  3. Entwicklung
  4. Adapter Worx Landroid v3.x.x
    6.3k
814 Beiträge 91 Kommentatoren 248.1k Aufrufe 78 Beobachtet
    @joergk-0 sagte in Adapter Worx Landroid v3.x.x:
    Device Header: {"date":"Fri, 27 Jun 2025 16:20:24 GMT","content-type":"application/json","transfer-encoding":"chunked","connection":"close","server":"nginx","retry-after":"5643575","x-ratelimit-throttle":"true","cache-control":"no-cache, private","x-robots-tag":"noindex, nofollow"}
    Ich habe keinen Device Header, sondern nur Token Header und Login Header und die sehen so aus:
    Token Header: {"date":"Sat, 28 Jun 2025 07:10:48 GMT","content-type":"text/plain","content-length":"21","connection":"close","cf-ray":"956b5dd25ab96c45-VIE","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=":443"; ma=86400"}
    Ich sehe also nicht wie lange ich gesperrt bin.
    Das Startlog des Adapters (GIT-Version) sieht komplett so aus:
    2025-06-28 12:48:25.265 - info: worx.0 (5394) Got terminate signal TERMINATE_YOURSELF
    2025-06-28 12:48:25.266 - info: worx.0 (5394) terminating
    2025-06-28 12:48:25.267 - debug: worx.0 (5394) Plugin sentry destroyed
    2025-06-28 12:48:25.267 - info: worx.0 (5394) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-06-28 12:48:25.768 - info: worx.0 (5394) terminating
    2025-06-28 12:48:29.584 - debug: worx.0 (5604) Redis Objects: Use Redis connection: 127.0.0.1:6379
    2025-06-28 12:48:29.593 - debug: worx.0 (5604) Objects client ready ... initialize now
    2025-06-28 12:48:29.594 - debug: worx.0 (5604) Objects create System PubSub Client
    2025-06-28 12:48:29.594 - debug: worx.0 (5604) Objects create User PubSub Client
    2025-06-28 12:48:29.629 - debug: worx.0 (5604) Objects client initialize lua scripts
    2025-06-28 12:48:29.631 - debug: worx.0 (5604) Objects connected to redis: 127.0.0.1:6379
    2025-06-28 12:48:29.637 - debug: worx.0 (5604) Redis States: Use Redis connection: 127.0.0.1:9000
    2025-06-28 12:48:29.653 - debug: worx.0 (5604) States create System PubSub Client
    2025-06-28 12:48:29.653 - debug: worx.0 (5604) States create User PubSub Client
    2025-06-28 12:48:29.716 - debug: worx.0 (5604) States connected to redis: 127.0.0.1:9000
    2025-06-28 12:48:29.736 - debug: worx.0 (5604) Plugin sentry Initialize Plugin (enabled=true)
    2025-06-28 12:48:30.002 - info: worx.0 (5604) starting. Version 3.2.5 (non-npm: iobroker-community-adapters/ioBroker.worx) in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.3, js-controller: 7.0.6
    2025-06-28 12:48:30.066 - debug: worx.0 (5604) Use old blocking data!
    2025-06-28 12:48:30.114 - info: worx.0 (5604) Reset Login counter. Restarting now!
    2025-06-28 12:48:30.119 - info: worx.0 (5604) Got terminate signal TERMINATE_YOURSELF
    2025-06-28 12:48:30.120 - info: worx.0 (5604) terminating
    2025-06-28 12:48:30.120 - debug: worx.0 (5604) Plugin sentry destroyed
    2025-06-28 12:48:30.120 - info: worx.0 (5604) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-06-28 12:48:30.122 - debug: worx.0 (5604) User and password have not been changed!
    2025-06-28 12:48:30.122 - debug: worx.0 (5604) Server have not been changed!
    2025-06-28 12:48:30.152 - info: worx.0 (5604) Login to worx
    2025-06-28 12:48:30.156 - debug: worx.0 (5604) Session value: 0
    2025-06-28 12:48:30.156 - info: worx.0 (5604) Start login
    2025-06-28 12:48:30.417 - error: worx.0 (5604) AxiosError: Request failed with status code 429
    2025-06-28 12:48:30.417 - info: worx.0 (5604) The maximum number of requests has been reached!
