  4. Error Meldung vom Shelly Adapter 9.2.0
    6.8k
15 Beiträge 4 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • G Gonzokalle
    @haselchen
    Sehr gerne.
    Gehe ich irgendwo ins Minus?
    <block xmlns="https://developers.google.com/blockly/xml" type="comment" id="i91ojf8}cj2PGVfzC4wj" x="688.39990234375" y="-1183.3999938964844">
      <field name="COMMENT">Licht von 5 Uhr bis Sonnenaufgang 5%</field>
      <next>
        <block type="schedule" id=",Jo1f;j.XVTC(MHM;+Hc">
          <field name="SCHEDULE">0 5 * * *</field>
          <statement name="STATEMENT">
            <block type="control" id="/i+(1Xg$dp-H;:UMsIhh">
              <field name="OID">shelly.0.SHDM-2#E89F6D85155D#1.lights.Switch</field>
              <value name="VALUE">
                <block type="logic_boolean" id="H]O/D+j.Pp7uq@;Z7zMY">
                </block>
              </value>
              <next>
                <block type="control" id="~emuxQG|E%|f*R`SU+AR">
                  <field name="OID">shelly.0.SHDM-2#E89F6D85155D#1.lights.brightness</field>
                    <block type="math_number" id="0SQAt3#qX~k#6c!E.Do4">
                      <field name="NUM">5</field>
                    </block>
                  </value>
                </block>
              </next>
            </block>
          </statement>
          <next>
            <block type="astro" id="J?he7/R7ojpe)V}Q7,Z9">
              <field name="TYPE">sunrise</field>
              <field name="OFFSET">2</field>
                <block type="control" id="oFF=4yApQxDe/J%+A4.r">
                    <block type="logic_boolean" id="A4kTBdBaM/KViTP=7i6q">
                    </block>
                  </value>
                </block>
              </statement>
              <next>
                <block type="comment" id="II@GOi5.2mz5t#W66l%Z">
                  <field name="COMMENT">Licht von Sonnenuntergang bis 23 Uhr 5%</field>
                  <next>
                    <block type="astro" id="rVQmj-JaK@OuzOp$N91L">
                      <field name="TYPE">sunset</field>
                      <field name="OFFSET">0</field>
                        <block type="control" id="N9?|LlosE}|1No}0etFM">
                            <block type="logic_boolean" id="(A:Mt5Pxh]8SZ^rEo*4_">
                            </block>
                          </value>
                          <next>
                            <block type="control" id=":$[|p(Shdj|eHk5sg7X+">
                                <block type="math_number" id="l7L]]mT6#7!E%305}?NO">
                                </block>
                              </value>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <next>
                        <block type="schedule" id="Uc;hmk?EXkir$SBu.9G+">
                          <field name="SCHEDULE">0 23 * * *</field>
                            <block type="control" id="pav`Phd2Nqq;ix26yjwG">
                                <block type="logic_boolean" id="ibtihJ5lvLfy0fFn$kkv">
                                </block>
                              </value>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </next>
        </block>
      </next>
    </block>
    @gonzokalle sagte in Error Meldung vom Shelly Adapter 9.2.0:
    muss nicht im Minus sein.
    Die Meldung ist
    Wert =0 und min =1
    (demnächst bitte keine Screenshots dann kann man auch zitieren!)
    und hier
    setzst du startwert auf 0
    G 1 Antwort Letzte Antwort
      Die Meldung ist
      Wert =0 und min =1
      und hier
      Gonzokalle
      Dankeschön.
      Also soll ich an dieser Stelle eine 1 eintragen?
      Hätte noch erwähnen sollen, dass der Error früher nicht gekommen ist.
      Scheinbar erst mit dem Update.
      Aktuell steht die Brightness auf 5%, Error kommt.
      MinBrightness steht in den Objekten auf 0. Kann ich nicht ändern ist schreibgeschützt.
      In der Oberfläche des Shellys konnte ich bei MinBrightness eine 1 eintragen. Jetzt ist Ruhe.
