  4. Nach Stromausfall startet iobroker nicht mehr
    1.9k
9 Beiträge 3 Kommentatoren 1.6k Aufrufe
  • P Offline
    pingps
    leider ist der iobroker wieder zerschossen.
    Nun habe ich eine USV installiert um nicht gleich wieder in die Stromausfallfalle zu tappen. Jetzt lohnt sich auch wieder den iobroker zu reparieren. Vielleicht kann mir jemand helfen:
    root@raspberrypi:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js --logs
    2018-01-25 18:45:08.055 - info: host.raspberrypi iobroker.js-controller version 1.2.0 js-controller starting
    2018-01-25 18:45:08.082 - info: host.raspberrypi Copyright (c) 2014-2017 bluefox, hobbyquaker
    2018-01-25 18:45:08.089 - info: host.raspberrypi hostname: raspberrypi, node: v0.12.6
    2018-01-25 18:45:08.093 - info: host.raspberrypi ip addresses: 192.168.0.9 fe80::cf32:e280:97e3:19af
    2018-01-25 18:45:08.656 - info: host.raspberrypi inMem-states listening on port 9000
    2018-01-25 18:45:09.616 - info: host.raspberrypi inMem-objects listening on port 9001
    2018-01-25 18:45:09.652 - info: host.raspberrypi InMemoryDB connected
    2018-01-25 18:45:09.749 - info: host.raspberrypi 30 instances found
    host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.hm-rpc.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.hm-rega.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.rpi.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.fritzbox.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-metro.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.sony-bravia.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.mqtt.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.amazon-dash.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-weather.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.vis-map.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.tr-064.1" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.tr-064.2" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.hm-rpc.2" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.hm-rpc.3" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.mobile.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.sql.1" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.mysensors.0" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.javascript.1" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.hm-rpc.4" for host "raspberrypi"
    host.raspberrypi check instance "system.adapter.admin.1" for host "raspberrypi"
    2018-01-25 18:45:09.813 - info: host.raspberrypi starting 18 instances
    2018-01-25 18:45:09.899 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1066
    ^C2018-01-25 18:45:11.720 - info: host.raspberrypi received SIGINT
    2018-01-25 18:45:11.797 - warn: host.raspberrypi instance system.adapter.admin.0 terminated due to SIGINT
    2018-01-25 18:45:11.799 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code null ()
    2018-01-25 18:45:11.801 - info: host.raspberrypi All instances are stopped.
    2018-01-25 18:45:12.424 - info: host.raspberrypi terminated
    root@raspberrypi:/opt/iobroker# cls
    -bash: cls: command not found
    root@raspberrypi:/opt/iobroker# clear
    2018-01-25 18:45:33.861 - info: host.raspberrypi iobroker.js-controller version 1.2.0 js-controller starting
    2018-01-25 18:45:33.889 - info: host.raspberrypi Copyright (c) 2014-2017 bluefox, hobbyquaker
    2018-01-25 18:45:33.895 - info: host.raspberrypi hostname: raspberrypi, node: v0.12.6
    2018-01-25 18:45:33.899 - info: host.raspberrypi ip addresses: 192.168.0.9 fe80::cf32:e280:97e3:19af
    2018-01-25 18:45:34.331 - info: host.raspberrypi inMem-states listening on port 9000
    2018-01-25 18:45:35.254 - info: host.raspberrypi inMem-objects listening on port 9001
    2018-01-25 18:45:35.290 - info: host.raspberrypi InMemoryDB connected
    2018-01-25 18:45:35.389 - info: host.raspberrypi 30 instances found
    2018-01-25 18:45:35.448 - info: host.raspberrypi starting 18 instances
    2018-01-25 18:45:35.563 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1083
    /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/boom/lib/index.js:5
    const Hoek = require('hoek');
    SyntaxError: Use of const in strict mode.
    at exports.runInThisContext (vm.js:73:16)
    at Module._compile (module.js:443:25)
    at Object.Module._extensions..js (module.js:478:10)
    at Module.load (module.js:355:32)
    at Function.Module._load (module.js:310:12)
    at Module.require (module.js:365:17)
    at require (module.js:384:17)
    at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/hawk/lib/index.js:5:33)
    at Module._compile (module.js:460:26)
    ! 2018-01-25 18:45:37.960 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/boom/lib/index.js:5
    2018-01-25 18:45:37.962 - error: Caught by controller[0]: const Hoek = require('hoek');
    2018-01-25 18:45:37.964 - error: Caught by controller[0]: ^^^^^
    2018-01-25 18:45:37.965 - error: Caught by controller[0]: SyntaxError: Use of const in strict mode.
    2018-01-25 18:45:37.966 - error: Caught by controller[0]: at exports.runInThisContext (vm.js:73:16)
    2018-01-25 18:45:37.967 - error: Caught by controller[0]: at Module._compile (module.js:443:25)
    2018-01-25 18:45:37.968 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:478:10)
    2018-01-25 18:45:37.969 - error: Caught by controller[0]: at Module.load (module.js:355:32)
    2018-01-25 18:45:37.971 - error: Caught by controller[0]: at Function.Module._load (module.js:310:12)
    2018-01-25 18:45:37.972 - error: Caught by controller[0]: at Module.require (module.js:365:17)
    2018-01-25 18:45:37.974 - error: Caught by controller[0]: at require (module.js:384:17)
    2018-01-25 18:45:37.975 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/hawk/lib/index.js:5:33)
    2018-01-25 18:45:37.976 - error: Caught by controller[0]: at Module._compile (module.js:460:26)
    2018-01-25 18:45:37.978 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:478:10)
    2018-01-25 18:45:37.980 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 1 ()
    2018-01-25 18:45:37.981 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2018-01-25 18:45:39.562 - info: host.raspberrypi instance system.adapter.admin.1 started with pid 1088
    ! 2018-01-25 18:45:41.977 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/boom/lib/index.js:5
    2018-01-25 18:45:41.979 - error: Caught by controller[0]: const Hoek = require('hoek');
    2018-01-25 18:45:41.980 - error: Caught by controller[0]: ^^^^^
    2018-01-25 18:45:41.982 - error: Caught by controller[0]: SyntaxError: Use of const in strict mode.
