Lay-Z-Spa Wifi Control
Update um die Außentemperatur (Umgebungstemperatur) über ioBroker zur Berechnung der virtuellen Temperatur einzubinden.
const Messages = { "CONTENT": "STATES", "LCK": 0, "PWR": 0, "UNT": 1, "AIR": 0, "GRN": 0, "RED": 0, "FLT": 0, "TGT": 22, "TMP": 13, "CH1": 32, "CH2": 49, "CH3": 51, "HJT": 0, "BRT": 7, "AMBC": 22 } const ID = '0_userdata.0.LazySpa'; const MQTTINSTANCE = 0; const debug = true; /* { "CONTENT": "TIMES", "TIME": 1650746370, "CLTIME": 1644734714, "FTIME": 1644734719, "UPTIME": 41660, "PUMPTIME": 50, "HEATINGTIME": 24, "AIRTIME": 512, "JETTIME": 4294966, "COST": 0, "FINT": 4294967295, "CLINT": 4294967295, "KWH": null, "TTTT": -74677 } */ const STATES=[ { _id: 'LCK', type: 'state', common: { name: 'lock', type: 'boolean', role: 'switch', read: true, write: false, desc: 'Lazy spa lock' }, native: {} }, { _id: 'PWR', type: 'state', common: { name: 'power', type: 'boolean', role: 'switch.power', read: true, write: true, desc: 'Lazy spa power' }, native: {} }, { _id: 'UNT', type: 'state', common: { name: 'unit', type: 'number', role: 'value', read: true, write: true, max: 1, desc: 'Lazy spa unit', states: { 0: 'Farenheit', 1: 'Celsius' } }, native: {} }, { _id: 'AIR', type: 'state', common: { name: 'bubbles', type: 'boolean', role: 'switch', read: true, write: true, desc: 'Lazy spa bubbles state' }, native: {} }, { _id: 'GRN', type: 'state', common: { name: 'Heating green', type: 'boolean', role: 'switch', read: true, write: false, desc: 'reached target temp.' }, native: {} }, { _id: 'RED', type: 'state', common: { name: 'Heating red', type: 'boolean', role: 'switch', read: true, write: false, desc: 'not reached target temp.' }, native: {} }, { _id: 'FLT', type: 'state', common: { name: 'pump', type: 'boolean', role: 'switch', read: true, write: true, desc: 'pump state' }, native: {} }, { _id: 'HEATER', type: 'state', common: { name: 'heater', type: 'boolean', role: 'switch', read: true, write: true, desc: 'heater state' }, native: {} }, { _id: 'TGT', type: 'state', common: { name: 'target temp', type: 'number', role: 'level.temperature', min: 20, max: 40, steps: 1, read: true, write: true, desc: 'taget temp.' }, native: {} }, { _id: 'TMP', type: 'state', common: { name: 'temp', type: 'number', role: 'value.temperature', read: true, write: false, unit: '°C', desc: 'temp.' }, native: {} }, { _id: 'VTM', type: 'state', common: { name: 'temp', type: 'number', role: 'value.temperature', read: true, write: false, unit: '°C', desc: 'vtemp.' }, native: {} }, { _id: 'AMBC', type: 'state', common: { name: 'ambient temp', type: 'number', role: 'value.temperature', read: false, write: true, desc: 'Ambienttemp.' }, native: {} }, ] init(); async function stateChange(obj){ let id = obj.id let state = id.split('.').pop() let value = obj.state.val log('change Unit' + state) switch (state) { case 'UNT': setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":1,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('change Unit') break; case 'TGT': setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":0,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('change target temp. to '+ value); break; case 'AIR': value = value ? 1: 0 ; setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":2,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('set bubbles to '+ value); break; case 'HEATER': value = value ? 1: 0 ; setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":3,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('set Heater to '+ value); break; case 'FLT': value = value ? 1: 0 ; setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":4,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('set pump to '+ value); break; case 'AMBC': setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":14,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('change ambient temp. to '+ value); break; default: // Anweisungen werden ausgeführt, // falls keine der case-Klauseln mit expression übereinstimmt break; } } async function init(){ await asyncForEach(STATES, async (obj, index) => { let id = ID +'.'+ obj._id if (!existsState(id)) { log('create state '+ id) await createStateAsync(id, obj.common) } else { log('skip state '+ id) } //set subscription if(obj.common.write){ on({id: id, change:"any"} , function(obj) { if(!obj.state.ack){ log('change state! '+ JSON.stringify(obj)) stateChange(obj) } }); } }); log('init done!') } async function setLazyStates(obj){ try{ let states = JSON.parse(obj) for (const [key, value] of Object.entries(states)) { let statevalue = value const found = STATES.find(state => state._id === key); if(found){ if (found.common.type === 'boolean'){ statevalue = value === 1 } await setStateAsync(ID +'.'+ key,statevalue,true) } } //set heater state await setStateAsync(ID +'.HEATER',(states.GRN || states.RED) === 1,true) } catch(e){ console.log('Error in setting State '+ e) } } async function asyncForEach(array, callback) { for (let index = 0; index < array.length; index++) { await callback(array[index], index, array); } } function log (msg){ if(debug) console.log (msg) } on({id:'mqtt.'+ MQTTINSTANCE+'.layzspa.message', change:"ne"} , function(obj) { log('Lazyspa reached message! '+ JSON.stringify(obj.state)) setLazyStates(obj.state.val) });Die Variable AMBC update ich bei Änderung der Außentemperatur. Ich lese die Außentemperatur über Netatmo ein.
