  3. Off Topic
  4. Pflege des Betriebssystems
  5. pnpm Fehler
    6.8k
pnpm Fehler
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
15 Beiträge 3 Kommentatoren 1.4k Aufrufe 2 Beobachtet
  • AutodidaktA Autodidakt
    Hallo allerseits.
    ich wollte gerade den Umstieg auf Zigbee2Mqtt wagen.
    Bei der Installation von
    npm install -g pnpm
    kommt folgende Fehlermeldung:
    pi@pi4-Master:~ $ npm install -g pnpm
    npm error code EACCES
    npm error syscall rename
    npm error path /usr/lib/node_modules/pnpm
    npm error dest /usr/lib/node_modules/.pnpm-H0EZVZtB
    npm error errno -13
    npm error Error: EACCES: permission denied, rename '/usr/lib/node_modules/pnpm' -> '/usr/lib/node_modules/.pnpm-H0EZVZtB'
    npm error     at async Object.rename (node:internal/fs/promises:782:10)
    npm error     at async moveFile (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/move-file.js:30:5)
    npm error     at async Promise.allSettled (index 0)
    npm error     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:337:11)
    npm error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:142:5)
    npm error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:149:5)
    npm error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:208:9)
    npm error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:67:5) {
    npm error   errno: -13,
    npm error   code: 'EACCES',
    npm error   syscall: 'rename',
    npm error   path: '/usr/lib/node_modules/pnpm',
    npm error   dest: '/usr/lib/node_modules/.pnpm-H0EZVZtB'
    npm error }
    npm error
    npm error The operation was rejected by your operating system.
    npm error It is likely you do not have the permissions to access this file as the current user
    npm error
    npm error If you believe this might be a permissions issue, please double-check the
    npm error permissions of the file and its containing directories, or try running
    npm error the command again as root/Administrator.
    npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-06-22T11_48_20_659Z-debug-0.log
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@10.9.2
    2 info using node@v22.16.0
    3 silly config load:file:/usr/lib/node_modules/npm/npmrc
    4 silly config load:file:/home/pi/.npmrc
    5 silly config load:file:/usr/etc/npmrc
    6 verbose title npm install pnpm
    7 verbose argv "install" "--global" "pnpm"
    8 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2025-06-22T12_17_32_738Z-
    9 verbose logfile /home/pi/.npm/_logs/2025-06-22T12_17_32_738Z-debug-0.log
    10 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
    11 silly logfile start cleaning logs, removing 1 files
    12 silly logfile done cleaning log files
    13 silly idealTree buildDeps
    14 silly fetch manifest pnpm@*
    15 silly packumentCache full:https://registry.npmjs.org/pnpm cache-miss
    16 http fetch GET 200 https://registry.npmjs.org/pnpm 371ms (cache revalidated)
    17 silly packumentCache full:https://registry.npmjs.org/pnpm set size:5092597 disposed:false
    18 silly placeDep ROOT pnpm@10.12.1 OK for:  want: *
    19 silly reify mark retired [ '/usr/lib/node_modules/pnpm', '/usr/bin/pnpm', '/usr/bin/pnpx' ]
    20 silly reify moves {
    20 silly reify   '/usr/lib/node_modules/pnpm': '/usr/lib/node_modules/.pnpm-H0EZVZtB',
    20 silly reify   '/usr/bin/pnpm': '/usr/bin/.pnpm-JTllyBcj',
    20 silly reify   '/usr/bin/pnpx': '/usr/bin/.pnpx-MALdymCV'
    20 silly reify }
    21 verbose stack Error: EACCES: permission denied, rename '/usr/lib/node_modules/pnpm' -> '/usr/lib/node_modules/.pnpm-H0EZVZtB'
    21 verbose stack     at async Object.rename (node:internal/fs/promises:778:10)
    21 verbose stack     at async moveFile (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/move-file.js:30:5)
    21 verbose stack     at async Promise.allSettled (index 0)
    21 verbose stack     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:325:11)
    21 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:142:5)
    21 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
    21 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
    21 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
    22 error code EACCES
    23 error syscall rename
    24 error path /usr/lib/node_modules/pnpm
    25 error dest /usr/lib/node_modules/.pnpm-H0EZVZtB
    26 error errno -13
    27 error Error: EACCES: permission denied, rename '/usr/lib/node_modules/pnpm' -> '/usr/lib/node_modules/.pnpm-H0EZVZtB'
    27 error     at async Object.rename (node:internal/fs/promises:778:10)
    27 error     at async moveFile (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/move-file.js:30:5)
    27 error     at async Promise.allSettled (index 0)
    27 error     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:325:11)
    27 error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:142:5)
    27 error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
    27 error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
    27 error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5) {
    27 error   errno: -13,
    27 error   code: 'EACCES',
    27 error   syscall: 'rename',
    Was kann ich tun?
