  4. 2 iobroker installationen ...
21 Beiträge 5 Kommentatoren 2.8k Aufrufe 3 Beobachtet
    @pille0557 was sagt iob diag in der Langfassung auf dem futro?
    pille0557P Offline
    pille0557P Offline
    pille0557
    ich poste mal lieber nicht alles ...
    zum Schluss das log etwas anders:
    2025-03-23 15:04:24.745  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
    2025-03-23 15:04:36.895  - error: fronius.0 (6554) IP is not a Fronius inverter
    2025-03-23 15:05:20.795  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
    2025-03-23 15:05:20.798  - info: fronius.0 (6554) Got terminate signal TERMINATE_YOURSELF
    2025-03-23 15:05:20.848  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
    2025-03-23 15:05:21.300  - info: fronius.0 (6554) terminating
    2025-03-23 15:05:21.301  - info: fronius.0 (6554) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-03-23 15:05:21.842  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-03-23 15:05:22.509  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
    2025-03-23 15:05:25.064  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6573
    2025-03-23 15:05:26.240  - info: fronius.0 (6573) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
    2025-03-23 15:05:26.254  - error: fronius.0 (6573) Please configure the Fronius adapter
    2025-03-23 15:06:30.491  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
    2025-03-23 15:06:37.755  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
    2025-03-23 15:06:37.758  - info: fronius.0 (6573) Got terminate signal TERMINATE_YOURSELF
    2025-03-23 15:06:37.806  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
    2025-03-23 15:06:38.260  - info: fronius.0 (6573) terminating
    2025-03-23 15:06:38.261  - info: fronius.0 (6573) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-03-23 15:06:38.804  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-03-23 15:06:39.722  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
    2025-03-23 15:06:42.026  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6589
    2025-03-23 15:06:43.199  - info: fronius.0 (6589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
    2025-03-23 15:06:43.213  - error: fronius.0 (6589) Please configure the Fronius adapter
    2025-03-23 15:07:08.589  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
    2025-03-23 15:38:12.549  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
    interessant die Zeile:
    aha ... nach dann ... ?
    • pille0557P pille0557
      @pille0557 sagte in 2 iobroker installationen ...:
      dann nutzt es nichts
      pille0557P 1 Antwort Letzte Antwort
        pille0557P Offline
        pille0557P Offline
        pille0557
        schrieb am zuletzt editiert von pille0557
        Script v.2025-02-23
        *** BASE SYSTEM ***
         Static hostname: debianiob
               Icon name: computer-desktop
                 Chassis: desktop 🖥️
                  Kernel: Linux 6.1.0-32-amd64
            Architecture: x86-64
         Hardware Vendor: FUJITSU
          Hardware Model: FUTRO S740
        Firmware Version: V5.0.0.13 R1.5.0 for D3544-A1x
        OS is similar to:
        model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2025-03-23 15:50:08 CET
                   Universal time: Sun 2025-03-23 14:50:08 UTC
                         RTC time: Sun 2025-03-23 14:50:08
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        peter
        HOME=/home/peter
        GROUPS=peter cdrom floppy sudo audio dip video plugdev users netdev lpadmin scanner iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:             16G        1.6G         13G         33M        1.6G         14G
        Swap:           1.0G          0B        1.0G
        Total:           17G        1.6G         14G
        Active iob-Instances:   8
                15762 M total memory
                 1502 M used memory
                  907 M active memory
                 1540 M inactive memory
                13029 M free memory
                  669 M buffer memory
                  889 M swap cache
                  976 M total swap
                    0 M used swap
                  976 M free swap
        top - 15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
        Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  15762.3 total,  13028.9 free,   1503.6 used,   1559.3 buff/cache
        MiB Swap:    977.0 total,    977.0 free,      0.0 used.  14258.7 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  7.7G     0  7.7G   0% /dev
        tmpfs          tmpfs     1.6G  1.4M  1.6G   1% /run
        /dev/sda2      ext4      233G  8.4G  213G   4% /
        tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
        tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
        /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
        tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run/user/107
        tmpfs          tmpfs     1.6G   64K  1.6G   1% /run/user/1000
        [Thu Mar 20 16:43:27 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Thu Mar 20 16:43:28 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET      SOURCE    FSTYPE OPTIONS
        /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
        `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
        /var:
        870M    /var/
        376M    /var/cache
        357M    /var/cache/apt
        315M    /var/lib
        279M    /var/cache/apt/archives
        Archived and active journals take up 11.9M in the file system.