    2018-01-25 18:45:41.983 - error: Caught by controller[0]: at exports.runInThisContext (vm.js:73:16)
    2018-01-25 18:45:41.984 - error: Caught by controller[0]: at Module._compile (module.js:443:25)
    2018-01-25 18:45:41.985 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:478:10)
    2018-01-25 18:45:41.986 - error: Caught by controller[0]: at Module.load (module.js:355:32)
    2018-01-25 18:45:41.988 - error: Caught by controller[0]: at Function.Module._load (module.js:310:12)
    2018-01-25 18:45:41.989 - error: Caught by controller[0]: at Module.require (module.js:365:17)
    2018-01-25 18:45:41.990 - error: Caught by controller[0]: at require (module.js:384:17)
    2018-01-25 18:45:41.992 - error: Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/node_modules/request/node_modules/hawk/lib/index.js:5:33)
    2018-01-25 18:45:41.994 - error: Caught by controller[0]: at Module._compile (module.js:460:26)
    2018-01-25 18:45:41.996 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:478:10)
    2018-01-25 18:45:41.997 - error: host.raspberrypi instance system.adapter.admin.1 terminated with code 1 ()
    2018-01-25 18:45:41.999 - info: host.raspberrypi Restart adapter system.adapter.admin.1 because enabled
    2018-01-25 18:45:43.491 - info: host.raspberrypi instance system.adapter.web.0 started with pid 1093
    ^C2018-01-25 18:45:43.705 - info: host.raspberrypi received SIGINT
    2018-01-25 18:45:43.742 - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGINT
    2018-01-25 18:45:43.746 - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
    2018-01-25 18:45:43.749 - info: host.raspberrypi All instances are stopped.
    2018-01-25 18:45:43.919 - info: host.raspberrypi terminated
    root@raspberrypi:/opt/iobroker#</anonymous></anonymous></anonymous></anonymous>
    :twisted:
    Die Ausführung wurde abgebrochen, nachdem das wohl eine Endlosschleife ist.
    Vielen Dank im Voraus
    Uli
    MOD-Edit by eric2905, Spoiler- und Code-Tags gesetzt
    • wendy2702W Offline
      wendy2702W Offline
      Kannst du das logfile in Spoiler und Code Tags setzen!
      Was genau hast du denn da versucht zu machen?
      Was sagt das iobroker logfile?
      Läuft irgendetwas von iobroker zurzeit?
      • P Offline
        pingps
        iobroker startet nicht mehr, deshalb habe ich die Seite http://www.iobroker.net/docu/?page_id=3928&lang=de versucht durchzuarbeiten.
        es kommt einfach "this side can be reached" nach aufruf von port 8081. Auch bei http://192.168.0.9:8082/vis/edit.html kommt nur "no connection".
        Habe noch update und upgrade gestartet und dann die obige Seite versucht durchzuarbeiten.
        Wie gesagt: Stromausfall bzw. Wackelkontakt in der Stromzuführung.
        achja: es läuft nichts von iobroker
          wendy2702W Offline
          Kann in deinen logs nichts von der Seite finden :(
          Vielleicht kannst du noch ein paar infos zum verwendeten System (HW/SW) bereitstellen und folgende eingaben mit den dazugehörigen ausgaben:
          ps -A | grep iobroker
          cd /opt/iobroker
          iobroker start
          Wenn das nicht klappt bitte direkt die Ausgabe dazu.
          cd /opt/iobroker
          So wie ich das sehe startet iobroker noch aber du hast zwei Instanzen vom admin installiert:````
          Ist das richtig das du zwei admin Instanzen benutzt?
          • eric2905E Offline
            eric2905E Offline
            eric2905
            Node v0.12.6 ist ein bisserl alt. ;)
            Gruß,
            Eric
            • P Offline
              pingps
              habe wohl versucht, einen zweiten admin zu starten, aber das Ergebnis war nicht erfolgsversprechend.
              Also erstmal die Ausgaben:
              ! root@raspberrypi:/opt/iobroker# ps -A | grep iobroker
              ! root@raspberrypi:/opt/iobroker# cd /opt/iobroker
              ! root@raspberrypi:/opt/iobroker# iobroker start
              ! Starting iobroker controller daemon…
              ! iobroker controller daemon started. PID: 1141
              ! root@raspberrypi:/opt/iobroker# node node_modules/iobroker.js-controller/controller.js --logs
              ! 2018-01-25 19:44:01.368 - info: host.raspberrypi iobroker.js-controller version 1.2.0 js-controller starting
              ! 2018-01-25 19:44:01.401 - info: host.raspberrypi Copyright (c) 2014-2017 bluefox, hobbyquaker
              ! 2018-01-25 19:44:01.409 - info: host.raspberrypi hostname: raspberrypi, node: v0.12.6
              ! 2018-01-25 19:44:01.413 - info: host.raspberrypi ip addresses: 192.168.0.9 fe80::cf32:e280:97e3:19af
              ! 2018-01-25 19:44:02.036 - info: host.raspberrypi inMem-states listening on port 9000
              ! 2018-01-25 19:44:03.047 - info: host.raspberrypi inMem-objects listening on port 9001
              ! 2018-01-25 19:44:03.085 - error: Another instance is running or some application uses port!
