  4. 2 iobroker installationen ...
21 Beiträge 5 Kommentatoren 2.8k Aufrufe 3 Beobachtet
    @pille0557 sagte in 2 iobroker installationen ...:
    2025-03-23 13:57:12.182 - error: fronius.0 (6431) Please configure the Fronius adapter
    Da fehlen wohl Einstellungen.
    pille0557P Offline
    pille0557P Offline
    pille0557
    mehr als die IP des WR ist doch nicht einzutragen ... ?
    • pille0557P pille0557
      Ich kenne den Adapter nicht.
        mal probehalber einen gestartet, die IP ist eingetragen ..
        2025-03-23 01:43:33.832 - info: host.debianiob Delete log file iobroker.2025-03-15.log.gz
        2025-03-23 13:32:03.541 - info: admin.0 (835) Request actual repository...
        2025-03-23 13:32:03.784 - info: host.debianiob Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2025-03-23 13:32:07.124 - info: admin.0 (835) Repository received successfully.
        2025-03-23 13:56:21.745 - info: admin.0 (835) failed connection to socket.io from ::ffff:192.168.0.76: Passport was not initialized
        2025-03-23 13:56:25.029 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
        2025-03-23 13:56:45.830 - info: host.debianiob "system.adapter.fronius.0" enabled
        2025-03-23 13:56:46.091 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6416
        2025-03-23 13:56:47.262 - info: fronius.0 (6416) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
        2025-03-23 13:56:47.275 - error: fronius.0 (6416) Please configure the Fronius adapter
        2025-03-23 13:56:59.553 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
        2025-03-23 13:57:06.703 - warn: fronius.0 (6416) Adapter requestType https:// was not matching, changed to http:// and trigger restart.
        2025-03-23 13:57:06.714 - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
        2025-03-23 13:57:06.720 - info: fronius.0 (6416) Got terminate signal TERMINATE_YOURSELF
        2025-03-23 13:57:06.804 - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
        2025-03-23 13:57:07.222 - info: fronius.0 (6416) terminating
        2025-03-23 13:57:07.223 - info: fronius.0 (6416) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-03-23 13:57:07.765 - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-03-23 13:57:10.985 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6431
        2025-03-23 13:57:12.169 - info: fronius.0 (6431) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
        2025-03-23 13:57:13.751 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
        pille0557P 1 Antwort Letzte Antwort
          pille0557P Offline
          pille0557P Offline
          pille0557
          schrieb am zuletzt editiert von pille0557
          ? keine Ahnung ... http://ip oder https://ip geht auch nicht ... ?
          es steht da: IP sonst nix und auf dem raspi habe ich ja auch nichts anderes eingetragen
            das zeigst du uns ja nicht
              pille0557P Offline
              pille0557P Offline
              pille0557
              raspi
              futro - debian
                raspi
                futro - debian
                @pille0557 was sagt iob diag in der Langfassung auf dem futro?
                  pille0557P Offline
                  pille0557P Offline
                  pille0557
                  ich poste mal lieber nicht alles ...
                  zum Schluss das log etwas anders:
                  2025-03-23 15:04:24.745  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                  2025-03-23 15:04:36.895  - error: fronius.0 (6554) IP is not a Fronius inverter
                  2025-03-23 15:05:20.795  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                  2025-03-23 15:05:20.798  - info: fronius.0 (6554) Got terminate signal TERMINATE_YOURSELF
                  2025-03-23 15:05:20.848  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                  2025-03-23 15:05:21.300  - info: fronius.0 (6554) terminating
                  2025-03-23 15:05:21.301  - info: fronius.0 (6554) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-03-23 15:05:21.842  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-03-23 15:05:22.509  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                  2025-03-23 15:05:25.064  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6573
                  2025-03-23 15:05:26.240  - info: fronius.0 (6573) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                  2025-03-23 15:05:26.254  - error: fronius.0 (6573) Please configure the Fronius adapter
                  2025-03-23 15:06:30.491  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                  2025-03-23 15:06:37.755  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                  2025-03-23 15:06:37.758  - info: fronius.0 (6573) Got terminate signal TERMINATE_YOURSELF
                  2025-03-23 15:06:37.806  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                  2025-03-23 15:06:38.260  - info: fronius.0 (6573) terminating
                  2025-03-23 15:06:38.261  - info: fronius.0 (6573) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-03-23 15:06:38.804  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-03-23 15:06:39.722  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                  2025-03-23 15:06:42.026  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6589
                  2025-03-23 15:06:43.199  - info: fronius.0 (6589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                  2025-03-23 15:06:43.213  - error: fronius.0 (6589) Please configure the Fronius adapter
                  2025-03-23 15:07:08.589  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                  2025-03-23 15:38:12.549  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                  interessant die Zeile:
                  aha ... nach dann ... ?
