  4. Fehler Backitup Grafana
    6.6k
94 Beiträge 7 Kommentatoren 15.0k Aufrufe 6 Beobachtet
  • M minkhx
    @simatec Jo, das hab ich hier irgendwo gelesen mit dem Ändern auf debug-state. Ich hab aber keine Ahnung, wo die log ist, dummerweise.
    Edit: Das hier?
    backitup.0
    	2025-05-23 22:33:30.863	error	[iobroker/grafana] cannot found Grafana Backup files
    Edit2:
    backitup.0
    	2025-05-23 22:33:32.824	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
    backitup.0
    backitup.0
    	2025-05-23 22:32:53.086	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
    backitup.0
    	2025-05-23 22:32:50.989	error	[iobroker/grafana] cannot found Grafana Backup files
    backitup.0
    	2025-05-23 22:27:49.895	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
    backitup.0
    	2025-05-23 22:27:47.936	error	[iobroker/grafana] cannot found Grafana Backup files
    host.flowbox
    	2025-05-23 22:27:27.556	warn	instance system.adapter.backitup.0 already running with pid 135751
    backitup.0
    	2025-05-23 22:27:05.581	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
    backitup.0
    	2025-05-23 22:27:03.612	error	[iobroker/grafana] cannot found Grafana Backup files
    simatecS Offline
    simatecS Offline
    simatec
    #79
    @minkhx Bitte den kompletten Log vom Backup posten
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      minkhx
      schrieb am zuletzt editiert von minkhx
      #80
      @simatec Ja, klar, nicht das Protokoll, sondern den output...
      mit Haken bei ioB, influx und Grafana.
      22:45:23.952
      INFO
      gui
      Backup gestartet ...
      22:45:30.750
      DEBUG
      iobroker
      host.flowbox 193 objects saved
      22:45:30.828
      DEBUG
      iobroker
      host.flowbox 141 states saved
      22:45:30.846
      DEBUG
      iobroker
      host.flowbox "config.json" is valid
      22:45:30.881
      DEBUG
      iobroker
      host.flowbox "objects.jsonl" exists
      host.flowbox "states.jsonl" exists
      22:45:31.767
      DEBUG
      iobroker
      host.flowbox JSONL lines are valid
      22:45:31.777
      DEBUG
      iobroker
      host.flowbox The backup is valid!
      22:45:33.948
      DEBUG
      iobroker
      Backup created: /opt/iobroker/backups/iobroker_2025_05_23-22_45_24_backupiobroker.tar.gz
      22:45:33.993
      DEBUG
      iobroker
      This backup can only be restored with js-controller version 7.0 or higher
      22:45:34.986
      DEBUG
      iobroker
      done
      22:45:35.147
      DEBUG
      influxDB
      InfluxDB-Backup started ...
      22:45:35.194
      DEBUG
      influxDB
      Start InfluxDB Backup ...
      22:45:35.205
      DEBUG
      influxDB
      InfluxDB Backup tmp directory created
      22:45:35.222
      DEBUG
      influxDB
      Backup created: /opt/iobroker/backups/influxDB_2025_05_23-22_45_35_backupiobroker.tar.gz
      22:45:35.235
      DEBUG
      influxDB
      InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-22_45_35_backupiobroker" successfully deleted
      22:45:35.271
      DEBUG
      influxDB
      InfluxDB-Backup for is finish
      22:45:35.282
      DEBUG
      influxDB
      done
      22:45:36.486
      DEBUG
      grafana
      Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
      22:45:36.502
      DEBUG
      grafana
      Created dashboard directory
      22:45:36.518
      DEBUG
      grafana
      Created folder directory
      22:45:36.521
      DEBUG
      grafana
      Created dashboards_manually_restore directory
      22:45:36.565
      DEBUG
      grafana
      Created datasource directory
      22:45:36.580
      DEBUG
      grafana
      Grafana is available ... Status: 200
      22:45:37.086
      DEBUG
      grafana
      Saved dashboard-folder mapping
      22:45:37.257
      DEBUG
      grafana
      start Grafana backup compress ...
      22:45:37.275
      DEBUG
      grafana
      Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
      22:45:37.290
      DEBUG
      grafana
      Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
      22:45:37.330
      ERROR
      grafana
      22:45:37.339
      DEBUG
      grafana
      done
      22:45:39.238
      WARN
      clean
      22:45:39.277
      DEBUG
      clean
      done
      22:45:39.402
      DEBUG
      historyHTML
      new history html values created
      22:45:39.495
      DEBUG
      historyHTML
      done
      22:45:39.660
      DEBUG
      historyJSON
      new history json values created
      22:45:39.705
      DEBUG
      historyJSON
      done
      22:45:42.176
      DEBUG
      notification
      done
      22:45:42.333
      INFO
      gui
      Das Backup wurde erfolgreich erstellt!