              ! 2018-01-25 19:44:03.087 - error: uncaught exception: listen EADDRINUSE
              ! 2018-01-25 19:44:03.102 - info: host.raspberrypi terminated
              ! 2018-01-25 19:44:03.134 - info: iobroker _restart
              ! 2018-01-25 19:44:03.198 - info: host.raspberrypi InMemoryDB connected
              ! 2018-01-25 19:44:03.309 - info: host.raspberrypi 30 instances found
              ! host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.hm-rpc.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.hm-rega.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.rpi.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.history.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.fritzbox.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.vis-metro.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.sony-bravia.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.mqtt.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.amazon-dash.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.vis-weather.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.vis-map.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.tr-064.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.tr-064.1" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.tr-064.2" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.hm-rpc.2" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.hm-rpc.3" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.mobile.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.sql.1" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.mysensors.0" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.javascript.1" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.hm-rpc.4" for host "raspberrypi"
              ! host.raspberrypi check instance "system.adapter.admin.1" for host "raspberrypi"
              ! 2018-01-25 19:44:03.407 - info: host.raspberrypi starting 18 instances
              ! 2018-01-25 19:44:03.523 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1361
              ! listen EADDRINUSE
              ! Error: listen EADDRINUSE
              ! at exports._errnoException (util.js:746:11)
              ! at Server._listen2 (net.js:1156:14)
              ! at listen (net.js:1182:10)
              ! at net.js:1280:9
              ! at dns.js:85:18
              ! at process._tickCallback (node.js:355:11)
              ! at Function.Module.runMain (module.js:503:11)
              ! at startup (node.js:129:16)
              ! at node.js:814:3
              bin hier leider nicht der linux guru und kenne nur die oberflächlichen Befehle…. 8-)
              HW: Raspberry Pi 3
              • P Offline
                pingps
                so. nun schon besser. Habe den Node v0.12.6 upgedatet.
                Jetzt startet iobroker wieder. Und ich kann das logfile beisteuern. :P
                ! Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
                ! javascript.0 2018-01-25 20:14:25.428 info system.adapter.admin.0: logging true
                ! discovery.0 2018-01-25 20:14:25.406 info system.adapter.admin.0: logging true
                ! mysensors.0 2018-01-25 20:14:25.419 info system.adapter.admin.0: logging true
                ! ping.0 2018-01-25 20:14:25.418 info system.adapter.admin.0: logging true
                ! hm-rpc.4 2018-01-25 20:14:25.414 info system.adapter.admin.0: logging true
                ! hm-rpc.2 2018-01-25 20:14:25.411 info system.adapter.admin.0: logging true
                ! admin.0 2018-01-25 20:14:25.401 info system.adapter.admin.0: logging true
                ! history.0 2018-01-25 20:14:25.404 info system.adapter.admin.0: logging true
                ! rpi.0 2018-01-25 20:14:25.398 info system.adapter.admin.0: logging true
                ! hm-rpc.0 2018-01-25 20:14:25.395 info system.adapter.admin.0: logging true
                ! hm-rega.0 2018-01-25 20:14:25.396 info system.adapter.admin.0: logging true
                ! admin.1 2018-01-25 20:14:25.387 info system.adapter.admin.0: logging true
                ! web.0 2018-01-25 20:14:25.384 info system.adapter.admin.0: logging true
                ! admin.0 2018-01-25 20:14:25.372 info Change log subscriber state: true
                ! javascript.0 2018-01-25 20:14:00.551 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.Messung.P2, state=35.73)
                ! javascript.0 2018-01-25 20:14:00.550 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.Messung.P1, state=61.03)
                ! javascript.0 2018-01-25 20:14:00.548 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.Messung.timestamp, state='2018-01-25 20:09:23')
                ! javascript.0 2018-01-25 20:14:00.538 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.country, state='DE')
                ! javascript.0 2018-01-25 20:14:00.538 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.lon, state=9.982)
                ! javascript.0 2018-01-25 20:14:00.536 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.lat, state=48.755)
                ! javascript.0 2018-01-25 20:14:00.536 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.location, state='4065')
                ! javascript.0 2018-01-25 20:14:00.535 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.sensor_type, state='SDS011 by Nova Fitness')
                ! javascript.0 2018-01-25 20:14:00.534 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.sensor_id, state='8044')
                ! javascript.0 2018-01-25 20:14:00.523 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.json, state='[{'sensordatavalues':[{'value_type':'P1','id':1563507104,'value':'61.03'},{'value_type':'P2','id':1563507105,'value':'35.73'}],'id':719506649,'sensor':{'id':8044,'pin':'1','sensor_type':{'name':'SDS011','id':14,'manufacturer':'Nova Fitness'}},'timestamp':'2018-01-25 20:09:23','location':{'altitude':'653.8','latitude':'48.755','id':4065,'longitude':'9.982','country':'DE'},'sampling_rate':null},{'sensordatavalues':[{'value_type':'P1','id':1563520525,'value':'647.22'},{'value_type':'P2','id':1563520526,'value':'330.50'}],'id':719512998,'sensor':{'id':8044,'pin':'1','sensor_type':{'name':'SDS011','id':14,'manufacturer':'Nova Fitness'}},'timestamp':'2018-01-25 20:11:50','location':{'altitude':'653.8','latitude':'48.755','id':4065,'longitude':'9.982','country':'DE'},'sampling_rate':null}]')
                ! javascript.0 2018-01-25 20:14:00.193 info script.js.common.Feinstaub.8044: Luftdaten aktualisiert
                ! admin.1 2018-01-25 20:13:22.341 info Subscribe on all states again