@chris685
Hi, wenn ich das richtig verstehe, sollte wenn ich den Datenpunkt AMBC ändere der Wert im Modul für die Außentemperatur stehen? -
@chris685
Hi, wenn ich das richtig verstehe, sollte wenn ich den Datenpunkt AMBC ändere der Wert im Modul für die Außentemperatur stehen?@ninjaturtle85 sagte in Lay-Z-Spa Wifi Control:
@chris685
Hi, wenn ich das richtig verstehe, sollte wenn ich den Datenpunkt AMBC ändere der Wert im Modul für die Außentemperatur stehen?Ich hab den Fehler selbst gefunden:
Ich musste in meinem Skript, in dem ich die Außentemperatur in den Datenpunkt schreibe, ändern. Und zwar habe ich den Wert aktualisiert und nicht gesteuert.Aber ich muss ihn in Fahrenheit umrechnen damit er im Datenpunkt und im Modul richtig dargestellt wird.
Hi, ich habe das Problem, dass ich das WifiWhirl ab und zu selber einschaltet ich hatte hier mal gelesen das es von dem Skript kommt stimmt das oder liegt das an was anderem ?
Kann ich das irgendwie verhindern ?Grüße
Basti -
@der-jeti sagte in Lay-Z-Spa Wifi Control:
@nonono ja, sind noch 6x da.
01.07.24
5x vorhandenHast du noch welche über? Würde 3Stk brauchen.
@firesaw sagte in Lay-Z-Spa Wifi Control:
01.07.24
Ja, schreib mir eine PM
01.07.24
Hallo Leute ich arbeite gerade daran meinen Lay-Z-Spa Smarthome kompatibel zu machen. bin da auf ein tolles Projekt gestoßen mit einem Esp8266 Wollte hierfür die Platinen bestellen hat noch jemand zufällig Interesse? Eine Platine alleine ist ein bisschen zu teuer... würde zwischen 6 und 11 Euro liegen die platine je nachdem wieviele es werden...
Platine : https://easyeda.com/editor#id=a1b94bf9fc01407591a9e0fec6a813b3
Projekt: https://github.com/visualapproach/WiFi-remote-for-Bestway-Lay-Z-SPAWollte am Wochenende mal ein Testaufbau machen... und werde berichten...
