  4. [Vorlage] Script für automatisches Backup steuerbar durch VIS
    5.9k
283 Beiträge 29 Kommentatoren 71.6k Aufrufe
  • PeoplesP Offline
    PeoplesP Offline
    Peoples
    Und wenn du jetzt mal 100px (bei mir steht da 60px) reinschreibst was ist dann?
    • WebrangerW Offline
      WebrangerW Offline
      Webranger
      dann passiert nur das:
      Intel NUC Celeron, Xiaomi Gateway, Fritzbox 7590, XS1
      • PeoplesP Offline
        PeoplesP Offline
        Peoples
        Puh…
        Welche Vis-Version hast du? Ich hab die 1.0.4
        Gib mir mal nur von dem Uhrzeit-Widget den Export dann schau ich mal wie das bei mir aussieht
          WebrangerW Offline
          Webranger
          hab auch die 1.0.4
          [{"tpl":"tplJquiInputDatetime","data":{"oid":"javascript.0.System.Iobroker.Backup.komplett.BackupZeit_Montag","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"timeOnly":true,"hideSeconds":true,"size":"1","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"797px","top":"92px","width":"60px","height":"","z-index":"2","font-weight":"bold"},"widgetSet":"jqui"}]
          • PeoplesP Offline
            PeoplesP Offline
            Peoples
            Schaut bei mir ganz normal aus, hast du vielleicht in deinem Projekt irgenwo Css - mäßig was definiert das hierrauf evtl. Auswirkungen hat?
            Wenn du noch das Main-Projekt hast könntest du es dort mal importieren und schauen wie es aussieht.
              Adnim
              hab es auch gerade installiert läuft klasse.
              Hatte aber auch anfangs die komische anzeige.
              Man muss unter Allgemein die Size von 1 erhöhen und nicht unten bei Css-allgemein.
              Danke für das Skript!!
                WebrangerW Offline
                Webranger
                Aaaaah DANKE das war es!
                Perfekt dann ist das erstmal erledigt und ich kann mir was neues ausdenken ;)
                • E Offline
                  eXTreMe
                  @peoples:
                  @eXTreMe:
                  Das klappt!!!
                  Wo liegt denn dann nun der Fehler? `
                  Dann machen wir mal weiter, geh mal in das JavaScript und schreibe bspw. in Zeile 110 folgendes:
                  backup_erstellen('komplett','','10','192.168.10.30','backup/ioBroker/','iobroker','DeinPasswort');
                  Dann auf Speichern. Dadurch wird die Funktion backup_erstellen mit den angegebenen Parametern aufgerufen und führt die backup.sh aus.
                  Auch hier wieder PW ändern und sagen was passiert. `
                  Danke für deine Hilfe! habe den Fehler gefunden:
                  Nach dem einfügen der Zeile gab es in log eine Meldung, dass das exec kommando in den javascript adapter settings aktiviert sein muss, ich hatte heute erst den javascript adapter geupdated, in der alten version (3.4.0 meine ich hatte ich davor) gab es diese einstellung nicht, da hatte ich nämlich auch schon mal nachgeschaut die tage.
                  Haken rein und läuft.
                  Am besten erwähnst du noch in deinem ersten Posting, dass die aktuelle version des Javascript adapters erforderlich ist.
                  Danke nochmal!
                  • PeoplesP Offline
                    PeoplesP Offline
                    Peoples
                    erledigt!
                    Danke für die Info
                    • O Offline
                      O Offline
                      olifall
                      ich habe das Backup erfolgreich installieren können, erstmal danke für die tolle Arbeit.
                      Nach dem alles lief wollte ich es genauer austesten und habe ein komplettes und ein paar kleine Backups gemacht. Nach jedem Backup habe ich auf der Konsole geschaut ob es auch sicher vorhanden ist. Zum Glück habe ich das komplette auch mal auf mein NAS rüber geschoben, denn nach dem 7 kleinen Backup ist mein Raspi plötzlich nicht mehr erreichbar gewesen. Auch nach mehrmaligem Neustart komme ich nicht mehr drauf. (Wollte doch nur die 10 Versionen testen)
                      Nun zu meiner Frage, hat schon mal jemand ein Backup zurück gespielt?
                      Wenn ich das mache und es ohne Fehler durchgelaufen ist, hat sich im ioBroker nichts geändert ist immer noch gleich wie nach der Neuinstallation. Gemacht habe ich das so wie am Anfang geschrieben,
                      mit "tar -xzvf …...........
                      Gruss Oli
                      • O Offline
                        O Offline
                        olifall
                        ich habe den Fehler gefunden.
                        Der Befehl lautet nicht so: tar -xzvf Backupname.tar.gz -C /euer Iobroker Verzeichnis
                        Es muss vom root Verzeichnis aus so eingegeben werden: tar -xzvf Backupname.tar.gz -C /
                        Bei mir ist das ioBroker Verzeichnis hier: "/opt/iobroker und im Backup steht er auch genau so drin. Mit dem oberen Befehl wurde mir unter dem ioBroker Verzeichnis ein weiteres ioBroker Verzeichnis angelegt.
                        Gruss Oli
                        • PeoplesP Offline
                          PeoplesP Offline
                          Peoples
                          #66
                          Hi Oli,
                          ich kam gestern Abend in die Verlegenheit ein komplettes Backup wiederherstellen zu müssen, habe auch gemerkt dass der Befehl so wie du es bereits klargestellt hast berichtigt werden muss.
                          Ich konnte das ganze Backup einspielen und dann den iobroker wieder starten, hat das bei dir auch geklappt?
