  3. Off Topic
  4. Pflege des Betriebssystems
  5. Veraltetes System retten
    6.1k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
25 Beiträge 5 Kommentatoren 3.5k Aufrufe 4 Beobachtet
    @syntetic sagte in Veraltetes System retten:
    es scheint tatsächlich alles zu funktionieren
    klingt gut!
    was sagt ein aktuelles iob diag?
    syntetic
    @homoran said in Veraltetes System retten:
    klingt gut!
    Ich hab ein bisschen Angst, dass du mir gleich wieder den Wind aus den Segeln nimmst, weil irgendwas nicht passt 😰
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.25+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     21:39:01 up  2:52,  2 users,  load average: 1.11, 0.78, 0.82
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-06-16 21:39:01 CEST
               Universal time: Mon 2025-06-16 19:39:01 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    mitcho
    HOME=/home/mitcho
    GROUPS=mitcho adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Mem:            4.0G        2.2G        303M        8.7M        1.6G        1.7G
    Swap:           536M          0B        536M
    Total:          4.5G        2.2G        840M
    Active iob-Instances: 	14
             3797 M total memory
             2131 M used memory
             2079 M active memory
             1211 M inactive memory
              289 M free memory
               67 M buffer memory
             1421 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 21:39:02 up  2:52,  2 users,  load average: 1.10, 0.78, 0.82
    Tasks: 193 total,   1 running, 192 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3797.4 total,    288.7 free,   2131.7 used,   1488.6 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1665.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  5.9M  374M   2% /run
    /dev/mmcblk0p2 ext4      235G  4.5G  218G   3% /
    tmpfs          tmpfs     1.9G  2.5M  1.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Jun 16 18:46:23 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:FC:5C:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bd7d57f9-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Mon Jun 16 18:46:24 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
    [Mon Jun 16 18:46:25 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    898M	/var/
    208M	/var/cache
    202M	/var/cache/apt
    164M	/var/lib
    135M	/var/lib/apt/lists
    Archived and active journals take up 4.7M in the file system.
    /opt/iobroker/backups:
    4.9M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    289M	/opt/iobroker/iobroker-data/
    180M	/opt/iobroker/iobroker-data/files
    47M	/opt/iobroker/iobroker-data/files/admin.admin
    46M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    60M	/opt/iobroker/iobroker-data/objects.jsonl
    45M	/opt/iobroker/iobroker-data/states.jsonl
    24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    8.4M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js
    8.1M	/opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.19.2
    /usr/bin/node 		v20.19.2
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.31.0
    nodejs:
      Installed: 20.19.2-1nodesource1
      Candidate: 20.19.2-1nodesource1
      Version table:
     *** 20.19.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 9063)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.17
    javascript: 	8.9.2
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              -  enabled
      system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.unifi.0                  : unifi                 : raspberrypi                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "backitup"     : 3.2.2    , installed 3.2.2
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 9.5.1    , installed 9.5.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis"          : 1.5.6    , installed 1.4.16 [Updatable]
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects: 	86932
    States: 	64365
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      995        9798       1936/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1847       600/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      995        11311      1936/pihole-FTL
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      995        9797       1936/pihole-FTL
    tcp        0      0 127.0.0.1:33217         0.0.0.0:*               LISTEN      1001       207245     4857/io.yahka.0
    tcp        0      0 0.0.0.0:34815           0.0.0.0:*               LISTEN      1001       207236     4857/io.yahka.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32916      3698/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31951      3698/iobroker.js-co
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       33376      3853/io.shelly.1
    tcp6       0      0 :::443                  :::*                    LISTEN      995        9800       1936/pihole-FTL
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1849       600/sshd: /usr/sbin
    tcp6       0      0 :::53                   :::*                    LISTEN      995        11313      1936/pihole-FTL
    tcp6       0      0 :::80                   :::*                    LISTEN      995        9799       1936/pihole-FTL
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33298      3915/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31487      3716/io.admin.0
    udp        0      0 0.0.0.0:36765           0.0.0.0:*                           104        4545       461/avahi-daemon: r
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           995        11310      1936/pihole-FTL
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           995        11407      1936/pihole-FTL
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4543       461/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       34178      3846/io.shelly.0
    udp6       0      0 :::57251                :::*                                104        4546       461/avahi-daemon: r
    udp6       0      0 :::53                   :::*                                995        11312      1936/pihole-FTL
    udp6       0      0 :::123                  :::*                                995        8894       1936/pihole-FTL
    udp6       0      0 :::5353                 :::*                                104        4544       461/avahi-daemon: r
    2025-06-16 21:14:31.745  - error: javascript.0 (3728) Script script.js.Überwachung.PV_Anlage_Datenabfrage is calling setState more than 1000 times per minute! Stopping Script now! Please check your script!