                    dann nutzt es nichts
                      pille0557P Offline
                      pille0557P Offline
                      pille0557
                      Script v.2025-02-23
                      *** BASE SYSTEM ***
                       Static hostname: debianiob
                             Icon name: computer-desktop
                               Chassis: desktop 🖥️
                                Kernel: Linux 6.1.0-32-amd64
                          Architecture: x86-64
                       Hardware Vendor: FUJITSU
                        Hardware Model: FUTRO S740
                      Firmware Version: V5.0.0.13 R1.5.0 for D3544-A1x
                      OS is similar to:
                      model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
                      Docker          : false
                      Virtualization  : none
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
                      CPU threads: 4
                      *** LIFE CYCLE STATUS ***
                      Operating System is the current Debian stable version codenamed 'bookworm'!
                      *** TIME AND TIMEZONES ***
                                     Local time: Sun 2025-03-23 15:50:08 CET
                                 Universal time: Sun 2025-03-23 14:50:08 UTC
                                       RTC time: Sun 2025-03-23 14:50:08
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      peter
                      HOME=/home/peter
                      GROUPS=peter cdrom floppy sudo audio dip video plugdev users netdev lpadmin scanner iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                      *** MEMORY ***
                      Mem:             16G        1.6G         13G         33M        1.6G         14G
                      Swap:           1.0G          0B        1.0G
                      Total:           17G        1.6G         14G
                      Active iob-Instances:   8
                              15762 M total memory
                               1502 M used memory
                                907 M active memory
                               1540 M inactive memory
                              13029 M free memory
                                669 M buffer memory
                                889 M swap cache
                                976 M total swap
                                  0 M used swap
                                976 M free swap
                      top - 15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
                      Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :  15762.3 total,  13028.9 free,   1503.6 used,   1559.3 buff/cache
                      MiB Swap:    977.0 total,    977.0 free,      0.0 used.  14258.7 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      udev           devtmpfs  7.7G     0  7.7G   0% /dev
                      tmpfs          tmpfs     1.6G  1.4M  1.6G   1% /run
                      /dev/sda2      ext4      233G  8.4G  213G   4% /
                      tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
                      tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
                      /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
                      tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run/user/107
                      tmpfs          tmpfs     1.6G   64K  1.6G   1% /run/user/1000
                      [Thu Mar 20 16:43:27 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Thu Mar 20 16:43:28 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
                      Show mounted filesystems:
                      TARGET      SOURCE    FSTYPE OPTIONS
                      /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
                      `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                      /var:
                      870M    /var/
                      376M    /var/cache
                      357M    /var/cache/apt
                      315M    /var/lib
                      279M    /var/cache/apt/archives
                      Archived and active journals take up 11.9M in the file system.
