  4. Versionsinformationen Admin falsch
    6.7k
23 Beiträge 5 Kommentatoren 2.0k Aufrufe 5 Beobachtet
  • Lucifor1976L Lucifor1976
    Hier mal ein vollständiger Diag...
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-10-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _Q35 + ICH9, 2009_
    Firmware Version: unknown
    OS is similar to:
    model name	: Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     19:32:00 up  7:38,  2 users,  load average: 0.82, 0.78, 0.44
    CPU threads: 56
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-06-05 19:32:00 CEST
               Universal time: Thu 2025-06-05 17:32:00 UTC
                     RTC time: Thu 2025-06-05 17:32:00
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    js-controller is not running
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             33G        812M         32G        868K        1.3G         32G
    Swap:           1.0G          0B        1.0G
    Total:           34G        812M         33G
    Active iob-Instances: 	1
            32075 M total memory
              773 M used memory
              737 M active memory
              185 M inactive memory
            30552 M free memory
              225 M buffer memory
              982 M swap cache
              976 M total swap
                0 M used swap
              976 M free swap
    top - 19:32:01 up  7:38,  2 users,  load average: 0.82, 0.78, 0.44
    Tasks: 494 total,   1 running, 493 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  1.7 sy,  0.0 ni, 96.7 id,  0.0 wa,  0.0 hi,  0.0 si,  1.7 st
    MiB Mem :  32075.9 total,  30552.1 free,    774.2 used,   1208.1 buff/cache
    MiB Swap:    977.0 total,    977.0 free,      0.0 used.  31301.8 avail Mem
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    [sudo] password for iobroker:
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs   16G     0   16G   0% /dev
    tmpfs          tmpfs     3.2G  856K  3.2G   1% /run
    /dev/vda2      ext4      124G   14G  105G  12% /
    tmpfs          tmpfs      16G     0   16G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/vda1      vfat      511M  5.9M  506M   2% /boot/efi
    tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/1001
    [Thu Jun  5 11:53:15 2025] EXT4-fs (vda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Thu Jun  5 11:53:15 2025] EXT4-fs (vda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET      SOURCE    FSTYPE OPTIONS
    /           /dev/vda2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/vda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    4.5G	/var/
    3.9G	/var/log
    3.8G	/var/log/journal/344d77984391492881db48d011483210
    479M	/var/cache
    Archived and active journals take up 3.3G in the file system.
    /opt/iobroker/backups:
    1.4G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.3G	/opt/iobroker/iobroker-data/
    1.1G	/opt/iobroker/iobroker-data/files
    241M	/opt/iobroker/iobroker-data/files/vis.0
    237M	/opt/iobroker/iobroker-data/files/vis-2.0
    208M	/opt/iobroker/iobroker-data/files/vis.0/images
    43M	/opt/iobroker/iobroker-data/objects.jsonl
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.19.2
    /usr/bin/node 		v20.19.2
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.31.0
    nodejs:
      Installed: 20.19.2-1nodesource1
      Candidate: 20.19.2-1nodesource1
      Version table:
     *** 20.19.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 497)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.17
    javascript: 	8.9.2
    nodejs modules from github: 	3
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
      system.adapter.admin.0.0                : admin                 : ioBrokerSlave                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
      system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
      system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
      system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
      system.adapter.enigma2.1                : enigma2               : iobroker                                 -  enabled
      system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
      system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
      system.adapter.hp-ilo.0                 : hp-ilo                : iobroker                                 -  enabled
      system.adapter.hp-ilo.1                 : hp-ilo                : iobroker                                 -  enabled
      system.adapter.hs100.0                  : hs100                 : iobroker                                 -  enabled
      system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
      system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
      system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
      system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
      system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
      system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
      system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
      system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
      system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
      system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
      system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
      system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
      system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.smartmeter.0             : smartmeter            : ioBrokerSlave                            -  enabled
      system.adapter.solarwetter.0            : solarwetter           : iobroker                                 - disabled
      system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      system.adapter.sql.0                    : sql                   : iobroker                                 - disabled, port: 3306
      system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
      system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
      system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
      system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
      system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.youtube.0                : youtube               : iobroker                                 -  enabled
      system.adapter.youtube.1                : youtube               : iobroker                                 -  enabled
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
      system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alarm"        : 3.7.0    , installed 3.7.0
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "awattar"      : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 3.2.2    , installed 3.2.2
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "e3dc-rscp"    : 1.4.2    , installed 1.4.2
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "hp-ilo"       : 1.0.6    , installed 1.0.6
    Adapter    "hs100"        : 2.2.2    , installed 2.2.2
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
    Adapter    "ring"         : 6.3.0    , installed 6.3.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.3.1  [Updatable]
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 9.5.1    , installed 9.5.1
    Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-weather"  : 2.5.11   , installed 2.5.11
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "youtube"      : 6.0.0    , installed 6.0.0
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Server Objects 192.168.1.227:45994 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerSlave: The database is not open!
