  4. IOBroker stürzt ab und alle Adapter starten neu
    1.0k
    6.1k
82 Beiträge 13 Kommentatoren 17.6k Aufrufe 11 Beobachtet
  • J jan_xx
    @wendy2702
    Meinst du das alles?->siehe anbei
    von meinem 4GB Raspi. habe ich 2,4GB verwendet?
     Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.15.84-v7l+
          Architecture: arm
    OS is similar to: debian
    Model		: Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     08:20:10 up 40 days, 23:21,  2 users,  load average: 2.94, 1.93, 1.67
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'bullseye'. Please check yourself if the Operating System is actively maintained.
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-04-03 08:20:10 CEST
               Universal time: Thu 2025-04-03 06:20:10 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iobroker
    XDG_CONFIG_HOME=/home/iobroker/.config
    HOME=/home/iobroker
    GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin gpio i2c spi
    iobroker
    HOME=/home/iobroker
    A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
    A root login is not required in most Linux Distributions.
    Run 'iobroker fix' or use the system tools to create a user.
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop: 	LXDE-pi
    Terminal: 	x11
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            3.8G        2.3G        542M         34M        1.0G        1.4G
    Swap:            99M         99M        0.0K
    Total:          3.9G        2.4G        543M
    Active iob-Instances: 	45
             3837 M total memory
             2288 M used memory
              588 M active memory
             2515 M inactive memory
              542 M free memory
              112 M buffer memory
              894 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    top - 08:20:11 up 40 days, 23:21,  2 users,  load average: 2.94, 1.93, 1.67
    Tasks: 238 total,   4 running, 234 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 44.6 us, 12.2 sy,  0.0 ni, 41.9 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
    MiB Mem :   3837.9 total,    541.0 free,   2289.0 used,   1007.9 buff/cache
    MiB Swap:    100.0 total,      0.4 free,     99.6 used.   1377.8 avail Mem
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    1 loaded units listed.
    @jan_xx sagte in IOBroker stürzt ab und alle Adapter starten neu:
    Natürlich
    • J jan_xx
      @wendy2702
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      iobroker
      HOME=/home/iobroker
      iobroker
      HOME=/home/iobroker
      Desktop: 	LXDE-pi
      Terminal: 	x11
      *** MEMORY ***
      Swap:            99M         99M        0.0K
               3837 M total memory
               2288 M used memory
                588 M active memory
                542 M free memory
                112 M buffer memory
                894 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Previously detected issues: ~ Under-voltage has occurred ~ Arm frequency capping has occurred ~ Throttling has occurred ~ Soft temperature limit has occurred
      Das zitierte sind die Hardware Probleme, und dazu noch jede Menge Software Probleme, die du hast.
      Lies dich bitte mal in die Doku ein, dazu ein paar kleine Linux Basics und installiere iobroker neu mit Bookworm 64bit, wie zur Zeit empfohlen.
      Du betreibst ein totes Betriebssystem mit etlichen Fehlern. ( root rechte, System EOL, usw.. )
      @Homoran
      Da braucht man kein komplettes iob diag mehr. Das Ding is fertich..
      J HomoranH 2 Antworten Letzte Antwort
        @Homoran
        jan_xx
        @neuschwansteini
        Bei Bookworm wird aber die USB Schnittstelle nicht mehr unterstützt habe ich irgendwo gelesen?
        Ich brauche die USB Geschichte, da hängt mein Victron Laderegler dran.
        • J jan_xx
          @neuschwansteini
          @jan_xx natuerlich wird bei Bookworm USB unterstuetzt..
            @Homoran
            @neuschwansteini sagte in IOBroker stürzt ab und alle Adapter starten neu:
            war das eben schon so drin?
            Dann Sorry, ging bei mir nur bis Zeile 17 und war nicht zu scrollen.
            • J jan_xx
              @wendy2702
                       Icon name: computer
                    Architecture: arm
              Docker          : false
              Kernel          : armv7l
              Userland        : 32 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              iobroker
              HOME=/home/iobroker
              iobroker
              HOME=/home/iobroker
              Desktop: 	LXDE-pi
              Terminal: 	x11
              *** MEMORY ***
              Swap:            99M         99M        0.0K
                       3837 M total memory
                       2288 M used memory
                        588 M active memory
                        542 M free memory
                        112 M buffer memory
                        894 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              Auch wenn jetzt genug RAM zur Verfügung staht, war das nicht immer so.
                jan_xx
                @neuschwansteini
                Ich habe mich schon sehr oft vor dem Update gescheut, da es damals schon eine ganze große Aktion war den USB Port zu überzeugen sich mit dem Laderegler zu unterhalten...
