  4. Could not process news: Error: timeout at http
    1.0k
    6.1k
errorproblem
19 Beiträge 6 Kommentatoren 2.0k Aufrufe 5 Beobachtet
    @digi-bit sagte in Could not process news: Error: timeout at http:
    Das ist System ist Aktuell
    wirklich?
    auf welches Repo/OS bezogen?
    Was man an Infos braucht um zu helfen weiß ich auch nicht so,
    Das steht alles hier
    fang mal mit der Langfassung von iob diag in code-tags an
    Digi-Bit
    @homoran sagte in Could not process news: Error: timeout at http:
    wirklich?
    Naja, relativ ^^
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2025.05.01 11:03:41 =~=~=~=~=~=~=~=~=~=~=~=
    Linux debianIOB1 6.1.0-33-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.133-1 (2025-04-10) x86_64
    permitted by applicable law.
    Last login: Thu May  1 11:00:10 2025 from 192.168.1.230
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    * Some output is masked. For full results please use 'iob diag --unmask' *
    Press any key to continue
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
    Static hostname: debianIOB1
          Icon name: computer-desktop
            Chassis: desktop 🖥️
             Kernel: Linux 6.1.0-33-amd64
       Architecture: x86-64
    Hardware Vendor: Intel_R_ Client Systems
     Hardware Model: NUC11PAHi5
    Firmware Version: PATGL357.0052.2023.0901.1439
    OS is similar to:
    model name	: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
    Docker          : false
    Virtualization  : none
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
    11:04:29 up 1 day, 18:32,  2 users,  load average: 0.63, 0.79, 0.83
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
                  Local time: Thu 2025-05-01 11:04:29 CEST
              Universal time: Thu 2025-05-01 09:04:29 UTC
                    RTC time: Thu 2025-05-01 09:04:29
                 NTP service: active
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    GROUPS=******** cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Mem:             50G        7.3G         36G        1.4M        6.7G         42G
    Swap:           1.0G          0B        1.0G
    Total:           51G        7.3G         37G
    Active iob-Instances: 	59
           47801 M total memory
            6966 M used memory
            2443 M active memory
            9734 M inactive memory
           35056 M free memory
            1122 M buffer memory
            5244 M swap cache
             975 M total swap
               0 M used swap
             975 M free swap
    top - 11:04:30 up 1 day, 18:32,  2 users,  load average: 0.63, 0.79, 0.83
    Tasks: 218 total,   2 running, 216 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  47801.5 total,  35056.2 free,   6966.7 used,   6367.2 buff/cache
    MiB Swap:    976.0 total,    976.0 free,      0.0 used.  40834.8 avail Mem
    *** FAILED SERVICES ***
     UNIT                LOAD   ACTIVE SUB    DESCRIPTION
    * nut-monitor.service loaded failed failed Network UPS Tools - power device monitor and shutdown controller
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs   24G     0   24G   0% /dev
    tmpfs          tmpfs     4.7G  1.2M  4.7G   1% /run
    /dev/sda2      ext4      456G   31G  403G   7% /
    tmpfs          tmpfs      24G     0   24G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
    tmpfs          tmpfs     4.7G     0  4.7G   0% /run/user/1000
    [Tue Apr 29 16:31:33 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Apr 29 16:31:33 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET      SOURCE    FSTYPE OPTIONS
    /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
    `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    2.4G	/var/
    1.9G	/var/lib
    905M	/var/lib/influxdb/engine
    876M	/var/lib/influxdb/engine/data/dd66704071003165/autogen
    Archived and active journals take up 62.2M in the file system.
    /opt/iobroker/backups:
    21G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.6G	/opt/iobroker/iobroker-data/
    1.1G	/opt/iobroker/iobroker-data/files
    313M	/opt/iobroker/iobroker-data/backup-objects
    232M	/opt/iobroker/iobroker-data/files/vis-2.0
    170M	/opt/iobroker/iobroker-data/files/vis-2
    94M	/opt/iobroker/iobroker-data/objects.jsonl
    62M	/opt/iobroker/iobroker-data/states.jsonl
    41M	/opt/iobroker/iobroker-data/files/vis-2.0/Meine_Icons/Netzwerk/HeidiSQL_12.5.0.6677_Setup.exe
    41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.36__Embed_with_CMSIS-DAP_L430047T-if03
    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.36__Embed_with_CMSIS-DAP_L430047T-if00
    /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.19.0
    /usr/bin/node 		v20.19.0
    /usr/bin/npm 		11.3.0
    /usr/bin/npx 		11.3.0
    /usr/bin/corepack 	0.31.0
    nodejs:
     Installed: 20.19.0-1nodesource1
     Candidate: 20.19.1-1nodesource1
     Version table:
        20.19.1-1nodesource1 1001
           500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
    *** 20.19.0-1nodesource1 1001
        20.18.3-1nodesource1 1001
        20.18.2-1nodesource1 1001
        20.18.1-1nodesource1 1001
        20.18.0-1nodesource1 1001
        20.17.0-1nodesource1 1001
        20.16.0-1nodesource1 1001
        20.15.1-1nodesource1 1001
        20.15.0-1nodesource1 1001
        20.14.0-1nodesource1 1001
        20.13.1-1nodesource1 1001
        20.13.0-1nodesource1 1001
        20.12.2-1nodesource1 1001
        20.12.1-1nodesource1 1001
        20.12.0-1nodesource1 1001
        20.11.1-1nodesource1 1001
        20.11.0-1nodesource1 1001
        20.10.0-1nodesource1 1001
        20.9.0-1nodesource1 1001
        20.8.1-1nodesource1 1001
        20.8.0-1nodesource1 1001
        20.7.0-1nodesource1 1001
        20.6.1-1nodesource1 1001
        20.6.0-1nodesource1 1001
        20.5.1-1nodesource1 1001
        20.5.0-1nodesource1 1001
        20.4.0-1nodesource1 1001
        20.3.1-1nodesource1 1001
        20.3.0-1nodesource1 1001
        20.2.0-1nodesource1 1001
        20.1.0-1nodesource1 1001
        20.0.0-1nodesource1 1001
        18.19.0+dfsg-6~deb12u2 500
           500 http://deb.debian.org/debian bookworm/main amd64 Packages
        18.19.0+dfsg-6~deb12u1 500
           500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    debianIOB1          debianIOB1 (version: 7.0.6, hostname: debianIOB1    , alive, uptime: 153174)
    raspberrypi-IOB     raspberrypi-IOB (version: 7.0.6, hostname: raspberrypi-IOB, alive, uptime: 153164)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.5
    javascript: 	8.9.1
    nodejs modules from github: 	2
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
    Adapter State
    + system.adapter.admin.0                  : admin                 : debianIOB1                               -  enabled, port: 12080, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : debianIOB1                               -  enabled, port: 12081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : debianIOB1                               -  enabled
    + system.adapter.backitup.0               : backitup              : debianIOB1                               -  enabled
    + system.adapter.bambulab.0               : bambulab              : debianIOB1                               -  enabled, port: 8883
     system.adapter.ble.0                    : ble                   : debianIOB1                               - disabled
    + system.adapter.cameras.0                : cameras               : debianIOB1                               -  enabled, port: 8200, bind: 127.0.0.1
     system.adapter.daswetter.0              : daswetter             : raspberrypi-IOB                          -  enabled
    + system.adapter.denon.0                  : denon                 : debianIOB1                               -  enabled
     system.adapter.dwd.0                    : dwd                   : debianIOB1                               -  enabled
    + system.adapter.dysonairpurifier.0       : dysonairpurifier      : raspberrypi-IOB                          -  enabled
    + system.adapter.email.0                  : email                 : raspberrypi-IOB                          -  enabled
