  4. Zigbee iobroker Error while opening serialport
    6.6k
231 Beiträge 28 Kommentatoren 64.2k Aufrufe 24 Beobachtet
  • M M1R0O
    ich würde ebenfalls gern einen Zigbee-Dongle betreieben, bekomme es aber nicht hin:
    Meine Hardware:
    /usr/bin/nodejs v20.19.0
    /usr/bin/node v20.19.0
    /usr/bin/npm 10.8.2
    ioBroker Core: js-controller 7.0.6
    admin 7.6.3
    Meine Steps:
    1. Dongle angeschlossen
    2. Abfrage ls -la /dev/serial/by-id
    3. Ausgabe: lrwxrwxrwx 1 root root 13 7. Apr 17:05 usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a91bed3c449ef11b1fed18cff00cc63-if00-port0 -> ../../ttyUSB0
    4. Abfrage: iob diag
    5. Ausgabe /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a91bed3c449ef11b1fed18cff00cc63-if00-port0 eingetragen
    6. HEX-Code eingetragen
    Klappt nicht.
    Protokoll sagt:
    zigbee.0
    2025-04-07 17:32:52.043	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"5a91bed3c449ef11b1fed18cff00cc63","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a91bed3c449ef11b1fed18cff00cc63-if00-port0","vendorId":"10c4","productId":"ea60"}]
    zigbee.0
    2025-04-07 17:32:37.865	error	Error herdsman start
    zigbee.0
    2025-04-07 17:32:37.863	error	Failed to start Zigbee
    zigbee.0
    2025-04-07 17:32:37.862	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
    zigbee.0
    2025-04-07 17:32:37.641	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-04-07 17:32:37.575	info	Starting Zigbee npm ...
    zigbee.0
    2025-04-07 17:32:37.572	info	Try to reconnect. 1 attempts left
    zigbee.0
    2025-04-07 17:32:30.358	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"5a91bed3c449ef11b1fed18cff00cc63","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a91bed3c449ef11b1fed18cff00cc63-if00-port0","vendorId":"10c4","productId":"ea60"}]
    zigbee.0
    2025-04-07 17:32:27.567	error	Error herdsman start
    zigbee.0
    2025-04-07 17:32:27.567	error	Failed to start Zigbee
    zigbee.0
    2025-04-07 17:32:27.566	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    2025-04-07 17:32:06.875	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-04-07 17:32:06.448	info	Starting Zigbee npm ...
    zigbee.0
    2025-04-07 17:32:06.306	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
    zigbee.0
    2025-04-07 17:31:55.542	info	terminating
    zigbee.0
    2025-04-07 17:31:55.059	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2025-04-07 17:31:55.057	info	terminating
    zigbee.0
    2025-04-07 17:31:55.045	info	Zigbee: disabling joining new devices.
    zigbee.0
    2025-04-07 17:31:55.041	info	cleaned everything up...
    zigbee.0
    2025-04-07 17:31:55.038	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2025-04-07 17:31:08.445	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"5a91bed3c449ef11b1fed18cff00cc63","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a91bed3c449ef11b1fed18cff00cc63-if00-port0","vendorId":"10c4","productId":"ea60"}]
    zigbee.0
    2025-04-07 17:30:26.808	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"5a91bed3c449ef11b1fed18cff00cc63","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a91bed3c449ef11b1fed18cff00cc63-if00-port0","vendorId":"10c4","productId":"ea60"}]
    zigbee.0
    2025-04-07 17:28:35.358	error	Error herdsman start
    zigbee.0
    2025-04-07 17:28:35.357	error	Failed to start Zigbee
    zigbee.0
    2025-04-07 17:28:35.356	error	Starting zigbee-herdsman problem : "Error Resource temporarily unavailable Cannot lock port"
    zigbee.0
    2025-04-07 17:28:35.172	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-04-07 17:28:35.160	info	Starting Zigbee npm ...
    zigbee.0
    2025-04-07 17:28:35.159	info	Try to reconnect. 1 attempts left
    zigbee.0
    2025-04-07 17:28:25.155	error	Error herdsman start
    zigbee.0
    2025-04-07 17:28:25.154	error	Failed to start Zigbee
    zigbee.0
    2025-04-07 17:28:25.153	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
    zigbee.0
    2025-04-07 17:28:04.474	info	Installed Version: iobroker.zigbee@1.10.14
    zigbee.0
    2025-04-07 17:28:04.049	info	Starting Zigbee npm ...