                ! javascript.0 2018-01-25 20:13:15.064 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.Messung.P2, state=35.73)
                ! javascript.0 2018-01-25 20:13:15.063 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.Messung.P1, state=61.03)
                ! javascript.0 2018-01-25 20:13:15.062 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.Messung.timestamp, state='2018-01-25 20:09:23')
                ! javascript.0 2018-01-25 20:13:15.062 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.country, state='DE')
                ! javascript.0 2018-01-25 20:13:15.061 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.lon, state=9.982)
                ! javascript.0 2018-01-25 20:13:15.060 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.lat, state=48.755)
                ! javascript.0 2018-01-25 20:13:15.060 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.location, state='4065')
                ! javascript.0 2018-01-25 20:13:15.059 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.sensor_type, state='SDS011 by Nova Fitness')
                ! javascript.0 2018-01-25 20:13:15.058 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.sensor_id, state='8044')
                ! javascript.0 2018-01-25 20:13:15.054 info script.js.common.Feinstaub.8044: setForeignState(id=javascript.0.Luftdaten.8044.json, state='[{'sensordatavalues':[{'value_type':'P1','id':1563507104,'value':'61.03'},{'value_type':'P2','id':1563507105,'value':'35.73'}],'id':719506649,'sensor':{'id':8044,'pin':'1','sensor_type':{'name':'SDS011','id':14,'manufacturer':'Nova Fitness'}},'timestamp':'2018-01-25 20:09:23','location':{'altitude':'653.8','latitude':'48.755','id':4065,'longitude':'9.982','country':'DE'},'sampling_rate':null},{'sensordatavalues':[{'value_type':'P1','id':1563520525,'value':'647.22'},{'value_type':'P2','id':1563520526,'value':'330.50'}],'id':719512998,'sensor':{'id':8044,'pin':'1','sensor_type':{'name':'SDS011','id':14,'manufacturer':'Nova Fitness'}},'timestamp':'2018-01-25 20:11:50','location':{'altitude':'653.8','latitude':'48.755','id':4065,'longitude':'9.982','country':'DE'},'sampling_rate':null}]')
                ! javascript.0 2018-01-25 20:13:14.845 info script.js.common.Feinstaub.8044: Luftdaten aktualisiert
                ! javascript.0 2018-01-25 20:13:13.212 info script.js.common.Feinstaub.8044: registered 1 subscription and 1 schedule
                ! javascript.0 2018-01-25 20:13:13.211 info script.js.common.Feinstaub.8044: subscribe: {'pattern':{'id':'javascript.0.Luftdaten.8044.forceRefresh','change':'ne'},'name':'script.js.common.Feinstaub.8044'}
                ! javascript.0 2018-01-25 20:13:13.207 info script.js.common.Feinstaub.8044: setTimeout(ms=1500)
                ! javascript.0 2018-01-25 20:13:13.192 info script.js.common.Feinstaub.8044: schedule(cron=14,29,44,59 * * * *)
                ! javascript.0 2018-01-25 20:13:13.118 info Start javascript script.js.common.Feinstaub.8044
                ! javascript.0 2018-01-25 20:13:12.959 info received all objects
                ! javascript.0 2018-01-25 20:13:10.246 info received all states
                ! javascript.0 2018-01-25 20:13:07.118 info requesting all objects
                ! javascript.0 2018-01-25 20:13:07.111 info requesting all states
                ! javascript.0 2018-01-25 20:13:07.108 error Cannot install npm packet: owlintuiton
                ! javascript.0 2018-01-25 20:13:07.107 error Cannot install owlintuiton: 1
                ! javascript.0 2018-01-25 20:13:07.089 error /npm-debug.log
                ! javascript.0 2018-01-25 20:13:07.087 error npm ERR!
                ! javascript.0 2018-01-25 20:13:07.087 error npm ERR! Please include the following file with any support request:
                ! javascript.0 2018-01-25 20:13:07.086 error
                ! javascript.0 2018-01-25 20:13:07.053 error 404 tarball, folder, http url, or git url.
                ! javascript.0 2018-01-25 20:13:07.052 error npm ERR!
                ! javascript.0 2018-01-25 20:13:07.052 error npm ERR! 404 Note that you can also install from a
                ! javascript.0 2018-01-25 20:13:07.051 error npm ERR! 404
                ! javascript.0 2018-01-25 20:13:07.051 error ERR! 404 It was specified as a dependency of 'iobroker.javascript'
                ! javascript.0 2018-01-25 20:13:07.050 error npm
                ! javascript.0 2018-01-25 20:13:07.050 error npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                ! javascript.0 2018-01-25 20:13:07.050 error npm ERR! 404 'owlintuiton' is not in the npm registry.
                ! javascript.0 2018-01-25 20:13:07.048 error npm ERR! 404
                ! javascript.0 2018-01-25 20:13:07.048 error ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/owlintuiton
                ! javascript.0 2018-01-25 20:13:07.047 error npm
                ! javascript.0 2018-01-25 20:13:07.042 error ERR! code E404
                ! javascript.0 2018-01-25 20:13:07.041 error npm
                ! javascript.0 2018-01-25 20:13:07.041 error npm v2.11.2
                ! javascript.0 2018-01-25 20:13:07.039 error npm ERR!
                ! javascript.0 2018-01-25 20:13:07.039 error ERR! node v0.12.6
                ! javascript.0 2018-01-25 20:13:07.038 error npm
                ! javascript.0 2018-01-25 20:13:07.034 error ERR! argv '/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'owlintuiton' '–production' '--prefix' '/opt/iobroker/node_modules/iobroker.javascript'
                ! javascript.0 2018-01-25 20:13:07.033 error npm
                ! javascript.0 2018-01-25 20:13:07.030 error Linux 4.9.35-v7+
                ! javascript.0 2018-01-25 20:13:07.029 error ERR!
                ! javascript.0 2018-01-25 20:13:07.027 error
                ! javascript.0 2018-01-25 20:13:07.024 error npm
                ! javascript.0 2018-01-25 20:13:01.010 info npm install owlintuiton --production --prefix '/opt/iobroker/node_modules/iobroker.javascript' (System call)
                ! javascript.0 2018-01-25 20:13:01.008 error Cannot install owlintuiton: 1
                ! javascript.0 2018-01-25 20:13:00.999 error /npm-debug.log
                ! javascript.0 2018-01-25 20:13:00.984 error npm ERR!
                ! javascript.0 2018-01-25 20:13:00.984 error npm ERR! Please include the following file with any support request:
                ! javascript.0 2018-01-25 20:13:00.983 error
                ! javascript.0 2018-01-25 20:13:00.951 error 404 tarball, folder, http url, or git url.