        at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-jsonl/src/lib/objects/objectsInMemServerRedis.js:574:63)
        at RedisHandler.emit (node:events:524:28)
        at RedisHandler.emit (node:domain:489:12)
        at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37)
        at processImmediate (node:internal/timers:483:21)
    Objects and States
    Objects: 	42824
    States: 	35049
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1002       449562     335199/nc
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          29708      1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          60534      1124/sshd: /usr/sbi
    tcp6       0      0 :::111                  :::*                    LISTEN      0          29709      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          60536      1124/sshd: /usr/sbi
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          51225      1065/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          16394      1/init
    udp6       0      0 :::111                  :::*                                0          20508      1/init
    2025-06-05 19:30:46.231  - error: host.iobroker Caught by controller[1]:   syscall: 'connect',
    2025-06-05 19:30:46.232  - error: host.iobroker Caught by controller[1]:   address: '192.168.1.214',
    2025-06-05 19:30:46.232  - error: host.iobroker Caught by controller[1]:   port: 9999
    2025-06-05 19:30:46.232  - error: host.iobroker Caught by controller[1]: }
    2025-06-05 19:30:46.232  - info: host.iobroker instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:46.952  - info: host.iobroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:46.969  - info: host.iobroker instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.018  - info: host.iobroker instance system.adapter.upnp.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.018  - info: host.iobroker instance system.adapter.nut.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.035  - info: host.iobroker instance system.adapter.admin.1 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.062  - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.105  - info: host.iobroker instance system.adapter.hue-extended.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.105  - info: host.iobroker instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.133  - info: host.iobroker instance system.adapter.rest-api.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.162  - info: host.iobroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.179  - info: host.iobroker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:47.330  - warn: host.iobroker instance system.adapter.sonoff.0 terminated due to SIGKILL
    2025-06-05 19:30:47.330  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null ()
    2025-06-05 19:30:48.078  - info: tuya.0 (327743) terminating
    2025-06-05 19:30:48.079  - info: tuya.0 (327743) Terminated (NO_ERROR): Without reason
    2025-06-05 19:30:48.716  - info: host.iobroker instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
    2025-06-05 19:30:49.108  - info: meross.0 (327206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-06-05 19:30:49.737  - info: host.iobroker instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-06-05 19:30:49.737  - info: host.iobroker All instances are stopped.
    2025-06-05 19:30:49.761  - info: host.iobroker terminated
    @lucifor1976 sagte in Versionsinformationen Admin falsch:
    Leg dir einen User abseits von 'admin', 'root', 'iobroker' oder sonstwas an. Dein Vorname ist z. B. ein guter username.
    Schalt den multi-user-Modus ein.
    iob del admin.0.0
    sagt?
    Die Instanz smartmeter.0 läuft auch noch auf dem Host ioBrokerSlave
    BTW: Hostnames schreibt man am besten in Kleinbuchstaben.
      iob del admin.0.0
      sagt?
      @thomas-braun sagte in Versionsinformationen Admin falsch:
      sagt?
      da bin ich gespannt!
