  5. PV Überschuss nutzen um 1,5KW und 3,0KW Heizstab zu schalten
    6.4k
17 Beiträge 2 Kommentatoren 1.5k Aufrufe 1 Beobachtet
  • S Spidermike
    so
      <value name="IF0">
        <block type="logic_compare" id="UQv[Rz^5f:#)fAqUWMk-">
          <field name="OP">NEQ</field>
          <value name="A">
            <block type="variables_get" id="K^Cr`lcToTn%,N+kEZ[s">
              <field name="VAR" id="9y5$f~sG5n39o=TlsnI_">heizstab2</field>
            </block>
          </value>
          <value name="B">
            <block type="get_value" id="3Yr2{GacZb_mhZ4^?jF*">
              <field name="OID">shelly.1.shelly1g3#3000W#1.Relay0.Switch</field>
            </block>
          </value>
        </block>
      </value>
      <statement name="DO0">
        <block type="control" id="D/q[T[3mSbu1ysV{VPjV">
          <value name="VALUE">
            <block type="variables_get" id=",[uX/yd,c(y.Gx~g[U#y">
            </block>
          </value>
        </block>
      </statement>
      <next>
        <block type="debug" id="KS{*7I7)yzeN1jB=6;V/">
          <field name="Severity">info</field>
          <value name="TEXT">
            <shadow type="text" id="KS:4~UZ{vccU~iTf-V_u">
            </shadow>
            <block type="text_join" id="5Y{~PghQ={@pOvAT^46;" inline="false">
              <mutation items="8"></mutation>
              <value name="ADD0">
                <block type="text" id="`0;1s$3.TKPa^lIjw~W4">
                  <field name="TEXT">Einspeisung:</field>
                </block>
              </value>
              <value name="ADD1">
                <block type="get_value" id="8z^$PnY|MP{gr{A#bPi.">
                  <field name="OID">plenticore.0.devices.local.ToGrid_P</field>
                </block>
              </value>
              <value name="ADD2">
                <block type="text" id="nlvwHcKhv@po6U57sDxA">
                  <field name="TEXT"> Netz-Bezug:</field>
                </block>
              </value>
              <value name="ADD3">
                <block type="get_value" id="EL:l7T_?7p#z;7DZZs6`">
                  <field name="OID">plenticore.0.devices.local.HomeGrid_P</field>
                </block>
              </value>
              <value name="ADD4">
                <block type="text" id="8R5CWhYs_y*4;ljCHQcR">
                  <field name="TEXT"> Heiz-Stufe:</field>
                </block>
              </value>
              <value name="ADD5">
                <block type="variables_get" id="(Oc3%bWXeM6!16qd]K7}">
                  <field name="VAR" id="(au?)v#|.A3h~W0?i*.n">heizstufe</field>
                </block>
              </value>
              <value name="ADD6">
                <block type="text" id="Y_gY|k^^bh44qU{VA%^z">
                  <field name="TEXT"> Boilertemp:</field>
                </block>
              </value>
              <value name="ADD7">
                <block type="get_value" id="s783,ESop@{W@u@|4o?r">
                  <field name="OID">mqtt.0.ESP_Easy.Sensor_1.temperature_oben</field>
                </block>
              </value>
            </block>
          </value>
        </block>
      </next>
    </block>
    @spidermike sagte: so
    Lässt sich nicht importieren!
    Zeige den unteren Blockly-Ausschnitt als Bild.
      Spidermike
      S paul53P 2 Antworten Letzte Antwort
      • S Spidermike
        Spidermike
        • S Spidermike
          @spidermike
          Den Debug-Block unter das Schalten von Heizstab1 schieben, denn der schaltet bei jeder Stufenänderung.
          Der gesteuerte Shelly für Heizstab1 ist offenbar falsch.
            @spidermike
            Spidermike
            schrieb am zuletzt editiert von Spidermike
            ja hatte ich schon gesehen und gegen den anderen Shelly geändert.
            ich sehe bei mir im script keine Geräte sondern nur den Datenpunkt
            komisch nur das er in deinen Bildern mir das Gerät sprich den Shelly anzeigt sonst wäre es mir nicht aufgefallen
            • S Spidermike
              Spidermike
              @spidermike
              hier noch ein versuch
              <block xmlns="https://developers.google.com/blockly/xml" type="debug" id="KS{*7I7)yzeN1jB=6;V/" x="-341.83333587646484" y="878">
                <value name="TEXT">
                  </shadow>
                    <value name="ADD0">
                      </block>
                    </value>
                    <value name="ADD1">
                      </block>
                    </value>
                    <value name="ADD2">
                      </block>
                    </value>
                    <value name="ADD3">
                      </block>
                    </value>
                    <value name="ADD4">
                      </block>
                    </value>
                    <value name="ADD5">
                      </block>
                    </value>
                    <value name="ADD6">
                      </block>
                    </value>
                    <value name="ADD7">
                      </block>
                    </value>
                  </block>
                </value>
              </block>
              • S Spidermike
                @spidermike
                  <value name="TEXT">
                    </shadow>
                      <value name="ADD0">
                        </block>
                      </value>
                      <value name="ADD1">
                        </block>
                      </value>
                      <value name="ADD2">
                        </block>
                      </value>
                      <value name="ADD3">
                        </block>
                      </value>
                      <value name="ADD4">
                        </block>
                      </value>
                      <value name="ADD5">
                        </block>
                      </value>
                      <value name="ADD6">
                        </block>
                      </value>
                      <value name="ADD7">
                        </block>
                      </value>
                    </block>
                  </value>
                </block>
                @spidermike sagte: hier noch ein versuch
                Das ist nur der Debug-Block.
                @spidermike sagte in PV Überschuss nutzen um 1,5KW und 3,0KW Heizstab zu schalten:
                Wenn der Datenpunkt existiert, wird in Blockly der Name dargestellt, andernfalls die ID.
                  Spidermike
                  @paul53 ist das jetzt soweit ok?
                  • S Spidermike
                    @spidermike sagte: ist das jetzt soweit ok?
                    Kann ich nicht beurteilen, denn der Export enthält nur den Debug-Block:
                    S 3 Antworten Letzte Antwort
                      Spidermike
                      @paul53 ok ich werde es morgen sehen was passiert und melde mich dann nochmal wenn ich es ok ist oder probleme gibt
                        Spidermike
                        @paul53 ich wollte mich mal wieder melden und nach einer gewissen testphase ein kleines Feedback geben.
                        das Script funktioniert jetzt wieder super und schaltet meine Heizstäbe wunderbar,
                        Danke für Deine Hilfe
                          Spidermike
                          @paul53 hallo,
                          nach dem Shelly adapter upate schaltet das script die zwei shellys nicht mehr obwohl die datenpunkte vorhanden sind.
                          was kann das jetzt wieder sein?
                          gruß Maik
