  4. [Vorlage] Servicemeldungen Volume2
    6.6k
224 Beiträge 14 Kommentatoren 63.2k Aufrufe 24 Beobachtet
  • Eduard77E Eduard77
    @looxer01
    ich habe die stelle ausgetauscht und bekomme beim Skriptstart folgende Fehler.
    javascript.0	20:54:51.514	info	Stopping script script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint
    javascript.0	20:56:05.774	info	Start JavaScript script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint (Javascript/js)
    javascript.0	20:56:05.778	error	script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint compile failed: at script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint:1173
    Und folgenses im LOG.
    2025-02-28 20:54:48.578 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.178.20
    2025-02-28 20:54:51.514 - info: javascript.0 (92966) Stopping script script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint
    2025-02-28 20:56:05.774 - info: javascript.0 (92966) Start JavaScript script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint (Javascript/js)
    2025-02-28 20:56:05.778 - error: javascript.0 (92966) script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint compile failed:
    2025-02-28 20:56:05.779 - error: javascript.0 (92966) })();
    2025-02-28 20:56:05.779 - error: javascript.0 (92966) ^
    2025-02-28 20:56:05.779 - error: javascript.0 (92966) SyntaxError: Unexpected token '}'
    2025-02-28 20:56:05.779 - error: javascript.0 (92966) at new Script (node:vm:117:7)
    2025-02-28 20:56:05.779 - error: javascript.0 (92966) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1956:21)
    2025-02-28 20:56:05.779 - error: javascript.0 (92966) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2224:37)
    2025-02-28 20:56:05.779 - error: javascript.0 (92966) at /opt/iobroker/node_modules/iobroker.javascript/main.js:2322:17
    2025-02-28 20:56:05.779 - error: javascript.0 (92966) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1732:17)
    2025-02-28 20:56:05.779 - error: javascript.0 (92966) at processImmediate (node:internal/timers:485:21)
    2025-02-28 20:56:57.027 - info: admin.0 (329) <== Disconnect system.user.admin from ::ffff:192.168.178.20 javascript
    looxer01
    #195
    @edis77
    ja, ist nicht richtig reinkopiert. lösche die Zeilen 273 - 386
    und kopier nochmal die Sequenz wie zuvor gepostet.
    vG Looxer
    • Eduard77E Offline
      Eduard77E Offline
      Eduard77
      #196
      @looxer01
      Habe jetzt so gemacht wie du beschreiben hast, aber bekomme wieder Warnung.
      anbei mein geänderte Skript zur Prüfung.
      // Beschreibung des Scriptes: https://forum.iobroker.net/topic/77816/vorlage-servicemeldungen-volume2
      // Autor Looxer01 02.11.2024 Version 1.0 (initiale Version)
      // Version 3.00 - 05.01.2025 Variable MessageBeiKeinerSM in die Experteneinstellungen geschoben // Problem bei der Datumsberechnung behoben // Zaehler fuer Historie hinzugefuegt
      //                           die Datenpunkte fuer Text-Format werden jetzt optional gefuellt
      // Version 3.10 - 01.02.2024 Wartezeit fuer HM-Rega von 2 auf 3,5 Sekunden erhoeht - Funktion der Tabelle MessengerScope erweitert
      // Version 3.20 - 24.02.2024 Doppelte Nachrichten im messageCollector verhindern - Vermeidung Meldung "keine Servicemeldungen..." in der Historie wenn bereits vorhanden - Wartezeit für Rega-Trigger wieder auf 5s
      //                           StickyMessages koennen automatisch bestaetigt werden
      // Muss-Einstellungen                                 ( HM-Classic , HMIP, Wired - hier muessen zwingend die Instanzen stimmmen )
      // Im folgenden sind die Instanzen gelistet fuer die die Selektion erfolgt bzw nicht erfolgt (Filter)
      // bitte 9 Eintragen falls eine Instanz nicht relevant ist // Gruppeninstanzen sind normalerweise nicht relevant
      // CuxD Instanzen duerfen nicht eingetragen werden  --- ACHTUNG: bei HMIPAccessPoint-Nutzung muss GeraeteTriggerID auf true stehen
      const HMClassicInstanz      = 9;        // HM-Classic Instanz eintragen     // 9 = falls nicht relevant
      const HMIPInstanz           = 9;        // Homematic IP instanz             // 9 = falls nicht relevant
      const WiredIClassicInstanz  = 9;        // Wired Instanz                    // 9 = falls nicht relevant
      const GruppenInstanz        = 9;        // virtuelle GeraeteInstanz- 9 = nicht relevant - Die Gruppen werden i.d.R. nicht gebraucht - Empfehlung: 9
      let   HMIPAccessPoint       = 0;        // AccessPoint Servicemeldungen - (normalerweise instanz = 0) bei nicht Verwendung Instanz = 9
      // Kann-Einstellungen
      // Pfad kann angepasst werden fuer userdata pfad einfach // entfernen
      const path      = "javascript.0.ServicemeldungenVol2.";
      //const path    = "0_userdata.0.ServicemeldungenVol2."; // alternativ zum javascript pfad
      // schreibt das Protokoll der Servicemeldungen in ein externes file (Excel Format)
      const SMProtokoll = true;
      const PathSMLog = "/opt/iobroker/log/ServicemeldungenVol2.csv";             // Pfad und Dateiname des externen Logs
      //const PathSMLog = "/iobroker/log/ServicemeldungenVol2.csv";            // Pfad fuer Windows/  iobroker ist der angenommene iobroker home-pfad
      //Geraete die nicht ueberwacht werden sollen. Geraete-IDs eingeben - Komma getrennt erfassen
      const Ausschlussliste = ['0000D7099xxx26', '00091D8xxx7410']; // immer mit Komma trennen // Filter auf Einzel-IDs
      // debug level kann eingestellt werden - wenn alles laeuft dann 0 = ruhe im log
      // debug level 0   kein log // debug level 1 - nur die wichtigsten Meldungen werden gelistet // debug level 2 - mehr als nur die wichtigsten Meldungen aber ohne einzelne IDs
      // debug level 3 - hier werden auch einzelne IDs gelistet (koennten lange listen werden)
      const debugLevel = 2 ;     // Empfehlung = 1
      const SystemLog = false;  // schreib das Sytemprotokoll in ein externes log (sollte normalerweise deaktviert sein  nur bei Problemen verwenden)
      const PathSystemLog = "/opt/iobroker/log/ServicemeldungenSystemLog.csv";             // Pfad und Dateiname des externen Logs
      //const PathSystemLog = "/iobroker/log/ServicemeldungenSystemLog.csv";             // Pfad fuer Windows
      // wenn GeraeteIDTrigger auf true gestellt wird, dann wird fuer jeden Datenpukt mit Relevanz fuer eine Servicemeldung eine subscription angelegt.
      // Vorteile: mehr Details in der Historie von Servicemeldungen: Nachteil: bei 80 CCU Geraeten ungefaehr 300 Susbsriptions
      // Wenn die variable auf false steht, dann wird auf hm.rega.0.maintenance eine subsription angelegt: Vorteil: 1 Subscription , Nachteil: erweiterte Funktion fuer nicht CCU Datenpunkte nicht verfuegbar
      // bei HMIP AccessPoint Cloud HCU - funktioniert das nur bei GeraeteTrigger = true
      let GeraeteIDTrigger = false; // true = viele subscriptions aber praezise Historie der Servicemeldungen - false = 1 subscription - weniger praezise Historie - Empfehlung = false
      // Speicherung der Servicemeldungen im  Text-Format - Empfehlung = false // davon ausgehend, dass das JSON Format in der Visualisierung gut dargestellt werden kann
      const UpdateTEXT_Datenpunkte = false; // die kurz- und langen Servicemeldungen als auch die historischen werden immer im JSON Format abgelegt. Alternativ koennen diese auch in einem TEXT Format in Datenpunkten gespeichert werden
      // Speicherung der Servicemeldungen im  HTML-Format - Wird empfohlen zu nutzen, wenn es Problem bei der Visualisierung von JSON gibt.
      const UpdateHTML_Datenpunkte = true; // die langen Servicemeldungen als auch die historischen werden immer im JSON Format abgelegt. Alternativ koennen diese auch in einem HTML Format in Datenpunkten gespeichert werden
      // Die Autobestaetigung bestaetigt automatisch evt Sticky-Meldungen der CCU
      const AutoBestaetigungCCUMeldungen = true; // Empfehlung ist true - nur relevant fur HM-Classic Geraete //bei true sollte in der CCU die autobestaetigung ausgeschaltet werden
      //  fuer alle Spalten mit true werden die Nachrichten ueber den zugeordneten Dienst versendet, vorausgesetzt der Messenge Adapter ist in iobroker installiert/konfiguriert
          const services =               ['email',    'whatsApp',     'Signal',  'Telegram',    'Pushover', 'Pushsafer', 'Pushsafer',];
          const MessengerScope = {
          'UNREACH_ALARM':                [true,        false,          false,      true,          false,      false,       false,],
          'STICKY_UNREACH_ALARM':         [false,       false,          false,      false,          false,      false,       false,],   // Sticky sollte nicht gesendet werden - alles auf false setzen
          'LOWBAT_ALARM':                 [true,        false,          false,      true,          false,      false,       false,],
          'SABOTAGE_ALARM':               [true,        false,          false,      true,          false,      false,       false,],
          'STICKY_SABOTAGE_ALARM':        [false,       false,          false,      false,          false,      false,       false,],   // Sticky sollte nicht gesendet werden - alles auf false setzen
          'CONFIG_PENDING_ALARM':         [true,        false,          false,      true,          false,      false,       false,],
          'Sonstige':                     [true,        false,          false,      true,          false,      false,       false,], // text ist fest verdrahtet nicht ändern
          'keineSM':                      [true,        false,          false,      true,          false,      false,       false,], // text ist fest verdrahtet nicht ändern
          const MessengerInstanz =        [0,             0,               0,          0,              0,          0,            1,  ]; // Instanz des Messengers
          const TextTypeKurz      =       [false,        true,            true,       true,           true,      true,         false,]; // bei true wird der Kurztext gesendet - sonst der Langtext
      // email-Einstellungen
      let emailAddresse = "Vorname-Nachname@web.de"   // Empfängeraddresse
      const Headline = "ioBroker Servicemeldung";     // Ueberschrift Messages fuer email und Pushsafer
      // telegram Einstellungen
      const TelegramUser = "Eduard";
      //Experten Einstellungen - Empfehlung:  Absprache mit dem Autor
      const MessageBeiKeinerSM = 'Derzeit keine Servicemeldungen'     // Text der erscheinen soll, wenn keine SM vorliegen Ein Kurztext ist erforderlich
      //const NichtRelevantText = 'n/a';                                // statt n/a kann ein beliebiger anderer Text in den JSON verwendet werden
      const NichtRelevantText = "......";
      // die folgenden Einstellungen sind nur relvant bei Verwendung von HTML als Datenpunkte
          // Definieren der Farbwerte für Kopfzeile, gerade und ungerade Zeilen
          const headerColor = '#333333';  // Standardfarbe (Fuellfarbe) für die Kopfzeile
          const evenRowColor = '#4e5049'; // Standardfarbe (Fuellfarbe) für gerade Zeilen
          const oddRowColor = '#333333';  // Standardfarbe (Fuellfarbe) für ungerade Zeilen
          // Definieren der Textfarben für Kopfzeile, gerade und ungerade Zeilen
          const headerTextColor = 'white'; // Textfarbe für Kopfzeile
          const evenRowTextColor = 'white'; // Textfarbe für gerade Zeilen
          const oddRowTextColor = 'white';  // Textfarbe für ungerade Zeilen
          // Definieren von Zellenumrandungseinstellungen
          const useBorderAll =    true; // true, wenn ein Gitternetz erzeugt werden soll
          const borderColor = '#000000'; // Farbe des Gitternetzes (Zellenumrandung)
          const borderWidth = '1px'; // Strichstärke der Zellenumrandung
      //Schedule Zeit fuer refresh der Historie
      const ScheduleAktiv = true;                         // Bei "false" wird der schedule nicht durchlaufen. Manuelles Löschen kann über den Datenpunkt id_Button_Refresh_Historie (Button) möglich
      const scheduleTimeClearSMTexte = "2 0 1 * *";       // am 1. tag des monats um 00:02 morgens sollen alle Servicemeldungen des Monats geloescht werden
      // const scheduleTimeClearSMTexte = "58 23 * * 0";  // alternative Sonntags um 23:58 Uhr sollen alle Servicemeldungen der Woche im datenpunkt der SM-Texte geloescht werden
      //Batterie-Zuordnungen fuer Servicmeldungen
      const batteryTypes = {
          '1x CR2016':    ['HM-RC-4', 'HM-RC-4-B', 'HM-RC-Key3', 'HM-RC-Key3-B', 'HM-RC-P1', 'HM-RC-Sec3', 'HM-RC-Sec3-B', 'ZEL STG RM HS 4'],
          '1x CR2032':    ['HM-PB-2-WM', 'HM-PB-4-WM', 'HM-PBI-4-FM', 'HM-SCI-3-FM', 'HM-Sec-TiS', 'HM-SwI-3-FM', 'HmIP-FCI1'],
          '2x LR14':      ['HM-Sec-Sir-WM', 'HM-OU-CFM-TW', 'HM-OU-CFM-Pl', 'HM-OU-CF-Pl'],
          '2x LR44/AG13': ['HM-Sec-SC', 'HM-Sec-SC2L', 'HM-Sec-SC-2', 'HM-Sec-RHS'],
          '2x LR6/AA':    ['HM-CC-VD', 'HM-CC-RT-DN', 'HM-Sec-WDS', 'HM-Sec-WDS-2', 'HM-CC-TC', 'HM-Dis-TD-T', 'HB-UW-Sen-THPL-I', 'HM-WDS40-TH-I', 'HM-WDS40-TH-I-2',
                           'HM-WDS10-TH-O', 'HmIP-SMI',                     'HMIP-eTRV', 'HM-WDS30-OT2-SM-2', 'HmIP-SMO', 'HmIP-SMO-A', 'HmIP-SPI', 'HmIP-eTRV-2',
                           'HmIP-SPDR', 'HmIP-STHO-A', 'HmIP-eTRV-B', 'HmIP-PCBS-BAT', 'HmIP-STHO', 'HmIP-eTRV-C',
                           'HmIP-WGC', 'HmIP-eTRV-C-2', 'HmIP-eTRV-E', 'HmIP-eTRV-2 I9F', 'HmIP-eTRV-E-S', 'ELV-SH-SW1-BAT'],
          '3x LR6/AA':    ['HmIP-SWO-PL', 'HM-Sec-MDIR', 'HM-Sec-MDIR-2', 'HM-Sec-SD', 'HM-Sec-Key', 'HM-Sec-Key-S', 'HM-Sec-Key-O', 'HM-Sen-Wa-Od', 'HM-Sen-MDIR',
                           'HM-Sen-MDIR-O', 'HM-Sen-MDIR-O-2', 'HM-WDS100-C6-O', 'HM-WDS100-C6-O-2', 'HmIP-ASIR', 'HmIP-SWO-B', 'HM-Sen-MDIR-O-3', 'HM-Sec-MDIR-3',
                           'HmIP-SWO-PR', 'HmIP-DLD', 'HmIP-ASIR-2'],
          '4x LR6/AA':    ['HM-CCU-1', 'HM-ES-TX-WM', 'HM-WDC7000'],
          '1x LR3/AAA':   ['HM-RC-4-2', 'HM-RC-4-3', 'HM-RC-Key4-2', 'HM-RC-Key4-3', 'HM-RC-Sec4-2', 'HM-RC-Sec4-3', 'HM-Sec-RHS-2', 'HM-Sec-SCo', 'HmIP-KRC4',
                           'HmIP-KRCA', 'HmIP-SRH', 'HMIP-SWDO', 'HmIP-DBB', 'HmIP-RCB1', 'HmIP-KRCK', 'HmIP-SWDO-2'],
          '2x LR3/AAA':   ['HmIP-WRCR', 'HmIP-SWD','HM-TC-IT-WM-W-EU', 'HM-Dis-WM55', 'HM-Dis-EP-WM55', 'HM-PB-2-WM55', 'HM-PB-2-WM55-2', 'HM-PB-6-WM55', 'HM-PBI-2-FM', 'HM-RC-8', 'HM-Sen-DB-PCB',
                          'HM-Sen-EP', 'HM-Sen-MDIR-SM', 'HM-Sen-MDIR-WM55', 'HM-WDS30-T-O', 'HM-WDS30-OT2-SM', 'HmIP-STH', 'HmIP-STHD', 'HmIP-WRC2', 'HmIP-WRC6', 'HmIP-WTH', 'HmIP-WTH-2',
                          'HmIP-SAM', 'HmIP-SLO', 'HMIP-SWDO-I', 'HmIP-FCI6', 'HmIP-SMI55', 'HM-PB-2-FM', 'HmIP-SWDM', 'HmIP-SCI', 'HmIP-SWDM-B2', 'HmIP-RC8', 'ALPHA-IP-RBG', 'HmIP-DSD-PCB',
                          'HmIP-WRCD', 'HmIP-WRC2-A', 'HmIP-WTH-B-2', 'HmIP-WTH-A', 'HmIP-STV', 'HmIP-WKP'],
          '3x LR3/AAA':   ['HM-PB-4Dis-WM', 'HM-PB-4Dis-WM-2', 'HM-RC-Dis-H-x-EU', 'HM-Sen-LI-O'],
          '3x AAA Akkus - bitte laden': ['HM-RC-19', 'HM-RC-19-B', 'HM-RC-12', 'HM-RC-12-B', 'HM-RC-12-W'],
          '3x LR14/C':    ['HmIP-MP3P'],
          '9Volt Block leer oder unbestimmt': ['HM-LC-Sw1-Ba-PCB', 'HM-LC-Sw4-PCB', 'HM-MOD-EM-8', 'HM-MOD-Re-8', 'HM-Sen-RD-O', 'HM-OU-CM-PCB', 'HM-LC-Sw4-WM'],
          'Festbatterie leer': ['HmIP-STE2-PCB', 'HM-Sec-SD-2', 'HmIP-SWSD', 'HmIP-PCBS'],
          'ohne Batterie': ['HM-LC-Sw1PBU-FM', 'HM-LC-Sw1-Pl-DN-R1', 'HM-LC-Sw1-DR', 'HM-LC-RGBW-WM', 'HM-LC-Sw1-Pl-CT-R1', 'HmIP-HEATING', 'HM-LC-Sw1-FM', 'HM-LC-Sw2-FM', 'HM-LC-Sw4-DR',
                              'HM-LC-Sw1-Pl', 'HM-LC-Sw1-Pl-2', 'HM-LC-Sw4-Ba-PCB', 'HM-LC-Sw1-SM', 'HM-LC-Sw4-SM', 'HM-Sys-sRP-Pl', 'HM-LC-Sw2PBU-FM', 'HM-LC-Sw1-PCB', 'HM-LC-Sw4-DR-2'],
          'Akku entladen - bitte aufladen': ['HM-Sec-Win', 'HM-Sec-SFA-SM', 'HM-RC-19-SW']
      // Rega Pfad
      const PathRega = ['hm-rega.0.maintenance',];                            // Array um ggf die HCU zu konfigurieren
      // Pfade fuer die Speicherung aktueller und vergangener Servicemeldungen
      const id_Text_ServicemeldungLang        = path+'TextLangAktuelleSM';    // Objekt wo die Servicemeldung hingeschrieben werden soll (String) = path+'TextLang';
      const id_Text_ServicemeldungKurz        = path+'TextKurzAktuelleSM';    // Objekt wo die Servicemeldung hingeschrieben werden soll (String) - kurze Version
      const id_Text_Servicemeldung_History    = path+'TextLangVergangeneSM';  // Objekt wo die Servicemeldung hinzugefuegt werden soll (String) - Lange Version (es gibt nur lang)
      const id_HTML_Servicemeldung_Aktuell    = path+'HtmlAktuelleSM';        // Objekt wo die Servicemeldung hingeschrieben werden soll (HTML formatiere Tabelle) = path+'htmlLang';
      const id_HTML_Servicemeldung_History    = path+'HtmlVergangeneSM';      // Objekt wo die Servicemeldung hinzugefuegt werden soll ((HTML formatiere Tabelle) - Lange Version (es gibt nur lang)
      const id_JSON_Servicemeldung_Aktuell    = path+'JSONAktuelleSM';        // JSON Tabelle Datenpunkt Aktuelle SM
      const id_JSON_Servicemeldung_Historie   = path+'JSONVergangeneSM';      // JSON Tabelle Datenpunkt Historische SM
      const id_Button_Refresh_Historie        = path+'ButtonRefreshHistorie'; // Wenn DP auf true gesetzt wird, dann wird die historie refreshed (geloescht)
      // Count-Pfade  und counts in einer Tabelle - wird auch fuer CREATE STATES verwendet
      const Zaehler = [
        { alarmtype: 'UNREACH_ALARM',                    count: 0,                    Datenpunkt: path+'Anzahl_UNREACH' },
        { alarmtype: 'STICKY_UNREACH_ALARM',             count: 0,                    Datenpunkt: path+'Anzahl_STICKY_UNREACH' },
        { alarmtype: 'CONFIG_PENDING_ALARM',             count: 0,                    Datenpunkt: path+'Anzahl_CONFIG_PENDING' },
        { alarmtype: 'UPDATE_PENDING_ALARM',             count: 0,                    Datenpunkt: path+'Anzahl_Update_PENDING' },
        { alarmtype: 'LOWBAT_ALARM',                     count: 0,                    Datenpunkt: path+'Anzahl_LOWBAT' },
        { alarmtype: 'DEVICE_IN_BOOTLOADER_ALARM',       count: 0,                    Datenpunkt: path+'Anzahl_DEVICE_IN_BOOTLOADER' },
        { alarmtype: 'ERROR',                            count: 0,                    Datenpunkt: path+'Anzahl_in_ERROR' },
        { alarmtype: 'FAULT_REPORTING',                  count: 0,                    Datenpunkt: path+'Anzahl_FAULT_REPORTING' },
        { alarmtype: 'SABOTAGE_ALARM',                   count: 0,                    Datenpunkt: path+'Anzahl_SABOTAGE' },
        { alarmtype: 'ERROR_NON_FLAT_POSITIONING_ALARM', count: 0,                    Datenpunkt: path+'Anzahl_NON_FLAT_POSITIONING' },
        { alarmtype: 'STICKY_SABOTAGE_ALARM',            count: 0,                    Datenpunkt: path+'Anzahl_Sticky_SABOTAGE' },
        { alarmtype: 'SMAktuell',                        count: 0,                    Datenpunkt: path+'Anzahl_SM-Aktuell' },
        { alarmtype: 'SMHistorie',                       count: 0,                    Datenpunkt: path+'Anzahl_SM-Historie' },
        { alarmtype: 'Gesamt',                           count: 0,                    Datenpunkt: path+'Anzahl_GESAMT' }
      // statusmessages je messagetype und   adapter // Fallback ist fuer unbekannte messagetypes - z.B. alle Error Messages // FALLBACK repraesentiert Standardmessages
      const statusMessages = {
          UNREACH_ALARM:                    { "hm-rpc": { 0: "keine Kommunikationsfehler",     1: "Kommunikation gestoert",                            2: "Kommunikation war gestoert" } },
          STICKY_UNREACH_ALARM:             { "hm-rpc": { 0: "keine Kommunikationsfehler",     1: "Sticky Kommunikation gestoert",                     2: "Sticky Kommunikation war gestoert" } },
          SABOTAGE_ALARM:                   { "hm-rpc": { 0: "Keine Sabotage",                 1: "Sabotage",                                          2: "Sabotage aufgehoben" } },
          STICKY_SABOTAGE_ALARM:            { "hm-rpc": { 0: "Keine Sabotage",                 1: "Sticky Sabotage",                                   2: "Sticky Sabotage aufgehoben" } },
          LOWBAT_ALARM:                     { "hm-rpc": { 0: "Batterie ok",                    1: "Batterie niedrig",                                  2: "Batterie ok" } },
          LOW_BAT_ALARM:                    { "hm-rpc": { 0: "Batterie ok",                    1: "Batterie niedrig",                                  2: "Batterie ok" } },
          ERROR_NON_FLAT_POSITIONING_ALARM: { "hm-rpc": { 0: "Keine Meldung",                  1: "Geraet wurde angehoben.",                           2: "Geraet wurde angehoben: Bestaetigt" } },
          CONFIG_PENDING_ALARM:             { "hm-rpc": { 0: "keine Meldung",                  1: "Konfigurationsdaten stehen zur Uebertragung an",    2: "Konfigurationsdaten standen zur Uebertragung an",}, },
          UPDATE_PENDING_ALARM:             { "hm-rpc": { 0: "kein Update verfuegbar",         1: "Update verfuegbar",                                 2: "Update wurde eingespielt" } },
          ERROR_OVERHEAT_ALARM:             { "hm-rpc": { 0: "kein Overheat Alarm",            1: "Overheat gemeldet",                                 2: "Overheat geloest" } },
          ERROR_UNDERVOLTAGE_ALARM:         { "hm-rpc": { 0: "Kein Undervoltage Alarm",        1: "Undervoltage gemeldet",                             2: "Undervoltage geloest" } },
          DEVICE_IN_BOOTLOADER_ALARM:       { "hm-rpc": { 0: "Keine Meldung",                  1: "Geraet startet neu",                                2: "Geraet wurde neu gestartet" } },
          DUTY_CYCLE:                       { "hm-rpc": { false: "Geraete-Duty Cycle ok",      true: "Geraete-Duty Cycle erreicht",                    null: "unbekannter Status (Duty_Cycle" } },
          lowBat:                           { "hmip":   { false: "Batterie ok",                true: "Batterie niedrig",                               null: "Batterie ok" } },
          unreach:                          { "hmip":   { false: "keine Kommunikationsfehler", true: "Kommunikation gestoert",                         null: "Kommunikation war gestoert" } },
          sabotage:                         { "hmip":   { false: "Keine Sabotage",             true: "Sabotage",                                       null: "Sabotage aufgehoben" } },
          configPending:                    { "hmip":   { false: "Keine Meldung",              true: "Konfigurationsdaten stehen zur Uebertragung an", null: "Konfigurationsdaten standen zur Uebertragung an" } },
          FALLBACK:                         { "hm-rpc": { 0: "keine Stoerung",                 1: "Stoerung",                                          2: "Stoerung aufgehoben",
                                                          false: "Keine Stoerung",             true: "Stoerung",                                       null: "unbekannter Status Fallback"},
                                              "hmip":   { false: "keine Stoerung",             true: "Stoerung",                                       null: "Stoerung aufgehoben" }, }
      //ErrorMessages fuer HM-Classic Geraete - Sonderfaelle
      const errorMessages = {
          'HM-Sec-RHS':   { 7: 'Sabotage' },
          'HM-Sec-RHS-2': { 7: 'Sabotage' },
          'HM-Sec-SC':    { 7: 'Sabotage' },
          'HM-Sec-SC-2':  { 7: 'Sabotage' },
          'HM-Sec-SCo':   { 7: 'Sabotage' },
          'HM-Sec-MD':    { 7: 'Sabotage' },
          'HM-Sec-MDIR':  { 7: 'Sabotage' },
          'HM-Sec-MDIR-2':{ 7: 'Sabotage' },
          'HM-Sec-Key':   { 1: 'Einkuppeln fehlgeschlagen', 2: 'Motorlauf abgebrochen' },
          'HM-Sec-Key-S': { 1: 'Einkuppeln fehlgeschlagen', 2: 'Motorlauf abgebrochen' },
          'HM-Sec-Key-O': { 1: 'Einkuppeln fehlgeschlagen', 2: 'Motorlauf abgebrochen' },
          'HM-CC-VD':     { 1: 'Ventil Antrieb blockiert',  2: 'Ventil nicht montiert', 3: 'Stellbereich zu klein', 4: 'Batteriezustand niedrig'
      //ErrorMessages fuer HM-Classic Geraet (Heizung) - Sonderfaelle
      const faultMessages = {
          'HM-CC-RT-DN': {
              0: 'keine Stoerung',
              1: 'Ventil blockiert',
              2: 'Einstellbereich Ventil zu gross',
              3: 'Einstellbereich Ventil zu klein',
              4: 'Kommunikationsfehler',
              6: 'Spannung Batterien/Akkus gering',
              7: 'Fehlstellung Ventil'
      // hier koennen die Alarmgruppen ggf erweitert werden - Aus Alarmgruppe und Instanz wird der Selector gebastelt und in Tabelle Selectors gesammelt
      const alarmTypes = [
          { key: 'UNREACH_ALARM',                     suffixes: ['UNREACH_ALARM','unreach' ] },//UNREACH_ALARM = HM-Classic & HMIP-CCU - unreach = HMIP Accesspoint
         // { key: 'STICKY_UNREACH_ALARM',              suffixes: ['STICKY_UNREACH_ALARM'] },
          { key: 'CONFIG_PENDING_ALARM',              suffixes: ['CONFIG_PENDING_ALARM','configPending'] }, //configPending ist eine HMIP Meldung
          { key: 'UPDATE_PENDING_ALARM',              suffixes: ['UPDATE_PENDING_ALARM'] },
          { key: 'LOWBAT_ALARM',                      suffixes: ['LOWBAT_ALARM', 'LOW_BAT_ALARM','lowBat'] }, //LOWBAT_ALARM = HM-Classic - LOW_BAT_ALARM = HMIP CCU - lowBat = HMIP Accesspoint