    Mfg
    Tom
    @autodidakt
    Der user 'pi' darf nicht nach /usr/lib/ schreiben, das darf nur root.
    nodemodule, die global verfügbar sein sollen muss also der root dort hinlegen.
    Wird dir aber auch angesagt:
    Also:
    sudo npm install -g pnpm
    AutodidaktA 1 Antwort Letzte Antwort
      @autodidakt
      Also:
      AutodidaktA Offline
      AutodidaktA Offline
      Autodidakt
      @thomas-braun Danke, wieder was gelernt...
      • AutodidaktA Offline
        AutodidaktA Offline
        Autodidakt
        schrieb am zuletzt editiert von Autodidakt
        Und schon kommt das nächste Problem.
        Zigbee2Mqtt will ums verrecken nicht starten.
        pi@pi4-Master:/opt/zigbee2mqtt $ pnpm start
        > zigbee2mqtt@2.4.0 start /opt/zigbee2mqtt
        > node index.js
        Starting Zigbee2MQTT without watchdog.
        [2025-06-23 16:21:03] info:     z2m: Logging to console, file (filename: log.log)
        [2025-06-23 16:21:04] info:     z2m: Starting Zigbee2MQTT version 2.4.0 (commit #bdb94da4)
        [2025-06-23 16:21:04] info:     z2m: Starting zigbee-herdsman (4.1.0)
        [2025-06-23 16:21:04] info:     zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"ac315ae1c912ef1184ed6fb8bf9df066","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_ac315ae1c912ef1184ed6fb8bf9df066-if00-port0","vendorId":"10c4","productId":"ea60"} => ember: 4
        [2025-06-23 16:21:04] info:     zh:ember: Using default stack config.
        [2025-06-23 16:21:04] info:     zh:ember: ======== Ember Adapter Starting ========
        [2025-06-23 16:21:04] info:     zh:ember:ezsp: ======== EZSP starting ========
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash: ======== ASH Adapter reset ========
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash: ASH COUNTERS since last clear:
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Total frames: RX=0, TX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Cancelled   : RX=0, TX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   DATA frames : RX=0, TX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   DATA bytes  : RX=0, TX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Retry frames: RX=0, TX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   ACK frames  : RX=0, TX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   NAK frames  : RX=0, TX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   nRdy frames : RX=0, TX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   CRC errors      : RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Comm errors     : RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Length < minimum: RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Length > maximum: RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Bad controls    : RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Bad lengths     : RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Bad ACK numbers : RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Out of buffers  : RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Retry dupes     : RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Out of sequence : RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   ACK timeouts    : RX=0
        [2025-06-23 16:21:04] info:     zh:ember:uart:ash: ======== ASH stopped ========
        [2025-06-23 16:21:04] error:    zh:ember:uart:ash: Failed to init port with error Error: Error Resource temporarily unavailable Cannot lock port
        [2025-06-23 16:21:04] error:    z2m: Error while starting zigbee-herdsman
        [2025-06-23 16:21:04] error:    z2m: Failed to start zigbee-herdsman
        [2025-06-23 16:21:04] error:    z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
        [2025-06-23 16:21:04] error:    z2m: Exiting...
        [2025-06-23 16:21:04] error:    z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
            at EmberAdapter.initEzsp (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19)
            at EmberAdapter.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1548:24)
            at Controller.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
            at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:71:27)
            at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:102:13)
            at start (/opt/zigbee2mqtt/index.js:149:5)
         ELIFECYCLE  Command failed with exit code 1.