        /opt/iobroker/backups:
        4.0K    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        240M    /opt/iobroker/iobroker-data/
        181M    /opt/iobroker/iobroker-data/files
        158M    /opt/iobroker/iobroker-data/files/admin.admin
        157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
        13M     /opt/iobroker/iobroker-data/objects.jsonl
        7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.19.0
        /usr/bin/node           v20.19.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.31.0
        nodejs:
          Installed: 20.19.0-1nodesource1
          Candidate: 20.19.0-1nodesource1
          Version table:
         *** 20.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
             20.18.3-1nodesource1 1001
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.19.0+dfsg-6~deb12u1 500
                500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        debianiob           debianiob (version: 7.0.6, hostname: debianiob     , alive, uptime: 255987)
        Core adapters versions
        admin:          7.4.10
        javascript:     "javascript" not found
        nodejs modules from github:     0
        Adapter State
        + system.adapter.admin.0                  : admin                 : debianiob                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : debianiob                                - disabled
        + system.adapter.discovery.0              : discovery             : debianiob                                -  enabled
        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : debianiob                                -  enabled
        + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : debianiob                                -  enabled
        + system.adapter.fronius.0                : fronius               : debianiob                                -  enabled
          system.adapter.fronius.1                : fronius               : debianiob                                - disabled
          system.adapter.fronius.2                : fronius               : debianiob                                - disabled
          system.adapter.fronius.3                : fronius               : debianiob                                - disabled
        + system.adapter.influxdb.0               : influxdb              : debianiob                                -  enabled, port: 8086
          system.adapter.shelly.0                 : shelly                : debianiob                                - disabled, port: 1882, bind: 0.0.0.0
        + system.adapter.shelly.1                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.4.10   , installed 7.4.10
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "fronius"      : 2.1.1    , installed 2.1.1
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
        Objects and States
        Objects:        5688
        States:         4438
        W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
        W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:5 https://packages.grafana.com/oss/deb stable InRelease
        Hit:6 https://packages.grafana.com/enterprise/deb stable InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          20864      581/brltty
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      112        18219      652/influxd
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14588      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22684      677/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23135      653/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18293      653/iobroker.js-con
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1161295    5328/cupsd
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1161294    5328/cupsd
        tcp6       0      0 :::8086                 :::*                    LISTEN      112        18242      652/influxd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24645      835/io.admin.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          14589      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          22686      677/sshd: /usr/sbin
        tcp6       0      0 ::1:4101                :::*                    LISTEN      0          22589      581/brltty
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1607       1/init
        udp        0      0 0.0.0.0:54464           0.0.0.0:*                           103        20852      591/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        20850      591/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24918      1062/io.shelly.1
        udp6       0      0 :::111                  :::*                                0          1608       1/init
        udp6       0      0 fe80::4e52:62ff:fe1:546 :::*                                0          1454426    606/NetworkManager
        udp6       0      0 :::59684                :::*                                103        20853      591/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                103        20851      591/avahi-daemon: r
                                v.2025-02-23
                 Chassis: desktop 🖥️
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        Pending OS-Updates:     1
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        Recommended versions are nodejs 20.19.0 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Swap:           1.0G          0B        1.0G
        Total:           17G        1.6G         14G
        ioBroker Core:          js-controller           7.0.6
                                admin                   7.4.10
        Objects type: jsonl
        States  type: jsonl
        Objects:                5688
        States:                 4438
        Size of iob-Database:
        4.5M    /opt/iobroker/iobroker-data/states.jsonl
          Script v.2025-02-23
          *** BASE SYSTEM ***
                   Chassis: desktop 🖥️
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          peter
          HOME=/home/peter
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
          Total:           17G        1.6G         14G
                   1502 M used memory
                    907 M active memory
                  13029 M free memory
                    669 M buffer memory
                    889 M swap cache
                    976 M total swap
                      0 M used swap
                    976 M free swap
          *** FILESYSTEM ***
          /var:
          870M    /var/
          376M    /var/cache
          357M    /var/cache/apt
          315M    /var/lib
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.4.10
          Adapter State
          + instance is alive
          Objects and States
          Objects:        5688
          States:         4438
          Pending Updates: 1
                                  v.2025-02-23
                   Chassis: desktop 🖥️
          Kernel:                 x86_64
          Userland:               64 bit
          User-ID:                1000
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Swap:           1.0G          0B        1.0G
          Total:           17G        1.6G         14G
                                  admin                   7.4.10
          Objects type: jsonl
          States  type: jsonl
          Objects:                5688
          States:                 4438
          T Nicht stören
          T Nicht stören
          ticaki
          @pille0557
          Hast du auf den Test Connection button gedrückt?
