  3. Entwicklung
  4. Adapter Worx Landroid v3.x.x
    6.3k
814 Beiträge 91 Kommentatoren 247.8k Aufrufe 78 Beobachtet
  • L Lucky_ESA
    @afi sagte in Adapter Worx Landroid v3.x.x:
    @lucky_esa Hi es scheint im moment zu funktionieren, habe es gerade auch getestet. Habe es seit unserem Test immer direkt im Objekt oder an der APP eingegeben nicht über blockly. Es scheint nicht zuverlässig zu sein. Kannst Du mir zeigen auf was ich im Debug Protokoll achten muss? VG Axel
    Der erste Eintrag sendet und die anderen 2 kommen als Bestätigung
    2025-04-21 13:19:24.603 - debug: worx.0 (1797618) sendData: {"id":23583,"cmd":0,"lg":"it","sn":"xxx","tm":"13:19:24","dt":"21/04/2025","sc":{"m":1,"p":-100,"d":[["09:00",0,0],["10:00",420,0],["10:00",480,0],["09:00",0,0],["10:00",480,0],["10:00",480,0],["09:30",150,0]]}}
    2025-04-21 13:19:25.172 - debug: worx.0 (1797618) Mower MQTT: {"cfg":{"id":23583,"lg":"it","tm":"13:19:24","dt":"21/04/2025","sc":{"m":1,"p":-100,"d":[["09:00",0,0],["10:00",420,0],["10:00",480,0],["09:00",0,0],["10:00",480,0],["10:00",480,0],["09:30",150,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"xxx"},"dat":{"mac":"xxx","fw":3.52,"bt":{"t":26.1,"v":19.41,"p":66,"nr":1296,"c":1,"m":0},"dmp":[7.6,1.8,137.4],"st":{"b":74402,"d":1343894,"wt":81845},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
    2025-04-21 13:19:25.222 - debug: worx.0 (1797618) GET MQTT DATA from API: {"cfg":{"id":23583,"lg":"it","tm":"13:19:24","dt":"21/04/2025","sc":{"m":1,"p":-100,"d":[["09:00",0,0],["10:00",420,0],["10:00",480,0],["09:00",0,0],["10:00",480,0],["10:00",480,0],["09:30",150,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"xxx"},"dat":{"mac":"xxx","fw":3.52,"bt":{"t":26.1,"v":19.41,"p":66,"nr":1296,"c":1,"m":0},"dmp":[7.6,1.8,137.4],"st":{"b":74402,"d":1343894,"wt":81845},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
    Hierauf dann achten. Wenn du Blockly verwendest dann darauf achten, dass du eine Zahl setzt und kein string.
    "p":-100
    Gruß//Lucky
    AFiA Offline
    AFiA Offline
    AFi
    #190
    @lucky_esa Hi, vielen Dank für die Unterstützung, werde dies beobachten. Axel
    AFi
    CCU3 (Homematic Komponenten iP und Funk, Schalter, Thermostate, Bewegungsmelder, Rollos etc.), Wemos D1 mini und ALEXA
    ioBroker auf NUC
    Mittelständler in ioBroker
      BlueTang
      #191
      Ich habe mir nochmal den Zeitlich limitierten Party Modus angeschaut. Während dessen Aktivierung wird am Mobiltelefon in der Landroid App der Status Party Modus bis zum Ablauf des Timers angezeigt. Dies sollte auch im Status der AvaDesktopApp so angezeigt werden. Also "Daheim Party Modus" anstelle von "Daheim". Nach Ablauf des Timers wäre es sinnvoll den Party Modus im PartyMode Plugin (v3.1) der AvaDesktopApp zurück auf "Current Party Mode setting off" zu setzen. Dieser bleibt zur Zeit auf "limited on" gesetzt obwohl der Party Modus beendet wurde.
      Das sind meine Beobachtungen. Bitte mal überprüfen.
