  4. 2 iobroker installationen ...
21 Beiträge 5 Kommentatoren 2.8k Aufrufe 3 Beobachtet
  • pille0557P pille0557
    mal probehalber einen gestartet, die IP ist eingetragen ..
    2025-03-23 01:43:33.832 - info: host.debianiob Delete log file iobroker.2025-03-15.log.gz
    2025-03-23 13:32:03.541 - info: admin.0 (835) Request actual repository...
    2025-03-23 13:32:03.784 - info: host.debianiob Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2025-03-23 13:32:07.124 - info: admin.0 (835) Repository received successfully.
    2025-03-23 13:56:21.745 - info: admin.0 (835) failed connection to socket.io from ::ffff:192.168.0.76: Passport was not initialized
    2025-03-23 13:56:25.029 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
    2025-03-23 13:56:45.830 - info: host.debianiob "system.adapter.fronius.0" enabled
    2025-03-23 13:56:46.091 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6416
    2025-03-23 13:56:47.262 - info: fronius.0 (6416) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
    2025-03-23 13:56:47.275 - error: fronius.0 (6416) Please configure the Fronius adapter
    2025-03-23 13:56:59.553 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
    2025-03-23 13:57:06.703 - warn: fronius.0 (6416) Adapter requestType https:// was not matching, changed to http:// and trigger restart.
    2025-03-23 13:57:06.714 - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
    2025-03-23 13:57:06.720 - info: fronius.0 (6416) Got terminate signal TERMINATE_YOURSELF
    2025-03-23 13:57:06.804 - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
    2025-03-23 13:57:07.222 - info: fronius.0 (6416) terminating
    2025-03-23 13:57:07.223 - info: fronius.0 (6416) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-03-23 13:57:07.765 - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-03-23 13:57:10.985 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6431
    2025-03-23 13:57:12.169 - info: fronius.0 (6431) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
    2025-03-23 13:57:12.182 - error: fronius.0 (6431) Please configure the Fronius adapter
    2025-03-23 13:57:13.751 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
    @pille0557 sagte in 2 iobroker installationen ...:
    pille0557P 1 Antwort Letzte Antwort
      pille0557P Offline
      pille0557P Offline
      pille0557
      schrieb am zuletzt editiert von pille0557
      ? keine Ahnung ... http://ip oder https://ip geht auch nicht ... ?
      es steht da: IP sonst nix und auf dem raspi habe ich ja auch nichts anderes eingetragen
        das zeigst du uns ja nicht
          pille0557P Offline
          pille0557P Offline
          pille0557
          raspi
          futro - debian
            raspi
            futro - debian
            @pille0557 was sagt iob diag in der Langfassung auf dem futro?
              pille0557P Offline
              pille0557P Offline
              pille0557
              ich poste mal lieber nicht alles ...
              zum Schluss das log etwas anders:
              2025-03-23 15:04:24.745  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
              2025-03-23 15:04:36.895  - error: fronius.0 (6554) IP is not a Fronius inverter
              2025-03-23 15:05:20.795  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
              2025-03-23 15:05:20.798  - info: fronius.0 (6554) Got terminate signal TERMINATE_YOURSELF
              2025-03-23 15:05:20.848  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
              2025-03-23 15:05:21.300  - info: fronius.0 (6554) terminating
              2025-03-23 15:05:21.301  - info: fronius.0 (6554) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2025-03-23 15:05:21.842  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2025-03-23 15:05:22.509  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
              2025-03-23 15:05:25.064  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6573
              2025-03-23 15:05:26.240  - info: fronius.0 (6573) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
              2025-03-23 15:05:26.254  - error: fronius.0 (6573) Please configure the Fronius adapter
              2025-03-23 15:06:30.491  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
              2025-03-23 15:06:37.755  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
              2025-03-23 15:06:37.758  - info: fronius.0 (6573) Got terminate signal TERMINATE_YOURSELF
              2025-03-23 15:06:37.806  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
              2025-03-23 15:06:38.260  - info: fronius.0 (6573) terminating
              2025-03-23 15:06:38.261  - info: fronius.0 (6573) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2025-03-23 15:06:38.804  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2025-03-23 15:06:39.722  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
              2025-03-23 15:06:42.026  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6589
              2025-03-23 15:06:43.199  - info: fronius.0 (6589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
              2025-03-23 15:06:43.213  - error: fronius.0 (6589) Please configure the Fronius adapter
              2025-03-23 15:07:08.589  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
              2025-03-23 15:38:12.549  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
              interessant die Zeile:
              aha ... nach dann ... ?