                Also wenn mein System fertig ist, werde ich wohl nicht drumherum kommen, vlt. sollte ich mir ein Zweitsystem aufbauen und dann langsam irgendwie umziehen. Der Raspi ist ja auch nicht unbedingt die Endlösung, dazu habe ich schon viel gelesen und einige fangen mit der Ärgerkiste garnicht erst an. Nutzt ihr ein NUC?
                HomoranH ? 2 Antworten Letzte Antwort
                  @homoran sagte in IOBroker stürzt ab und alle Adapter starten neu:
                  ist nur n halbes iob diag.. aber bei den Hardwareproblemen und dem verkorksten System ist sowieso neu machen angesagt.
                    jan_xx
                    irgendetwas müllt anscheinend die Kiste, aber das herauszufinden wird nicht einfach werden....
                    • J jan_xx
                      @neuschwansteini
                      es gibt viel Mist im Netz
                      läuft problemlos
                        läuft problemlos
                        jan_xx
                        @homoran wow👍
                        • J jan_xx
                          @neuschwansteini
                          @jan_xx
                          vor Updates darf man sich nicht scheuen, das ist der groesste Fehler.
                          Der Raspi ist schon gut, kommt halt drauf an, was man damit alles machen moechte.
                          Ist wie mit allem, erstmal die Anforderungen feststellen, dann schauen, was es gibt, das dem gerecht wird, und dann die beste Loesung auswaehlen.
                          Da wir nicht wissen, was deine Anforderungen sind, koennen wir hier nicht sagen, ob der Raspi gut oder schlecht ist..
                            @jan_xx
                            jan_xx
                            @neuschwansteini
                            ein stabiles System sind meine Anforderungen...
                            • J jan_xx
                              @neuschwansteini
                              @neuschwansteini
                              Das sind nicht deine Anforderungen, das soll das System mit/trotz deinen noch nicht formulierten Anforderungen erreichen.
                              • J jan_xx
                                @neuschwansteini
                                @neuschwansteini
                                Das ist keine Anforderung, das ist ein Ziel.
                                Es geht um dein Environment, was hast du alles zu steuern, regeln, tracken??
                                Wenn du nur eine Lampe und einen Sensor hast, dann reicht ein Raspi Zero.
                                Hast du ein Environment, wie bei mir mit 700 Devices und 250 Sensoren, 85 Instanzen, brauchste etwas maechtigere Hardware..
                                  @neuschwansteini
                                  jan_xx
                                  schrieb am zuletzt editiert von jan_xx
                                  Was meinst du damit, ich steuere und automatisiere einige Sachen im Haus, hierfür ist doch IObroker da.
                                  Ich möchte damit keine Fertigungslinie steuern.
                                  Also ich habe meiner Meinung nach schon nicht wenig an der Kiste hängen, 40 Adapter sind es bestimmt bald und
                                  ich habe sehr viele externe Hardware darin versucht zu vereinigen. Es läuft auch einiges an Regelung wegen PV und Verbrauchern damit ich alles selber verwende + Heizung wird auch sehr viel gesteuert.
                                  Wenn dann ein 16GB Raspi oder gleich ein NUC?
