  4. div. 404 Fehler im IOB (Admin)
    1.0k
    6.1k
19 Beiträge 6 Kommentatoren 2.3k Aufrufe 6 Beobachtet
    Dass letzte Backup war vom 29.01.25 und am 28. hatte ich die Adapter upgedated. Kann dann nicht auseinander sein.
    @wsvd
    Dann die Langfassung von
    iob diag
    Auch wenn die Zusammenfassung eigentlich keinen Hinweis auf was 'krummes' liefert.
      @wsvd
      iob diag
      ```bash
      Script v.2024-10-19
      *** BASE SYSTEM ***
       Static hostname: odroid-m1-iob
             Icon name: computer
                Kernel: Linux 6.1.0-odroid-arm64
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       18:47:57 up 7 min,  2 users,  load average: 1.22, 1.01, 0.51
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2025-02-01 18:47:57 CET
                 Universal time: Sat 2025-02-01 17:47:57 UTC
                       RTC time: Sat 2025-02-01 17:47:57
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      mario
      HOME=/home/mario
      GROUPS=mario cdrom floppy audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        1.3G        6.0G        9.4M        618M        6.5G
      Swap:           5.0G          0B        5.0G
      Total:           12G        1.3G         11G
      Active iob-Instances:   13
               7449 M total memory
               1286 M used memory
               1125 M active memory
                352 M inactive memory
               5743 M free memory
                 52 M buffer memory
                537 M swap cache
               4790 M total swap
                  0 M used swap
               4790 M free swap
      top - 18:47:57 up 7 min,  2 users,  load average: 1.22, 1.01, 0.51
      Tasks: 152 total,   1 running, 151 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 57.1 id,  0.0 wa, 14.3 hi,  0.0 si,  0.0 st
      MiB Mem :   7449.3 total,   5743.1 free,   1286.2 used,    589.5 buff/cache
      MiB Swap:   4791.0 total,   4791.0 free,      0.0 used.   6163.1 avail Mem
      *** FAILED SERVICES ***
        UNIT                LOAD   ACTIVE SUB    DESCRIPTION
      * odroid-alsa.service loaded failed failed ODROID ALSA Setup Service
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     745M  9.0M  736M   2% /run
      /dev/nvme0n1p2 ext4      112G  5.7G  101G   6% /
      tmpfs          tmpfs     3.7G     0  3.7G   0% /dev/shm
      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
      tmpfs          tmpfs     128M   12K  128M   1% /var/log
      /dev/nvme0n1p1 ext2      457M   27M  406M   7% /boot
      tmpfs          tmpfs     745M     0  745M   0% /run/user/1000
      [Sat Feb  1 18:40:43 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Feb  1 18:40:44 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE                                                 FSTYPE OPTIONS
      /       /dev/disk/by-uuid/7d46186d-d54a-4af5-90d0-1567fa2a316b ext4   rw,relatime,errors=remount-ro
      `-/boot /dev/nvme0n1p1                                         ext2   rw,relatime,errors=continue
      /var:
      266M    /var/
      184M    /var/lib
      142M    /var/lib/apt/lists
      142M    /var/lib/apt
      83M     /var/cache
      No journal files were opened due to insufficient permissions.
      /opt/iobroker/backups:
      23M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G    /opt/iobroker/iobroker-data/
      1018M   /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
      18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.2-1nodesource1
        Candidate: 20.18.2-1nodesource1
        Version table:
       *** 20.18.2-1nodesource1 500
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.18.1-1nodesource1 500
           20.18.0-1nodesource1 500
           20.17.0-1nodesource1 500
           20.16.0-1nodesource1 500
           20.15.1-1nodesource1 500
           20.15.0-1nodesource1 500
           20.14.0-1nodesource1 500
           20.13.1-1nodesource1 500
           20.13.0-1nodesource1 500
           20.12.2-1nodesource1 500
           20.12.1-1nodesource1 500
           20.12.0-1nodesource1 500
           20.11.1-1nodesource1 500
           20.11.0-1nodesource1 500
           20.10.0-1nodesource1 500
           20.9.0-1nodesource1 500
           20.8.1-1nodesource1 500
           20.8.0-1nodesource1 500
           20.7.0-1nodesource1 500
           20.6.1-1nodesource1 500
           20.6.0-1nodesource1 500
           20.5.1-1nodesource1 500
           20.5.0-1nodesource1 500
           20.4.0-1nodesource1 500
           20.3.1-1nodesource1 500
           20.3.0-1nodesource1 500
           20.2.0-1nodesource1 500
           20.1.0-1nodesource1 500
           20.0.0-1nodesource1 500
           18.19.0+dfsg-6~deb12u2 500
              500 http://ftp.gwdg.de/debian bookworm/main arm64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      odroid-m1-iob       odroid-m1-iob (version: 7.0.6, hostname: odroid-m1-iob , alive, uptime: 425)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : odroid-m1-iob                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : odroid-m1-iob                            - disabled
      + system.adapter.discovery.0              : discovery             : odroid-m1-iob                            -  enabled
      + system.adapter.echarts.0                : echarts               : odroid-m1-iob                            -  enabled
        system.adapter.feiertage.0              : feiertage             : odroid-m1-iob                            -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : odroid-m1-iob                            -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : odroid-m1-iob                            -  enabled