          { key: 'DEVICE_IN_BOOTLOADER_ALARM',        suffixes: ['DEVICE_IN_BOOTLOADER_ALARM'] },
          { key: 'ERROR',                             suffixes: ['ERROR','DUTY_CYCLE'] },                  // error ist ein Sammler fuer hier nicht definierte Meldungen
          { key: 'FAULT_REPORTING',                   suffixes: ['FAULT_REPORTING'] },
          { key: 'SABOTAGE_ALARM',                    suffixes: ['SABOTAGE_ALARM','sabotage'] }, // sabotage ist eine HMIP Meldung
        //  { key: 'STICKY_SABOTAGE_ALARM',             suffixes: ['STICKY_SABOTAGE_ALARM'] },
          { key: 'ERROR_NON_FLAT_POSITIONING_ALARM',  suffixes: ['ERROR_NON_FLAT_POSITIONING_ALARM'] },
          { key: 'OVERHEAT_ALARM',                    suffixes: ['ERROR_OVERHEAT_ALARM'] },
          { key: 'UNDERVOLTAGE_ALARM',                suffixes: ['ERROR_UNDERVOLTAGE_ALARM'] },
      // Umlaut Umwandlung und entfernung PUnkte - kann aber auch erweitert werden
      const replacements = { '.': ' ', 'ä': 'ae', 'ü': 'ue', 'ö': 'oe', 'ß': 'ss' }; // Umwandlung fuer Namen der Geraete (common.name)
      // Definition der Datenstrukturen fuer MetaDaten je nach Adapter, da abweichend
      const StrukturDefinition = [
          { Adapter: 'hm-rpc',   GeraeteID: 2, AlarmFeld: 4, nativeType: 3,                                             common_name:  3 }, // die Ziffer ist die Positinierung des Feldes 'hm-rpc.1.00085D89B14067.0.UPDATE_PENDING_ALARM' 0=Adapter - 2 = ID 4= Feld Alarm / native Type = die ersten Strings bis zur dritten STelle fuer getObject
          { Adapter: 'hmip',     GeraeteID: 3, AlarmFeld: 6, nativeType: 'hmip.xinstancex.devices.xidx.info.modelType', common_name: 'hmip.xinstancex.devices.xidx.info.label' }, // Positionierung wie bei Rm-rpc - bei hmip wird native type aber ueber den DP ausgelesen und nicht getObject "xidx" wird dann mit der geraeteiD ersetzt
      // Moegliche Homematic Instanzen (CuxD ausgeschlossen) // Adapter hinzugefuegt um ggf HCU zu konfigurieren
      const instanceIds = [
          { name: 'HMClassicInstanz',     adapter: 'hm-rpc', Instanz: HMClassicInstanz     },
          { name: 'HMIPInstanz',          adapter: 'hm-rpc', Instanz: HMIPInstanz          },
          { name: 'GruppenInstanz',       adapter: 'hm-rpc', Instanz: GruppenInstanz       },
          { name: 'WiredIClassicInstanz', adapter: 'hm-rpc', Instanz: WiredIClassicInstanz },
          { name: 'HMIPAccessPoint',      adapter: 'hmip'  , Instanz: HMIPAccessPoint      },
      // Die StickingMappingsTabelle stellt sicher, dass die Sticky entsprechend dieser Regel bestaetigt werden kann
      const StickyMappings = {
          STICKY_UNREACH_ALARM:            ['UNREACH_ALARM'],
          STICKY_SABOTAGE_ALARM:           ['SABOTAGE_ALARM'],
      // Konfigurationsobjekt fuer Ausnahmen / es koennen Arlarmtypes je Instanz ausgeschlossen werden / Filter auf AlarmTypes
      const exceptions = {
          HMClassicInstanz:       [],
          HMIPInstanz:            ['DUTY_CYCLE'],
          GruppenInstanz:         ['ERROR_NON_FLAT_POSITIONING_ALARM'],
          WiredIClassicInstanz:   ['LOWBAT_ALARM', 'LOW_BAT_ALARM','ERROR_NON_FLAT_POSITIONING_ALARM'],
      //Ende Einstellungen
      LOG(`Script: Servicemeldungen Volume 2 - Autor: Looxer01 Datum: 24.02.2025 Version:3.20`,`Einstellungen`,`Start`,0 )
      if(HMIPAccessPoint !== 9 && !GeraeteIDTrigger) {
          GeraeteIDTrigger = true // Wenn der HMIPAccessPoint aktiv ist, dann funktioniert der REGA Trigger nicht. also setzen auf geraeteID Trigger=true
          LOG(`HMIP AccessPoint bzw Cloud HCU sind aktiv - GeraeteTriggerID muss aktiviert sein - wurde aktiviert. Bitte auch manuell korrigieren und auf GeraeteTriggerID = true setzen`,`Einstellungen`,`Start`,0 )
      LOG(`HMClassicInstanz: ${HMClassicInstanz}; HMIPInstanz: ${HMIPInstanz}; WiredIClassicInstanz: ${WiredIClassicInstanz}; GruppenInstanz: ${GruppenInstanz}`, "Einstellungen", "Start", 2);
      LOG(`Inhalt instanceIds: ${JSON.stringify(instanceIds)}`, "Einstellungen", "Start", 2);
      LOG(`GeraeteIDTrigger: ${GeraeteIDTrigger}`, "Einstellungen", "Start", 2);
      LOG(`Inhalt Messengerscope: ${JSON.stringify(MessengerScope)}`, "Einstellungen", "Start", 2);
      LOG(`Inhalt Services: ${JSON.stringify(services)}`, "Einstellungen", "Start", 2);
      LOG(`Inhalt Messenger-Instanzen: ${JSON.stringify(MessengerInstanz)}`, "Einstellungen", "Start", 2);
      LOG(`Inhalt TextTypeKurz: ${JSON.stringify(TextTypeKurz)}`, "Einstellungen", "Start", 2);
      let HistorischeMeldungenJSON = [], AktuelleMeldungenJSON = [], MessageSendCollector = {};
      // jetzt selectors fuellen anhand der Tabelle InstanceIDs, sowie der Auscchlusstabellen
      let totalIdsCount = 0;                                                  // Variable fuer die Gesamtzahl der IDs
      const selectors = alarmTypes.map(alarmType => {
          const collectedIds = [];
          instanceIds.forEach(instance => {
              if (instance.Instanz !== 9) {                                   // Umbenennung von `instance.id` zu `instance.Instanz`
                  const excludedAlarmTypes = exceptions[instance.name] || []; // Hole Ausnahmen oder leere Liste
                  if (!excludedAlarmTypes.includes(alarmType.key)) {          // Wenn Alarmtype nicht in der Ausnahme
                      alarmType.suffixes.forEach(suffix => {                  // wenn suffix (meldungsart) nicht in der Ausnahme
                          if (!excludedAlarmTypes.includes(suffix)) {
                              // IDs sammeln, ohne sofort zu filtern
                              // @ts-ignore
                              $(`state[id=${instance.adapter}.${instance.Instanz}.*.${suffix}]`).each(id => collectedIds.push(id));
          const filteredIds = collectedIds.filter(id => !id.includes("groups"));  // for accessPoint und HCU sollten die Ids, die "groups" enthalten ausgeschlossen werden . das sind z.B. Raeume
          const finalFilteredIds = filteredIds.filter(id => {                     // IDs anhand der Geraete-IDs in der Ausschlussliste filtern
              const deviceId = id.split('.')[2];                                  // Geraete-ID aus der vollstaendigen ID extrahieren (z. B. "0000D7099xxx26" aus "hm-rpc.1.0000D7099xxx26.0.LOW_BAT_ALARM")
              return !Ausschlussliste.includes(deviceId);                         // Behalten, wenn nicht in der Ausschlussliste
          totalIdsCount += finalFilteredIds.length;                                // IDs zur Gesamtzahl hinzufuegen
          return { name: alarmType.key, ids: finalFilteredIds };
          AktuelleMeldungenJSON = [];
          let jsonString = getState(id_JSON_Servicemeldung_Historie).val || '[]';    // Lade den aktuellen JSON-String des Historie-Datenpunkts
          HistorischeMeldungenJSON = JSON.parse(jsonString);
          Zaehler.forEach(entry => { entry.count = 0; }); // Alle count-Werte im Objekt auf 0 setzen
          for (let j = 0; j < selectors.length; j++) {
              const selector = selectors[j];
              if (selector.ids.length > 0) {
                  for (let i = 0; i < selector.ids.length; i++) {
                      let id = selector.ids[i], status = getState(id).val;
                      if (!existsState(id)) {
                          LOG(`Geraet ${obj.id} scheint zwischenzeitlich nicht mehr zu existieren - Empfehlung: script neu starten`, "WARN", "Check_All", 0, "warn");
                          continue;
                      switch (selector.name) {        // fuer alle alarmtypes - erst die Sonderfaelle
                          case 'ERROR':
                              if (status >= 1 && status <= 7) {
                                  if (status === 7) { // Sonderfall bei HM-Classic
                                      processServiceMessage('SABOTAGE_ALARM', status, id,RunType);
                                  } else {
                                      processServiceMessage(selector.name, status, id,RunType);
                              break;
                      default:                    // Standardfall fuer alle anderen alarmtypes
                              if(status === 1 || status === true ) {processServiceMessage(selector.name, status, id,RunType);  } // bei status = true = AccessPoint
                              break;
                      increaseCount('Gesamt');
                  } // Ende Loop der Mitglieder des Alarmtypes
              }  // Endif selector ist gefuellt
          }    // Ende Loop ueber den Selector
          const AnzahlAktuellerSM = Zaehler.find(e => e.alarmtype === 'SMAktuell').count;
          // Sequenz zur Speicherung der aktuellen Servicemeldungen in die JSON -Datenpunkte--------------------------
          if (AnzahlAktuellerSM  === 0) {
              AktuelleMeldungenJSON =CreateJsonEntry([] ,func_get_datum(),'', '', '','',func_get_datum() + " - " + MessageBeiKeinerSM,MessageBeiKeinerSM,null,false );  // Keine aktuellen Meldungen -> "Keine Meldungen" hinzufuegen
              let jsonString = JSON.stringify(AktuelleMeldungenJSON);
              setState(id_JSON_Servicemeldung_Aktuell, jsonString);           // Aktuelle SM wird in JSON-Datenpunkt als String gespeichert
          } else {
              let jsonString = JSON.stringify(AktuelleMeldungenJSON);              // AktuelleMeldungenJSON wird in Funktion DefineServiceMessage gefuellt
          if (GeraeteIDTrigger && RunType === "trigger" && !existsState(obj.id)) { // obj.id nicht mehr in ioBroker aber noch im Selector
              const GeraeteId = ExtractMetaData(obj.id, "GeraeteID");
              LOG(`Geraet ${GeraeteId} scheint zwischenzeitlich nicht mehr zu existieren - Empfehlung: script neu starten`, "WARN", "Check_All", 0, "warn");
              return;
          // Speziell fuer GerateIDTrigger = true ist, dass es "aufgehoben"-Meldungen gibt, die fuer REGA Trigger nicht ausgewertet werden koennen. diese duerfen auch nicht als aktuelle meldungen in den DP gelangen
          let ExtendedAktuelleMeldungenJSON = [...AktuelleMeldungenJSON]; // Erstelle eine flat copy
          if (GeraeteIDTrigger && RunType === "trigger") {
              const status = obj.newState.val;
              const common_name = ExtractMetaData(obj.id, "CommonName");
              const native_type = ExtractMetaData(obj.id, "nativeType");
              const meldungsart = ExtractMetaData(obj.id, "meldungsart");
              let status_textLang = DefineServiceMessage(native_type, status, obj.id, "lang");
              let status_textPure = DefineServiceMessage(native_type, status, obj.id, "pure");
              if (!checkIFJSONfEntryExists(ExtendedAktuelleMeldungenJSON,func_get_datum(obj.id), GeraeteId,status, meldungsart) ) {       // checken ob ein Eintrag schon in der Historie ist, wenn nicht dann hinzufuegen
                  ExtendedAktuelleMeldungenJSON = CreateJsonEntry(ExtendedAktuelleMeldungenJSON, func_get_datum(obj.id), meldungsart, common_name, GeraeteId, status, status_textLang, status_textPure, func_Batterie(native_type), true)
          // Historische Meldungen hinzufuegen, wenn nicht bereits vorhanden
          ExtendedAktuelleMeldungenJSON.forEach(aktuelleMeldung => {        // Iteriere ueber alle aktuellen Meldungen und fuege aktuelle meldungen in die historie wenn noch nicht vorhanden
              if (!checkIFJSONfEntryExists(HistorischeMeldungenJSON,aktuelleMeldung.datum_seit  ,aktuelleMeldung.GeraeteId, aktuelleMeldung.status, aktuelleMeldung.meldungsart) ) {       // checken ob ein Eintrag schon in der Historie ist, wenn nicht dann hinzufuegen
                  if(!isLatestEntryMessageBeiKeinerSM(ExtendedAktuelleMeldungenJSON)) {    // nicht wenn nicht "keine Servicemeldungen" in aktuellJSON vorhanden ist
                      const message_kurz = aktuelleMeldung.common_name + " " + aktuelleMeldung.status_message_Pure
                      addMessageToCollector(aktuelleMeldung.meldungsart, message_kurz, aktuelleMeldung.status_message_Lang);
                      HistorischeMeldungenJSON = CreateJsonEntry(HistorischeMeldungenJSON, aktuelleMeldung.datum_seit, aktuelleMeldung.meldungsart, aktuelleMeldung.common_name, aktuelleMeldung.GeraeteId, aktuelleMeldung.status, aktuelleMeldung.status_message_Lang, aktuelleMeldung.status_message_Pure, aktuelleMeldung.batterie_bezeichnung, true )
                      writelog(aktuelleMeldung.common_name, aktuelleMeldung.GeraeteId, aktuelleMeldung.meldungsart, aktuelleMeldung.status, aktuelleMeldung.status_message_Lang);       // externes log erzeugen
          // Handling "keine aktuellen Servicemeldungen"
          if (AnzahlAktuellerSM  === 0 && RunType === "trigger") {       // wenn keine SM vorliegen, die Meldung "keine Servicmeldungen" in die History
              if(!isLatestEntryMessageBeiKeinerSM(HistorischeMeldungenJSON)) {    // nur  wenn  "keine Servicemeldungen" in Historische Meldung nicht bereits an erster Stelle vorhanden ist
                  HistorischeMeldungenJSON =CreateJsonEntry(HistorischeMeldungenJSON ,func_get_datum(),'', '', '','',func_get_datum() + " - " + MessageBeiKeinerSM,MessageBeiKeinerSM,null,false );  // Keine aktuellen Meldungen
                  writelog("", "", "", "", MessageBeiKeinerSM);       //  log erzeugen
                  addMessageToCollector('keineSM', MessageBeiKeinerSM, MessageBeiKeinerSM); // Vorbereitung Messagesending
                  sendMessage('keineSM');
          // AutoBestaetigung fuer StickyMessages, wenn diese nicht mehr aktuell sind. nur relevant fuer HM-Classic
          if (AutoBestaetigungCCUMeldungen ) {ConfirmStickyMessages() }
          // Messages senden fuer alle Faelle mit Servicemeldungen
          if (AnzahlAktuellerSM  > 0 && RunType ==="trigger") {            // Servicemeldungen versenden, falls servicemeldungen vorliegen
              sendMessage();
          HistorischeMeldungenJSON = Markiere_HistSM_als_Aufgehoben(HistorischeMeldungenJSON) // markiert hist messages als erledigt falls nicht mehr in aktuelle meldungen enthalten
          jsonString = JSON.stringify(HistorischeMeldungenJSON);                  // Vorbereitung speichern
          setState(id_JSON_Servicemeldung_Historie, jsonString);                  // hist JSON-Daten speichern
          // falls so eingestellt werden jetzt die TEXTe aus den JSON (aktuell und historie) erzeugt und in die Datenpunkte geschrieben
          GenerateTEXT_Datenpunkte();
          generateHtmlTable(AktuelleMeldungenJSON,"AKT");                 // Aktuelle SM wird in HTML Format gespeichert falls so eingestellt
          generateHtmlTable(HistorischeMeldungenJSON,"HIST");             // Historische  SM wird in HTML Format gespeichert falls so eingestellt
          // anzahl der Eintraege in HistorischeMeldungenJSON ermitteln und alle counts in die Statistik schreiben
          let entry = Zaehler.find(item => item.alarmtype === "SMHistorie");
          if (entry) {entry.count = HistorischeMeldungenJSON.length;    }          // Wenn der Eintrag gefunden wird, aktualisiere den count-Wert
          Zaehler.forEach(entry => {    // JETZT: ZaehlerStaende in die ioBroker - Datenpunkte-------------------fuer aktuelle Meldungen
              setState(entry.Datenpunkt, entry.count);
          // Log Ausgabe der Ergebnisse--------------------------------------------
          LOG(`Es wurden insgesamt ${Zaehler.find(e => e.alarmtype === 'Gesamt').count} IDs gecheckt - insgesamt gibt es ${AnzahlAktuellerSM} Servicemeldungen`, "Ergebnis", "Check_All", 2);
          Zaehler.forEach(({ alarmtype, count }) => {
              LOG(`SMAktuell fuer alarmtype: ${alarmtype} insgesamt festgestellte Servicemeldungen: ${count}`, "Ergebnis", "Check_All", 2);
          LOG(`Zeitverbrauch fuer Routine Check_All: ${Date.now() - startTime} Millisekunden`, "Ergebnis", "Check_All", 1);
          AktuelleMeldungenJSON =[]; HistorischeMeldungenJSON = [];  MessageSendCollector = {};    // Speicher freigeben
      //  Function processServiceMessage // Zuordnung der richtigen Servicemeldung zum Alarmtype / Zaehlung der Faelle
      function processServiceMessage(alarmtype, status, id, RunType) {
          const native_type = ExtractMetaData(id, "nativeType");
          const meldungsart = ExtractMetaData(id, "meldungsart");
          const common_name = ReplaceString(ExtractMetaData(id, "CommonName"));
          const GeraeteId = ExtractMetaData(id, "GeraeteID");
          let ServiceMeldungTextLang = DefineServiceMessage(native_type, status, id, "lang");     // aktuelle Servicemeldung ableiten
          let ServiceMeldungTextPure = DefineServiceMessage(native_type, status, id, "pure");
          AktuelleMeldungenJSON = CreateJsonEntry(AktuelleMeldungenJSON, func_get_datum(id), meldungsart, common_name, GeraeteId, status, ServiceMeldungTextLang, ServiceMeldungTextPure, func_Batterie(native_type), true); // nur einmal unabhaengig der Version
          increaseCount(alarmtype); increaseCount('SMAktuell');
      // Funktion ConfirmStickyMessages Autoconfirm Servicemeldungen (STICKY bei HM-Classic)
      function ConfirmStickyMessages() {
          LOG("Routine ConfirmStickyMessages wird ausgeführt", "Ablauf", "ConfirmStickyMessages", 2);
          let Adapter, Instanz, StickyMeldungsart, StickyMappedString, ID_Constructed, GeraeteID;
          let AckFlag = false; let delay = 0;
          const foundInstance = instanceIds.find(item => item.name === 'HMClassicInstanz'); // die HMClassic Instanz wird ermittelt
          if (foundInstance) {
              Adapter = foundInstance.adapter;
              Instanz = foundInstance.Instanz;
          for (let i = 0; i < AktuelleMeldungenJSON.length; i++) {
              const aktuelleMeldung = AktuelleMeldungenJSON[i];
              StickyMeldungsart = aktuelleMeldung.meldungsart;
              StickyMappedString = StickyMappings[StickyMeldungsart];
              GeraeteID = aktuelleMeldung.GeraeteId;
              if (StickyMappedString === undefined) { continue }
              ID_Constructed = Adapter + "." + Instanz + "." + GeraeteID + ".0." + StickyMeldungsart; // Gilt nur bei HM-Classic
              AckFlag = CheckStickyNochAktuell(StickyMappedString, GeraeteID); // kann die Message bestaetigt werden ? true = ja
              if (AckFlag) {
                  setTimeout(() => {
                      setState(ID_Constructed, 2);
                      LOG("Eine Sticky Meldung wurde bestaetigt fuer ID " + ID_Constructed, "Ergebnis", "ConfirmStickyMessages", 2);
                  }, delay); //  Verzögerung
                  delay = delay + 500
              } else {
                  LOG("Eine Sticky Meldung ist noch aktuell und wird nicht bestaetigt fuer ID " + ID_Constructed, "Ergebnis", "ConfirmStickyMessages", 2);
      // Funktion CheckStickyNochAktuell checked of Sticky Meldung bestaetigt werden kann
      function CheckStickyNochAktuell(MappedString, GeraeteID) {
          let AckFlag = true;
          MappedString = String(MappedString); // Wandelt MappedString in einen String um
          GeraeteID = String(GeraeteID); // Wandelt GeraeteID in einen String um
          for (let j = 0; j < AktuelleMeldungenJSON.length; j++) {    // Iteriere über alle aktuellen Meldungen, um nach einer Nicht-Sticky-Meldung zu suchen
              const AktuelleMeldung = AktuelleMeldungenJSON[j];
              const aktuelleMeldungsart = String(AktuelleMeldung.meldungsart).trim();
              const aktuelleGeraeteId = String(AktuelleMeldung.GeraeteId).trim();
              if (aktuelleMeldungsart === MappedString && aktuelleGeraeteId === GeraeteID) {  // ueberpruefen ob die Sticky message noch aktuell ist
                  AckFlag = false;
                  break; // Schleife abbrechen
          return AckFlag;
      // Function increaseCount // Diese Funktion reduziert Wiederholungen der Case abfragen in Check_ALL
      function increaseCount(alarmtype) {
          const entry = Zaehler.find(e => e.alarmtype === alarmtype);
          if (entry) entry.count++;
      // Funktion DefineServiceMessage  Message ERmittlung
      function DefineServiceMessage(native_type, status, id, version) {
          LOG(`Routine DefineServiceMessage wird ausgefuehrt meldungsart ${meldungsart} und ID:${id}`, "Ablauf", "DefineServiceMessage", 2);
          const adapter = ExtractMetaData(id, "adapter");
          const datum_seit = func_get_datum(id);
          let matchingAlarmType = meldungsart;
          let isValidMessageType = alarmTypes.some((type) => type.suffixes.includes(meldungsart));
          if (isValidMessageType) {    // Bestimmen des passenden Alarmtyps
              matchingAlarmType = alarmTypes.find((type) => type.suffixes.includes(meldungsart)).key;
              if (matchingAlarmType === "ERROR" && meldungsart !== "ERROR") {
          const createServiceMessage = (message) => {    // Hilfsfunktion zum Erzeugen der ServiceMessage
              if (version === "lang") {        // Unterschiedliche Formate je nach Version
                  let Status_Message_Lang = `${datum_seit} - ${meldungsart} - ${common_name} - (${GeraeteId}) - ${status} - ${message}`;
                  return Status_Message_Lang;
              } else if (version === "pure") {
                  return message;  // Nur die pure status Nachricht
              } else {
                  return `${common_name} ${message}`;  // Kurze Nachricht, falls kurze Nachrichten gewuenscht fuer das messaging
          switch (matchingAlarmType) {    // Logik je nach meldungsart
              case "LOWBAT_ALARM":
                  const lowBatMessage = `${getStatusMessage(meldungsart, status, adapter)} - Batteriebezeichnung: ${func_Batterie(native_type)}`;
                  return createServiceMessage(lowBatMessage);
              case "ERROR":
                  if (status >= 1 && status <= 7 && errorMessages[native_type] && errorMessages[native_type][status]) {
                      return createServiceMessage(errorMessages[native_type][status]);
                  if (status === 0) {
                      const fallbackMessage = getStatusMessage("FALLBACK", status, adapter);
                      return createServiceMessage(fallbackMessage);
                  break;
              case "FAULT_REPORTING":
                  if (faultMessages[native_type] && faultMessages[native_type][status]) {
                      return createServiceMessage(faultMessages[native_type][status]);
                  break;
              default:
                      return createServiceMessage(getStatusMessage(meldungsart, status, adapter));
                  } else {
          return createServiceMessage(getStatusMessage("FALLBACK", status, adapter));    // kann eigentlich nicht aufteten
      //Funktion getStatusMessage zur Abfrage der Meldung je messageType, Adapter und Status (fuer Routine DefineServiceMessage)
      function getStatusMessage(messageType, statusKey, adapter) {
          if ( statusMessages[messageType] && statusMessages[messageType][adapter] &&statusMessages[messageType][adapter][statusKey] !== undefined  ) {    // Existenzpruefung- ggf regagieren
              return statusMessages[messageType][adapter][statusKey];
          } else {
              return `Keine passende Meldung fuer MessageType: "${messageType}", Adapter: "${adapter}", Status: "${statusKey}".`;
      // addMessageToCollector  Messages werden unter beruecksichtigung der folgenden Objekte in den MessageCollector genommen
      // MessengerScope, Services, AlarmTypes, TextTypeKurz
      function addMessageToCollector(messageType, MessageKurz, MessageLang) {
          let actualMessageType, matchingAlarmType;
          if (messageType !== "keineSM") {
              let isValidMessageType = alarmTypes.some((type) => type.suffixes.includes(messageType));
                  matchingAlarmType = alarmTypes.find((type) => type.suffixes.includes(messageType)).key;
                  actualMessageType = messageType;
              } else {
                  LOG(`MessageType: ${messageType} ist nicht konfiguriert in alarmTypes`, "WARN", "addMessageToCollector", 0);
          if (messageType === "keineSM") {
              actualMessageType = "keineSM";
              matchingAlarmType = "keineSM";
          if (!MessageSendCollector[actualMessageType]) {
              MessageSendCollector[actualMessageType] = {};
          let messengerConfig = MessengerScope[matchingAlarmType] || MessengerScope['Sonstige'] || Array(services.length).fill(false);
          messengerConfig.forEach((isActive, index) => {
              if (isActive) {
                  const service = services[index];
                  const instance = MessengerInstanz[index];
                  if (instance !== null && !isNaN(instance) && instance >= 0) {
                      if (!MessageSendCollector[actualMessageType][service]) {
                          MessageSendCollector[actualMessageType][service] = [];
                      const messageToAdd = TextTypeKurz[index] ? MessageKurz : MessageLang;
                      const existingMessages = MessageSendCollector[actualMessageType][service];
                      // **Doppelprüfung:** Gibt es bereits eine Nachricht mit demselben Text und Instanz?