    + system.adapter.enigma2.0                : enigma2               : debianIOB1                               -  enabled
    + system.adapter.enigma2.1                : enigma2               : debianIOB1                               -  enabled
     system.adapter.flot.0                   : flot                  : debianIOB1                               - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : debianIOB1                               -  enabled
    + system.adapter.harmony.0                : harmony               : debianIOB1                               -  enabled
    + system.adapter.heos.0                   : heos                  : debianIOB1                               -  enabled
    + system.adapter.hmip.0                   : hmip                  : debianIOB1                               -  enabled
     system.adapter.ical.0                   : ical                  : raspberrypi-IOB                          -  enabled
     system.adapter.icons-material-png.0     : icons-material-png    : debianIOB1                               - disabled
     system.adapter.icons-material-svg.0     : icons-material-svg    : debianIOB1                               - disabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : debianIOB1                               - disabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : debianIOB1                               - disabled
     system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: debianIOB1                               - disabled
    + system.adapter.influxdb.0               : influxdb              : debianIOB1                               -  enabled, port: 8086
     system.adapter.info.0                   : info                  : debianIOB1                               - disabled
    + system.adapter.iot.0                    : iot                   : debianIOB1                               -  enabled
    + system.adapter.iot.2                    : iot                   : debianIOB1                               -  enabled
    + system.adapter.javascript.0             : javascript            : debianIOB1                               -  enabled
    + system.adapter.linux-control.0          : linux-control         : raspberrypi-IOB                          -  enabled
    + system.adapter.logparser.0              : logparser             : raspberrypi-IOB                          -  enabled
     system.adapter.material.0               : material              : debianIOB1                               - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : debianIOB1                               -  enabled, port: 54321
    + system.adapter.moma.0                   : moma                  : debianIOB1                               -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : debianIOB1                               -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.netatmo-energy.0         : netatmo-energy        : debianIOB1                               -  enabled
    + system.adapter.nut.0                    : nut                   : debianIOB1                               -  enabled
    + system.adapter.nut.1                    : nut                   : raspberrypi-IOB                          -  enabled
    + system.adapter.openligadb.0             : openligadb            : raspberrypi-IOB                          -  enabled
     system.adapter.openweathermap.0         : openweathermap        : debianIOB1                               -  enabled
    + system.adapter.ping.0                   : ping                  : debianIOB1                               -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi-IOB                          -  enabled
    + system.adapter.radar2.0                 : radar2                : raspberrypi-IOB                          -  enabled
    + system.adapter.reolink.0                : reolink               : debianIOB1                               -  enabled
    + system.adapter.reolink.1                : reolink               : debianIOB1                               -  enabled
    + system.adapter.reolink.2                : reolink               : debianIOB1                               -  enabled
    + system.adapter.reolink.3                : reolink               : debianIOB1                               -  enabled
    + system.adapter.reolink.4                : reolink               : debianIOB1                               -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi-IOB                          -  enabled
     system.adapter.samsung.0                : samsung               : debianIOB1                               - disabled
    + system.adapter.scenes.0                 : scenes                : debianIOB1                               -  enabled
    + system.adapter.simple-api.0             : simple-api            : debianIOB1                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
     system.adapter.smartthings.0            : smartthings           : debianIOB1                               - disabled
    + system.adapter.snmp.0                   : snmp                  : debianIOB1                               -  enabled
    + system.adapter.sonoff.0                 : sonoff                : debianIOB1                               -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : debianIOB1                               -  enabled, port: 3306
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi-IOB                          -  enabled
    + system.adapter.tankerkoenig.1           : tankerkoenig          : raspberrypi-IOB                          -  enabled
    + system.adapter.telegram.0               : telegram              : debianIOB1                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : raspberrypi-IOB                          -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : debianIOB1                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : debianIOB1                               -  enabled
    + system.adapter.tuya.1                   : tuya                  : raspberrypi-IOB                          -  enabled
    + system.adapter.unifi.0                  : unifi                 : debianIOB1                               -  enabled
     system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : debianIOB1                               - disabled
     system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : debianIOB1                               - disabled
     system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: debianIOB1                               - disabled
     system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: debianIOB1                               - disabled
    + system.adapter.vis-2.0                  : vis-2                 : debianIOB1                               -  enabled
     system.adapter.vis-history.0            : vis-history           : debianIOB1                               - disabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debianIOB1                               - disabled
     system.adapter.vis-icontwo.0            : vis-icontwo           : debianIOB1                               - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : debianIOB1                               -  enabled
     system.adapter.vis-justgage.0           : vis-justgage          : debianIOB1                               - disabled
     system.adapter.vis-map.0                : vis-map               : debianIOB1                               - disabled
     system.adapter.vis-material.0           : vis-material          : debianIOB1                               - disabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : debianIOB1                               - disabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : debianIOB1                               - disabled
     system.adapter.vis.0                    : vis                   : debianIOB1                               -  enabled
    + system.adapter.web.0                    : web                   : debianIOB1                               -  enabled, port: 12085, bind: 0.0.0.0, run as: admin