      • Lucifor1976L Offline
        Lucifor1976
        iob del admin.0.0
        Neuer User = check
        Multiuser = check
        oben genanntes ergab:
        meinname@iobroker:/home/iobroker$ iob del admin.0.0
        iobroker del <adapter>.<instance>
        Remove adapter instance
        Options:
        --help Show help [boolean]
        --custom Remove instance custom attribute from all objects [boolean]
        Ich mach nochmal ein upgrade, bin mir aber sicher das der Fehler nicht weg ist.
        ioBroker@Debian 12 VM auf Proxmox 8.4.1 | HP Proliant DL380G9 | DS923+ 10TB | RS4021+ 144TB | Unifi Netzwerk 6AP, 3 EtagenSwitche | Anycubic MegaS+Kossel+Chiron, Elektroniker und Funkamateur
          iob del admin.0.0
          Neuer User = check
          Multiuser = check
          Options:
          @lucifor1976 bitte code-tags verwenden!
          Was ist Kommentar und was ist die Ausgabe?
          ich auch, daher
          NEIN!
            Lucifor1976
            Das ist der Prompt: iob del admin.0.0
            und das die Ausgabe:
            Options:
            Upgrade geht eh nicht, der Fehler bleibt.
            Cannot check dependencies: Invalid version of "admin". Installed "4.1.10", required ">=7.4.10
              iob del admin.0.0
              Neuer User = check
              Multiuser = check
              Options:
              Dann stell dich auch in das home des neuen users...
                M Online
                M Online
                MCU
                iob del admin.0.0
                Das gibt es nicht. Wenn dann
                 iob del admin.0
                  Options:
                  das wird an der falschen Nomenklatur deiner ID liegen.
                  da passiert wohl nichts im Hintergrund
                  • M MCU
                    iob del admin.0.0
                     iob del admin.0
                    @mcu sagte in Versionsinformationen Admin falsch:
                    Besser: Das sollte es nicht geben. Im fraglichen System ist die Instanz aber so aufgeführt. Warum auch immer.
                      M Online
                      M Online
                      MCU
                      @thomas-braun Hängt es evtl mit dem Slavesystem zusammen?
                      mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
                      • M MCU
                        mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        @apollon77
                        Hast du da ne Idee wgen der krummen id (admin.0.0 - mit ZWEI nullen)?
                        Support Repositoryverwaltung.
                        LESEN - gute Forenbeitrage
                        • M MCU
                          @mcu
                          Den Slave gibt es wohl auch nur noch als Fragment.
                          Die Frage ist, wie ist der abgeräumt worden?
                          Ich würde mal versuchen, den admin komplett rauszuwerfen
                          iob del admin
                          Vielleicht bekommt man das damit sauber.
                          @Lucifor1976 :
                          Den gibt es dann auch nicht mehr und es ist ein Überbleibsel?
                            Lucifor1976
                            Mit sicherheit, ich habe des Slave aber vorher ordnungsgemäß aus dem System geworfen.
                            iobroker host remove ioBrokerSlave
                            Diese Prozedur mache ich seit Jahren, Host remove, beide Systeme updaten, Host wieder einfügen.
                            Vor ein paar Monaten dann dieser Fehler mit der falschen Admin Version.
                            Heute hats dann den Master komplett zerschossen :(
                              Lucifor1976
                              Ich hab es mit Hängen und Würgen wieder hinbekommen,
                              der Slave wurde nicht korrekt entfernt, Nachdem ich erneut den Slave entfernt habe, ist plötzlich ein Adapter mit 4.x auf dem Master aufgetaucht, der liess sich jedoch nicht löschen. Hatte dann aber seltsamerweise die aktuelle Verionsnummer. Die Instanz ist nun deaktiviert und hat, warum auch immer die Bezeichnung Admin.0.0.
                              Den Slave von Grund auf neu aufgezogen und wieder hinzugefügt und nun läuft alles wieder und ist auf dem aktuellen Stand.
                              Jemand eine Idee wie ich den verweisten Eintrag entfernt bekomme?
                              Erledigt: Hab ihn in "System.Admin.0.0" gefunden, den Baum gelöscht, verweister Eintrag weg.
                                @lucifor1976
                                Dann schau dir jetzt nochmal die Ausgabe von
                                iob diag
                                im Ganzen an, ob das nun alles stimmig ist.