      MfG
      BlueTang
      hsteinmeH 1 Antwort Letzte Antwort
      • B BlueTang
        MfG
        BlueTang
        hsteinmeH Offline
        hsteinmeH Offline
        hsteinme
        #192
        @bluetang Dieses Forum bzw. dieser Thread haben den ioBroker bzw. dessen Worx Adapter zum Thema, keineswegs die AvaDesktopApp. Deren Entwickler liest hier nicht mit. Der Diskussionsplatz für die AvaDesktopApp befindet sich im Roboter-Forum: https://www.roboter-forum.com/threads/alternative-app-fuer-worx-kress-und-landxcape-ava-desk-app.67392/
        Es gäbe also mehr Sinn, Deine Hinweise dort zu platzieren.
          BlueTang
          #193
          Vielen Dank für den Hinweis. Ich habe den Thread ins Roboter-Forum gestellt. Könnte dies nicht auch Auswirkungen auf das Iobroker Obect mowerActive haben?
          • B BlueTang
            hsteinmeH Offline
            hsteinmeH Offline
            hsteinme
            #194
            @bluetang Nööh!
            AFiA 1 Antwort Letzte Antwort
            • hsteinmeH hsteinme
              @bluetang Nööh!
              AFiA Offline
              AFiA Offline
              AFi
              #195
              Hi zusammen, bin eigentlich am verzweifel mit dem Adapter, es scheint er funktioniert und funktioniert nicht. Dies gilt für die Arbeitszeitverkürzung bzw. Verlängerung als auch die direkte Startzeiteingabe, Arbeitszeiteingabe und Kantenschnittvorgabe. Derzeit bin ich am letzteren und habe die Vorgaben in extra Variablen, die ich zur Zeit x übertrage per Blockly:
              Protokoll Ausschnitte:
              worx.0
              	2025-04-26 18:23:50.485	debug	Test Status: 1
              worx.0
              	2025-04-26 18:23:50.397	debug	GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"18:23:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":22.1,"v":19.64,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7,1.2,141.2],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
              worx.0
              	2025-04-26 18:23:50.266	debug	Set new timestamp
              worx.0
              	2025-04-26 18:23:50.266	debug	Worxcloud MQTT get Message for mower fifi (20183019090500523351)
              worx.0
              	2025-04-26 18:23:50.266	debug	getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
              worx.0
              	2025-04-26 18:23:50.266	debug	topic: DB510/F0FE6BB1AA86/commandOut
              worx.0
              	2025-04-26 18:23:50.265	debug	Mower MQTT: {"cfg":{"id":0,"lg":"it","tm":"18:23:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":22.1,"v":19.64,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7,1.2,141.2],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
              worx.0
              	2025-04-26 18:20:12.223	debug	Update this.deviceArray: 0
              worx.0
              	2025-04-26 18:20:12.223	debug	Index Update: 0
              worx.0
              	2025-04-26 18:20:12.126	debug	Test Status: 1
              worx.0
              	2025-04-26 18:20:12.041	debug	GET MQTT DATA from API: {"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:13:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":22.8,"v":19.71,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,140.8],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}
              worx.0
              	2025-04-26 18:20:12.034	debug	{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":null,"test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":null,"capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":null,"app_settings":null,"warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":null,"auto_schedule_settings":{"boost":0,"grass_type":null,"irrigation":null,"nutrition":null,"soil_type":null},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"timestamp":"2025-04-26 16:13:50","payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:13:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":22.8,"v":19.71,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,140.8],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":null}
              worx.0
              	2025-04-26 18:13:50.487	debug	Test Status: 1
              worx.0
              	2025-04-26 18:13:50.389	debug	GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"18:13:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":22.8,"v":19.71,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,140.8],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
              worx.0
              	2025-04-26 18:13:50.241	debug	Set new timestamp
              worx.0
              	2025-04-26 18:13:50.240	debug	Worxcloud MQTT get Message for mower fifi (20183019090500523351)
              worx.0
              	2025-04-26 18:13:50.240	debug	getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
              worx.0
              	2025-04-26 18:13:50.240	debug	topic: DB510/F0FE6BB1AA86/commandOut
              worx.0
              	2025-04-26 18:13:50.239	debug	Mower MQTT: {"cfg":{"id":0,"lg":"it","tm":"18:13:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":22.8,"v":19.71,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,140.8],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
              worx.0
              	2025-04-26 18:06:00.106	debug	test cfg: 6 valID: 2 val: true sval: 1
