  3. Cloud Dienste
  4. Kein Anmelden am Alexa Adapter mehr möglich
    6.4k
50 Beiträge 7 Kommentatoren 6.3k Aufrufe 5 Beobachtet
  • B Balkonfarmer
    Script v.2025-03-08
    *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32 bit
    Systemuptime and Load:
     16:03:56 up  2:25,  1 user,  load average: 1.02, 0.56, 0.49
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-07-07 16:03:56 CEST
               Universal time: Mon 2025-07-07 14:03:56 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            3.8G        1.2G        2.2G        0.0K        360M        2.8G
    Swap:            99M          0B         99M
    Total:          3.9G        1.2G        2.3G
    Active iob-Instances:   22
             3793 M total memory
             1207 M used memory
              912 M active memory
              527 M inactive memory
             2224 M free memory
               58 M buffer memory
              302 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 16:03:57 up  2:25,  1 user,  load average: 1.02, 0.56, 0.49
    Tasks: 176 total,   1 running, 175 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  5.6 us,  7.0 sy,  0.0 ni, 87.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3793.3 total,   2224.6 free,   1207.4 used,    361.3 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2828.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       15G  5.3G  8.4G  39% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  836K  758M   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Jul  7 13:38:05 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:17:D0:59 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=a97293b6-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Jul  7 13:38:08 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jul  7 13:38:08 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mon Jul  7 13:38:10 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.0G    /var/
    1.5G    /var/log/journal/faf0bbffdeae42ee938bcf9ac7b405cd
    1.5G    /var/log
    345M    /var/cache
    Archived and active journals take up 1.4G in the file system.
    /opt/iobroker/backups:
    42M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    587M    /opt/iobroker/iobroker-data/
    231M    /opt/iobroker/iobroker-data/files
    220M    /opt/iobroker/iobroker-data/Luftdaten
    96M     /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.ea6ad656.chunk.js.map
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b7bbd921.chunk.js.map
    9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    7.6M    /opt/iobroker/iobroker-data/objects.json.migrated
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    nodejs:                 N/A
    /usr/bin/node           v14.21.3
    /usr/bin/npm            6.14.18
    /usr/bin/npx            6.14.18
    /usr/bin/corepack       0.15.1
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 14.21.3-deb-1nodesource1
      Candidate: 14.21.3-deb-1nodesource1
      Version table:
     *** 14.21.3-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u7 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: redis
    Hosts:
    raspberrypi         raspberrypi (version: 4.0.24, hostname: raspberrypi   , alive, uptime: 8750)
    Core adapters versions
    js-controller:  4.0.24
    admin:          5.3.8
    javascript:     5.7.0
    nodejs modules from github:     0
    Adapter State
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
    + system.adapter.chromecast.0             : chromecast            : raspberrypi                              -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              - disabled, port: 1883
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
      system.adapter.nina.0                   : nina                  : raspberrypi                              - disabled
      system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled, port: 0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.78
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.6.17   , installed 5.3.8  [Updatable]
    Adapter    "alexa2"       : 3.26.5   , installed 3.11.2 [Updatable]
    Adapter    "backitup"     : 3.2.2    , installed 2.4.9  [Updatable]
    Adapter    "broadlink2"   : 2.3.0    , installed 2.0.3  [Updatable]
    Adapter    "chromecast"   : 4.0.0    , installed 2.3.1  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 3.0.3  [Updatable]
    Adapter    "email"        : 2.0.4    , installed 1.1.3  [Updatable]
    Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
    Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
    Adapter    "history"      : 3.0.1    , installed 1.11.1 [Updatable]
    Adapter    "hmip"         : 1.27.0   , installed 1.17.0 [Updatable]
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 3.3.0    , installed 1.11.4 [Updatable]
    Adapter    "javascript"   : 8.9.2    , installed 5.7.0  [Updatable]
    Controller "js-controller": 7.0.6    , installed 4.0.24 [Updatable]
    Adapter    "luftdaten"    : 4.0.0    , installed 2.2.4  [Updatable]
    Adapter    "meross"       : 1.17.0   , installed 1.12.0 [Updatable]
    Adapter    "mqtt"         : 6.1.2    , installed 3.0.6  [Updatable]
    Adapter    "mqtt-client"  : 3.0.0    , installed 1.6.2  [Updatable]
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.4  [Updatable]
    Adapter    "rpi2"         : 2.4.0    , installed 1.3.2  [Updatable]