                      const isDuplicate = existingMessages.some(msg => msg.message.trim() === messageToAdd.trim() && msg.instance === instance);
                      if (!isDuplicate) {
                          MessageSendCollector[actualMessageType][service].push({
                              message: messageToAdd + '\n',
                              instance: instance
                          LOG(`Nachricht hinzugefügt für ${actualMessageType} - Service: ${service} - Instanz: ${instance}`, "Ablauf", "addMessageToCollector", 3);
                      } else {
                          LOG(`Doppelte Nachricht erkannt und verworfen für ${actualMessageType} - Service: ${service} - Instanz: ${instance}`, "DEBUG", "addMessageToCollector", 3);
                  } else {
                      LOG(`Ungültige Instanz für Service: ${service} (Instanz: ${instance})`, "WARN", "addMessageToCollector", 0);
      // sendMessage  Hier werden die Nachrichten fuer den jeweiligen Service aufbereitet
      function sendMessage(messageType = null) {
          LOG(`Routine sendMessage wird ausgefuehrt, meldungsart: ${messageType}`, "Ablauf", "sendMessage", 2);
          const messageTypesToProcess = messageType ? [messageType] : Object.keys(MessageSendCollector);    // Bestimme die MessageTypes, die verarbeitet werden sollen
          messageTypesToProcess.forEach((type) => {
              const messagesByService = MessageSendCollector[type];
              if (messagesByService) {
                  Object.keys(messagesByService).forEach((service) => {
                      const serviceMessages = messagesByService[service];
                      let messagesToRemove = [];
                      serviceMessages.forEach((item) => {
                          const { message, instance } = item;
                          sendToService(service, message, instance);
                          messagesToRemove.push(item);
                      messagesToRemove.forEach((item) => {                // Entferne alle verarbeiteten Nachrichten
                          const serviceMessagesIndex = serviceMessages.indexOf(item);
                          if (serviceMessagesIndex > -1) {
                              serviceMessages.splice(serviceMessagesIndex, 1);
      // sendToService    - hier wird der Versand vorgenommen
      // Reihenfolge:       Email, WhatsApp, Signal, Telegram, Pushover, Pushsafer
      // MessengerInstanz = [0,       0,        0,      0,         0,        0]    Instanzen der Messenger-Dienste in
      function sendToService(service, message, instance) {
      LOG(`Message wird versendet mit: ${service} : ${instance} : ${message}`, "Ablauf", "sendToService", 2);
          switch (service) {
              case "email":
                  sendTo(`email.${instance}`, "send", {
                      text: message,
                      to: emailAddresse,
                      subject: Headline
                  break;
              case "whatsApp":
                  sendTo(`whatsapp-cmb.${instance}`, "send", {
                      text: message
                  break;
              case "Signal":
                  sendTo(`signal-cmb.${instance}`, "send", {
                      text: message
                  break;
              case "Telegram":
                  sendTo(`telegram.${instance}`, "send", {
                      text: message,
                      user: TelegramUser  // Telegram User ID, um den Nachrichteneempfaenger festzulegen
                  break;
              case "Pushover":
                  sendTo(`pushover.${instance}`, "send", {
                      message: message,
                      sound: ""
                  break;
              case "Pushsafer":
                  sendTo(`pushsafer.${instance}`, "send", {
                      message: message,
                      title: Headline
                  break;
              default:
                  LOG(`Unbekannter Service: ${service}`, "WARN", "sendToService", "warn");
      // Funktion ExtractMetaData  Verarbeitung des Datenpunkts zur Extraktion der Metadaten: GeraeteId, meldungsart
      function ExtractMetaData(datenpunkt, ExtractType) {
          LOG(`Routine ExtractMetaData wird ausgefuehrt datenpunkt fuer Metadaten ${datenpunkt} ExtractType ${ExtractType} `, "Ablauf", "ExtractMetaData", 2);
          ExtractType = ExtractType.toUpperCase();
          const teile = datenpunkt.split('.');                                        // Splitte den Datenpunkt in Teile
          const adapter = teile[0];                                                   // Der erste Teil ist immer der Adapter
          const instance = teile[1];                                                  // Der zweite  Teil ist immer die  Instance
          const struktur = StrukturDefinition.find(s => s.Adapter === adapter);       // Strukturzeile aus Tabelle StrukturDefinition fuer den Adapter aus dem uebergebenen DP
          const GeraeteID = teile[struktur.GeraeteID];                                // Extrahiere Felder basierend auf der Strukturdefinition
          if (!struktur) {
              LOG(`Die Struktur fuer MetaDaten Extract ist nicht korrekt eingestellt. Der uebergebenen datenpunkt war:$(datenpunkt)- Abbruch`, "Fehler", "ExtractMetaData", 0);
              return null;
          if(ExtractType === "ADAPTER") { return adapter; }
          if(ExtractType === "GERAETEID") { return GeraeteID; }
          if(ExtractType === "MELDUNGSART") {
              const meldungsart = teile[struktur.AlarmFeld];                                       // Extrahiere Felder basierend auf der Strukturdefinition
              return meldungsart;
          if(ExtractType === "NATIVETYPE" && typeof struktur.nativeType === 'number') {
              const MetaDP = datenpunkt.split('.').slice(0, struktur.nativeType).join('.');        // ergibt den Datenpunkt fuer getObject z.B. hm-rpc.1.00085D89B14067
              const nativeType  = getObject(MetaDP).native.TYPE;
              return nativeType;
          if(ExtractType === "NATIVETYPE" && typeof struktur.nativeType === 'string') {           // bei string liegt der native-type im datenpunkt
              let  DPNativeTypeDP = struktur.nativeType;
              DPNativeTypeDP = DPNativeTypeDP.replace('xidx', GeraeteID);
              DPNativeTypeDP = DPNativeTypeDP.replace('xinstancex', instance);
              let nativeType = getState(DPNativeTypeDP).val
              return nativeType;
          if(ExtractType === "COMMONNAME" && typeof struktur.common_name === 'number') {
              const MetaDP = datenpunkt.split('.').slice(0, struktur.common_name).join('.');        // ergibt den Datenpunkt fuer getObject z.B. hm-rpc.1.00085D89B14067
              const common_name  = getObject(MetaDP).common.name;
              return common_name;
          if(ExtractType === "COMMONNAME" && typeof struktur.common_name === 'string') {           // bei string liegt der common_name im datenpunkt
              let DPcommmon_name = struktur.common_name;
              DPcommmon_name = DPcommmon_name.replace('xidx', GeraeteID).replace('xinstancex', instance);
              let common_name = getState(DPcommmon_name).val
              return common_name;
          LOG(`Der Datenpunkt/ExtractType, die erforderlich zur Ermittlung von Metadaten sind nicht bekannt Der Datenpunkt lautet ${datenpunkt} ExtractType ${ExtractType}  - Abbruch`, "Fehler", "ExtractMetaData", 0);
          return null
      // ReplaceString  // ersetzen  entsprechend tabelle replacements
      function ReplaceString(string) {
          for (const [key, value] of Object.entries(replacements)) {
              // Escape den Punkt (.) fuer den regulaeren Ausdruck
              const escapedKey = key.replace('.', '\\.');
              string = string.replace(new RegExp(escapedKey, 'g'), value);
          return string;
      // func_get_datum  aktuelles Datum formatiert
      function func_get_datum(id) {
          let datum;
          if (id && getState(id)) {
              datum = formatDate(getState(id).lc, "TT.MM.JJ SS:mm:ss");
          } else {
              datum = formatDate(new Date(), "TT.MM.JJ SS:mm:ss"); // Aktuelles Datum
          let datumDate = new Date(datum); // korrekte verwendung des datumsformates
          let cutoffDate = new Date('1971-01-01T01:00:00');
          return datumDate < cutoffDate ? '' : `${datum} Uhr`;
      // func_Batterie Batterieermittlung
      function func_Batterie(native_type) {
          LOG(`Routine wird ausgefuehrt`, "Ablauf", "func_Batterie", 2);
          const normalizedType = native_type.toUpperCase();
          return Object.keys(batteryTypes).find(battery =>
              batteryTypes[battery].some(device => device.toUpperCase() === normalizedType)
          ) || NichtRelevantText;
      // Funktion CreateJsonEntry erzeugen einer JSON Tabelle
      function CreateJsonEntry(existingJson = [], datum_seit = '', meldungsart = '', common_name = '', GeraeteId = '', status = '', Status_Lang = '', Status_Pure, Batterie = '',sortierung = false) {
          let parsedJson;
          if (Array.isArray(existingJson)) {     // ueberpruefen, ob existingJson bereits ein Array ist
              parsedJson = existingJson; // Nur das Array uebernehmen
          } else {
              parsedJson = [];  // Falls es kein Array ist, setze es auf ein leeres Array
          const neuerEintrag = {
              datum_seit: datum_seit || func_get_datum(),     // Fallback auf aktuelles Datum
              meldungsart: meldungsart || NichtRelevantText,
              common_name: common_name || NichtRelevantText,
              GeraeteId: GeraeteId || NichtRelevantText,
              status: status || NichtRelevantText,                                // Status entweder number oder boolean
              status_message_Lang: Status_Lang || 'Keine Meldung',    // Langer Text
              status_message_Pure: Status_Pure || 'Keine Meldung',    // nur die Status aus den Status-Tabellen
              batterie_bezeichnung: Batterie || NichtRelevantText,
              SM_aufgehoben_seit:  "aktiv"          // status ob eine message bereits aufgeboben ist. wenn aufgehoben wird ein Datum eingestellt
          parsedJson.unshift(neuerEintrag);
          if(sortierung) { sortJason(parsedJson);}
          return parsedJson;  // Gib das aktualisierte Array zurueck
      // Funktion checkIfEntryExists Checken of ein Eintrag schon vorhanden ist
      function checkIFJSONfEntryExists(parsedJson, datum_seit, GeraeteId, status, meldungsart) {
          if (!Array.isArray(parsedJson)) { // Überprüfen, ob parsedJson ein Array ist
              LOG(`parsedJson ist kein Array`, "WARN", "checkIFJSONfEntryExists", 1);
              return false;
          for (let entry of parsedJson) { // Durch das Array iterieren und kriterien checken // meldungsart ist optional
              if (entry.datum_seit === datum_seit && entry.GeraeteId === GeraeteId && entry.status === status && (meldungsart === undefined || entry.meldungsart === meldungsart)  ) {
                  return true; // Eintrag gefunden
          return false; // Kein passender Eintrag gefunden
      // Funktion isLatestEntryMessageBeiKeinerSM Checken ob die letzte message der variablen MessageBeiKeinerSM entspricht
      function isLatestEntryMessageBeiKeinerSM(existingJson = []) {
          if (!Array.isArray(existingJson) || existingJson.length === 0) {    // ueberpruefen, ob existingJson ein Array ist und Eintraege enthaelt
              return false;
          const latestEntry = existingJson[0];    // Neuesten Eintrag extrahieren (erster Eintrag im Array)
          if (latestEntry.status_message_Lang && latestEntry.status_message_Lang.includes(MessageBeiKeinerSM)) {
              return true;
          return false;
      // Funktion Markiere_HistSM_als_Aufgehoben Zuordnung von historischen Messages zu "aufgehoben" mit Datum der Zuordnung
      function Markiere_HistSM_als_Aufgehoben(HistorischeMeldungenJSON_transfer) {
          const maxTimeDiffMs = 1000; // z.B. 1000 ms fuer eine Sekunde Unterschied
          const nurKeineMeldungen = AktuelleMeldungenJSON[0].status_message_Lang.includes(MessageBeiKeinerSM);    // Pruefen, ob AktuelleMeldungenJSON nur eine Meldung mit "Derzeit keine Servicemeldungen" enthaelt
          if (nurKeineMeldungen) {
              HistorischeMeldungenJSON_transfer.forEach(meldung => {        // Alle historischen Eintraege als aufgehoben markieren
                  if (meldung.SM_aufgehoben_seit === "aktiv") {
                      meldung.SM_aufgehoben_seit = func_get_datum();
              return HistorischeMeldungenJSON_transfer;
          HistorischeMeldungenJSON_transfer.forEach(historischeMeldung => {    // Iteriere ueber alle historischen Meldungen (aeussere Schleife)
              if (historischeMeldung.SM_aufgehoben_seit !== "aktiv") return; // Wenn die historische Meldung bereits aufgehoben wurde, ueberspringen
              let zugeordnet = false;
              const historischeDatum = extractDate(historischeMeldung.datum_seit);
              AktuelleMeldungenJSON.forEach(aktuelleMeldung => {        // Iteriere ueber alle aktuellen Meldungen (innere Schleife)
                  const aktuelleDatum = extractDate(aktuelleMeldung.datum_seit);
                  const gleicheGeraeteID = historischeMeldung.GeraeteId === aktuelleMeldung.GeraeteId;
                  const gleicheStatusMessage = historischeMeldung.status_message_Pure === aktuelleMeldung.status_message_Pure;
                  const zeitDifferenz = Math.abs(aktuelleDatum.getTime() - historischeDatum.getTime());            // Berechne den Zeitunterschied in Millisekunden
                  const gleicheOderNaheZeit = zeitDifferenz <= maxTimeDiffMs;            // Pruefe, ob die Zeitdifferenz innerhalb des erlaubten Bereichs liegt
                  if (gleicheGeraeteID && gleicheStatusMessage && gleicheOderNaheZeit) {
                      historischeMeldung.SM_aufgehoben_seit = "aktiv"; // Als nicht aufgehoben markieren
                      zugeordnet = true
              if (!zugeordnet) {
                  historischeMeldung.SM_aufgehoben_seit = func_get_datum() // kein pendant gefunden, also muss die message obsolet sein
      // Funktion sortJason zum Sortieren des History Jason nach datum
      function sortJason(parsedJson) {
          if (!Array.isArray(parsedJson)) { LOG("Die Eingabe fuer sortJason ist kein Array.", "Fehler", "sortJason", 2); return[] ;}
          const parseDate = (datum) => {
              try {
                  const [date, time] = datum.split(' '); // Datum und Zeit trennen
                  const [day, month, year] = date.split('.'); // Datum aufteilen in Tag, Monat, Jahr
                  const [hours, minutes, seconds] = time.split(':'); // Zeit aufteilen in Stunden, Minuten, Sekunden
                  return new Date(`20${year}-${month}-${day}T${hours}:${minutes}:${seconds}`); // ISO-Format erstellen
              } catch (error) {
                  LOG(`Fehler beim Parsen des Datums: ${datum}`, "Fehler", "sortJason", 1);
                  return null;  // Rueckgabe von null, wenn das Datum ungueltig ist
          return parsedJson.sort((a, b) => {
              const dateA = parseDate(a.datum_seit);
              const dateB = parseDate(b.datum_seit);
              if (dateA === null && dateB === null) return 0; // Keine aenderung bei ungueltigen Datumswerten
              if (dateA === null) return 1; // Null-Werte ans Ende verschieben
              if (dateB === null) return -1;
              return dateB.getTime() - dateA.getTime(); // Neueste zuerst
      // Funktion extractDatum // Hilfsfunktion zur Extraktion des Datums        // Beispieltext: "01.12.24 12:04:55 Uhr - SABOTAGE_ALARM ..."