    + system.adapter.web.1                    : web                   : debianIOB1                               -  enabled, port: 12090, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : debianIOB1                               -  enabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : debianIOB1                               -  enabled
    + system.adapter.wled.0                   : wled                  : debianIOB1                               -  enabled
    + system.adapter.zigbee.0                 : zigbee                : debianIOB1                               -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.7
    Adapter    "backitup"     : 3.0.31   , installed 3.2.0
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "heos"         : 2.2.1    , installed 2.2.4
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 3.3.0    , installed 3.5.0
    Adapter    "javascript"   : 8.8.3    , installed 8.9.1
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "netatmo-energy": 2.8.0   , installed 2.8.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "ping"         : 1.6.2    , installed 1.7.9
    Adapter    "reolink"      : 1.2.1    , installed 1.2.1
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "simple-api"   : 2.8.0    , installed 3.0.6
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.1.2    , installed 3.2.1
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "trashschedule": 3.3.0    , installed 4.0.0
    Adapter    "tuya"         : 3.16.0   , installed 3.17.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.11.2
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.1
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.12
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.5
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.3
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects: 	88679
    States: 	77883
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:5 https://packages.grafana.com/oss/deb stable InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:9 https://repos.influxdata.com/debian stable InRelease
    Hit:4 https://downloads.mariadb.com/Tools/debian bookworm InRelease
    Hit:7 https://dlm.mariadb.com/repo/mariadb-server/11.rolling/repo/debian bookworm InRelease
    Hit:8 https://dlm.mariadb.com/repo/maxscale/latest/apt bookworm InRelease
    Hit:10 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 4
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       15106      875/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       25197      875/iobroker.js-con
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       36167      1574/io.sonoff.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       36130      1425/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       36129      1425/io.mqtt.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          290        1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21175      695/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      102        19396      766/mariadbd
    tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          21205      860/upsd
    tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1001       8590197    670467/io.cameras.0
    tcp6       0      0 ::1:3493                :::*                    LISTEN      0          21206      860/upsd
    tcp6       0      0 :::12081                :::*                    LISTEN      1001       3603155    280857/io.admin.1
    tcp6       0      0 :::12080                :::*                    LISTEN      1001       3570318    278127/io.admin.0
    tcp6       0      0 :::12085                :::*                    LISTEN      1001       8596549    670435/io.web.0
    tcp6       0      0 :::12090                :::*                    LISTEN      1001       8595625    670428/io.web.1
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10808      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          21177      695/sshd: /usr/sbin
    tcp6       0      0 :::3306                 :::*                    LISTEN      102        19397      766/mariadbd
    tcp6       0      0 :::3000                 :::*                    LISTEN      104        21225      892/grafana
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       36430      1872/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        15072      656/influxd
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       38107      1338/io.harmony.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       38108      1338/io.harmony.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18429      595/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          291        1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       43384      2145/io.wled.0
    udp        0      0 0.0.0.0:39277           0.0.0.0:*                           1001       40560      1543/io.snmp.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       40627      1592/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       40628      1592/io.tuya.0
    udp        0      0 0.0.0.0:46838           0.0.0.0:*                           1001       40559      1543/io.snmp.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       40279      1408/io.mihome-vacu
    udp        0      0 0.0.0.0:55257           0.0.0.0:*                           1001       39341      1354/io.heos.0
    udp        0      0 0.0.0.0:59233           0.0.0.0:*                           1001       40561      1543/io.snmp.0
    udp6       0      0 :::111                  :::*                                0          15645      1/init
    2025-05-01 10:41:14.860  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    2025-05-01 10:41:35.093  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    2025-05-01 10:42:08.809  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    2025-05-01 10:42:08.834  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    2025-05-01 10:42:08.837  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    2025-05-01 10:42:37.288  - info: web.0 (670435) ==> Connected system.user.admin from ::ffff:
    2025-05-01 10:42:59.355  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    2025-05-01 10:42:59.357  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    2025-05-01 10:43:18.052  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    2025-05-01 10:45:35.246  - info: web.0 (670435) <== Disconnect system.user.admin from ::ffff:vis-2
    2025-05-01 10:55:27.313  - info: web.0 (670435) <== Disconnect system.user.admin from ::ffff:vis-2
    2025-05-01 10:55:43.996  - warn: sonoff.0 (1574) Client [test] has invalid password or username
    2025-05-01 10:55:52.273  - info: web.0 (670435) <== Disconnect system.user.admin from ::ffff:vis-2
    2025-05-01 10:56:16.010  - info: host.debianIOB1 instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 760135
    2025-05-01 10:56:18.058  - info: openweathermap.0 (760135) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.0, js-controller: 7.0.6
    2025-05-01 10:56:43.468  - info: openweathermap.0 (760135) Terminated (NO_ERROR): Without reason
    2025-05-01 10:56:43.983  - info: host.debianIOB1 instance system.adapter.openweathermap.0 having pid 760135 terminated with code 0 (NO_ERROR)
    2025-05-01 11:00:00.123  - info: javascript.0 (616422) script.js.90:_Java.Speedtest_II: Speedtest mit Server 53495 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
    2025-05-01 11:00:05.004  - warn: trashschedule.0 (1915) [removeOldCacheFiles] Error: Not exists
    2025-05-01 11:00:06.011  - info: host.debianIOB1 instance system.adapter.dwd.0 in version "2.8.5" started with pid 761328
    2025-05-01 11:00:08.699  - info: host.debianIOB1 instance system.adapter.dwd.0 having pid 761328 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-05-01 11:00:29.358  - info: javascript.0 (616422) script.js.90:_Java.Speedtest_II: Speedtest durchgeführt. Ergebnisse: Download: 108.75 MB/s | Upload: 5.61 MB/s | Ping: 12.576ms
    2025-05-01 11:01:16.298  - info: web.0 (670435) ==> Connected system.user.admin from ::ffff:230.104
    2025-05-01 11:04:10.748  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    2025-05-01 11:04:10.750  - info: zigbee.0 (1644) Device '0x0017880106f67ccd' announced itself
    iob diag has finished.