      EDIT:
      Z109-113 - Wenn der das immer deleted, kanner ja auch nix finden, oder? Vllt. ist das gar nicht so schlimm?
      • M minkhx
        22:45:23.952
        INFO
        gui
        22:45:30.750
        DEBUG
        iobroker
        22:45:30.828
        DEBUG
        iobroker
        22:45:30.846
        DEBUG
        iobroker
        22:45:30.881
        DEBUG
        iobroker
        22:45:31.767
        DEBUG
        iobroker
        22:45:31.777
        DEBUG
        iobroker
        22:45:33.948
        DEBUG
        iobroker
        22:45:33.993
        DEBUG
        iobroker
        22:45:34.986
        DEBUG
        iobroker
        done
        22:45:35.147
        DEBUG
        influxDB
        22:45:35.194
        DEBUG
        influxDB
        22:45:35.205
        DEBUG
        influxDB
        22:45:35.222
        DEBUG
        influxDB
        22:45:35.235
        DEBUG
        influxDB
        22:45:35.271
        DEBUG
        influxDB
        22:45:35.282
        DEBUG
        influxDB
        done
        22:45:36.486
        DEBUG
        grafana
        22:45:36.502
        DEBUG
        grafana
        22:45:36.518
        DEBUG
        grafana
        22:45:36.521
        DEBUG
        grafana
        22:45:36.565
        DEBUG
        grafana
        22:45:36.580
        DEBUG
        grafana
        22:45:37.086
        DEBUG
        grafana
        22:45:37.257
        DEBUG
        grafana
        22:45:37.275
        DEBUG
        grafana
        22:45:37.290
        DEBUG
        grafana
        22:45:37.330
        ERROR
        grafana
        22:45:37.339
        DEBUG
        grafana
        done
        22:45:39.238
        WARN
        clean
        22:45:39.277
        DEBUG
        clean
        done
        22:45:39.402
        DEBUG
        historyHTML
        22:45:39.495
        DEBUG
        historyHTML
        done
        22:45:39.660
        DEBUG
        historyJSON
        22:45:39.705
        DEBUG
        historyJSON
        done
        22:45:42.176
        DEBUG
        notification
        done
        22:45:42.333
        INFO
        gui
        EDIT:
        simatecS Offline
        simatecS Offline
        simatec
        #81
        @minkhx Wie sieht denn das Grafana Backup aus? Ist da was drin? Zeige mal den Log, wo es funktioniert hat. In dem Log steht ja nix zur Sicherung von Dashboards
        • simatecS simatec
          minkhx
          #82
          @simatec Also das ist der log jetzt nur mit ioB-Haken:
          22:51:11.771
          INFO
          gui
          22:51:19.916
          DEBUG
          iobroker
          22:51:20.040
          DEBUG
          iobroker
          host.flowbox Validating backup ...
          22:51:20.057
          DEBUG
          iobroker
          22:51:21.114
          DEBUG
          iobroker
          22:51:21.129
          DEBUG
          iobroker
          22:51:23.131
          DEBUG
          iobroker
          Backup created: /opt/iobroker/backups/iobroker_2025_05_23-22_51_14_backupiobroker.tar.gz
          22:51:23.143
          DEBUG
          iobroker
          22:51:24.233
          DEBUG
          iobroker
          done
          22:51:27.554
          WARN
          clean
          22:51:27.597
          DEBUG
          clean
          done
          22:51:27.719
          DEBUG
          historyHTML
          22:51:27.845
          DEBUG
          historyHTML
          done
          22:51:27.993
          DEBUG
          historyJSON
          22:51:28.035
          DEBUG
          historyJSON
          done
          22:51:30.520
          DEBUG
          notification
          done
          22:51:30.666
          INFO
          gui
          Das ist der log mit ioB- und Grafana-Haken:
          22:52:04.644
          INFO
          gui
          22:52:12.872
          DEBUG
          iobroker
          22:52:12.988
          DEBUG
          iobroker
          host.flowbox 140 states saved
          22:52:13.003
          DEBUG
          iobroker
          22:52:13.005
          DEBUG
          iobroker
          22:52:14.017
          DEBUG
          iobroker
          22:52:15.067
          DEBUG
          iobroker
          Backup created: /opt/iobroker/backups/iobroker_2025_05_23-22_52_07_backupiobroker.tar.gz
          22:52:15.111
          DEBUG
          iobroker
          22:52:16.118
          DEBUG
          iobroker
          done
          22:52:17.522
          DEBUG
          grafana
          Start Grafana Backup ...