                      /opt/iobroker/backups:
                      4.0K    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      240M    /opt/iobroker/iobroker-data/
                      181M    /opt/iobroker/iobroker-data/files
                      158M    /opt/iobroker/iobroker-data/files/admin.admin
                      157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                      13M     /opt/iobroker/iobroker-data/objects.jsonl
                      7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
                      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                      7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v20.19.0
                      /usr/bin/node           v20.19.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.31.0
                      nodejs:
                        Installed: 20.19.0-1nodesource1
                        Candidate: 20.19.0-1nodesource1
                        Version table:
                       *** 20.19.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                           20.18.3-1nodesource1 1001
                           20.18.2-1nodesource1 1001
                           20.18.1-1nodesource1 1001
                           20.18.0-1nodesource1 1001
                           20.17.0-1nodesource1 1001
                           20.16.0-1nodesource1 1001
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                           18.19.0+dfsg-6~deb12u2 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      debianiob           debianiob (version: 7.0.6, hostname: debianiob     , alive, uptime: 255987)
                      Core adapters versions
                      admin:          7.4.10
                      javascript:     "javascript" not found
                      nodejs modules from github:     0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : debianiob                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.backitup.0               : backitup              : debianiob                                - disabled
                      + system.adapter.discovery.0              : discovery             : debianiob                                -  enabled
                      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : debianiob                                -  enabled
                      + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : debianiob                                -  enabled
                      + system.adapter.fronius.0                : fronius               : debianiob                                -  enabled
                        system.adapter.fronius.1                : fronius               : debianiob                                - disabled
                        system.adapter.fronius.2                : fronius               : debianiob                                - disabled
                        system.adapter.fronius.3                : fronius               : debianiob                                - disabled
                      + system.adapter.influxdb.0               : influxdb              : debianiob                                -  enabled, port: 8086
                        system.adapter.shelly.0                 : shelly                : debianiob                                - disabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shelly.1                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Used repository: stable
                      Adapter    "admin"        : 7.4.10   , installed 7.4.10
                      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                      Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
                      Controller "js-controller": 7.0.6    , installed 7.0.6
                      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                      Objects and States
                      Objects:        5688
                      States:         4438
                      W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                      W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                      Hit:6 https://packages.grafana.com/enterprise/deb stable InRelease
                      Reading package lists...
                      Pending Updates: 1
                      *** Listening Ports ***
                      tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          20864      581/brltty
                      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      112        18219      652/influxd
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14588      1/init
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22684      677/sshd: /usr/sbin
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23135      653/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18293      653/iobroker.js-con
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1161295    5328/cupsd
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1161294    5328/cupsd
                      tcp6       0      0 :::8086                 :::*                    LISTEN      112        18242      652/influxd
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24645      835/io.admin.0
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          14589      1/init
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          22686      677/sshd: /usr/sbin
                      tcp6       0      0 ::1:4101                :::*                    LISTEN      0          22589      581/brltty
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1607       1/init
                      udp        0      0 0.0.0.0:54464           0.0.0.0:*                           103        20852      591/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        20850      591/avahi-daemon: r
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24918      1062/io.shelly.1
                      udp6       0      0 :::111                  :::*                                0          1608       1/init
                      udp6       0      0 fe80::4e52:62ff:fe1:546 :::*                                0          1454426    606/NetworkManager
                      udp6       0      0 :::59684                :::*                                103        20853      591/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                103        20851      591/avahi-daemon: r
                                              v.2025-02-23
                               Chassis: desktop 🖥️
                      Kernel:                 x86_64
                      Userland:               64 bit
                      Timezone:               Europe/Berlin (CET, +0100)
                      User-ID:                1000
                      Pending OS-Updates:     1
                      Pending iob updates:    0
                      Nodejs-Installation:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      Recommended versions are nodejs 20.19.0 and npm 10.8.2
                      nodeJS installation is correct
                      MEMORY:
                      Swap:           1.0G          0B        1.0G
                      Total:           17G        1.6G         14G
                      ioBroker Core:          js-controller           7.0.6
                                              admin                   7.4.10
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                5688
                      States:                 4438
                      Size of iob-Database:
                      4.5M    /opt/iobroker/iobroker-data/states.jsonl
                        Script v.2025-02-23
                        *** BASE SYSTEM ***
                                 Chassis: desktop 🖥️
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 4
                                      NTP service: active
                                  RTC in local TZ: no
                        peter
                        HOME=/home/peter
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:           1.0G          0B        1.0G
                        Total:           17G        1.6G         14G
                                 1502 M used memory
                                  907 M active memory
                                13029 M free memory
                                  669 M buffer memory
                                  889 M swap cache
                                  976 M total swap
                                    0 M used swap
                                  976 M free swap
                        *** FILESYSTEM ***
                        /var:
                        870M    /var/
                        376M    /var/cache
                        357M    /var/cache/apt
                        315M    /var/lib
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.4.10
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        5688
                        States:         4438
                        Pending Updates: 1
                                                v.2025-02-23
                                 Chassis: desktop 🖥️
                        Kernel:                 x86_64
                        Userland:               64 bit
                        User-ID:                1000
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        MEMORY:
                        Swap:           1.0G          0B        1.0G
                        Total:           17G        1.6G         14G
                                                admin                   7.4.10
                        Objects type: jsonl
                        States  type: jsonl
                        Objects:                5688
                        States:                 4438
                        T Nicht stören
                        T Nicht stören
                        ticaki
                        @pille0557
                        Hast du auf den Test Connection button gedrückt?
