  3. Entwicklung
  4. Adapter Worx Landroid v3.x.x
    6.3k
814 Beiträge 91 Kommentatoren 248.0k Aufrufe 78 Beobachtet
  • N Offline
    N Offline
    NewPaint2
    #369
    irgendwas hängt immernoch: Adapter wird gelb und verbindet sich erst wieder sauber wenn ich den roten Button löschen der Sitzungsdaten drücke.
    worx.0
    2025-06-24 12:24:58.389	info	terminating
    worx.0
    2025-06-24 12:24:57.888	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    worx.0
    2025-06-24 12:24:57.886	info	terminating
    worx.0
    2025-06-24 12:24:57.885	info	Got terminate signal TERMINATE_YOURSELF
    worx.0
    2025-06-24 12:24:11.277	warn	Serial number 2020302091010020598D was not found. Please delete the object tree worx.0.2020302091010020598D.
    worx.0
    2025-06-24 12:24:11.264	info	Start check devices object!
    worx.0
    2025-06-24 12:24:11.261	warn	No mower found to start mqtt
    worx.0
    2025-06-24 12:24:11.261	info	Start MQTT connection
    worx.0
    2025-06-24 12:24:11.242	error	AxiosError: timeout of 5000ms exceeded
    worx.0
    2025-06-24 12:24:06.231	error	AxiosError: timeout of 5000ms exceeded
    worx.0
    2025-06-24 12:24:01.221	info	Start login
    worx.0
    2025-06-24 12:24:01.216	error	AxiosError: timeout of 5000ms exceeded
    worx.0
    2025-06-24 12:23:55.965	info	Login to worx
    worx.0
    2025-06-24 12:23:55.963	info	Changed timeout for edgecut to 5000
    worx.0
    2025-06-24 12:23:55.963	info	Use new aws-iot-device-sdk-v2.
    worx.0
    2025-06-24 12:23:55.834	info	starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.2, js-controller: 7.0.7
    • N NewPaint2
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      worx.0
      haselchenH Offline
      haselchenH Offline
      haselchen
      #370
      Nun hats mich aus dem Nichts auch getroffen.
      Jedenfalls was das Log betrifft
      worx.0	2025-06-24 15:42:03.967	info	MQTT ERROR: Error: Error: libaws-c-mqtt: AWS_ERROR_MQTT_NOT_CONNECTED, The requested operation is invalid as the connection is not open.
      worx.0	2025-06-24 15:42:03.967	warn	Error mqtt connection!
      worx.0	2025-06-24 15:42:03.966	info	awsMqtt: Error: libaws-c-mqtt: AWS_ERROR_MQTT_NOT_CONNECTED, The requested operation is invalid as the connection is not open.
      • ? Offline
        #371
        @haselchen
        geht die App noch?
          @haselchen
          geht die App noch?
          haselchenH Offline
          haselchenH Offline
          haselchen
          #372
          @neuschwansteini
          Ja, die läuft.
          Ich hab hier die Tage mitgelesen und mich gewundert, wieso ich keine Probleme habe.
          Bis auf das die DP ein wenig später aktualisiert wurden , war alles okay.
          Heute dann die Einträge im Log gesehen.
          Wie gesagt, ich habe am Gerät, an der App , am Adapter nüscht gemacht.
          • haselchenH haselchen
            @neuschwansteini
            Ja, die läuft.
            #373
            @haselchen
            ich hatte auch nichts gemacht, ausser den iobroker am Nachmittag 3 oder 4 mal neu gestartet, weil ich mit ner Datenbank umgezogen bin..
            Das ist anscheinend ein unglueckliches Zusammenspiel mit dem Adapter / App / Worx Account.. oder vielleicht noch IP Vx / Provider Dinge...