    2025-06-28 12:48:30.417 - error: worx.0 (5604) Login Header: {"date":"Sat, 28 Jun 2025 10:48:30 GMT","content-type":"text/plain","content-length":"21","connection":"keep-alive","cf-ray":"956c9cb50b105b9b-VIE","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=\":443\"; ma=86400"}
    2025-06-28 12:48:30.417 - error: worx.0 (5604) "429 TOO MANY REQUESTS"
    2025-06-28 12:48:30.621 - info: worx.0 (5604) terminating
    2025-06-28 12:48:34.342 - debug: worx.0 (5661) Redis Objects: Use Redis connection: 127.0.0.1:6379
    2025-06-28 12:48:34.353 - debug: worx.0 (5661) Objects client ready ... initialize now
    2025-06-28 12:48:34.354 - debug: worx.0 (5661) Objects create System PubSub Client
    2025-06-28 12:48:34.354 - debug: worx.0 (5661) Objects create User PubSub Client
    2025-06-28 12:48:34.419 - debug: worx.0 (5661) Objects client initialize lua scripts
    2025-06-28 12:48:34.423 - debug: worx.0 (5661) Objects connected to redis: 127.0.0.1:6379
    2025-06-28 12:48:34.431 - debug: worx.0 (5661) Redis States: Use Redis connection: 127.0.0.1:9000
    2025-06-28 12:48:34.488 - debug: worx.0 (5661) States create System PubSub Client
    2025-06-28 12:48:34.489 - debug: worx.0 (5661) States create User PubSub Client
    2025-06-28 12:48:34.521 - debug: worx.0 (5661) States connected to redis: 127.0.0.1:9000
    2025-06-28 12:48:34.542 - debug: worx.0 (5661) Plugin sentry Initialize Plugin (enabled=true)
    2025-06-28 12:48:34.724 - info: worx.0 (5661) starting. Version 3.2.5 (non-npm: iobroker-community-adapters/ioBroker.worx) in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.3, js-controller: 7.0.6
    2025-06-28 12:48:34.747 - debug: worx.0 (5661) Use old blocking data!
    2025-06-28 12:48:34.756 - debug: worx.0 (5661) User and password have not been changed!
    2025-06-28 12:48:34.756 - debug: worx.0 (5661) Server have not been changed!
    2025-06-28 12:48:34.782 - info: worx.0 (5661) Login to worx
    2025-06-28 12:48:34.787 - debug: worx.0 (5661) Session value: 0
    2025-06-28 12:48:34.788 - info: worx.0 (5661) Start login
    2025-06-28 12:48:35.051 - error: worx.0 (5661) AxiosError: Request failed with status code 429
    2025-06-28 12:48:35.051 - info: worx.0 (5661) The maximum number of requests has been reached!
    2025-06-28 12:48:35.051 - error: worx.0 (5661) Login Header: {"date":"Sat, 28 Jun 2025 10:48:34 GMT","content-type":"text/plain","content-length":"21","connection":"keep-alive","cf-ray":"956c9cd1ff6e3264-VIE","x-ratelimit-throttle":"true","cf-cache-status":"DYNAMIC","server":"cloudflare","alt-svc":"h3=\":443\"; ma=86400"}
    2025-06-28 12:48:35.051 - error: worx.0 (5661) "429 TOO MANY REQUESTS"
    JoergK 0
    #470
    @dr-bakterius said in Adapter Worx Landroid v3.x.x:
    Ich würde mal vermuten daß Deine Sperrzeit in "ma=86400" steht, also die üblichen 24h
    Dr. BakteriusD 1 Antwort Letzte Antwort
    • J JoergK 0
      Dr. BakteriusD Online
      Dr. Bakterius
      #471
      Das habe ich mir auch gedacht. Leider war die Sperre nach 25 Stunden immer noch aktiv. Ich werde jetzt zusätzlich den Roboter ausschalten. Dann kann wirklich nichts mehr auf meinen Account zugreifen versuchen.
        saeft_2003
        #472
        Ich bin auch betroffen... Das Problem ist das ich es nicht hinbekomme :-(
        Ich hatte jetzt schon mehrfach 24 Stunden gewartet app und adapter sind gelöscht. Nach 24 Stunden komm ich wieder auf id.worx.com dann installiere ich die app und will mich anmelden --> langsamer!