    Press any key for a summary
    Copy text starting here:
    			v.2025-02-23
             Chassis: desktop 🖥️
    Installation: 		native
    Kernel: 		x86_64
    Userland: 		64 bit
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    Boot Target: 		multi-user.target
    Pending OS-Updates: 	4
    Pending iob updates: 	0
    Nodejs-Installation:
    /usr/bin/npm 		11.3.0
    /usr/bin/npx 		11.3.0
    Recommended versions are nodejs 20.19.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Swap:           1.0G          0B        1.0G
    Total:           51G        7.3G         37G
    ioBroker Core: 		js-controller 		7.0.6
    			admin 			7.6.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects: 		88679
    States: 		77883
    Size of iob-Database:
    63M	/opt/iobroker/iobroker-data/states.jsonl
    === Mark text until here for copying ===
    Abgemeldet
    [/s]
    Etwas lang hoffe es hilft
    mfg
    Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
    7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
    • D Digi-Bit
      wirklich?
      Naja, relativ ^^
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
              Chassis: desktop 🖥️
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 8
                   NTP service: active
               RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
      Total:           51G        7.3G         37G
              6966 M used memory
             35056 M free memory
              5244 M swap cache
               975 M total swap
                 0 M used swap
               975 M free swap
      *** FILESYSTEM ***
      /var:
      2.4G	/var/
      1.9G	/var/lib
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm 		11.3.0
      /usr/bin/npx 		11.3.0
      nodejs:
       Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.6.5
      javascript: 	8.9.1
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	88679
      States: 	77883
      Pending Updates: 4
      			v.2025-02-23
               Chassis: desktop 🖥️
      Kernel: 		x86_64
      Userland: 		64 bit
      User-ID: 		1000
      /usr/bin/npm 		11.3.0
      /usr/bin/npx 		11.3.0
      MEMORY:
      Swap:           1.0G          0B        1.0G
      Total:           51G        7.3G         37G
      			admin 			7.6.5
      Objects type: jsonl
      States  type: jsonl
      Objects: 		88679
      States: 		77883
      Abgemeldet
      [/s]
      mfg
      Digi-Bit
      ich glaube das es gekürtz wurde
      putty.log
      vielleicht besser ?
      mfg
      Digi-Bit
      • D Digi-Bit
        Schönen Feiertag erstmal ;)
        ich habe schon seit Wochen immer diese Meldung
        Could not process news: Error: timeout at http://***********/assets/bootstrap-BUITsQhA.js:17:46068 at r (http://**********/assets/bootstrap-BUITsQhA.js:16:7862)
        Ich habe Google schon so oft befragt und auch einige sachen ausprobiert wie Node.js neu installiert bzw update gemacht Java ausgeschaltet um zu sehen ob ein Script Amok läuft , Debian und IOB neu installiert und Backup eingespielt ..........
        Ich muss dazu sagen das ich sonst keine merklichen Probleme habe, alles scheint Normal zu Funktionieren aber irgend was muss es ja sein das da ein Fehler immer
        eingeblendet wird,
        Ich weiß auch nicht mehr wonach ich suchen soll.
        Das ist System ist Aktuell und rennt auf einem NUC I5/32GB
        Was man an Infos braucht um zu helfen weiß ich auch nicht so, aber wenn was benötigt wird kann ich das natürlich liefern !
        Wäre sehr dankbar wenn mich einer in die richtige Richtung schuppsen würde 😊
        MFG
        Digi-Bit
        arteckA Offline
        arteckA Offline
        arteck
        @digi-bit
        was soll die maskierung... du suchst hilfe und postet ein schnippsel..
        ausserdm LOG immer als Text posten..
        du mus** mal unter htt******/******** schauen und dann kannst du im LOG sugh sehen..das mal posten
        na hats funktionirt ??
        • arteckA arteck
          @digi-bit
          Digi-Bit
          schrieb am zuletzt editiert von Digi-Bit
          @arteck sagte in Could not process news: Error: timeout at http:
          @digi-bit
          Ich bin mir nicht sicher was Sie meinen.
          Das steht nicht im Log sondern wird im Browser einge4blendet und irgend wann verschwindet es auch wieder.
          darum habe ich das auch noch mal als Screenshot gemacht,
          Ich gehe mal davon aus das es was mit dem IOB zu tun hat und nicht mit den Opera/FireFox/Crome Browser
          wir reden doch von diesem hier :
          Could not process news: Error: timeout at http://10.10.10.100:12080/assets/bootstrap-BUITsQhA.js:17:46068 at r (http://10.10.10.100:12080/assets/bootstrap-BUITsQhA.js:16:7862)
          im IOB Log finde ich sowas wie " sugh " nicht und auch nicht im Putty Log
          mfg
          Digi-Bit
          • D Digi-Bit
            @digi-bit
            mfg
            Digi-Bit
            mcm1957M Online
            mcm1957M Online
            mcm1957
            Dieser Beitrag wurde gelöscht!