    zigbee.0
    2025-04-07 17:28:03.859	info	starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
    zigbee.0
    2025-04-07 17:27:52.088	info	terminating
    zigbee.0
    2025-04-07 17:27:51.607	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
    2025-04-07 17:27:51.605	info	terminating
    zigbee.0
    2025-04-07 17:27:51.591	info	Zigbee: disabling joining new devices.
    zigbee.0
    2025-04-07 17:27:51.586	info	cleaned everything up...
    zigbee.0
    2025-04-07 17:27:51.583	info	Got terminate signal TERMINATE_YOURSELF
    zigbee.0
    2025-04-07 17:27:38.548	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"5a91bed3c449ef11b1fed18cff00cc63","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a91bed3c449ef11b1fed18cff00cc63-if00-port0","vendorId":"10c4","productId":"ea60"}]
    Wenn ich die Instanz öffne, erhalte ich jedes Mal den Error: "You need to save an run adapter before pairing"
    Was habe ich vergessen oder falsch gemacht?
    Meister MopperM Offline
    Meister Mopper
    schrieb am zuletzt editiert von Meister Mopper
    #217
    @m1r0o
    Was sagt iob diag ?
    Bitte das Ergebnis der Langfassung (nicht Summary) in </> codetags hier reinstellen.
    Proxmox und HA ...
      @m1r0o
      Was sagt iob diag ?
      M1R0O
      #218
      @meister-mopper sagte in Zigbee iobroker Error while opening serialport:
      @m1r0o
      Was sagt iob diag ?
      Hier die Langfassung:
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
      Static hostname: iobroker
            Icon name: computer
               Kernel: Linux 6.6.74+rpt-rpi-v8
         Architecture: arm64
      OS is similar to:
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
      17:59:00 up 30 days,  4:43,  4 users,  load average: 0.95, 0.74, 0.73
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                    Local time: Mon 2025-04-07 17:59:00 CEST
                Universal time: Mon 2025-04-07 15:59:00 UTC
                      RTC time: n/a
                   NTP service: active
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: true
      Desktop:
      Terminal: 	tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            4.0G        2.6G        341M         11M        1.2G        1.4G
      Swap:           209M        114M         95M
      Total:          4.2G        2.7G        436M
      Active iob-Instances: 	26
              3791 M total memory
              2474 M used memory
              1065 M active memory
              2125 M inactive memory
               325 M free memory
               159 M buffer memory
               975 M swap cache
               199 M total swap
               109 M used swap
                90 M free swap
      top - 17:59:00 up 30 days,  4:43,  4 users,  load average: 0.95, 0.74, 0.73
      Tasks: 217 total,   2 running, 215 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 33.3 us, 16.7 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3791.9 total,    324.3 free,   2474.8 used,   1135.0 buff/cache
      MiB Swap:    200.0 total,     90.7 free,    109.3 used.   1317.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.3M  378M   1% /run
      /dev/mmcblk0p2 ext4       58G   12G   44G  22% /
      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
      tmpfs          tmpfs     380M   44K  380M   1% /run/user/1000
      [Sat Mar  8 12:15:37 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:40:0A:20 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d43b0484-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Sat Mar  8 12:15:41 2025] EXT4-fs (mmcblk0p2): mounted filesystem 4aa56689-dcb4-4759-90e6-179beae559ac ro with ordered data mode. Quota mode: none.
      [Sat Mar  8 12:15:45 2025] EXT4-fs (mmcblk0p2): re-mounted 4aa56689-dcb4-4759-90e6-179beae559ac r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.1G	/var/
      392M	/var/log
      391M	/var/log/journal/7b830b1fef9c4965b5f08a63b1f9927d
      226M	/var/cache
      Archived and active journals take up 390.5M in the file system.