    Adapter    "sayit"        : 5.0.0    , installed 1.12.3 [Updatable]
    Adapter    "simple-api"   : 2.8.0    , installed 2.7.0  [Updatable]
    Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
    Adapter    "sonoff"       : 3.1.2    , installed 2.5.1  [Updatable]
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.16 [Updatable]
    Adapter    "vis"          : 1.5.6    , installed 1.4.15 [Updatable]
    Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.3  [Updatable]
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.2.0  [Updatable]
    Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
    Adapter    "web"          : 7.0.8    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
    Objects and States
    Objects:        4815
    States:         3719
    Get:1 http://giteduberger.fr rpimonitor/ InRelease [1933 B]
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:4 https://deb.nodesource.com/node_14.x bullseye InRelease
    Fetched 1933 B in 1s (1653 B/s)
    Reading package lists...
    Pending Updates: 28
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          3867       569/perl
    tcp        0      0 192.168.178.78:1883     0.0.0.0:*               LISTEN      1001       17575      1175/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3838       532/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        13895      508/redis-server 12
    tcp        0      0 0.0.0.0:34675           0.0.0.0:*               LISTEN      1001       732532     12412/io.alexa2.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14849      545/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          3840       532/sshd: /usr/sbin
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       21035      2085/io.socketio.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17140      1851/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14940      591/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21983      2438/io.web.0
    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        13896      508/redis-server 12
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18476      1266/io.chromecast.
    udp        0      0 192.168.178.78:5353     0.0.0.0:*                           1001       15953      1192/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13833      389/avahi-daemon: r
    udp        0      0 0.0.0.0:46726           0.0.0.0:*                           108        13835      389/avahi-daemon: r
    udp        0      0 0.0.0.0:57137           0.0.0.0:*                           1001       18452      1244/io.broadlink2.
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          3893       795/dhcpcd
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       18450      1244/io.broadlink2.
    udp6       0      0 :::5353                 :::*                                108        13834      389/avahi-daemon: r
    udp6       0      0 :::36482                :::*                                108        13836      389/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14908      795/dhcpcd
    2025-07-07 16:01:28.952  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:01:38.992  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:01:48.986  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:01:58.978  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:02:09.029  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:02:14.063  - info: sonoff.0 (1175) Client [Luftdaten] connected with secret 1751896934062_9433
    2025-07-07 16:02:18.997  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:02:28.974  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:02:39.023  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:02:48.992  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:02:58.969  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:03:09.018  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:03:14.264  - info: sonoff.0 (1175) Client [Luftdaten] connection closed: timeout
    2025-07-07 16:03:18.995  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:03:28.981  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:03:39.023  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:03:45.085  - info: sonoff.0 (1175) Client [Luftdaten] connected with secret 1751897025083_575
    2025-07-07 16:03:49.008  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:03:58.972  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:04:09.012  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:04:19.001  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:04:28.975  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:04:39.016  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    2025-07-07 16:04:45.115  - info: sonoff.0 (1175) Client [Luftdaten] connection closed: timeout
    2025-07-07 16:04:48.982  - info: javascript.0 (801) Stop script script.js.Neue_Scripte.Roller_Keller
    iob diag has finished.
    @balkonfarmer
    Kannste sinnvoll nur komplett Neuinstallieren.
    Zuerst den ioBroker samt Unterbau auf einen aktuellen Stand bringen.
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    iob stop
    iob fix
    iob nodejs-update 20
    iob update
    iob upgrade all
    iob upgrade self
    iob update
    iob upgrade all
    iob start
    Dann davon ein Backup ziehen und mit dem auf ein frisch installiertes RaspberryOS 12 'Bookworm' in der 64Bit-Lite-Version umziehen.
