  4. ioBroker.cloudless-homeconnect Adapter konfigurieren
    6.7k
9 Beiträge 4 Kommentatoren 958 Aufrufe 3 Beobachtet
    Shakira1972
    Guten Tag,
    habe den ioBroker.cloudless-homeconnect Adapter installiert, da ich mit den HomeConnect Adapter immer Probleme habe:
    homeconnect.0
    2025-07-03 05:29:11.706	error	Start Event Stream Error: {"type":"error","status":429,"message":"Too Many Requests"}
    homeconnect.0
    2025-07-03 05:29:11.706	error	429 Too Many Requests
    Nun aber zu meinen Problem,
    nach der Installation des cloudless-homeconnect Adapter gab es meiner Ansicht nach, keine Fehlermeldungen:
    host.raspberrypi
    2025-07-03 06:31:50.139	info	iobroker exit 0
    host.raspberrypi
    2025-07-03 06:31:48.979	info	iobroker Updating objects from io-package.json for adapter "cloudless-homeconnect" with version "1.6.2"
    host.raspberrypi
    2025-07-03 06:31:48.956	info	iobroker upload [0] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/jsonConfig.json jsonConfig.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.943	info	iobroker upload [1] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.930	info	iobroker upload [2] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.916	info	iobroker upload [3] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.897	info	iobroker upload [4] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.883	info	iobroker upload [5] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.871	info	iobroker upload [6] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.860	info	iobroker upload [7] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/it/translations.json i18n/it/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.846	info	iobroker upload [8] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.832	info	iobroker upload [9] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/es/translations.json i18n/es/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.819	info	iobroker upload [10] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/en/translations.json i18n/en/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.806	info	iobroker upload [11] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/i18n/de/translations.json i18n/de/translations.json application/json
    host.raspberrypi
    2025-07-03 06:31:48.797	info	iobroker upload [12] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/cloudless-homeconnect.png cloudless-homeconnect.png image/png
    host.raspberrypi
    2025-07-03 06:31:48.783	info	iobroker upload [13] cloudless-homeconnect.admin /opt/iobroker/node_modules/iobroker.cloudless-homeconnect/admin/cloudless-homeconnect-880x800.png cloudless-homeconnect-880x800.png image/png
    host.raspberrypi
    2025-07-03 06:31:48.632	info	iobroker added 26 packages in 17s243 packages are looking for funding run `npm fund` for details
    host.raspberrypi
    2025-07-03 06:31:43.339	info	iobroker npm warn skipping integrity check for git dependency ssh://git@github.com/eifel-tech/ioBroker.cloudless-homeconnect.git
    host.raspberrypi
    2025-07-03 06:31:31.626	info	iobroker Installing eifel-tech/ioBroker.cloudless-homeconnect#c133633fb50e28e55169099f4f7c0617ca72e835... (System call)
    host.raspberrypi
    2025-07-03 06:31:31.621	info	iobroker NPM version: 10.8.2
    host.raspberrypi
    2025-07-03 06:31:31.257	info	iobroker install eifel-tech/ioBroker.cloudless-homeconnect#c133633fb50e28e55169099f4f7c0617ca72e835
    host.raspberrypi
    2025-07-03 06:31:27.580	info	iobroker url https://github.com/eifel-tech/ioBroker.cloudless-homeconnect.git --host raspberrypi --debug
    Normalerweise, zumindest bei den anderen Apps, erscheint unter den Instanzen dann die App und ich kann dort Konfigurieren. Aber hier finde ich diese App nicht.
    Unter Objekte kann ich lediglich einen leeren Ordner finden.
    Laut Beschreibung (https://github.com/eifel-tech/ioBroker.cloudless-homeconnect/blob/master/docs/de/README.md#iobrokercloudless-homeconnect)
    "In der Adapter-Config muss der Homeconnect App Benutzername und Passwort eingetragen werden."
    Wo finde ich diese?
    Danke für Eure Hilfe.