      /opt/iobroker/backups:
      32M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G	/opt/iobroker/iobroker-data/
      955M	/opt/iobroker/iobroker-data/files
      617M	/opt/iobroker/iobroker-data/files/javascript.admin
      560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      26M	/opt/iobroker/iobroker-data/objects.jsonl
      24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
      24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      USB-Devices by-id:
      *** ZigBee Settings ***
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.31.0
      nodejs:
       Installed: 20.19.0-1nodesource1
       Candidate: 20.19.0-1nodesource1
       Version table:
      *** 20.19.0-1nodesource1 1001
             500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
          20.18.3-1nodesource1 1001
          20.18.2-1nodesource1 1001
          20.18.1-1nodesource1 1001
          20.18.0-1nodesource1 1001
          20.17.0-1nodesource1 1001
          20.16.0-1nodesource1 1001
          20.15.1-1nodesource1 1001
          20.15.0-1nodesource1 1001
          20.14.0-1nodesource1 1001
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          18.19.0+dfsg-6~deb12u2 500
             500 http://deb.debian.org/debian bookworm/main arm64 Packages
          18.19.0+dfsg-6~deb12u1 500
             500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 534317)
      Core adapters versions
      admin: 		7.6.3
      javascript: 	8.8.3
      nodejs modules from github: 	1
      +-- iobroker.solaredge-modbus@0.0.25 (git+ssh://git@github.com/joergspoerl/ioBroker.solaredge-modbus.git#a17300b3182465292a476c4e0fbaa96c9706e14d)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.38, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
       system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
       system.adapter.denon.0                  : denon                 : iobroker                                 - disabled
       system.adapter.devices.0                : devices               : iobroker                                 - disabled
       system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
       system.adapter.dysonairpurifier.0       : dysonairpurifier      : iobroker                                 - disabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
      + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
       system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
      + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
       system.adapter.history.0                : history               : iobroker                                 - disabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
       system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
       system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
       system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
       system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
       system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
      + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
      + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
       system.adapter.parser.0                 : parser                : iobroker                                 - disabled
       system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
       system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
       system.adapter.scenes.0                 : scenes                : iobroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
      + system.adapter.solaredge-modbus.0       : solaredge-modbus      : iobroker                                 -  enabled, port: 1502
       system.adapter.solaredge.0              : solaredge             : iobroker                                 -  enabled
       system.adapter.sonoff.0                 : sonoff                : iobroker                                 - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
       system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
       system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
       system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_5a91bed3c449ef11b1fed18cff00cc63-if00-port0
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name     │ url                                              │ auto upgrade │
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.6.3
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "dysonairpurifier": 3.2.6 , installed 3.2.6
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "fb-checkpresence": 1.3.1 , installed 1.3.1
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "hue"          : 3.14.1   , installed 3.14.1
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "lovelace"     : 4.1.15   , installed 4.1.15
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "parser"       : 2.2.4    , installed 2.2.4
      Adapter    "ring"         : 6.3.0    , installed 6.3.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
      Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 2.0.5    , installed 1.10.14 [Updatable]
      Objects and States
      Objects: 	15596
      States: 	14011
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 38
      *** Listening Ports ***
      tcp        0      0 192.168.178.38:8081     0.0.0.0:*               LISTEN      1001       74213469   1498218/io.admin.0
      tcp        0      0 192.168.178.38:2010     0.0.0.0:*               LISTEN      1001       74213308   1498452/io.hm-rpc.1
      tcp        0      0 192.168.178.38:2001     0.0.0.0:*               LISTEN      1001       74213707   1498419/io.hm-rpc.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       74214763   1498524/io.shelly.0
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          91037014   357656/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       74212986   1498187/iobroker.js
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       74212991   1498187/iobroker.js
      tcp        0      0 0.0.0.0:33489           0.0.0.0:*               LISTEN      1001       74216693   1498719/io.yahka.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6768       745/sshd: /usr/sbin
      tcp6       0      0 :::8091                 :::*                    LISTEN      1001       74214908   1498637/io.lovelace
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       74214966   1498708/io.web.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          91037013   357656/cupsd
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       74213225   1498385/io.harmony.
      tcp6       0      0 :::51989                :::*                    LISTEN      1001       74213805   1498553/io.nuki-ext
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6770       745/sshd: /usr/sbin
      udp        0      0 0.0.0.0:46700           0.0.0.0:*                           104        2960       549/avahi-daemon: r
      udp        0      0 0.0.0.0:45100           0.0.0.0:*                           1001       91963639   1498363/io.broadlin
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       74213843   1498531/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       74213844   1498531/io.tuya.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       74213226   1498385/io.harmony.