      function extractDate(text) {
          if (!text || typeof text !== "string") {
              LOG(`extractDate Fehler: Ungueltiger Eingabetext: ${text}`, "Fehler", "extractDate", 2);
              return new Date(0); // Fallback auf ein Default-Datum
          const match = text.match(/^(\d{2})\.(\d{2})\.(\d{2}) (\d{2}):(\d{2}):(\d{2})/);    // Regulaerer Ausdruck, um Datum und Uhrzeit zu extrahieren
          if (!match) {
              LOG(`extractDate Fehler: Kein gueltiges Datum gefunden: ${text}`, "Fehler", "extractDate", 2);
          const [_, day, month, year, hours, minutes, seconds] = match;    // Teile aus dem Match extrahieren
          const fullYear = year.length === 2 ? `20${year}` : year;    // Jahr vervollstaendigen, falls noetig
          const dateString = `${fullYear}-${month}-${day}T${hours}:${minutes}:${seconds}`;    // Erstellen des Datums im Format "YYYY-MM-DDTHH:mm:ss"
          const date = new Date(dateString);    // Umwandlung in ein Date-Objekt
          if (isNaN(date.getTime())) {    // ueberpruefen, ob das Datum gueltig ist
              LOG(`extractDate Fehler: Ungueltiges Datum erzeugt: ${dateString}`, "Fehler", "extractDate", 2);
              return new Date(0);
          return date;
      // Funktion GenerateTEXT_Datenpunkte // Generiert TEXT format aus den JSON Arrays und speichert diese in die Datenpunkte
      function GenerateTEXT_Datenpunkte() {
          LOG(`Routine wird ausgefuehrt`, "Ablauf", "GenerateTEXT_Datenpunkte", 2);
          if(!UpdateTEXT_Datenpunkte){return}; // wenn keine TEXT-Datenpunkte updates erfolgen sollen nicht ausfuehren
          let  SMAktuellMessageLangTEXT = [], SMHistMessageLangTEXT = [],SMAktuellMessageKurzTEXT = [];
          HistorischeMeldungenJSON.forEach(Meldung => {        // Iteriere durch HistorischeMeldungenJSON und extrahiere die status_message_Lang
              SMHistMessageLangTEXT.push(Meldung.status_message_Lang + " - Meldung aufgehoben: " + Meldung.SM_aufgehoben_seit + "<br>");            // Status-Lang-Text extrahieren und ins Array pushen
          setState(id_Text_Servicemeldung_History, SMHistMessageLangTEXT.join(''));        // Umwandlung des Arrays in einen String und Speichern im Datenpunkt id_Text_ServicemeldungLang
          AktuelleMeldungenJSON.forEach(Meldung => {        // Iteriere durch AktuelleMeldungenJSON und extrahiere die status_message_Pure und status_message_Lang
              if (Meldung.status_message_Pure) {
                  SMAktuellMessageKurzTEXT.push(Meldung.datum_seit + " " + Meldung.status_message_Pure + "<br>"); // Status-Kurz-Text extrahieren und ins Array pushen
              if (Meldung.status_message_Lang) {
                  SMAktuellMessageLangTEXT.push(Meldung.status_message_Lang + "<br>"); // Status-Lang-Text extrahieren und ins Array pushen
          setState(id_Text_ServicemeldungKurz, SMAktuellMessageKurzTEXT.join(''));        // Umwandlung der Arrays in Strings und Speichern in den entsprechenden Datenpunkten
          setState(id_Text_ServicemeldungLang, SMAktuellMessageLangTEXT.join(''));
      // Funktion generateHtmlTable // Funktion, aus den JSON Tabellen ein HTML-Format erzeugt
      function generateHtmlTable(data, HistOderAkt) {
          if (!UpdateHTML_Datenpunkte) { return; }        // Keine Updates, wenn HTML-Datenpunkte deaktiviert sind
          const uniqueClass = "custom-table";    // Eindeutige Klasse für die Tabelle
          const cellPadding = '6px';
          // Baue die Tabelle mit einer eindeutigen Klasse auf
          let table = `
              <table class="${uniqueClass}" style="
                  width: 100%;
                  border-collapse: collapse; /* Rahmen zusammenführen */
                  border-spacing: 0; /* Kein Abstand zwischen Zellen */
          // Scoped Stile für die Tabelle
          table += `
              <style>
                  .${uniqueClass} th, .${uniqueClass} td {
                      padding: ${cellPadding};
                      ${useBorderAll ? `border: ${borderWidth} solid ${borderColor};` : 'border: none;'} /* Innerer Rahmen basierend auf useBorderAll */
                  .${uniqueClass} thead th {
                      position: sticky;
                      top: 0;
                      background-color: ${headerColor};
                      color: ${headerTextColor};
                      z-index: 1;
              </style>
          // Kopfzeile
          table += `
              <thead>
              <tr>
                  <th style="text-align: left;">Datum_Seit</th>
                  <th style="text-align: left;">Meldungsart</th>
                  <th style="text-align: left;">Name</th>
                  <th style="text-align: left;">GeraeteId</th>
                  <th style="text-align: left;">Status</th>
                  <th style="text-align: left;">Batterie</th>
                  <th style="text-align: left;">SM_aufgehoben_seit</th>
              </tr>
              </thead>
          // Tabellenkörper
          table += '<tbody>';
          data.forEach((item, index) => {
              const rowColor = index % 2 === 0 ? evenRowColor : oddRowColor; // Farben der Zeilen
              const textColor = index % 2 === 0 ? evenRowTextColor : oddRowTextColor; // Textfarbe
              table += `
              <tr style="background-color: ${rowColor}; color: ${textColor};">
                  <td>${item.datum_seit}</td>
                  <td>${item.meldungsart}</td>
                  <td>${item.common_name}</td>
                  <td>${item.GeraeteId}</td>
                  <td>${item.status_message_Pure}</td>
                  <td>${item.batterie_bezeichnung}</td>
                  <td>${item.SM_aufgehoben_seit}</td>
              </tr>
          table += '</tbody>';
          table += '</table>';
          // Zustand setzen je nach HistOderAkt
          if (HistOderAkt === "AKT") {
              setState(id_HTML_Servicemeldung_Aktuell, table);
          } else {
              setState(id_HTML_Servicemeldung_History, table);
      // Funktion Refresh_History loescht die Historie - Ausloeser entweder subcription oder schedule
      function Refresh_History() {
          let jsonString = getState(id_JSON_Servicemeldung_Historie).val || '[]'; // zunaechst die JSON Eintraege
          HistorischeMeldungenJSON = HistorischeMeldungenJSON.filter(meldung => meldung.SM_aufgehoben_seit === "aktiv");    // Filtern der Meldungen, um nur die zu behalten, die den Wert "aktiv" in "SM_aufgehoben_seit" haben
          let updatedJsonString = JSON.stringify(HistorischeMeldungenJSON);    // Speichern der gefilterten historischen Meldungen zurueck in den Datenpunkt
          setState(id_JSON_Servicemeldung_Historie, updatedJsonString);
          Check_All("init")
      // Funktion schreibt einen Logeintrag in das Filesystem und auch in das interne Log-System
      function writelog(Name, GeraeteId, SMType, SMStatus, SMStatus_Text) {
          if (!SMProtokoll) return;
          const fs = require('fs');                     // enable write fuer externes log
          const logdate = formatDate(new Date(), "TT.MM.JJJJ");
          const logtime = formatDate(new Date(), "SS:mm:ss");
          const logEntry = `${logdate} ;${logtime} ;${Name} ;${GeraeteId} ; ${SMType} ;${SMStatus} ;${SMStatus_Text}\n`;
          const headerLine = "Datum;Uhrzeit;Name;ID-Name;Meldungssart;Status;Servicemeldung\n";
          fs.readFile(PathSMLog, 'utf8', function(err, data) {
              if (!err) {
                  fs.appendFileSync(PathSMLog, logEntry, 'utf8');
              } else {
                  LOG(`Logfile nicht gefunden - wird angelegt`, "Ablauf", "writelog", 0);
                  fs.writeFileSync(PathSMLog, headerLine + logEntry, 'utf8');
      // Funktion schreibt die Syste-Log-Eintraege in ein externes CSV - File
      function LOG(Message,Kategorie,Routine, Level, type) {
          if(type !== "warn" && type !== "error") {type = "info"}
          if (!SystemLog && debugLevel >= Level) { log(Message+" Routine:"+Routine,type); return;}     // Wenn SystemLog false ist und der Debug-Level hoeher oder gleich dem uebergebenen Level, schreibe normalen Logeintrag
          if  (Level === 0) { log(Message+" Routine:"+Routine,type);} // bei level 0 soll auf jeden fall auch in das normale log geschrieben werden
          if (SystemLog && debugLevel >= Level) {         // Wenn SystemLog true ist und der Debug-Level hoeher oder gleich dem uebergebenen Level
              const now = new Date();
              const logdate = `${now.getDate().toString().padStart(2, '0')}.${(now.getMonth() + 1).toString().padStart(2, '0')}.${now.getFullYear()}`;
              const logtime = `${now.getHours().toString().padStart(2, '0')}:${now.getMinutes().toString().padStart(2, '0')}:${now.getSeconds().toString().padStart(2, '0')}:${now.getMilliseconds().toString().padStart(3, '0')}`;
              const logEntry = `${logdate};${logtime};${Level};${Kategorie};${Routine};${Message}\n`;
              const headerLine = "Datum;Uhrzeit;Debug Level;Kategorie;Routine;Log-Message\n";
              const logFilePath = PathSystemLog || './defaultLog.csv'; // falls PathSystemLog nicht definiert ist, standardmaessigen Pfad verwenden
              try {
                  if (!fs.existsSync(logFilePath)) {
                      log(`Routine:LOG - Logfile nicht gefunden - wird angelegt`,"info")
                      fs.writeFileSync(logFilePath, headerLine + logEntry, 'utf8');  // Datei erstellen und Header hinzufuegen
                  } else {
                      fs.appendFileSync(logFilePath, logEntry, 'utf8'); // Eintrag zum Logfile hinzufuegen
              } catch (err) {
                  log(`Routine:LOG - Fehler beim Schreiben in das Logfile: ${err}`, "error"); // Fehler beim Schreiben
      // Funktion Create States
      async function CreateStates(callback) {
          LOG(`Routine wird ausgefuehrt`, "Ablauf", "CreateStates", 2);
          try {
              if(UpdateTEXT_Datenpunkte) {    // nur wenn Text-Datenpunkte auch gewuenscht sind
                  await createStateAsync(id_Text_ServicemeldungLang, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen LangText', desc: 'LangText Servicemeldung' });
                  await createStateAsync(id_Text_ServicemeldungKurz, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen KurzText', desc: 'KurzText Servicemeldung' });
                  await createStateAsync(id_Text_Servicemeldung_History, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen History', desc: 'History Servicemeldung' });
              if(UpdateHTML_Datenpunkte) {    // nur wenn Text-Datenpunkte auch gewuenscht sind
                  await createStateAsync(id_HTML_Servicemeldung_Aktuell, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen HTML-Text', desc: 'HTML-Text Servicemeldung' });
                  await createStateAsync(id_HTML_Servicemeldung_History, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen HTML-History', desc: 'HTML-History Servicemeldung' });
              await createStateAsync(id_JSON_Servicemeldung_Aktuell, "", { read: true, write: true, type: 'string', name: 'Aktuelle Servicemeldungen als JSON', desc: 'Vergangene Servicemeldung JSON' });
              await createStateAsync(id_JSON_Servicemeldung_Historie, "", { read: true, write: true, type: 'string',name: 'Servicemeldungen History', desc: 'History Servicemeldung' });
              await createStateAsync(id_Button_Refresh_Historie, false, { read: true, write: true, type: 'boolean', name: 'Refresh Button History', desc: 'Loescht die Historie Servicemeldungem wenn true' });
              for (const { alarmtype, count, Datenpunkt } of Zaehler) {               // Schleife ueber das Zaehler-Array und anlegen der States
                  await createStateAsync(Datenpunkt, count, {read: true, write: true,type: 'number',name: `Servicemeldungen Anzahl ${alarmtype}`,desc: `Anzahl ${alarmtype} Servicemeldungen`});
          if (callback) await callback();         // Aufruf des Callbacks nach Abschluss aller Operationen
              } catch (error) {
              LOG(`Kategorie:WARN; Routine:CreateStates; Routine Create States - Fehler beim Erstellen der Zustaende: ${error}`, 0, "warn");
          if (!UpdateTEXT_Datenpunkte) {
              if (existsState(id_Text_ServicemeldungLang)) { deleteState(id_Text_ServicemeldungLang); }
              if (existsState(id_Text_ServicemeldungKurz)) { deleteState(id_Text_ServicemeldungKurz); }
              if (existsState(id_Text_Servicemeldung_History)) { deleteState(id_Text_Servicemeldung_History); }
          if(!UpdateHTML_Datenpunkte) {    // nur wenn Text-Datenpunkte auch gewuenscht sind
              if (existsState(id_HTML_Servicemeldung_Aktuell)) { deleteState(id_HTML_Servicemeldung_Aktuell); }
              if (existsState(id_HTML_Servicemeldung_History)) { deleteState(id_HTML_Servicemeldung_History); }
      L 1 Antwort Letzte Antwort
      • Eduard77E Eduard77
        @looxer01
        Habe jetzt so gemacht wie du beschreiben hast, aber bekomme wieder Warnung.
        anbei mein geänderte Skript zur Prüfung.
        // Beschreibung des Scriptes: https://forum.iobroker.net/topic/77816/vorlage-servicemeldungen-volume2
        // Autor Looxer01 02.11.2024 Version 1.0 (initiale Version)
        // Version 3.00 - 05.01.2025 Variable MessageBeiKeinerSM in die Experteneinstellungen geschoben // Problem bei der Datumsberechnung behoben // Zaehler fuer Historie hinzugefuegt
        //                           die Datenpunkte fuer Text-Format werden jetzt optional gefuellt
        // Version 3.10 - 01.02.2024 Wartezeit fuer HM-Rega von 2 auf 3,5 Sekunden erhoeht - Funktion der Tabelle MessengerScope erweitert
        // Version 3.20 - 24.02.2024 Doppelte Nachrichten im messageCollector verhindern - Vermeidung Meldung "keine Servicemeldungen..." in der Historie wenn bereits vorhanden - Wartezeit für Rega-Trigger wieder auf 5s
        //                           StickyMessages koennen automatisch bestaetigt werden
        // Muss-Einstellungen                                 ( HM-Classic , HMIP, Wired - hier muessen zwingend die Instanzen stimmmen )
        // Im folgenden sind die Instanzen gelistet fuer die die Selektion erfolgt bzw nicht erfolgt (Filter)
        // bitte 9 Eintragen falls eine Instanz nicht relevant ist // Gruppeninstanzen sind normalerweise nicht relevant
        // CuxD Instanzen duerfen nicht eingetragen werden  --- ACHTUNG: bei HMIPAccessPoint-Nutzung muss GeraeteTriggerID auf true stehen
        const HMClassicInstanz      = 9;        // HM-Classic Instanz eintragen     // 9 = falls nicht relevant
        const HMIPInstanz           = 9;        // Homematic IP instanz             // 9 = falls nicht relevant
        const WiredIClassicInstanz  = 9;        // Wired Instanz                    // 9 = falls nicht relevant
        const GruppenInstanz        = 9;        // virtuelle GeraeteInstanz- 9 = nicht relevant - Die Gruppen werden i.d.R. nicht gebraucht - Empfehlung: 9
        let   HMIPAccessPoint       = 0;        // AccessPoint Servicemeldungen - (normalerweise instanz = 0) bei nicht Verwendung Instanz = 9
        // Kann-Einstellungen
        // Pfad kann angepasst werden fuer userdata pfad einfach // entfernen
        const path      = "javascript.0.ServicemeldungenVol2.";
        //const path    = "0_userdata.0.ServicemeldungenVol2."; // alternativ zum javascript pfad
        // schreibt das Protokoll der Servicemeldungen in ein externes file (Excel Format)
        const SMProtokoll = true;
        const PathSMLog = "/opt/iobroker/log/ServicemeldungenVol2.csv";             // Pfad und Dateiname des externen Logs
        //const PathSMLog = "/iobroker/log/ServicemeldungenVol2.csv";            // Pfad fuer Windows/  iobroker ist der angenommene iobroker home-pfad
        //Geraete die nicht ueberwacht werden sollen. Geraete-IDs eingeben - Komma getrennt erfassen
        const Ausschlussliste = ['0000D7099xxx26', '00091D8xxx7410']; // immer mit Komma trennen // Filter auf Einzel-IDs
        // debug level kann eingestellt werden - wenn alles laeuft dann 0 = ruhe im log
        // debug level 0   kein log // debug level 1 - nur die wichtigsten Meldungen werden gelistet // debug level 2 - mehr als nur die wichtigsten Meldungen aber ohne einzelne IDs
        // debug level 3 - hier werden auch einzelne IDs gelistet (koennten lange listen werden)
        const debugLevel = 2 ;     // Empfehlung = 1
        const SystemLog = false;  // schreib das Sytemprotokoll in ein externes log (sollte normalerweise deaktviert sein  nur bei Problemen verwenden)
        const PathSystemLog = "/opt/iobroker/log/ServicemeldungenSystemLog.csv";             // Pfad und Dateiname des externen Logs
        //const PathSystemLog = "/iobroker/log/ServicemeldungenSystemLog.csv";             // Pfad fuer Windows
        // wenn GeraeteIDTrigger auf true gestellt wird, dann wird fuer jeden Datenpukt mit Relevanz fuer eine Servicemeldung eine subscription angelegt.
        // Vorteile: mehr Details in der Historie von Servicemeldungen: Nachteil: bei 80 CCU Geraeten ungefaehr 300 Susbsriptions
        // Wenn die variable auf false steht, dann wird auf hm.rega.0.maintenance eine subsription angelegt: Vorteil: 1 Subscription , Nachteil: erweiterte Funktion fuer nicht CCU Datenpunkte nicht verfuegbar
        // bei HMIP AccessPoint Cloud HCU - funktioniert das nur bei GeraeteTrigger = true
        let GeraeteIDTrigger = false; // true = viele subscriptions aber praezise Historie der Servicemeldungen - false = 1 subscription - weniger praezise Historie - Empfehlung = false
        // Speicherung der Servicemeldungen im  Text-Format - Empfehlung = false // davon ausgehend, dass das JSON Format in der Visualisierung gut dargestellt werden kann
        const UpdateTEXT_Datenpunkte = false; // die kurz- und langen Servicemeldungen als auch die historischen werden immer im JSON Format abgelegt. Alternativ koennen diese auch in einem TEXT Format in Datenpunkten gespeichert werden
        // Speicherung der Servicemeldungen im  HTML-Format - Wird empfohlen zu nutzen, wenn es Problem bei der Visualisierung von JSON gibt.
        const UpdateHTML_Datenpunkte = true; // die langen Servicemeldungen als auch die historischen werden immer im JSON Format abgelegt. Alternativ koennen diese auch in einem HTML Format in Datenpunkten gespeichert werden
        // Die Autobestaetigung bestaetigt automatisch evt Sticky-Meldungen der CCU
        const AutoBestaetigungCCUMeldungen = true; // Empfehlung ist true - nur relevant fur HM-Classic Geraete //bei true sollte in der CCU die autobestaetigung ausgeschaltet werden
        //  fuer alle Spalten mit true werden die Nachrichten ueber den zugeordneten Dienst versendet, vorausgesetzt der Messenge Adapter ist in iobroker installiert/konfiguriert
            const services =               ['email',    'whatsApp',     'Signal',  'Telegram',    'Pushover', 'Pushsafer', 'Pushsafer',];
            const MessengerScope = {
            'UNREACH_ALARM':                [true,        false,          false,      true,          false,      false,       false,],
            'STICKY_UNREACH_ALARM':         [false,       false,          false,      false,          false,      false,       false,],   // Sticky sollte nicht gesendet werden - alles auf false setzen
            'LOWBAT_ALARM':                 [true,        false,          false,      true,          false,      false,       false,],
            'SABOTAGE_ALARM':               [true,        false,          false,      true,          false,      false,       false,],
            'STICKY_SABOTAGE_ALARM':        [false,       false,          false,      false,          false,      false,       false,],   // Sticky sollte nicht gesendet werden - alles auf false setzen
            'CONFIG_PENDING_ALARM':         [true,        false,          false,      true,          false,      false,       false,],
            'Sonstige':                     [true,        false,          false,      true,          false,      false,       false,], // text ist fest verdrahtet nicht ändern
            'keineSM':                      [true,        false,          false,      true,          false,      false,       false,], // text ist fest verdrahtet nicht ändern
            const MessengerInstanz =        [0,             0,               0,          0,              0,          0,            1,  ]; // Instanz des Messengers
            const TextTypeKurz      =       [false,        true,            true,       true,           true,      true,         false,]; // bei true wird der Kurztext gesendet - sonst der Langtext
        // email-Einstellungen
        let emailAddresse = "Vorname-Nachname@web.de"   // Empfängeraddresse
        const Headline = "ioBroker Servicemeldung";     // Ueberschrift Messages fuer email und Pushsafer
        // telegram Einstellungen
        const TelegramUser = "Eduard";
        //Experten Einstellungen - Empfehlung:  Absprache mit dem Autor
        const MessageBeiKeinerSM = 'Derzeit keine Servicemeldungen'     // Text der erscheinen soll, wenn keine SM vorliegen Ein Kurztext ist erforderlich
        //const NichtRelevantText = 'n/a';                                // statt n/a kann ein beliebiger anderer Text in den JSON verwendet werden
        const NichtRelevantText = "......";
        // die folgenden Einstellungen sind nur relvant bei Verwendung von HTML als Datenpunkte
            // Definieren der Farbwerte für Kopfzeile, gerade und ungerade Zeilen
            const headerColor = '#333333';  // Standardfarbe (Fuellfarbe) für die Kopfzeile
            const evenRowColor = '#4e5049'; // Standardfarbe (Fuellfarbe) für gerade Zeilen
            const oddRowColor = '#333333';  // Standardfarbe (Fuellfarbe) für ungerade Zeilen
            // Definieren der Textfarben für Kopfzeile, gerade und ungerade Zeilen
            const headerTextColor = 'white'; // Textfarbe für Kopfzeile
            const evenRowTextColor = 'white'; // Textfarbe für gerade Zeilen
            const oddRowTextColor = 'white';  // Textfarbe für ungerade Zeilen
            // Definieren von Zellenumrandungseinstellungen
            const useBorderAll =    true; // true, wenn ein Gitternetz erzeugt werden soll
            const borderColor = '#000000'; // Farbe des Gitternetzes (Zellenumrandung)
            const borderWidth = '1px'; // Strichstärke der Zellenumrandung
        //Schedule Zeit fuer refresh der Historie
        const ScheduleAktiv = true;                         // Bei "false" wird der schedule nicht durchlaufen. Manuelles Löschen kann über den Datenpunkt id_Button_Refresh_Historie (Button) möglich
        const scheduleTimeClearSMTexte = "2 0 1 * *";       // am 1. tag des monats um 00:02 morgens sollen alle Servicemeldungen des Monats geloescht werden
        // const scheduleTimeClearSMTexte = "58 23 * * 0";  // alternative Sonntags um 23:58 Uhr sollen alle Servicemeldungen der Woche im datenpunkt der SM-Texte geloescht werden
        //Batterie-Zuordnungen fuer Servicmeldungen
        const batteryTypes = {
            '1x CR2016':    ['HM-RC-4', 'HM-RC-4-B', 'HM-RC-Key3', 'HM-RC-Key3-B', 'HM-RC-P1', 'HM-RC-Sec3', 'HM-RC-Sec3-B', 'ZEL STG RM HS 4'],
            '1x CR2032':    ['HM-PB-2-WM', 'HM-PB-4-WM', 'HM-PBI-4-FM', 'HM-SCI-3-FM', 'HM-Sec-TiS', 'HM-SwI-3-FM', 'HmIP-FCI1'],
            '2x LR14':      ['HM-Sec-Sir-WM', 'HM-OU-CFM-TW', 'HM-OU-CFM-Pl', 'HM-OU-CF-Pl'],
            '2x LR44/AG13': ['HM-Sec-SC', 'HM-Sec-SC2L', 'HM-Sec-SC-2', 'HM-Sec-RHS'],
            '2x LR6/AA':    ['HM-CC-VD', 'HM-CC-RT-DN', 'HM-Sec-WDS', 'HM-Sec-WDS-2', 'HM-CC-TC', 'HM-Dis-TD-T', 'HB-UW-Sen-THPL-I', 'HM-WDS40-TH-I', 'HM-WDS40-TH-I-2',
                             'HM-WDS10-TH-O', 'HmIP-SMI',                     'HMIP-eTRV', 'HM-WDS30-OT2-SM-2', 'HmIP-SMO', 'HmIP-SMO-A', 'HmIP-SPI', 'HmIP-eTRV-2',
                             'HmIP-SPDR', 'HmIP-STHO-A', 'HmIP-eTRV-B', 'HmIP-PCBS-BAT', 'HmIP-STHO', 'HmIP-eTRV-C',
                             'HmIP-WGC', 'HmIP-eTRV-C-2', 'HmIP-eTRV-E', 'HmIP-eTRV-2 I9F', 'HmIP-eTRV-E-S', 'ELV-SH-SW1-BAT'],
            '3x LR6/AA':    ['HmIP-SWO-PL', 'HM-Sec-MDIR', 'HM-Sec-MDIR-2', 'HM-Sec-SD', 'HM-Sec-Key', 'HM-Sec-Key-S', 'HM-Sec-Key-O', 'HM-Sen-Wa-Od', 'HM-Sen-MDIR',
                             'HM-Sen-MDIR-O', 'HM-Sen-MDIR-O-2', 'HM-WDS100-C6-O', 'HM-WDS100-C6-O-2', 'HmIP-ASIR', 'HmIP-SWO-B', 'HM-Sen-MDIR-O-3', 'HM-Sec-MDIR-3',
                             'HmIP-SWO-PR', 'HmIP-DLD', 'HmIP-ASIR-2'],
            '4x LR6/AA':    ['HM-CCU-1', 'HM-ES-TX-WM', 'HM-WDC7000'],
            '1x LR3/AAA':   ['HM-RC-4-2', 'HM-RC-4-3', 'HM-RC-Key4-2', 'HM-RC-Key4-3', 'HM-RC-Sec4-2', 'HM-RC-Sec4-3', 'HM-Sec-RHS-2', 'HM-Sec-SCo', 'HmIP-KRC4',
                             'HmIP-KRCA', 'HmIP-SRH', 'HMIP-SWDO', 'HmIP-DBB', 'HmIP-RCB1', 'HmIP-KRCK', 'HmIP-SWDO-2'],
            '2x LR3/AAA':   ['HmIP-WRCR', 'HmIP-SWD','HM-TC-IT-WM-W-EU', 'HM-Dis-WM55', 'HM-Dis-EP-WM55', 'HM-PB-2-WM55', 'HM-PB-2-WM55-2', 'HM-PB-6-WM55', 'HM-PBI-2-FM', 'HM-RC-8', 'HM-Sen-DB-PCB',
                            'HM-Sen-EP', 'HM-Sen-MDIR-SM', 'HM-Sen-MDIR-WM55', 'HM-WDS30-T-O', 'HM-WDS30-OT2-SM', 'HmIP-STH', 'HmIP-STHD', 'HmIP-WRC2', 'HmIP-WRC6', 'HmIP-WTH', 'HmIP-WTH-2',
                            'HmIP-SAM', 'HmIP-SLO', 'HMIP-SWDO-I', 'HmIP-FCI6', 'HmIP-SMI55', 'HM-PB-2-FM', 'HmIP-SWDM', 'HmIP-SCI', 'HmIP-SWDM-B2', 'HmIP-RC8', 'ALPHA-IP-RBG', 'HmIP-DSD-PCB',
                            'HmIP-WRCD', 'HmIP-WRC2-A', 'HmIP-WTH-B-2', 'HmIP-WTH-A', 'HmIP-STV', 'HmIP-WKP'],
            '3x LR3/AAA':   ['HM-PB-4Dis-WM', 'HM-PB-4Dis-WM-2', 'HM-RC-Dis-H-x-EU', 'HM-Sen-LI-O'],
            '3x AAA Akkus - bitte laden': ['HM-RC-19', 'HM-RC-19-B', 'HM-RC-12', 'HM-RC-12-B', 'HM-RC-12-W'],
            '3x LR14/C':    ['HmIP-MP3P'],
            '9Volt Block leer oder unbestimmt': ['HM-LC-Sw1-Ba-PCB', 'HM-LC-Sw4-PCB', 'HM-MOD-EM-8', 'HM-MOD-Re-8', 'HM-Sen-RD-O', 'HM-OU-CM-PCB', 'HM-LC-Sw4-WM'],