                                  (https://www.amazon.de/Raspberry-Starter-Kit-Netzteil-Gehäuse-Lüfter/dp/B0D9RBH6R6/ref=sr_1_1_sspa?adgrpid=71577759792&dib=eyJ2IjoiMSJ9.EIRWMNAsT_JPS2JI4yVop3_AT54DGyDI1Wi-wi24XSkwnO4DFKnyEk1U2HpnXOKDtriV2ETU6i302jA9UJzleM7dIoDHeRuXkFRJAb2qWtNRJgY1Nf8e0CRJagRTuKnq8w7-4Ik5QAxwPrGHbJYo7CtdjR8OoUduedPGExvqYWkSzQolp_WvTSZuCBUT2DvsophpJFqeA2NK4EbS3XKg2ln0-cuGzv7imnth8fr1pWk.cN3FL6xZOi5y0UVtKu7ytn7tZDHdZm_8BAaBo66YCCk&dib_tag=se&hvadid=353346583904&hvdev=c&hvlocphy=9042820&hvnetw=g&hvqmt=e&hvrand=17855096761886324403&hvtargid=kwd-822849820722&hydadcr=5455_1747176&keywords=raspi%2B5&mcid=db649754c7313dd2b423a7d1653694f9&qid=1743664008&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1)
                                  (https://www.amazon.de/dp/B0CNSYWHLR?aa_adgroupid=176791241272&aa_campaignid=22319457990&aa_creativeid=ad-737965899726_kwd-299901437200_dev-x_ext-&maas=maas_adg_api_586307528208015866_macro_1_36&ref_=aa_maas&smid=A24AW0P5HX7LW9&tag=maas&gad_source=1&gbraid=0AAAAAqv6X6gxqHXYMdMMdr6HuJsKADWRH&gclid=CjwKCAjwwLO_BhB2EiwAx2e-3857HzInQ2R4LIu9J_eiVMwZ6chBVVH9vvhnRUdpwBg9G6CqzWewxRoCHUIQAvD_BwE)
                                  HomoranH CodierknechtC 2 Antworten Letzte Antwort
                                  • J jan_xx
                                    @jan_xx Bitte tracking/affiliate Informationen aus den Links entfernen!
                                    das ist ohne strukturiertes Anforderungsprofil nicht zu sagen.
                                    Ich bin vom NUC zurück zum Pi.
                                    EDIT:
                                    Bitte keine nachträglichen Ergänzungen ohne Kennzeichnung
                                    • J jan_xx
                                      @wendy2702
                                               Icon name: computer
                                            Architecture: arm
                                      Docker          : false
                                      Kernel          : armv7l
                                      Userland        : 32 bit
                                      CPU threads: 4
                                      Current issues:
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      iobroker
                                      HOME=/home/iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      Desktop: 	LXDE-pi
                                      Terminal: 	x11
                                      *** MEMORY ***
                                      Swap:            99M         99M        0.0K
                                               3837 M total memory
                                               2288 M used memory
                                                588 M active memory
                                                542 M free memory
                                                112 M buffer memory
                                                894 M swap cache
                                                 99 M total swap
                                                 99 M used swap
                                                  0 M free swap
                                      Kernel : armv7l
                                      Userland : 32 bit
                                      Neuaufsetzen, diesmal als 64Bit-RaspberryOS12 Lite.
                                      Da stimmt was mit der Spannungsversorgung nicht.
                                      Desktop: LXDE-pi
                                      Da läuft ein Desktop mit. Ausschalten, bzw. bei der Neuinstallation gar nicht erst installieren.
                                        EDIT:
                                        jan_xx
                                        Wie du weißt ist das immer leichter gesagt als getan, als ich angefangen habe, wurde mal ein Licht ein und ausgeschaltet und jetzt habe ich PV Regelung, Heizung, Licht, Kleinere Automationen, u.s.w
                                        Es ist jedes Jahr etwas dazu gekommen und wo die Reise hin geht kann ich wirklich nicht sagen.
                                        • J jan_xx
                                          CodierknechtC Online
                                          Codierknecht
                                          einige Sachen
                                          Definiere einige.
                                          Interessant ist das was da zusätzlich läuft oder später laufen soll:
                                          • Eine Datenbank zur Speicherung historischer Daten
                                          • Grafana o.ä. für deren Aufbereitung und Anzeige
                                          • MotionEye, Frigate oder andere Video-Dienste
                                          Da kommt dann schnell etwas zusammen.
                                          Ein Pi kann da durchaus ausreichen. Allerdings ist die von Dir eingesetzte Variante mit nur 4 GB RAM bei Deinen 45 Instanzen jetzt schon am Anschlag.
                                          Ein NUC oder vergleichbarer Mini-PC mit 'ner N100 oder N150 CPU ist etwas leistungsfähiger.
                                          Zu beachten ist allerdings der Stromverbrauch. Mein Core i7 schlägt da schon ein ordentliches Loch in den Geldbeutel, falls man keine PV hat.
                                          HmIP|ZigBee|Tasmota|Unifi
                                          Zabbix Certified Specialist