            • arteckA Offline
              arteckA Offline
              arteck
              was ist das für eine Adresse ??? wo kommt die her.. das muss was lokales sein..
              und klar findest du nix zu " sugh " warum auch.. das ist nur Ausgedacht...
              haus-automatisierungH D 2 Antworten Letzte Antwort
              • arteckA arteck
                haus-automatisierungH Offline
                Das wird wohl die IP vom ioBroker-System sein. Ist doch eine ganz normale IP aus einem privaten Adressbereich. Sehe kein Problem.
                Am Ende ist der Fehler erstmal unkritisch. Die news sind ja nur die Neuigkeiten im ioBroker-Umfeld. Hast Du Pihole oder ähnliches aktiv? Die werden von https://iobroker.live/repo/news.json abgerufen.
                📚 Meine Dokumentation
                haus-automatisierungH D 3 Antworten Letzte Antwort
                  Der Fehler kann auch auftreten, wenn Wert von admin.0.info.newsFeed kein gültiges JSON ist. Kannst Du mal zeigen, was da bei Dir aktuell drin steht?
                  • arteckA arteck
                    Digi-Bit
                    Jep, vom Router kommt die als internes Netzwerk der IOB läuft von Anfang an schon auf diese Adresse .......so 8 Jahre ....
                    ist das ein Problem jetzt ?
                    mfg
                    Digi-Bit
                      Digi-Bit
                      @haus-automatisierung sagte in Could not process news: Error: timeout at http:
                      Pihole das sagt mir Ganix daher würde ich sagen das ich sowas nicht habe !
                      mfg
                      Digi-Bit
                        Digi-Bit
                        Falsch zitiert :(
                        Delete ;)
                          Digi-Bit
                          Guten Abend ;)
                          Ja. sieht etwas komisch alles aus aber nunja
                          [{"title":{"de":"Bei KISSHome Studie teilnehmen","en":"Participate in KISSHome study"},"content":{"de":"Liebe ioBroker-Community,\n\nwir möchten euch herzlich einladen, an der Studie unseres Partners KISSHome teilzunehmen und dabei 50€ zu verdienen, solange der Vorrat reicht!\nIm Forschungsprojekt KISSHome wird untersucht, wie die Sicherheit in Smarthome Umgebungen durch die Entwicklung von nutzerfreundlichen und KI-gestützten Sicherheitslösungen verbessert werden kann.\nGesucht werden aktive ioBroker Nutzer, die eine Fritz!Box als Router verwenden und bereit sind, ihre Smart Home-Systeme durch einen einfach zu installierenden Adapter zu teilen.\nEure Teilnahme ermöglicht die Entwicklung praxisnaher Sicherheitslösungen, die allen Nutzern offen und kostenfrei zur Verfügung gestellt werden sollen.\nErfahrt mehr über die Teilnahmedetails und wie ihr durch eure Mitwirkung die Zukunft der Smart Homes sicherer gestalten könnt.\nWir freuen uns auf eure Unterstützung und Zusammenarbeit!\n\nEuer ioBroker-Team","en":"Dear ioBroker community,\n\nwe would like to invite you to participate in the study of our partner KISSHome and earn 50€ while supplies last!\nThe KISSHome research project investigates how security in smart home environments can be improved by developing user-friendly and AI-supported security solutions.\nWe are looking for active ioBroker users who use a Fritz!Box as a router and are willing to share their smart home systems through an easy-to-install adapter.\nYour participation enables the development of practice-oriented security solutions that should be made available to all users openly and free of charge.\nLearn more about the participation details and how you can help make the future of smart homes safer through your participation.\nWe look forward to your support and cooperation!\n\nYour ioBroker team"},"id":"kisshome-research-3","class":"info","created":"2024-12-21T00:00:00.000Z","link":"https://kisshome-research.if-is.net/","date-end":"2025-03-30T00:00:00.000Z","img":"data:image/svg+xml;base64,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","conditions":{"tr-064":"installed"}},{"title":{"en":"Cloud / Vis offline Christmas offer 2024","de":"Cloud / Vis Offline Weihnachtsangebot 2024","ru":"Новогоднее предложение Cloud / Vis offline 2024","pt":"Cloud / Vis offline oferta de Natal 2024","nl":"Cloud / Vis offline Kerstaanbieding 2024","fr":"Offre de Noël hors ligne Cloud / Vis 2024","it":"Offerta di Natale offline Cloud/Vis 2024","es":"Oferta de Navidad fuera de línea de Cloud / Vis 2024","pl":"Cloud / Vis offline Oferta świąteczna 2024","uk":"Cloud / Vis офлайн Різдвяна пропозиція 2024","zh-cn":"Cloud / Vis 线下圣诞节优惠 2024"},"content":{"en":"There is again a discount on the cloud packages of around 27%! However, we have to limit the availability of the cloud or remote access licenses again in order to guarantee the stability and availability of the servers. The following applies to these licenses: As long as stocks last :). The assistant licenses are unlimited!\n\nRead more here: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (German only)","de":"Auf die Cloud-Pakete gibt es wieder einen Rabatt von rund 27%!\nAllerdings müssen wir die Verfügbarkeit der Cloud- bzw. Fernzugriffslizenzen wieder einschränken, um die Stabilität und Verfügbarkeit der Server zu gewährleisten. Für diese Lizenzen gilt: Solange der Vorrat reicht :).\nDie Assistentenlizenzen sind unbegrenzt!\n\nDer reguläre Preis einiger Produkte wird erhöht, sodass Sie die letzte Chance haben, eine Fernzugriffs- oder Assistentenlizenz zum alten Preis zu kaufen.","ru":"На облачные пакеты снова действует скидка около 27%! Однако мы должны снова ограничить доступность облачных лицензий или лицензий удаленного доступа, чтобы гарантировать стабильность и доступность серверов. К этим лицензиям применимо следующее: Пока доступно :). Лицензии ассистента не ограничены!