    B 2 Antworten Letzte Antwort
      @balkonfarmer
      sudo apt update
      sudo reboot
      iob stop
      iob fix
      iob update
      iob upgrade all
      iob upgrade self
      iob update
      iob upgrade all
      iob start
      Balkonfarmer
      Da habe ich einige Probleme:
      • kann ich die Skripte sichern? So dass ich sie in die Neuinstallation integrieren kann.
      • der Adapter Broadlink ist mir sehr wichtig. Leider habe ich die Fernbedienungen nicht mehr und die Funkcodes liegen nur noch in den Objekten vor. (die könnte ich notfalls händisch kopieren,aber das macht viel Arbeit)
      • kann ich VIS irgendwie übernehmen?
      • B Balkonfarmer
        @balkonfarmer sagte in Kein Anmelden am Alexa Adapter mehr möglich:
        Geht mit dem Backitup-Adapter.
        Kann ich ja nix zu.
        Lass einfach Kiste künftig nicht mehr so versumpfen, dann ist das auch alles viel leichter handlebar.
          Kann ich ja nix zu.
          Balkonfarmer
          @thomas-braun Ich danke Dir schonmal. Das werde ich morgen mal in Angriff nehmen.
            @balkonfarmer
            sudo apt update
            sudo reboot
            iob stop
            iob fix
            iob update
            iob upgrade all
            iob upgrade self
            iob update
            iob upgrade all
            iob start
            Balkonfarmer
            @thomas-braun sagte in Kein Anmelden am Alexa Adapter mehr möglich:
            @balkonfarmer
            Das habe ich nun getan, aber nachdem ich das Backup wiederhergestellt habe, komme ich nicht mehr auf die Oberfläche von IoBroker.
            Ro75R Thomas BraunT 2 Antworten Letzte Antwort
            • B Balkonfarmer
              @balkonfarmer
              Ro75R Offline
              Ro75R Offline
              Ro75
              @balkonfarmer wie lange hast du gewartet? 5 Minuten oder eine Stunde? Aber das gehört nicht hier her.
              Ro75.
              • Ro75R Ro75
                Ro75.
                Balkonfarmer
                @ro75 Ich hab gewartet, bis sich das Fenster geschlossen hat. Das war nach ein paar Minuten.
                Wohin soll ich es denn posten, ich habe ihm ja nur geantwortet.
                Ro75R 1 Antwort Letzte Antwort
                • B Balkonfarmer
                  Ro75R Offline
                  Ro75R Offline
                  Ro75
                  du warst zu schnell. Da hat gerade erst die Wiederherstellung begonnen. Du musst warten, ruhig ne Stunde.
                  Ro75.
                  • B Balkonfarmer
                    @balkonfarmer
                    Kann eine Stunde dauern, kann aber im logfile beobachtet werden
                    iob logs --watch
                    Wenn das dann da ruhig ist kommst du auch wieder auf den Admin, sonst ggfls den Admin von Hand starten, wenn alle Stricke reißen per
                    iob diag
                    den Zustand prüfen.
                    B 3 Antworten Letzte Antwort
                    • Ro75R Ro75
                      Ro75.
                      Balkonfarmer
                      @ro75
                      Das Backup zu erstellen hat auch nur so kurz gedauert.
                      Das ist auch der Grund, warum ich kaum Updates gemacht habe, denn immer war irgendwas. Ich bin jetzt mit meinem Latein am Ende.
                        iob logs --watch
                        iob diag
                        den Zustand prüfen.