          22:52:17.537
          DEBUG
          grafana
          22:52:17.543
          DEBUG
          grafana
          22:52:17.547
          DEBUG
          grafana
          22:52:17.549
          DEBUG
          grafana
          22:52:17.602
          DEBUG
          grafana
          start Grafana request ...
          22:52:17.663
          DEBUG
          grafana
          22:52:18.021
          DEBUG
          grafana
          22:52:18.202
          DEBUG
          grafana
          22:52:18.217
          DEBUG
          grafana
          22:52:18.231
          DEBUG
          grafana
          22:52:18.249
          DEBUG
          grafana
          done
          22:52:20.191
          WARN
          clean
          22:52:20.234
          DEBUG
          clean
          done
          22:52:20.356
          DEBUG
          historyHTML
          22:52:20.450
          DEBUG
          historyHTML
          done
          22:52:20.638
          DEBUG
          historyJSON
          22:52:20.669
          DEBUG
          historyJSON
          done
          22:52:23.150
          DEBUG
          notification
          done
          22:52:23.303
          INFO
          gui
          BTW:
          Es gibt keine Dashboards, oh, oh, oh, sag nicht der ganze Tanz nur weil ich hier ins Blaue schieße. Ich wollte erstmal testen, ob das funzt.
          Backup machen, restoren, ein bisschen cash rüberwachsen lassen und dann ioB fröhlich als Modbus-Watcher nutzen.
          • M minkhx
            22:51:11.771
            INFO
            gui
            22:51:19.916
            DEBUG
            iobroker
            22:51:20.040
            DEBUG
            iobroker
            22:51:20.057
            DEBUG
            iobroker
            22:51:21.114
            DEBUG
            iobroker
            22:51:21.129
            DEBUG
            iobroker
            22:51:23.131
            DEBUG
            iobroker
            22:51:23.143
            DEBUG
            iobroker
            22:51:24.233
            DEBUG
            iobroker
            done
            22:51:27.554
            WARN
            clean
            22:51:27.597
            DEBUG
            clean
            done
            22:51:27.719
            DEBUG
            historyHTML
            22:51:27.845
            DEBUG
            historyHTML
            done
            22:51:27.993
            DEBUG
            historyJSON
            22:51:28.035
            DEBUG
            historyJSON
            done
            22:51:30.520
            DEBUG
            notification
            done
            22:51:30.666
            INFO
            gui
            22:52:04.644
            INFO
            gui
            22:52:12.872
            DEBUG
            iobroker
            22:52:12.988
            DEBUG
            iobroker
            22:52:13.003
            DEBUG
            iobroker
            22:52:13.005
            DEBUG
            iobroker
            22:52:14.017
            DEBUG
            iobroker
            22:52:15.067
            DEBUG
            iobroker
            22:52:15.111
            DEBUG
            iobroker
            22:52:16.118
            DEBUG
            iobroker
            done
            22:52:17.522
            DEBUG
            grafana
            22:52:17.537
            DEBUG
            grafana
            22:52:17.543
            DEBUG
            grafana
            22:52:17.547
            DEBUG
            grafana
            22:52:17.549
            DEBUG
            grafana
            22:52:17.602
            DEBUG
            grafana
            22:52:17.663
            DEBUG
            grafana
            22:52:18.021
            DEBUG
            grafana
            22:52:18.202
            DEBUG
            grafana
            22:52:18.217
            DEBUG
            grafana
            22:52:18.231
            DEBUG
            grafana
            22:52:18.249
            DEBUG
            grafana
            done
            22:52:20.191
            WARN
            clean
            22:52:20.234
            DEBUG
            clean
            done
            22:52:20.356
            DEBUG
            historyHTML
            22:52:20.450
            DEBUG
            historyHTML
            done
            22:52:20.638
            DEBUG
            historyJSON
            22:52:20.669
            DEBUG
            historyJSON
            done
            22:52:23.150
            DEBUG
            notification
            done
            22:52:23.303
            INFO
            gui
            BTW:
            simatecS Offline
            simatecS Offline
            simatec
            #83
            @minkhx Hat dein Grafana denn keine Inhalte? Keine Datasource und keine Dashboards?
            • simatecS simatec
              minkhx
              #84
              @simatec Äh, nope? Grade erst alles eingerichtet. Grafane stünde am Schluss von Allem bzw. habe ich noch nicht mal Sensordaten, welche ich fluxen und dann darstellen könnte.