                dann nutzt es nichts
                  pille0557P Offline
                  pille0557P Offline
                  pille0557
                  Script v.2025-02-23
                  *** BASE SYSTEM ***
                   Static hostname: debianiob
                         Icon name: computer-desktop
                           Chassis: desktop 🖥️
                            Kernel: Linux 6.1.0-32-amd64
                      Architecture: x86-64
                   Hardware Vendor: FUJITSU
                    Hardware Model: FUTRO S740
                  Firmware Version: V5.0.0.13 R1.5.0 for D3544-A1x
                  OS is similar to:
                  model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
                  Docker          : false
                  Virtualization  : none
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  Operating System is the current Debian stable version codenamed 'bookworm'!
                  *** TIME AND TIMEZONES ***
                                 Local time: Sun 2025-03-23 15:50:08 CET
                             Universal time: Sun 2025-03-23 14:50:08 UTC
                                   RTC time: Sun 2025-03-23 14:50:08
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  peter
                  HOME=/home/peter
                  GROUPS=peter cdrom floppy sudo audio dip video plugdev users netdev lpadmin scanner iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server: false
                  Desktop:
                  Terminal:       tty
                  System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                  *** MEMORY ***
                  Mem:             16G        1.6G         13G         33M        1.6G         14G
                  Swap:           1.0G          0B        1.0G
                  Total:           17G        1.6G         14G
                  Active iob-Instances:   8
                          15762 M total memory
                           1502 M used memory
                            907 M active memory
                           1540 M inactive memory
                          13029 M free memory
                            669 M buffer memory
                            889 M swap cache
                            976 M total swap
                              0 M used swap
                            976 M free swap
                  top - 15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
                  Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :  15762.3 total,  13028.9 free,   1503.6 used,   1559.3 buff/cache
                  MiB Swap:    977.0 total,    977.0 free,      0.0 used.  14258.7 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  udev           devtmpfs  7.7G     0  7.7G   0% /dev
                  tmpfs          tmpfs     1.6G  1.4M  1.6G   1% /run
                  /dev/sda2      ext4      233G  8.4G  213G   4% /
                  tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
                  tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
                  /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
                  tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run/user/107
                  tmpfs          tmpfs     1.6G   64K  1.6G   1% /run/user/1000
                  [Thu Mar 20 16:43:27 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Thu Mar 20 16:43:28 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
                  Show mounted filesystems:
                  TARGET      SOURCE    FSTYPE OPTIONS
                  /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
                  `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                  /var:
                  870M    /var/
                  376M    /var/cache
                  357M    /var/cache/apt
                  315M    /var/lib
                  279M    /var/cache/apt/archives
                  Archived and active journals take up 11.9M in the file system.