        Langsam bekomme ich einen dicken Hals. Habt ihr noch Tipps was ich noch tun kann?
        L 1 Antwort Letzte Antwort
        • S saeft_2003
          L Online
          L Online
          Lucky_ESA
          #473
          @saeft_2003 Wenn man hier liest dann ist es klar, dass das Login vielleicht nach 24h freigegeben wird aber der nächste API Abruf ist für 72 Tage blockiert. Das schafft man eigentlich nur mit einer DDoS Attacke. Wann hat es dich denn erwischt??? Hast du noch das Logfile? Bei so einer Sperre muss das komplett rote Einträge haben.
          Die aktuelle Version 3.2.6 ist bald verfügbar. Habe dort zur Sicherheit ein RateLimit hinzugefügt. Allerdings nur für die API Abfrage und nicht für MQTT...Kommt noch...
          Gruß//Lucky
          pajdaP 1 Antwort Letzte Antwort
          • L Lucky_ESA
            Gruß//Lucky
            pajdaP Offline
            pajdaP Offline
            pajda
            #474
            @lucky_esa
            Hallo an alle ich gehöre auch zu Betroffenen
            Meine frage haben alle Betroffenen auch FindMyLandroid
            WA0862 verbaut oder ist das nur bei mir so da ich mir vorstellen könnte das das den fehler machen könnte "FindMyLandroid
            WA0862"
            Lg.
            • pajdaP pajda
              @lucky_esa
              WA0862"
              Lg.
              martenn
              #475
              Ich bin auch seit 3 Tagen von dem Problem betroffen, habe meinen Adapater seit Freitag deaktiviert und auch auf dem Smartphone habe ich die App nicht aktiv genutzt. Trotzdem bekomme ich noch immer die Fehlermeldung, dass ich zu viele Anfragen stellen würde.
              Ich habe gestern abend allerdings einen interessanten Beitrag in einer Worx-Landroid-Gruppe auf Facebook gelesen. Dort hat ein User von den identischen Problemen berichtet und er nutzt keine Smarthome-Integrationen, sondern nur die native App von Worx.
              Es scheint also offenbar ein generelles Problem bei Worx zu geben. Irgendwer schrieb in der FB-Gruppe auch, dass die wohl seit Tagen mit DDOS-Attacken zu kämpfen haben und das ggf. deren Abwehrmaßnahmen zu unbeabsichtigten Blocks fürhren.
              W 1 Antwort Letzte Antwort
              • M martenn
                W Offline
                W Offline
                Wuschl
                schrieb am zuletzt editiert von Wuschl
                #476
                @martenn Ich bin mittlerweile überzeugt davon daß es ein Problem bei Worx ist. Mein Adapter läuft absolut zuverlässig 3.2.5.
                Ich hatte mittlerweile die 2. Sperre diese Woche, aber erst nachdem ich die App geöffnet hatte. Wir haben auf unseren Grundstück 2 Worx laufen, mit 2 verschiedenen Accounts. Einer wird nur über den Adapter gesteuert, der andere nur über die App.
                Einmal die App aufgerufen, zack, beide gesperrt... gestern Nachmittag, dann kam die Fehlermeldung 429 im Adapter, aber ich konnte den einen Worx über den Adapter um 20 Uhr ganz normal starten. Ich habe nichts gestoppt oder gelöscht, die App und der Adapter liefen ganz normal weiter
                Klar, laufen über die selbe Internet IP.
                Q 1 Antwort Letzte Antwort
                • W Wuschl
                  Q Offline
                  Q Offline
                  quinti
                  schrieb am zuletzt editiert von quinti
                  #477
                  Zitat aus facebook gruppenbeitrag:
                  Das Problem wird wohl durch verschärfte Drosselungsmaßnahmen seitens Positec hervorgerufen.
                  Diese sind laut Entwicklern aktuell notwendig, da scheinbar seit über einer Woche DDOS-Angriffe gegen die Worx-Cloud gefahren werden.
                  Hier die orginale Aussage:
                  "We're having issues with a (probably) involuntary DDOS of MQTT connect packages in the last 12 days. ...