              Vllt. kann ich ja einen Systemdienst/Sensor loggen, wenn das erforderlich ist.
              • M minkhx
                simatecS Offline
                simatecS Offline
                simatec
                #85
                @minkhx Richte das erstmal ein und dann setze den Hacken in Backitup. Du sicherst gerade ein System, das nicht vorhanden ist
                M S 3 Antworten Letzte Antwort
                • simatecS simatec
                  minkhx
                  #86
                  @simatec Ok, ich hatte am Anfang Influx als input gesetzt, aber noch keine Dashes angelegt. Ich versuch das mal. Mal sehen, was in influx so Verwertbares enthält.
                  • simatecS simatec
                    minkhx
                    #87
                    @simatec
                    Hier der log mit ioB, flux, Grafana:
                    23:10:26.402
                    INFO
                    gui
                    23:10:34.540
                    DEBUG
                    iobroker
                    23:10:34.623
                    DEBUG
                    iobroker
                    23:10:34.688
                    DEBUG
                    iobroker
                    23:10:34.692
                    DEBUG
                    iobroker
                    23:10:35.634
                    DEBUG
                    iobroker
                    23:10:37.256
                    DEBUG
                    iobroker
                    Backup created: /opt/iobroker/backups/iobroker_2025_05_23-23_10_28_backupiobroker.tar.gz
                    23:10:37.257
                    DEBUG
                    iobroker
                    23:10:38.296
                    DEBUG
                    iobroker
                    done
                    23:10:38.465
                    DEBUG
                    influxDB
                    23:10:38.479
                    DEBUG
                    influxDB
                    23:10:38.575
                    DEBUG
                    influxDB
                    Backup created: /opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker.tar.gz
                    23:10:38.590
                    DEBUG
                    influxDB
                    Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker"
                    23:10:38.604
                    DEBUG
                    influxDB
                    InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker" successfully deleted
                    23:10:38.641
                    DEBUG
                    influxDB
                    23:10:38.643
                    DEBUG
                    influxDB
                    done
                    23:10:39.888
                    DEBUG
                    grafana
                    23:10:39.902
                    DEBUG
                    grafana
                    23:10:39.932
                    DEBUG
                    grafana
                    23:10:39.949
                    DEBUG
                    grafana
                    23:10:40.011
                    DEBUG
                    grafana
                    23:10:40.026
                    DEBUG
                    grafana
                    23:10:40.662
                    DEBUG
                    grafana
                    found Dashboard: tst-dashboard-gauge
                    23:10:40.978
                    DEBUG
                    grafana
                    23:10:41.178
                    DEBUG
                    grafana
                    23:10:46.208
                    DEBUG
                    grafana
                    Backup created: /opt/iobroker/backups/grafana_2025_05_23-23_10_41_backupiobroker.tar.gz
                    23:10:46.223
                    DEBUG
                    grafana
                    23:10:46.265
                    DEBUG
                    grafana
                    done
                    23:10:48.183
                    WARN
                    clean
                    23:10:48.224
                    DEBUG
                    clean
                    done
                    23:10:48.353
                    DEBUG
                    historyHTML
                    23:10:48.452
                    DEBUG
                    historyHTML
                    done
                    23:10:48.640
                    DEBUG
                    historyJSON
                    23:10:48.681
                    DEBUG
                    historyJSON
                    done
                    23:10:51.151
                    DEBUG
                    notification
                    done
                    23:10:51.315
                    INFO
                    gui
                    Zusätzlich noch Node-Red:
                    23:11:50.291
                    INFO
                    gui
                    23:11:58.680
                    DEBUG
                    iobroker
                    23:11:58.775
                    DEBUG
                    iobroker
                    23:11:58.787
                    DEBUG
                    iobroker
                    23:11:59.757
                    DEBUG
                    iobroker
                    23:11:59.767
                    DEBUG
                    iobroker
                    23:12:01.472
                    DEBUG
                    iobroker
                    Backup created: /opt/iobroker/backups/iobroker_2025_05_23-23_11_52_backupiobroker.tar.gz
                    23:12:01.474
                    DEBUG
                    iobroker
                    23:12:02.514
                    DEBUG
                    iobroker
                    done
                    23:12:02.681
                    DEBUG
                    influxDB
                    23:12:02.683
                    DEBUG
                    influxDB
                    23:12:02.725
                    DEBUG
                    influxDB
                    23:12:02.845
                    DEBUG
                    influxDB
                    Backup created: /opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker.tar.gz
                    23:12:02.865