            'Festbatterie leer': ['HmIP-STE2-PCB', 'HM-Sec-SD-2', 'HmIP-SWSD', 'HmIP-PCBS'],
            'ohne Batterie': ['HM-LC-Sw1PBU-FM', 'HM-LC-Sw1-Pl-DN-R1', 'HM-LC-Sw1-DR', 'HM-LC-RGBW-WM', 'HM-LC-Sw1-Pl-CT-R1', 'HmIP-HEATING', 'HM-LC-Sw1-FM', 'HM-LC-Sw2-FM', 'HM-LC-Sw4-DR',
                                'HM-LC-Sw1-Pl', 'HM-LC-Sw1-Pl-2', 'HM-LC-Sw4-Ba-PCB', 'HM-LC-Sw1-SM', 'HM-LC-Sw4-SM', 'HM-Sys-sRP-Pl', 'HM-LC-Sw2PBU-FM', 'HM-LC-Sw1-PCB', 'HM-LC-Sw4-DR-2'],
            'Akku entladen - bitte aufladen': ['HM-Sec-Win', 'HM-Sec-SFA-SM', 'HM-RC-19-SW']
        // Rega Pfad
        const PathRega = ['hm-rega.0.maintenance',];                            // Array um ggf die HCU zu konfigurieren
        // Pfade fuer die Speicherung aktueller und vergangener Servicemeldungen
        const id_Text_ServicemeldungLang        = path+'TextLangAktuelleSM';    // Objekt wo die Servicemeldung hingeschrieben werden soll (String) = path+'TextLang';
        const id_Text_ServicemeldungKurz        = path+'TextKurzAktuelleSM';    // Objekt wo die Servicemeldung hingeschrieben werden soll (String) - kurze Version
        const id_Text_Servicemeldung_History    = path+'TextLangVergangeneSM';  // Objekt wo die Servicemeldung hinzugefuegt werden soll (String) - Lange Version (es gibt nur lang)
        const id_HTML_Servicemeldung_Aktuell    = path+'HtmlAktuelleSM';        // Objekt wo die Servicemeldung hingeschrieben werden soll (HTML formatiere Tabelle) = path+'htmlLang';
        const id_HTML_Servicemeldung_History    = path+'HtmlVergangeneSM';      // Objekt wo die Servicemeldung hinzugefuegt werden soll ((HTML formatiere Tabelle) - Lange Version (es gibt nur lang)
        const id_JSON_Servicemeldung_Aktuell    = path+'JSONAktuelleSM';        // JSON Tabelle Datenpunkt Aktuelle SM
        const id_JSON_Servicemeldung_Historie   = path+'JSONVergangeneSM';      // JSON Tabelle Datenpunkt Historische SM
        const id_Button_Refresh_Historie        = path+'ButtonRefreshHistorie'; // Wenn DP auf true gesetzt wird, dann wird die historie refreshed (geloescht)
        // Count-Pfade  und counts in einer Tabelle - wird auch fuer CREATE STATES verwendet
        const Zaehler = [
          { alarmtype: 'UNREACH_ALARM',                    count: 0,                    Datenpunkt: path+'Anzahl_UNREACH' },
          { alarmtype: 'STICKY_UNREACH_ALARM',             count: 0,                    Datenpunkt: path+'Anzahl_STICKY_UNREACH' },
          { alarmtype: 'CONFIG_PENDING_ALARM',             count: 0,                    Datenpunkt: path+'Anzahl_CONFIG_PENDING' },
          { alarmtype: 'UPDATE_PENDING_ALARM',             count: 0,                    Datenpunkt: path+'Anzahl_Update_PENDING' },
          { alarmtype: 'LOWBAT_ALARM',                     count: 0,                    Datenpunkt: path+'Anzahl_LOWBAT' },
          { alarmtype: 'DEVICE_IN_BOOTLOADER_ALARM',       count: 0,                    Datenpunkt: path+'Anzahl_DEVICE_IN_BOOTLOADER' },
          { alarmtype: 'ERROR',                            count: 0,                    Datenpunkt: path+'Anzahl_in_ERROR' },
          { alarmtype: 'FAULT_REPORTING',                  count: 0,                    Datenpunkt: path+'Anzahl_FAULT_REPORTING' },
          { alarmtype: 'SABOTAGE_ALARM',                   count: 0,                    Datenpunkt: path+'Anzahl_SABOTAGE' },
          { alarmtype: 'ERROR_NON_FLAT_POSITIONING_ALARM', count: 0,                    Datenpunkt: path+'Anzahl_NON_FLAT_POSITIONING' },
          { alarmtype: 'STICKY_SABOTAGE_ALARM',            count: 0,                    Datenpunkt: path+'Anzahl_Sticky_SABOTAGE' },
          { alarmtype: 'SMAktuell',                        count: 0,                    Datenpunkt: path+'Anzahl_SM-Aktuell' },
          { alarmtype: 'SMHistorie',                       count: 0,                    Datenpunkt: path+'Anzahl_SM-Historie' },
          { alarmtype: 'Gesamt',                           count: 0,                    Datenpunkt: path+'Anzahl_GESAMT' }
        // statusmessages je messagetype und   adapter // Fallback ist fuer unbekannte messagetypes - z.B. alle Error Messages // FALLBACK repraesentiert Standardmessages
        const statusMessages = {
            UNREACH_ALARM:                    { "hm-rpc": { 0: "keine Kommunikationsfehler",     1: "Kommunikation gestoert",                            2: "Kommunikation war gestoert" } },
            STICKY_UNREACH_ALARM:             { "hm-rpc": { 0: "keine Kommunikationsfehler",     1: "Sticky Kommunikation gestoert",                     2: "Sticky Kommunikation war gestoert" } },
            SABOTAGE_ALARM:                   { "hm-rpc": { 0: "Keine Sabotage",                 1: "Sabotage",                                          2: "Sabotage aufgehoben" } },
            STICKY_SABOTAGE_ALARM:            { "hm-rpc": { 0: "Keine Sabotage",                 1: "Sticky Sabotage",                                   2: "Sticky Sabotage aufgehoben" } },
            LOWBAT_ALARM:                     { "hm-rpc": { 0: "Batterie ok",                    1: "Batterie niedrig",                                  2: "Batterie ok" } },
            LOW_BAT_ALARM:                    { "hm-rpc": { 0: "Batterie ok",                    1: "Batterie niedrig",                                  2: "Batterie ok" } },
            ERROR_NON_FLAT_POSITIONING_ALARM: { "hm-rpc": { 0: "Keine Meldung",                  1: "Geraet wurde angehoben.",                           2: "Geraet wurde angehoben: Bestaetigt" } },
            CONFIG_PENDING_ALARM:             { "hm-rpc": { 0: "keine Meldung",                  1: "Konfigurationsdaten stehen zur Uebertragung an",    2: "Konfigurationsdaten standen zur Uebertragung an",}, },
            UPDATE_PENDING_ALARM:             { "hm-rpc": { 0: "kein Update verfuegbar",         1: "Update verfuegbar",                                 2: "Update wurde eingespielt" } },
            ERROR_OVERHEAT_ALARM:             { "hm-rpc": { 0: "kein Overheat Alarm",            1: "Overheat gemeldet",                                 2: "Overheat geloest" } },
            ERROR_UNDERVOLTAGE_ALARM:         { "hm-rpc": { 0: "Kein Undervoltage Alarm",        1: "Undervoltage gemeldet",                             2: "Undervoltage geloest" } },
            DEVICE_IN_BOOTLOADER_ALARM:       { "hm-rpc": { 0: "Keine Meldung",                  1: "Geraet startet neu",                                2: "Geraet wurde neu gestartet" } },
            DUTY_CYCLE:                       { "hm-rpc": { false: "Geraete-Duty Cycle ok",      true: "Geraete-Duty Cycle erreicht",                    null: "unbekannter Status (Duty_Cycle" } },
            lowBat:                           { "hmip":   { false: "Batterie ok",                true: "Batterie niedrig",                               null: "Batterie ok" } },
            unreach:                          { "hmip":   { false: "keine Kommunikationsfehler", true: "Kommunikation gestoert",                         null: "Kommunikation war gestoert" } },
            sabotage:                         { "hmip":   { false: "Keine Sabotage",             true: "Sabotage",                                       null: "Sabotage aufgehoben" } },
            configPending:                    { "hmip":   { false: "Keine Meldung",              true: "Konfigurationsdaten stehen zur Uebertragung an", null: "Konfigurationsdaten standen zur Uebertragung an" } },
            FALLBACK:                         { "hm-rpc": { 0: "keine Stoerung",                 1: "Stoerung",                                          2: "Stoerung aufgehoben",
                                                            false: "Keine Stoerung",             true: "Stoerung",                                       null: "unbekannter Status Fallback"},
                                                "hmip":   { false: "keine Stoerung",             true: "Stoerung",                                       null: "Stoerung aufgehoben" }, }
        //ErrorMessages fuer HM-Classic Geraete - Sonderfaelle
        const errorMessages = {
            'HM-Sec-RHS':   { 7: 'Sabotage' },
            'HM-Sec-RHS-2': { 7: 'Sabotage' },
            'HM-Sec-SC':    { 7: 'Sabotage' },
            'HM-Sec-SC-2':  { 7: 'Sabotage' },
            'HM-Sec-SCo':   { 7: 'Sabotage' },
            'HM-Sec-MD':    { 7: 'Sabotage' },
            'HM-Sec-MDIR':  { 7: 'Sabotage' },
            'HM-Sec-MDIR-2':{ 7: 'Sabotage' },
            'HM-Sec-Key':   { 1: 'Einkuppeln fehlgeschlagen', 2: 'Motorlauf abgebrochen' },
            'HM-Sec-Key-S': { 1: 'Einkuppeln fehlgeschlagen', 2: 'Motorlauf abgebrochen' },
            'HM-Sec-Key-O': { 1: 'Einkuppeln fehlgeschlagen', 2: 'Motorlauf abgebrochen' },
            'HM-CC-VD':     { 1: 'Ventil Antrieb blockiert',  2: 'Ventil nicht montiert', 3: 'Stellbereich zu klein', 4: 'Batteriezustand niedrig'
        //ErrorMessages fuer HM-Classic Geraet (Heizung) - Sonderfaelle
        const faultMessages = {
            'HM-CC-RT-DN': {
                0: 'keine Stoerung',
                1: 'Ventil blockiert',
                2: 'Einstellbereich Ventil zu gross',
                3: 'Einstellbereich Ventil zu klein',
                4: 'Kommunikationsfehler',
                6: 'Spannung Batterien/Akkus gering',
                7: 'Fehlstellung Ventil'
        // hier koennen die Alarmgruppen ggf erweitert werden - Aus Alarmgruppe und Instanz wird der Selector gebastelt und in Tabelle Selectors gesammelt
        const alarmTypes = [
            { key: 'UNREACH_ALARM',                     suffixes: ['UNREACH_ALARM','unreach' ] },//UNREACH_ALARM = HM-Classic & HMIP-CCU - unreach = HMIP Accesspoint
           // { key: 'STICKY_UNREACH_ALARM',              suffixes: ['STICKY_UNREACH_ALARM'] },
            { key: 'CONFIG_PENDING_ALARM',              suffixes: ['CONFIG_PENDING_ALARM','configPending'] }, //configPending ist eine HMIP Meldung
            { key: 'UPDATE_PENDING_ALARM',              suffixes: ['UPDATE_PENDING_ALARM'] },
            { key: 'LOWBAT_ALARM',                      suffixes: ['LOWBAT_ALARM', 'LOW_BAT_ALARM','lowBat'] }, //LOWBAT_ALARM = HM-Classic - LOW_BAT_ALARM = HMIP CCU - lowBat = HMIP Accesspoint
            { key: 'DEVICE_IN_BOOTLOADER_ALARM',        suffixes: ['DEVICE_IN_BOOTLOADER_ALARM'] },
            { key: 'ERROR',                             suffixes: ['ERROR','DUTY_CYCLE'] },                  // error ist ein Sammler fuer hier nicht definierte Meldungen
            { key: 'FAULT_REPORTING',                   suffixes: ['FAULT_REPORTING'] },
            { key: 'SABOTAGE_ALARM',                    suffixes: ['SABOTAGE_ALARM','sabotage'] }, // sabotage ist eine HMIP Meldung
          //  { key: 'STICKY_SABOTAGE_ALARM',             suffixes: ['STICKY_SABOTAGE_ALARM'] },
            { key: 'ERROR_NON_FLAT_POSITIONING_ALARM',  suffixes: ['ERROR_NON_FLAT_POSITIONING_ALARM'] },
            { key: 'OVERHEAT_ALARM',                    suffixes: ['ERROR_OVERHEAT_ALARM'] },
            { key: 'UNDERVOLTAGE_ALARM',                suffixes: ['ERROR_UNDERVOLTAGE_ALARM'] },
        // Umlaut Umwandlung und entfernung PUnkte - kann aber auch erweitert werden
        const replacements = { '.': ' ', 'ä': 'ae', 'ü': 'ue', 'ö': 'oe', 'ß': 'ss' }; // Umwandlung fuer Namen der Geraete (common.name)
        // Definition der Datenstrukturen fuer MetaDaten je nach Adapter, da abweichend
        const StrukturDefinition = [
            { Adapter: 'hm-rpc',   GeraeteID: 2, AlarmFeld: 4, nativeType: 3,                                             common_name:  3 }, // die Ziffer ist die Positinierung des Feldes 'hm-rpc.1.00085D89B14067.0.UPDATE_PENDING_ALARM' 0=Adapter - 2 = ID 4= Feld Alarm / native Type = die ersten Strings bis zur dritten STelle fuer getObject
            { Adapter: 'hmip',     GeraeteID: 3, AlarmFeld: 6, nativeType: 'hmip.xinstancex.devices.xidx.info.modelType', common_name: 'hmip.xinstancex.devices.xidx.info.label' }, // Positionierung wie bei Rm-rpc - bei hmip wird native type aber ueber den DP ausgelesen und nicht getObject "xidx" wird dann mit der geraeteiD ersetzt
        // Moegliche Homematic Instanzen (CuxD ausgeschlossen) // Adapter hinzugefuegt um ggf HCU zu konfigurieren
        const instanceIds = [
            { name: 'HMClassicInstanz',     adapter: 'hm-rpc', Instanz: HMClassicInstanz     },
            { name: 'HMIPInstanz',          adapter: 'hm-rpc', Instanz: HMIPInstanz          },
            { name: 'GruppenInstanz',       adapter: 'hm-rpc', Instanz: GruppenInstanz       },
            { name: 'WiredIClassicInstanz', adapter: 'hm-rpc', Instanz: WiredIClassicInstanz },
            { name: 'HMIPAccessPoint',      adapter: 'hmip'  , Instanz: HMIPAccessPoint      },
        // Die StickingMappingsTabelle stellt sicher, dass die Sticky entsprechend dieser Regel bestaetigt werden kann
        const StickyMappings = {
            STICKY_UNREACH_ALARM:            ['UNREACH_ALARM'],
            STICKY_SABOTAGE_ALARM:           ['SABOTAGE_ALARM'],
        // Konfigurationsobjekt fuer Ausnahmen / es koennen Arlarmtypes je Instanz ausgeschlossen werden / Filter auf AlarmTypes
        const exceptions = {
            HMClassicInstanz:       [],
            HMIPInstanz:            ['DUTY_CYCLE'],
            GruppenInstanz:         ['ERROR_NON_FLAT_POSITIONING_ALARM'],
            WiredIClassicInstanz:   ['LOWBAT_ALARM', 'LOW_BAT_ALARM','ERROR_NON_FLAT_POSITIONING_ALARM'],
        //Ende Einstellungen
        LOG(`Script: Servicemeldungen Volume 2 - Autor: Looxer01 Datum: 24.02.2025 Version:3.20`,`Einstellungen`,`Start`,0 )
        if(HMIPAccessPoint !== 9 && !GeraeteIDTrigger) {
            GeraeteIDTrigger = true // Wenn der HMIPAccessPoint aktiv ist, dann funktioniert der REGA Trigger nicht. also setzen auf geraeteID Trigger=true
            LOG(`HMIP AccessPoint bzw Cloud HCU sind aktiv - GeraeteTriggerID muss aktiviert sein - wurde aktiviert. Bitte auch manuell korrigieren und auf GeraeteTriggerID = true setzen`,`Einstellungen`,`Start`,0 )
        LOG(`HMClassicInstanz: ${HMClassicInstanz}; HMIPInstanz: ${HMIPInstanz}; WiredIClassicInstanz: ${WiredIClassicInstanz}; GruppenInstanz: ${GruppenInstanz}`, "Einstellungen", "Start", 2);
        LOG(`Inhalt instanceIds: ${JSON.stringify(instanceIds)}`, "Einstellungen", "Start", 2);
        LOG(`GeraeteIDTrigger: ${GeraeteIDTrigger}`, "Einstellungen", "Start", 2);
        LOG(`Inhalt Messengerscope: ${JSON.stringify(MessengerScope)}`, "Einstellungen", "Start", 2);
        LOG(`Inhalt Services: ${JSON.stringify(services)}`, "Einstellungen", "Start", 2);
        LOG(`Inhalt Messenger-Instanzen: ${JSON.stringify(MessengerInstanz)}`, "Einstellungen", "Start", 2);
        LOG(`Inhalt TextTypeKurz: ${JSON.stringify(TextTypeKurz)}`, "Einstellungen", "Start", 2);
        let HistorischeMeldungenJSON = [], AktuelleMeldungenJSON = [], MessageSendCollector = {};
        // jetzt selectors fuellen anhand der Tabelle InstanceIDs, sowie der Auscchlusstabellen
        let totalIdsCount = 0;                                                  // Variable fuer die Gesamtzahl der IDs
        const selectors = alarmTypes.map(alarmType => {
            const collectedIds = [];
            instanceIds.forEach(instance => {
                if (instance.Instanz !== 9) {                                   // Umbenennung von `instance.id` zu `instance.Instanz`
                    const excludedAlarmTypes = exceptions[instance.name] || []; // Hole Ausnahmen oder leere Liste
                    if (!excludedAlarmTypes.includes(alarmType.key)) {          // Wenn Alarmtype nicht in der Ausnahme
                        alarmType.suffixes.forEach(suffix => {                  // wenn suffix (meldungsart) nicht in der Ausnahme
                            if (!excludedAlarmTypes.includes(suffix)) {
                                // IDs sammeln, ohne sofort zu filtern
                                // @ts-ignore
                                $(`state[id=${instance.adapter}.${instance.Instanz}.*.${suffix}]`).each(id => collectedIds.push(id));
            const filteredIds = collectedIds.filter(id => !id.includes("groups"));  // for accessPoint und HCU sollten die Ids, die "groups" enthalten ausgeschlossen werden . das sind z.B. Raeume
            const finalFilteredIds = filteredIds.filter(id => {                     // IDs anhand der Geraete-IDs in der Ausschlussliste filtern
                const deviceId = id.split('.')[2];                                  // Geraete-ID aus der vollstaendigen ID extrahieren (z. B. "0000D7099xxx26" aus "hm-rpc.1.0000D7099xxx26.0.LOW_BAT_ALARM")
                return !Ausschlussliste.includes(deviceId);                         // Behalten, wenn nicht in der Ausschlussliste
            totalIdsCount += finalFilteredIds.length;                                // IDs zur Gesamtzahl hinzufuegen
            return { name: alarmType.key, ids: finalFilteredIds };
            AktuelleMeldungenJSON = [];
            let jsonString = getState(id_JSON_Servicemeldung_Historie).val || '[]';    // Lade den aktuellen JSON-String des Historie-Datenpunkts
            HistorischeMeldungenJSON = JSON.parse(jsonString);
            Zaehler.forEach(entry => { entry.count = 0; }); // Alle count-Werte im Objekt auf 0 setzen
            for (let j = 0; j < selectors.length; j++) {
                const selector = selectors[j];
                if (selector.ids.length > 0) {
                    for (let i = 0; i < selector.ids.length; i++) {
                        let id = selector.ids[i], status = getState(id).val;
                        if (!existsState(id)) {
                            LOG(`Geraet ${obj.id} scheint zwischenzeitlich nicht mehr zu existieren - Empfehlung: script neu starten`, "WARN", "Check_All", 0, "warn");
                            continue;
                        switch (selector.name) {        // fuer alle alarmtypes - erst die Sonderfaelle
                            case 'ERROR':
                                if (status >= 1 && status <= 7) {
                                    if (status === 7) { // Sonderfall bei HM-Classic
                                        processServiceMessage('SABOTAGE_ALARM', status, id,RunType);
                                    } else {
                                        processServiceMessage(selector.name, status, id,RunType);
                                break;
                        default:                    // Standardfall fuer alle anderen alarmtypes
                                if(status === 1 || status === true ) {processServiceMessage(selector.name, status, id,RunType);  } // bei status = true = AccessPoint
                                break;
                        increaseCount('Gesamt');
                    } // Ende Loop der Mitglieder des Alarmtypes
                }  // Endif selector ist gefuellt
            }    // Ende Loop ueber den Selector
            const AnzahlAktuellerSM = Zaehler.find(e => e.alarmtype === 'SMAktuell').count;
            // Sequenz zur Speicherung der aktuellen Servicemeldungen in die JSON -Datenpunkte--------------------------
            if (AnzahlAktuellerSM  === 0) {
                AktuelleMeldungenJSON =CreateJsonEntry([] ,func_get_datum(),'', '', '','',func_get_datum() + " - " + MessageBeiKeinerSM,MessageBeiKeinerSM,null,false );  // Keine aktuellen Meldungen -> "Keine Meldungen" hinzufuegen
                let jsonString = JSON.stringify(AktuelleMeldungenJSON);
                setState(id_JSON_Servicemeldung_Aktuell, jsonString);           // Aktuelle SM wird in JSON-Datenpunkt als String gespeichert
            } else {
                let jsonString = JSON.stringify(AktuelleMeldungenJSON);              // AktuelleMeldungenJSON wird in Funktion DefineServiceMessage gefuellt
            if (GeraeteIDTrigger && RunType === "trigger" && !existsState(obj.id)) { // obj.id nicht mehr in ioBroker aber noch im Selector
                const GeraeteId = ExtractMetaData(obj.id, "GeraeteID");
                LOG(`Geraet ${GeraeteId} scheint zwischenzeitlich nicht mehr zu existieren - Empfehlung: script neu starten`, "WARN", "Check_All", 0, "warn");
                return;
            // Speziell fuer GerateIDTrigger = true ist, dass es "aufgehoben"-Meldungen gibt, die fuer REGA Trigger nicht ausgewertet werden koennen. diese duerfen auch nicht als aktuelle meldungen in den DP gelangen
            let ExtendedAktuelleMeldungenJSON = [...AktuelleMeldungenJSON]; // Erstelle eine flat copy
            if (GeraeteIDTrigger && RunType === "trigger") {
                const status = obj.newState.val;
                const common_name = ExtractMetaData(obj.id, "CommonName");
                const native_type = ExtractMetaData(obj.id, "nativeType");
                const meldungsart = ExtractMetaData(obj.id, "meldungsart");
                let status_textLang = DefineServiceMessage(native_type, status, obj.id, "lang");
                let status_textPure = DefineServiceMessage(native_type, status, obj.id, "pure");
                if (!checkIFJSONfEntryExists(ExtendedAktuelleMeldungenJSON,func_get_datum(obj.id), GeraeteId,status, meldungsart) ) {       // checken ob ein Eintrag schon in der Historie ist, wenn nicht dann hinzufuegen
                    ExtendedAktuelleMeldungenJSON = CreateJsonEntry(ExtendedAktuelleMeldungenJSON, func_get_datum(obj.id), meldungsart, common_name, GeraeteId, status, status_textLang, status_textPure, func_Batterie(native_type), true)
            // Historische Meldungen hinzufuegen, wenn nicht bereits vorhanden
            ExtendedAktuelleMeldungenJSON.forEach(aktuelleMeldung => {        // Iteriere ueber alle aktuellen Meldungen und fuege aktuelle meldungen in die historie wenn noch nicht vorhanden
                if (!checkIFJSONfEntryExists(HistorischeMeldungenJSON,aktuelleMeldung.datum_seit  ,aktuelleMeldung.GeraeteId, aktuelleMeldung.status, aktuelleMeldung.meldungsart) ) {       // checken ob ein Eintrag schon in der Historie ist, wenn nicht dann hinzufuegen
                    if(!isLatestEntryMessageBeiKeinerSM(ExtendedAktuelleMeldungenJSON)) {    // nicht wenn nicht "keine Servicemeldungen" in aktuellJSON vorhanden ist
                        const message_kurz = aktuelleMeldung.common_name + " " + aktuelleMeldung.status_message_Pure
                        addMessageToCollector(aktuelleMeldung.meldungsart, message_kurz, aktuelleMeldung.status_message_Lang);
                        HistorischeMeldungenJSON = CreateJsonEntry(HistorischeMeldungenJSON, aktuelleMeldung.datum_seit, aktuelleMeldung.meldungsart, aktuelleMeldung.common_name, aktuelleMeldung.GeraeteId, aktuelleMeldung.status, aktuelleMeldung.status_message_Lang, aktuelleMeldung.status_message_Pure, aktuelleMeldung.batterie_bezeichnung, true )
                        writelog(aktuelleMeldung.common_name, aktuelleMeldung.GeraeteId, aktuelleMeldung.meldungsart, aktuelleMeldung.status, aktuelleMeldung.status_message_Lang);       // externes log erzeugen
            // Handling "keine aktuellen Servicemeldungen"
            if (AnzahlAktuellerSM  === 0 && RunType === "trigger") {       // wenn keine SM vorliegen, die Meldung "keine Servicmeldungen" in die History
                if(!isLatestEntryMessageBeiKeinerSM(HistorischeMeldungenJSON)) {    // nur  wenn  "keine Servicemeldungen" in Historische Meldung nicht bereits an erster Stelle vorhanden ist
                    HistorischeMeldungenJSON =CreateJsonEntry(HistorischeMeldungenJSON ,func_get_datum(),'', '', '','',func_get_datum() + " - " + MessageBeiKeinerSM,MessageBeiKeinerSM,null,false );  // Keine aktuellen Meldungen
                    writelog("", "", "", "", MessageBeiKeinerSM);       //  log erzeugen
                    addMessageToCollector('keineSM', MessageBeiKeinerSM, MessageBeiKeinerSM); // Vorbereitung Messagesending
                    sendMessage('keineSM');
            // AutoBestaetigung fuer StickyMessages, wenn diese nicht mehr aktuell sind. nur relevant fuer HM-Classic
            if (AutoBestaetigungCCUMeldungen ) {ConfirmStickyMessages() }
            // Messages senden fuer alle Faelle mit Servicemeldungen
            if (AnzahlAktuellerSM  > 0 && RunType ==="trigger") {            // Servicemeldungen versenden, falls servicemeldungen vorliegen
                sendMessage();
            HistorischeMeldungenJSON = Markiere_HistSM_als_Aufgehoben(HistorischeMeldungenJSON) // markiert hist messages als erledigt falls nicht mehr in aktuelle meldungen enthalten
            jsonString = JSON.stringify(HistorischeMeldungenJSON);                  // Vorbereitung speichern
            setState(id_JSON_Servicemeldung_Historie, jsonString);                  // hist JSON-Daten speichern
            // falls so eingestellt werden jetzt die TEXTe aus den JSON (aktuell und historie) erzeugt und in die Datenpunkte geschrieben
            GenerateTEXT_Datenpunkte();
            generateHtmlTable(AktuelleMeldungenJSON,"AKT");                 // Aktuelle SM wird in HTML Format gespeichert falls so eingestellt
            generateHtmlTable(HistorischeMeldungenJSON,"HIST");             // Historische  SM wird in HTML Format gespeichert falls so eingestellt
            // anzahl der Eintraege in HistorischeMeldungenJSON ermitteln und alle counts in die Statistik schreiben
            let entry = Zaehler.find(item => item.alarmtype === "SMHistorie");
            if (entry) {entry.count = HistorischeMeldungenJSON.length;    }          // Wenn der Eintrag gefunden wird, aktualisiere den count-Wert
            Zaehler.forEach(entry => {    // JETZT: ZaehlerStaende in die ioBroker - Datenpunkte-------------------fuer aktuelle Meldungen
                setState(entry.Datenpunkt, entry.count);
            // Log Ausgabe der Ergebnisse--------------------------------------------
            LOG(`Es wurden insgesamt ${Zaehler.find(e => e.alarmtype === 'Gesamt').count} IDs gecheckt - insgesamt gibt es ${AnzahlAktuellerSM} Servicemeldungen`, "Ergebnis", "Check_All", 2);
            Zaehler.forEach(({ alarmtype, count }) => {