            Bist du bei der Telekom ?
            ps. meiner ist seit Donnerstag nicht mehr steuerbar, da ich weder die App noch den Adapter zum laufen bekomme.. ich kann mir ne neue IP geben lassen und die 26h warten, dann komm ich zwar in den Login/id-Account, aber wie ich entweder die App (ios) oder den Adapter starte, ist sofort wieder Error 429 da.. und dann wars das wieder.. echt zum K*** da mein Worx so smart gesteuert ist, dass er ausschliesslich vom iobroker gesteuert wird.. nutzt halt nix.. wenn das nicht geht.. seit Tagen kein Rasen gemaeht.. das ist nicht Sinn von dem 2000 Euro Teil.. und der Support ist natuerlich zum ... da nur Standard-Mails kommen.. da kannste schreiben was du willst.. (war schon freundlich.. ausnahmsweise :))
              @haselchen
              haselchenH Offline
              haselchenH Offline
              haselchen
              #374
              @neuschwansteini
              Glasfaser, mit eigener IP4.
              Kann ja nicht am Reboot liegen. Das wäre ja lustig.
              Hab die Tage auch den IoBroker paar mal neustarten müssen.
              Edit: die 429 ist das Eine. Ich hab keinen Plan, ob man denen vom Adapter hier erzählen darf.
              Sollte die Elektronik mal ausfallen, hat der Gute ja noch Knöpfe zum Bedienen :)
              André KoschnikA 1 Antwort Letzte Antwort
                @neuschwansteini
                André KoschnikA Offline
                André Koschnik
                #375
                Bin auch betroffen😞 .
                Das hat alles Jahre lang super funktioniert.
                worx.0
                	2025-06-24 16:11:40.469	error	"429 TOO MANY REQUESTS"
                worx.0
                	2025-06-24 16:11:40.469	error	AxiosError: Request failed with status code 429
                worx.0
                	2025-06-24 16:11:40.469	error	https://api.worxlandroid.com/api/v2/product-items/$id/?status=1&gps_status=1
                worx.0
                	2025-06-24 16:04:16.527	debug	Last interrupt 1200930 ms
                worx.0
                	2025-06-24 16:04:16.526	debug	Connection interrupted: Error: aws-c-io: AWS_IO_SOCKET_CLOSED, socket is closed.
                worx.0
                	2025-06-24 16:00:54.917	error	"429 TOO MANY REQUESTS"
                worx.0
                	2025-06-24 16:00:54.917	error	AxiosError: Request failed with status code 429
                worx.0
                	2025-06-24 16:00:54.775	debug	Refresh token
                worx.0
                	2025-06-24 16:00:40.456	error	"429 TOO MANY REQUESTS"
                worx.0
                	2025-06-24 16:00:40.456	error	AxiosError: Request failed with status code 429
                worx.0
                	2025-06-24 16:00:40.456	error	https://api.worxlandroid.com/api/v2/product-items/$id/?status=1&gps_status=1
                worx.0
                	2025-06-24 15:49:40.457	error	"429 TOO MANY REQUESTS"
                worx.0
                	2025-06-24 15:49:40.457	error	AxiosError: Request failed with status code 429
                worx.0
                	2025-06-24 15:49:40.456	error	https://api.worxlandroid.com/api/v2/product-items/$id/?status=1&gps_status=1
                Steffe.S.S L 2 Antworten Letzte Antwort
                • André KoschnikA André Koschnik
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  worx.0
                  Steffe.S.S Online
                  Steffe.S.S Online
                  Steffe.S.
                  #376
                  bei mir auch....
                  NasenbohrerN 1 Antwort Letzte Antwort
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    worx.0
                    L Online
                    L Online
                    Lucky_ESA
                    #377
                    @andré-koschnik sagte in Adapter Worx Landroid v3.x.x:
                    product-items
                    Hast du 2 Mäher?
                    • Steffe.S.S Steffe.S.
                      bei mir auch....