                  /opt/iobroker/backups:
                  4.0K    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  240M    /opt/iobroker/iobroker-data/
                  181M    /opt/iobroker/iobroker-data/files
                  158M    /opt/iobroker/iobroker-data/files/admin.admin
                  157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                  13M     /opt/iobroker/iobroker-data/objects.jsonl
                  7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
                  7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                  7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                  7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.19.0
                  /usr/bin/node           v20.19.0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.31.0
                  nodejs:
                    Installed: 20.19.0-1nodesource1
                    Candidate: 20.19.0-1nodesource1
                    Version table:
                   *** 20.19.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                       20.18.3-1nodesource1 1001
                       20.18.2-1nodesource1 1001
                       20.18.1-1nodesource1 1001
                       20.18.0-1nodesource1 1001
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u2 500
                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  debianiob           debianiob (version: 7.0.6, hostname: debianiob     , alive, uptime: 255987)
                  Core adapters versions
                  admin:          7.4.10
                  javascript:     "javascript" not found
                  nodejs modules from github:     0
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : debianiob                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.backitup.0               : backitup              : debianiob                                - disabled
                  + system.adapter.discovery.0              : discovery             : debianiob                                -  enabled
                  + system.adapter.fronius-solarweb.0       : fronius-solarweb      : debianiob                                -  enabled
                  + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : debianiob                                -  enabled
                  + system.adapter.fronius.0                : fronius               : debianiob                                -  enabled
                    system.adapter.fronius.1                : fronius               : debianiob                                - disabled
                    system.adapter.fronius.2                : fronius               : debianiob                                - disabled
                    system.adapter.fronius.3                : fronius               : debianiob                                - disabled
                  + system.adapter.influxdb.0               : influxdb              : debianiob                                -  enabled, port: 8086
                    system.adapter.shelly.0                 : shelly                : debianiob                                - disabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shelly.1                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Upgrade policy: none
                  Installed ioBroker-Adapters
                  Used repository: stable
                  Adapter    "admin"        : 7.4.10   , installed 7.4.10
                  Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                  Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                  Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                  Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
                  Controller "js-controller": 7.0.6    , installed 7.0.6
                  Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                  Objects and States
                  Objects:        5688
                  States:         4438
                  W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                  W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                  Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                  Hit:6 https://packages.grafana.com/enterprise/deb stable InRelease
                  Reading package lists...
                  Pending Updates: 1
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          20864      581/brltty
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      112        18219      652/influxd
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14588      1/init
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22684      677/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23135      653/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18293      653/iobroker.js-con
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1161295    5328/cupsd
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1161294    5328/cupsd
                  tcp6       0      0 :::8086                 :::*                    LISTEN      112        18242      652/influxd
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24645      835/io.admin.0
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          14589      1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          22686      677/sshd: /usr/sbin
                  tcp6       0      0 ::1:4101                :::*                    LISTEN      0          22589      581/brltty
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1607       1/init
                  udp        0      0 0.0.0.0:54464           0.0.0.0:*                           103        20852      591/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        20850      591/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24918      1062/io.shelly.1
                  udp6       0      0 :::111                  :::*                                0          1608       1/init
                  udp6       0      0 fe80::4e52:62ff:fe1:546 :::*                                0          1454426    606/NetworkManager
                  udp6       0      0 :::59684                :::*                                103        20853      591/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                103        20851      591/avahi-daemon: r
                                          v.2025-02-23
                           Chassis: desktop 🖥️
                  Kernel:                 x86_64
                  Userland:               64 bit
                  Timezone:               Europe/Berlin (CET, +0100)
                  User-ID:                1000
                  Pending OS-Updates:     1
                  Pending iob updates:    0
                  Nodejs-Installation:
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  Recommended versions are nodejs 20.19.0 and npm 10.8.2
                  nodeJS installation is correct
                  MEMORY:
                  Swap:           1.0G          0B        1.0G
                  Total:           17G        1.6G         14G
                  ioBroker Core:          js-controller           7.0.6
                                          admin                   7.4.10
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                5688
                  States:                 4438
                  Size of iob-Database:
                  4.5M    /opt/iobroker/iobroker-data/states.jsonl
                    Script v.2025-02-23
                    *** BASE SYSTEM ***
                             Chassis: desktop 🖥️
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 4
                                  NTP service: active
                              RTC in local TZ: no
                    peter
                    HOME=/home/peter
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           1.0G          0B        1.0G
                    Total:           17G        1.6G         14G
                             1502 M used memory
                              907 M active memory
                            13029 M free memory
                              669 M buffer memory
                              889 M swap cache
                              976 M total swap
                                0 M used swap
                              976 M free swap
                    *** FILESYSTEM ***
                    /var:
                    870M    /var/
                    376M    /var/cache
                    357M    /var/cache/apt
                    315M    /var/lib
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.4.10
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        5688
                    States:         4438
                    Pending Updates: 1
                                            v.2025-02-23
                             Chassis: desktop 🖥️
                    Kernel:                 x86_64
                    Userland:               64 bit
                    User-ID:                1000
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    MEMORY:
                    Swap:           1.0G          0B        1.0G
                    Total:           17G        1.6G         14G
                                            admin                   7.4.10
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                5688
                    States:                 4438
                    T Nicht stören
                    T Nicht stören
                    ticaki
                    @pille0557
                    Hast du auf den Test Connection button gedrückt?