                LOG(`SMAktuell fuer alarmtype: ${alarmtype} insgesamt festgestellte Servicemeldungen: ${count}`, "Ergebnis", "Check_All", 2);
            LOG(`Zeitverbrauch fuer Routine Check_All: ${Date.now() - startTime} Millisekunden`, "Ergebnis", "Check_All", 1);
            AktuelleMeldungenJSON =[]; HistorischeMeldungenJSON = [];  MessageSendCollector = {};    // Speicher freigeben
        //  Function processServiceMessage // Zuordnung der richtigen Servicemeldung zum Alarmtype / Zaehlung der Faelle
        function processServiceMessage(alarmtype, status, id, RunType) {
            const native_type = ExtractMetaData(id, "nativeType");
            const meldungsart = ExtractMetaData(id, "meldungsart");
            const common_name = ReplaceString(ExtractMetaData(id, "CommonName"));
            const GeraeteId = ExtractMetaData(id, "GeraeteID");
            let ServiceMeldungTextLang = DefineServiceMessage(native_type, status, id, "lang");     // aktuelle Servicemeldung ableiten
            let ServiceMeldungTextPure = DefineServiceMessage(native_type, status, id, "pure");
            AktuelleMeldungenJSON = CreateJsonEntry(AktuelleMeldungenJSON, func_get_datum(id), meldungsart, common_name, GeraeteId, status, ServiceMeldungTextLang, ServiceMeldungTextPure, func_Batterie(native_type), true); // nur einmal unabhaengig der Version
            increaseCount(alarmtype); increaseCount('SMAktuell');
        // Funktion ConfirmStickyMessages Autoconfirm Servicemeldungen (STICKY bei HM-Classic)
        function ConfirmStickyMessages() {
            LOG("Routine ConfirmStickyMessages wird ausgeführt", "Ablauf", "ConfirmStickyMessages", 2);
            let Adapter, Instanz, StickyMeldungsart, StickyMappedString, ID_Constructed, GeraeteID;
            let AckFlag = false; let delay = 0;
            const foundInstance = instanceIds.find(item => item.name === 'HMClassicInstanz'); // die HMClassic Instanz wird ermittelt
            if (foundInstance) {
                Adapter = foundInstance.adapter;
                Instanz = foundInstance.Instanz;
            for (let i = 0; i < AktuelleMeldungenJSON.length; i++) {
                const aktuelleMeldung = AktuelleMeldungenJSON[i];
                StickyMeldungsart = aktuelleMeldung.meldungsart;
                StickyMappedString = StickyMappings[StickyMeldungsart];
                GeraeteID = aktuelleMeldung.GeraeteId;
                if (StickyMappedString === undefined) { continue }
                ID_Constructed = Adapter + "." + Instanz + "." + GeraeteID + ".0." + StickyMeldungsart; // Gilt nur bei HM-Classic
                AckFlag = CheckStickyNochAktuell(StickyMappedString, GeraeteID); // kann die Message bestaetigt werden ? true = ja
                if (AckFlag) {
                    setTimeout(() => {
                        setState(ID_Constructed, 2);
                        LOG("Eine Sticky Meldung wurde bestaetigt fuer ID " + ID_Constructed, "Ergebnis", "ConfirmStickyMessages", 2);
                    }, delay); //  Verzögerung
                    delay = delay + 500
                } else {
                    LOG("Eine Sticky Meldung ist noch aktuell und wird nicht bestaetigt fuer ID " + ID_Constructed, "Ergebnis", "ConfirmStickyMessages", 2);
        // Funktion CheckStickyNochAktuell checked of Sticky Meldung bestaetigt werden kann
        function CheckStickyNochAktuell(MappedString, GeraeteID) {
            let AckFlag = true;
            MappedString = String(MappedString); // Wandelt MappedString in einen String um
            GeraeteID = String(GeraeteID); // Wandelt GeraeteID in einen String um
            for (let j = 0; j < AktuelleMeldungenJSON.length; j++) {    // Iteriere über alle aktuellen Meldungen, um nach einer Nicht-Sticky-Meldung zu suchen
                const AktuelleMeldung = AktuelleMeldungenJSON[j];
                const aktuelleMeldungsart = String(AktuelleMeldung.meldungsart).trim();
                const aktuelleGeraeteId = String(AktuelleMeldung.GeraeteId).trim();
                if (aktuelleMeldungsart === MappedString && aktuelleGeraeteId === GeraeteID) {  // ueberpruefen ob die Sticky message noch aktuell ist
                    AckFlag = false;
                    break; // Schleife abbrechen
            return AckFlag;
        // Function increaseCount // Diese Funktion reduziert Wiederholungen der Case abfragen in Check_ALL
        function increaseCount(alarmtype) {
            const entry = Zaehler.find(e => e.alarmtype === alarmtype);
            if (entry) entry.count++;
        // Funktion DefineServiceMessage  Message ERmittlung
        function DefineServiceMessage(native_type, status, id, version) {
            LOG(`Routine DefineServiceMessage wird ausgefuehrt meldungsart ${meldungsart} und ID:${id}`, "Ablauf", "DefineServiceMessage", 2);
            const adapter = ExtractMetaData(id, "adapter");
            const datum_seit = func_get_datum(id);
            let matchingAlarmType = meldungsart;
            let isValidMessageType = alarmTypes.some((type) => type.suffixes.includes(meldungsart));
            if (isValidMessageType) {    // Bestimmen des passenden Alarmtyps
                matchingAlarmType = alarmTypes.find((type) => type.suffixes.includes(meldungsart)).key;
                if (matchingAlarmType === "ERROR" && meldungsart !== "ERROR") {
            const createServiceMessage = (message) => {    // Hilfsfunktion zum Erzeugen der ServiceMessage
                if (version === "lang") {        // Unterschiedliche Formate je nach Version
                    let Status_Message_Lang = `${datum_seit} - ${meldungsart} - ${common_name} - (${GeraeteId}) - ${status} - ${message}`;
                    return Status_Message_Lang;
                } else if (version === "pure") {
                    return message;  // Nur die pure status Nachricht
                } else {
                    return `${common_name} ${message}`;  // Kurze Nachricht, falls kurze Nachrichten gewuenscht fuer das messaging
            switch (matchingAlarmType) {    // Logik je nach meldungsart
                case "LOWBAT_ALARM":
                    const lowBatMessage = `${getStatusMessage(meldungsart, status, adapter)} - Batteriebezeichnung: ${func_Batterie(native_type)}`;
                    return createServiceMessage(lowBatMessage);
                case "ERROR":
                    if (status >= 1 && status <= 7 && errorMessages[native_type] && errorMessages[native_type][status]) {
                        return createServiceMessage(errorMessages[native_type][status]);
                    if (status === 0) {
                        const fallbackMessage = getStatusMessage("FALLBACK", status, adapter);
                        return createServiceMessage(fallbackMessage);
                    break;
                case "FAULT_REPORTING":
                    if (faultMessages[native_type] && faultMessages[native_type][status]) {
                        return createServiceMessage(faultMessages[native_type][status]);
                    break;
                default:
                        return createServiceMessage(getStatusMessage(meldungsart, status, adapter));
                    } else {
            return createServiceMessage(getStatusMessage("FALLBACK", status, adapter));    // kann eigentlich nicht aufteten
        //Funktion getStatusMessage zur Abfrage der Meldung je messageType, Adapter und Status (fuer Routine DefineServiceMessage)
        function getStatusMessage(messageType, statusKey, adapter) {
            if ( statusMessages[messageType] && statusMessages[messageType][adapter] &&statusMessages[messageType][adapter][statusKey] !== undefined  ) {    // Existenzpruefung- ggf regagieren
                return statusMessages[messageType][adapter][statusKey];
            } else {
                return `Keine passende Meldung fuer MessageType: "${messageType}", Adapter: "${adapter}", Status: "${statusKey}".`;
        // addMessageToCollector  Messages werden unter beruecksichtigung der folgenden Objekte in den MessageCollector genommen
        // MessengerScope, Services, AlarmTypes, TextTypeKurz
        function addMessageToCollector(messageType, MessageKurz, MessageLang) {
            let actualMessageType, matchingAlarmType;
            if (messageType !== "keineSM") {
                let isValidMessageType = alarmTypes.some((type) => type.suffixes.includes(messageType));
                    matchingAlarmType = alarmTypes.find((type) => type.suffixes.includes(messageType)).key;
                    actualMessageType = messageType;
                } else {
                    LOG(`MessageType: ${messageType} ist nicht konfiguriert in alarmTypes`, "WARN", "addMessageToCollector", 0);
            if (messageType === "keineSM") {
                actualMessageType = "keineSM";
                matchingAlarmType = "keineSM";
            if (!MessageSendCollector[actualMessageType]) {
                MessageSendCollector[actualMessageType] = {};
            let messengerConfig = MessengerScope[matchingAlarmType] || MessengerScope['Sonstige'] || Array(services.length).fill(false);
            messengerConfig.forEach((isActive, index) => {
                if (isActive) {
                    const service = services[index];
                    const instance = MessengerInstanz[index];
                    if (instance !== null && !isNaN(instance) && instance >= 0) {
                        if (!MessageSendCollector[actualMessageType][service]) {
                            MessageSendCollector[actualMessageType][service] = [];
                        const messageToAdd = TextTypeKurz[index] ? MessageKurz : MessageLang;
                        const existingMessages = MessageSendCollector[actualMessageType][service];
                        // **Doppelprüfung:** Gibt es bereits eine Nachricht mit demselben Text und Instanz?
                        const isDuplicate = existingMessages.some(msg => msg.message.trim() === messageToAdd.trim() && msg.instance === instance);
                        if (!isDuplicate) {
                            MessageSendCollector[actualMessageType][service].push({
                                message: messageToAdd + '\n',
                                instance: instance
                            LOG(`Nachricht hinzugefügt für ${actualMessageType} - Service: ${service} - Instanz: ${instance}`, "Ablauf", "addMessageToCollector", 3);
                        } else {
                            LOG(`Doppelte Nachricht erkannt und verworfen für ${actualMessageType} - Service: ${service} - Instanz: ${instance}`, "DEBUG", "addMessageToCollector", 3);
                    } else {
                        LOG(`Ungültige Instanz für Service: ${service} (Instanz: ${instance})`, "WARN", "addMessageToCollector", 0);
        // sendMessage  Hier werden die Nachrichten fuer den jeweiligen Service aufbereitet
        function sendMessage(messageType = null) {
            LOG(`Routine sendMessage wird ausgefuehrt, meldungsart: ${messageType}`, "Ablauf", "sendMessage", 2);
            const messageTypesToProcess = messageType ? [messageType] : Object.keys(MessageSendCollector);    // Bestimme die MessageTypes, die verarbeitet werden sollen
            messageTypesToProcess.forEach((type) => {
                const messagesByService = MessageSendCollector[type];
                if (messagesByService) {
                    Object.keys(messagesByService).forEach((service) => {
                        const serviceMessages = messagesByService[service];
                        let messagesToRemove = [];
                        serviceMessages.forEach((item) => {
                            const { message, instance } = item;
                            sendToService(service, message, instance);
                            messagesToRemove.push(item);
                        messagesToRemove.forEach((item) => {                // Entferne alle verarbeiteten Nachrichten
                            const serviceMessagesIndex = serviceMessages.indexOf(item);
                            if (serviceMessagesIndex > -1) {
                                serviceMessages.splice(serviceMessagesIndex, 1);
        // sendToService    - hier wird der Versand vorgenommen
        // Reihenfolge:       Email, WhatsApp, Signal, Telegram, Pushover, Pushsafer
        // MessengerInstanz = [0,       0,        0,      0,         0,        0]    Instanzen der Messenger-Dienste in
        function sendToService(service, message, instance) {
        LOG(`Message wird versendet mit: ${service} : ${instance} : ${message}`, "Ablauf", "sendToService", 2);
            switch (service) {
                case "email":
                    sendTo(`email.${instance}`, "send", {
                        text: message,
                        to: emailAddresse,
                        subject: Headline
                    break;
                case "whatsApp":
                    sendTo(`whatsapp-cmb.${instance}`, "send", {
                        text: message
                    break;
                case "Signal":
                    sendTo(`signal-cmb.${instance}`, "send", {
                        text: message
                    break;
                case "Telegram":
                    sendTo(`telegram.${instance}`, "send", {
                        text: message,
                        user: TelegramUser  // Telegram User ID, um den Nachrichteneempfaenger festzulegen
                    break;
                case "Pushover":
                    sendTo(`pushover.${instance}`, "send", {
                        message: message,
                        sound: ""
                    break;
                case "Pushsafer":
                    sendTo(`pushsafer.${instance}`, "send", {
                        message: message,
                        title: Headline
                    break;
                default:
                    LOG(`Unbekannter Service: ${service}`, "WARN", "sendToService", "warn");
        // Funktion ExtractMetaData  Verarbeitung des Datenpunkts zur Extraktion der Metadaten: GeraeteId, meldungsart
        function ExtractMetaData(datenpunkt, ExtractType) {
            LOG(`Routine ExtractMetaData wird ausgefuehrt datenpunkt fuer Metadaten ${datenpunkt} ExtractType ${ExtractType} `, "Ablauf", "ExtractMetaData", 2);
            ExtractType = ExtractType.toUpperCase();
            const teile = datenpunkt.split('.');                                        // Splitte den Datenpunkt in Teile
            const adapter = teile[0];                                                   // Der erste Teil ist immer der Adapter
            const instance = teile[1];                                                  // Der zweite  Teil ist immer die  Instance
            const struktur = StrukturDefinition.find(s => s.Adapter === adapter);       // Strukturzeile aus Tabelle StrukturDefinition fuer den Adapter aus dem uebergebenen DP
            const GeraeteID = teile[struktur.GeraeteID];                                // Extrahiere Felder basierend auf der Strukturdefinition
            if (!struktur) {
                LOG(`Die Struktur fuer MetaDaten Extract ist nicht korrekt eingestellt. Der uebergebenen datenpunkt war:$(datenpunkt)- Abbruch`, "Fehler", "ExtractMetaData", 0);
                return null;
            if(ExtractType === "ADAPTER") { return adapter; }
            if(ExtractType === "GERAETEID") { return GeraeteID; }
            if(ExtractType === "MELDUNGSART") {
                const meldungsart = teile[struktur.AlarmFeld];                                       // Extrahiere Felder basierend auf der Strukturdefinition
                return meldungsart;
            if(ExtractType === "NATIVETYPE" && typeof struktur.nativeType === 'number') {
                const MetaDP = datenpunkt.split('.').slice(0, struktur.nativeType).join('.');        // ergibt den Datenpunkt fuer getObject z.B. hm-rpc.1.00085D89B14067
                const nativeType  = getObject(MetaDP).native.TYPE;
                return nativeType;
            if(ExtractType === "NATIVETYPE" && typeof struktur.nativeType === 'string') {           // bei string liegt der native-type im datenpunkt
                let  DPNativeTypeDP = struktur.nativeType;
                DPNativeTypeDP = DPNativeTypeDP.replace('xidx', GeraeteID);
                DPNativeTypeDP = DPNativeTypeDP.replace('xinstancex', instance);
                let nativeType = getState(DPNativeTypeDP).val
                return nativeType;
            if(ExtractType === "COMMONNAME" && typeof struktur.common_name === 'number') {
                const MetaDP = datenpunkt.split('.').slice(0, struktur.common_name).join('.');        // ergibt den Datenpunkt fuer getObject z.B. hm-rpc.1.00085D89B14067
                const common_name  = getObject(MetaDP).common.name;
                return common_name;
            if(ExtractType === "COMMONNAME" && typeof struktur.common_name === 'string') {           // bei string liegt der common_name im datenpunkt
                let DPcommmon_name = struktur.common_name;
                DPcommmon_name = DPcommmon_name.replace('xidx', GeraeteID).replace('xinstancex', instance);
                let common_name = getState(DPcommmon_name).val
                return common_name;
            LOG(`Der Datenpunkt/ExtractType, die erforderlich zur Ermittlung von Metadaten sind nicht bekannt Der Datenpunkt lautet ${datenpunkt} ExtractType ${ExtractType}  - Abbruch`, "Fehler", "ExtractMetaData", 0);
            return null
        // ReplaceString  // ersetzen  entsprechend tabelle replacements
        function ReplaceString(string) {
            for (const [key, value] of Object.entries(replacements)) {
                // Escape den Punkt (.) fuer den regulaeren Ausdruck
                const escapedKey = key.replace('.', '\\.');
                string = string.replace(new RegExp(escapedKey, 'g'), value);
            return string;
        // func_get_datum  aktuelles Datum formatiert
        function func_get_datum(id) {
            let datum;
            if (id && getState(id)) {
                datum = formatDate(getState(id).lc, "TT.MM.JJ SS:mm:ss");
            } else {
                datum = formatDate(new Date(), "TT.MM.JJ SS:mm:ss"); // Aktuelles Datum
            let datumDate = new Date(datum); // korrekte verwendung des datumsformates
            let cutoffDate = new Date('1971-01-01T01:00:00');
            return datumDate < cutoffDate ? '' : `${datum} Uhr`;
        // func_Batterie Batterieermittlung
        function func_Batterie(native_type) {
            LOG(`Routine wird ausgefuehrt`, "Ablauf", "func_Batterie", 2);
            const normalizedType = native_type.toUpperCase();
            return Object.keys(batteryTypes).find(battery =>
                batteryTypes[battery].some(device => device.toUpperCase() === normalizedType)
            ) || NichtRelevantText;
        // Funktion CreateJsonEntry erzeugen einer JSON Tabelle
        function CreateJsonEntry(existingJson = [], datum_seit = '', meldungsart = '', common_name = '', GeraeteId = '', status = '', Status_Lang = '', Status_Pure, Batterie = '',sortierung = false) {
            let parsedJson;
            if (Array.isArray(existingJson)) {     // ueberpruefen, ob existingJson bereits ein Array ist
                parsedJson = existingJson; // Nur das Array uebernehmen
            } else {
                parsedJson = [];  // Falls es kein Array ist, setze es auf ein leeres Array
            const neuerEintrag = {
                datum_seit: datum_seit || func_get_datum(),     // Fallback auf aktuelles Datum
                meldungsart: meldungsart || NichtRelevantText,
                common_name: common_name || NichtRelevantText,
                GeraeteId: GeraeteId || NichtRelevantText,
                status: status || NichtRelevantText,                                // Status entweder number oder boolean
                status_message_Lang: Status_Lang || 'Keine Meldung',    // Langer Text
                status_message_Pure: Status_Pure || 'Keine Meldung',    // nur die Status aus den Status-Tabellen
                batterie_bezeichnung: Batterie || NichtRelevantText,
                SM_aufgehoben_seit:  "aktiv"          // status ob eine message bereits aufgeboben ist. wenn aufgehoben wird ein Datum eingestellt
            parsedJson.unshift(neuerEintrag);
            if(sortierung) { sortJason(parsedJson);}
            return parsedJson;  // Gib das aktualisierte Array zurueck
        // Funktion checkIfEntryExists Checken of ein Eintrag schon vorhanden ist
        function checkIFJSONfEntryExists(parsedJson, datum_seit, GeraeteId, status, meldungsart) {
            if (!Array.isArray(parsedJson)) { // Überprüfen, ob parsedJson ein Array ist
                LOG(`parsedJson ist kein Array`, "WARN", "checkIFJSONfEntryExists", 1);
                return false;
            for (let entry of parsedJson) { // Durch das Array iterieren und kriterien checken // meldungsart ist optional
                if (entry.datum_seit === datum_seit && entry.GeraeteId === GeraeteId && entry.status === status && (meldungsart === undefined || entry.meldungsart === meldungsart)  ) {
                    return true; // Eintrag gefunden
            return false; // Kein passender Eintrag gefunden
        // Funktion isLatestEntryMessageBeiKeinerSM Checken ob die letzte message der variablen MessageBeiKeinerSM entspricht
        function isLatestEntryMessageBeiKeinerSM(existingJson = []) {
            if (!Array.isArray(existingJson) || existingJson.length === 0) {    // ueberpruefen, ob existingJson ein Array ist und Eintraege enthaelt
                return false;
            const latestEntry = existingJson[0];    // Neuesten Eintrag extrahieren (erster Eintrag im Array)
            if (latestEntry.status_message_Lang && latestEntry.status_message_Lang.includes(MessageBeiKeinerSM)) {
                return true;
            return false;
        // Funktion Markiere_HistSM_als_Aufgehoben Zuordnung von historischen Messages zu "aufgehoben" mit Datum der Zuordnung
        function Markiere_HistSM_als_Aufgehoben(HistorischeMeldungenJSON_transfer) {
            const maxTimeDiffMs = 1000; // z.B. 1000 ms fuer eine Sekunde Unterschied
            const nurKeineMeldungen = AktuelleMeldungenJSON[0].status_message_Lang.includes(MessageBeiKeinerSM);    // Pruefen, ob AktuelleMeldungenJSON nur eine Meldung mit "Derzeit keine Servicemeldungen" enthaelt
            if (nurKeineMeldungen) {
                HistorischeMeldungenJSON_transfer.forEach(meldung => {        // Alle historischen Eintraege als aufgehoben markieren
                    if (meldung.SM_aufgehoben_seit === "aktiv") {
                        meldung.SM_aufgehoben_seit = func_get_datum();
                return HistorischeMeldungenJSON_transfer;
            HistorischeMeldungenJSON_transfer.forEach(historischeMeldung => {    // Iteriere ueber alle historischen Meldungen (aeussere Schleife)
                if (historischeMeldung.SM_aufgehoben_seit !== "aktiv") return; // Wenn die historische Meldung bereits aufgehoben wurde, ueberspringen
                let zugeordnet = false;
                const historischeDatum = extractDate(historischeMeldung.datum_seit);
                AktuelleMeldungenJSON.forEach(aktuelleMeldung => {        // Iteriere ueber alle aktuellen Meldungen (innere Schleife)
                    const aktuelleDatum = extractDate(aktuelleMeldung.datum_seit);
                    const gleicheGeraeteID = historischeMeldung.GeraeteId === aktuelleMeldung.GeraeteId;
                    const gleicheStatusMessage = historischeMeldung.status_message_Pure === aktuelleMeldung.status_message_Pure;
                    const zeitDifferenz = Math.abs(aktuelleDatum.getTime() - historischeDatum.getTime());            // Berechne den Zeitunterschied in Millisekunden
                    const gleicheOderNaheZeit = zeitDifferenz <= maxTimeDiffMs;            // Pruefe, ob die Zeitdifferenz innerhalb des erlaubten Bereichs liegt
                    if (gleicheGeraeteID && gleicheStatusMessage && gleicheOderNaheZeit) {
                        historischeMeldung.SM_aufgehoben_seit = "aktiv"; // Als nicht aufgehoben markieren
                        zugeordnet = true
                if (!zugeordnet) {
                    historischeMeldung.SM_aufgehoben_seit = func_get_datum() // kein pendant gefunden, also muss die message obsolet sein
        // Funktion sortJason zum Sortieren des History Jason nach datum
        function sortJason(parsedJson) {
            if (!Array.isArray(parsedJson)) { LOG("Die Eingabe fuer sortJason ist kein Array.", "Fehler", "sortJason", 2); return[] ;}
            const parseDate = (datum) => {
                try {
                    const [date, time] = datum.split(' '); // Datum und Zeit trennen
                    const [day, month, year] = date.split('.'); // Datum aufteilen in Tag, Monat, Jahr
                    const [hours, minutes, seconds] = time.split(':'); // Zeit aufteilen in Stunden, Minuten, Sekunden
                    return new Date(`20${year}-${month}-${day}T${hours}:${minutes}:${seconds}`); // ISO-Format erstellen
                } catch (error) {
                    LOG(`Fehler beim Parsen des Datums: ${datum}`, "Fehler", "sortJason", 1);
                    return null;  // Rueckgabe von null, wenn das Datum ungueltig ist
            return parsedJson.sort((a, b) => {
                const dateA = parseDate(a.datum_seit);
                const dateB = parseDate(b.datum_seit);
                if (dateA === null && dateB === null) return 0; // Keine aenderung bei ungueltigen Datumswerten
                if (dateA === null) return 1; // Null-Werte ans Ende verschieben
                if (dateB === null) return -1;
                return dateB.getTime() - dateA.getTime(); // Neueste zuerst
        // Funktion extractDatum // Hilfsfunktion zur Extraktion des Datums        // Beispieltext: "01.12.24 12:04:55 Uhr - SABOTAGE_ALARM ..."