    2025-06-16 21:14:31.746  - info: javascript.0 (3728) Stopping script script.js.Überwachung.PV_Anlage_Datenabfrage
    2025-06-16 21:22:14.125  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
    2025-06-16 21:22:16.405  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
    2025-06-16 21:22:17.802  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
    2025-06-16 21:22:19.028  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
    2025-06-16 21:22:22.685  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
    2025-06-16 21:22:23.134  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
    2025-06-16 21:22:26.223  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
    2025-06-16 21:22:36.173  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
    2025-06-16 21:30:00.092  - info: host.raspberrypi instance system.adapter.ical.1 in version "1.16.1" started with pid 7005
    2025-06-16 21:30:04.144  - info: host.raspberrypi instance system.adapter.ical.2 in version "1.16.1" started with pid 7016
    2025-06-16 21:30:05.707  - info: ical.1 (7005) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
    2025-06-16 21:30:08.147  - info: ical.1 (7005) processing URL: Geburtstage http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7obrJTyh7JrvM5W7hWbXKYV98z6u1ArEpUzT0Qfx8u5BCClYRNKct5WlBkEJoZzDg4
    2025-06-16 21:30:08.445  - info: host.raspberrypi instance system.adapter.ical.0 in version "1.16.1" started with pid 7031
    2025-06-16 21:30:11.141  - info: ical.2 (7016) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
    2025-06-16 21:30:14.810  - info: ical.1 (7005) Terminated (NO_ERROR): Without reason
    2025-06-16 21:30:15.279  - info: ical.2 (7016) processing URL: Termine http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7oYOZ-wGjmsa5xf0_Job--v
    2025-06-16 21:30:15.370  - info: host.raspberrypi instance system.adapter.ical.1 having pid 7005 terminated with code 0 (NO_ERROR)
    2025-06-16 21:30:16.034  - info: ical.0 (7031) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
    2025-06-16 21:30:17.850  - info: ical.0 (7031) processing URL: Abfallkalender http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7p4SoafHZSRCZlAgdEYtjMS7V69VebAe4k5Fje7F1AUj1kDgxQWHADWcnNrtdAr7CU
    2025-06-16 21:30:20.594  - info: ical.2 (7016) Terminated (NO_ERROR): Without reason
    2025-06-16 21:30:21.141  - info: host.raspberrypi instance system.adapter.ical.2 having pid 7016 terminated with code 0 (NO_ERROR)
    2025-06-16 21:30:23.177  - info: ical.0 (7031) Terminated (NO_ERROR): Without reason
    2025-06-16 21:30:23.713  - info: host.raspberrypi instance system.adapter.ical.0 having pid 7031 terminated with code 0 (NO_ERROR)
    • S syntetic
      klingt gut!
      Script v.2025-03-08
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      mitcho
      HOME=/home/mitcho
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           536M          0B        536M
               3797 M total memory
               2131 M used memory
                289 M free memory
                 67 M buffer memory
               1421 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      898M	/var/
      208M	/var/cache
      202M	/var/cache/apt
      164M	/var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.6.17
      javascript: 	8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	86932
      States: 	64365
      Pending Updates: 0
      Nö, passt soweit. Bring vis noch auf Stand.
      • S syntetic
        klingt gut!
        Script v.2025-03-08
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        mitcho
        HOME=/home/mitcho
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Swap:           536M          0B        536M
                 3797 M total memory
                 2131 M used memory
                  289 M free memory
                   67 M buffer memory
                 1421 M swap cache
                  511 M total swap
                    0 M used swap
                  511 M free swap
        *** FILESYSTEM ***
        /var:
        898M	/var/
        208M	/var/cache
        202M	/var/cache/apt
        164M	/var/lib
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin: 		7.6.17
        javascript: 	8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	86932
        States: 	64365
        Pending Updates: 0
        wenn, dann nur um dir zu helfen.
        Aber ich sehe nichts, lediglich
        hat es da gehakt?
          hat es da gehakt?
          syntetic
          hat es da gehakt?
          Nein. Schon erledigt.
          • S syntetic
            hat es da gehakt?
            @syntetic
            Das würde ich mir aber anschauen:
            S HomoranH 2 Antworten Letzte Antwort
              @syntetic
              syntetic
              @thomas-braun said in Veraltetes System retten:
              @syntetic
              Ich wollte das Abfrageintervall auf 10 Sekunden verkürzen. Das mochte er offenbar nicht. Bei 1 Minute gibts keine Probleme.
              • S syntetic
                @syntetic
                auf 10 Sekunden
                sind das vielleicht Millisekunden?
                  auf 10 Sekunden
                  syntetic
                  Nein, Sekunden. Scheint bekannt zu sein, was ich so gelesen habe. 1 Minute reicht i.d.R. auch.
                    @syntetic
                    @thomas-braun sagte in Veraltetes System retten:
                    bei 10 Sekunden Intervall müssten das ja 200 setState() pro Aufruf sein
                    P 1 Antwort Letzte Antwort
                      peterfido
                      @homoran Hauptsache, da wird nicht auch jedesmal in den Flash vom Wechselrichter geschrieben.
                      Peterfido