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       74213193   1498363/io.broadlin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2958       549/avahi-daemon: r
      udp        0      0 0.0.0.0:46390           0.0.0.0:*                           1001       74214549   1498363/io.broadlin
      udp6       0      0 :::55462                :::*                                104        2961       549/avahi-daemon: r
      udp6       0      0 fe80::b931:3052:c4f:546 :::*                                0          8520       666/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        2959       549/avahi-daemon: r
      2025-04-07 17:57:05.390  - info: host.iobroker instance system.adapter.solaredge.0 having pid 2512579 terminated with code 0 (NO_ERROR)
      2025-04-07 17:57:05.885  - info: nuki.0 (1498501) Bridge Info requested: http://192.168.178.24:8080/info?ts=2025-04-07T15:54:51Z&rnr=52251&hash=620ca2c85548ca5ae83328a867516c7a556771fd80a1ae7a13adfefda479bb40
      2025-04-07 17:57:05.886  - error: nuki.0 (1498501) Error: connect ETIMEDOUT 192.168.178.24:8080
      2025-04-07 17:57:07.069  - error: solaredge-modbus.0 (495838) netSocket ERROR{"errno":-104,"code":"ECONNRESET","syscall":"read"}
      2025-04-07 17:57:07.069  - error: solaredge-modbus.0 (495838) ERROR - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
      2025-04-07 17:57:07.069  - error: solaredge-modbus.0 (495838) ERROR in callback{"err":"Offline","message":"connection to modbus server closed","request":{"_id":1,"_protocol":0,"_length":6,"_unitId":1,"_body":{"_fc":3,"_start":0,"_count":111}}}
      2025-04-07 17:57:07.430  - warn: solaredge-modbus.0 (495838) setInfoConnectionState: false - connection lost ! connectionErrorCounter:1
      2025-04-07 17:57:07.933  - info: nuki.0 (1498501) Lock list requested: http://192.168.178.24:8080/list?ts=2025-04-07T15:54:54Z&rnr=33712&hash=1e82ccdb736731c074b5f9d197a1a7465ddc2bc8f876bb1738810bbaec80c9fe
      2025-04-07 17:57:07.934  - error: nuki.0 (1498501) Error: connect ETIMEDOUT 192.168.178.24:8080
      2025-04-07 17:57:26.089  - error: solaredge-modbus.0 (495838) netSocket ERROR{"errno":-104,"code":"ECONNRESET","syscall":"read"}
      2025-04-07 17:57:26.089  - error: solaredge-modbus.0 (495838) ERROR - {"errno":-104,"code":"ECONNRESET","syscall":"read"}
      2025-04-07 17:57:26.090  - error: solaredge-modbus.0 (495838) ERROR in callback{"err":"Offline","message":"connection to modbus server closed","request":{"_id":1,"_protocol":0,"_length":6,"_unitId":1,"_body":{"_fc":3,"_start":0,"_count":111}}}
      2025-04-07 17:58:00.033  - info: host.iobroker instance system.adapter.solaredge.0 in version "1.4.1" started with pid 2514744
      2025-04-07 17:58:02.717  - info: solaredge.0 (2514744) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.solaredge, node: v20.19.0, js-controller: 7.0.6
      2025-04-07 17:58:03.927  - info: solaredge.0 (2514744) Terminated (NO_ERROR): Without reason
      2025-04-07 17:58:04.696  - info: host.iobroker instance system.adapter.solaredge.0 having pid 2514744 terminated with code 0 (NO_ERROR)
      2025-04-07 17:58:22.525  - error: solaredge-modbus.0 (495838) netSocket ERROR{"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.138","port":1502}
      2025-04-07 17:58:22.526  - error: solaredge-modbus.0 (495838) ERROR - {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.138","port":1502}
      2025-04-07 17:59:00.044  - info: host.iobroker instance system.adapter.solaredge.0 in version "1.4.1" started with pid 2516820
      2025-04-07 17:59:03.375  - info: solaredge.0 (2516820) starting. Version 1.4.1 in /opt/iobroker/node_modules/iobroker.solaredge, node: v20.19.0, js-controller: 7.0.6
      2025-04-07 17:59:04.539  - info: solaredge.0 (2516820) Terminated (NO_ERROR): Without reason
      2025-04-07 17:59:05.489  - info: host.iobroker instance system.adapter.solaredge.0 having pid 2516820 terminated with code 0 (NO_ERROR)
      2025-04-07 17:59:16.627  - error: solaredge-modbus.0 (495838) netSocket ERROR{"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.138","port":1502}
      2025-04-07 17:59:16.628  - error: solaredge-modbus.0 (495838) ERROR - {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.138","port":1502}
      2025-04-07 17:59:17.445  - warn: solaredge-modbus.0 (495838) setInfoConnectionState: false - connection lost ! connectionErrorCounter:1
      iob diag has finished.