                        Balkonfarmer
                        iob logs --watch
                        Der sagt im Log immer das gleiche
                        2025-07-09 17:37:21.843  - error: host.PiHole No connection to databases possibl                 e, restart
                        2025-07-09 17:37:21.863  - info: host.PiHole iobroker _restart
                        2025-07-09 17:37:28.057  - info: host.PiHole iobroker.js-controller version 7.0.                 6 js-controller starting
                        2025-07-09 17:37:28.063  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 20                 14 hobbyquaker
                        2025-07-09 17:37:28.065  - info: host.PiHole hostname: PiHole, node: v20.19.3
                        2025-07-09 17:37:28.066  - info: host.PiHole ip addresses: 192.168.178.78 2001:9                 e8:f0b3:8a00:e85d:c197:a829:228f fdd0:3d3:253b:0:d911:b3c0:c7c0:2034 fe80::3033:                 88cb:66e6:9b32
                        2025-07-09 17:37:58.080  - error: host.PiHole No connection to databases possibl                 e, restart
                        2025-07-09 17:37:58.101  - info: host.PiHole iobroker _restart
                        2025-07-09 17:38:04.320  - info: host.PiHole iobroker.js-controller version 7.0.                 6 js-controller starting
                        2025-07-09 17:38:04.328  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 20                 14 hobbyquaker
                        2025-07-09 17:38:04.329  - info: host.PiHole hostname: PiHole, node: v20.19.3
                        2025-07-09 17:38:04.331  - info: host.PiHole ip addresses: 192.168.178.78 2001:9                 e8:f0b3:8a00:e85d:c197:a829:228f fdd0:3d3:253b:0:d911:b3c0:c7c0:2034 fe80::3033:                 88cb:66e6:9b32
                          iob logs --watch
                          iob diag
                          den Zustand prüfen.
                          Balkonfarmer
                          Ich mach das jetzt nochmal neu.
                            iob logs --watch
                            iob diag
                            den Zustand prüfen.
                            Balkonfarmer
                            Den roten Text habe ich beim ersten Mal nicht gesehen. Jetzt habe ich IoBroker nochmal neu installiert. Im Log steht weiterhin das, was ich schon beim letzten Mal gepostet habe.
                            • B Balkonfarmer
                              Ro75R Offline
                              Ro75R Offline
                              Ro75
                              schrieb am zuletzt editiert von Ro75
                              @balkonfarmer hast du eine Stunde gewartet, bevor du irgend etwas versucht hast zu öffnen oder zu starten? Die Meldung besagt nur, dass die Wiederherstellung der gespeicherten "Parameter" abgeschlossen ist. Danach beginnt der Download und die Einrichtung der Adapter. Genau dieser Vorgang dauert... Warten... Wenn du da rein "stürmst", wird es immer wieder in die Hose gehen.
                              Ro75.
                              • Ro75R Ro75
                                Ro75.
                                Balkonfarmer
                                @ro75
                                Ich habe nur in den Log geschaut und nichts weiter gemacht.
                                • B Balkonfarmer
                                  @ro75
                                  Balkonfarmer
                                  Also ich habe jetzt 2 Stunden gewartet und es tut sich immer noch nichts.
                                  Log sagt:
                                  2025-07-09 20:52:28.396  - error: host.PiHole No connection to databases possible, restart
                                  2025-07-09 20:52:28.417  - info: host.PiHole iobroker _restart
                                  2025-07-09 20:52:34.614  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                  2025-07-09 20:52:34.622  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                  2025-07-09 20:52:34.623  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                  2025-07-09 20:52:34.624  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                  iob diag sagt:
                                  /usr/bin/iob: line 21: /home/iobroker/iob_diag.log: Permission denied
                                  • B Balkonfarmer
                                    Log sagt:
                                    iob diag sagt:
                                    @balkonfarmer
                                    Du musst nach einer frischen Installation als erstes den
                                    iob fix
                                    ausführen. Steht auch in einer entsprechenden Meldung drin.
                                      @balkonfarmer
                                      iob fix
                                      Balkonfarmer
                                      Hab ich jetzt gemacht.
                                      jetzt steht das drin:
                                      ```bash
                                      Script v.2025-03-08
                                      *** BASE SYSTEM ***
                                       Static hostname: PiHole
                                             Icon name: computer
                                                Kernel: Linux 6.12.34+rpt-rpi-v8
                                          Architecture: arm64
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                       21:04:58 up  2:52,  2 users,  load average: 0.61, 0.52, 0.37
                                      CPU threads: 4
                                      Operating System is the current Debian stable version codenamed 'bookworm'!