                    DEBUG
                    influxDB
                    Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker"
                    23:12:02.869
                    DEBUG
                    influxDB
                    InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker" successfully deleted
                    23:12:02.874
                    DEBUG
                    influxDB
                    23:12:02.912
                    DEBUG
                    influxDB
                    done
                    23:12:04.180
                    DEBUG
                    grafana
                    23:12:04.186
                    DEBUG
                    grafana
                    23:12:04.193
                    DEBUG
                    grafana
                    23:12:04.214
                    DEBUG
                    grafana
                    23:12:04.227
                    DEBUG
                    grafana
                    23:12:04.234
                    DEBUG
                    grafana
                    23:12:04.332
                    DEBUG
                    grafana
                    23:12:04.346
                    DEBUG
                    grafana
                    23:12:05.041
                    DEBUG
                    grafana
                    23:12:05.355
                    DEBUG
                    grafana
                    23:12:05.529
                    DEBUG
                    grafana
                    23:12:10.600
                    DEBUG
                    grafana
                    Backup created: /opt/iobroker/backups/grafana_2025_05_23-23_12_06_backupiobroker.tar.gz
                    23:12:10.605
                    DEBUG
                    grafana
                    23:12:10.622
                    DEBUG
                    grafana
                    23:12:10.661
                    DEBUG
                    grafana
                    done
                    23:12:11.383
                    DEBUG
                    nodered
                    Created nodered tmp directory
                    23:12:11.401
                    DEBUG
                    nodered
                    Node-Red tmp copy finish
                    23:12:11.427
                    DEBUG
                    nodered
                    Backup created: /opt/iobroker/backups/nodered.0_2025_05_23-23_12_12_backupiobroker.tar.gz
                    23:12:11.438
                    DEBUG
                    nodered
                    Try deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
                    23:12:11.441
                    DEBUG
                    nodered
                    node-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
                    23:12:11.494
                    DEBUG
                    nodered
                    done
                    23:12:12.652
                    WARN
                    clean
                    23:12:12.693
                    DEBUG
                    clean
                    done
                    23:12:12.824
                    DEBUG
                    historyHTML
                    23:12:12.923
                    DEBUG
                    historyHTML
                    done
                    23:12:13.131
                    DEBUG
                    historyJSON
                    23:12:13.171
                    DEBUG
                    historyJSON
                    done
                    23:12:15.641
                    DEBUG
                    notification
                    done
                    23:12:15.791
                    INFO
                    gui
                    Das funzt auch mit DNS statt IP.
                    Oh, srry, mein Fehler. Ich hab da iwie die Fehlermeldung ganz anders interpretiert...
                    Das Dash ist zwar leer bzw. visualisiert "keine Daten", aber das reicht scheinbar erstmal.
                    Backitup ist durchdacht und zweckmäßig, brauche ich:) Ich lass euch was cash rüberwachsen.
                    • simatecS simatec
                      SabineT
                      #88
                      @simatec es wäre praktisch, wenn es für das "Grafana Backup" auch so einen Knopf "JETZT SICHERN" geben würde, wie bei ioBroker oder Homematic. Gerade wenn man testen will, ob das Backup funktioniert.
                      • S SabineT
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #89
                        @sabinet das ist nicht geplant. Backups wie Grafana, zigbee und Co sind zusätzliche Backup Optionen zum ioBroker Backup
                        • simatecS simatec
                          saeft_2003
                          #90
                          @simatec
                          Hi. Mit der 3.3.5 funktioniert das grafana backup nicht mehr. Es fehlt die Möglichkeit den Benutzernamen und das Passwort einzugeben. Nach einem downgrad auf 3.2.2 funktioniert wieder alles wie gewohnt.
                          Ist der Fehler bekannt?
                          • S saeft_2003
                            @simatec
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #91
                            @saeft_2003 Benutzername und Passwort werden nicht mehr benötigt... Der Token übernimmt alles
                            • simatecS simatec
                              saeft_2003
                              #92
                              @simatec
                              Geht aber nicht bei mir. Langt ein normaler viewer token?
                              • S saeft_2003
                                @simatec
                                simatecS Offline
                                simatecS Offline
                                simatec
                                #93
                                @saeft_2003 nein immer ein Admin Token. Steht auch so in der Doku
                                • simatecS simatec
                                  saeft_2003
                                  #94
                                  @simatec
                                  Ok danke bis jetzt hatte es mit dem viewer token funktioniert. Ich probiere jetzt den admin…