\n\nПодробнее здесь: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (только на немецком языке)","pt":"Há novamente um desconto nos pacotes de nuvem em torno de 27%! No entanto, temos que limitar a disponibilidade da nuvem ou licenças de acesso remoto novamente para garantir a estabilidade e disponibilidade dos servidores. O seguinte se aplica a essas licenças: Enquanto durarem os estoques :). As licenças do assistente são ilimitadas!\n\nLeia mais aqui: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (apenas em alemão)","nl":"Er is weer een korting op de cloudpakketten van circa 27%! Wel moeten we de beschikbaarheid van de cloud- of remote access-licenties weer inperken om de stabiliteit en beschikbaarheid van de servers te garanderen. Voor deze licenties geldt het volgende: Zolang de voorraad strekt :). De assistent-licenties zijn onbeperkt!\n\nLees hier meer: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (alleen Duits)","fr":"Il y a encore une remise sur les forfaits cloud d'environ 27% ! Cependant, nous devons à nouveau limiter la disponibilité des licences cloud ou d'accès distant afin de garantir la stabilité et la disponibilité des serveurs. Ce qui suit s'applique à ces licences : Jusqu'à épuisement des stocks :). Les licences assistantes sont illimitées !\n\nEn savoir plus ici : https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (en allemand uniquement)","it":"C'è di nuovo uno sconto sui pacchetti cloud di circa il 27%! Tuttavia, dobbiamo limitare nuovamente la disponibilità delle licenze cloud o di accesso remoto per garantire la stabilità e la disponibilità dei server. Quanto segue si applica a queste licenze: Fino ad esaurimento scorte :). Le licenze di assistente sono illimitate!\n\nLeggi di più qui: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (solo in tedesco)","es":"¡Nuevamente hay un descuento en los paquetes en la nube de alrededor del 27%! Sin embargo, tenemos que volver a limitar la disponibilidad de la nube o las licencias de acceso remoto para garantizar la estabilidad y disponibilidad de los servidores. Para estas licencias se aplica lo siguiente: Hasta agotar existencias :). ¡Las licencias de asistente son ilimitadas!\n\nLea más aquí: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (solo en alemán)","pl":"Ponownie mamy zniżkę na pakiety w chmurze w wysokości około 27%! Musimy jednak ponownie ograniczyć dostępność licencji na chmurę lub dostęp zdalny, aby zagwarantować stabilność i dostępność serwerów. Do tych licencji obowiązuje: Do wyczerpania zapasów :). Licencje asystenta są nieograniczone!\n\nPrzeczytaj więcej tutaj: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (tylko w języku niemieckim)","uk":"Знову діє знижка на хмарні пакети близько 27%! Однак нам знову потрібно обмежити доступність ліцензій на хмару або віддалений доступ, щоб гарантувати стабільність і доступність серверів. До цих ліцензій відноситься наступне: доки вичерпаються запаси :). Ліцензії помічника необмежені! Звичайна ціна на деякі продукти буде підвищена, тож у вас є останній шанс придбати віддалений доступ або ліцензію помічника за старою ціною.\n\nДокладніше тут: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (лише німецькою мовою)","zh-cn":"云套餐又优惠了40%左右!但是,我们必须再次限制云或远程访问许可证的可用性,以保证服务器的稳定性和可用性。以下内容适用于这些许可证:只要存货售完 :)。助理许可证是无限的!\n\n在此处阅读更多信息:https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024(仅限德语)"},"img":"data:image/png;base64,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","linkTitle":"Mehr auf Deutsch lesen","link":"https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024","id":"christmas-action-2024","class":"info","fa-icon":"usb","created":"2024-12-09T11:00:00.000Z","date-end":"2025-01-06T23:00:00.000Z"},{"title":{"en":"Adapter ioBroker.hyperion will be deprecated","de":"Adapter ioBroker.hyperion wird abgekündigt","ru":"Адаптер ioBroker.hyperion будет обесценен","pt":"Adaptador ioBroker.hyperion será deprecated","nl":"Adapter ioBroker.hyperion zal worden verouderd","fr":"Adaptateur ioBroker.hyperion sera déprécié","it":"Adattatore ioBroker.hyperion sarà deprecato","es":"Adaptador ioBroker.hiperión será deprecatado","pl":"Adapter jOBroker.hyperion zostanie zdepregowany","uk":"Адаптер ioBroker.hyperion буде депресовано","zh-cn":"适配器ioBroker.hyperion将贬值"},"content":{"en":"The adapter ioBroker.hyperion will be deprecated and be removed from repositories. Please note that this does not refer to ioBroker.hyperion-ng but to ioBroker.hyperion. According to forum postings the adapter ioBroker.hyperion is no longer working and there was no reaction from maintainer. With ioBroker.hyperion-ng an replacement seems to exist (altough this adapter is not activly developed either).","de":"Der Adapter ioBroker.hyperion wird abgekündigt und aus den Repositories entfernt. Bitte beachten Sie, dass sich dies nicht auf ioBroker .hyperion-ng sondern nur auf ioBroker.hyperion bezieht. Gemäß Forumsbeiträgen fun ktioniert der Adapter ioBroker.hyperion nicht mehr und es gab keine Reaktion vom Betreuer. Mit ioBroker.hyperion-ng scheint ein Ersatz zu existieren (auch wenn dieser Adapter nicht aktiv entwickelt wird).","ru":"Адаптер ioBroker.hyperion будет обесценен и удален из хранилищ. Обратите внимание, что это не относится к ioBroker. гиперион-нг, но для ioBroker. гиперион.
                          Ich musste es etwas Kürzen weil er das sonst nicht absenden wollte !
                          Muss das so aussehen ?
                          mfg
                          Digi-Bit
                          Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
                          7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
                          • D Digi-Bit
                            @haus-automatisierung sagte in Could not process news: Error: timeout at http:
                            Der Fehler kann auch auftreten, wenn Wert von admin.0.info.newsFeed kein gültiges JSON ist. Kannst Du mal zeigen, was da bei Dir aktuell drin steht?