                      NasenbohrerN Offline
                      Nasenbohrer
                      #378
                      @steffe-s Dito
                      • E Online
                        E Online
                        eve11
                        schrieb am zuletzt editiert von eve11
                        #379
                        Heute früh ist der Adapter noch gestartet und nach einiger Zeit kam diese Fehlermeldung:
                        worx.0
                        2025-06-24 09:36:15.794	info	connectMqtt: Failed to connect: libaws-c-mqtt: AWS_ERROR_MQTT_UNEXPECTED_HANGUP, The connection was closed unexpectedly.
                        worx.0
                        2025-06-24 09:36:15.793	info	MQTT ERROR: Error: Failed to connect: libaws-c-mqtt: AWS_ERROR_MQTT_UNEXPECTED_HANGUP, The connection was closed unexpectedly.
                        Jetzt startet der Adapter nicht mehr:
                        worx.0
                        2025-06-24 17:10:56.993	info	connectMqtt: Failed to connect: libaws-c-mqtt: AWS_ERROR_MQTT_UNEXPECTED_HANGUP, The connection was closed unexpectedly.
                        worx.0
                        2025-06-24 17:10:56.993	info	MQTT ERROR: Error: Failed to connect: libaws-c-mqtt: AWS_ERROR_MQTT_UNEXPECTED_HANGUP, The connection was closed unexpectedly.
                        worx.0
                        2025-06-24 17:10:56.834	info	Start check devices object!
                        worx.0
                        2025-06-24 17:10:56.672	info	Start MQTT connection
                        worx.0
                        2025-06-24 17:10:56.558	info	Autolock found! Create State : AutoLockTimer
                        worx.0
                        2025-06-24 17:10:56.556	info	Autolock found! Create State : AutoLock
                        worx.0
                        2025-06-24 17:10:56.551	info	Torque control found, create states...
                        worx.0
                        2025-06-24 17:10:56.099	info	Create product folder and states for WR141E
                        worx.0
                        2025-06-24 17:10:55.640	info	Create folder activityLog and set states.
                        worx.0
                        2025-06-24 17:10:55.620	info	New Firmware found, create states...
                        worx.0
                        2025-06-24 17:10:55.614	info	PartyModus found, create states...
                        worx.0
                        2025-06-24 17:10:55.612	info	OneTimeShedule found, create states...
                        worx.0
                        2025-06-24 17:10:55.564	info	DoubleShedule found, create states...
                        worx.0
                        2025-06-24 17:10:55.058	info	Multi-ZoneKeeper found! Create State : zoneKeeper
                        worx.0
                        2025-06-24 17:10:54.963	info	Found device null with id 2020xxxxxxxxxxxxxxx
                        worx.0
                        2025-06-24 17:10:54.963	info	Found 1 devices
                        worx.0
                        2025-06-24 17:10:54.673	info	Login to worx
                        worx.0
                        2025-06-24 17:10:54.672	info	Use new aws-iot-device-sdk-v2.
                        worx.0
                        2025-06-24 17:10:54.612	info	starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.1, js-controller: 7.0.3
                        Die Android App funtioniert.
                        L 1 Antwort Letzte Antwort
                        • E eve11
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          worx.0
                          L Online
                          L Online
                          Lucky_ESA
                          #380
                          @eve11 Bitte Adapter stoppen, unter Instanzen den Adapter auf debug stellen, in der Instanz Einstellungen den roten Button drücken. Adapter starten...Sobald du dann den Fehler bekommst, dann mir das gesamte Logfile an github@luckyskills.de zusenden.
                          Gruß//Lucky
                          Bjoern77B E L 3 Antworten Letzte Antwort
                          • L Lucky_ESA
                            Gruß//Lucky
                            Bjoern77B Offline
                            Bjoern77B Offline
                            Bjoern77
                            #381
                            Moin
                            Also bei mir läuft die Android App wieder.
                            Den Adapter hatte ich gestern zum laufen bekommen, nachdem ich den Mäher neu gestartet habe. (Zufall?)
                            Heute ging der Adapter öfters wieder auf Gelb, mit diesem Grund:
                            2025-06-24 09:18:25.600 - info: worx.0 (206570) MQTT ERROR: Error: Failed to connect: libaws-c-mqtt: AWS_ERROR_MQTT_UNEXPECTED_HANGUP, The connection was closed unexpectedly.