      + system.adapter.hm-rpc.1                 : hm-rpc                : odroid-m1-iob                            -  enabled
      + system.adapter.influxdb.0               : influxdb              : odroid-m1-iob                            -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : odroid-m1-iob                            -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : odroid-m1-iob                            -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shelly.0                 : shelly                : odroid-m1-iob                            - disabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : odroid-m1-iob                            -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.vis-bars.0               : vis-bars              : odroid-m1-iob                            - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : odroid-m1-iob                            - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : odroid-m1-iob                            -  enabled
        system.adapter.vis.0                    : vis                   : odroid-m1-iob                            -  enabled
      + system.adapter.web.0                    : web                   : odroid-m1-iob                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Objects and States
      Objects:        1950
      States:         1591
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://ftp.gwdg.de/debian bookworm InRelease
      Hit:3 http://ftp.gwdg.de/debian bookworm-updates InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:6 http://ppa.linuxfactory.or.kr bookworm InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2215       1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11020      1223/sshd: /usr/sbi
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        10048      1203/influxd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11289      1350/io.mqtt.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1642       1335/io.sonoff.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10085      1242/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1541       1242/iobroker.js-co
      tcp        0      0 192.168.230.199:2010    0.0.0.0:*               LISTEN      1001       12363      1414/io.hm-rpc.1
      tcp        0      0 192.168.230.199:2001    0.0.0.0:*               LISTEN      1001       1666       1399/io.hm-rpc.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          9538       1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11029      1223/sshd: /usr/sbi
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1686       1444/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1578       1262/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        10061      1203/influxd
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1266       1/init
      udp6       0      0 :::111                  :::*                                0          2216       1/init
      2025-02-01 18:41:27.235  - info: hm-rega.0 (1384) time difference local-ccu 0s
      2025-02-01 18:41:29.555  - info: hm-rega.0 (1384) request state values
      2025-02-01 18:41:30.779  - info: hm-rpc.0 (1399) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.18.2, js-controller: 7.0.6
      2025-02-01 18:41:31.153  - info: hm-rpc.0 (1399) xmlrpc server is trying to listen on 192.168.230.199:2001
      2025-02-01 18:41:31.156  - info: hm-rpc.0 (1399) xmlrpc client is trying to connect to 192.168.230.210:2001/ with ["http://192.168.230.211:2001","odroid-m1-iob:hm-rpc.0:e17154b5a40c67e5d6bab12d82c83565"]
      2025-02-01 18:41:31.267  - info: hm-rpc.0 (1399) Connected
      2025-02-01 18:41:31.587  - info: hm-rega.0 (1384) Updated all datapoints
      2025-02-01 18:41:32.089  - info: hm-rega.0 (1384) added/updated 1 objects
      2025-02-01 18:41:32.113  - info: hm-rega.0 (1384) got 9 variables
      2025-02-01 18:41:33.171  - info: hm-rega.0 (1384) added/updated 9 variables
      2025-02-01 18:41:33.174  - info: hm-rega.0 (1384) deleted 0 variables
      2025-02-01 18:41:33.323  - info: hm-rega.0 (1384) got 11 programs
      2025-02-01 18:41:34.303  - info: hm-rega.0 (1384) added/updated 11 programs
      2025-02-01 18:41:34.306  - info: hm-rega.0 (1384) deleted 0 programs
      2025-02-01 18:41:34.340  - info: hm-rega.0 (1384) update rooms to enum.rooms
      2025-02-01 18:41:34.401  - info: hm-rega.0 (1384) update functions to enum.functions
      2025-02-01 18:41:34.449  - info: hm-rega.0 (1384) update favorites to enum.favorites
      2025-02-01 18:41:34.840  - info: hm-rpc.1 (1414) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.18.2, js-controller: 7.0.6
      2025-02-01 18:41:35.101  - info: hm-rpc.1 (1414) xmlrpc server is trying to listen on 192.168.230.199:2010
      2025-02-01 18:41:35.104  - info: hm-rpc.1 (1414) xmlrpc client is trying to connect to 192.168.230.210:2010/ with ["http://192.168.230.211:2010","odroid-m1-iob:hm-rpc.1:049c08b7ce16b0b492e6b313c51d3859"]
      2025-02-01 18:41:35.220  - info: hm-rpc.1 (1414) Connected
      2025-02-01 18:41:38.407  - info: discovery.0 (1429) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.2, js-controller: 7.0.6
      2025-02-01 18:41:45.343  - info: vis.0 (1459) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.2, js-controller: 7.0.6
      2025-02-01 18:41:47.310  - info: vis.0 (1459) Terminated (NO_ERROR): Without reason
      2025-02-01 18:41:52.665  - info: vis-inventwo.0 (1489) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.18.2, js-controller: 7.0.6
      iob diag has finished.
        ```bash
        Script v.2024-10-19
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
                      NTP service: active
                  RTC in local TZ: no
        mario
        HOME=/home/mario
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           5.0G          0B        5.0G
        Total:           12G        1.3G         11G
                 7449 M total memory
                 1286 M used memory
                 5743 M free memory
                   52 M buffer memory
                  537 M swap cache
                 4790 M total swap
                    0 M used swap
                 4790 M free swap
        *** FILESYSTEM ***
        /var:
        266M    /var/
        184M    /var/lib
        142M    /var/lib/apt
        83M     /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.4.10
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        1950
        States:         1591
        Pending Updates: 0
        @wsvd sagte in div. 404 Fehler im IOB (Admin):
        Setz den mario in die Gruppe adm rein:
        sudo usermod -a -G adm mario
        exit
        Was ist das? Was odroid-spezifisches?
        Ansonsten sehe ich da nix ungewöhnliches.
          exit
          Ja genau. Vom Hersteller.
          PS:
          Da fehlt doch definitiv was (Icons).
            PS:
            Noch was Neues:
            Klicke ich auf Return to Home dann ist plötzlich alles wieder verfügbar.
            Also ich kann es mir nicht erklären :-(
            O 1 Antwort Letzte Antwort
              Noch was Neues:
              O Offline
              O Offline
              Oceanwaves
              Ich habe hier seit kurzem ein ähnliches Problem.
              Ich will mich an ioBroker anmelden, habe dafür im Firefox ein Lesezeichen, das http://<ip des pi5>:8081 aufruft.
              Im Browser see ich dann eine Weiterleitung auf http://<ip des pi5>:8081/login?href=#tab-intro und bekomme dann die Fehlermeldung
              404
              Oops! The page you're looking for can't be found. 😔
              File /login?href= not found
              Darunter ein Link "Return to Home", der wieder auf http://<ip des pi5>:8081 verweist. Wenn ich den dann anklicke, läuft die Anmeldung sauber durch und ich lande in der Übersicht.
              • O Oceanwaves
                404
                O Offline
                O Offline
                Oceanwaves
                Habe die Ursache meines Problems wohl zufällig gefunden, als ich auf der Suche danach war, warum ich im Log immer wieder "error socket.io [init] Cannot detect user" gefunden habe. Kam wohl mit admin-7.6.3. Mit 7.6.4 scheint das socket.io-Problem behoben zu sein. Aber mit 7.6.3 kam gleichzeitig ein Problem beim Login, wenn man einen Passwort-Manager benutzt (hier Enpass).
                Beschrieben ist das Problem hier: [bug]: Login with password manager no longer possible]: https://github.com/ioBroker/ioBroker.admin/issues/3047
                Soll mit 7.6.7 behoben sein, habe ich aber noch nicht installiert, momentan kann ich damit leben, muss ich halt das PW über Copy/Paste einfügen...
                • O Oceanwaves
                  CodierknechtC Online
                  Codierknecht
                  @oceanwaves sagte in div. 404 Fehler im IOB (Admin):
                  oder alternativ auf die Anmeldung verzichten.
                  Wenn im Haus keine böswilligen Pupertisten wohnen, kann man ja wohl darauf verzichten.
                  HmIP|ZigBee|Tasmota|Unifi
                  Zabbix Certified Specialist
                  • arteckA Offline
                    arteckA Offline
                    arteck
                    da stimmt was mit den internen iobroker rechten nicht für den user
                    zeigmal die benutzer .. und deren rechte
                    • CodierknechtC Codierknecht
                      O Offline
                      O Offline
                      Oceanwaves
                      @codierknecht said in div. 404 Fehler im IOB (Admin):
                      So oft melde ich mich nicht an. Und an dem Problem mit dem PW-Manager wird ja gearbeitet.
                      • O Oceanwaves
                        Codierknecht
                        @oceanwaves
                        Da unsere Vögelchen bereits ausgeflogen sind, kann ich auf einen Login verzichten. Eine potenzielle Fehlerquelle weniger ;-)