                            Guten Abend ;)
                            Ja. sieht etwas komisch alles aus aber nunja
                            [{"title":{"de":"Bei KISSHome Studie teilnehmen","en":"Participate in KISSHome study"},"content":{"de":"Liebe ioBroker-Community,\n\nwir möchten euch herzlich einladen, an der Studie unseres Partners KISSHome teilzunehmen und dabei 50€ zu verdienen, solange der Vorrat reicht!\nIm Forschungsprojekt KISSHome wird untersucht, wie die Sicherheit in Smarthome Umgebungen durch die Entwicklung von nutzerfreundlichen und KI-gestützten Sicherheitslösungen verbessert werden kann.\nGesucht werden aktive ioBroker Nutzer, die eine Fritz!Box als Router verwenden und bereit sind, ihre Smart Home-Systeme durch einen einfach zu installierenden Adapter zu teilen.\nEure Teilnahme ermöglicht die Entwicklung praxisnaher Sicherheitslösungen, die allen Nutzern offen und kostenfrei zur Verfügung gestellt werden sollen.\nErfahrt mehr über die Teilnahmedetails und wie ihr durch eure Mitwirkung die Zukunft der Smart Homes sicherer gestalten könnt.\nWir freuen uns auf eure Unterstützung und Zusammenarbeit!\n\nEuer ioBroker-Team","en":"Dear ioBroker community,\n\nwe would like to invite you to participate in the study of our partner KISSHome and earn 50€ while supplies last!\nThe KISSHome research project investigates how security in smart home environments can be improved by developing user-friendly and AI-supported security solutions.\nWe are looking for active ioBroker users who use a Fritz!Box as a router and are willing to share their smart home systems through an easy-to-install adapter.\nYour participation enables the development of practice-oriented security solutions that should be made available to all users openly and free of charge.\nLearn more about the participation details and how you can help make the future of smart homes safer through your participation.\nWe look forward to your support and cooperation!\n\nYour ioBroker team"},"id":"kisshome-research-3","class":"info","created":"2024-12-21T00:00:00.000Z","link":"https://kisshome-research.if-is.net/","date-end":"2025-03-30T00:00:00.000Z","img":"data:image/svg+xml;base64,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","conditions":{"tr-064":"installed"}},{"title":{"en":"Cloud / Vis offline Christmas offer 2024","de":"Cloud / Vis Offline Weihnachtsangebot 2024","ru":"Новогоднее предложение Cloud / Vis offline 2024","pt":"Cloud / Vis offline oferta de Natal 2024","nl":"Cloud / Vis offline Kerstaanbieding 2024","fr":"Offre de Noël hors ligne Cloud / Vis 2024","it":"Offerta di Natale offline Cloud/Vis 2024","es":"Oferta de Navidad fuera de línea de Cloud / Vis 2024","pl":"Cloud / Vis offline Oferta świąteczna 2024","uk":"Cloud / Vis офлайн Різдвяна пропозиція 2024","zh-cn":"Cloud / Vis 线下圣诞节优惠 2024"},"content":{"en":"There is again a discount on the cloud packages of around 27%! However, we have to limit the availability of the cloud or remote access licenses again in order to guarantee the stability and availability of the servers. The following applies to these licenses: As long as stocks last :). The assistant licenses are unlimited!\n\nRead more here: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (German only)","de":"Auf die Cloud-Pakete gibt es wieder einen Rabatt von rund 27%!\nAllerdings müssen wir die Verfügbarkeit der Cloud- bzw. Fernzugriffslizenzen wieder einschränken, um die Stabilität und Verfügbarkeit der Server zu gewährleisten. Für diese Lizenzen gilt: Solange der Vorrat reicht :).\nDie Assistentenlizenzen sind unbegrenzt!\n\nDer reguläre Preis einiger Produkte wird erhöht, sodass Sie die letzte Chance haben, eine Fernzugriffs- oder Assistentenlizenz zum alten Preis zu kaufen.","ru":"На облачные пакеты снова действует скидка около 27%! Однако мы должны снова ограничить доступность облачных лицензий или лицензий удаленного доступа, чтобы гарантировать стабильность и доступность серверов. К этим лицензиям применимо следующее: Пока доступно :). Лицензии ассистента не ограничены!\n\nПодробнее здесь: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (только на немецком языке)","pt":"Há novamente um desconto nos pacotes de nuvem em torno de 27%! No entanto, temos que limitar a disponibilidade da nuvem ou licenças de acesso remoto novamente para garantir a estabilidade e disponibilidade dos servidores. O seguinte se aplica a essas licenças: Enquanto durarem os estoques :). As licenças do assistente são ilimitadas!\n\nLeia mais aqui: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (apenas em alemão)","nl":"Er is weer een korting op de cloudpakketten van circa 27%! Wel moeten we de beschikbaarheid van de cloud- of remote access-licenties weer inperken om de stabiliteit en beschikbaarheid van de servers te garanderen. Voor deze licenties geldt het volgende: Zolang de voorraad strekt :). De assistent-licenties zijn onbeperkt!\n\nLees hier meer: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (alleen Duits)","fr":"Il y a encore une remise sur les forfaits cloud d'environ 27% ! Cependant, nous devons à nouveau limiter la disponibilité des licences cloud ou d'accès distant afin de garantir la stabilité et la disponibilité des serveurs. Ce qui suit s'applique à ces licences : Jusqu'à épuisement des stocks :). Les licences assistantes sont illimitées !\n\nEn savoir plus ici : https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (en allemand uniquement)","it":"C'è di nuovo uno sconto sui pacchetti cloud di circa il 27%! Tuttavia, dobbiamo limitare nuovamente la disponibilità delle licenze cloud o di accesso remoto per garantire la stabilità e la disponibilità dei server. Quanto segue si applica a queste licenze: Fino ad esaurimento scorte :). Le licenze di assistente sono illimitate!\n\nLeggi di più qui: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (solo in tedesco)","es":"¡Nuevamente hay un descuento en los paquetes en la nube de alrededor del 27%! Sin embargo, tenemos que volver a limitar la disponibilidad de la nube o las licencias de acceso remoto para garantizar la estabilidad y disponibilidad de los servidores. Para estas licencias se aplica lo siguiente: Hasta agotar existencias :). ¡Las licencias de asistente son ilimitadas!