      [/s]
      • M M1R0O
        Meine Hardware:
        /usr/bin/npm 10.8.2
        admin 7.6.3
        Meine Steps:
        Klappt nicht.
        Protokoll sagt:
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #219
        @m1r0o sagte in Zigbee iobroker Error while opening serialport:
        So wie es aussieht hast du einen der folgenden Fehler:
        • Kein oder ein schlechtes USB Verlängerungskabel am Sonoff Stick
        • Sonoff-Stick im USB3 Port
        • SSD oder HDD am USB3 Port welche den Stick stört
        • Falsche WLAN/Zigbee Kanal Kombination
        • Falsche Firmware eingetragen (TI vs. Ember vs. EZSP)
        Ich würde mit dem letzten anfangen - Firmware auf EZSP wechseln.
        Nebenbei - es ist echt toll wieviel Du in den Posts darüber gelesen hast. Da wurde genau die gleiche Fehlermeldung beschrieben:
        zigbee.0 2025-04-07 17:28:25.153	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
        Die Bitte nach dem iob diag ist erstmal nicht entscheidend - das der Port nicht geöffnet werden kann ist ein Folgefehler des oben gerosteten.
        A.
        • AsgothianA Asgothian
          A.
          M1R0O
          schrieb am zuletzt editiert von M1R0O
          #220
          @asgothian sagte in Zigbee iobroker Error while opening serialport:
          Kein Verlängerungkabel
          Nicht um USB3-Port (soll er in den USB3Port?)
          Keine SSD/HDD
          Kanal Zigbee 11, Kanal WLAN 6
          Keine Änderung, bei Änderung der FW (Adapter bei Ember kurz grün, dann wieder gelb)
          Der Post darüber hiulft mir nicht, weil ich es nciht verstehe, sorry!
          Meister MopperM AsgothianA 2 Antworten Letzte Antwort
          • M M1R0O
            Keine SSD/HDD
            Meister Mopper
            #221
            Ändere das, der Stick direkt am Gerät verursacht Interferenzen (oder wie auch immer das heißt) => nicht in USB3.
            Proxmox und HA ...
            • M M1R0O
              Keine SSD/HDD
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #222
              @m1r0o bitte das log vom Start Versuch posten.
              Zum Thema Post darüber - es gibt eigentlich um den thread - nicht den Post. Die Fehlermeldung die du gepostet hat steht da an mehreren Stellen - gegenmassnahmen auch.
              Das zu lesen und mit dem eigenen Log abzugleichen hilft schon.
              Ansonsten fehlen weitere Informationen - was für einen koordinator hast du. - die genaue Bezeichnung, nicht nur “sonoff stick”.
              Mit dem was du lieferst ist es echt schwer dir zu helfen.
              A.
                M1R0O
                #223
                Danke!
                Ich habe einen SONOFF EFR32MG21 + CH9102F/CP2102N.
                Ich habe den Adapter nun nach dieser Anleitung
                Stick noch nicht wechseln! Alle Geräte im Adapter löschen.
                Stick Im Adapter Hard Resetten. Stick entfernen.
                Instanz Zigbee löschen.
                Adapter deinstallieren.
                Ordner /opt/iobroker/iobroker-data/zigbee_0 löschen.
                Neue Stick verbinden.
                Aktuele Adapter installieren.
                gelöscht und neu installiert.
                Stick in den anderen USB2.0 Port - nun mit ca. 50cm-Verlängerung
                iob diag Abfrage
                Egal welche FW - es geht nicht.
                Log:
                zigbee.0
                2025-04-07 19:46:28.226	info	terminating
                zigbee.0
                2025-04-07 19:46:28.219	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:315:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                zigbee.0
                2025-04-07 19:46:28.211	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                zigbee.0
                2025-04-07 19:46:28.209	info	terminating
                zigbee.0
                2025-04-07 19:46:28.208	info	Saved local configuration data
                zigbee.0
                2025-04-07 19:46:28.205	info	local config saved
                zigbee.0
                2025-04-07 19:46:28.204	info	cleaned everything up...
                zigbee.0
                2025-04-07 19:46:28.151	error	undefined
                zigbee.0
                2025-04-07 19:46:28.150	error	unhandled promise rejection: undefined
                zigbee.0
                2025-04-07 19:46:28.149	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                2025-04-07 19:46:28.147	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
                zigbee.0
                2025-04-07 19:46:27.999	info	Unable to obtain herdsman settings
                zigbee.0
                2025-04-07 19:46:01.633	info	Starting Zigbee-Herdsman
                zigbee.0
                2025-04-07 19:46:01.631	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.1)
                zigbee.0
                2025-04-07 19:46:01.581	info	Starting Adapter npm ...