        function extractDate(text) {
            if (!text || typeof text !== "string") {
                LOG(`extractDate Fehler: Ungueltiger Eingabetext: ${text}`, "Fehler", "extractDate", 2);
                return new Date(0); // Fallback auf ein Default-Datum
            const match = text.match(/^(\d{2})\.(\d{2})\.(\d{2}) (\d{2}):(\d{2}):(\d{2})/);    // Regulaerer Ausdruck, um Datum und Uhrzeit zu extrahieren
            if (!match) {
                LOG(`extractDate Fehler: Kein gueltiges Datum gefunden: ${text}`, "Fehler", "extractDate", 2);
            const [_, day, month, year, hours, minutes, seconds] = match;    // Teile aus dem Match extrahieren
            const fullYear = year.length === 2 ? `20${year}` : year;    // Jahr vervollstaendigen, falls noetig
            const dateString = `${fullYear}-${month}-${day}T${hours}:${minutes}:${seconds}`;    // Erstellen des Datums im Format "YYYY-MM-DDTHH:mm:ss"
            const date = new Date(dateString);    // Umwandlung in ein Date-Objekt
            if (isNaN(date.getTime())) {    // ueberpruefen, ob das Datum gueltig ist
                LOG(`extractDate Fehler: Ungueltiges Datum erzeugt: ${dateString}`, "Fehler", "extractDate", 2);
                return new Date(0);
            return date;
        // Funktion GenerateTEXT_Datenpunkte // Generiert TEXT format aus den JSON Arrays und speichert diese in die Datenpunkte
        function GenerateTEXT_Datenpunkte() {
            LOG(`Routine wird ausgefuehrt`, "Ablauf", "GenerateTEXT_Datenpunkte", 2);
            if(!UpdateTEXT_Datenpunkte){return}; // wenn keine TEXT-Datenpunkte updates erfolgen sollen nicht ausfuehren
            let  SMAktuellMessageLangTEXT = [], SMHistMessageLangTEXT = [],SMAktuellMessageKurzTEXT = [];
            HistorischeMeldungenJSON.forEach(Meldung => {        // Iteriere durch HistorischeMeldungenJSON und extrahiere die status_message_Lang
                SMHistMessageLangTEXT.push(Meldung.status_message_Lang + " - Meldung aufgehoben: " + Meldung.SM_aufgehoben_seit + "<br>");            // Status-Lang-Text extrahieren und ins Array pushen
            setState(id_Text_Servicemeldung_History, SMHistMessageLangTEXT.join(''));        // Umwandlung des Arrays in einen String und Speichern im Datenpunkt id_Text_ServicemeldungLang
            AktuelleMeldungenJSON.forEach(Meldung => {        // Iteriere durch AktuelleMeldungenJSON und extrahiere die status_message_Pure und status_message_Lang
                if (Meldung.status_message_Pure) {
                    SMAktuellMessageKurzTEXT.push(Meldung.datum_seit + " " + Meldung.status_message_Pure + "<br>"); // Status-Kurz-Text extrahieren und ins Array pushen
                if (Meldung.status_message_Lang) {
                    SMAktuellMessageLangTEXT.push(Meldung.status_message_Lang + "<br>"); // Status-Lang-Text extrahieren und ins Array pushen
            setState(id_Text_ServicemeldungKurz, SMAktuellMessageKurzTEXT.join(''));        // Umwandlung der Arrays in Strings und Speichern in den entsprechenden Datenpunkten
            setState(id_Text_ServicemeldungLang, SMAktuellMessageLangTEXT.join(''));
        // Funktion generateHtmlTable // Funktion, aus den JSON Tabellen ein HTML-Format erzeugt
        function generateHtmlTable(data, HistOderAkt) {
            if (!UpdateHTML_Datenpunkte) { return; }        // Keine Updates, wenn HTML-Datenpunkte deaktiviert sind
            const uniqueClass = "custom-table";    // Eindeutige Klasse für die Tabelle
            const cellPadding = '6px';
            // Baue die Tabelle mit einer eindeutigen Klasse auf
            let table = `
                <table class="${uniqueClass}" style="
                    width: 100%;
                    border-collapse: collapse; /* Rahmen zusammenführen */
                    border-spacing: 0; /* Kein Abstand zwischen Zellen */
            // Scoped Stile für die Tabelle
            table += `
                <style>
                    .${uniqueClass} th, .${uniqueClass} td {
                        padding: ${cellPadding};
                        ${useBorderAll ? `border: ${borderWidth} solid ${borderColor};` : 'border: none;'} /* Innerer Rahmen basierend auf useBorderAll */
                    .${uniqueClass} thead th {
                        position: sticky;
                        top: 0;
                        background-color: ${headerColor};
                        color: ${headerTextColor};
                        z-index: 1;
                </style>
            // Kopfzeile
            table += `
                <thead>
                <tr>
                    <th style="text-align: left;">Datum_Seit</th>
                    <th style="text-align: left;">Meldungsart</th>
                    <th style="text-align: left;">Name</th>
                    <th style="text-align: left;">GeraeteId</th>
                    <th style="text-align: left;">Status</th>
                    <th style="text-align: left;">Batterie</th>
                    <th style="text-align: left;">SM_aufgehoben_seit</th>
                </tr>
                </thead>
            // Tabellenkörper
            table += '<tbody>';
            data.forEach((item, index) => {
                const rowColor = index % 2 === 0 ? evenRowColor : oddRowColor; // Farben der Zeilen
                const textColor = index % 2 === 0 ? evenRowTextColor : oddRowTextColor; // Textfarbe
                table += `
                <tr style="background-color: ${rowColor}; color: ${textColor};">
                    <td>${item.datum_seit}</td>
                    <td>${item.meldungsart}</td>
                    <td>${item.common_name}</td>
                    <td>${item.GeraeteId}</td>
                    <td>${item.status_message_Pure}</td>
                    <td>${item.batterie_bezeichnung}</td>
                    <td>${item.SM_aufgehoben_seit}</td>
                </tr>
            table += '</tbody>';
            table += '</table>';
            // Zustand setzen je nach HistOderAkt
            if (HistOderAkt === "AKT") {
                setState(id_HTML_Servicemeldung_Aktuell, table);
            } else {
                setState(id_HTML_Servicemeldung_History, table);
        // Funktion Refresh_History loescht die Historie - Ausloeser entweder subcription oder schedule
        function Refresh_History() {
            let jsonString = getState(id_JSON_Servicemeldung_Historie).val || '[]'; // zunaechst die JSON Eintraege
            HistorischeMeldungenJSON = HistorischeMeldungenJSON.filter(meldung => meldung.SM_aufgehoben_seit === "aktiv");    // Filtern der Meldungen, um nur die zu behalten, die den Wert "aktiv" in "SM_aufgehoben_seit" haben
            let updatedJsonString = JSON.stringify(HistorischeMeldungenJSON);    // Speichern der gefilterten historischen Meldungen zurueck in den Datenpunkt
            setState(id_JSON_Servicemeldung_Historie, updatedJsonString);
            Check_All("init")
        // Funktion schreibt einen Logeintrag in das Filesystem und auch in das interne Log-System
        function writelog(Name, GeraeteId, SMType, SMStatus, SMStatus_Text) {
            if (!SMProtokoll) return;
            const fs = require('fs');                     // enable write fuer externes log
            const logdate = formatDate(new Date(), "TT.MM.JJJJ");
            const logtime = formatDate(new Date(), "SS:mm:ss");
            const logEntry = `${logdate} ;${logtime} ;${Name} ;${GeraeteId} ; ${SMType} ;${SMStatus} ;${SMStatus_Text}\n`;
            const headerLine = "Datum;Uhrzeit;Name;ID-Name;Meldungssart;Status;Servicemeldung\n";
            fs.readFile(PathSMLog, 'utf8', function(err, data) {
                if (!err) {
                    fs.appendFileSync(PathSMLog, logEntry, 'utf8');
                } else {
                    LOG(`Logfile nicht gefunden - wird angelegt`, "Ablauf", "writelog", 0);
                    fs.writeFileSync(PathSMLog, headerLine + logEntry, 'utf8');
        // Funktion schreibt die Syste-Log-Eintraege in ein externes CSV - File
        function LOG(Message,Kategorie,Routine, Level, type) {
            if(type !== "warn" && type !== "error") {type = "info"}
            if (!SystemLog && debugLevel >= Level) { log(Message+" Routine:"+Routine,type); return;}     // Wenn SystemLog false ist und der Debug-Level hoeher oder gleich dem uebergebenen Level, schreibe normalen Logeintrag
            if  (Level === 0) { log(Message+" Routine:"+Routine,type);} // bei level 0 soll auf jeden fall auch in das normale log geschrieben werden
            if (SystemLog && debugLevel >= Level) {         // Wenn SystemLog true ist und der Debug-Level hoeher oder gleich dem uebergebenen Level
                const now = new Date();
                const logdate = `${now.getDate().toString().padStart(2, '0')}.${(now.getMonth() + 1).toString().padStart(2, '0')}.${now.getFullYear()}`;
                const logtime = `${now.getHours().toString().padStart(2, '0')}:${now.getMinutes().toString().padStart(2, '0')}:${now.getSeconds().toString().padStart(2, '0')}:${now.getMilliseconds().toString().padStart(3, '0')}`;
                const logEntry = `${logdate};${logtime};${Level};${Kategorie};${Routine};${Message}\n`;
                const headerLine = "Datum;Uhrzeit;Debug Level;Kategorie;Routine;Log-Message\n";
                const logFilePath = PathSystemLog || './defaultLog.csv'; // falls PathSystemLog nicht definiert ist, standardmaessigen Pfad verwenden
                try {
                    if (!fs.existsSync(logFilePath)) {
                        log(`Routine:LOG - Logfile nicht gefunden - wird angelegt`,"info")
                        fs.writeFileSync(logFilePath, headerLine + logEntry, 'utf8');  // Datei erstellen und Header hinzufuegen
                    } else {
                        fs.appendFileSync(logFilePath, logEntry, 'utf8'); // Eintrag zum Logfile hinzufuegen
                } catch (err) {
                    log(`Routine:LOG - Fehler beim Schreiben in das Logfile: ${err}`, "error"); // Fehler beim Schreiben
        // Funktion Create States
        async function CreateStates(callback) {
            LOG(`Routine wird ausgefuehrt`, "Ablauf", "CreateStates", 2);
            try {
                if(UpdateTEXT_Datenpunkte) {    // nur wenn Text-Datenpunkte auch gewuenscht sind
                    await createStateAsync(id_Text_ServicemeldungLang, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen LangText', desc: 'LangText Servicemeldung' });
                    await createStateAsync(id_Text_ServicemeldungKurz, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen KurzText', desc: 'KurzText Servicemeldung' });
                    await createStateAsync(id_Text_Servicemeldung_History, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen History', desc: 'History Servicemeldung' });
                if(UpdateHTML_Datenpunkte) {    // nur wenn Text-Datenpunkte auch gewuenscht sind
                    await createStateAsync(id_HTML_Servicemeldung_Aktuell, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen HTML-Text', desc: 'HTML-Text Servicemeldung' });
                    await createStateAsync(id_HTML_Servicemeldung_History, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen HTML-History', desc: 'HTML-History Servicemeldung' });
                await createStateAsync(id_JSON_Servicemeldung_Aktuell, "", { read: true, write: true, type: 'string', name: 'Aktuelle Servicemeldungen als JSON', desc: 'Vergangene Servicemeldung JSON' });
                await createStateAsync(id_JSON_Servicemeldung_Historie, "", { read: true, write: true, type: 'string',name: 'Servicemeldungen History', desc: 'History Servicemeldung' });
                await createStateAsync(id_Button_Refresh_Historie, false, { read: true, write: true, type: 'boolean', name: 'Refresh Button History', desc: 'Loescht die Historie Servicemeldungem wenn true' });
                for (const { alarmtype, count, Datenpunkt } of Zaehler) {               // Schleife ueber das Zaehler-Array und anlegen der States
                    await createStateAsync(Datenpunkt, count, {read: true, write: true,type: 'number',name: `Servicemeldungen Anzahl ${alarmtype}`,desc: `Anzahl ${alarmtype} Servicemeldungen`});
            if (callback) await callback();         // Aufruf des Callbacks nach Abschluss aller Operationen
                } catch (error) {
                LOG(`Kategorie:WARN; Routine:CreateStates; Routine Create States - Fehler beim Erstellen der Zustaende: ${error}`, 0, "warn");
            if (!UpdateTEXT_Datenpunkte) {
                if (existsState(id_Text_ServicemeldungLang)) { deleteState(id_Text_ServicemeldungLang); }
                if (existsState(id_Text_ServicemeldungKurz)) { deleteState(id_Text_ServicemeldungKurz); }
                if (existsState(id_Text_Servicemeldung_History)) { deleteState(id_Text_Servicemeldung_History); }
            if(!UpdateHTML_Datenpunkte) {    // nur wenn Text-Datenpunkte auch gewuenscht sind
                if (existsState(id_HTML_Servicemeldung_Aktuell)) { deleteState(id_HTML_Servicemeldung_Aktuell); }
                if (existsState(id_HTML_Servicemeldung_History)) { deleteState(id_HTML_Servicemeldung_History); }
        looxer01
        #197
        @edis77
        ok, kein Problem. Ich erstelle eine Version, die aber dann schon final ist.
        Ich bin sicher, dass das beschriebene Problem damit behoben wird.
        kann aber Morgen werden.
        vG Looxer
        • L Offline
          looxer01
          schrieb am zuletzt editiert von looxer01
          #198
          Hi Version 3.21 ist online
          • ACHTUNG die JSON fuer aktuelle und historische Servicemeldungen wurde um ein Feld erweitert. Bitte sorgt dafür, dass ihr keine aktuellen STICKY-Meldungen habt, wenn diese Script-Version aktiviert wird (gibt dann Fehlermeldungen). Ansonsten kann die Version ohne Probleme aktiviert werden.
          • Tabelle "instanceIds" um feld "Messaging" erweitert(Ausschalten von Nachrichten Adapter/Instanz Kombi). Somit kann z.B. für die Gruppenmeldungen generell ein Nachrichtenversand verhindert werden
          • DataPoint Filter für selektor hinzugefuegt. Der Filter laesst sich flexibel mit wildcards in einer Tabelle einstellen. Notwendig wurde dieser für den HM-AccessPoint, um Datenpunkte mit Alarmtypes auszuschliessen, die aber nur für Gruppen relevant waren und nicht für einzelne Geräte
          vG Looxer
          @Edis77
          Diese Version sollte dein Problem beheben.
          Eduard77E 1 Antwort Letzte Antwort
          • L looxer01
            vG Looxer
            @Edis77
            Eduard77E Offline
            Eduard77E Offline
            Eduard77
            #199
            @looxer01
            Danke für das Anpassung.
            Skript läuft und keine Fehler im LOG.
            • L Offline
              looxer01
              #200
              Version 3.30 ist online mit der Möglichkeit der Sprachausgabe.
              Ich schreibe gerade für mich ein Alarmanlagenscript. Sprachausgabe ist eine von vielen Anforderungen.
              Dabei nutze ich viele Elemente des Servicemeldungsscripts. Daher habe ich die Sprachausgabe dem Servicemeldungsscript jetzt hinzugefügt.
              Die Sprachausgabe erfolgt über den "sayit" Adapter.
              Eine Uhrzeit von bis kann konfiguriert werden, damit es Nachts nicht zu Störungen kommt.
              Ich meine, dass die Sprachausgabe insbesondere bei Sabotage Sinn macht.
              Anmerkung: im sayit Adapter kann je instanz ein anderes ausgabegerät festgelegt werden.
              Im servicemeldungsscript können mehrere Instanzen konfiguriert werden - das passt also.
              Die Konfig findet ihr in der Tabelle messenger scope und die Uhrzeiten für die Sprachausgaben darunter.
              noch ein Hinweis:
              im SayIt Adapter kann man "Browser" als Ausgabegerät konfigurieren. Damit können also eventuelle Tablets z.B. mit dem FullyKioskBrowser als Ausgabegeräte genutzt werden
              vG Looxer
              • L looxer01
                Das vorliegende Script logged Servicemeldungen von der CCU/AccessPoint/HCU-
                Für welche Umgebungen eignet sich das Skript?
                • CCU (bzw. Raspberry Pi-Ersatz)
                • CCU FUNK
                • CCU Wired
                • HMIP Access Point (Achtung: „GeraeteIDTrigger“ muss auf „true“ gesetzt sein)
                • HMIP HCU Cloud (Achtung: „GeraeteIDTrigger“ muss auf „true“ gesetzt sein)
                Es handelt sich dabei nicht um ein „entweder-oder“ – die Instanzen werden parallel überwacht.
                Was kann das Skript?
                • Überprüfung der Servicemeldungen: Das Skript prüft, ob Servicemeldungen vorliegen.
                • Speicherung der Servicemeldungen: Servicemeldungen werden in Lang- und Kurztexten (Text, JSON, HTML) gespeichert.
                • Zählung von Servicemeldungen: Es werden Zählungen nach Meldungsarten und insgesamt gespeichert.
                • Erstellung der erforderlichen Datenpunkte: Das Skript legt automatisch die notwendigen Datenpunkte an.
                • Reaktion auf Geräteänderungen: Es reagiert entweder auf Veränderungen auf Geräteebene (viele Subscriptions – z.B. 298 bei 80 Geräten) oder, standardmäßig, auf Veränderungen der Anzahl der in der CCU gemeldeten Servicemeldungen (1 Subscription)
                • Historie: Es wird eine Historie geführt, die auch zeigt, wann Servicemeldungen wieder aufgehoben wurden.
                • HMIP Access Point/HCU Support: Wenn der Access Point genutzt wird, muss auf die Geräte-ID getriggert werden (da der REGA-Datenpunkt fehlt).
                • Externe Log-Datei: Es kann ein externes Log im Excel-Format fortgeschrieben werden. Hierin werden alle Servicemeldungen langfristig fortgeschrieben
                • Heizungsgruppenmeldungen: Heizungsgruppenmeldungen sind standardmäßig deaktiviert. Sie können jedoch bei Bedarf aktiviert werden.
                • Servicemeldungen Bestätigung: Das Skript bestätigt auf Wunsch CCU Servicemeldungen.
                • Flexible Messaging Services: Es können email', 'whatsApp', 'Signal','Telegram', 'Pushover', 'Pushsafer oder auch SPRACHE zum versenden von Servicemeldungen eingestellt werden. Das Versenden kann per MessageType vereinbart werden.
                • Flexibles Tabellenwerk: Anpassungen für z.B. neue MessageTypes von Servicemeldungen bei neuen Geräten können ohne Programmierung im Tabellenwerk konfiguriert werden
                Einfache Nutzung: Das Skript ist sofort lauffähig, vorausgesetzt, die Instanzen (CCU etc.) sind korrekt eingerichtet.
                Das Skript arbeitet in der aktuellen Version stabil und zuverlässig.
                Zusätzliche Hinweise:
                In der Standardkonfiguration des Skripts werden 2 Subscriptions und 1 Schedule erstellt.