                        Spenden
                        • T ticaki
                          @pille0557
                          pille0557P Offline
                          pille0557P Offline
                          pille0557
                          @ticaki said in 2 iobroker installationen ...:
                          @pille0557
                          ja habe ich auch schon, keine Info als Ergebnis
                          HomoranH T 2 Antworten Letzte Antwort
                            @pille0557
                            @pille0557 ist da vielleicht noch ein Leerzeichen o.ä. in der Adresse?
                              @pille0557
                              T Nicht stören
                              T Nicht stören
                              ticaki
                              @pille0557
                              Dann schalte den Adapter mal in den Debugmodus - da sollte mehr an infos kommen.
                              Spenden
                              • T ticaki
                                @pille0557
                                pille0557P Offline
                                pille0557P Offline
                                pille0557
                                @ticaki
                                2025-03-23 17:04:23.191 - error: fronius.0 (11921) Please configure the Fronius adapter
                                2025-03-23 17:04:27.896 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                                2025-03-23 17:33:21.021 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                                2025-03-23 17:33:32.189 - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                                2025-03-23 17:33:32.193 - info: fronius.0 (11921) Got terminate signal TERMINATE_YOURSELF
                                2025-03-23 17:33:32.257 - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                                2025-03-23 17:33:32.695 - info: fronius.0 (11921) terminating
                                2025-03-23 17:33:32.696 - info: fronius.0 (11921) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2025-03-23 17:33:33.267 - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2025-03-23 17:33:36.493 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 14290
                                2025-03-23 17:33:37.435 - debug: fronius.0 (14290) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2025-03-23 17:33:37.472 - debug: fronius.0 (14290) Objects client ready ... initialize now
                                2025-03-23 17:33:37.473 - debug: fronius.0 (14290) Objects create System PubSub Client
                                2025-03-23 17:33:37.474 - debug: fronius.0 (14290) Objects create User PubSub Client
                                2025-03-23 17:33:37.505 - debug: fronius.0 (14290) Objects client initialize lua scripts
                                2025-03-23 17:33:37.510 - debug: fronius.0 (14290) Objects connected to redis: 127.0.0.1:9001
                                2025-03-23 17:33:37.531 - debug: fronius.0 (14290) Redis States: Use Redis connection: 127.0.0.1:9000
                                2025-03-23 17:33:37.540 - debug: fronius.0 (14290) States create System PubSub Client
                                2025-03-23 17:33:37.541 - debug: fronius.0 (14290) States create User PubSub Client
                                2025-03-23 17:33:37.597 - debug: fronius.0 (14290) States connected to redis: 127.0.0.1:9000
                                2025-03-23 17:33:37.666 - info: fronius.0 (14290) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                                2025-03-23 17:33:37.678 - error: fronius.0 (14290) Please configure the Fronius adapter
                                2025-03-23 17:33:38.184 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                                  @ticaki
                                  pille0557P Offline
                                  pille0557P Offline
                                  pille0557
                                  @pille0557
                                  danke für die Hilfe, ich werde die Kiste mal neu aufsetzen ...
                                  damit ich grafana mit meinem älteren iPad in der Küche als Statusanzeigen benutzen kann, muss ich sowieso eine ältere Grafana Version installieren, ein downgrade wird wohl auch nicht einfach
                                    @pille0557
                                    Meister MopperM Offline
                                    Meister Mopper
                                    @pille0557
                                    Da muss nur die ältere Version gepinnt werden.
                                    Ein wenig aufwändiger wird es lediglich, wenn du major upgrades verhindern möchtest. Das ist aber auch kein Hexenwerk.
                                    Proxmox und HA ...