\n\nLea más aquí: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (solo en alemán)","pl":"Ponownie mamy zniżkę na pakiety w chmurze w wysokości około 27%! Musimy jednak ponownie ograniczyć dostępność licencji na chmurę lub dostęp zdalny, aby zagwarantować stabilność i dostępność serwerów. Do tych licencji obowiązuje: Do wyczerpania zapasów :). Licencje asystenta są nieograniczone!\n\nPrzeczytaj więcej tutaj: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (tylko w języku niemieckim)","uk":"Знову діє знижка на хмарні пакети близько 27%! Однак нам знову потрібно обмежити доступність ліцензій на хмару або віддалений доступ, щоб гарантувати стабільність і доступність серверів. До цих ліцензій відноситься наступне: доки вичерпаються запаси :). Ліцензії помічника необмежені! Звичайна ціна на деякі продукти буде підвищена, тож у вас є останній шанс придбати віддалений доступ або ліцензію помічника за старою ціною.\n\nДокладніше тут: https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024 (лише німецькою мовою)","zh-cn":"云套餐又优惠了40%左右!但是,我们必须再次限制云或远程访问许可证的可用性,以保证服务器的稳定性和可用性。以下内容适用于这些许可证:只要存货售完 :)。助理许可证是无限的!\n\n在此处阅读更多信息:https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024(仅限德语)"},"img":"data:image/png;base64,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","linkTitle":"Mehr auf Deutsch lesen","link":"https://forum.iobroker.net/topic/78541/cloud-vis-offline-weihnachtsangebot-2024","id":"christmas-action-2024","class":"info","fa-icon":"usb","created":"2024-12-09T11:00:00.000Z","date-end":"2025-01-06T23:00:00.000Z"},{"title":{"en":"Adapter ioBroker.hyperion will be deprecated","de":"Adapter ioBroker.hyperion wird abgekündigt","ru":"Адаптер ioBroker.hyperion будет обесценен","pt":"Adaptador ioBroker.hyperion será deprecated","nl":"Adapter ioBroker.hyperion zal worden verouderd","fr":"Adaptateur ioBroker.hyperion sera déprécié","it":"Adattatore ioBroker.hyperion sarà deprecato","es":"Adaptador ioBroker.hiperión será deprecatado","pl":"Adapter jOBroker.hyperion zostanie zdepregowany","uk":"Адаптер ioBroker.hyperion буде депресовано","zh-cn":"适配器ioBroker.hyperion将贬值"},"content":{"en":"The adapter ioBroker.hyperion will be deprecated and be removed from repositories. Please note that this does not refer to ioBroker.hyperion-ng but to ioBroker.hyperion. According to forum postings the adapter ioBroker.hyperion is no longer working and there was no reaction from maintainer. With ioBroker.hyperion-ng an replacement seems to exist (altough this adapter is not activly developed either).","de":"Der Adapter ioBroker.hyperion wird abgekündigt und aus den Repositories entfernt. Bitte beachten Sie, dass sich dies nicht auf ioBroker .hyperion-ng sondern nur auf ioBroker.hyperion bezieht. Gemäß Forumsbeiträgen fun ktioniert der Adapter ioBroker.hyperion nicht mehr und es gab keine Reaktion vom Betreuer. Mit ioBroker.hyperion-ng scheint ein Ersatz zu existieren (auch wenn dieser Adapter nicht aktiv entwickelt wird).","ru":"Адаптер ioBroker.hyperion будет обесценен и удален из хранилищ. Обратите внимание, что это не относится к ioBroker. гиперион-нг, но для ioBroker. гиперион.
                            Ich musste es etwas Kürzen weil er das sonst nicht absenden wollte !
                            Muss das so aussehen ?
                            mfg
                            Digi-Bit
                            haus-automatisierungH Offline
                            @digi-bit Ja, Hauptsache das JSON ist gültig
                            📚 Meine Dokumentation
                            • D Digi-Bit
                              ich glaube das es gekürtz wurde
                              putty.log
                              vielleicht besser ?
                              mfg
                              Digi-Bit
                              @digi-bit
                              Da ist doch irgendwas händisch dran gefrickelt worden.
                              nodejs 20 kommt nicht mit npm 11 daher.
                              Installier das noch mal ORDENTLICH, ohne an npm herumzufummeln.
                              Und leg den User in die Gruppe 'adm' rein.
                              Veränder die Ausgaben von iob diag nicht.
                                @digi-bit
                                Digi-Bit
                                @thomas-braun sagte in Could not process news: Error: timeout at http:
                                @digi-bit
                                Moin
                                Ich habe das über den " Übersicht's Butten " gemacht
                                digibit@debianIOB1:~$ node -v
                                v20.19.1
                                digibit@debianIOB1:~$ npm -v
                                10.8.2
                                Welchen User soll ich den in Admin reinlegen ?
                                mfg
                                Digi-Bit
                                Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
                                7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
                                • D Digi-Bit
                                  @digi-bit
                                  Moin
                                  v20.19.1
                                  10.8.2
                                  mfg
                                  Digi-Bit
                                  @digi-bit sagte in Could not process news: Error: timeout at http:
                                  dann mach es nochmal über die Konsole
                                  iob diag
                                  und die Langfassung hier in code-tags posten
                                  • D Digi-Bit
                                    @digi-bit
                                    Moin
                                    v20.19.1
                                    10.8.2
                                    mfg
                                    Digi-Bit
                                    @digi-bit
                                    Da ist also irgendwas krumm, denn:
                                    /usr/bin/npm 		11.3.0
                                    Da hast du also manuell, am Paketmanager vorbei die Version 11.3.0 reingeklatscht.
                                    Und der username, denn du im Output von iob diag gelöscht hast gehört in die Gruppe adm rein.