                    Spenden
                    • T ticaki
                      @pille0557
                      pille0557P Offline
                      pille0557P Offline
                      pille0557
                      @ticaki said in 2 iobroker installationen ...:
                      @pille0557
                      ja habe ich auch schon, keine Info als Ergebnis
                      HomoranH T 2 Antworten Letzte Antwort
                        @pille0557
                        @pille0557 ist da vielleicht noch ein Leerzeichen o.ä. in der Adresse?
                          @pille0557
                          T Nicht stören
                          T Nicht stören
                          ticaki
                          @pille0557
                          Dann schalte den Adapter mal in den Debugmodus - da sollte mehr an infos kommen.
                          Spenden
                          • T ticaki
                            @pille0557
                            pille0557P Offline
                            pille0557P Offline
                            pille0557
                            @ticaki
                            2025-03-23 17:04:23.191 - error: fronius.0 (11921) Please configure the Fronius adapter
                            2025-03-23 17:04:27.896 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                            2025-03-23 17:33:21.021 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                            2025-03-23 17:33:32.189 - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                            2025-03-23 17:33:32.193 - info: fronius.0 (11921) Got terminate signal TERMINATE_YOURSELF
                            2025-03-23 17:33:32.257 - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                            2025-03-23 17:33:32.695 - info: fronius.0 (11921) terminating
                            2025-03-23 17:33:32.696 - info: fronius.0 (11921) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2025-03-23 17:33:33.267 - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2025-03-23 17:33:36.493 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 14290
                            2025-03-23 17:33:37.435 - debug: fronius.0 (14290) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2025-03-23 17:33:37.472 - debug: fronius.0 (14290) Objects client ready ... initialize now
                            2025-03-23 17:33:37.473 - debug: fronius.0 (14290) Objects create System PubSub Client
                            2025-03-23 17:33:37.474 - debug: fronius.0 (14290) Objects create User PubSub Client
                            2025-03-23 17:33:37.505 - debug: fronius.0 (14290) Objects client initialize lua scripts
                            2025-03-23 17:33:37.510 - debug: fronius.0 (14290) Objects connected to redis: 127.0.0.1:9001
                            2025-03-23 17:33:37.531 - debug: fronius.0 (14290) Redis States: Use Redis connection: 127.0.0.1:9000
                            2025-03-23 17:33:37.540 - debug: fronius.0 (14290) States create System PubSub Client
                            2025-03-23 17:33:37.541 - debug: fronius.0 (14290) States create User PubSub Client
                            2025-03-23 17:33:37.597 - debug: fronius.0 (14290) States connected to redis: 127.0.0.1:9000
                            2025-03-23 17:33:37.666 - info: fronius.0 (14290) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                            2025-03-23 17:33:37.678 - error: fronius.0 (14290) Please configure the Fronius adapter
                            2025-03-23 17:33:38.184 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                              @ticaki
                              pille0557P Offline
                              pille0557P Offline
                              pille0557
                              @pille0557
                              danke für die Hilfe, ich werde die Kiste mal neu aufsetzen ...
                              damit ich grafana mit meinem älteren iPad in der Küche als Statusanzeigen benutzen kann, muss ich sowieso eine ältere Grafana Version installieren, ein downgrade wird wohl auch nicht einfach
                                @pille0557
                                Meister MopperM Offline
                                Meister Mopper
                                @pille0557
                                Da muss nur die ältere Version gepinnt werden.
                                Ein wenig aufwändiger wird es lediglich, wenn du major upgrades verhindern möchtest. Das ist aber auch kein Hexenwerk.
                                Proxmox und HA ...