                          Werde den Befehl im ersten Post sofort berichtigen war nur gestern ein bisschen angespannt und hatte keine Lust mehr :lol:
                          Danke für den Hinweis!
                          • PeoplesP Offline
                            PeoplesP Offline
                            Peoples
                            #67
                            @olifall:
                            (Wollte doch nur die 10 Versionen testen) `
                            Hast du 10 komplette oder 10 normale gemacht bevor er abgeschmiert ist?
                            Ich wüsste jetzt nicht warum das passiert ist, da ich keinen Raspberry benutze kann ich das mal auf die schnelle auch nicht reproduzieren, werde aber bei Gelegenheit mal einen Raspberry mit einem Image füttern und versuchen das nachzustellen.
                            • O Offline
                              O Offline
                              olifall
                              #68
                              Hallo Steffen,
                              bei mir hat es jetzt funktioniert. :-)
                              Folgendes konnte ich auch noch feststellen und zwar zwei mal, habe den Raspi zwei mal installiert. :-)
                              Nach erfolgreichem zurückspielen vom Backup konnte ich den ioBroker starten aber nicht per Web darauf zugreifen.
                              Dann habe ich folgendes gemacht:
                              sudo iobroker status
                              Meldung = "No connection to states 127.0.0.0:6379[redis]"
                              sudo apt-get install redis-server
                              Danach lief es wieder und meine Daten waren da. :-)
                              @Hatte ein komplettes und erst 6 Normale, nach dem 7ten ist er dann abgeschmiert. Was ich aber sagen muss vor dem testen hatte es geklappt.
                              Ich habe in der "backup.sh" Datein folgendes hinzugefügt: sudo mount -t cifs //IP-Adresse vom Nas/Share /media/nas/ -o username=????????,password=???????
                              und dann noch einen "scp" kopie Befehl der mir dann die Backups auf mein NAS schiebt. (Das war mein Glück, dadurch hatte ich ein Komplettes Backup)
                              Hat funktioniert bin mir aber nicht sicher ob das der richtige Weg ist, ich bin eigentlich ein Windows User. :-)
                              Gruss Oli
                              • PeoplesP Offline
                                PeoplesP Offline
                                Peoples
                                #69
                                Das kopieren auf den Nas macht doch das Script auch so?
                                Oder wolltest du anstelle des lftp-Befehls lieber den Kopiervorgang über scp machen?
                                • O Offline
                                  O Offline
                                  olifall
                                  #70
                                  das mit dem Script habe ich nicht hinbekommen.
                                  Kannst Du mir sagen wie ich das im Script richtig eintragen muss damit es funktioniert, das mit dem FTP hat nicht geklappt.
                                  Gruss Oli
                                  • PeoplesP Offline
                                    PeoplesP Offline
                                    Peoples
                                    #71
                                        Backup[1] = [];
                                        Backup[1][0] = 'komplett';                        // Backup Typ (nicht verändern)
                                        Backup[1][1] = '';                                   // Names Zusatz, wird an den Dateinamen angehängt bspw. Master/Slave (falls gewünscht, ansonsten leer lassen)
                                        Backup[1][2] = '10';                                // Alte Backups löschen nach X Tagen (falls gewünscht, ansonsten leer lassen)
                                        Backup[1][3] = '192.168.10.30';                // FTP-Host
                                        Backup[1][4] = 'backup/ioBroker/';             // genaue Verzeichnissangabe bspw. /volume1/Backup/ auf FTP-Server (falls gewünscht, ansonsten leer lassen)
                                        Backup[1][5] = 'iobroker';                         // Username für FTP - Verbindung
                                        Backup[1][6] = 'xxxx';                              // Passwort für FTP - Verbindung
                                    Was hast du für einen Nas? Hast du ein spezielles Verzeichnis einen speziellen user?
                                    • O Offline
                                      O Offline
                                      olifall
                                      #72
                                      das habe ich schon versucht, geht leider nicht. Mein NAS ist ein QNAP TS-219P, getestet mit einer normalen Freigabe und einem User mit Admin Rechten.
                                      Diesen Fehler konnte ich gestern nach einer erneuten Installation auf einem anderen Raspi wieder nachstellen:
                                      ****Nach erfolgreichem zurückspielen vom Backup konnte ich den ioBroker starten aber nicht per Web darauf zugreifen.
                                      sudo apt-get install redis-server****
                                      Gruss Oli
                                      • PeoplesP Offline
                                        PeoplesP Offline
                                        Peoples
                                        #73
                                        Ich habe gestern mal ein komplettes Backup meiner VM auf einem Raspberry mit einem Stretch image aus dem Downloadbereich der IoBroker HP "zurückgespielt" danach hab ich noch iobroker über putty gestartet und alles lief ganz normal hoch inkl. dem Webinterface.
                                        Aber es ist ein super Hinweis, dass wenn man auf das Webinterface keinen Zugriff hat man mit deiner Lösung wieder alles zum laufen bekommt. Habe diesen ebenfalls im ersten Post aufgenommen.
                                        Wegen dem Zugriff auf die Nas kann ich leider nicht weiterhelfen hab eine Synology, dort habe ich den User eingestellt und das Pw. Dann Script gestartet und alles lief inkl. dem lftp - Transfer. Ich sichere alle zwei Tage via IoBroker Backup und einmal im Monat ein Komplettes und bisher tut es stetig seinen Dienst.
                                        • O Offline
                                          O Offline
                                          olifall
                                          #74
                                          Hallo Steffen,
                                          alles klar, vielen Dank.
                                          Gruss Oli
