  4. [Gelöst]VIS FLOAT Verbindung Rückwärts
    5.8k
16 Beiträge 2 Kommentatoren 1.2k Aufrufe 1 Beobachtet
  • Haifeif 0H Haifeif 0
    @bahnuhr
    http://192.168.178.101:8082/flot/index.html?l%5B0%5D%5Bid%5D=zigbee.0.84ba20fffee21b92.target_temperature&l%5B0%5D%5Binstance%5D=history.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23addbff&l%5B0%5D%5Bmin%5D=5&l%5B0%5D%5Bmax%5D=35&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=+%C2%B0C&l%5B0%5D%5Bname%5D=Ventil&l%5B0%5D%5Bxmove%5D=0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=zigbee.0.ec1bbdfffeac2e9a.opened&l%5B1%5D%5Binstance%5D=history.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%23ff00de&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bmax%5D=1&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=1&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=2&l%5B1%5D%5BafterComma%5D=2&l%5B1%5D%5Bdashes%5D=true&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5Bmultiplicator%5D=1&l%5B1%5D%5ByOffset%5D=0&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BchartType%5D=line&l%5B1%5D%5Bfill%5D=0.2&l%5B1%5D%5Bname%5D=Fenster+offen&l%5B2%5D%5Bid%5D=zigbee.0.00158d0007558147.temperature&l%5B2%5D%5Binstance%5D=history.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%2321ff00&l%5B2%5D%5Bmin%5D=5&l%5B2%5D%5Bmax%5D=35&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=Raum&l%5B2%5D%5Bxmove%5D=0&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B3%5D%5Bid%5D=zigbee.0.84ba20fffee21b92.local_temp&l%5B3%5D%5Binstance%5D=history.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=5&l%5B3%5D%5Bmax%5D=35&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=HKN&l%5B3%5D%5Bxmove%5D=0&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=bottom&timeType=relative&relativeEnd=now&range=2880&aggregateType=step&aggregateSpan=300&hoverDetail=false&useComma=false&zoom=false&noedit=false&animation=0&live=3600&start=2022-01-05&start_time=04%3A00&end=2022-01-05&end_time=00%3A00&width=700&height=295&noBorder=noborder&window_bg=%23000000&x_labels_color=%23ffffff&y_labels_color=%23ffffff&barColor=%23000000&barLabels=topover&barFontColor=%23fefefe&titleColor=%2331ff12&titleSize=28&legColumns=3&legBgOpacity=0.5&legBg=%23ffffff&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&border_color=%23faf7f7&grid_color=%23bebbbb&barWidth=0.05&barFontSize=%23ffffff&legend=nw&bg=2&title=CO2+Gehalt
    Meinst Du das?
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    @haifeif-0
    Ja,
    du nimmst diesen link und änderst am Anfang das Wort index in edit ab und dann kommst du in den flot edit modus.
    Danke.
    Haifeif 0H 1 Antwort Letzte Antwort
    • bahnuhrB bahnuhr
      @haifeif-0
      was ist float ?
      oder meinst du flot ?
      Wenn flot, dann zeige mal deinen Eintrag in Edit.
      Haifeif 0H Offline
      Haifeif 0H Offline
      Haifeif 0
      @bahnuhr Ja, natürlich. Mein Fehler, ich meine flot.
      Never argue with stupid people, they will drag you down to their level and then beat you with experience.
      • bahnuhrB bahnuhr
        @haifeif-0
        Ja,
        Haifeif 0H Offline
        Haifeif 0H Offline
        Haifeif 0
        @bahnuhr
        Ok, das funktioniert. Aber ich habe doch in FLOT dutzende Grafiken mit Namen abgespeichert. Wie kann ich den Namen einer Grafik in VIS herausfinden, um dann die Datei über den gespeicherten Namen in FLOT zu öffnen?
          @bahnuhr
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @haifeif-0
          Ich benutze die Speicherung in flot nicht.
          Ist mir zu umständlich.
          Ich gehe immer den gezeigten Weg, dann weiß ich auch, dass ich die letzte in vis gezeigte Version habe.
          Und dann halt einfach auf edit ändern, fertig.
          Danke.
          • bahnuhrB bahnuhr
            @haifeif-0
            Haifeif 0H Offline
            Haifeif 0H Offline
            Haifeif 0
            @bahnuhr Danke für den Hinweis. Manche meiner Grafiken haben einen blauen Pfeil(?), wenn ich den anklicke, bin ich sofort im Editor, ohne die Index/Editor Änderung. Mal schauen, ob ich die EInstellung finde, mit der ich das Ding einschalten kann. Denn nicht alle Grafiken haben ihn ...
            Aber Danke für Deine Hilfe!
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @haifeif-0 sagte in VIS FLOAT Verbindung Rückwärts:
              bitte hardcopy zeigen
              Danke.
              • bahnuhrB bahnuhr
                Haifeif 0H Offline
                Haifeif 0H Offline
                Haifeif 0
                Oben rechts, zwischen 35° und 30°
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  @haifeif-0
                  habe ich bei mir in keiner flot Grafik.
                  Aber schau doch mal in den Optionen im flot editor
                  Danke.
                  • bahnuhrB bahnuhr
                    @haifeif-0
                    Haifeif 0H Offline
                    Haifeif 0H Offline
                    Haifeif 0
                    @bahnuhr Hab ich gerade, auch nix gefunden.
                    bahnuhrB Haifeif 0H 2 Antworten Letzte Antwort
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      ich schon!
                      Könnte doch dies sein.
                      Ich finde dies aber nicht schön.
                      Danke.
                        Haifeif 0H Offline
                        Haifeif 0H Offline
                        Haifeif 0
                        @haifeif-0 Ich frag mal die KI ...
                        Chat weiß vieles:
                        ...&noedit=false...
                        Wenn das im Text steht, erscheint das Symbol und DU kannst die Grafik direkt editieren.
                          Chat weiß vieles:
                          ...&noedit=false...
                          Haifeif 0H Offline
                          Haifeif 0H Offline
                          Haifeif 0
                          @haifeif-0 Funktioniert! Wenn ich in Vis auf Quelle gehe und in der langen URL angabe nach &noedit= suche und das true durch false ersetze, erscheint beim Aufruf der Grafik oben rechts ein dunkelblaues Symbol. Das ist der Link in den Editor! Warum das aber machmal an und manchmal aus ist? Keine Ahnung. Ebenso finde ich keine korrespondierende Einstellung.
                          • bahnuhrB bahnuhr
                            ich schon!
                            Haifeif 0H Offline
                            Haifeif 0H Offline
                            Haifeif 0
                            @bahnuhr Stimmt! Augen auf hilft! Alles klar, wieder was gelernt.
                            Danke, schönen Abend noch!