                Ich verwende das Skript mit einer Subscription auf Ebene Einzel-ID (Einstellung „GeraeteIDTrigger“). Bei dieser Konfiguration wird eine Warnung im Log angezeigt, wenn mehr als 100 Subscriptions von dem Servicemeldungs-Skript erstellt werden.
                Diese Grenze kann in den „Instanzen JavaScript“-Einstellungen angepasst werden. Für diesen Anwendungsfall sind keine Performance-Probleme zu erwarten.
                Channel Selector: Das Skript verwendet statische Channel-Selector. Das bedeutet, dass Änderungen an den Datenstrukturen durch die CCU (z.B. das Löschen oder Hinzufügen von Geräten) nicht bekannt sind, solange das Skript nicht neu gestartet wird.
                Falls Geräte hinzugefügt oder gelöscht werden, muss das Skript neu gestartet werden.
                und hier das Script:
                Servicemeldungen_Vol2_3-32.txt
                Dazu stelle ich zwei Views für VIS zur Verfügung:
                Den View gibt es für das JSON Format also auch für das HTML Format. Beide sehen weitestgehend identisch aus
                1. JSON View: Diese View ist für die Darstellung der JSON-Datenpunkte gedacht. Die Datenpunkte sind auf „javascript.0....“ ausgerichtet, was ggf. angepasst werden muss. Die View kann in VIS über „view importieren“ geladen werden. Der Inventwo-Adapter muss installiert sein. Falls du VIS2 nutzt, empfiehlt sich momentan die HTML-Variante.
                  View_SM_JSON.txt
                2. HTML View: Diese View zeigt die HTML-Datenpunkte an. Auch hier müssen die Datenpunkte ggf. angepasst werden. Die View kann ebenfalls in VIS über „view importieren“ geladen werden. Die verwendeten Widgets sind klassische ioBroker-Widgets und funktionieren sowohl in VIS1 als auch in VIS2.
                  View_SM_HTML.txt
                Die Views enthalten einen Push-Button. Wenn der gedrückt wird, wird die Meldungshistorie ohne Nachfrage gelöscht
                Da das Skript bei niedrigem Batteriestand automatisch die erforderlichen Batterien überprüft, müssen die Geräte mit den Batterien in eine Liste eingetragen werden. Mit dem folgenden Script kannst du überprüfen, ob die Liste vollständig ist. Alle Geräte mit unbekannten Batterien werden aufgelistet. Du kannst mir diese Liste dann zur Verfügung stellen, und ich pflege sie gerne ein.
                hier das Checkscript:
                Batterie-Check-1-1.txt
                Zusätzlich stelle ich ein Tool zur Verfügung, das alle ioBroker-Subscriptions auflistet. Dies steht nicht direkt im Zusammenhang mit dem Servicemeldungsskript, ist aber hilfreich, um transparent zu sehen, was insgesamt abonniert wurde. Über eine Variable kann die Liste auch auf ein bestimmtes Skript eingeschränkt werden. Das Ergebnis kann in eine externe Datei geschrieben werden.
                Hier das script
                ListSubscriptions_1.0
                rantanplanR Offline
                rantanplanR Offline
                rantanplan
                #201
                @looxer01 Hallo
                Ich habe hier eine Servicemeldung die Dein Script nicht mitbekommt.
                Bei dem Gerät handelt es sich um ein HM-Classic "HM-CC-RT-DN".
                Die Servicemeldung lautet: "Leere Batterie".
                In Deinem Script habe ich mal folgendes hinzugefügt.
                    'HM-CC-RT-DN': {
                        7: 'Fehlstellung Ventil',
                	8: 'Leere Batterie'       //von mir hinzugefügt !!!
                Hat aber nichts gebracht. (Vielleicht weil die Meldung schon vorhanden ist?)
                Rantanplan
                L 1 Antwort Letzte Antwort
                • rantanplanR rantanplan
                  @looxer01 Hallo
                      'HM-CC-RT-DN': {
                  looxer01
                  #202
                  @rantanplan
                  kannst du mal die Objektliste für das Gerät checken ?
                  In den Objektdaten stehen ja die möglichen Status. (also mindestens die 0 - 7)
                  Ich muss halt wissen welcher Datenpunkt den Status für die leere Batterie mit welcher Ausprägung enthält.
                  (leider besitze ich kein classic mehr)
                  Kannst du das Protokoll laufen lassen mit debug level 2 und posten ?
                  muss der Zeitpunkt sein bei dem die CCU die Servicemeldung lowbat erzeugt.
                  vG Looxer
                  Edit: der relevante Datenpunkt müsste FAULT_REPORTING sein, wenn es der ist, den du im Blick hast.
                  Allerdings war ich der Meinung, dass es auch einen "lowbat"-Datenpunkt geben müsste.
                  • L looxer01
                    @rantanplan
                    vG Looxer
                    E Online
                    E Online
                    emil70
                    schrieb am zuletzt editiert von emil70
                    #203
                    @looxer01
                    Der LOWBAT Datenpunkt sieht so aus
                      "type": "state",
                      "common": {
                        "name": "Heizung Büro:0.LOWBAT",
                        "role": "indicator.lowbat",
                        "def": false,
                        "type": "boolean",
                        "read": true,
                        "write": false
                      "native": {
                        "DEFAULT": false,
                        "FLAGS": 9,
                        "ID": "LOWBAT",
                        "MAX": true,
                        "MIN": false,
                        "OPERATIONS": 5,
                        "TAB_ORDER": 3,
                        "TYPE": "BOOL",
                        "UNIT": ""
                      "from": "system.adapter.hm-rega.0",
                      "user": "system.user.admin",
                      "ts": 1733764617734,
                      "_id": "hm-rpc.0.NEQ0871182.0.LOWBAT",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                        "owner": "system.user.admin",
                    der LOWBAT_ALARM Datenpunkt so
                      "type": "state",
                      "common": {
                        "name": "Heizung Büro:0.LOWBAT_ALARM",
                        "type": "number",
                        "role": "indicator.alarm",
                        "read": true,
                        "write": true,
                        "def": 0,
                        "states": {
                          "0": "NO ALARM",
                          "1": "ALARM",
                          "2": "ACKNOWLEDGED"
                      "native": {
                        "Name": "Heizung Büro:0.LOWBAT_ALARM",
                        "TypeName": "ALARM",
                        "DP": "16869"
                      "ts": 1733806812677,
                      "_id": "hm-rpc.0.NEQ0871182.0.LOWBAT_ALARM",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    der BATTERY_STATE Datenpunkt so
                      "type": "state",
                      "common": {
                        "name": "Heizung Büro.BATTERY_STATE",
                        "role": "value.voltage",
                        "def": 0,
                        "type": "number",
                        "read": true,
                        "write": false,
                        "min": 1.5,
                        "max": 4.6,
                        "unit": "V"
                      "native": {
                        "CONTROL": "NONE",
                        "DEFAULT": 0,
                        "FLAGS": 1,
                        "ID": "BATTERY_STATE",
                        "MAX": 4.6,
                        "MIN": 1.5,
                        "OPERATIONS": 5,
                        "TAB_ORDER": 2,
                        "TYPE": "FLOAT",
                        "UNIT": "V"
                      "ts": 1733764617915,
                      "_id": "hm-rpc.0.NEQ0871182.4.BATTERY_STATE",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    Hoffe das ist das was du brauchst
                    gruss emil70
                    iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
                    • E emil70
                      @looxer01
                        "type": "state",
                        "common": {
                          "def": false,
                          "type": "boolean",
                          "read": true,
                          "write": false
                        "native": {
                          "DEFAULT": false,
                          "FLAGS": 9,
                          "ID": "LOWBAT",
                          "MAX": true,
                          "MIN": false,
                          "OPERATIONS": 5,
                          "TAB_ORDER": 3,
                          "TYPE": "BOOL",
                          "UNIT": ""
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                        "type": "state",
                        "common": {
                          "type": "number",
                          "read": true,
                          "write": true,
                          "def": 0,
                          "states": {
                            "0": "NO ALARM",
                            "1": "ALARM",
                            "2": "ACKNOWLEDGED"
                        "native": {
                          "DP": "16869"
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                        "type": "state",
                        "common": {
                          "def": 0,
                          "type": "number",
                          "read": true,
                          "write": false,
                          "min": 1.5,
                          "max": 4.6,
                          "unit": "V"
                        "native": {
                          "CONTROL": "NONE",
                          "DEFAULT": 0,
                          "FLAGS": 1,
                          "MAX": 4.6,
                          "MIN": 1.5,
                          "OPERATIONS": 5,
                          "TAB_ORDER": 2,
                          "TYPE": "FLOAT",
                          "UNIT": "V"
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                      looxer01
                      #204
                      @emil70
                      @rantanplan
                      vielen Dank, das ist es was ich brauchte
                      Allerdings stelle ich fest, dass es sich hier um einen Standardfall handelt.
                      LOWBAT_ALARM wird mit 1 gesetzt womit das Gerät selektiert werden sollte, wie andere classic Geräte auch.
                      Die erste Frage ist, ob das Script überhaupt ausgelöst wird. Das hängt mit der GeraeteIDTrigger einstellung zusammen
                      Entweder weil der Datenpunkt hm-rega.0.maintenance verändert wurde (bei GeraeteIDTrigger = false) oder
                      weil die 1 im Datenpunkt LOWBAT_ALARM gesetzt wurde (bei GeraeteIDTrigger = true).
                      Wenn es auslöst, dann hilft ein Protokoll. Das kann ja auch über längere Zeit aktiv gesetzt werden und als Datei abgespeichert werden.
                      So stört es dann nicht im Protokoll und du brauchst nicht danach im Protokoll zu suchen.
                      vG Looxer
                      rantanplanR 1 Antwort Letzte Antwort
                      • L looxer01
                        @emil70
                        @rantanplan
                        vG Looxer
                        rantanplanR Offline
                        rantanplanR Offline
                        rantanplan
                        #205
                        @looxer01
                        Ich habe mal im Script debugLevel auf 2 gesetzt.
                        GeraeteId steht bei mir auf false.
                        Dann habe ich neue Batterien eingesetzt.
                        Meldung auf der CCU3 weg.
                        Dann wieder die alten Batterien eingesetzt.
                        Systemmeldung auf der CCU3 "Leere Batterie"
                        Hier das LOG.
                        ServicemeldungenSystemLog.csv
                        Aktuell sind noch die leeren Batterien drin.
                        Sieht so aus:
                        Object Daten WZ-VD-Regal:4.FAULT_REPORTING
                         "type": "state",
                         "common": {
                           "def": 0,
                           "type": "number",
                           "read": true,
                           "write": false,
                           "min": 0,
                           "max": 7,
                           "states": {
                             "0": "NO_FAULT",
                             "1": "VALVE_TIGHT",
                             "2": "ADJUSTING_RANGE_TOO_LARGE",
                             "3": "ADJUSTING_RANGE_TOO_SMALL",
                             "4": "COMMUNICATION_ERROR",
                             "5": "",
                             "6": "LOWBAT",
                             "7": "VALVE_ERROR_POSITION"
                           "role": "indicator",
                           "name": "WZ-VD-Regal:4.FAULT_REPORTING"
                         "native": {
                           "CONTROL": "NONE",
                           "DEFAULT": 0,
                           "FLAGS": 9,
                           "ID": "FAULT_REPORTING",
                           "MAX": 7,
                           "MIN": 0,
                           "OPERATIONS": 5,
                           "TAB_ORDER": 1,
                           "TYPE": "ENUM",
                           "UNIT": "",
                           "VALUE_LIST": [
                             "NO_FAULT",
                             "VALVE_TIGHT",
                             "LOWBAT",
                         "ts": 1740918410792,
                         "_id": "hm-rpc.0.OEQ2637929.4.FAULT_REPORTING",
                         "acl": {
                           "object": 1636,
                           "state": 1636,
                        Object Daten WZ-VD-Regal:4.FAULT_REPORTING-6_ALARM
                         "type": "state",
                         "common": {
                           "name": "WZ-VD-Regal:4.FAULT_REPORTING-6_ALARM",
                           "type": "number",
                           "read": true,
                           "write": true,
                           "def": 0,
                           "states": {
                             "0": "NO ALARM",
                             "1": "ALARM",
                             "2": "ACKNOWLEDGED"
                         "native": {
                           "Name": "WZ-VD-Regal:4.FAULT_REPORTING-6_ALARM",
                           "DP": "16978"
                         "ts": 1548955628248,
                         "_id": "hm-rpc.0.OEQ2637929.4.FAULT_REPORTING-6_ALARM",
                         "acl": {
                           "object": 1636,
                           "state": 1636,
                        Was kann ich noch tun?
                        Rantanplan
                        L 3 Antworten Letzte Antwort
                          @looxer01
                          Hier das LOG.
                          Sieht so aus:
                           "type": "state",
                           "common": {
                             "def": 0,
                             "type": "number",
                             "read": true,
                             "write": false,
                             "min": 0,
                             "max": 7,
                             "states": {
                               "0": "NO_FAULT",
                               "1": "VALVE_TIGHT",
                               "5": "",
                               "6": "LOWBAT",
                           "native": {
                             "CONTROL": "NONE",
                             "DEFAULT": 0,
                             "FLAGS": 9,
                             "MAX": 7,
                             "MIN": 0,
                             "OPERATIONS": 5,
                             "TAB_ORDER": 1,
                             "TYPE": "ENUM",
                             "UNIT": "",
                             "VALUE_LIST": [
                               "NO_FAULT",
                               "VALVE_TIGHT",
                               "LOWBAT",
                           "acl": {
                             "object": 1636,
                             "state": 1636,
                           "type": "state",
                           "common": {
                             "type": "number",
                             "read": true,
                             "write": true,
                             "def": 0,
                             "states": {
                               "0": "NO ALARM",
                               "1": "ALARM",
                               "2": "ACKNOWLEDGED"
                           "native": {
                             "DP": "16978"
                           "acl": {
                             "object": 1636,
                             "state": 1636,
                          looxer01
                          #206
                          @rantanplan
                          @rantanplan sagte in [Vorlage] Servicemeldungen Volume2:
                          im moment nichts. Ich erstelle einen Fix und poste ihn hier.
                          Ursache ist, so glaube ich, klar.
                          vG Looxer
                            @looxer01
                            Hier das LOG.
                            Sieht so aus:
                             "type": "state",
                             "common": {
                               "def": 0,
                               "type": "number",
                               "read": true,
                               "write": false,
                               "min": 0,
                               "max": 7,
                               "states": {
                                 "0": "NO_FAULT",
                                 "1": "VALVE_TIGHT",
                                 "5": "",
                                 "6": "LOWBAT",
                             "native": {
                               "CONTROL": "NONE",
                               "DEFAULT": 0,
                               "FLAGS": 9,
                               "MAX": 7,
                               "MIN": 0,
                               "OPERATIONS": 5,
                               "TAB_ORDER": 1,
                               "TYPE": "ENUM",
                               "UNIT": "",
                               "VALUE_LIST": [
                                 "NO_FAULT",
                                 "VALVE_TIGHT",
                                 "LOWBAT",
                             "acl": {
                               "object": 1636,
                               "state": 1636,
                             "type": "state",
                             "common": {
                               "type": "number",
                               "read": true,
                               "write": true,
                               "def": 0,
                               "states": {
                                 "0": "NO ALARM",
                                 "1": "ALARM",
                                 "2": "ACKNOWLEDGED"
                             "native": {
                               "DP": "16978"
                             "acl": {
                               "object": 1636,
                               "state": 1636,
                            looxer01
                            #207
                            @rantanplan
                            kannst du diese Tabelle austauschen und dann nochmal mit debug laufen lassen ?
                            const alarmTypes = [
                                { key: 'UNREACH_ALARM',                     suffixes: ['UNREACH_ALARM','unreach' ] },//UNREACH_ALARM = HM-Classic & HMIP-CCU - unreach = HMIP Accesspoint
                                { key: 'STICKY_UNREACH_ALARM',              suffixes: ['STICKY_UNREACH_ALARM'] },
                                { key: 'CONFIG_PENDING_ALARM',              suffixes: ['CONFIG_PENDING_ALARM','configPending'] }, //configPending ist eine HMIP Meldung
                                { key: 'UPDATE_PENDING_ALARM',              suffixes: ['UPDATE_PENDING_ALARM'] },
                                { key: 'LOWBAT_ALARM',                      suffixes: ['LOWBAT_ALARM', 'LOW_BAT_ALARM','lowBat'] }, //LOWBAT_ALARM = HM-Classic - LOW_BAT_ALARM = HMIP CCU - lowBat = HMIP Accesspoint
                                { key: 'DEVICE_IN_BOOTLOADER_ALARM',        suffixes: ['DEVICE_IN_BOOTLOADER_ALARM'] },
                                { key: 'ERROR',                             suffixes: ['ERROR','DUTY_CYCLE'] },                  // error ist ein Sammler fuer hier nicht definierte Meldungen
                                { key: 'FAULT_REPORTING',                   suffixes: ['FAULT_REPORTING','FAULT_REPORTING-1_ALARM','FAULT_REPORTING-2_ALARM','FAULT_REPORTING-3_ALARM','FAULT_REPORTING-4_ALARM','FAULT_REPORTING-5_ALARM','FAULT_REPORTING-6_ALARM'] },
                                { key: 'SABOTAGE_ALARM',                    suffixes: ['SABOTAGE_ALARM','sabotage'] }, // sabotage ist eine HMIP Meldung
                                { key: 'STICKY_SABOTAGE_ALARM',             suffixes: ['STICKY_SABOTAGE_ALARM'] },
                                { key: 'ERROR_NON_FLAT_POSITIONING_ALARM',  suffixes: ['ERROR_NON_FLAT_POSITIONING_ALARM'] },
                                { key: 'OVERHEAT_ALARM',                    suffixes: ['ERROR_OVERHEAT_ALARM'] },
                                { key: 'UNDERVOLTAGE_ALARM',                suffixes: ['ERROR_UNDERVOLTAGE_ALARM'] },
                            Die Änderung befindet sich in Zeile 9.
                              @looxer01
                              Hier das LOG.
                              Sieht so aus:
                               "type": "state",
                               "common": {
                                 "def": 0,
                                 "type": "number",
                                 "read": true,
                                 "write": false,
                                 "min": 0,
                                 "max": 7,
                                 "states": {
                                   "0": "NO_FAULT",
                                   "1": "VALVE_TIGHT",
                                   "5": "",
                                   "6": "LOWBAT",
                               "native": {
                                 "CONTROL": "NONE",
                                 "DEFAULT": 0,
                                 "FLAGS": 9,
                                 "MAX": 7,
                                 "MIN": 0,
                                 "OPERATIONS": 5,
                                 "TAB_ORDER": 1,
                                 "TYPE": "ENUM",
                                 "UNIT": "",
                                 "VALUE_LIST": [
                                   "NO_FAULT",
                                   "VALVE_TIGHT",
                                   "LOWBAT",
                               "acl": {
                                 "object": 1636,
                                 "state": 1636,
                               "type": "state",
                               "common": {
                                 "type": "number",
                                 "read": true,
                                 "write": true,
                                 "def": 0,
                                 "states": {
                                   "0": "NO ALARM",
                                   "1": "ALARM",
                                   "2": "ACKNOWLEDGED"
                               "native": {
                                 "DP": "16978"
                               "acl": {
                                 "object": 1636,
                                 "state": 1636,
                              looxer01
                              #208
                              @rantanplan
                              ignoriere die voherige message.
                              Nutze stattdessen die angehängte Version. Ich musste noch ein paar Codezeilen hinzufügen.
                              Es konnte gar nicht funktionieren
                              Servicemeldungen_Vol2_3-30_Rantanplan.txt
                              rantanplanR 2 Antworten Letzte Antwort
                              • L looxer01
                                @rantanplan
                                rantanplanR Offline
                                rantanplanR Offline
                                rantanplan
                                #209
                                @looxer01 sagte in [Vorlage] Servicemeldungen Volume2:
                                @rantanplan
                                Zu spät😊
                                Mit leeren Batterien kam die Meldung ".....Ventil blockiert"
                                Damit meine "Arbeit" nicht umsonst war, hier das Log.😬
                                Probiere jetzt Dein geändertes Script.
                                Rantanplan
                                • L looxer01
                                  @rantanplan
                                  rantanplanR Offline
                                  rantanplanR Offline
                                  rantanplan
                                  #210
                                  @looxer01
                                  Nach dem Script-Start wird "Einstellbereich Ventil zu gross" gemeldet
                                  Auf der CCU3 keine Servicemeldung.
                                  Hier das Log.
                                  Habe auch mal das andere Log aktiviert.
                                  ServicemeldungenVol2.csv
                                  Sehe gerade, dass "FAULT_REPORTING-6_ALARM" in ioBroker tatsächlich auf '2' steht. Warum auch immer.
                                  CCU3 sagt "alles ok".
                                  Tausche jetzt nochmal die Batterien.
                                  Rantanplan
                                  L 2 Antworten Letzte Antwort
                                    @looxer01
                                    Hier das Log.
                                    looxer01
                                    #211
                                    @rantanplan
                                    • es wäre gut zu wissen wie Object Daten WZ-VD-Regal:4.FAULT_REPORTING ausgeprägt ist. Denn dort gibt es die status 1 - 7. bei den anderen nicht. (das hatte ich leider falsch gesehen)
                                      In der Regel werden die ALARM-Datenpunkte augelöst.
                                    • Ein quick Fix wäre 'FAULT_REPORTING-6_ALARM' unter den AlarmType LowBat zu listen. Dann fehlen aber immer noch die anderen Alarme.
                                    ich muss nochmal nachdenken.
                                    EDIT
                                    ok, nachgedacht.
                                    Der Ansatz wäre
                                    • 'FAULT_REPORTING-6_ALARM' unter lowbat zu führen. Dann bekommst du das auch klassifiziert als lowbat und nicht als 'FaultMessage"
                                    • Die anderen werde ich dann vom status her als FaultMessages führen und die status 1-7 (ohne 6) entsprechend als status messages entsprechend der Tabelle: faultMessages aus dem Script darstellen
                                    brauche ich jetzt aber ein wenig Zeit für
                                      @looxer01
                                      Hier das Log.
                                      looxer01
                                      #212
                                      @rantanplan
                                      ich habe eine neue Version gebaut und hoffe, dass es jetzt ok ist.
                                      Du solltest jetzt eine lowbat message erhalten für dieses gerät.
                                      für alle anderen messages (Ventilstellung etc) erhälts du "Fault Messages"
                                      Servicemeldungen_Vol2_3-30_Rantanplan2.txt
                                      Falls ok, werde ich das in die nächste Version übernehmen.
                                      vG Looxer
                                      • L looxer01
                                        @rantanplan
                                        vG Looxer
                                        rantanplanR Offline
                                        rantanplanR Offline
                                        rantanplan
                                        #213
                                        @rantanplan
                                        Irgendetwas hakt noch. (Sorry)
                                        Leztes Script gestartet.
                                        Leere Batterien noch im Gerät.
                                        CCU3 zeigt "Leere Batterie"
                                        Script JSONAktuelleSM "Keine passende Meldung......."
                                           "datum_seit": "20.03.25 13:12:21 Uhr",
                                           "meldungsart": "FAULT_REPORTING-6_ALARM",
                                           "common_name": "Wohnzimmer-VD-Regal",
                                           "GeraeteId": "OEQ2637929",
                                           "status": 1,
                                           "status_message_Lang": "20.03.25 13:12:21 Uhr - FAULT_REPORTING-6_ALARM - Wohnzimmer-VD-Regal - (OEQ2637929) - 1 - Keine passende Meldung fuer MessageType: \"FAULT_REPORTING-6_ALARM\", Adapter: \"hm-rpc\", Status: \"1\". - Batteriebezeichnung: 2x LR6/AA",
                                           "status_message_Pure": "Keine passende Meldung fuer MessageType: \"FAULT_REPORTING-6_ALARM\", Adapter: \"hm-rpc\", Status: \"1\". - Batteriebezeichnung: 2x LR6/AA",
                                           "batterie_bezeichnung": "2x LR6/AA",
                                           "SM_aufgehoben_seit": "aktiv",
                                           "DataPoint": "hm-rpc.0.OEQ2637929.4.FAULT_REPORTING-6_ALARM"
                                        Über Telegram kam keine Meldung!!!
                                        Hier das LOG.
                                        Rantanplan
                                          @rantanplan
                                             "status": 1,
                                          Hier das LOG.
                                          looxer01
                                          #214
                                          @rantanplan
                                          wenn ich mir das log ansehe, dann sehe ich, dass eine Message reported wird:
                                          EDIT:
                                          ja, schon gefunden. Ist die Umsetzung für die Nachricht.
                                          Muss ich mir aber näher ansehen.