                  The DDoS issues I've mentioned … are getting worse. We've deployed a more aggressive throttling mechanics to contain the issue, including disabling user accounts for longer periods. "
                  Die verschärften Drosselungsmaßnahmen scheinen Nebenwirkungen zu haben, besonders häufig werden aktuell Probleme im Zusammenhang mit ioBroker gemeldet.
                  Die Aussage "(...) including disabling user accounts for longer periods" erklärt, warum die Sperrungen nicht wie erwartet nach 24 Stunden enden.
                  Es scheint außerdem so zu sein, dass jeder Loginversuch innerhalb der Sperrzeit dazu führt, dass die Sperrung verlängert wird.
                  Daher kann ich aktuell nur empfehlen, sämtliche Hausautomatisierungs-Software auszuschalten und ein paar Tage abzuwarten.
                  Und währenddessen die Worx-App und den Worx-Account nicht zu benutzen.
                  Wenn das so stimmt hilft wohl alles nix ausser abwarten, Eistee trinken und zugucken wie aus rasen Wiese wird.
                  falke69F HomoranH 2 Antworten Letzte Antwort
                  • Dr. BakteriusD Online
                    Dr. Bakterius
                    #478
                    So etwas darf sich ein Unternehmen mit seinen Kunden nicht erlauben! Sie machen damit das Eigentum ihrer Kunden unbenutzbar. Ein Armutszeugnis ist auch, wenn sie reguläre Zugriffe von DDOS nicht unterscheiden können. Da dieses Problem scheinbar schon länger andauert, sollten sie das schon im Griff haben.
                    Allen die die API regulär verwenden einfach zu sperren, dazu noch ohne Warnung oder Hinweis für wie lange, kann Positec noch teuer zu stehen kommen.
                    Wenn die das in den nächsten Tagen nicht in den Griff bekommen, werde ich auf Wandlung des Kaufvertrags bei meinem Händler bestehen. Ich habe noch Gewährleistung und Garantie.
                    hsteinmeH 1 Antwort Letzte Antwort
                    • L Online
                      L Online
                      Lucky_ESA
                      schrieb am zuletzt editiert von Lucky_ESA
                      #479
                      Ihr seid dann wohl nicht mehr alleine Issue
                      Ab hier solltet ihr den Intervall auf 360 stellen und ALLE Scripte deaktivieren. Die Supportanfragen sollten nun auch nicht mehr nett sein. Bitte davon Erzählen das ihr 72 Tage gesperrt seit.
                      Edit: Bei Openhab melden sich nun auch die ersten User....
                      Gruß//Lucky
                        hsteinmeH Online
                        hsteinmeH Online
                        hsteinme
                        #480
                        @dr-bakterius sagte in Adapter Worx Landroid v3.x.x:
                        Allen? Ist dies wirklich so? Bei mir z.B. hat noch keine Sperre zugeschlagen trotz Nutzung von Worx und Kress 3rd pParty Apps.
                          Matt77CHE
                          #481
                          Bei mir hat es gestern zugeschlagen....
                          • P Powertrain01
                            Hallo zusammen ich hab nun mehrfach iob update /iob upgrade /iob fix gemach
                            auch mehrfach versucht npm install Axios alles schein ohne Probleme gelaufen zu sein.
                            aber beim Update des Works Adapter bekomme ich immer noch die Meldung, dass Axios nicht gefunden wird. was kann ich noch tun dammit ich den Adapter upgedatet bekomme.
                            L Online
                            L Online
                            Lucky_ESA
                            #482
                            @powertrain01 sagte in Adapter Worx Landroid v3.x.x:
                            Bei nächsten Release sollte es funktionieren.
                            • M Matt77CHE
                              L Online
                              L Online
                              Lucky_ESA
                              #483
                              @matt77che sagte in Adapter Worx Landroid v3.x.x:
                              Was hast du im Intervall eingetragen und hast du einen Haken bei Aktualisierung der Daten nach der Token-Aktualisierung. gesetzt? Mich würde derzeit das Limit interessieren.
                              • L Lucky_ESA
                                Matt77CHE
                                #484
                                @lucky_esa
                                Aktualisierungsintervall = 60min
                                Kein Haken gesetzt
                                • Q quinti
                                  falke69F Offline
                                  falke69F Offline
                                  falke69
                                  #485
                                  @quinti
                                  ich habe schon seit einigen Tagen den Adapter deaktiviert und trotzdem bekomme ich noch diese dusslige Fehlermeldung in der App.