PS: ich selbst habe einen Palm-Springs
edit: so ein kleines script habe ich auch dafür:
const Messages = { "CONTENT": "STATES", "LCK": 0, "PWR": 0, "UNT": 1, "AIR": 0, "GRN": 0, "RED": 0, "FLT": 0, "TGT": 22, "TMP": 13, "CH1": 32, "CH2": 49, "CH3": 51, "HJT": 0, "BRT": 7 } const ID = '0_userdata.0.LazySpa'; const MQTTINSTANCE = 0; const debug = true; /* { "CONTENT": "TIMES", "TIME": 1650746370, "CLTIME": 1644734714, "FTIME": 1644734719, "UPTIME": 41660, "PUMPTIME": 50, "HEATINGTIME": 24, "AIRTIME": 512, "JETTIME": 4294966, "COST": 0, "FINT": 4294967295, "CLINT": 4294967295, "KWH": null, "TTTT": -74677 } */ const STATES=[ { _id: 'LCK', type: 'state', common: { name: 'lock', type: 'boolean', role: 'switch', read: true, write: false, desc: 'Lazy spa lock' }, native: {} }, { _id: 'PWR', type: 'state', common: { name: 'power', type: 'boolean', role: 'switch.power', read: true, write: true, desc: 'Lazy spa power' }, native: {} }, { _id: 'UNT', type: 'state', common: { name: 'unit', type: 'number', role: 'value', read: true, write: true, max: 1, desc: 'Lazy spa unit', states: { 0: 'Farenheit', 1: 'Celsius' } }, native: {} }, { _id: 'AIR', type: 'state', common: { name: 'bubbles', type: 'boolean', role: 'switch', read: true, write: true, desc: 'Lazy spa bubbles state' }, native: {} }, { _id: 'GRN', type: 'state', common: { name: 'Heating green', type: 'boolean', role: 'switch', read: true, write: false, desc: 'reached target temp.' }, native: {} }, { _id: 'RED', type: 'state', common: { name: 'Heating red', type: 'boolean', role: 'switch', read: true, write: false, desc: 'not reached target temp.' }, native: {} }, { _id: 'FLT', type: 'state', common: { name: 'pump', type: 'boolean', role: 'switch', read: true, write: true, desc: 'pump state' }, native: {} }, { _id: 'HEATER', type: 'state', common: { name: 'heater', type: 'boolean', role: 'switch', read: true, write: true, desc: 'heater state' }, native: {} }, { _id: 'TGT', type: 'state', common: { name: 'target temp', type: 'number', role: 'level.temperature', min: 20, max: 40, steps: 1, read: true, write: true, desc: 'taget temp.' }, native: {} }, { _id: 'TMP', type: 'state', common: { name: 'temp', type: 'number', role: 'value.temperature', read: true, write: false, unit: '°C', desc: 'temp.' }, native: {} }, ] init(); async function stateChange(obj){ let id = obj.id let state = id.split('.').pop() let value = obj.state.val log('change Unit' + state) switch (state) { case 'UNT': setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":1,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('change Unit') break; case 'TGT': setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":0,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('change target temp. to '+ value); break; case 'AIR': value = value ? 1: 0 ; setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":2,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('set bubbles to '+ value); break; case 'HEATER': value = value ? 1: 0 ; setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":3,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('set Heater to '+ value); break; case 'FLT': value = value ? 1: 0 ; setStateAsync('mqtt.'+ MQTTINSTANCE+'.layzspa.command','{"CMD":4,"VALUE":'+ value +',"XTIME":0,"INTERVAL":0}') log('set pump to '+ value); break; default: // Anweisungen werden ausgeführt, // falls keine der case-Klauseln mit expression übereinstimmt break; } } async function init(){ await asyncForEach(STATES, async (obj, index) => { let id = ID +'.'+ obj._id if (!existsState(id)) { log('create state '+ id) await createStateAsync(id, obj.common) } else { log('skip state '+ id) } //set subscription if(obj.common.write){ on({id: id, change:"any"} , function(obj) { if(!obj.state.ack){ log('change state! '+ JSON.stringify(obj)) stateChange(obj) } }); } }); log('init done!') } async function setLazyStates(obj){ try{ let states = JSON.parse(obj) for (const [key, value] of Object.entries(states)) { let statevalue = value const found = STATES.find(state => state._id === key); if(found){ if (found.common.type === 'boolean'){ statevalue = value === 1 } await setStateAsync(ID +'.'+ key,statevalue,true) } } //set heater state await setStateAsync(ID +'.HEATER',(states.GRN || states.RED) === 1,true) } catch(e){ console.log('Error in setting State '+ e) } } async function asyncForEach(array, callback) { for (let index = 0; index < array.length; index++) { await callback(array[index], index, array); } } function log (msg){ if(debug) console.log (msg) } on({id:'mqtt.'+ MQTTINSTANCE+'.layzspa.message', change:"ne"} , function(obj) { log('Lazyspa reached message! '+ JSON.stringify(obj.state)) setLazyStates(obj.state.val) }); -
@bomer
ich bin auf dieses Projekt gestoßen und auch neu hier in diesem Forum. Ich wäre an 2 der Leiterplatten interessiert, wenn die noch zu haben wären.