        Hier die Config
        version: 4
        mqtt:
          base_topic: zigbee2mqtt
          server: mqtt://localhost:1883
          user: xxxxxxxx
          password: xxxxxxxx
        serial:
          port: /dev/ttyUSB0
          adapter: ember
          baudrate: 115200
          rtscts: false
        advanced:
          log_level: info
          channel: 11
          network_key:
            - 223
            - 25
            - 181
            - 70
            - 48
            - 140
            - 164
            - 218
            - 20
            - 78
            - 112
            - 96
            - 167
            - 137
            - 205
            - 12
          pan_id: 53749
          ext_pan_id:
            - 230
            - 19
            - 60
            - 177
            - 44
            - 17
            - 21
            - 12
        frontend:
          enabled: true
          port: 8080
        homeassistant:
          enabled: false
        Muss ich evtl die Porteinstellung ändern?
          > node index.js
          Hier die Config
          version: 4
          mqtt:
            user: xxxxxxxx
            password: xxxxxxxx
          serial:
            port: /dev/ttyUSB0
            adapter: ember
            baudrate: 115200
            rtscts: false
          advanced:
            log_level: info
            channel: 11
            network_key:
              - 223
              - 25
              - 181
              - 70
              - 48
              - 140
              - 164
              - 218
              - 20
              - 78
              - 112
              - 96
              - 167
              - 137
              - 205
              - 12
            pan_id: 53749
            ext_pan_id:
              - 230
              - 19
              - 60
              - 177
              - 44
              - 17
              - 21
              - 12
          frontend:
            enabled: true
            port: 8080
          homeassistant:
            enabled: false
          @autodidakt
          Bist du sicher, dass die Choose so installiert werden soll?
            @autodidakt
            AutodidaktA Offline
            AutodidaktA Offline
            Autodidakt
            @thomas-braun Asolut nicht.
            Ich humpel hald jetz mal ein wenig hin und her.
            Ich brauche das Zigbee2Mqtt weil ich einen Feuchtesensor einbinden muss.
            Ich hab mich vor einiger zeit schon mal eingelesen, bin aber dann doch beim alten zigbee geblieben.
            Ich hab mich an die Anleitungen gehalten, die ich gefunden hab. Moquitto läuft schon mal.
              @autodidakt sagte in pnpm Fehler:
              im zigbee Adapter werkelt auch due zigbee²mqtt Engine!
              Wwofü genau benötigst du Z2m?
              was geht nicht mit dem Zigbee Adapter?
                AutodidaktA Offline
                AutodidaktA Offline
                Autodidakt
                für den da.
                https://www.zigbee2mqtt.io/devices/3RSM0147Z.html
                  für den da.
                  @autodidakt und
                  @homoran sagte in pnpm Fehler:
                    AutodidaktA Offline
                    Autodidakt
                    Ich hab das wohl falsch verstanden. Ich dacht dafür brauch ich Z2M...
                    Dummer weise habe ich meinem Sonoff Zigbee 3.0 heute eine neue Firmware verpasst, nun läuft auch der Zigbee Adapter nicht mehr.🙄
                      @autodidakt womit wolltest du den z2m betreiben?
                      welchen Koordinator hast du denn noch?
                        AutodidaktA Offline
                        AutodidaktA Offline
                        Autodidakt
                        @homoran Der Sonoff war mein Koordinator, oder täusch ich mich?
                        Mit dem wollte ich Z2M betreiben.
                          @autodidakt ....und jetzt hast du gar nichts mehr 😞 ?
                          Dann musdt du den sonoff wiederbeleben oder was anderes kaufen.
                            AutodidaktA Offline
                            AutodidaktA Offline
                            Autodidakt
                            @homoran Ich versuch Ihn grade neu zu flashen. Ist aber nicht ganz einfach in dem ganzen Firmware-Gewirr.
                            Wenn das nichts wird, muss hald ein neuer her.
                              AutodidaktA Offline
                              Autodidakt
                              Hallo nochmal.