              worx.0
              	2025-04-26 18:06:00.106	debug	Mowing time change at d to: {"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",240,1]],"p":0}
              worx.0
              	2025-04-26 18:06:00.106	debug	state change: id_____ worx.0.20183019090500523351.calendar.saturday.borderCut Mower 20183019090500523351_____borderCut______{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":"","capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":"","auto_schedule_settings":{"boost":0,"grass_type":"","irrigation":"","nutrition":{"n":0,"p":0,"k":0},"soil_type":""},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",240,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":""}
              worx.0
              	2025-04-26 18:06:00.106	debug	this.modules! {"20183019090500523351":{"edgeCut":false,"notify":true}}
              worx.0
              	2025-04-26 18:06:00.105	debug	test cfg: 6 valID: 1 val: 240 sval: 240
              worx.0
              	2025-04-26 18:06:00.105	debug	Mowing time change at d to: {"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",240,0]],"p":0}
              worx.0
              	2025-04-26 18:06:00.105	debug	state change: id_____ worx.0.20183019090500523351.calendar.saturday.workTime Mower 20183019090500523351_____workTime______{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":"","capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":"","auto_schedule_settings":{"boost":0,"grass_type":"","irrigation":"","nutrition":{"n":0,"p":0,"k":0},"soil_type":""},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":""}
              worx.0
              	2025-04-26 18:06:00.104	debug	this.modules! {"20183019090500523351":{"edgeCut":false,"notify":true}}
              worx.0
              	2025-04-26 18:06:00.097	debug	test cfg: 6 valID: 0 val: 15:00 sval: 15:00
              worx.0
              	2025-04-26 18:06:00.097	debug	Mowing time change at d to: {"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",0,0]],"p":0}
              worx.0
              	2025-04-26 18:06:00.097	debug	h: 15 m: 00
              worx.0
              	2025-04-26 18:06:00.097	debug	state change: id_____ worx.0.20183019090500523351.calendar.saturday.startTime Mower 20183019090500523351_____startTime______{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":"","capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":"","auto_schedule_settings":{"boost":0,"grass_type":"","irrigation":"","nutrition":{"n":0,"p":0,"k":0},"soil_type":""},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":""}
              worx.0
              	2025-04-26 18:06:00.096	debug	this.modules! {"20183019090500523351":{"edgeCut":false,"notify":true}}
              worx.0
              	2025-04-26 18:05:12.160	debug	Update this.deviceArray: 0
              worx.0
              	2025-04-26 18:05:12.160	debug	Index Update: 0
              worx.0
              	2025-04-26 18:05:12.056	debug	Test Status: 1
              worx.0
              	2025-04-26 18:05:11.973	debug	GET MQTT DATA from API: {"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}
              worx.0
              	2025-04-26 18:05:11.967	debug	{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":null,"test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":null,"capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":null,"app_settings":null,"warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":null,"auto_schedule_settings":{"boost":0,"grass_type":null,"irrigation":null,"nutrition":null,"soil_type":null},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"timestamp":"2025-04-26 16:03:50","payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":null}
              worx.0
              	2025-04-26 18:03:50.524	debug	Test Status: 1
              worx.0
              	2025-04-26 18:03:50.433	debug	GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"18:03:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
              worx.0
              	2025-04-26 18:03:50.340	debug	Set new timestamp
              worx.0
              	2025-04-26 18:03:50.340	debug	Worxcloud MQTT get Message for mower fifi (20183019090500523351)
              worx.0
              	2025-04-26 18:03:50.340	debug	getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
              worx.0
              	2025-04-26 18:03:50.339	debug	topic: DB510/F0FE6BB1AA86/commandOut
              worx.0
              	2025-04-26 18:03:50.339	debug	Mower MQTT: {"cfg":{"id":0,"lg":"it","tm":"18:03:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
              worx.0
              	2025-04-26 17:59:00.162	debug	test cfg: 6 valID: 2 val: true sval: 1
              worx.0
              	2025-04-26 17:59:00.162	debug	Mowing time change at d to: {"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",240,1]]}
              VG Axel
              AFi
              ioBroker auf NUC
              L 1 Antwort Letzte Antwort
              • AFiA AFi
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                worx.0
                VG Axel
                L Online
                L Online
                Lucky_ESA
                #196
                @afi Wie man States absetzt ist in der Anleitung genau beschrieben. Wenn du da was nicht verstehst, dann frage bitte nach.