Ich habe leider nichts gefunden wie man hier private Nachrichten schicken kann, würde mich über ein Feedback freuen.Gruß
Christian -
@timowald die WifiWhirl Software findest du hier:
WifiWhirl-Software
Wenn du ein Modul besitzt geht es alternativ auch als Update: WifiWhirl Update -
WifiWhirl-Software
So, Ich wollte mal von meiner Umsetzung berichten.
Ich habe den Lay-Z-Spa Miami mit dem >2021er Pumpenmodul.
Die Platinen waren nach ca. 1,5 Wochen aus China bei mir.
Bei einem ersten Testaufbau auf Steckbrett hatte ich schon festgestellt, dass ich für meinen Pool die Kabelbelegung 1:1 aufbauen muss, damit es funktioniert. Bei dem Versuch war kein Low-Pass Filter vorhanden und es kam zu keinem Display-Flickern. Zur Sicherheit baute ich dann im ersten Versuch mit Platine den Filter mit ein. Dies führte aber dazu, dass das Display nicht mehr funktionierte. Also bestückte ich eine zweiter Platine ohne filter und es funktionierte einwandfrei.
Die Einbindung in IO broker lief soweit auch.
Für den finalen Einbau musste aber noch ein Gehäuse her.
Ich orientierte mich am Design von @Rickman (Vielen Dank!) und einem Case ohne Halterung von thingiverse. Heraus kam dieses Thing: https://www.thingiverse.com/thing:6061047 mit dem ich auch ziemlich zufrieden bin. Evtl. muss ich hier nochmal eine neuere Version aus ABS erstellen. PLA scheint mir hier bei den Temperaturen etwas kritisch…
Alles in allem bin ich aber super zufrieden mit dem Projekt und bedanke mich bei euch allen für die Berichte die zu meinem Erfolg beigetragen haben!
@johobo sagte in Lay-Z-Spa Wifi Control:
Hallo
Ich kann leider auf Thingivers das Gehäuse nicht mehr finden. Ich bin an der Befestigung interessiert, da meine Platine jetzt da so lose im Pumpen Gehäuse rumfliegt.
LG EDSTOBI -
Hallo
LG EDSTOBIHallo
Ich benötige einmal eure Hilfe.ch habe die Original-Platine V2B, eine Poolpumpe mit 4-adrigem Anschluss, Modell 54123 (Air), sowie MQTT eingerichtet.
Im Web-Interface des Lay-Z-Spa-Moduls sehe ich die Pumpe, und auch in MQTT taucht sie auf. Soweit funktioniert alles.Nun habe ich einige Verständnisfragen:
Wenn ich im Web-Interface "Take Control" aktiviere, wird das Display der Pumpe deaktiviert. Ist das so richtig?
Ich kann diesen Zustand an der Pumpe selbst nicht rückgängig machen, ohne die Pumpe komplett vom Strom zu trennen und neu zu starten.Im MQTT-Interface sehe ich die Option "Take Control" nicht, bzw. kann sie dort nicht ein- oder ausschalten.
Ist das so vorgesehen oder ist das der SETGODMODE in MQTT "GOD"Wenn ich "Take Control" nicht aktiviert habe, kann ich im Lay-Z-Spa-Webmodul keine Funktionen schalten.
Ist das der normale Ablauf?Wenn ich "Take Control" über die Web-Oberfläche aktiviere und dann Pumpe oder Heizung über MQTT steuere, sehe ich keine Änderung an den Buttons im Web-Interface.
Ist das erwartetes Verhalten?Zusammengefasst:
Ich möchte verstehen, wie die Steuerung zwischen Web-Interface, MQTT und der physischen Pumpe genau funktioniert, insbesondere im Zusammenhang mit der "Take Control"-Funktion.
Ist das Verhalten, wie oben beschrieben, korrekt? Gibt es eine Möglichkeit, "Take Control" auch über MQTT zu steuern sodas es im Webmodule sichtbar ist oder den Zustand an der Pumpe direkt zurückzusetzen, ohne einen Neustart?