                                  Habe gereade ne Mail an den Support geschrieben und mich über den Mist beschwert.
                                  Bin gerade im Urlaub und kann nicht mal über die App das Gerät steuern.
                                  Wenn man wenigstens irgendwie die Cloud umgegen könnte und im internen Netzwerk die Daten hinundher schieben könnte. Irgendeine Schnittstelle müsste es doch geben, die man anzapfen könnte und vielleicht zu Hause die Cloud zu "simulieren".
                                  • M Matt77CHE
                                    @lucky_esa
                                    Kein Haken gesetzt
                                    L Online
                                    L Online
                                    Lucky_ESA
                                    #486
                                    @lucky_esa
                                    Kein Haken gesetzt
                                    Das wären dann pro Tag:
                                    24 x API Daten Abfragen - Der Intervall
                                    24 x API Refreshtoken
                                    1 x Überprüfung Firmware
                                    (x) x ActivityLog - Immer wenn sich der Status ändern also Max 15 x
                                    Das wären 64 Anfragen...Das ist nicht wirklich viel.
                                    Gruß//Lucky
                                    • falke69F falke69
                                      @quinti
                                      L Online
                                      L Online
                                      Lucky_ESA
                                      #487
                                      @falke69
                                      Das ist leider nicht möglich. Ich habe den automatsichen Mähplan aktiviert daher würder meiner immer weiter mähen, auch ohne Cloud.
                                      Ich bin derzeit noch nicht gesperrt. Vielleich weil ein Pool auf meinem Rasen steht und ich seit 10 Tagen den Party Modus aktiv habe.
                                      Gruß//Lucky
                                      N falke69F 2 Antworten Letzte Antwort
                                      • L Lucky_ESA
                                        @falke69
                                        Gruß//Lucky
                                        N Offline
                                        N Offline
                                        Nitro25NOH
                                        #488
                                        Moin zusammen, ich habe seit ca 2 Wochen Probleme mit dem Adapter und seit zwei Tagen die Hier beschriebenen Probleme mit dem „Gesamtpaket“. Mein lief jetzt 6 Jahre ohne ein derartig großes Problem!
                                        Ich brauche den Adapter weil ich mit den Meldungen über Blockly den Begrenzungsdraht schalte und dadurch Türen öffne/schließe und ihn auf verschiedene Fahrwege zu den Jeweiligen Mähzohnen schicke.
                                        Beim durchstöbern des Netzes nach weiteren Meldungen außerhalb der iOB-Welt bin ich auf die aktuellen Bewertungen von Worx bei Trustpilot gestoßen! 😧 Was ist den in letzter Zeit bei denen passiert. Da bei mir alles super lief, habe ich das Ding immer weiter empfohlen. Hab schon ein schlechtes Gewissen deswegen.
                                        Hat sich die Firma wirklich so ins Negative verändert?
                                        Ich hoffe wirklich auf eine Schnelle Lösung für unser Problem. Wenn die Bewertung über den Kundenservice lese mache ich mir da aber schon Sorgen das hier was passiert!
                                        Grüße Christian
                                        • L Lucky_ESA
                                          @falke69
                                          Gruß//Lucky
                                          falke69F Offline
                                          falke69F Offline
                                          falke69
                                          #489
                                          @lucky_esa
                                          Das ist wirklich schade.
                                          Selbst wenn ich den Mähplan aktiviert hätte, müsste ich dann in den Moment meine Bewässerung deaktivieren.
                                          Was natürlich recht umständlich ist, wenn der Adapter aufgrund der Tatsache, dass die Worx ein Problem mit der Cloud hat, nicht nutzbar ist, weil man blockiert wird.
                                          Ich habe aktuell auch keinen Schimmer, wie lange ich noch blockiert werde.
                                          In der App konnte ich vorhin sehen, das er aufgeladen ist und startklar wäre.
                                          Ein Versuch den Mäher zu starten, brachte mir den Fehler, das der Mäher offline sei und nicht zu erreichen.
                                          Einmal versucht zu aktualisieren, brachte mir die verdammte Eieruhr wieder.