                So setzt man die Zeiten.
                Bei deinem Blockly fehlt das Versenden deiner Eingabe.
                Gruß//Lucky
                • L Lucky_ESA
                  Gruß//Lucky
                  AFiA Offline
                  AFiA Offline
                  AFi
                  #197
                  @lucky_esa Hi, danke für die Antwort, die 1,1 s zwischen den Befehlen im Blockly habe ich inzwischen verstanden, aber der notwendige Befehl der Versendung im Blockly erschließt sich mir leider nicht. Mir ist damit auch nicht klar, ob ich den Befehl am Schluß senden muss oder dazwischen. VG Axel
                  AFi
                  ioBroker auf NUC
                  • AFiA AFi
                    L Online
                    L Online
                    Lucky_ESA
                    #198
                    @afi Du musst erst alle Zeiten per Blockly schreiben und wenn du fertig bist, den State worx.0.xxxx.calendar.calJson_tosend auf true setzen. Alle Befehle ohne Pause. Nur zwischen 2 aktiven Befehle muss man 1,1 Sekunden Pause einhalten (siehe rot oder grüner Punkt).
                    Aber ACHTUNG! Die Zeiten sollten ohne Pause gesetzt werden weil, kommt in der Zeit zwischen Zeiten setzen und worx.0.xxxx.calendar.calJson_tosend auf true setzen ein Update vom Mower, dann werden aller deine Änderung wieder überschrieben und dann werden keine Änderungen versendet.
                    Deine Änderungen der Zeiten kannst du in worx.0.xxx.calendar.calJson_tosend beobachten.
                    Gruß//Lucky
                    • L Lucky_ESA
                      Gruß//Lucky
                      AFiA Offline
                      AFiA Offline
                      AFi
                      #199
                      @lucky_esa Danke, werde dies morgen testen. VG Axel
                      AFi
                      ioBroker auf NUC
                      • arteckA Offline
                        arteckA Offline
                        arteck
                        #200
                        seid wann schmeisst der Adapter Benachrichtigungn raus im Admin
                        wozu ??
                          bommel_030
                          #201
                          Regenverzögerung ist ihm neuerdings auch ne Fehlerbenachrichtigung im Admin wert?!?
                          • arteckA arteck
                            wozu ??
                            L Online
                            L Online
                            Lucky_ESA
                            #202
                            @arteck Seit dem 04.11.2024 - Warum? Für mich wichtig solche Fehler sofrt zu sehen
                            @bommel_030 Weil es eine Fehlermeldung ist
                            Wie bereits ein paar posts vorher beschrieben könnt ihr diese Meldung deaktivieren.