                                      Current issues:
                                                     Local time: Wed 2025-07-09 21:04:58 CEST
                                                 Universal time: Wed 2025-07-09 19:04:58 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      pi
                                      HOME=/home/pi
                                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            4.0G        303M        3.2G        8.5M        565M        3.7G
                                      Swap:           536M          0B        536M
                                      Total:          4.5G        303M        3.7G
                                      Active iob-Instances:   0
                                               3795 M total memory
                                                289 M used memory
                                                252 M active memory
                                                352 M inactive memory
                                               3043 M free memory
                                                 48 M buffer memory
                                                490 M swap cache
                                                511 M total swap
                                                  0 M used swap
                                                511 M free swap
                                      top - 21:04:59 up  2:52,  2 users,  load average: 0.61, 0.52, 0.37
                                      Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   3795.9 total,   3043.2 free,    290.0 used,    539.3 buff/cache
                                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3505.9 avail Mem
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                      tmpfs          tmpfs     380M  8.1M  372M   3% /run
                                      /dev/sda2      ext4       14G  3.2G   11G  25% /
                                      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                                      /dev/sda1      vfat      510M   57M  454M  11% /boot/firmware
                                      [Wed Jul  9 18:12:26 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:17:D0:59 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=f11aec40-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GE
                                      [Wed Jul  9 18:12:30 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                                      [Wed Jul  9 18:12:32 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
                                      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      885M    /var/
                                      205M    /var/cache
                                      199M    /var/cache/apt
                                      168M    /var/lib
                                      135M    /var/lib/apt/lists
                                      Archived and active journals take up 6.9M in the file system.
                                      2.8M    /opt/iobroker/backups/
                                      69M     /opt/iobroker/iobroker-data/
                                      63M     /opt/iobroker/iobroker-data/files
                                      47M     /opt/iobroker/iobroker-data/files/admin.admin
                                      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                                      8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
                                      5.3M    /opt/iobroker/iobroker-data/objects.jsonl
                                      3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
                                      3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
                                      3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
                                      USB-Devices by-id:
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/nodejs         v20.19.3
                                      /usr/bin/node           v20.19.3
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      /usr/bin/corepack       0.32.0
                                      nodejs:
                                        Installed: 20.19.3-1nodesource1
                                        Candidate: 20.19.3-1nodesource1
                                        Version table:
                                       *** 20.19.3-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                           20.19.2-1nodesource1 1001
                                           20.19.1-1nodesource1 1001
                                           20.19.0-1nodesource1 1001
                                           20.18.3-1nodesource1 1001
                                           20.18.2-1nodesource1 1001
                                           20.18.1-1nodesource1 1001
                                           20.18.0-1nodesource1 1001
                                           20.17.0-1nodesource1 1001
                                           20.16.0-1nodesource1 1001
                                           20.15.1-1nodesource1 1001
                                           20.15.0-1nodesource1 1001
                                           20.14.0-1nodesource1 1001
                                           20.13.1-1nodesource1 1001
                                           20.13.0-1nodesource1 1001
                                           20.12.2-1nodesource1 1001
                                           20.12.1-1nodesource1 1001
                                           20.12.0-1nodesource1 1001
                                           20.11.1-1nodesource1 1001
                                           20.11.0-1nodesource1 1001
                                           20.10.0-1nodesource1 1001
                                           20.9.0-1nodesource1 1001
                                           20.8.1-1nodesource1 1001
                                           20.8.0-1nodesource1 1001
                                           20.7.0-1nodesource1 1001
                                           20.6.1-1nodesource1 1001
                                           20.6.0-1nodesource1 1001
                                           20.5.1-1nodesource1 1001
                                           20.5.0-1nodesource1 1001
                                           20.4.0-1nodesource1 1001
                                           20.3.1-1nodesource1 1001
                                           20.3.0-1nodesource1 1001
                                           20.2.0-1nodesource1 1001
                                           20.1.0-1nodesource1 1001
                                           20.0.0-1nodesource1 1001
                                           18.19.0+dfsg-6~deb12u2 500
