62d5:ebcd:e5c:546 :::*                                0          690        548/NetworkManager
          udp6       0      0 :::35718                :::*                                104        5274       470/avahi-daemon: r
            ```bash
            Script v.2025-03-08
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           536M          0B        536M
                     3795 M total memory
                     1593 M used memory
                      561 M free memory
                      112 M buffer memory
                     1634 M swap cache
                      511 M total swap
                        0 M used swap
                      511 M free swap
            *** FILESYSTEM ***
            /var:
            891M    /var/
            205M    /var/cache
            200M    /var/cache/apt
            174M    /var/lib
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.6.17
            javascript:     8.9.2
            Adapter State
            + instance is alive
            Objects and States
            Objects:        5073
            States:         3980
            Pending Updates: 0
            @michael-schmitt
            Ja, jetzt passt es.
              ```bash
              Script v.2025-03-08
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           536M          0B        536M
                       3795 M total memory
                       1593 M used memory
                        561 M free memory
                        112 M buffer memory
                       1634 M swap cache
                        511 M total swap
                          0 M used swap
                        511 M free swap
              *** FILESYSTEM ***
              /var:
              891M    /var/
              205M    /var/cache
              200M    /var/cache/apt
              174M    /var/lib
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.6.17
              javascript:     8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        5073
              States:         3980
              Pending Updates: 0
              da ist ein Repo zuviel.
              Hast du ggf. auch eine Host-Leiche unter system.host. (im Expertenmodus)?
                Michael Schmitt
                @homoran das hatte ich da mal reingemacht weil irgendwas mit dem update nicht funktioniert hatt (ist scho eeeeewig her)
                  hat aber den selben Pfad hinterlegt.
                  Dann brauchst du es nicht
                    Michael Schmitt
                    @homoran ich hab jetzt mal den Haken beim zweiten rein gemacht und wenn damit auch alles läuft werde ich das doppelte löschen ;)
                    • bergjetB Offline
                      bergjetB Offline
                      bergjet
                      Inzwischen gibt es node.js 20.19.4 Aber ich bekomm das auch nicht drauf. Es bleibt bei 20.19.1
                      Ich habe das Update nach jeder neuen Version versucht.
                      homee, ioBroker, iMac, iPhone, Sonos, Alaxa
                      • bergjetB bergjet
                        @bergjet sagte in Node.js update will nicht wie es soll:
                        sudo apt update
                        apt policy nodejs
                        liefert?
                        Edit: Wird aber vermutlich mit einem 32Bit-System zusammenhängen. In wenigen Wochen wird wohl Debian/RaspberryOS 13 'Trixie' veröffentlicht werden. Ich würde dann darauf per Neuinstallation umsatteln.
                        bergjetB 1 Antwort Letzte Antwort
                          sudo apt update
                          apt policy nodejs
                          liefert?
                          bergjetB Offline
                          bergjetB Offline
                          bergjet
                          pi@pi4:~ $ apt policy nodejs
                          nodejs:
                            Installiert:           20.19.1-1nodesource1
                            Installationskandidat: 20.19.1-1nodesource1
                            Versionstabelle:
                               12.22.12~dfsg-1~deb11u7 500
                          pi@pi4:~ $
                          • bergjetB bergjet
                            nodejs:
                              Versionstabelle:
                            pi@pi4:~ $
                            @bergjet
                            Ja, also eine 32Bit-Kiste.
                            Bring das per NEUINSTALLATION auf die 64Bit-Lite-Basis.
                            G 1 Antwort Letzte Antwort
                              @bergjet
                              Gerhardptl
                              Hallo Thomas, habe das gleiche Problem - gibt es eine Anleitung wie man das System auf 64 bit umstellt?
                              • G Gerhardptl
                                @gerhardptl sagte in [GELÖST]Node.js update will nicht wie es soll:
                                Installier es NEU.
                                Ich würde jetzt aber noch die paar Tage abwarten, bis Debian 13 'Trixie' veröffentlicht wird.
                                  Installier es NEU.
                                  MartinPM Online
                                  MartinPM Online
                                  MartinP
                                  @thomas-braun Ich weiß nicht, ob ich da sofort mit wehenden Fahnen von Bookworm überlaufen würde ...
                                  Support für Bookworm gibt es noch bis Mitte 2026, LTS Support sogar bis 2028...
                                  Ich würde da vielleicht noch ein paar Monate warten, und das Echo hier im Forum abwarten, von Early-Adopters ;-)
                                  • MartinPM MartinP
                                    @martinp
                                    Dann halt Bookworm neuinstallieren und nach dem ersten PointRelease von Trixie upgraden.
                                    Aber man kommt nicht ohne Neuinstallation von einem 32Bit 'armhf' auf 64Bit 'arm64'.
                                    Und bitte den LTS-Kram vermeiden. Das ist für ein weiterlaufendes Projekt wie den ioBroker keine gescheite Basis.
                                    Man fällt maximal auf das 'oldstable' Release zurück, und auch das nur innerhalb des ersten Jahres nach Erscheinen der stabilen Version.
                                    Davon abgesehen gibt es für RaspberryOS keine LTS-Versionen. Die unterstützen nur deren aktuelles stable-Release und mit merklichen Abstrichen den Vorgänger. Nix mit LTS bis 2028.
                                    MartinPM G 2 Antworten Letzte Antwort
                                      @martinp
                                      MartinPM Online
                                      MartinPM Online
                                      MartinP
                                      @thomas-braun Im Sommer ist mehr Arbeit im Garten... die dunklen Winterabende bieten sich an, den Wechsel zu vollziehen ;-)
                                      • MartinPM MartinP
                                        @martinp
                                        Kannste ja in dem ersten Jahr dann machen.
                                        Ich wollte @Gerhardptl nur sagen, dass er mit der erforderlichen Neuinstallation auch noch ein paar Wochen warten kann und dann gleich das aktuelle Release hat und er da nichts einfach nur 'umstellen' kann.
                                          @martinp
                                          Gerhardptl
                                          Hier mein System