Ich möchte die Poolpumpe und den Heizer über ioBroker oder Node-RED automatisch steuern, sodass sie bei PV-Überschuss eingeschaltet werden und die Pumpe zusätzlich nur stundenweise läuft.Gleichzeitig soll es möglich sein, die Pumpe und die Bubbles direkt am Pool zu bedienen, falls jemand den Pool nutzen möchte – ohne dass man erst ins Haus gehen und dort am Display etwas umstellen muss. Andernfalls wäre die Lösung nicht familienfreundlich und hätte keinen hohen WAF (Wife Acceptance Factor)
Sollte das Verhalten der Steuerung von Visualapproach so korrekt sein, werde ich versuchen, am ESP weitere GPIO-Input-Knöpfe zu konfigurieren, um darüber zum Beispiel die Bubbles anzusteuern.
Ich kenne das PDF „REMOTE CONTROLLED LAY-Z-SPA“ von ihm, jedoch sind solche Verhaltensfragen dort nicht beschrieben.
Ich hoffe, dass hier jemand ein identisches Modell 4-adrigem Anschluss, Modell 54123 hat und mir weiterhelfen kann.
EDSTOBI -
Hallo zusammen gibt es auch für die Pumpe S100201 eine Möglichkeit Werte per mqtt zu bekommen?
Danke Christoph
Bei mir kommt jetzt im Script folgender Fehler
javascript.0 18:55:30.845 error script.js.Lay_Z_Spa: script.js.Lay_Z_Spa:1 javascript.0 18:55:30.845 error at script.js.Lay_Z_Spa:1:1und in Log von IO Broker kommt folgendes:
javascript.0 2025-08-06 18:52:04.102 error at Script.runInContext (node:vm:149:12) javascript.0 2025-08-06 18:52:04.102 error at script.js.Lay_Z_Spa:1:1 javascript.0 2025-08-06 18:52:04.102 error SyntaxError: Identifier 'log' has already been declared javascript.0 2025-08-06 18:52:04.102 error script.js.Lay_Z_Spa: script.js.Lay_Z_Spa:1
Wer kann mir sagen was mt einmal nicht mehr stimmt bis jetzt lief alles
Mod-Edit
Code-Tags gesetzt -
AI machts möglich habe mir den Code reparieren lassen.```
const ID = '0_userdata.0.LazySpa'; const MQTTINSTANCE = 0; const debug = true; // Definition der zu erstellenden Datenpunkte const STATES = [ { _id: 'LCK', type: 'state', common: { name: 'lock', type: 'boolean', role: 'indicator.lock', read: true, write: false, desc: 'Lazy spa lock' }, native: {} }, { _id: 'PWR', type: 'state', common: { name: 'power', type: 'boolean', role: 'switch.power', read: true, write: true, desc: 'Lazy spa power' }, native: {} }, { _id: 'UNT', type: 'state', common: { name: 'unit', type: 'number', role: 'value', read: true, write: true, max: 1, desc: 'Lazy spa unit', states: { 0: 'Farenheit', 1: 'Celsius' } }, native: {} }, { _id: 'AIR', type: 'state', common: { name: 'bubbles', type: 'boolean', role: 'switch.light', read: true, write: true, desc: 'Lazy spa bubbles state' }, native: {} }, { _id: 'GRN', type: 'state', common: { name: 'Heating green', type: 'boolean', role: 'indicator', read: true, write: false, desc: 'Reached target temp.' }, native: {} }, { _id: 'RED', type: 'state', common: { name: 'Heating red', type: 'boolean', role: 'indicator', read: true, write: false, desc: 'Not reached target temp.' }, native: {} }, { _id: 'FLT', type: 'state', common: { name: 'pump', type: 'boolean', role: 'switch.pump', read: true, write: true, desc: 'Pump state' }, native: {} }, { _id: 'HEATER', type: 'state', common: { name: 'heater', type: 'boolean', role: 'switch.heater', read: true, write: true, desc: 'Heater state' }, native: {} }, { _id: 'TGT', type: 'state', common: { name: 'target temp', type: 'number', role: 'level.temperature', min: 20, max: 40, step: 1, read: true, write: true, desc: 'Target temp.' }, native: {} }, { _id: 'TMP', type: 'state', common: { name: 'temp', type: 'number', role: 'value.temperature', read: true, write: false, unit: '°C', desc: 'Current temp.' }, native: {} }, ]; /** * Sendet Befehle an den Spa via MQTT. * @param {object} obj Das Objekt vom "on"-Trigger. */ async function stateChange(obj) { const state = obj.id.split('.').pop(); let value = obj.state.val; if (debug) log(`Change detected for '${state}'. Sending command.`); let cmd, val; switch (state) { case 'UNT': cmd = 1; val = value; break; case 'TGT': cmd = 0; val = value; break; case 'AIR': cmd = 2; val = value ? 1 : 0; break; case 'HEATER': cmd = 3; val = value ? 1 : 0; break; case 'FLT': cmd = 4; val = value ? 1 : 0; break; default: if (debug) log(`No action defined for state change of: ${state}`, 'warn'); return; } const mqttCommand = `{"CMD":${cmd},"VALUE":${val},"XTIME":0,"INTERVAL":0}`; await setStateAsync(`mqtt.${MQTTINSTANCE}.layzspa.command`, mqttCommand, false); if (debug) log(`Sent command for '${state}': ${mqttCommand}`); } /** * Verarbeitet eingehende Status-Updates vom Spa. * @param {string} jsonString Der JSON-String von der MQTT-Nachricht. */ async function setLazyStates(jsonString) { let states; try { states = JSON.parse(jsonString); } catch (e) { log(`Error parsing JSON from MQTT: ${jsonString}. Error: ${e.stack}`, 'error'); return; } for (const [key, value] of Object.entries(states)) { const stateDef = STATES.find(s => s._id === key); if (stateDef) { let stateValue = (stateDef.common.type === 'boolean') ? (value === 1) : value; await setStateAsync(`${ID}.${key}`, stateValue, true); } } const isHeaterOn = (states.GRN === 1 || states.RED === 1); await setStateAsync(`${ID}.HEATER`, isHeaterOn, true); } /** * Hauptfunktion zur Initialisierung des Skripts. */ async function main() { // 1. Datenpunkte erstellen oder sicherstellen, dass sie existieren for (const stateObject of STATES) { const id = `${ID}.${stateObject._id}`; if (!(await getObjectAsync(id))) { if (debug) log(`Creating state: ${id}`); await createStateAsync(id, stateObject.common); } // 2. Trigger für schreibbare Datenpunkte erstellen if (stateObject.common.write) { on({ id: id, change: "any", ack: false }, async (obj) => { try { if (obj.state) { await stateChange(obj); } } catch (e) { log(`Error in stateChange trigger for ${id}: ${e.stack}`, 'error'); } }); } } // 3. Trigger für eingehende MQTT-Nachrichten on({ id: `mqtt.${MQTTINSTANCE}.layzspa.message`, change: "ne" }, async (obj) => { try { if (obj.state && obj.state.val) { if (debug) log(`Received MQTT message: ${obj.state.val}`); await setLazyStates(obj.state.val); } } catch (e) { log(`Error in MQTT message handler: ${e.stack}`, 'error'); } }); log("LazySpa script started and all triggers are active."); } // Skriptausführung starten und alle Fehler abfangen. try { main(); } catch (e) { log(`A critical error occurred during script initialization: ${e.stack}`, 'error'); } -
Danke Christoph
@christoph-4 sagte in Lay-Z-Spa Wifi Control:
Danke Christoph
Hat niemand eine Idee?
Gruß Christoph -
Hi zusammen,
ich brauche etwas Unterstützung.
Ich habe für meinen LayZSpa ein Wlan Modul eingebaut und möchte nun versuchen per MQTT (Habe ich noch nie benutzt) den Wirlpool zu steuern.Den MQTT Adapter habe ich eingerichtet und er ist auch auf grün gegangen. Nun hätte ich erwartet, dass ich bei Objekte die Temperatur sehe und Status der Pumpe/Heizung etc.
Kann mir jemand sagen wie ich da weiter komm? Danke im Voraus.
ich hole mal diesen Thread hier wieder raus. Ich habe noch eine alte Platine Version 1 hier herum liegen. Würde diese gerne an meinem Miami 2021 anschließen. Leder finde ich nur noch Anleitungen für die V2 Platine. Hat jemand noch die Anleitung der V1? Irgendwie muss man glaub noch Widerstände einlöten oder?