    Noch ein paar Infos:
    Node.js: v20.19.3
    Port 443 am Gerät freigeschaltet
    Bosch Spülmaschine SMS6ZCI49E/08
    • S Shakira1972
      Guten Tag,
      homeconnect.0
      homeconnect.0
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      Wo finde ich diese?
      Node.js: v20.19.3
      arteckA Offline
      arteckA Offline
      arteck
      @oliver1972 die instanz musst du schon manuell hinzufügen wenn du von GIT installierst..
      • arteckA arteck
        Shakira1972
        @arteck Gibt es hierfür eine Anleitung für Anfänger?
        HomoranH mcm1957M 2 Antworten Letzte Antwort
        • arteckA Offline
          arteckA Offline
          arteck
          komm so schwer ist es nicht
          klick
          klick
          • S Shakira1972
            @oliver1972 sagte in ioBroker.cloudless-homeconnect Adapter konfigurieren:
            sogar mit video!
            https://www.iobroker.net/#de/documentation/tutorial/adapter.md
            und das seit Jahren in der offiziellen Doku
            • arteckA arteck
              klick
              klick
              Shakira1972
              @arteck
              Danke!
              S mcm1957M 2 Antworten Letzte Antwort
              • S Shakira1972
                @arteck
                Danke!
                Shakira1972
                Noch eine Frage, wahrscheinlich auch einfach zu lösen.
                Der Adapter ist nun Grün, aber die Werte sind nicht aktuell.
                In der Beschreibung steht: Es kann vorkommen, dass das Gerät nach Laden der Konfiguration nicht angesprochen werden kann. Dann liegt im lokalen Netz kein DNS-Eintrag für die Domain des Geräts vor. Außer diesen im Netzwerk einzurichten, kann im Datenpunkt info.config bei host einfach die lokale IP des Gerätes eingetragen werden.
                Wenn ich die Datei info.config öffne:
                  "_id": "cloudless-homeconnect.0.info.config",
                  "type": "state",
                  "common": {
                    "role": "json",
                    "name": {
                      "en": "Device config",
                      "de": "Gerätekonfiguration",
                      "ru": "Настройка устройства",
                      "pt": "Configuração do dispositivo",
                      "nl": "Apparaatconfiguratie",
                      "fr": "Configuration du périphérique",
                      "it": "Configurazione del dispositivo",
                      "es": "Configuración de dispositivo",
                      "pl": "Konfiguracja urządzenia",
                      "uk": "Налаштування пристрою",
                      "zh-cn": "设备配置"
                    "type": "string",
                    "read": true,
                    "write": true,
                    "def": ""
                  "native": {},
                  "from": "system.adapter.cloudless-homeconnect.0",
                  "ts": 1751537843281,
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                    "owner": "system.user.admin",
                  "user": "system.user.admin"
                hier gibt es keinen Punkt der Host heißt, wo ich die IP eintragen könnte...
                Danke!
                • S Shakira1972
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @oliver1972 said in ioBroker.cloudless-homeconnect Adapter konfigurieren:
                  Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                  GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                  Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                  Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                  Und falls es irgendwie unklar ist:
                  ioBroker unterstützt folgende Arten von Installation:
                  • aus dem STABLE Repository
                    Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                  • aus dem LATEST Repository
                    Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                  • direkt von GITHUB
                    Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                  • direkt von npm
                    Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                  Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit Sicherheit minimalistisch.
                  @mcm1957
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • S Shakira1972
                    @arteck
                    Danke!
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @oliver1972
                    Schreib doch bitte den Entwickler des Adapters an und ersuche ihn den Adapter in die Repos aufnehmen zu lassen.
                    Installationen direkt von Github sollten als ALPHA Testversionen betrachtet werden. Setz dich am Besten direkt mit dem Entwickler des Adapters zusammen um Hilfe zu erhaltennubd den Status abzuklären.
                    EDIT
                    Direktes Editieren von Objecten zu empfehlen spricht eher für ein Verbesserungspotenzial am Adapter. Der Dev könnte die notwendige Parametrisierung in der Admin UI einbauen. Der Aufwand sollte minimal sein. Evcerstell ein Issue beim Adapter damit das verbessert werden kann.