                zigbee.0
                2025-04-07 19:46:01.579	info	--- creating device debug ---
                zigbee.0
                2025-04-07 19:46:01.563	info	--> transmitPower : normal
                zigbee.0
                2025-04-07 19:46:01.555	info	init localConfig
                zigbee.0
                2025-04-07 19:46:01.528	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                Ich habe den Stick jetzt mit 7.4.4 neu geflasht, keine Veränderung
                • M M1R0O
                  Danke!
                  iob diag Abfrage
                  Log:
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  #224
                  @m1r0o
                  Welchen Treiber/Stack hast du denn nun eingestellt?
                    M1R0O
                    #225
                    Geflasht habe ich so: https://darkxst.github.io/silabs-firmware-builder/
                    Nach dem Flashen wurde mir EZSP angezeigt, das habe ich dann auch eingestellt.
                    Meinst du das?
                    Was sagen diese Fehler:
                    zigbee.0
                    2025-04-07 21:04:34.481	debug	Plugin sentry destroyed
                    zigbee.0
                    2025-04-07 21:02:56.706	debug	Plugin sentry Initialize Plugin (enabled=true)
                    zigbee.0
                    2025-04-07 20:56:49.595	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin
                    zigbee.0
                    2025-04-07 20:56:49.590	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    zigbee.0
                    2025-04-07 20:56:49.587	info	terminating
                    zigbee.0
                    2025-04-07 20:56:49.586	info	Saved local configuration data
                    zigbee.0
                    2025-04-07 20:56:49.584	info	local config saved
                    zigbee.0
                    2025-04-07 20:56:49.582	info	cleaned everything up...
                    zigbee.0
                    2025-04-07 20:56:49.530	error	undefined
                    zigbee.0
                    2025-04-07 20:56:49.530	error	unhandled promise rejection: undefined
                    zigbee.0
                    2025-04-07 20:56:49.529	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    In USB3.0-Slot eingesteckt - läuft!
                    • M M1R0O
                      Meinst du das?
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #226
                      Mit oder ohne Verlängerung ?
                      A.
                      p.s. das ist nicht nur eine Neugier-Frage - bisher ist mein Wissensstand das einstecken in einen USB3 Port eher ungünstig ist. Das was Du schreibst beschreibt das Gegenteil. Solche Informationen sammle ich, damit ich die Leute nicht in die Irre führe.
                        A.
                        M1R0O
                        #227
                        @asgothian
                        Im Moment ohne Verlängerung, da ich diese zunächst als Fehlerquelle ausschließen wollte.
                        • M M1R0O
                          @asgothian
                          #228
                          eine fehlende Verlängerung ist eine Fehlerquelle!
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #229
                            @homoran sagte in Zigbee iobroker Error while opening serialport:
                            Das ist so pauschal nicht korrekt. Inwieweit eine Verlängerung vorteilhaft ist, hängt stark davon ab wie das Umfeld des Systems, an dem der Stick eingesetzt wird aufgebaut ist. Auch die Frage, an welcher Stelle sich die WLAN Antenne befindet und ob das WLAN aktiv ist, hat einen Einfluss.
                            Korrekt ist das in den meisten fällen, die Verwendung einer qualitativ hochwertigen Verlängerung einen Vorteil bringt. Wenn man aber nicht sicher ist, wie gut die vorhandene USB Verlängerung ist, dann ist es durchaus eine Überlegung wert auf die Verlängerung zu verzichten, um diese als Fehlerquelle auszuschließen.
                            A.
                              A.
                              #230
                              ihr versteht mich nicht 😢
                              Um eine Einstreuung/Interferenz zwischen SBC und Zigbee-Stick zu vermeiden, ermöglicht eine Verlängerung eine größere Distanz zwischen den beiden Geräten.
                              fehlt dieser Abstand kann es zu den genannten Problemen kommen.
                              Also ist es eine mögliche Fehlerquelle, ohne Verlängerung zu arbeiten.
                                M1R0O
                                #231
                                Ich denke, ihr habt beide recht ;-)
                                Bei mir läuft es aktuell gut ohne Verlängerung mit EMBER in USB3.0
                                Danke!