                ! javascript.0 2018-01-25 20:13:00.949 error npm ERR!
                ! javascript.0 2018-01-25 20:13:00.949 error npm ERR! 404 Note that you can also install from a
                ! javascript.0 2018-01-25 20:13:00.948 error npm ERR! 404
                ! javascript.0 2018-01-25 20:13:00.948 error npm ERR! 404 It was specified as a dependency of 'iobroker.javascript'
                ! javascript.0 2018-01-25 20:13:00.947 error npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                ! javascript.0 2018-01-25 20:13:00.947 error npm ERR! 404 'owlintuiton' is not in the npm registry.
                ! javascript.0 2018-01-25 20:13:00.946 error npm ERR! 404
                ! javascript.0 2018-01-25 20:13:00.946 error ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/owlintuiton
                ! javascript.0 2018-01-25 20:13:00.944 error npm
                ! javascript.0 2018-01-25 20:13:00.939 error code E404
                ! javascript.0 2018-01-25 20:13:00.938 error npm ERR!
                ! javascript.0 2018-01-25 20:13:00.937 error npm ERR! npm v2.11.2
                ! javascript.0 2018-01-25 20:13:00.937 error v0.12.6
                ! javascript.0 2018-01-25 20:13:00.935 error npm ERR! node
                ! javascript.0 2018-01-25 20:13:00.933 error ERR! argv '/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'owlintuiton' '--production' '--prefix' '/opt/iobroker/node_modules/iobroker.javascript'
                ! javascript.0 2018-01-25 20:13:00.930 error npm
                ! javascript.0 2018-01-25 20:13:00.928 error Linux 4.9.35-v7+
                ! javascript.0 2018-01-25 20:13:00.926 error ERR!
                ! javascript.0 2018-01-25 20:13:00.924 error
                ! javascript.0 2018-01-25 20:13:00.921 error npm
                ! hm-rpc.4 2018-01-25 20:12:56.165 info Connected
                ! hm-rpc.4 2018-01-25 20:12:56.155 info new CUxD devices/channels after filter: 0
                ! hm-rpc.4 2018-01-25 20:12:56.102 info binrpc -> listDevices 36
                ! hm-rpc.4 2018-01-25 20:12:55.152 info binrpc client is trying to connect to 192.168.0.34:8701 with ['xmlrpc_bin://192.168.0.9:18701','hm-rpc.4']
                ! hm-rpc.4 2018-01-25 20:12:55.149 info binrpc server is trying to listen on 192.168.0.9:18701
                ! hm-rpc.4 2018-01-25 20:12:54.617 info starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.9.4
                ! javascript.0 2018-01-25 20:12:53.701 info npm install owlintuiton –production --prefix '/opt/iobroker/node_modules/iobroker.javascript' (System call)
                ! javascript.0 2018-01-25 20:12:53.699 error Cannot install owlintuiton: 1
                ! javascript.0 2018-01-25 20:12:53.673 error npm ERR! /npm-debug.log
                ! javascript.0 2018-01-25 20:12:53.671 error npm ERR! Please include the following file with any support request:
                ! javascript.0 2018-01-25 20:12:53.670 error
                ! javascript.0 2018-01-25 20:12:53.628 error 404 tarball, folder, http url, or git url.
                ! javascript.0 2018-01-25 20:12:53.616 error ERR!
                ! javascript.0 2018-01-25 20:12:53.614 error npm
                ! javascript.0 2018-01-25 20:12:53.614 error npm ERR! 404 Note that you can also install from a
                ! javascript.0 2018-01-25 20:12:53.608 error npm ERR! 404 It was specified as a dependency of 'iobroker.javascript'
                ! javascript.0 2018-01-25 20:12:53.607 error npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                ! javascript.0 2018-01-25 20:12:53.607 error npm ERR! 404 'owlintuiton' is not in the npm registry.
                ! javascript.0 2018-01-25 20:12:53.607 error 404
                ! javascript.0 2018-01-25 20:12:53.605 error npm ERR!
                ! javascript.0 2018-01-25 20:12:53.605 error ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/owlintuiton
                ! javascript.0 2018-01-25 20:12:53.603 error npm
                ! javascript.0 2018-01-25 20:12:53.597 error code E404
                ! javascript.0 2018-01-25 20:12:53.596 error npm ERR!
                ! javascript.0 2018-01-25 20:12:53.594 error npm ERR! npm v2.11.2
                ! javascript.0 2018-01-25 20:12:53.593 error npm ERR! node v0.12.6
                ! javascript.0 2018-01-25 20:12:53.591 error ERR! argv '/usr/local/bin/node' '/usr/local/bin/npm' 'install' 'owlintuiton' '--production' '--prefix' '/opt/iobroker/node_modules/iobroker.javascript'
                ! javascript.0 2018-01-25 20:12:53.587 error npm
                ! javascript.0 2018-01-25 20:12:53.584 error Linux 4.9.35-v7+
                ! javascript.0 2018-01-25 20:12:53.583 error ERR!