                                              500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                           18.19.0+dfsg-6~deb12u1 500
                                              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                      ioBroker Status
                                      No connection to states 127.0.0.1:6379[redis]
                                      Hosts:
                                      js-controller:  7.0.6
                                      admin:          "admin" not found
                                      javascript:     "javascript" not found
                                      Adapter State
                                      Objects and States
                                      Objects:        2
                                      States:         1
                                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                      Pending Updates: 0
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4527       621/sshd: /usr/sbin
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          4529       621/sshd: /usr/sbin
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2646       478/avahi-daemon: r
                                      udp        0      0 0.0.0.0:48814           0.0.0.0:*                           104        2648       478/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                104        2647       478/avahi-daemon: r
                                      udp6       0      0 :::47074                :::*                                104        2649       478/avahi-daemon: r
                                      udp6       0      0 fe80::523d:8bd6:ead:546 :::*                                0          5567       558/NetworkManager
                                      2025-07-09 21:04:15.162  - info: host.PiHole iobroker _restart
                                      2025-07-09 21:04:21.369  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                      2025-07-09 21:04:21.375  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                      2025-07-09 21:04:21.376  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                      2025-07-09 21:04:21.378  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                      2025-07-09 21:04:51.393  - error: host.PiHole No connection to databases possible, restart
                                      2025-07-09 21:04:51.409  - info: host.PiHole iobroker _restart
                                      2025-07-09 21:04:57.617  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                      2025-07-09 21:04:57.623  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                      2025-07-09 21:04:57.625  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                      2025-07-09 21:04:57.626  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                      2025-07-09 21:05:27.642  - error: host.PiHole No connection to databases possible, restart
                                      2025-07-09 21:05:27.650  - info: host.PiHole iobroker _restart
                                      2025-07-09 21:05:34.095  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                      2025-07-09 21:05:34.103  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                      2025-07-09 21:05:34.104  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                      2025-07-09 21:05:34.106  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                      2025-07-09 21:06:04.121  - error: host.PiHole No connection to databases possible, restart
                                      2025-07-09 21:06:04.129  - info: host.PiHole iobroker _restart
                                      2025-07-09 21:06:10.367  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
                                      2025-07-09 21:06:10.374  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                                      2025-07-09 21:06:10.375  - info: host.PiHole hostname: PiHole, node: v20.19.3
                                      2025-07-09 21:06:10.376  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
                                      2025-07-09 21:06:40.404  - error: host.PiHole No connection to databases possible, restart
                                      2025-07-09 21:06:40.413  - info: host.PiHole iobroker _restart
                                      kann man da noch etwas retten?
                                      • B Balkonfarmer
                                        ```bash
                                        Script v.2025-03-08
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        CPU threads: 4
                                        Current issues:
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        pi
                                        HOME=/home/pi
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Swap:           536M          0B        536M
                                                 3795 M total memory
                                                  289 M used memory
                                                  252 M active memory
                                                 3043 M free memory
                                                   48 M buffer memory
                                                  490 M swap cache
                                                  511 M total swap
                                                    0 M used swap
                                                  511 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        885M    /var/
                                        205M    /var/cache
                                        199M    /var/cache/apt
                                        168M    /var/lib
                                        USB-Devices by-id:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Hosts:
                                        Adapter State
                                        Objects and States
                                        Objects:        2
                                        States:         1
                                        Pending Updates: 0
                                        @balkonfarmer
                                        Hast du auch zuvor 'redis' installiert?
                                        Die alte Installation lief wohl offenbar darauf.
                                        sudo apt update
                                        apt policy redis
                                          @balkonfarmer
                                          sudo apt update
                                          apt policy redis
                                          Balkonfarmer
                                          achso, muss ich das jetzt immer installieren, wenn ich eine Wiederherstellung mache?