                              Ich habe jetzt einen neuen Stick (Zigbee 3.0 USB Dongle Plus) den Zigbee Adapter V3.0.1 neu installiert und versuche nun meine Geräte neu anzulernen.
                              Leider kommt immer ein Herdsman Fehler.
                              zigbee.0
                              2025-06-25 11:06:24.603	warn	ELEVATED:I02 (a0ca) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:24.602	warn	ELEVATED:I02 (a0ca) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:24.601	warn	ELEVATED:I01 (a0ca) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined'
                              zigbee.0
                              2025-06-25 11:06:24.598	warn	ELEVATED:I02 (a0c2) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:24.597	warn	ELEVATED:I02 (a0c2) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:24.596	warn	ELEVATED:I01 (a0c2) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined'
                              zigbee.0
                              2025-06-25 11:06:24.592	warn	ELEVATED:I02 (a0c0) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              zigbee.0
                              2025-06-25 11:06:24.592	warn	ELEVATED:I01 (a0c0) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined'
                              zigbee.0
                              2025-06-25 11:06:24.591	warn	ELEVATED:I02 (a0b3) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:24.590	warn	ELEVATED:I02 (a0b3) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:24.589	warn	ELEVATED:I01 (a0b3) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined'
                              zigbee.0
                              2025-06-25 11:06:24.587	warn	ELEVATED:I01 (a0ca) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":171,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":97,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                              zigbee.0
                              2025-06-25 11:06:24.578	warn	ELEVATED:I01 (a0c2) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":15},"linkquality":168,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":96,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                              zigbee.0
                              2025-06-25 11:06:24.576	warn	ELEVATED:I01 (a0c0) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":168,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":95,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                              zigbee.0
                              2025-06-25 11:06:24.565	warn	ELEVATED:I01 (a0b3) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":2869},"linkquality":168,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":94,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                              zigbee.0
                              2025-06-25 11:06:09.592	warn	ELEVATED:I02 (661d) value generated '174' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              zigbee.0
                              2025-06-25 11:06:09.591	warn	ELEVATED:I01 (661d) message received '{"linkquality":174}' from device ffffb40e060599a0 type 'undefined'
                              zigbee.0
                              2025-06-25 11:06:09.578	warn	ELEVATED:I02 (6611) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:09.576	warn	ELEVATED:I02 (6611) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:09.575	warn	ELEVATED:I01 (6611) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined'
                              zigbee.0
                              2025-06-25 11:06:09.574	warn	ELEVATED:I02 (660e) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:09.573	warn	ELEVATED:I02 (660e) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:09.573	warn	ELEVATED:I01 (660e) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined'
                              zigbee.0
                              2025-06-25 11:06:09.566	warn	ELEVATED:I01 (661d) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":174,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":93,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                              zigbee.0
                              2025-06-25 11:06:09.553	warn	ELEVATED:I01 (6611) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":15},"linkquality":171,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":92,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                              zigbee.0
                              2025-06-25 11:06:09.551	warn	ELEVATED:I01 (660e) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":171,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":91,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                              zigbee.0
                              2025-06-25 11:06:09.393	warn	ELEVATED:I02 (6568) value generated '174' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:09.392	warn	ELEVATED:I02 (6568) value generated '174' from device ffffb40e060599a0 for 'Link quality'
                              zigbee.0
                              2025-06-25 11:06:09.391	warn	ELEVATED:I01 (6568) message received '{"linkquality":174}' from device ffffb40e060599a0 type 'undefined'
                              zigbee.0
                              2025-06-25 11:06:09.385	warn	ELEVATED:I01 (6568) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":2869},"linkquality":174,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":88,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                              Irgendwo steckt wohl noch was fest. Gibt es eine Möglichkeit Zigbee komplett mit allem zu entfernen und neu zu beginnen?
                              Failed to open the network: Error: SRSP - ZDO - mgmtPermitJoinReq after 6000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:47:23) at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:263:41 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:26) at Znp.requestZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:257:27) at func (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:322:32) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:26) at ZStackAdapter.sendZdoInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:341:60) at ZStackAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:263:27) at ZStackAdapter.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:176:24) at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:249:32)
                              Mfg
                              Tom