                            2025-06-24 09:18:25.601 - info: worx.0 (206570) connectMqtt: Failed to connect: libaws-c-mqtt: AWS_ERROR_MQTT_UNEXPECTED_HANGUP, The connection was closed unexpectedly.
                            Ich bin dann auf eine ältere Version gegangen (3.20). Diese startete Sauber, aber nach einer Weile kommt irgendwann das gleiche Problem. (Siehe LOG)
                            Björn
                            • L Lucky_ESA
                              Gruß//Lucky
                              E Online
                              E Online
                              eve11
                              #382
                              @lucky_esa
                              Done
                              • L Lucky_ESA
                                Gruß//Lucky
                                L Online
                                L Online
                                Lucky_ESA
                                #383
                                @lucky_esa Benötige ich nicht mehr. Habe nun endlich auch diesen Fehler und kann jetzt suchen gehen.
                                • L Online
                                  L Online
                                  Lucky_ESA
                                  #384
                                  Habe jetzt seit 4 Stunden diverse Änderungen bei mir im Live System ohne Probleme laufen. Sollten die Änderungen Stabil bis morgen Abend laufen werde ich das auf GIT laden. Ich habe ein Problem wenn der Token erneuert werden muss (jede Stunde). Es wir manchmal der neuen Token bei der MQTT Verbindung nicht akzeptiert aber bei der API wird dieser akzeptiert. Wenn der Adapter läuft und erhaltet diesen Fehler, dann einfach ignorieren. Auch wenn der Adapter gelb leuchtet, wird nach 1 Stunde der neue Token geholt und die MQTT Verbindung wird neu aufgebaut, womit der Adapter wieder grün wird. Wer sein Adapter neu startet und erhält die Meldung, der muss den roten Button in der Instanz Einstellung drücken. Warum das so ist kann ich nicht sagen, finde ich aber keine Lösung werde ich bei Worx ein Issue anlegen. Mit ein wenig Glück könnte es auch der Grund für Fehler 429 sein.
                                  Gruß//Lucky
                                  haselchenH Dr. BakteriusD 2 Antworten Letzte Antwort
                                  • L Lucky_ESA
                                    Gruß//Lucky
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    #385
                                    @lucky_esa
                                    Sollte der Adapter gelb leuchten, werden dann trotzdem die DP aktualisiert?
                                      @lucky_esa
                                      L Online
                                      L Online
                                      Lucky_ESA
                                      #386
                                      @haselchen sagte in Adapter Worx Landroid v3.x.x:
                                      @lucky_esa
                                      Leider nein da 1 Stunde keine MQTT Verbindung besteht.
                                      • L Lucky_ESA
                                        @lucky_esa
                                        katt
                                        #387
                                        Guten Morgen. Muss mich jetzt hier auch mit einklinken... Gibt es bisher eine Möglichkeit, zumindest den App Zugang wiederherzustellen? Entsprechend den Hinweisen hier habe ich folgendes versucht:
                                        1. (Adapter ist seit Tagen pausiert. Mäher ist "On" und wird nur manuell am Gerät zum Mähen gestartet).
                                        2. Alle Apps deinstalliert.
                                        3. Unter id.worx.com alle accounts gelöscht, bis auf "Landroid Account".
                                        4. IOS App neu installiert und angemeldet -> werde sofort wieder geblockt: "Langsamer" und "429 TOO MANY REQUESTS".
                                        Hab ich irgend etwas übersehen?? IP wechsel ist mir am Glasfaseranschluss (Internet Nord) bisher nicht geglückt. Ein Neustart des Glasfasermodems erzwingt offensichtlich keine IP Änderung.
                                        • L Lucky_ESA
                                          product-items
                                          Hast du 2 Mäher?
                                          André Koschnik
                                          #388
                                          @lucky_esa
                                          nein wieso?