                ! javascript.0 2018-01-25 20:12:53.581 error
                ! javascript.0 2018-01-25 20:12:53.578 error npm
                ! host.raspberrypi 2018-01-25 20:12:52.274 info instance system.adapter.hm-rpc.4 started with pid 986
                ! mysensors.0 2018-01-25 20:12:50.857 info starting. Version 1.0.10 in /opt/iobroker/node_modules/iobroker.mysensors, node: v8.9.4
                ! host.raspberrypi 2018-01-25 20:12:48.263 info instance system.adapter.mysensors.0 started with pid 976
                ! javascript.0 2018-01-25 20:12:44.515 info npm install owlintuiton --production --prefix '/opt/iobroker/node_modules/iobroker.javascript' (System call)
                ! javascript.0 2018-01-25 20:12:44.478 info starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.9.4
                ! host.raspberrypi 2018-01-25 20:12:40.263 info instance system.adapter.javascript.0 started with pid 954
                ! hm-rpc.2 2018-01-25 20:12:40.262 info Connected
                ! hm-rpc.2 2018-01-25 20:12:39.682 info binrpc -> 285 devices
                ! hm-rpc.2 2018-01-25 20:12:39.624 info binrpc <- listDevices ['hm-rpc.2']
                ! hm-rpc.2 2018-01-25 20:12:39.601 info binrpc <- system.listMethods ['hm-rpc.2']
                ! hm-rpc.2 2018-01-25 20:12:39.342 info binrpc client is trying to connect to 192.168.0.34:2001 with ['xmlrpc_bin://192.168.0.9:12001','hm-rpc.2']
                ! hm-rpc.2 2018-01-25 20:12:39.340 info binrpc server is trying to listen on 192.168.0.9:12001
                ! hm-rpc.2 2018-01-25 20:12:38.585 info starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.9.4
                ! host.raspberrypi 2018-01-25 20:12:36.259 info instance system.adapter.hm-rpc.2 started with pid 930
                ! ping.0 2018-01-25 20:12:34.359 info starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ping, node: v8.9.4
                ! host.raspberrypi 2018-01-25 20:12:32.243 info instance system.adapter.ping.0 started with pid 918
                ! discovery.0 2018-01-25 20:12:30.423 info starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.discovery, node: v8.9.4
                ! host.raspberrypi 2018-01-25 20:12:28.704 info instance system.adapter.vis.0 terminated while should be started once
                ! host.raspberrypi 2018-01-25 20:12:28.248 info instance system.adapter.discovery.0 started with pid 908
                ! vis.0 2018-01-25 20:12:22.760 info vis license is OK.
                ! vis.0 2018-01-25 20:12:22.417 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.vis, node: v8.9.4
                ! admin.1 2018-01-25 20:12:21.484 info Unsubscribe from all states, except system's, because over 3 seconds the number of events is over 200 (in last second 0)
                ! hm-rega.0 2018-01-25 20:12:16.533 info got state values
                ! hm-rega.0 2018-01-25 20:12:15.669 info request state values
                ! hm-rega.0 2018-01-25 20:12:15.666 info deleted 0 variables
                ! hm-rega.0 2018-01-25 20:12:15.665 info added/updated 50 variables
                ! hm-rega.0 2018-01-25 20:12:15.175 info got 50 variables
                ! hm-rega.0 2018-01-25 20:12:13.723 info deleted 0 programs
                ! hm-rega.0 2018-01-25 20:12:13.722 info added/updated 68 programs
                ! hm-rega.0 2018-01-25 20:12:13.492 info got 68 programs
                ! hm-rega.0 2018-01-25 20:12:13.430 info renamed hm-rpc.0.OEQ1269825.1.ERROR_SMOKE_CHAMBER-1_ALARM to 'HM-Sec-SD-2 OEQ1269825:1.ERROR_SMOKE_CHAMBER-1_ALARM'
                ! hm-rega.0 2018-01-25 20:12:13.418 info renamed hm-rpc.1.CUX2800001 to 'Min-timer'
                ! hm-rega.0 2018-01-25 20:12:13.404 info renamed hm-rpc.1.CUX2800001.0 to 'Min-timer:0'
                ! hm-rega.0 2018-01-25 20:12:13.391 info renamed hm-rpc.1.CUX2800001.1 to 'Min-timer:1'
                ! hm-rega.0 2018-01-25 20:12:13.379 info renamed hm-rpc.1.CUX2800001.2 to 'Heizungstimer:2'
                ! hm-rega.0 2018-01-25 20:12:13.365 info renamed hm-rpc.1.CUX2800001.3 to 'Heizungstimer:3'
                ! hm-rega.0 2018-01-25 20:12:13.352 info renamed hm-rpc.1.CUX2800001.4 to 'Heizungstimer:4'
                ! hm-rega.0 2018-01-25 20:12:13.340 info renamed hm-rpc.1.CUX2800001.5 to 'Heizungstimer:5'
                ! hm-rega.0 2018-01-25 20:12:13.326 info renamed hm-rpc.1.CUX2800001.6 to 'Heizungstimer:6'
                ! hm-rega.0 2018-01-25 20:12:13.313 info renamed hm-rpc.1.CUX2800001.7 to 'Heizungstimer:7'
                ! hm-rega.0 2018-01-25 20:12:13.299 info renamed hm-rpc.1.CUX2800001.8 to 'Heizungstimer:8'
                ! hm-rega.0 2018-01-25 20:12:13.285 info renamed hm-rpc.1.CUX2800001.9 to 'Heizungstimer:9'
                ! hm-rega.0 2018-01-25 20:12:13.272 info renamed hm-rpc.1.CUX2800001.10 to 'Heizungstimer:10'