      Eventuell kann man ja den Adapter so konfigurieren, dass man eine 0 ohne Error eintragen kann?
      Viele im Forum wollen ein Screenshot haben für unterwegs.
      Was soll ich denn stattdessen nehmen?
      • G Gonzokalle
        Dankeschön.
        laut nicht zitierbarem log eben nicht!
        bitte beides zeigen
        in code-tags!
          bitte beides zeigen
          in code-tags!
          Gonzokalle
          @Homoran
          Wenn ich in der Oberfläche des Shellys unter Minimum brightness eine 0 eintrage kommt der Error.
          shelly.0
          2025-04-13 16:36:04.312	warn	State value to set for "shelly.0.SHDM-2#E89F6D85155D#1.lights.MinBrightness" has value "0" less than min "1"
          shelly.0
          2025-04-13 16:35:58.996	warn	State value to set for "shelly.0.SHDM-2#E89F6D85155D#1.lights.MinBrightness" has value "0" less than min "1"
          shelly.0
          2025-04-13 16:35:53.725	warn	State value to set for "shelly.0.SHDM-2#E89F6D85155D#1.lights.MinBrightness" has value "0" less than min "1"
          Wenn ich in der Oberfläche des Shellys unter Minimum brightness eine 1 eintrage kommt kein Error.
          Also auch kein Log.
          • G Gonzokalle
            @Homoran
            shelly.0
            shelly.0
            shelly.0
            Also auch kein Log.
            dann zeig mal dazu die Objektdaten!
              Gonzokalle
                "type": "state",
                "common": {
                  "name": {
                    "en": "Minimum Brightness",
                    "de": "Mindesthelligkeit",
                    "ru": "Минимальная яркость",
                    "pt": "Brilho mínimo",
                    "nl": "Minimale helderheid",
                    "fr": "Luminosité minimale",
                    "it": "Minimo splendore",
                    "es": "Brillo mínimo",
                    "pl": "Minimalna jasność",
                    "uk": "Мінімальна яскравість",
                    "zh-cn": "最小亮度"
                  "type": "number",
                  "role": "level.brightness",
                  "read": true,
                  "write": false,
                  "min": 1,
                  "max": 100,
                  "unit": "%"
                "native": {},
                "from": "system.adapter.shelly.0",
                "user": "system.user.admin",
                "ts": 1744535952296,
                "_id": "shelly.0.SHDM-2#E89F6D85155D#1.lights.MinBrightness",
                "acl": {
                  "object": 1636,
                  "state": 1636,
                  "owner": "system.user.admin",
              • G Gonzokalle
                  "type": "state",
                  "common": {
                    "name": {
                      "zh-cn": "最小亮度"
                    "type": "number",
                    "read": true,
                    "write": false,
                    "min": 1,
                    "max": 100,
                    "unit": "%"
                  "native": {},
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                min": 1,
                passt zur Meldung
                dann darfst du das nicht
                  min": 1,
                  passt zur Meldung
                  Gonzokalle
                  So ist es.
                  Scheint aber so erst seit dem Update zu sein.
                  Hauptsache es geht.
                  Vielen Dank für deine Hilfe.
                  HomoranH mcm1957M 2 Antworten Letzte Antwort
                  • G Gonzokalle
                    So ist es.
                    Hauptsache es geht.
                    welches?
                    steht hier
                    auch nicht
                    • G Gonzokalle
                      So ist es.
                      Hauptsache es geht.
                      mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      @gonzokalle
                      Leg gern ein Issue beim Adapter an.
                      Bitte gib jedenfalls an welches device (DEVICE-ID) und beschreib möglichst genau wo du wie welchen wert eingibts. Dann kann man sich das ansehen.
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      • mcm1957M mcm1957
                        @gonzokalle
                        Gonzokalle
                        @mcm1957
                        Mit Issue habe ich es nicht so.
                        • G Gonzokalle
                          @mcm1957
                          mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          @gonzokalle
                          Schade ohne issue wird da ziemlich sicher nichts geändert / verbessert.