                            Gruß//Lucky
                            mcm1957M B arteckA 3 Antworten Letzte Antwort
                            • L Lucky_ESA
                              Gruß//Lucky
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #203
                              @lucky_esa said in Adapter Worx Landroid v3.x.x:
                              Gruß//Lucky
                              Eine Verzögerung weilsregnet ist aber m.E
                              als notification grenzwertig. Das Notificatoon system soöl nicht das logfile ersetzen oder jrde Info als notificatoon den Admin - provokant formuliert - zumüllen.
                              Notifications sollten im allgemeinen eine Info an den User sein damit dieser was tut.
                              @apollon77
                              Gibt wo eine best praxis / empfehlung was als notificaton ok / gewünscht / eher übertrieben ist?
                              Support Repositoryverwaltung.
                              LESEN - gute Forenbeitrage
                              • L Lucky_ESA
                                Gruß//Lucky
                                bommel_030
                                #204
                                @lucky_esa
                                Das mit dem abschalten ist schon klar, meiner Meinung nach ist Regen halt kein "Fehler". Bei außerhalb der Begrenzung würde ich das noch verstehen, da muss man manuell eingreifen.
                                Wenn die Meldungen von dir so gewünscht sind passt es ja und ist kein "Bug" im Adapter. Auf jeden Fall danke für deine Entwicklung.
                                • B bommel_030
                                  @lucky_esa
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #205
                                  @Lucky_ESA
                                  Bitte um Info wo man die Notifications abschalten kann. Ich habe in jsonConfig.json keinen entsprechenden Punkt gesehen (aber vielleicht übersehen).
                                  • mcm1957M mcm1957
                                    @Lucky_ESA
                                    L Online
                                    L Online
                                    Lucky_ESA
                                    #206
                                    @mcm1957 Hier und hier
                                    Steht alles in der Description. Die Benachrichtigung kann man mit einen State aktivieren/deaktivieren. Das ist besser als in der Instanz Einstellungen.
                                    Ich könnte noch ein Object hinzufügen wo der User die ID`s eintragen kann, welche Meldung nicht erwünscht ist.
                                    Welche Meldungen wären den nicht gewünscht?
                                    Möglich Fehler ID`s kann man auch in der Description erlesen.
                                    Gruß//Lucky
                                    • L Lucky_ESA
                                      Gruß//Lucky
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      #207
                                      @lucky_esa
                                      Danke für die Rückmeldung. Steht diese Information auch im Readme? Oder auf welche Description verweist du?
                                      Eine Konfiguration sollte IMMER - zumindest auch - via adminUI erfolgen. Dort sucht man die möglichen Einstellungen zuerst. Und dies ist auch das Konzept von Iobroker betreffend Konfiguration. (Weil im Kern könnte man natürlich admin UI auch ganz weglassen und alles via States / Files lösen :-) ).
                                      Bitte ergänze die adminUI - via Component STATE kannst du einen State direkt setzen - damit sollte das voll kompatibel verbesserbar sein. Wenn es wer via Script / VIA anpassen will, dann geht das via State und adminUI setzt auch den State. Damit ist keine Codeänderung notwendig,
                                      Siehe
                                      https://github.com/ioBroker/ioBroker.admin/blob/master/packages/jsonConfig/README.md#state
                                      https://github.com/ioBroker/ioBroker.admin/blob/master/packages/jsonConfig/README.md#setstate
                                      Bitte auch eine Konfiguration von nicht erwünschten Infos jedenfalls den Support in Admin einbauen. Wir wollen definitiv nicht in Zeiten vor Admin UI zurückfallen und die Konfiguration jetzt außerhalb vornehmen.
                                      • L Lucky_ESA
                                        Gruß//Lucky
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #208
                                        @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                                        dann mach es bitte zusätzlich per Admin UI schaltbar. vor allem da es einfluss auf die Admin UI nimmt
                                        • arteckA arteck
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #209
                                          @arteck said in Adapter Worx Landroid v3.x.x:
                                          FYI
                                          https://github.com/iobroker-community-adapters/ioBroker.worx/issues/1003