                ! hm-rega.0 2018-01-25 20:12:13.259 info renamed hm-rpc.1.CUX2800001.11 to 'Heizungstimer:11'
                ! hm-rega.0 2018-01-25 20:12:13.246 info renamed hm-rpc.1.CUX2800001.12 to 'Heizungstimer:12'
                ! hm-rega.0 2018-01-25 20:12:13.235 info renamed hm-rpc.1.CUX2800001.13 to 'Heizungstimer:13'
                ! hm-rega.0 2018-01-25 20:12:13.222 info renamed hm-rpc.1.CUX2800001.14 to 'Heizungstimer:14'
                ! hm-rega.0 2018-01-25 20:12:13.210 info renamed hm-rpc.1.CUX2800001.15 to 'Heizungstimer:15'
                ! hm-rega.0 2018-01-25 20:12:13.196 info renamed hm-rpc.1.CUX2800001.16 to 'Heizungstimer:16'
                ! hm-rega.0 2018-01-25 20:12:13.185 info renamed hm-rpc.1.CUX2803001 to 'PING'
                ! hm-rega.0 2018-01-25 20:12:13.171 info renamed hm-rpc.1.CUX2803001.0 to 'PING:0'
                ! hm-rega.0 2018-01-25 20:12:13.157 info renamed hm-rpc.1.CUX2803001.1 to 'HM-EM-CMM CUX2803001:1'
                ! hm-rega.0 2018-01-25 20:12:13.126 info renamed hm-rpc.1.CUX2803001.2 to 'HM-EM-CMM CUX2803001:2'
                ! hm-rega.0 2018-01-25 20:12:13.114 info renamed hm-rpc.1.CUX2803001.3 to 'HM-EM-CMM CUX2803001:3'
                ! hm-rega.0 2018-01-25 20:12:13.101 info renamed hm-rpc.1.CUX2803001.4 to 'HM-EM-CMM CUX2803001:4'
                ! hm-rega.0 2018-01-25 20:12:13.088 info renamed hm-rpc.1.CUX2803001.5 to 'HM-EM-CMM CUX2803001:5'
                ! hm-rega.0 2018-01-25 20:12:13.078 info renamed hm-rpc.1.CUX2803001.6 to 'HM-EM-CMM CUX2803001:6'
                ! hm-rega.0 2018-01-25 20:12:13.065 info renamed hm-rpc.1.CUX2803001.7 to 'HM-EM-CMM CUX2803001:7'
                ! hm-rega.0 2018-01-25 20:12:13.054 info renamed hm-rpc.1.CUX2803001.8 to 'HM-EM-CMM CUX2803001:8'
                ! hm-rega.0 2018-01-25 20:12:13.041 info renamed hm-rpc.1.CUX2803001.9 to 'HM-EM-CMM CUX2803001:9'
                ! hm-rega.0 2018-01-25 20:12:13.026 info renamed hm-rpc.1.CUX2803001.10 to 'HM-EM-CMM CUX2803001:10'
                ! hm-rega.0 2018-01-25 20:12:13.009 info renamed hm-rpc.1.CUX2803001.11 to 'HM-EM-CMM CUX2803001:11'
                ! hm-rega.0 2018-01-25 20:12:12.994 info renamed hm-rpc.1.CUX2803001.12 to 'HM-EM-CMM CUX2803001:12'
                ! hm-rega.0 2018-01-25 20:12:12.978 info renamed hm-rpc.1.CUX2803001.13 to 'HM-EM-CMM CUX2803001:13'
                ! hm-rega.0 2018-01-25 20:12:12.966 info renamed hm-rpc.1.CUX2803001.14 to 'HM-EM-CMM CUX2803001:14'
                ! hm-rega.0 2018-01-25 20:12:12.954 info renamed hm-rpc.1.CUX2803001.15 to 'HM-EM-CMM CUX2803001:15'
                ! hm-rega.0 2018-01-25 20:12:12.936 info renamed hm-rpc.1.CUX2803001.16 to 'HM-EM-CMM CUX2803001:16'
                ! history.0 2018-01-25 20:12:12.506 info enabled logging of hm-rpc.0.NEQ0386739.2.POWER
                ! history.0 2018-01-25 20:12:12.505 info enabled logging of hm-rpc.0.NEQ0387084.2.POWER
                ! history.0 2018-01-25 20:12:12.302 info starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.history, node: v8.9.4
                ! admin.1 2018-01-25 20:12:11.578 info Repository received successfully.
                ! rpi.0 2018-01-25 20:12:08.285 info starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.rpi, node: v8.9.4
                ! admin.0 2018-01-25 20:12:08.321 info Repository received successfully.
                ! host.raspberrypi 2018-01-25 20:12:08.220 info instance system.adapter.history.0 started with pid 843
                ! host.raspberrypi 2018-01-25 20:12:07.212 info Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
                ! hm-rega.0 2018-01-25 20:12:05.999 info added/updated rooms to enum.rooms
                ! hm-rega.0 2018-01-25 20:12:05.913 info added/updated functions to enum.functions
                ! hm-rega.0 2018-01-25 20:12:05.836 info added/updated 6 favorites to enum.favorites
                ! hm-rega.0 2018-01-25 20:12:05.765 info time difference local-ccu 1s
                ! hm-rega.0 2018-01-25 20:12:05.703 info ReGaHSS 192.168.0.34 up
                ! hm-rega.0 2018-01-25 20:12:03.117 info subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                ! hm-rega.0 2018-01-25 20:12:03.081 info starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v8.9.4
                ! host.raspberrypi 2018-01-25 20:12:05.055 info Update repository 'default' under 'http://download.iobroker.net/sources-dist.json'
                ! admin.1 2018-01-25 20:12:05.053 info Request actual repository…
                ! admin.0 2018-01-25 20:12:04.951 info Request actual repository...
                ! admin.1 2018-01-25 20:12:04.708 info Use link 'http://localhost:8089' to configure.
                ! admin.1 2018-01-25 20:12:04.707 info http server listening on port 8089
                ! admin.0 2018-01-25 20:12:04.090 info Use link 'http://localhost:8081' to configure.