          Spenden
          • T ticaki
            @pille0557
            pille0557P Offline
            pille0557P Offline
            pille0557
            @ticaki said in 2 iobroker installationen ...:
            @pille0557
            ja habe ich auch schon, keine Info als Ergebnis
            HomoranH T 2 Antworten Letzte Antwort
              @pille0557
              @pille0557 ist da vielleicht noch ein Leerzeichen o.ä. in der Adresse?
                @pille0557
                T Nicht stören
                T Nicht stören
                ticaki
                @pille0557
                Dann schalte den Adapter mal in den Debugmodus - da sollte mehr an infos kommen.
                Spenden
                • T ticaki
                  @pille0557
                  pille0557P Offline
                  pille0557P Offline
                  pille0557
                  @ticaki
                  2025-03-23 17:04:23.191 - error: fronius.0 (11921) Please configure the Fronius adapter
                  2025-03-23 17:04:27.896 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                  2025-03-23 17:33:21.021 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                  2025-03-23 17:33:32.189 - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                  2025-03-23 17:33:32.193 - info: fronius.0 (11921) Got terminate signal TERMINATE_YOURSELF
                  2025-03-23 17:33:32.257 - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                  2025-03-23 17:33:32.695 - info: fronius.0 (11921) terminating
                  2025-03-23 17:33:32.696 - info: fronius.0 (11921) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-03-23 17:33:33.267 - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-03-23 17:33:36.493 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 14290
                  2025-03-23 17:33:37.435 - debug: fronius.0 (14290) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2025-03-23 17:33:37.472 - debug: fronius.0 (14290) Objects client ready ... initialize now
                  2025-03-23 17:33:37.473 - debug: fronius.0 (14290) Objects create System PubSub Client
                  2025-03-23 17:33:37.474 - debug: fronius.0 (14290) Objects create User PubSub Client
                  2025-03-23 17:33:37.505 - debug: fronius.0 (14290) Objects client initialize lua scripts
                  2025-03-23 17:33:37.510 - debug: fronius.0 (14290) Objects connected to redis: 127.0.0.1:9001
                  2025-03-23 17:33:37.531 - debug: fronius.0 (14290) Redis States: Use Redis connection: 127.0.0.1:9000
                  2025-03-23 17:33:37.540 - debug: fronius.0 (14290) States create System PubSub Client
                  2025-03-23 17:33:37.541 - debug: fronius.0 (14290) States create User PubSub Client
                  2025-03-23 17:33:37.597 - debug: fronius.0 (14290) States connected to redis: 127.0.0.1:9000
                  2025-03-23 17:33:37.666 - info: fronius.0 (14290) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                  2025-03-23 17:33:37.678 - error: fronius.0 (14290) Please configure the Fronius adapter
                  2025-03-23 17:33:38.184 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                    @ticaki
                    pille0557P Offline
                    pille0557P Offline
                    pille0557
                    @pille0557
                    danke für die Hilfe, ich werde die Kiste mal neu aufsetzen ...
                    damit ich grafana mit meinem älteren iPad in der Küche als Statusanzeigen benutzen kann, muss ich sowieso eine ältere Grafana Version installieren, ein downgrade wird wohl auch nicht einfach
                      @pille0557
                      Meister MopperM Offline
                      Meister Mopper
                      @pille0557
                      Da muss nur die ältere Version gepinnt werden.
                      Ein wenig aufwändiger wird es lediglich, wenn du major upgrades verhindern möchtest. Das ist aber auch kein Hexenwerk.
                      Proxmox und HA ...