                ! admin.0 2018-01-25 20:12:04.090 info http server listening on port 8081
                ! host.raspberrypi 2018-01-25 20:12:04.213 info instance system.adapter.rpi.0 started with pid 833
                ! admin.1 2018-01-25 20:12:04.062 info received all objects
                ! admin.0 2018-01-25 20:12:03.682 info received all objects
                ! hm-rpc.0 2018-01-25 20:12:02.909 info Connected
                ! hm-rpc.0 2018-01-25 20:12:02.284 info binrpc -> 285 devices
                ! hm-rpc.0 2018-01-25 20:12:02.218 info binrpc <- listDevices ['hm-rpc.0']
                ! hm-rpc.0 2018-01-25 20:12:02.191 info binrpc <- system.listMethods ['hm-rpc.0']
                ! hm-rpc.0 2018-01-25 20:12:01.921 info binrpc client is trying to connect to 192.168.0.34:2001 with ['xmlrpc_bin://192.168.0.9:2001','hm-rpc.0']
                ! hm-rpc.0 2018-01-25 20:12:01.918 info binrpc server is trying to listen on 192.168.0.9:2001
                ! web.0 2018-01-25 20:12:01.042 info http server listening on port 8082
                ! hm-rpc.0 2018-01-25 20:12:00.742 info starting. Version 1.4.14 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.9.4
                ! web.0 2018-01-25 20:12:01.029 info socket.io server listening on port 8082
                ! admin.1 2018-01-25 20:12:00.400 info received all states
                ! host.raspberrypi 2018-01-25 20:12:00.215 info instance system.adapter.hm-rega.0 started with pid 816
                ! admin.0 2018-01-25 20:11:59.714 info received all states
                ! web.0 2018-01-25 20:11:58.531 info starting. Version 2.1.8 in /opt/iobroker/node_modules/iobroker.web, node: v8.9.4
                ! host.raspberrypi 2018-01-25 20:11:57.622 info instance system.adapter.hm-rpc.0 started with pid 806
                ! admin.1 2018-01-25 20:11:55.731 info requesting all objects
                ! admin.1 2018-01-25 20:11:55.726 info requesting all states
                ! admin.1 2018-01-25 20:11:55.633 info starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v8.9.4
                ! admin.0 2018-01-25 20:11:53.016 info requesting all objects
                ! admin.0 2018-01-25 20:11:53.011 info requesting all states
                ! admin.0 2018-01-25 20:11:52.909 info starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.admin, node: v8.9.4
                ! host.raspberrypi 2018-01-25 20:11:52.211 info instance system.adapter.web.0 started with pid 792
                ! host.raspberrypi 2018-01-25 20:11:48.267 info instance system.adapter.admin.1 started with pid 785
                ! host.raspberrypi 2018-01-25 20:11:44.331 info instance system.adapter.admin.0 started with pid 779
                ! host.raspberrypi 2018-01-25 20:11:44.177 info starting 18 instances
                ! host.raspberrypi 2018-01-25 20:11:44.057 info 30 instances found
                ! host.raspberrypi 2018-01-25 20:11:43.955 info InMemoryDB connected
                ! host.raspberrypi 2018-01-25 20:11:43.913 info inMem-objects listening on port 9001
                ! host.raspberrypi 2018-01-25 20:11:25.651 info inMem-states listening on port 9000
                ! host.raspberrypi 2018-01-25 20:11:25.227 info ip addresses: 192.168.0.9 fe80::cf32:e280:97e3:19af
                ! host.raspberrypi 2018-01-25 20:11:25.218 info hostname: raspberrypi, node: v8.9.4
                ! host.raspberrypi 2018-01-25 20:11:25.217 info Copyright © 2014-2017 bluefox, hobbyquaker
                ! host.raspberrypi 2018-01-25 20:11:25.204 info iobroker.js-controller version 1.2.0 js-controller starting
                ! host.raspberrypi 2018-01-25 20:11:11.172 info instance system.adapter.hm-rega.0 terminated with code 0 (OK)
                ! Caught 2018-01-25 20:11:11.171 error by controller[0]: Use of const in strict mode.]
                ! Caught 2018-01-25 20:11:11.171 error by controller[0]: ^^^^^
                ! Caught 2018-01-25 20:11:11.171 error by controller[0]: const Hoek = require('hoek');
                ! Caught 2018-01-25 20:11:11.170 error by controller[0]: [SyntaxError: /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/request/node_modules/hawk/node_modules/boom/lib/index.js:5
                ! host.raspberrypi 2018-01-25 20:11:10.697 info instance system.adapter.ping.0 terminated with code 0 (OK)
                ! ping.0 2018-01-25 20:11:10.648 info terminating
                ! host.raspberrypi 2018-01-25 20:11:10.372 info instance system.adapter.history.0 terminated with code 0 (OK)
                ! host.raspberrypi 2018-01-25 20:11:10.307 info instance system.adapter.mysensors.0 terminated with code 0 (OK)
                ! host.raspberrypi 2018-01-25 20:11:10.279 info instance system.adapter.rpi.0 terminated with code 0 (OK)
                ! host.raspberrypi 2018-01-25 20:11:10.250 info instance system.adapter.discovery.0 terminated with code 0 (OK)
                ! history.0 2018-01-25 20:11:10.320 info terminating
                ! host.raspberrypi 2018-01-25 20:11:10.221 info instance system.adapter.web.0 terminated with code 0 (OK)
                ! mysensors.0 2018-01-25 20:11:10.176 info terminating
                ! rpi.0 2018-01-25 20:11:10.156 info terminating
                ! discovery.0 2018-01-25 20:11:10.155 info terminating
                ! hm-rpc.0 2018-01-25 20:11:10.111 info binrpc -> 192.168.0.34:2001 init ['xmlrpc_bin://192.168.0.9:2001','']
                ! web.0 2018-01-25 20:11:10.130 info terminating
                ! web.0 2018-01-25 20:11:10.106 info terminated http server on port 8082
                ! hm-rpc.4 2018-01-25 20:11:10.114 info binrpc -> 192.168.0.34:8701 init ['xmlrpc_bin://192.168.0.9:18701','']
                ! hm-rpc.2 2018-01-25 20:11:10.109 info binrpc -> 192.168.0.34:2001 init ['xmlrpc_bin://192.168.0.9:12001','']
                ! host.raspberrypi 2018-01-25 20:11:10.113 info received SIGTERM
                ! web.0 2018-01-25 20:11:10.104 info terminating http server on port 8082
                ! host.raspberrypi 2018-01-25 20:11:07.983 info Restart adapter system.adapter.admin.1 because enabled
                ein paar Probleme gibts ja noch :mrgreen:
                  wendy2702W Offline
                  Na dann heißt es jetzt aufräumen!
                  • P Offline
                    pingps
                    … danke.
                    bis zum nächsten mal :mrgreen:
