  4. IOBroker stürzt ab und alle Adapter starten neu
    1.0k
    6.1k
82 Beiträge 13 Kommentatoren 17.6k Aufrufe 11 Beobachtet
  • M matrose65
    @wendy2702
    du meinst ganz normal mit ssh zugreifen und dann dmesg eingeben?
    uwe@iobroker:~$ dmesg
    dmesg: read kernel buffer failed: Die Operation ist nicht erlaubt
    wendy2702W Offline
    wendy2702W Offline
    @matrose65 ok.
    Sorry, mein Fehler. Ist ja ne VM
    Dann am besten noch die lang Version von
    iob diag
    • wendy2702W wendy2702
      @matrose65 ok.
      iob diag
      matrose65
      @wendy2702
      klar doch
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-30-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
      OS is similar to:
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       16:31:58 up 12 days,  7:37,  2 users,  load average: 0.14, 0.09, 0.03
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-02-27 16:31:58 CET
                 Universal time: Thu 2025-02-27 15:31:58 UTC
                       RTC time: Thu 2025-02-27 15:31:58
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      uwe
      HOME=/home/uwe
      GROUPS=uwe cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             16G        2.3G         12G        565K        2.5G         14G
      Swap:           1.0G          0B        1.0G
      Total:           17G        2.3G         13G
      Active iob-Instances:   21
              15992 M total memory
               2179 M used memory
                890 M active memory
               2933 M inactive memory
              11779 M free memory
                340 M buffer memory
               2023 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 16:31:58 up 12 days,  7:37,  2 users,  load average: 0.14, 0.09, 0.03
      Tasks: 124 total,   1 running, 123 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 33.3 us, 33.3 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15992.7 total,  11779.0 free,   2179.7 used,   2364.0 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.  13812.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  7.8G     0  7.8G   0% /dev
      tmpfs          tmpfs     1.6G  552K  1.6G   1% /run
      /dev/sda1      ext4       39G  7.1G   30G  20% /
      tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Sat Feb 15 08:54:11 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Feb 15 08:54:11 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      474M    /var/
      251M    /var/cache
      244M    /var/cache/apt
      176M    /var/lib
      167M    /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      141M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.4G    /opt/iobroker/iobroker-data/
      1.2G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      *** ZigBee Settings ***
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.3
      /usr/bin/node           v20.18.3
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.30.0
      nodejs:
        Installed: 20.18.3-1nodesource1
        Candidate: 20.18.3-1nodesource1
        Version table:
       *** 20.18.3-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 68883)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.1.13, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
        system.adapter.history.0                : history               : iobroker                                 - disabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
      + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.2                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "devices"      : 1.1.5    , installed 1.1.5
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "roborock"     : 0.6.18   , installed 0.6.18
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.11.2
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "weather-warnings": 0.7.3 , installed 0.7.3
      Adapter    "web"          : 6.2.5    , installed 6.3.0
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "worx"         : 3.1.1    , installed 3.1.1
      Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
      Objects and States
      Objects:        7265
      States:         6407
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9495887    85306/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       9493325    85306/iobroker.js-c
      tcp        0      0 192.168.1.13:8081       0.0.0.0:*               LISTEN      1001       9493435    85439/io.admin.0
      tcp        0      0 192.168.1.13:2001       0.0.0.0:*               LISTEN      1001       9498686    85713/io.hm-rpc.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5783698    58804/sshd: /usr/sb
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          110        1/init
      tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       9496850    85798/io.mqtt.0
      tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       9496851    85798/io.mqtt.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       9496436    85828/io.shelly.1
      tcp6       0      0 :::6824                 :::*                    LISTEN      1001       10021613   87609/io.roborock.0
      tcp6       0      0 :::7906                 :::*                    LISTEN      1001       10021614   87609/io.roborock.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9497098    86023/io.web.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       9499920    86053/io.fullybrows
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       9497845    85884/io.sonos.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5783700    58804/sshd: /usr/sb
      tcp6       0      0 :::111                  :::*                    LISTEN      0          111        1/init
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       9499139    86038/io.wled.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       9498821    85858/io.shelly.2
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2348       1/init
      udp6       0      0 :::111                  :::*                                0          1662       1/init
      2025-02-27 16:11:59.012  - info: host.iobroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 87936
      2025-02-27 16:11:59.950  - info: netatmo-crawler.0 (87936) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.3, js-controller: 7.0.6
      2025-02-27 16:11:59.972  - info: netatmo-crawler.0 (87936) Getting data for stationid:70:ee:50:7f:ff:f4
      2025-02-27 16:12:02.312  - info: netatmo-crawler.0 (87936) Getting data for stationid:70:ee:50:58:fd:44
      2025-02-27 16:12:05.099  - info: netatmo-crawler.0 (87936) Getting data for stationid:70:ee:50:2e:9d:b8
      2025-02-27 16:12:05.989  - info: netatmo-crawler.0 (87936) Getting data for stationid:70:ee:50:7f:c8:b6
      2025-02-27 16:12:06.807  - info: netatmo-crawler.0 (87936) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2025-02-27 16:12:07.322  - info: host.iobroker instance system.adapter.netatmo-crawler.0 having pid 87936 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-02-27 16:13:54.565  - info: web.0 (86023) <== Disconnect system.user.admin from ::ffff:192.168.1.144 vis-2
      2025-02-27 16:14:24.010  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 87953
      2025-02-27 16:14:24.866  - info: dwd.0 (87953) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.3, js-controller: 7.0.6
      2025-02-27 16:14:25.375  - info: dwd.0 (87953) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-02-27 16:14:25.889  - info: host.iobroker instance system.adapter.dwd.0 having pid 87953 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-02-27 16:16:33.859  - info: web.0 (86023) ==> Connected system.user.admin from ::ffff:192.168.1.144
      2025-02-27 16:16:34.109  - info: fullybrowser.0 (86053) 🗸 192.168.1.144: Command screenOn successfully set to true
      2025-02-27 16:21:04.149  - info: fullybrowser.0 (86053) 🗸 192.168.1.144: Command screenOff successfully set to true
      2025-02-27 16:24:05.605  - error: roborock.0 (87609) Failed to update updateHomeData with error: Error: read ECONNRESET
      2025-02-27 16:26:13.947  - info: web.0 (86023) <== Disconnect system.user.admin from ::ffff:192.168.1.144 vis-2
      2025-02-27 16:29:12.752  - info: web.0 (86023) ==> Connected system.user.admin from ::ffff:192.168.1.144
      2025-02-27 16:29:12.898  - info: fullybrowser.0 (86053) 🗸 192.168.1.144: Command screenOn successfully set to true
      2025-02-27 16:30:00.012  - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 88008
      2025-02-27 16:30:00.914  - info: ical.0 (88008) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
      2025-02-27 16:30:01.559  - info: ical.0 (88008) processing URL: Familie https://calendar.google.com/calendar/ical/3cf4jlif04jr6m92ahk0degosc%40group.calendar.google.com/private-45041f110be4e228cac90a1f44edc113/basic.ics
      2025-02-27 16:30:06.723  - info: ical.0 (88008) Terminated (NO_ERROR): Without reason
      2025-02-27 16:30:07.236  - info: host.iobroker instance system.adapter.ical.0 having pid 88008 terminated with code 0 (NO_ERROR)
      iob diag has finished.
      • M matrose65
        @wendy2702
        JLegJ Offline
        JLegJ Offline
        JLeg
        @matrose65 sagte in IOBroker stürzt ab und alle Adapter starten neu:
        @wendy2702
        sudo dmesg - geht auch sowohl in VM und LXC...
        • JLegJ JLeg
          @wendy2702
          matrose65
          @jleg sagte in IOBroker stürzt ab und alle Adapter starten neu:
          sudo dmesg
          hier nun die Ausgabe von sudo dmesg
          uwe@iobroker:~$ sudo dmesg
          [    0.000000] Linux version 6.1.0-30-amd64 (debian-kernel@lists.debian.org) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC Debian 6.1.124-1 (2025-01-12)
          [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-amd64 root=UUID=27157ade-289f-4c85-9942-840201a0ed72 ro quiet
          [    0.000000] BIOS-provided physical RAM map:
          [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
          [    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
          [    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
          [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bffd9fff] usable
          [    0.000000] BIOS-e820: [mem 0x00000000bffda000-0x00000000bfffffff] reserved
          [    0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
          [    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
          [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000043fffffff] usable
          [    0.000000] NX (Execute Disable) protection: active
          [    0.000000] SMBIOS 2.8 present.
          [    0.000000] DMI: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org 04/01/2014
          [    0.000000] Hypervisor detected: KVM
          [    0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
          [    0.000001] kvm-clock: using sched offset of 10887319567 cycles
          [    0.000002] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
          [    0.000005] tsc: Detected 2999.998 MHz processor
          [    0.001000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
          [    0.001003] e820: remove [mem 0x000a0000-0x000fffff] usable
          [    0.001007] last_pfn = 0x440000 max_arch_pfn = 0x400000000
          [    0.001050] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
          [    0.001057] last_pfn = 0xbffda max_arch_pfn = 0x400000000
          [    0.009584] found SMP MP-table at [mem 0x000f5450-0x000f545f]
          [    0.010289] RAMDISK: [mem 0x334f3000-0x35a70fff]
          [    0.010299] ACPI: Early table checksum verification disabled
          [    0.010302] ACPI: RSDP 0x00000000000F5250 000014 (v00 BOCHS )
          [    0.010307] ACPI: RSDT 0x00000000BFFE3048 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
          [    0.010312] ACPI: FACP 0x00000000BFFE2E1A 000074 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
          [    0.010320] ACPI: DSDT 0x00000000BFFDF040 003DDA (v01 BOCHS  BXPC     00000001 BXPC 00000001)
          [    0.010324] ACPI: FACS 0x00000000BFFDF000 000040
          [    0.010327] ACPI: APIC 0x00000000BFFE2E8E 000090 (v03 BOCHS  BXPC     00000001 BXPC 00000001)
          [    0.010330] ACPI: SSDT 0x00000000BFFE2F1E 0000CA (v01 BOCHS  VMGENID  00000001 BXPC 00000001)
          [    0.010334] ACPI: HPET 0x00000000BFFE2FE8 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
          [    0.010337] ACPI: WAET 0x00000000BFFE3020 000028 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
          [    0.010340] ACPI: Reserving FACP table memory at [mem 0xbffe2e1a-0xbffe2e8d]
          [    0.010341] ACPI: Reserving DSDT table memory at [mem 0xbffdf040-0xbffe2e19]
          [    0.010342] ACPI: Reserving FACS table memory at [mem 0xbffdf000-0xbffdf03f]
          [    0.010342] ACPI: Reserving APIC table memory at [mem 0xbffe2e8e-0xbffe2f1d]
          [    0.010343] ACPI: Reserving SSDT table memory at [mem 0xbffe2f1e-0xbffe2fe7]
          [    0.010343] ACPI: Reserving HPET table memory at [mem 0xbffe2fe8-0xbffe301f]
          [    0.010344] ACPI: Reserving WAET table memory at [mem 0xbffe3020-0xbffe3047]
          [    0.010658] No NUMA configuration found
          [    0.010660] Faking a node at [mem 0x0000000000000000-0x000000043fffffff]
          [    0.010668] NODE_DATA(0) allocated [mem 0x43ffc9000-0x43fff3fff]
          [    0.010976] Zone ranges:
          [    0.010978]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
          [    0.010980]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
          [    0.010982]   Normal   [mem 0x0000000100000000-0x000000043fffffff]
          [    0.010984]   Device   empty
          [    0.010985] Movable zone start for each node
          [    0.010987] Early memory node ranges
          [    0.010988]   node   0: [mem 0x0000000000001000-0x000000000009efff]
          [    0.010989]   node   0: [mem 0x0000000000100000-0x00000000bffd9fff]
          [    0.010991]   node   0: [mem 0x0000000100000000-0x000000043fffffff]
          [    0.010995] Initmem setup node 0 [mem 0x0000000000001000-0x000000043fffffff]
          [    0.011185] On node 0, zone DMA: 1 pages in unavailable ranges
          [    0.011206] On node 0, zone DMA: 97 pages in unavailable ranges
          [    0.019824] On node 0, zone Normal: 38 pages in unavailable ranges
          [    0.021118] ACPI: PM-Timer IO Port: 0x608
          [    0.021130] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
          [    0.021163] IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-23
          [    0.021166] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
          [    0.021168] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 high level)
          [    0.021169] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
          [    0.021169] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 high level)
          [    0.021170] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 high level)
          [    0.021174] ACPI: Using ACPI (MADT) for SMP configuration information
          [    0.021176] ACPI: HPET id: 0x8086a201 base: 0xfed00000
          [    0.021186] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
          [    0.021204] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
          [    0.021206] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
          [    0.021207] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000effff]
          [    0.021207] PM: hibernation: Registered nosave memory: [mem 0x000f0000-0x000fffff]
          [    0.021208] PM: hibernation: Registered nosave memory: [mem 0xbffda000-0xbfffffff]
          [    0.021209] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xfeffbfff]
          [    0.021209] PM: hibernation: Registered nosave memory: [mem 0xfeffc000-0xfeffffff]
          [    0.021210] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xfffbffff]
          [    0.021210] PM: hibernation: Registered nosave memory: [mem 0xfffc0000-0xffffffff]
          [    0.021212] [mem 0xc0000000-0xfeffbfff] available for PCI devices
          [    0.021213] Booting paravirtualized kernel on KVM
          [    0.021214] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
          [    0.025175] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
          [    0.025410] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
          [    0.025417] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
          [    0.025420] pcpu-alloc: [0] 0 1 2 3
          [    0.025455] kvm-guest: PV spinlocks enabled
          [    0.025458] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
          [    0.025467] Fallback order for Node 0: 0
          [    0.025469] Built 1 zonelists, mobility grouping on.  Total pages: 4128474
          [    0.025471] Policy zone: Normal
          [    0.025472] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-amd64 root=UUID=27157ade-289f-4c85-9942-840201a0ed72 ro quiet
          [    0.025517] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-amd64", will be passed to user space.
          [    0.027249] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
          [    0.028138] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
          [    0.028210] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
          [    0.028214] software IO TLB: area num 4.
          [    0.050518] Memory: 3171436K/16776672K available (14342K kernel code, 2336K rwdata, 9084K rodata, 2796K init, 17392K bss, 446644K reserved, 0K cma-reserved)
          [    0.050715] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [    0.050727] Kernel/User page tables isolation: enabled
          [    0.050751] ftrace: allocating 40305 entries in 158 pages
          [    0.056622] ftrace: allocated 158 pages with 5 groups
          [    0.057186] Dynamic Preempt: voluntary
          [    0.057374] rcu: Preemptible hierarchical RCU implementation.
          [    0.057376] rcu:     RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
          [    0.057377]  Trampoline variant of Tasks RCU enabled.
          [    0.057378]  Rude variant of Tasks RCU enabled.
          [    0.057379]  Tracing variant of Tasks RCU enabled.
          [    0.057380] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
          [    0.057381] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
          [    0.061445] NR_IRQS: 524544, nr_irqs: 456, preallocated irqs: 16
          [    0.061644] rcu: srcu_init: Setting srcu_struct sizes based on contention.
          [    0.077150] Console: colour VGA+ 80x25
          [    0.077161] printk: console [tty0] enabled
          [    0.077182] ACPI: Core revision 20220331
          [    0.077325] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
          [    0.077454] APIC: Switch to symmetric I/O mode setup
          [    0.077696] x2apic enabled
          [    0.077952] Switched APIC routing to physical x2apic.
          [    0.079115] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
          [    0.079143] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b3e43c8763, max_idle_ns: 440795360101 ns
          [    0.079148] Calibrating delay loop (skipped) preset value.. 5999.99 BogoMIPS (lpj=11999992)
          [    0.079283] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
          [    0.079284] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
          [    0.079286] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
          [    0.079288] Spectre V2 : Mitigation: Retpolines
          [    0.079288] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
          [    0.079289] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
          [    0.079290] Speculative Store Bypass: Vulnerable
          [    0.079291] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
          [    0.079291] MMIO Stale Data: Unknown: No mitigations
          [    0.079293] x86/fpu: x87 FPU will use FXSAVE
          [    0.092525] Freeing SMP alternatives memory: 36K
          [    0.092529] pid_max: default: 32768 minimum: 301
          [    0.092576] LSM: Security Framework initializing
          [    0.092590] landlock: Up and running.
          [    0.092591] Yama: disabled by default; enable with sysctl kernel.yama.*
          [    0.092615] AppArmor: AppArmor initialized
          [    0.092617] TOMOYO Linux initialized
          [    0.092621] LSM support for eBPF active
          [    0.092832] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
          [    0.092848] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
          [    0.201244] smpboot: CPU0: Intel QEMU Virtual CPU version 2.5+ (family: 0xf, model: 0x6b, stepping: 0x1)
          [    0.201380] cblist_init_generic: Setting adjustable number of callback queues.
          [    0.201381] cblist_init_generic: Setting shift to 2 and lim to 1.
          [    0.201396] cblist_init_generic: Setting adjustable number of callback queues.
          [    0.201397] cblist_init_generic: Setting shift to 2 and lim to 1.
          [    0.201408] cblist_init_generic: Setting adjustable number of callback queues.
          [    0.201409] cblist_init_generic: Setting shift to 2 and lim to 1.
          [    0.201419] Performance Events: unsupported Netburst CPU model 107 no PMU driver, software events only.
          [    0.201434] signal: max sigframe size: 1440
          [    0.201452] rcu: Hierarchical SRCU implementation.
          [    0.201453] rcu:     Max phase no-delay instances is 1000.
          [    0.201639] NMI watchdog: Perf NMI watchdog permanently disabled
          [    0.201703] smp: Bringing up secondary CPUs ...
          [    0.201785] x86: Booting SMP configuration:
          [    0.201786] .... node  #0, CPUs:      #1 #2 #3
          [    0.239196] smp: Brought up 1 node, 4 CPUs
          [    0.239200] smpboot: Max logical packages: 1
          [    0.239201] smpboot: Total of 4 processors activated (23999.98 BogoMIPS)
          [    0.265816] node 0 deferred pages initialised in 24ms
          [    0.265816] devtmpfs: initialized
          [    0.265816] x86/mm: Memory block size: 128MB
          [    0.268265] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
          [    0.268265] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
          [    0.268265] pinctrl core: initialized pinctrl subsystem
          [    0.268265] NET: Registered PF_NETLINK/PF_ROUTE protocol family
          [    0.268516] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
          [    0.268675] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
          [    0.268871] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
          [    0.268887] audit: initializing netlink subsys (disabled)
          [    0.268919] audit: type=2000 audit(1739606050.013:1): state=initialized audit_enabled=0 res=1
          [    0.268919] thermal_sys: Registered thermal governor 'fair_share'
          [    0.268919] thermal_sys: Registered thermal governor 'bang_bang'
          [    0.268919] thermal_sys: Registered thermal governor 'step_wise'
          [    0.268919] thermal_sys: Registered thermal governor 'user_space'
          [    0.268919] thermal_sys: Registered thermal governor 'power_allocator'
          [    0.268919] cpuidle: using governor ladder
          [    0.268919] cpuidle: using governor menu
          [    0.268919] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
          [    0.268919] PCI: Using configuration type 1 for base access
          [    0.271569] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
          [    0.271725] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
          [    0.271727] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
          [    0.271847] ACPI: Added _OSI(Module Device)
          [    0.271847] ACPI: Added _OSI(Processor Device)
          [    0.271847] ACPI: Added _OSI(3.0 _SCP Extensions)
          [    0.271847] ACPI: Added _OSI(Processor Aggregator Device)
          [    0.271847] ACPI: 2 ACPI AML tables successfully acquired and loaded
          [    0.275707] ACPI: Interpreter enabled
          [    0.275707] ACPI: PM: (supports S0 S3 S4 S5)
          [    0.275707] ACPI: Using IOAPIC for interrupt routing
          [    0.275707] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
          [    0.275707] PCI: Using E820 reservations for host bridge windows
          [    0.275707] ACPI: Enabled 3 GPEs in block 00 to 0F
          [    0.278778] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
          [    0.278784] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI HPX-Type3]
          [    0.278787] acpi PNP0A03:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
          [    0.278793] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
          [    0.279273] acpiphp: Slot [3] registered
          [    0.279309] acpiphp: Slot [8] registered
          [    0.279323] acpiphp: Slot [18] registered
          [    0.279355] acpiphp: Slot [4] registered
          [    0.279367] acpiphp: Slot [6] registered
          [    0.279379] acpiphp: Slot [7] registered
          [    0.279391] acpiphp: Slot [9] registered
          [    0.279403] acpiphp: Slot [10] registered
          [    0.279417] acpiphp: Slot [11] registered
          [    0.279430] acpiphp: Slot [12] registered
          [    0.279442] acpiphp: Slot [13] registered
          [    0.279454] acpiphp: Slot [14] registered
          [    0.279466] acpiphp: Slot [15] registered
          [    0.279478] acpiphp: Slot [16] registered
          [    0.279494] acpiphp: Slot [17] registered
          [    0.279508] acpiphp: Slot [19] registered
          [    0.279521] acpiphp: Slot [20] registered
          [    0.279533] acpiphp: Slot [21] registered
          [    0.279545] acpiphp: Slot [22] registered
          [    0.279557] acpiphp: Slot [23] registered
          [    0.279570] acpiphp: Slot [24] registered
          [    0.279583] acpiphp: Slot [25] registered
          [    0.279595] acpiphp: Slot [26] registered
          [    0.279607] acpiphp: Slot [27] registered
          [    0.279619] acpiphp: Slot [28] registered
          [    0.279631] acpiphp: Slot [29] registered
          [    0.279641] PCI host bridge to bus 0000:00
          [    0.279642] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
          [    0.279644] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
          [    0.279645] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
          [    0.279646] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff window]
          [    0.279647] pci_bus 0000:00: root bus resource [mem 0x440000000-0x4bfffffff window]
          [    0.279649] pci_bus 0000:00: root bus resource [bus 00-ff]
          [    0.279690] pci 0000:00:00.0: [8086:1237] type 00 class 0x060000
          [    0.280103] pci 0000:00:01.0: [8086:7000] type 00 class 0x060100
          [    0.280736] pci 0000:00:01.1: [8086:7010] type 00 class 0x010180
          [    0.285511] pci 0000:00:01.1: reg 0x20: [io  0xf0c0-0xf0cf]
          [    0.287173] pci 0000:00:01.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
          [    0.287176] pci 0000:00:01.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
          [    0.287177] pci 0000:00:01.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
          [    0.287178] pci 0000:00:01.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
          [    0.287361] pci 0000:00:01.2: [8086:7020] type 00 class 0x0c0300
          [    0.292066] pci 0000:00:01.2: reg 0x20: [io  0xf080-0xf09f]
          [    0.295601] pci 0000:00:01.3: [8086:7113] type 00 class 0x068000
          [    0.296100] pci 0000:00:01.3: quirk: [io  0x0600-0x063f] claimed by PIIX4 ACPI
          [    0.296110] pci 0000:00:01.3: quirk: [io  0x0700-0x070f] claimed by PIIX4 SMB
          [    0.296306] pci 0000:00:02.0: [1234:1111] type 00 class 0x030000
          [    0.299189] pci 0000:00:02.0: reg 0x10: [mem 0xfc000000-0xfcffffff pref]
          [    0.301758] pci 0000:00:02.0: reg 0x18: [mem 0xfea50000-0xfea50fff]
          [    0.307756] pci 0000:00:02.0: reg 0x30: [mem 0xfea40000-0xfea4ffff pref]
          [    0.307890] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
          [    0.308336] pci 0000:00:03.0: [1af4:1002] type 00 class 0x00ff00
          [    0.309202] pci 0000:00:03.0: reg 0x10: [io  0xf000-0xf03f]
          [    0.313488] pci 0000:00:03.0: reg 0x20: [mem 0xfd600000-0xfd603fff 64bit pref]
          [    0.315511] pci 0000:00:05.0: [1b36:0001] type 01 class 0x060400
          [    0.318767] pci 0000:00:05.0: reg 0x10: [mem 0xfea51000-0xfea510ff 64bit]
          [    0.321983] pci 0000:00:08.0: [1af4:1003] type 00 class 0x078000
          [    0.324178] pci 0000:00:08.0: reg 0x10: [io  0xf040-0xf07f]
          [    0.325327] pci 0000:00:08.0: reg 0x14: [mem 0xfea52000-0xfea52fff]
          [    0.329041] pci 0000:00:08.0: reg 0x20: [mem 0xfd604000-0xfd607fff 64bit pref]
          [    0.332810] pci 0000:00:12.0: [1af4:1000] type 00 class 0x020000
          [    0.335150] pci 0000:00:12.0: reg 0x10: [io  0xf0a0-0xf0bf]
          [    0.336154] pci 0000:00:12.0: reg 0x14: [mem 0xfea53000-0xfea53fff]
          [    0.339150] pci 0000:00:12.0: reg 0x20: [mem 0xfd608000-0xfd60bfff 64bit pref]
          [    0.340040] pci 0000:00:12.0: reg 0x30: [mem 0xfea00000-0xfea3ffff pref]
          [    0.341005] pci 0000:00:1e.0: [1b36:0001] type 01 class 0x060400
          [    0.343548] pci 0000:00:1e.0: reg 0x10: [mem 0xfea54000-0xfea540ff 64bit]
          [    0.345209] pci 0000:00:1f.0: [1b36:0001] type 01 class 0x060400
          [    0.347850] pci 0000:00:1f.0: reg 0x10: [mem 0xfea55000-0xfea550ff 64bit]
          [    0.349783] pci_bus 0000:01: extended config space not accessible
          [    0.350015] acpiphp: Slot [1-2] registered
          [    0.350034] acpiphp: Slot [0] registered
          [    0.350047] acpiphp: Slot [2] registered
          [    0.350064] acpiphp: Slot [3-2] registered
          [    0.350079] acpiphp: Slot [4-2] registered
          [    0.350092] acpiphp: Slot [5] registered
          [    0.350107] acpiphp: Slot [6-2] registered
          [    0.350121] acpiphp: Slot [7-2] registered
          [    0.350135] acpiphp: Slot [8-2] registered
          [    0.350152] acpiphp: Slot [9-2] registered
          [    0.350167] acpiphp: Slot [10-2] registered
          [    0.350181] acpiphp: Slot [11-2] registered
          [    0.350196] acpiphp: Slot [12-2] registered
          [    0.350210] acpiphp: Slot [13-2] registered
          [    0.350227] acpiphp: Slot [14-2] registered
          [    0.350245] acpiphp: Slot [15-2] registered
          [    0.350260] acpiphp: Slot [16-2] registered
          [    0.350275] acpiphp: Slot [17-2] registered
          [    0.350289] acpiphp: Slot [18-2] registered
          [    0.350304] acpiphp: Slot [19-2] registered
          [    0.350318] acpiphp: Slot [20-2] registered
          [    0.350333] acpiphp: Slot [21-2] registered
          [    0.350349] acpiphp: Slot [22-2] registered
          [    0.350364] acpiphp: Slot [23-2] registered
          [    0.350378] acpiphp: Slot [24-2] registered
          [    0.350393] acpiphp: Slot [25-2] registered
          [    0.350407] acpiphp: Slot [26-2] registered
          [    0.350422] acpiphp: Slot [27-2] registered
          [    0.350438] acpiphp: Slot [28-2] registered
          [    0.350453] acpiphp: Slot [29-2] registered
          [    0.350466] acpiphp: Slot [30] registered
          [    0.350478] acpiphp: Slot [31] registered
          [    0.350584] pci 0000:01:01.0: [1af4:1004] type 00 class 0x010000
          [    0.351763] pci 0000:01:01.0: reg 0x10: [io  0xe000-0xe03f]
          [    0.353106] pci 0000:01:01.0: reg 0x14: [mem 0xfe800000-0xfe800fff]
          [    0.359151] pci 0000:01:01.0: reg 0x20: [mem 0xfd400000-0xfd403fff 64bit pref]
          [    0.361889] pci 0000:00:05.0: PCI bridge to [bus 01]
          [    0.361907] pci 0000:00:05.0:   bridge window [io  0xe000-0xefff]
          [    0.361923] pci 0000:00:05.0:   bridge window [mem 0xfe800000-0xfe9fffff]
          [    0.361951] pci 0000:00:05.0:   bridge window [mem 0xfd400000-0xfd5fffff 64bit pref]
          [    0.362481] pci_bus 0000:02: extended config space not accessible
          [    0.363152] acpiphp: Slot [27-3] registered
          [    0.363173] acpiphp: Slot [0-2] registered
          [    0.363189] acpiphp: Slot [1-3] registered
          [    0.363204] acpiphp: Slot [2-2] registered
          [    0.363219] acpiphp: Slot [3-3] registered
          [    0.363233] acpiphp: Slot [4-3] registered
          [    0.363250] acpiphp: Slot [5-2] registered
          [    0.363265] acpiphp: Slot [6-3] registered
          [    0.363280] acpiphp: Slot [7-3] registered
          [    0.363295] acpiphp: Slot [8-3] registered
          [    0.363311] acpiphp: Slot [9-3] registered
          [    0.363326] acpiphp: Slot [10-3] registered
          [    0.363343] acpiphp: Slot [11-3] registered
          [    0.363358] acpiphp: Slot [12-3] registered
          [    0.363376] acpiphp: Slot [13-3] registered
          [    0.363391] acpiphp: Slot [14-3] registered
          [    0.363406] acpiphp: Slot [15-3] registered
          [    0.363420] acpiphp: Slot [16-3] registered
          [    0.363435] acpiphp: Slot [17-3] registered
          [    0.363452] acpiphp: Slot [18-3] registered
          [    0.363467] acpiphp: Slot [19-3] registered
          [    0.363482] acpiphp: Slot [20-3] registered
          [    0.363500] acpiphp: Slot [21-3] registered
          [    0.363515] acpiphp: Slot [22-3] registered
          [    0.363530] acpiphp: Slot [23-3] registered
          [    0.363547] acpiphp: Slot [24-3] registered
          [    0.363562] acpiphp: Slot [25-3] registered
          [    0.363578] acpiphp: Slot [26-3] registered
          [    0.363593] acpiphp: Slot [28-3] registered
          [    0.363608] acpiphp: Slot [29-3] registered
          [    0.363623] acpiphp: Slot [30-2] registered
          [    0.363638] acpiphp: Slot [31-2] registered
          [    0.363882] pci 0000:02:1b.0: [1b36:000d] type 00 class 0x0c0330
          [    0.364345] pci 0000:02:1b.0: reg 0x10: [mem 0xfe600000-0xfe603fff 64bit]
          [    0.366749] pci 0000:00:1e.0: PCI bridge to [bus 02]
          [    0.366767] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
          [    0.366783] pci 0000:00:1e.0:   bridge window [mem 0xfe600000-0xfe7fffff]
          [    0.366811] pci 0000:00:1e.0:   bridge window [mem 0xfd200000-0xfd3fffff 64bit pref]
          [    0.368655] pci_bus 0000:03: extended config space not accessible
          [    0.368889] acpiphp: Slot [0-3] registered
          [    0.368912] acpiphp: Slot [1-4] registered
          [    0.368928] acpiphp: Slot [2-3] registered
          [    0.368951] acpiphp: Slot [3-4] registered
          [    0.368972] acpiphp: Slot [4-4] registered
          [    0.368996] acpiphp: Slot [5-3] registered
          [    0.369028] acpiphp: Slot [6-4] registered
          [    0.369058] acpiphp: Slot [7-4] registered
          [    0.369095] acpiphp: Slot [8-4] registered
          [    0.369126] acpiphp: Slot [9-4] registered
          [    0.369149] acpiphp: Slot [10-4] registered
          [    0.369168] acpiphp: Slot [11-4] registered
          [    0.369187] acpiphp: Slot [12-4] registered
          [    0.369208] acpiphp: Slot [13-4] registered
          [    0.369227] acpiphp: Slot [14-4] registered
          [    0.369246] acpiphp: Slot [15-4] registered
          [    0.369266] acpiphp: Slot [16-4] registered
          [    0.369286] acpiphp: Slot [17-4] registered
          [    0.369309] acpiphp: Slot [18-4] registered
          [    0.369331] acpiphp: Slot [19-4] registered
          [    0.369350] acpiphp: Slot [20-4] registered
          [    0.369370] acpiphp: Slot [21-4] registered
          [    0.369391] acpiphp: Slot [22-4] registered
          [    0.369410] acpiphp: Slot [23-4] registered
          [    0.369429] acpiphp: Slot [24-4] registered
          [    0.369448] acpiphp: Slot [25-4] registered
          [    0.369466] acpiphp: Slot [26-4] registered
          [    0.369485] acpiphp: Slot [27-4] registered
          [    0.369504] acpiphp: Slot [28-4] registered
          [    0.369528] acpiphp: Slot [29-4] registered
          [    0.369547] acpiphp: Slot [30-3] registered
          [    0.369566] acpiphp: Slot [31-3] registered
          [    0.369807] pci 0000:00:1f.0: PCI bridge to [bus 03]
          [    0.369824] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
          [    0.369841] pci 0000:00:1f.0:   bridge window [mem 0xfe400000-0xfe5fffff]
          [    0.369880] pci 0000:00:1f.0:   bridge window [mem 0xfd000000-0xfd1fffff 64bit pref]
          [    0.372063] ACPI: PCI: Interrupt link LNKA configured for IRQ 10
          [    0.372184] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
          [    0.372289] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
          [    0.372397] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
          [    0.372463] ACPI: PCI: Interrupt link LNKS configured for IRQ 9
          [    0.372937] iommu: Default domain type: Translated
          [    0.372937] iommu: DMA domain TLB invalidation policy: lazy mode
          [    0.372937] pps_core: LinuxPPS API ver. 1 registered
          [    0.372937] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
          [    0.372937] PTP clock support registered
          [    0.372937] EDAC MC: Ver: 3.0.0
          [    0.375431] NetLabel: Initializing
          [    0.375432] NetLabel:  domain hash size = 128
          [    0.375433] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
          [    0.375471] NetLabel:  unlabeled traffic allowed by default
          [    0.375472] PCI: Using ACPI for IRQ routing
          [    0.375474] PCI: pci_cache_line_size set to 64 bytes
          [    0.375704] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
          [    0.375707] e820: reserve RAM buffer [mem 0xbffda000-0xbfffffff]
          [    0.375730] pci 0000:00:02.0: vgaarb: setting as boot VGA device
          [    0.375730] pci 0000:00:02.0: vgaarb: bridge control possible
          [    0.375730] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
          [    0.375730] vgaarb: loaded
          [    0.375859] hpet: 3 channels of 0 reserved for per-cpu timers
          [    0.375874] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
          [    0.375878] hpet0: 3 comparators, 64-bit 100.000000 MHz counter
          [    0.379165] clocksource: Switched to clocksource kvm-clock
          [    0.387497] VFS: Disk quotas dquot_6.6.0
          [    0.387512] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
          [    0.387636] AppArmor: AppArmor Filesystem Enabled
          [    0.387651] pnp: PnP ACPI init
          [    0.387743] pnp 00:02: [dma 2]
          [    0.387955] pnp: PnP ACPI: found 4 devices
          [    0.395485] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
          [    0.395611] NET: Registered PF_INET protocol family
          [    0.395997] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
          [    0.399804] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
          [    0.399833] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
          [    0.399901] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
          [    0.400341] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
          [    0.400572] TCP: Hash tables configured (established 131072 bind 65536)
          [    0.400895] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
          [    0.400960] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
          [    0.401021] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
          [    0.401103] NET: Registered PF_UNIX/PF_LOCAL protocol family
          [    0.401116] NET: Registered PF_XDP protocol family
          [    0.401138] pci 0000:00:05.0: PCI bridge to [bus 01]
          [    0.401184] pci 0000:00:05.0:   bridge window [io  0xe000-0xefff]
          [    0.402079] pci 0000:00:05.0:   bridge window [mem 0xfe800000-0xfe9fffff]
          [    0.402555] pci 0000:00:05.0:   bridge window [mem 0xfd400000-0xfd5fffff 64bit pref]
          [    0.403561] pci 0000:00:1e.0: PCI bridge to [bus 02]
          [    0.403618] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
          [    0.404326] pci 0000:00:1e.0:   bridge window [mem 0xfe600000-0xfe7fffff]
          [    0.404847] pci 0000:00:1e.0:   bridge window [mem 0xfd200000-0xfd3fffff 64bit pref]
          [    0.405865] pci 0000:00:1f.0: PCI bridge to [bus 03]
          [    0.406197] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
          [    0.406889] pci 0000:00:1f.0:   bridge window [mem 0xfe400000-0xfe5fffff]
          [    0.407373] pci 0000:00:1f.0:   bridge window [mem 0xfd000000-0xfd1fffff 64bit pref]
          [    0.408136] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
          [    0.408139] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
          [    0.408140] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
          [    0.408141] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xfebfffff window]
          [    0.408142] pci_bus 0000:00: resource 8 [mem 0x440000000-0x4bfffffff window]
          [    0.408144] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
          [    0.408145] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe9fffff]
          [    0.408146] pci_bus 0000:01: resource 2 [mem 0xfd400000-0xfd5fffff 64bit pref]
          [    0.408148] pci_bus 0000:02: resource 0 [io  0xd000-0xdfff]
          [    0.408157] pci_bus 0000:02: resource 1 [mem 0xfe600000-0xfe7fffff]
          [    0.408158] pci_bus 0000:02: resource 2 [mem 0xfd200000-0xfd3fffff 64bit pref]
          [    0.408159] pci_bus 0000:03: resource 0 [io  0xc000-0xcfff]
          [    0.408159] pci_bus 0000:03: resource 1 [mem 0xfe400000-0xfe5fffff]
          [    0.408160] pci_bus 0000:03: resource 2 [mem 0xfd000000-0xfd1fffff 64bit pref]
          [    0.408368] pci 0000:00:01.0: PIIX3: Enabling Passive Release
          [    0.408396] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
          [    0.427766] ACPI: \_SB_.LNKD: Enabled at IRQ 11
          [    0.443426] pci 0000:00:01.2: quirk_usb_early_handoff+0x0/0x750 took 34135 usecs
          [    0.457985] ACPI: \_SB_.LNKB: Enabled at IRQ 10
          [    0.474115] ACPI: \_SB_.LNKA: Enabled at IRQ 10
          [    0.490455] pci 0000:02:1b.0: quirk_usb_early_handoff+0x0/0x750 took 45816 usecs
          [    0.490493] PCI: CLS 0 bytes, default 64
          [    0.490572] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
          [    0.490573] software IO TLB: mapped [mem 0x00000000bbfda000-0x00000000bffda000] (64MB)
          [    0.490619] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b3e43c8763, max_idle_ns: 440795360101 ns
          [    0.490729] Trying to unpack rootfs image as initramfs...
          [    0.491184] Initialise system trusted keyrings
          [    0.491214] Key type blacklist registered
          [    0.491521] workingset: timestamp_bits=36 max_order=22 bucket_order=0
          [    0.493302] zbud: loaded
          [    0.494194] integrity: Platform Keyring initialized
          [    0.494203] integrity: Machine keyring initialized
          [    0.494205] Key type asymmetric registered
          [    0.494212] Asymmetric key parser 'x509' registered
          [    0.751606] Freeing initrd memory: 38392K
          [    0.757062] alg: self-tests for CTR-KDF (hmac(sha256)) passed
          [    0.757091] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
          [    0.757177] io scheduler mq-deadline registered
          [    0.758043] shpchp 0000:00:05.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.S28_)
          [    0.758049] shpchp 0000:00:05.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
          [    0.758055] shpchp 0000:00:05.0: Cannot get control of SHPC hotplug
          [    0.758109] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.SF0_)
          [    0.758113] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
          [    0.758115] shpchp 0000:00:1e.0: Cannot get control of SHPC hotplug
          [    0.758158] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.SF8_)
          [    0.758161] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
          [    0.758163] shpchp 0000:00:1f.0: Cannot get control of SHPC hotplug
          [    0.758170] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
          [    0.758536] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
          [    0.759230] Linux agpgart interface v0.103
          [    0.759320] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
          [    0.759716] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
          [    0.760553] serio: i8042 KBD port at 0x60,0x64 irq 1
          [    0.760560] serio: i8042 AUX port at 0x60,0x64 irq 12
          [    0.760682] mousedev: PS/2 mouse device common for all mice
          [    0.760703] rtc_cmos 00:03: RTC can wake from S4
          [    0.761478] rtc_cmos 00:03: registered as rtc0
          [    0.761606] rtc_cmos 00:03: setting system clock to 2025-02-15T07:54:09 UTC (1739606049)
          [    0.761750] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
          [    0.761765] rtc_cmos 00:03: alarms up to one day, y3k, 242 bytes nvram, hpet irqs
          [    0.761776] intel_pstate: CPU model not supported
          [    0.762111] ledtrig-cpu: registered to indicate activity on CPUs
          [    0.772716] NET: Registered PF_INET6 protocol family
          [    0.777466] Segment Routing with IPv6
          [    0.777484] In-situ OAM (IOAM) with IPv6
          [    0.777575] mip6: Mobile IPv6
          [    0.777584] NET: Registered PF_PACKET protocol family
          [    0.777693] mpls_gso: MPLS GSO support
          [    0.778028] IPI shorthand broadcast: enabled
          [    0.778046] sched_clock: Marking stable (764457814, 13494714)->(779962800, -2010272)
          [    0.778261] registered taskstats version 1
          [    0.778268] Loading compiled-in X.509 certificates
          [    0.791980] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
          [    0.792004] Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f'
          [    0.792411] zswap: loaded using pool lzo/zbud
          [    0.792779] Key type .fscrypt registered
          [    0.792781] Key type fscrypt-provisioning registered
          [    0.797455] Key type encrypted registered
          [    0.797460] AppArmor: AppArmor sha1 policy hashing enabled
          [    0.797473] ima: No TPM chip found, activating TPM-bypass!
          [    0.797475] ima: Allocated hash algorithm: sha256
          [    0.797488] ima: No architecture policies found
          [    0.797522] evm: Initialising EVM extended attributes:
          [    0.797523] evm: security.selinux
          [    0.797525] evm: security.SMACK64 (disabled)
          [    0.797526] evm: security.SMACK64EXEC (disabled)
          [    0.797527] evm: security.SMACK64TRANSMUTE (disabled)
          [    0.797527] evm: security.SMACK64MMAP (disabled)
          [    0.797528] evm: security.apparmor
          [    0.797529] evm: security.ima
          [    0.797530] evm: security.capability
          [    0.797530] evm: HMAC attrs: 0x1
          [    0.868352] clk: Disabling unused clocks
          [    0.869384] Freeing unused decrypted memory: 2036K
          [    0.869752] Freeing unused kernel image (initmem) memory: 2796K
          [    0.869813] Write protecting the kernel read-only data: 26624k
          [    0.871234] Freeing unused kernel image (text/rodata gap) memory: 2040K
          [    0.871513] Freeing unused kernel image (rodata/data gap) memory: 1156K
          [    0.916635] x86/mm: Checked W+X mappings: passed, no W+X pages found.
          [    0.916677] x86/mm: Checking user space page tables
          [    0.962237] x86/mm: Checked W+X mappings: passed, no W+X pages found.
          [    0.962245] Run /init as init process
          [    0.962254]   with arguments:
          [    0.962256]     /init
          [    0.962256]   with environment:
          [    0.962257]     HOME=/
          [    0.962257]     TERM=linux
          [    0.962258]     BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-amd64
          [    1.087798] piix4_smbus 0000:00:01.3: SMBus Host Controller at 0x700, revision 0
          [    1.093928] FDC 0 is a S82078B
          [    1.096955] SCSI subsystem initialized
          [    1.132836] ACPI: bus type USB registered
          [    1.132868] usbcore: registered new interface driver usbfs
          [    1.132876] usbcore: registered new interface driver hub
          [    1.132888] usbcore: registered new device driver usb
          [    1.146313] libata version 3.00 loaded.
          [    1.146660] ACPI: bus type drm_connector registered
          [    1.175371] uhci_hcd 0000:00:01.2: UHCI Host Controller
          [    1.175401] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
          [    1.175423] uhci_hcd 0000:00:01.2: detected 2 ports
          [    1.175724] uhci_hcd 0000:00:01.2: irq 11, io port 0x0000f080
          [    1.176000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
          [    1.176004] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [    1.176006] usb usb1: Product: UHCI Host Controller
          [    1.176007] usb usb1: Manufacturer: Linux 6.1.0-30-amd64 uhci_hcd
          [    1.176009] usb usb1: SerialNumber: 0000:00:01.2
          [    1.176215] hub 1-0:1.0: USB hub found
          [    1.176221] hub 1-0:1.0: 2 ports detected
          [    1.178108] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input3
          [    1.178390] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input2
          [    1.179683] ata_piix 0000:00:01.1: version 2.13
          [    1.181702] bochs-drm 0000:00:02.0: vgaarb: deactivate vga console
          [    1.184692] Console: switching to colour dummy device 80x25
          [    1.195412] [drm] Found bochs VGA, ID 0xb0c5.
          [    1.195415] [drm] Framebuffer size 16384 kB @ 0xfc000000, mmio @ 0xfea50000.
          [    1.195657] scsi host0: ata_piix
          [    1.196014] scsi host1: ata_piix
          [    1.196055] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xf0c0 irq 14
          [    1.196057] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xf0c8 irq 15
          [    1.197185] [drm] Found EDID data blob.
          [    1.197301] [drm] Initialized bochs-drm 1.0.0 20130925 for 0000:00:02.0 on minor 0
          [    1.198407] fbcon: bochs-drmdrmfb (fb0) is primary device
          [    1.201846] Console: switching to colour frame buffer device 160x50
          [    1.203490] bochs-drm 0000:00:02.0: [drm] fb0: bochs-drmdrmfb frame buffer device
          [    1.213303] ACPI: \_SB_.LNKC: Enabled at IRQ 11
          [    1.214017] xhci_hcd 0000:02:1b.0: xHCI Host Controller
          [    1.214031] xhci_hcd 0000:02:1b.0: new USB bus registered, assigned bus number 2
          [    1.214521] xhci_hcd 0000:02:1b.0: hcc params 0x00087001 hci version 0x100 quirks 0x0000000000000010
          [    1.216125] xhci_hcd 0000:02:1b.0: xHCI Host Controller
          [    1.216133] xhci_hcd 0000:02:1b.0: new USB bus registered, assigned bus number 3
          [    1.216138] xhci_hcd 0000:02:1b.0: Host supports USB 3.0 SuperSpeed
          [    1.216220] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
          [    1.216223] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [    1.216225] usb usb2: Product: xHCI Host Controller
          [    1.216227] usb usb2: Manufacturer: Linux 6.1.0-30-amd64 xhci-hcd
          [    1.216228] usb usb2: SerialNumber: 0000:02:1b.0
          [    1.216369] hub 2-0:1.0: USB hub found
          [    1.216478] hub 2-0:1.0: 15 ports detected
          [    1.217224] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
          [    1.217245] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
          [    1.217247] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [    1.217249] usb usb3: Product: xHCI Host Controller
          [    1.217250] usb usb3: Manufacturer: Linux 6.1.0-30-amd64 xhci-hcd
          [    1.217252] usb usb3: SerialNumber: 0000:02:1b.0
          [    1.217372] hub 3-0:1.0: USB hub found
          [    1.217470] hub 3-0:1.0: 15 ports detected
          [    1.586455] ata2: found unknown device (class 0)
          [    1.587417] ata2.00: ATAPI: QEMU DVD-ROM, 2.5+, max UDMA/100
          [    1.588809] scsi 1:0:0:0: CD-ROM            QEMU     QEMU DVD-ROM     2.5+ PQ: 0 ANSI: 5
          [    1.645618] usb 1-1: new full-speed USB device number 2 using uhci_hcd
          [    1.665884] scsi host2: Virtio SCSI HBA
          [    1.666949] scsi 2:0:0:0: Direct-Access     QEMU     QEMU HARDDISK    2.5+ PQ: 0 ANSI: 5
          [    1.684572] sr 1:0:0:0: [sr0] scsi3-mmc drive: 4x/4x cd/rw xa/form2 tray
          [    1.684581] cdrom: Uniform CD-ROM driver Revision: 3.20
          [    1.713629] usb 2-1: new full-speed USB device number 2 using xhci_hcd
          [    1.713693] virtio_net virtio2 ens18: renamed from eth0
          [    1.746632] sr 1:0:0:0: Attached scsi CD-ROM sr0
          [    1.758654] sd 2:0:0:0: Power-on or device reset occurred
          [    1.758786] sd 2:0:0:0: [sda] 83886080 512-byte logical blocks: (42.9 GB/40.0 GiB)
          [    1.758826] sd 2:0:0:0: [sda] Write Protect is off
          [    1.758828] sd 2:0:0:0: [sda] Mode Sense: 63 00 00 08
          [    1.758889] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
          [    1.761230]  sda: sda1 sda2 < sda5 >
          [    1.761488] sd 2:0:0:0: [sda] Attached SCSI disk
          [    1.806559] usb 1-1: not running at top speed; connect to a high speed hub
          [    1.840379] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
          [    1.840385] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
          [    1.840387] usb 1-1: Product: QEMU USB Tablet
          [    1.840389] usb 1-1: Manufacturer: QEMU
          [    1.840390] usb 1-1: SerialNumber: 28754-0000:00:01.2-1
          [    1.850201] hid: raw HID events driver (C) Jiri Kosina
          [    1.855850] usbcore: registered new interface driver usbhid
          [    1.855853] usbhid: USB HID core driver
          [    1.857706] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:01.2/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input4
          [    1.857920] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:01.2-1/input0
          [    1.869020] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
          [    1.869024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [    1.869026] usb 2-1: Product: Sonoff Zigbee 3.0 USB Dongle Plus
          [    1.869027] usb 2-1: Manufacturer: Silicon Labs
          [    1.869028] usb 2-1: SerialNumber: 0001
          [    1.926293] PM: Image not found (code -22)
          [    2.070625] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [    2.117299] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
          [    2.166113] systemd[1]: Inserted module 'autofs4'
          [    2.184221] systemd[1]: systemd 252.33-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
          [    2.184227] systemd[1]: Detected virtualization kvm.
          [    2.184231] systemd[1]: Detected architecture x86-64.
          [    2.185854] systemd[1]: Hostname set to <iobroker>.
          [    2.370152] systemd[1]: Queued start job for default target multi-user.target.
          [    2.386544] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
          [    2.386860] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
          [    2.387132] systemd[1]: Created slice user.slice - User and Session Slice.
          [    2.387216] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
          [    2.387288] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
          [    2.387503] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
          [    2.387528] systemd[1]: Expecting device dev-disk-by\x2duuid-3fa31c5f\x2d0f90\x2d49c4\x2dadef\x2dfcadb0a838fa.device - /dev/disk/by-uuid/3fa31c5f-0f90-49c4-adef-fcadb0a838fa...
          [    2.387543] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
          [    2.387560] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
          [    2.387585] systemd[1]: Reached target paths.target - Path Units.
          [    2.387609] systemd[1]: Reached target slices.target - Slice Units.
          [    2.387633] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
          [    2.391335] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
          [    2.391626] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
          [    2.391736] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
          [    2.392183] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
          [    2.392334] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
          [    2.392487] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
          [    2.393071] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
          [    2.393199] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
          [    2.394224] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
          [    2.395412] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
          [    2.396725] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
          [    2.398250] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
          [    2.398354] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
          [    2.399669] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
          [    2.400971] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
          [    2.402416] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
          [    2.403840] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
          [    2.405380] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
          [    2.406964] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
          [    2.408334] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
          [    2.409896] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
          [    2.410032] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
          [    2.412278] systemd[1]: Starting systemd-journald.service - Journal Service...
          [    2.417451] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
          [    2.418582] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
          [    2.419778] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
          [    2.423214] loop: module loaded
          [    2.424981] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
          [    2.425013] device-mapper: uevent: version 1.0.3
          [    2.425121] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
          [    2.425235] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
          [    2.425390] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
          [    2.425662] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
          [    2.425863] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
          [    2.426206] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
          [    2.426645] systemd[1]: modprobe@configfs.service: Deactivated successfully.
          [    2.426857] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
          [    2.427310] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
          [    2.427492] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
          [    2.427883] systemd[1]: modprobe@drm.service: Deactivated successfully.
          [    2.428079] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
          [    2.428730] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
          [    2.429509] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
          [    2.430121] systemd[1]: modprobe@loop.service: Deactivated successfully.
          [    2.430332] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
          [    2.432343] fuse: init (API version 7.38)
          [    2.435075] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
          [    2.435286] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
          [    2.435926] systemd[1]: modprobe@fuse.service: Deactivated successfully.
          [    2.436176] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
          [    2.438059] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
          [    2.439296] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
          [    2.440159] EXT4-fs (sda1): re-mounted. Quota mode: none.
          [    2.443270] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
          [    2.443833] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
          [    2.444123] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
          [    2.444276] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
          [    2.444357] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
          [    2.445633] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
          [    2.446855] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
          [    2.448118] systemd[1]: Starting systemd-sysusers.service - Create System Users...
          [    2.471236] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
          [    2.485259] systemd[1]: Finished systemd-sysusers.service - Create System Users.
          [    2.487170] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
          [    2.492907] systemd[1]: Started systemd-journald.service - Journal Service.
          [    2.510452] systemd-journald[250]: Received client request to flush runtime journal.
          [    2.659651] audit: type=1400 audit(1739606051.392:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=317 comm="apparmor_parser"
          [    2.659657] audit: type=1400 audit(1739606051.392:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=317 comm="apparmor_parser"
          [    2.664298] audit: type=1400 audit(1739606051.396:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=320 comm="apparmor_parser"
          [    2.664305] audit: type=1400 audit(1739606051.396:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=320 comm="apparmor_parser"
          [    2.664307] audit: type=1400 audit(1739606051.396:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=320 comm="apparmor_parser"
          [    2.739911] sr 1:0:0:0: Attached scsi generic sg0 type 5
          [    2.739937] audit: type=1400 audit(1739606051.472:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=316 comm="apparmor_parser"
          [    2.740786] sd 2:0:0:0: Attached scsi generic sg1 type 0
          [    2.753237] audit: type=1400 audit(1739606051.484:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=319 comm="apparmor_parser"
          [    2.753243] audit: type=1400 audit(1739606051.484:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=319 comm="apparmor_parser"
          [    2.753246] audit: type=1400 audit(1739606051.484:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=319 comm="apparmor_parser"
          [    2.828160] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
          [    2.849727] ACPI: button: Power Button [PWRF]
          [    2.869094] Free page reporting enabled
          [    2.875218] input: PC Speaker as /devices/platform/pcspkr/input/input6
          [    2.925086] usbcore: registered new interface driver usbserial_generic
          [    2.925100] usbserial: USB Serial support registered for generic
          [    2.952656] usbcore: registered new interface driver cp210x
          [    2.952671] usbserial: USB Serial support registered for cp210x
          [    2.952760] cp210x 2-1:1.0: cp210x converter detected
          [    2.960137] Adding 998396k swap on /dev/sda5.  Priority:-2 extents:1 across:998396k FS
          [    2.961777] usb 2-1: cp210x converter now attached to ttyUSB0
          [    2.965891] cryptd: max_cpu_qlen set to 1000
          [    3.005439] SSE version of gcm_enc/dec engaged.
          [    3.433518] random: crng init done
          [    3.505324] RPC: Registered named UNIX socket transport module.
          [    3.505327] RPC: Registered udp transport module.
          [    3.505328] RPC: Registered tcp transport module.
          [    3.505329] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [  147.473410] usb 2-1: USB disconnect, device number 2
          [  147.473647] cp210x ttyUSB0: failed set request 0x7 status: -19
          [  147.473683] cp210x ttyUSB0: failed set request 0x12 status: -19
          [  147.473694] cp210x ttyUSB0: failed set request 0x0 status: -19
          [  147.475966] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
          [  147.475982] cp210x 2-1:1.0: device disconnected
          [  147.992398] usb 2-1: new full-speed USB device number 3 using xhci_hcd
          [  148.142653] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
          [  148.142658] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [  148.142659] usb 2-1: Product: Sonoff Zigbee 3.0 USB Dongle Plus
          [  148.142660] usb 2-1: Manufacturer: Silicon Labs
          [  148.142662] usb 2-1: SerialNumber: 0001
          [  148.143292] usb 2-1: can't set config #1, error -32
          [11507.277732] usb 2-1: USB disconnect, device number 3
          [11517.758624] usb 2-1: new full-speed USB device number 4 using xhci_hcd
          [11517.909063] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
          [11517.909067] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [11517.909068] usb 2-1: Product: Sonoff Zigbee 3.0 USB Dongle Plus
          [11517.909069] usb 2-1: Manufacturer: Silicon Labs
          [11517.909070] usb 2-1: SerialNumber: 0001
          [11517.910370] cp210x 2-1:1.0: cp210x converter detected
          [11517.913438] usb 2-1: cp210x converter now attached to ttyUSB0
          [173398.417895] show_signal_msg: 1 callbacks suppressed
          [173398.417902] apt[25770]: segfault at 7fe23931be08 ip 00007fe23e6b7eca sp 00007ffcd8822c00 error 4 in libc.so.6[7fe23e645000+155000] likely on CPU 3 (core 3, socket 0)
          [173398.417914] Code: dc 2c 10 00 e8 27 63 fe ff 0f 1f 80 00 00 00 00 48 85 ff 0f 84 bf 00 00 00 55 48 8d 77 f0 53 48 83 ec 18 48 8b 1d 16 8f 13 00 <48> 8b 47 f8 64 8b 2b a8 02 75 5b 48 8b 15 9c 8e 13 00 64 48 83 3a
          [180105.147372] traps: node[29654] trap int3 ip:2197c92 sp:7f58af21bc20 error:0 in node[b82000+1abe000]
          [682690.774115] traps: node[65308] trap invalid opcode ip:2197c92 sp:7f4869d3b5f0 error:0 in node[b82000+1abe000]
          JLegJ 1 Antwort Letzte Antwort
          • M matrose65
            Hallo zusammen
            Ich muss mich leider wieder mal melden. Ich habe immer noch das Problem, das IOB einfach abschmiert.
            Ich kann leider nicht feststellen an was es liegt. Auch sind die Zeiten wann es passiert unterschiedlich.
            Ich habe alles neu installiert und dann ein Backup zurückgespielt. Aber keine Änderung
            Ich habe alles neu installiert und alle Adapter selbst eingerichtet. Keine Änderung
            Ich habe die SSD getauscht, Proxmox neu aufgesetzt. Wieder das selbe Spiel.
            Der ganze Vorgang dauert ca. 3 min dann ist alles wieder in Ordnung.
            Ehrlich ich weiß nicht was ich noch machen soll.
            Ich habe sogar schon mit dem Gedanken gespielt, zu HomeAutomation zu wechseln, aber da komme ich mit dem Dashbord nicht zurecht und auch die Scripte fehlen.
            • Adaptername: alle
            • Link zu Adapterrepository: www.github.com...
            • Adapterversion: ...
            • js-controller Version: 7.0.6
            • Admin Version: 7.4.10
            • Hardwaresystem: NUC, und Proxmox
            • Arbeitsspeicher: 16GB
            • Festplattenart: SSD
            • Betriebssystem: Linux 12
            • Nodejs-Version: 20.18.3
            • NPM-Version: 10.8.2.
            • Installationsart: Manuell
            • Image, Docker genutzt:
            • Ort, Name der Imagedatei: ...
            Linux User bitte hier den Output von iob diag einfügen.
            ```bash
            Script v.2025-02-23
            *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer-vm
                     Chassis: vm 🖴
              Virtualization: kvm
                      Kernel: Linux 6.1.0-30-amd64
                Architecture: x86-64
             Hardware Vendor: QEMU
              Hardware Model: Standard PC _i440FX + PIIX, 1996_
            Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
            OS is similar to:
            model name      : QEMU Virtual CPU version 2.5+
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             17:31:01 up 9 days,  8:36,  2 users,  load average: 0.15, 0.11, 0.07
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** TIME AND TIMEZONES ***
                           Local time: Mon 2025-02-24 17:31:01 CET
                       Universal time: Mon 2025-02-24 16:31:01 UTC
                             RTC time: Mon 2025-02-24 16:31:01
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            uwe
            HOME=/home/uwe
            GROUPS=uwe cdrom floppy sudo audio dip video plugdev users netdev iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:             16G        2.2G         12G        557K        2.4G         14G
            Swap:           1.0G          0B        1.0G
            Total:           17G        2.2G         13G
            Active iob-Instances:   21
                    15992 M total memory
                     2112 M used memory
                      868 M active memory
                     2779 M inactive memory
                    11943 M free memory
                      337 M buffer memory
                     1930 M swap cache
                      974 M total swap
                        0 M used swap
                      974 M free swap
            top - 17:31:01 up 9 days,  8:36,  2 users,  load average: 0.15, 0.11, 0.07
            Tasks: 126 total,   1 running, 125 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  15992.7 total,  11943.0 free,   2112.0 used,   2267.7 buff/cache
            MiB Swap:    975.0 total,    975.0 free,      0.0 used.  13880.7 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs  7.8G     0  7.8G   0% /dev
            tmpfs          tmpfs     1.6G  552K  1.6G   1% /run
            /dev/sda1      ext4       39G  7.1G   30G  20% /
            tmpfs          tmpfs     7.9G     0  7.9G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
            [Sat Feb 15 08:54:11 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
            [Sat Feb 15 08:54:11 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET SOURCE    FSTYPE OPTIONS
            /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
            /var:
            466M    /var/
            251M    /var/cache
            244M    /var/cache/apt
            176M    /var/lib
            167M    /var/cache/apt/archives
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            135M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.4G    /opt/iobroker/iobroker-data/
            1.2G    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
            24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
            19M     /opt/iobroker/iobroker-data/objects.jsonl
            19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
            *** ZigBee Settings ***
            Your zigbee.0 COM-Port is matching 'by-id'. Very good!
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.3
            /usr/bin/node           v20.18.3
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.30.0
            nodejs:
              Installed: 20.18.3-1nodesource1
              Candidate: 20.18.3-1nodesource1
              Version table:
             *** 20.18.3-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                 20.18.2-1nodesource1 1001
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 3062)
            Core adapters versions
            admin:          7.4.10
            javascript:     8.8.3
            nodejs modules from github:     0
            Adapter State
            + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.1.13, run as: admin
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              system.adapter.devices.0                : devices               : iobroker                                 - disabled
              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
              system.adapter.history.0                : history               : iobroker                                 - disabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
              system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
            + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
            + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.2                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
              system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
              system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
              system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
            + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
            + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
            Adapter    "admin"        : 7.4.10   , installed 7.4.10
            Adapter    "backitup"     : 3.0.31   , installed 3.0.31
            Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
            Adapter    "devices"      : 1.1.5    , installed 1.1.5
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "ical"         : 1.16.1   , installed 1.16.1
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
            Adapter    "roborock"     : 0.6.18   , installed 0.6.18
            Adapter    "scenes"       : 3.2.3    , installed 3.2.3
            Adapter    "shelly"       : 8.5.1    , installed 8.5.1
            Adapter    "sonos"        : 3.0.0    , installed 3.0.0
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
            Adapter    "vis-2"        : 2.9.64   , installed 2.11.2
            Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
            Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
            Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
            Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
            Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
            Adapter    "weather-warnings": 0.7.3 , installed 0.7.3
            Adapter    "web"          : 6.2.5    , installed 6.3.0
            Adapter    "wled"         : 0.7.2    , installed 0.7.2
            Adapter    "worx"         : 3.1.1    , installed 3.1.1
            Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
            Objects and States
            Objects:        7267
            States:         6407
            Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7668262    74191/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7668798    74191/iobroker.js-c
            tcp        0      0 192.168.1.13:8081       0.0.0.0:*               LISTEN      1001       7669885    74301/io.admin.0
            tcp        0      0 192.168.1.13:2001       0.0.0.0:*               LISTEN      1001       7671222    74594/io.hm-rpc.0
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5783698    58804/sshd: /usr/sb
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          110        1/init
            tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       7670244    74680/io.mqtt.0
            tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1001       7670245    74680/io.mqtt.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       7674892    74950/io.shelly.1
            tcp6       0      0 :::6824                 :::*                    LISTEN      1001       7673714    74983/io.roborock.0
            tcp6       0      0 :::7906                 :::*                    LISTEN      1001       7673715    74983/io.roborock.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       7670479    74904/io.web.0
            tcp6       0      0 :::3000                 :::*                    LISTEN      1001       7672102    74874/io.fullybrows
            tcp6       0      0 :::3500                 :::*                    LISTEN      1001       7670342    74765/io.sonos.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          5783700    58804/sshd: /usr/sb
            tcp6       0      0 :::111                  :::*                    LISTEN      0          111        1/init
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       7670494    74919/io.wled.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       7671338    74739/io.shelly.2
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2348       1/init
            udp6       0      0 :::111                  :::*                                0          1662       1/init
            2025-02-24 17:12:17.426  - info: host.iobroker instance system.adapter.netatmo-crawler.0 having pid 75055 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-02-24 17:13:45.711  - info: web.0 (74904) <== Disconnect system.user.admin from ::ffff:192.168.1.144 vis-2
            2025-02-24 17:14:46.012  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 75071
            2025-02-24 17:14:46.880  - info: dwd.0 (75071) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 17:14:47.333  - info: dwd.0 (75071) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-02-24 17:14:47.847  - info: host.iobroker instance system.adapter.dwd.0 having pid 75071 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-02-24 17:20:56.643  - error: accuweather.0 (74515) Error: Forecast cannot be retrieved. ERROR: Status:none SyntaxError: Unexpected template string
            2025-02-24 17:20:56.643  - info: accuweather.0 (74515) Retry in 10 Minutes
            2025-02-24 17:27:36.203  - info: host.iobroker stopInstance system.adapter.accuweather.0 (force=false, process=true)
            2025-02-24 17:27:36.205  - info: accuweather.0 (74515) Got terminate signal TERMINATE_YOURSELF
            2025-02-24 17:27:36.206  - info: accuweather.0 (74515) cleaned everything up...
            2025-02-24 17:27:36.206  - info: accuweather.0 (74515) terminating
            2025-02-24 17:27:36.206  - info: accuweather.0 (74515) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-02-24 17:27:36.246  - info: host.iobroker stopInstance system.adapter.accuweather.0 send kill signal
            2025-02-24 17:27:36.707  - info: accuweather.0 (74515) terminating
            2025-02-24 17:27:36.740  - info: host.iobroker instance system.adapter.accuweather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-02-24 17:27:40.025  - info: host.iobroker instance system.adapter.accuweather.0 in version "2.1.0" started with pid 75094
            2025-02-24 17:27:40.772  - info: accuweather.0 (75094) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.accuweather, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 17:27:42.390  - info: accuweather.0 (75094) Update current weather!
            2025-02-24 17:30:00.003  - info: javascript.0 (74367) script.js.Heizung.FBH_Bad: 1
            2025-02-24 17:30:00.012  - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 75111
            2025-02-24 17:30:00.949  - info: ical.0 (75111) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 17:30:01.661  - info: ical.0 (75111) processing URL: Familie https://calendar.google.com/calendar/ical/3cf4jlif04jr6m92ahk0degosc%40group.calendar.google.com/private-45041f110be4e228cac90a1f44edc113/basic.ics
            2025-02-24 17:30:06.826  - info: ical.0 (75111) Terminated (NO_ERROR): Without reason
            2025-02-24 17:30:07.339  - info: host.iobroker instance system.adapter.ical.0 having pid 75111 terminated with code 0 (NO_ERROR)
            iob diag has finished.
            Hier noch einmal das Log von heute. Ich wollte die Adapter aufrufen, Dann war der Bildschirm grau und los ging es
            16:39 und um 16:44 Uhr war wieder alles gut
            2025-02-24 16:14:04.811 - info: host.iobroker instance system.adapter.dwd.0 having pid 74132 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-02-24 16:30:00.012 - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 74158
            2025-02-24 16:30:01.001 - info: ical.0 (74158) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:30:01.747 - info: ical.0 (74158) processing URL:
            2025-02-24 16:30:06.959 - info: ical.0 (74158) Terminated (NO_ERROR): Without reason
            2025-02-24 16:30:07.477 - info: host.iobroker instance system.adapter.ical.0 having pid 74158 terminated with code 0 (NO_ERROR)
            2025-02-24 16:37:44.364 - info: shelly.2 (73556) [CoAP] Device 192.168.1.155 (shellycolorbulb / shellycolorbulb-E8DB84AA2596 / SHCB-1#E8DB84AA2596#1) connected! Polltime set to 15 sec.
            2025-02-24 16:39:39.940 - info: wled.0 (73747) cleaned everything up...
            2025-02-24 16:39:39.939 - info: unifi.0 (73936) cleaned everything up...
            2025-02-24 16:39:39.942 - info: hm-rpc.0 (73411) xmlrpc -> 192.168.1.18:2001/ init ["http://192.168.1.13:2001",""]
            2025-02-24 16:39:39.943 - warn: web.0 (73732) setTimeout called, but adapter is shutting down
            2025-02-24 16:39:39.943 - info: backitup.0 (73280) cleaned everything up...
            2025-02-24 16:39:39.941 - info: javascript.0 (73193) Stopping script script.js.Arbeitszimmer.Roborock
            2025-02-24 16:39:39.938 - info: accuweather.0 (73332) cleaned everything up...
            2025-02-24 16:39:39.942 - info: sonos.0 (73582) terminating
            2025-02-24 16:39:39.945 - info: admin.0 (73132) terminating http server on port 8081
            2025-02-24 16:39:39.953 - info: zigbee.0 (73671) cleaned everything up...
            2025-02-24 16:39:39.946 - info: javascript.0 (73193) Stopping script script.js.Arbeitszimmer.Schalter
            2025-02-24 16:39:39.946 - info: javascript.0 (73193) Stopping script script.js.Bad.BWM
            2025-02-24 16:39:39.947 - info: javascript.0 (73193) Stopping script script.js.Bad.Schalter
            2025-02-24 16:39:39.947 - info: javascript.0 (73193) Stopping script script.js.Esszimmer.Remote
            2025-02-24 16:39:39.947 - info: javascript.0 (73193) Stopping script script.js.Heizung.FBH_Bad
            2025-02-24 16:39:39.948 - info: javascript.0 (73193) Stopping script script.js.Heizung.Heizung_AZ
            2025-02-24 16:39:39.948 - info: javascript.0 (73193) Stopping script script.js.Heizung.Heizung_Bad
            2025-02-24 16:39:39.948 - info: javascript.0 (73193) Stopping script script.js.Heizung.Heizung_EZ
            2025-02-24 16:39:39.948 - info: javascript.0 (73193) Stopping script script.js.Heizung.Heizung_Küche
            2025-02-24 16:39:39.948 - info: javascript.0 (73193) Stopping script script.js.Heizung.Heizung_WZ
            2025-02-24 16:39:39.949 - info: javascript.0 (73193) Stopping script script.js.Heizung.Heizung_Zeit
            2025-02-24 16:39:39.949 - info: javascript.0 (73193) Stopping script script.js.Küche.Licht_Arbeitsplatte
            2025-02-24 16:39:39.949 - info: javascript.0 (73193) Stopping script script.js.Küche.Remote_1
            2025-02-24 16:39:39.949 - info: javascript.0 (73193) Stopping script script.js.Küche.Tablet_BWM
            2025-02-24 16:39:39.949 - info: javascript.0 (73193) Stopping script script.js.Küche.Tablet_laden
            2025-02-24 16:39:39.950 - info: javascript.0 (73193) Stopping script script.js.Küche.VIS_zurück
            2025-02-24 16:39:39.951 - info: javascript.0 (73193) Stopping script script.js.Schlafzimmer.Remote
            2025-02-24 16:39:39.951 - info: javascript.0 (73193) Stopping script script.js.Schlafzimmer.Schalter
            2025-02-24 16:39:39.951 - info: javascript.0 (73193) Stopping script script.js.Wohnung.Anwesenheit
            2025-02-24 16:39:39.952 - info: javascript.0 (73193) Stopping script script.js.Wohnzimmer.Remote
            2025-02-24 16:39:39.952 - info: javascript.0 (73193) Stopping script script.js.common.NSPanel.NSPanel_1_4_4_0_7
            2025-02-24 16:39:39.957 - info: hm-rpc.0 (73411) Disconnected
            2025-02-24 16:39:39.954 - info: zigbee.0 (73671) Zigbee: disabling joining new devices.
            2025-02-24 16:39:41.439 - info: scenes.0 (73239) terminating with timeout
            2025-02-24 16:39:41.440 - info: tankerkoenig.0 (73702) terminating with timeout
            2025-02-24 16:39:41.440 - info: scenes.0 (73239) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.440 - info: hm-rega.0 (73385) terminating with timeout
            2025-02-24 16:39:41.441 - info: tankerkoenig.0 (73702) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.441 - info: hm-rega.0 (73385) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.443 - info: wled.0 (73747) terminating with timeout
            2025-02-24 16:39:41.443 - info: unifi.0 (73936) terminating with timeout
            2025-02-24 16:39:41.443 - info: wled.0 (73747) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.444 - info: unifi.0 (73936) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.445 - info: shelly.2 (73556) terminating with timeout
            2025-02-24 16:39:41.445 - info: fullybrowser.0 (73687) terminating with timeout
            2025-02-24 16:39:41.446 - info: web.0 (73732) terminating with timeout
            2025-02-24 16:39:41.446 - info: fullybrowser.0 (73687) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.446 - info: shelly.2 (73556) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.447 - info: accuweather.0 (73332) terminating with timeout
            2025-02-24 16:39:41.447 - info: web.0 (73732) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.447 - info: accuweather.0 (73332) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.446 - info: tr-064.0 (73634) terminating with timeout
            2025-02-24 16:39:41.448 - info: vis-2.0 (73717) terminating with timeout
            2025-02-24 16:39:41.449 - info: tr-064.0 (73634) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.449 - info: vis-2.0 (73717) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.450 - info: mqtt.0 (73502) terminating with timeout
            2025-02-24 16:39:41.450 - info: backitup.0 (73280) terminating with timeout
            2025-02-24 16:39:41.451 - info: mqtt.0 (73502) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.451 - info: admin.0 (73132) terminating with timeout
            2025-02-24 16:39:41.451 - info: backitup.0 (73280) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.452 - info: admin.0 (73132) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.453 - info: zigbee.0 (73671) terminating with timeout
            2025-02-24 16:39:41.452 - info: shelly.1 (73527) terminating with timeout
            2025-02-24 16:39:41.454 - info: zigbee.0 (73671) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.454 - info: shelly.1 (73527) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.458 - info: sonos.0 (73582) terminating with timeout
            2025-02-24 16:39:41.459 - info: sonos.0 (73582) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:41.947 - info: hm-rpc.0 (73411) terminating with timeout
            2025-02-24 16:39:41.947 - info: hm-rpc.0 (73411) Terminated (NO_ERROR): Without reason
            2025-02-24 16:39:44.930 - error: sonos.0 (73582) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.931 - warn: sonos.0 (73582) get state error: Connection is closed.
            2025-02-24 16:39:44.931 - warn: sonos.0 (73582) get state error: DB closed
            2025-02-24 16:39:44.932 - info: sonos.0 (73582) terminating
            2025-02-24 16:39:44.941 - error: tankerkoenig.0 (73702) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.942 - error: hm-rpc.0 (73411) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.937 - error: shelly.1 (73527) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.946 - error: mqtt.0 (73502) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.948 - error: admin.0 (73132) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.953 - error: scenes.0 (73239) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.953 - error: web.0 (73732) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.954 - error: accuweather.0 (73332) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.957 - warn: hm-rpc.0 (73411) get state error: DB closed
            2025-02-24 16:39:44.945 - warn: wled.0 (73747) get state error: Connection is closed.
            2025-02-24 16:39:44.960 - error: unifi.0 (73936) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.961 - warn: shelly.2 (73556) get state error: Connection is closed.
            2025-02-24 16:39:44.954 - error: hm-rega.0 (73385) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.936 - error: fullybrowser.0 (73687) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.960 - warn: wled.0 (73747) get state error: DB closed
            2025-02-24 16:39:44.960 - info: wled.0 (73747) terminating
            2025-02-24 16:39:44.961 - info: wled.0 (73747) terminating
            2025-02-24 16:39:44.965 - warn: fullybrowser.0 (73687) get state error: Connection is closed.
            2025-02-24 16:39:44.940 - error: tr-064.0 (73634) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.967 - error: backitup.0 (73280) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:44.958 - warn: vis-2.0 (73717) get state error: Connection is closed.
            2025-02-24 16:39:44.958 - warn: hm-rpc.0 (73411) get state error: DB closed
            2025-02-24 16:39:44.959 - info: hm-rpc.0 (73411) terminating
            2025-02-24 16:39:44.961 - warn: shelly.2 (73556) get state error: DB closed
            2025-02-24 16:39:44.979 - info: shelly.2 (73556) terminating
            2025-02-24 16:39:44.990 - info: fullybrowser.0 (73687) terminating
            2025-02-24 16:39:45.003 - error: zigbee.0 (73671) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
            2025-02-24 16:39:53.652 - info: host.iobroker iobroker.js-controller version 7.0.6 js-controller starting
            2025-02-24 16:39:53.655 - info: host.iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
            2025-02-24 16:39:53.655 - info: host.iobroker hostname: iobroker, node: v20.18.3
            2025-02-24 16:39:53.655 - info: host.iobroker ip addresses: 192.168.1.13 fe80::be24:11ff:fee0:6c23
            2025-02-24 16:39:54.563 - info: host.iobroker connected to Objects and States
            2025-02-24 16:39:54.572 - info: host.iobroker added notifications configuration of host
            2025-02-24 16:39:54.828 - info: host.iobroker 36 instances found
            2025-02-24 16:39:54.842 - info: host.iobroker starting 27 instances
            2025-02-24 16:39:55.111 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
            2025-02-24 16:39:55.139 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
            2025-02-24 16:39:55.187 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 74209
            2025-02-24 16:39:55.189 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
            2025-02-24 16:39:55.235 - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
            2025-02-24 16:39:55.279 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
            2025-02-24 16:39:55.324 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
            2025-02-24 16:39:55.367 - info: host.iobroker Some obsolete host states deleted.
            2025-02-24 16:39:56.054 - error: admin.0 (74209) admin.0 already running
            2025-02-24 16:39:56.055 - warn: admin.0 (74209) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:39:56.606 - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:39:56.606 - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
            2025-02-24 16:39:59.106 - info: host.iobroker instance system.adapter.javascript.0 in version "8.8.3" started with pid 74220
            2025-02-24 16:40:00.070 - error: javascript.0 (74220) javascript.0 already running
            2025-02-24 16:40:00.071 - warn: javascript.0 (74220) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:00.604 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:00.604 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
            2025-02-24 16:40:03.113 - info: host.iobroker instance system.adapter.scenes.0 in version "3.2.3" started with pid 74231
            2025-02-24 16:40:03.773 - error: scenes.0 (74231) scenes.0 already running
            2025-02-24 16:40:03.775 - warn: scenes.0 (74231) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:04.305 - error: host.iobroker instance system.adapter.scenes.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:04.305 - info: host.iobroker Restart adapter system.adapter.scenes.0 because enabled
            2025-02-24 16:40:07.112 - info: host.iobroker instance system.adapter.backitup.0 in version "3.0.31" started with pid 74242
            2025-02-24 16:40:07.782 - error: backitup.0 (74242) backitup.0 already running
            2025-02-24 16:40:07.783 - warn: backitup.0 (74242) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:08.315 - error: host.iobroker instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:08.315 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
            2025-02-24 16:40:11.100 - info: host.iobroker instance system.adapter.accuweather.0 in version "2.1.0" started with pid 74253
            2025-02-24 16:40:11.778 - error: accuweather.0 (74253) accuweather.0 already running
            2025-02-24 16:40:11.779 - warn: accuweather.0 (74253) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:12.308 - error: host.iobroker instance system.adapter.accuweather.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:12.308 - info: host.iobroker Restart adapter system.adapter.accuweather.0 because enabled
            2025-02-24 16:40:15.116 - info: host.iobroker instance scheduled system.adapter.feiertage.0 0 0 * * *
            2025-02-24 16:40:15.120 - info: host.iobroker instance system.adapter.feiertage.0 in version "1.2.1" started with pid 74264
            2025-02-24 16:40:15.866 - info: feiertage.0 (74264) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.feiertage, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:15.998 - info: feiertage.0 (74264) Next holiday: Rosenmontag is in 7 days on 03.03.2025
            2025-02-24 16:40:16.005 - info: feiertage.0 (74264) all objects written
            2025-02-24 16:40:16.008 - info: feiertage.0 (74264) Terminated (NO_ERROR): Without reason
            2025-02-24 16:40:16.535 - info: host.iobroker instance system.adapter.feiertage.0 terminated with code 0 (NO_ERROR)
            2025-02-24 16:40:19.096 - info: host.iobroker instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 74279
            2025-02-24 16:40:19.790 - error: hm-rega.0 (74279) hm-rega.0 already running
            2025-02-24 16:40:19.792 - warn: hm-rega.0 (74279) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:20.321 - error: host.iobroker instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:20.321 - info: host.iobroker Restart adapter system.adapter.hm-rega.0 because enabled
            2025-02-24 16:40:23.099 - info: host.iobroker instance system.adapter.hm-rpc.0 in version "2.0.2" started with pid 74290
            2025-02-24 16:40:23.762 - error: hm-rpc.0 (74290) hm-rpc.0 already running
            2025-02-24 16:40:23.764 - warn: hm-rpc.0 (74290) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:24.294 - error: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:24.294 - info: host.iobroker Restart adapter system.adapter.hm-rpc.0 because enabled
            2025-02-24 16:40:27.102 - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 74301
            2025-02-24 16:40:27.153 - info: host.iobroker instance scheduled system.adapter.ical.0 0,30 * * * *
            2025-02-24 16:40:27.156 - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 74308
            2025-02-24 16:40:28.186 - info: ical.0 (74308) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:28.267 - info: admin.0 (74301) starting. Version 7.4.10 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:28.289 - info: admin.0 (74301) requesting all objects
            2025-02-24 16:40:28.865 - info: ical.0 (74308) processing URL:
            2025-02-24 16:40:29.073 - info: admin.0 (74301) received all objects
            2025-02-24 16:40:29.200 - warn: admin.0 (74301) Cannot update news: ETIMEDOUT
            2025-02-24 16:40:29.371 - info: admin.0 (74301) socket.io server listening on port 8081
            2025-02-24 16:40:29.373 - info: admin.0 (74301) http server listening on port 8081
            2025-02-24 16:40:29.373 - info: admin.0 (74301) Use link "http://127.0.0.1:8081" to configure.
            2025-02-24 16:40:29.853 - info: admin.0 (74301) ==> Connected system.user.admin from 192.168.1.121
            2025-02-24 16:40:31.709 - info: host.iobroker instance scheduled system.adapter.ical.1 7 */3 * * *
            2025-02-24 16:40:31.712 - info: host.iobroker instance system.adapter.ical.1 in version "1.16.1" started with pid 74361
            2025-02-24 16:40:31.728 - info: host.iobroker instance system.adapter.javascript.0 in version "8.8.3" started with pid 74367
            2025-02-24 16:40:33.639 - info: ical.1 (74361) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:33.943 - info: javascript.0 (74367) starting. Version 8.8.3 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:34.059 - info: ical.0 (74308) Terminated (NO_ERROR): Without reason
            2025-02-24 16:40:34.581 - warn: ical.0 (74308) get state error: Connection is closed.
            2025-02-24 16:40:34.620 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2025-02-24 16:40:34.676 - info: host.iobroker instance system.adapter.scenes.0 in version "3.2.3" started with pid 74422
            2025-02-24 16:40:35.210 - info: ical.1 (74361) processing URL:
            2025-02-24 16:40:35.294 - info: host.iobroker instance scheduled system.adapter.ical.2 8 */6 * * *
            2025-02-24 16:40:35.300 - info: host.iobroker instance system.adapter.ical.2 in version "1.16.1" started with pid 74433
            2025-02-24 16:40:35.891 - info: scenes.0 (74422) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.scenes, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:36.545 - info: ical.2 (74433) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:37.063 - info: ical.2 (74433) processing URL:
            2025-02-24 16:40:37.291 - info: javascript.0 (74367) Removed custom npm package: "axios"
            2025-02-24 16:40:38.576 - info: host.iobroker instance system.adapter.backitup.0 in version "3.0.31" started with pid 74463
            2025-02-24 16:40:39.208 - info: host.iobroker instance scheduled system.adapter.ical.3 8 */12 * * *
            2025-02-24 16:40:39.213 - info: host.iobroker instance system.adapter.ical.3 in version "1.16.1" started with pid 74474
            2025-02-24 16:40:39.656 - info: javascript.0 (74367) Removed custom npm package: "moment"
            2025-02-24 16:40:39.768 - info: backitup.0 (74463) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:39.798 - info: backitup.0 (74463) [iobroker] backup will be activated at 03:00 every 1 day(s)
            2025-02-24 16:40:39.840 - info: backitup.0 (74463) [ccu] backup will be activated at 01:36 every 2 day(s)
            2025-02-24 16:40:40.466 - info: ical.3 (74474) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:40.652 - info: ical.1 (74361) Terminated (NO_ERROR): Without reason
            2025-02-24 16:40:40.964 - info: ical.3 (74474) processing URL: Feiertage https://calendar.google.com/calendar/ical/de.german%23holiday%40group.v.calendar.google.com/public/basic.ics
            2025-02-24 16:40:41.194 - info: host.iobroker instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
            2025-02-24 16:40:42.012 - info: javascript.0 (74367) Removed custom npm package: "moment-parseformat"
            2025-02-24 16:40:42.132 - info: ical.2 (74433) Terminated (NO_ERROR): Without reason
            2025-02-24 16:40:42.587 - info: host.iobroker instance system.adapter.accuweather.0 in version "2.1.0" started with pid 74515
            2025-02-24 16:40:42.679 - info: host.iobroker instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
            2025-02-24 16:40:43.220 - info: host.iobroker instance system.adapter.mqtt.0 in version "6.1.2" started with pid 74526
            2025-02-24 16:40:43.610 - info: accuweather.0 (74515) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.accuweather, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:44.346 - error: mqtt.0 (74526) mqtt.0 already running
            2025-02-24 16:40:44.348 - warn: mqtt.0 (74526) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:44.864 - info: javascript.0 (74367) Removed custom npm package: "qr-image"
            2025-02-24 16:40:44.881 - error: host.iobroker instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:44.882 - info: host.iobroker Restart adapter system.adapter.mqtt.0 because enabled
            2025-02-24 16:40:45.263 - info: javascript.0 (74367) requesting all states
            2025-02-24 16:40:45.263 - info: javascript.0 (74367) requesting all objects
            2025-02-24 16:40:45.836 - info: javascript.0 (74367) received all objects
            2025-02-24 16:40:46.066 - info: javascript.0 (74367) received all states
            2025-02-24 16:40:46.103 - info: ical.3 (74474) Terminated (NO_ERROR): Without reason
            2025-02-24 16:40:46.118 - info: javascript.0 (74367) script.js.global.IconsSelector: compiling TypeScript source...
            2025-02-24 16:40:46.278 - info: javascript.0 (74367) script.js.global.IconsSelector: source code did not change, using cached compilation result...
            2025-02-24 16:40:46.298 - info: javascript.0 (74367) Start JavaScript script.js.Arbeitszimmer.Roborock (Blockly)
            2025-02-24 16:40:46.324 - info: javascript.0 (74367) script.js.Arbeitszimmer.Roborock: registered 6 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.324 - info: javascript.0 (74367) Start JavaScript script.js.Arbeitszimmer.Schalter (Blockly)
            2025-02-24 16:40:46.328 - info: javascript.0 (74367) script.js.Arbeitszimmer.Schalter: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.328 - info: javascript.0 (74367) Start JavaScript script.js.Bad.BWM (Blockly)
            2025-02-24 16:40:46.332 - info: javascript.0 (74367) script.js.Bad.BWM: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.332 - info: javascript.0 (74367) Start JavaScript script.js.Bad.Schalter (Blockly)
            2025-02-24 16:40:46.336 - info: javascript.0 (74367) script.js.Bad.Schalter: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.336 - info: javascript.0 (74367) Start JavaScript script.js.Esszimmer.Remote (Blockly)
            2025-02-24 16:40:46.340 - info: javascript.0 (74367) script.js.Esszimmer.Remote: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.341 - info: javascript.0 (74367) Start JavaScript script.js.Heizung.FBH_Bad (Blockly)
            2025-02-24 16:40:46.346 - info: javascript.0 (74367) script.js.Heizung.FBH_Bad: registered 0 subscriptions, 8 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.346 - info: javascript.0 (74367) Start JavaScript script.js.Heizung.Heizung_AZ (Blockly)
            2025-02-24 16:40:46.349 - info: javascript.0 (74367) script.js.Heizung.Heizung_AZ: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.350 - info: javascript.0 (74367) Start JavaScript script.js.Heizung.Heizung_Bad (Blockly)
            2025-02-24 16:40:46.354 - info: javascript.0 (74367) script.js.Heizung.Heizung_Bad: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.354 - info: javascript.0 (74367) Start JavaScript script.js.Heizung.Heizung_EZ (Blockly)
            2025-02-24 16:40:46.358 - info: javascript.0 (74367) script.js.Heizung.Heizung_EZ: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.358 - info: javascript.0 (74367) Start JavaScript script.js.Heizung.Heizung_Küche (Blockly)
            2025-02-24 16:40:46.362 - info: javascript.0 (74367) script.js.Heizung.Heizung_Küche: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.362 - info: javascript.0 (74367) Start JavaScript script.js.Heizung.Heizung_WZ (Blockly)
            2025-02-24 16:40:46.366 - info: javascript.0 (74367) script.js.Heizung.Heizung_WZ: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.366 - info: javascript.0 (74367) Start JavaScript script.js.Heizung.Heizung_Zeit (Blockly)
            2025-02-24 16:40:46.371 - info: javascript.0 (74367) script.js.Heizung.Heizung_Zeit: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.371 - info: javascript.0 (74367) Start JavaScript script.js.Küche.Licht_Arbeitsplatte (Blockly)
            2025-02-24 16:40:46.375 - info: javascript.0 (74367) script.js.Küche.Licht_Arbeitsplatte: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.375 - info: javascript.0 (74367) Start JavaScript script.js.Küche.Remote_1 (Blockly)
            2025-02-24 16:40:46.380 - info: javascript.0 (74367) script.js.Küche.Remote_1: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.380 - info: javascript.0 (74367) Start JavaScript script.js.Küche.Tablet_BWM (Blockly)
            2025-02-24 16:40:46.384 - info: javascript.0 (74367) script.js.Küche.Tablet_BWM: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.384 - info: javascript.0 (74367) Start JavaScript script.js.Küche.Tablet_laden (Blockly)
            2025-02-24 16:40:46.388 - info: javascript.0 (74367) script.js.Küche.Tablet_laden: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.393 - info: javascript.0 (74367) Start JavaScript script.js.Küche.VIS_zurück (Blockly)
            2025-02-24 16:40:46.398 - info: javascript.0 (74367) script.js.Küche.VIS_zurück: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.400 - info: javascript.0 (74367) Start JavaScript script.js.Schlafzimmer.Remote (Blockly)
            2025-02-24 16:40:46.404 - info: javascript.0 (74367) script.js.Schlafzimmer.Remote: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.404 - info: javascript.0 (74367) Start JavaScript script.js.Schlafzimmer.Schalter (Blockly)
            2025-02-24 16:40:46.407 - info: javascript.0 (74367) script.js.Schlafzimmer.Schalter: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.408 - info: javascript.0 (74367) Start JavaScript script.js.Wohnung.Anwesenheit (Javascript/js)
            2025-02-24 16:40:46.411 - info: javascript.0 (74367) script.js.Wohnung.Anwesenheit: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.640 - info: host.iobroker instance system.adapter.ical.3 terminated with code 0 (NO_ERROR)
            2025-02-24 16:40:47.191 - info: host.iobroker instance system.adapter.shelly.1 in version "8.5.1" started with pid 74541
            2025-02-24 16:40:46.413 - info: javascript.0 (74367) Start JavaScript script.js.Wohnzimmer.Remote (Blockly)
            2025-02-24 16:40:46.417 - info: javascript.0 (74367) script.js.Wohnzimmer.Remote: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:46.417 - info: javascript.0 (74367) Compiling TypeScript source script.js.common.NSPanel.NSPanel_1_4_4_0_7
            2025-02-24 16:40:46.996 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: source code did not change, using cached compilation result...
            2025-02-24 16:40:47.109 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: --- start of NsPanelTs: 0_userdata.0.NSPanel.1. ---
            2025-02-24 16:40:47.118 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: setObjects enabled - create Alias Channels possible
            2025-02-24 16:40:47.125 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: weather alias for accuweather.0. already exists
            2025-02-24 16:40:47.195 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: registered 40 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            2025-02-24 16:40:47.222 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: No Updates for NSPanel available
            2025-02-24 16:40:47.361 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: Desired TFT Firmware: 53 / v4.4.0
            2025-02-24 16:40:47.361 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: Installed TFT Firmware: 53 / v4.4.0
            2025-02-24 16:40:47.403 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: Debug mode disabled
            2025-02-24 16:40:47.740 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: hidden Cards disabled
            2025-02-24 16:40:48.198 - error: shelly.1 (74541) shelly.1 already running
            2025-02-24 16:40:48.200 - warn: shelly.1 (74541) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:48.727 - error: host.iobroker instance system.adapter.shelly.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:48.727 - info: host.iobroker Restart adapter system.adapter.shelly.1 because enabled
            2025-02-24 16:40:49.399 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: Start MQTT-Port-Check -------------------------------------
            2025-02-24 16:40:49.399 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: -- admin.0 - 8081
            2025-02-24 16:40:49.399 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: -- shelly.1 - 1882
            2025-02-24 16:40:49.399 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: -- shelly.2 - 1883
            2025-02-24 16:40:49.400 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: -- web.0 - 8082
            2025-02-24 16:40:49.400 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: -- zigbee.0 - /dev
            2025-02-24 16:40:49.400 - warn: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: Object "system.adapter.undefined" does not exist
            2025-02-24 16:40:49.400 - info: javascript.0 (74367) script.js.common.NSPanel.NSPanel_1_4_4_0_7: End MQTT-Port-Check ---------------------------------------
            2025-02-24 16:40:50.547 - info: host.iobroker instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 74568
            2025-02-24 16:40:51.151 - info: host.iobroker instance system.adapter.shelly.2 in version "8.5.1" started with pid 74579
            2025-02-24 16:40:51.500 - info: hm-rega.0 (74568) starting. Version 5.1.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:51.563 - info: hm-rega.0 (74568) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
            2025-02-24 16:40:51.589 - info: hm-rega.0 (74568) ReGaHSS 192.168.1.18 up
            2025-02-24 16:40:51.610 - info: hm-rega.0 (74568) time difference local-ccu 1s
            2025-02-24 16:40:51.912 - info: hm-rega.0 (74568) request state values
            2025-02-24 16:40:52.054 - error: shelly.2 (74579) shelly.2 already running
            2025-02-24 16:40:52.055 - warn: shelly.2 (74579) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:52.094 - info: hm-rega.0 (74568) Updated all datapoints
            2025-02-24 16:40:52.103 - info: hm-rega.0 (74568) got 5 variables
            2025-02-24 16:40:52.125 - info: hm-rega.0 (74568) added/updated 5 variables
            2025-02-24 16:40:52.125 - info: hm-rega.0 (74568) deleted 0 variables
            2025-02-24 16:40:52.135 - info: hm-rega.0 (74568) got 0 programs
            2025-02-24 16:40:52.139 - info: hm-rega.0 (74568) added/updated 0 programs
            2025-02-24 16:40:52.139 - info: hm-rega.0 (74568) deleted 0 programs
            2025-02-24 16:40:52.143 - info: hm-rega.0 (74568) update rooms to enum.rooms
            2025-02-24 16:40:52.153 - info: hm-rega.0 (74568) update functions to enum.functions
            2025-02-24 16:40:52.161 - info: hm-rega.0 (74568) update favorites to enum.favorites
            2025-02-24 16:40:52.581 - error: host.iobroker instance system.adapter.shelly.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:52.581 - info: host.iobroker Restart adapter system.adapter.shelly.2 because enabled
            2025-02-24 16:40:54.530 - info: host.iobroker instance system.adapter.hm-rpc.0 in version "2.0.2" started with pid 74594
            2025-02-24 16:40:55.140 - info: host.iobroker instance system.adapter.sonos.0 in version "3.0.0" started with pid 74605
            2025-02-24 16:40:55.471 - info: hm-rpc.0 (74594) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:40:55.606 - info: hm-rpc.0 (74594) xmlrpc server is trying to listen on 192.168.1.13:2001
            2025-02-24 16:40:55.606 - info: hm-rpc.0 (74594) xmlrpc client is trying to connect to 192.168.1.18:2001/ with ["http://192.168.1.13:2001","iobroker:hm-rpc.0:38f144b0f17d0e1a59b89a207115ff2c"]
            2025-02-24 16:40:55.623 - info: hm-rpc.0 (74594) xmlrpc <- system.listMethods ["iobroker:hm-rpc.0:38f144b0f17d0e1a59b89a207115ff2c"]
            2025-02-24 16:40:55.627 - info: hm-rpc.0 (74594) xmlrpc <- listDevices ["iobroker:hm-rpc.0:38f144b0f17d0e1a59b89a207115ff2c"]
            2025-02-24 16:40:55.649 - info: hm-rpc.0 (74594) xmlrpc -> 92 devices
            2025-02-24 16:40:55.661 - info: hm-rpc.0 (74594) Connected
            2025-02-24 16:40:55.889 - error: sonos.0 (74605) sonos.0 already running
            2025-02-24 16:40:55.891 - warn: sonos.0 (74605) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:40:56.417 - error: host.iobroker instance system.adapter.sonos.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:40:56.417 - info: host.iobroker Restart adapter system.adapter.sonos.0 because enabled
            2025-02-24 16:40:59.086 - info: host.iobroker instance system.adapter.tankerkoenig.0 in version "3.4.0" started with pid 74620
            2025-02-24 16:40:59.786 - error: tankerkoenig.0 (74620) tankerkoenig.0 already running
            2025-02-24 16:40:59.787 - warn: tankerkoenig.0 (74620) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:41:00.316 - error: host.iobroker instance system.adapter.tankerkoenig.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:41:00.317 - info: host.iobroker Restart adapter system.adapter.tankerkoenig.0 because enabled
            2025-02-24 16:41:03.123 - info: host.iobroker instance system.adapter.tr-064.0 in version "4.3.0" started with pid 74631
            2025-02-24 16:41:03.922 - error: tr-064.0 (74631) tr-064.0 already running
            2025-02-24 16:41:03.923 - warn: tr-064.0 (74631) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:41:04.451 - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:41:04.451 - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
            2025-02-24 16:41:07.095 - info: host.iobroker instance system.adapter.unifi.0 in version "0.7.0" started with pid 74642
            2025-02-24 16:41:07.810 - error: unifi.0 (74642) unifi.0 already running
            2025-02-24 16:41:07.811 - warn: unifi.0 (74642) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:41:08.338 - error: host.iobroker instance system.adapter.unifi.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:41:08.338 - info: host.iobroker Restart adapter system.adapter.unifi.0 because enabled
            2025-02-24 16:41:09.658 - info: host.iobroker instance system.adapter.unifi.0 in version "0.7.0" started with pid 74653
            2025-02-24 16:41:10.601 - info: unifi.0 (74653) starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.unifi, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:10.653 - info: unifi.0 (74653) UniFi adapter is ready
            2025-02-24 16:41:11.092 - info: host.iobroker instance system.adapter.zigbee.0 in version "1.10.14" started with pid 74668
            2025-02-24 16:41:12.765 - error: zigbee.0 (74668) zigbee.0 already running
            2025-02-24 16:41:12.767 - warn: zigbee.0 (74668) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:41:13.304 - error: host.iobroker instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:41:13.304 - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled
            2025-02-24 16:41:15.359 - info: host.iobroker instance scheduled system.adapter.daswetter.0 55 * * * *
            2025-02-24 16:41:15.362 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.2" started with pid 74679
            2025-02-24 16:41:15.370 - info: host.iobroker instance system.adapter.mqtt.0 in version "6.1.2" started with pid 74680
            2025-02-24 16:41:16.357 - info: daswetter.0 (74679) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:16.372 - info: mqtt.0 (74680) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:16.461 - info: mqtt.0 (74680) Starting MQTT authenticated server on 0.0.0.0:1888
            2025-02-24 16:41:16.462 - info: mqtt.0 (74680) Starting MQTT-WebSocket authenticated server on 0.0.0.0:1889
            2025-02-24 16:41:18.570 - info: daswetter.0 (74679) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2025-02-24 16:41:19.215 - info: daswetter.0 (74679) cleaned everything up...
            2025-02-24 16:41:19.238 - info: host.iobroker instance system.adapter.shelly.1 in version "8.5.1" started with pid 74709
            2025-02-24 16:41:19.311 - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-02-24 16:41:19.318 - info: host.iobroker instance scheduled system.adapter.dwd.0 14,44 * * * *
            2025-02-24 16:41:19.323 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 74716
            2025-02-24 16:41:20.343 - info: shelly.1 (74709) starting. Version 8.5.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:20.377 - info: dwd.0 (74716) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:20.511 - info: shelly.1 (74709) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
            2025-02-24 16:41:20.864 - info: shelly.1 (74709) [MQTT] Device with client id "shellyplus2pm-b48a0a22690c" connected!
            2025-02-24 16:41:20.927 - info: dwd.0 (74716) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-02-24 16:41:21.454 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-02-24 16:41:22.823 - info: host.iobroker instance system.adapter.shelly.2 in version "8.5.1" started with pid 74739
            2025-02-24 16:41:23.152 - info: host.iobroker instance system.adapter.fullybrowser.0 in version "3.0.13" started with pid 74746
            2025-02-24 16:41:23.963 - error: fullybrowser.0 (74746) fullybrowser.0 already running
            2025-02-24 16:41:23.963 - info: shelly.2 (74739) starting. Version 8.5.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:23.964 - warn: fullybrowser.0 (74746) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:41:24.134 - info: shelly.2 (74739) Starting in CoAP mode. Listening on 0.0.0.0:5683
            2025-02-24 16:41:24.154 - info: shelly.2 (74739) [CoAP Server] Listening for packets in the network
            2025-02-24 16:41:24.491 - error: host.iobroker instance system.adapter.fullybrowser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:41:24.491 - info: host.iobroker Restart adapter system.adapter.fullybrowser.0 because enabled
            2025-02-24 16:41:26.542 - info: shelly.2 (74739) [CoAP] Device 192.168.1.154 (shellydimmer / shellydimmer-CC50E3F3AB05 / SHDM-1#CC50E3F3AB05#1) connected! Polltime set to 15 sec.
            2025-02-24 16:41:26.704 - info: host.iobroker instance system.adapter.sonos.0 in version "3.0.0" started with pid 74765
            2025-02-24 16:41:26.727 - info: shelly.2 (74739) [CoAP] Device 192.168.1.153 (shellyplug-s / shellyplug-s-79F6A9 / SHPLG-S#79F6A9#1) connected! Polltime set to 15 sec.
            2025-02-24 16:41:27.179 - info: host.iobroker instance scheduled system.adapter.netatmo-crawler.0 11 */1 * * *
            2025-02-24 16:41:27.187 - info: host.iobroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 74776
            2025-02-24 16:41:27.789 - info: sonos.0 (74765) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:28.516 - info: netatmo-crawler.0 (74776) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:28.537 - info: netatmo-crawler.0 (74776) Getting data for stationid:70:ee:50:7f:ff:f4
            2025-02-24 16:41:29.273 - info: mqtt.0 (74680) Client [NS-Panel_1] connected with secret 1740411689270_8007
            2025-02-24 16:41:29.357 - info: mqtt.0 (74680) Client [NS-Panel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^SmartHome\.NSPanel_1\.cmnd\..*/
            2025-02-24 16:41:29.358 - info: mqtt.0 (74680) Client [NS-Panel_1] subscribes on "SmartHome/NSPanel_1/cmnd/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_1\.cmnd\..*/
            2025-02-24 16:41:29.359 - info: mqtt.0 (74680) Client [NS-Panel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^SmartHome\.tasmotas\.cmnd\..*/
            2025-02-24 16:41:29.359 - info: mqtt.0 (74680) Client [NS-Panel_1] subscribes on "SmartHome/tasmotas/cmnd/#" with regex /^mqtt\.0\.SmartHome\.tasmotas\.cmnd\..*/
            2025-02-24 16:41:29.359 - info: mqtt.0 (74680) Client [NS-Panel_1] subscribes on "cmnd/NS-Panel_1_fb/#" with regex /^cmnd\.NS-Panel_1_fb\..*/
            2025-02-24 16:41:29.360 - info: mqtt.0 (74680) Client [NS-Panel_1] subscribes on "cmnd/NS-Panel_1_fb/#" with regex /^mqtt\.0\.cmnd\.NS-Panel_1_fb\..*/
            2025-02-24 16:41:29.396 - info: netatmo-crawler.0 (74776) Getting data for stationid:70:ee:50:58:fd:44
            2025-02-24 16:41:29.559 - info: mqtt.0 (74680) Client [NS-Panel_1] publishOnSubscribe send all known states
            2025-02-24 16:41:29.560 - info: mqtt.0 (74680) Client [NS-Panel_1] publishOnSubscribe send all known states
            2025-02-24 16:41:30.295 - info: netatmo-crawler.0 (74776) Getting data for stationid:70:ee:50:2e:9d:b8
            2025-02-24 16:41:30.560 - info: host.iobroker instance system.adapter.tankerkoenig.0 in version "3.4.0" started with pid 74795
            2025-02-24 16:41:31.010 - info: shelly.2 (74739) [CoAP] Device 192.168.1.158 (shellyrgbw2 / shellyrgbw2-48E729634D95 / SHRGBW2#48E729634D95#1) connected! Polltime set to 15 sec.
            2025-02-24 16:41:31.173 - info: host.iobroker instance system.adapter.vis-2.0 in version "2.11.2" started with pid 74806
            2025-02-24 16:41:31.423 - info: netatmo-crawler.0 (74776) Getting data for stationid:70:ee:50:7f:c8:b6
            2025-02-24 16:41:31.660 - info: tankerkoenig.0 (74795) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:31.687 - info: tankerkoenig.0 (74795) Adapter is already in daemon mode
            2025-02-24 16:41:31.688 - info: tankerkoenig.0 (74795) Sync time set to 10 minutes or 600000 ms
            2025-02-24 16:41:32.038 - error: vis-2.0 (74806) vis-2.0 already running
            2025-02-24 16:41:32.039 - warn: vis-2.0 (74806) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:41:32.156 - info: shelly.2 (74739) [CoAP] Device 192.168.1.157 (shellyplug-s / shellyplug-s-80646F8265FB / SHPLG-S#80646F8265FB#1) connected! Polltime set to 15 sec.
            2025-02-24 16:41:32.223 - info: shelly.2 (74739) [CoAP] Device 192.168.1.152 (shelly1 / shelly1-10DCB4 / SHSW-1#10DCB4#1) connected! Polltime set to 15 sec.
            2025-02-24 16:41:32.576 - error: host.iobroker instance system.adapter.vis-2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:41:32.577 - info: host.iobroker Restart adapter system.adapter.vis-2.0 because enabled
            2025-02-24 16:41:32.832 - info: netatmo-crawler.0 (74776) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
            2025-02-24 16:41:32.932 - info: shelly.2 (74739) [CoAP] Device 192.168.1.156 (shelly1 / shelly1-349454766669 / SHSW-1#349454766669#1) connected! Polltime set to 15 sec.
            2025-02-24 16:41:33.364 - info: host.iobroker instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-02-24 16:41:34.681 - info: host.iobroker instance system.adapter.tr-064.0 in version "4.3.0" started with pid 74821
            2025-02-24 16:41:35.143 - info: host.iobroker instance system.adapter.web.0 in version "6.3.0" started with pid 74828
            2025-02-24 16:41:35.175 - info: tankerkoenig.0 (74795) Start first request
            2025-02-24 16:41:35.819 - info: tr-064.0 (74821) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:36.044 - error: web.0 (74828) web.0 already running
            2025-02-24 16:41:36.048 - warn: web.0 (74828) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:41:36.577 - error: host.iobroker instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:41:36.577 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
            2025-02-24 16:41:37.035 - info: shelly.2 (74739) [CoAP] Device 192.168.1.151 (shelly1 / shelly1-767A0F / SHSW-1#767A0F#1) connected! Polltime set to 15 sec.
            2025-02-24 16:41:37.100 - info: shelly.2 (74739) [CoAP] Device 192.168.1.155 (shellycolorbulb / shellycolorbulb-E8DB84AA2596 / SHCB-1#E8DB84AA2596#1) connected! Polltime set to 15 sec.
            2025-02-24 16:41:38.358 - info: shelly.1 (74709) [MQTT] Device with client id "shellyplus2pm-c82e18087dc0" connected!
            2025-02-24 16:41:39.079 - info: host.iobroker instance system.adapter.wled.0 in version "0.7.2" started with pid 74847
            2025-02-24 16:41:39.841 - error: wled.0 (74847) wled.0 already running
            2025-02-24 16:41:39.842 - warn: wled.0 (74847) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            2025-02-24 16:41:40.373 - error: host.iobroker instance system.adapter.wled.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            2025-02-24 16:41:40.374 - info: host.iobroker Restart adapter system.adapter.wled.0 because enabled
            2025-02-24 16:41:43.171 - info: shelly.1 (74709) [MQTT] Device with client id "shellyplus2pm-30c922819fe0" connected!
            2025-02-24 16:41:43.604 - info: host.iobroker instance system.adapter.zigbee.0 in version "1.10.14" started with pid 74858
            2025-02-24 16:41:45.472 - info: zigbee.0 (74858) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:45.508 - info: zigbee.0 (74858) delete old Backup files. keep only last 10
            2025-02-24 16:41:45.509 - info: zigbee.0 (74858) Starting Zigbee npm ...
            2025-02-24 16:41:45.631 - info: zigbee.0 (74858) Installed Version: iobroker.zigbee@1.10.14
            2025-02-24 16:41:45.936 - info: zigbee.0 (74858) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
            2025-02-24 16:41:45.936 - info: zigbee.0 (74858) Unable to disable LED, unsupported function.
            2025-02-24 16:41:45.943 - info: zigbee.0 (74858) --> transmitPower : normal
            2025-02-24 16:41:45.949 - info: zigbee.0 (74858) Currently 24 devices are joined:
            2025-02-24 16:41:45.990 - info: zigbee.0 (74858) 0x5c0272fffe2c4ca3 (addr 46419): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
            2025-02-24 16:41:45.991 - info: zigbee.0 (74858) 0x5c0272fffe28904b (addr 57806): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
            2025-02-24 16:41:45.992 - info: zigbee.0 (74858) 0x00158d00042d17a0 (addr 56903): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
            2025-02-24 16:41:45.992 - info: zigbee.0 (74858) 0x00158d00045140d3 (addr 41274): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
            2025-02-24 16:41:45.993 - info: zigbee.0 (74858) 0x60a423fffe116b9c (addr 35979): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
            2025-02-24 16:41:45.993 - info: zigbee.0 (74858) 0x54ef44100047abf0 (addr 314): WXKG17LM - Aqara Wireless remote switch E1 (double rocker) (EndDevice)
            2025-02-24 16:41:45.994 - info: zigbee.0 (74858) 0x00158d0007e02974 (addr 38207): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
            2025-02-24 16:41:45.994 - info: zigbee.0 (74858) -> Configuring 0x804b50fffe859ac0 TRADFRI remote control
            2025-02-24 16:41:45.995 - info: zigbee.0 (74858) 0x84ba20fffe668126 (addr 32677): E2001/E2002 - IKEA STYRBAR remote control (EndDevice)
            2025-02-24 16:41:45.997 - info: zigbee.0 (74858) 0xa4c13829060d4be9 (addr 7622): 900091 - EGLO ROVITO-Z ceiling light (Router)
            2025-02-24 16:41:45.998 - info: zigbee.0 (74858) 0x00158d00045c5d25 (addr 30239): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
            2025-02-24 16:41:45.999 - info: zigbee.0 (74858) 0x804b50fffe859ac0 (addr 48983): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
            2025-02-24 16:41:45.999 - info: zigbee.0 (74858) 0xbc33acfffe158f61 (addr 55337): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
            2025-02-24 16:41:45.999 - info: zigbee.0 (74858) 0x14b457fffe732925 (addr 3103): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
            2025-02-24 16:41:46.000 - info: zigbee.0 (74858) 0x00158d00045d46cc (addr 20180): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
            2025-02-24 16:41:46.000 - info: zigbee.0 (74858) 0x804b50fffe68f934 (addr 38448): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
            2025-02-24 16:41:46.000 - info: zigbee.0 (74858) 0x54ef44100047af77 (addr 44964): WXKG17LM - Aqara Wireless remote switch E1 (double rocker) (EndDevice)
            2025-02-24 16:41:46.001 - info: zigbee.0 (74858) 0x84ba20fffedeec13 (addr 39144): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
            2025-02-24 16:41:46.001 - info: zigbee.0 (74858) 0x84ba20fffed483c1 (addr 45865): SNZB-02D - SONOFF Temperature and humidity sensor with screen (EndDevice)
            2025-02-24 16:41:46.002 - info: zigbee.0 (74858) 0x842e14fffea1801a (addr 34589): LED1624G9 - IKEA TRADFRI bulb E12/E14/E26/E27, color/white spectum, globe, opal, 600 lm (Router)
            2025-02-24 16:41:46.003 - info: zigbee.0 (74858) 0x94deb8fffeabe2a1 (addr 31755): LED1925G6 - IKEA TRADFRI bulb E12/E14/E17, color/white spectrum, globe, opal, 440/450/470 lm (Router)
            2025-02-24 16:41:46.003 - info: zigbee.0 (74858) 0x00158d000358c57a (addr 44647): MCCGQ01LM - Xiaomi Mi door and window sensor (EndDevice)
            2025-02-24 16:41:46.003 - info: zigbee.0 (74858) 0x00158d0003faf01b (addr 51146): RTCGQ11LM - Aqara Motion sensor (EndDevice)
            2025-02-24 16:41:46.004 - info: zigbee.0 (74858) 0x00158d0006f6ba34 (addr 34805): RTCGQ11LM - Aqara Motion sensor (EndDevice)
            2025-02-24 16:41:46.004 - info: zigbee.0 (74858) 0x60a423fffe03ce72 (addr 14557): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
            2025-02-24 16:41:46.007 - info: zigbee.0 (74858) Zigbee started
            2025-02-24 16:41:46.049 - info: zigbee.0 (74858) debug devices set to []
            2025-02-24 16:41:50.277 - info: shelly.1 (74709) [MQTT] Device with client id "shellyplusplugs-30c922870570" connected!
            2025-02-24 16:41:50.608 - info: shelly.1 (74709) [MQTT] Device with client id "shellypro3em-fce8c0d96134" connected!
            2025-02-24 16:41:54.870 - info: host.iobroker instance system.adapter.fullybrowser.0 in version "3.0.13" started with pid 74874
            2025-02-24 16:41:55.670 - info: fullybrowser.0 (74874) starting. Version 3.0.13 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:41:55.681 - info: fullybrowser.0 (74874) 🗸 192.168.1.144 (192.168.1.144): Config successfully verified.
            2025-02-24 16:41:55.764 - info: fullybrowser.0 (74874) 🚀 Start RESTApi request intervall
            2025-02-24 16:41:55.765 - info: fullybrowser.0 (74874) 🚀 MQTT Server started and is listening on port 3000.
            2025-02-24 16:41:56.086 - warn: zigbee.0 (74858) DeviceConfigure: 0x804b50fffe859ac0 TRADFRI remote control Failed to configure. When device works is all fine when not wake up the device and check again
            2025-02-24 16:41:56.087 - info: zigbee.0 (74858) -> Configuring 0xbc33acfffe158f61 TRADFRI remote control
            2025-02-24 16:42:02.842 - info: host.iobroker instance system.adapter.vis-2.0 in version "2.11.2" started with pid 74889
            2025-02-24 16:42:03.720 - info: vis-2.0 (74889) starting. Version 2.11.2 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:42:03.969 - info: vis-2.0 (74889) vis-2 license is OK.
            2025-02-24 16:42:06.098 - warn: zigbee.0 (74858) DeviceConfigure: 0xbc33acfffe158f61 TRADFRI remote control Failed to configure. When device works is all fine when not wake up the device and check again
            2025-02-24 16:42:06.099 - info: zigbee.0 (74858) -> Configuring 0x804b50fffe68f934 TRADFRI remote control
            2025-02-24 16:42:06.835 - info: host.iobroker instance system.adapter.web.0 in version "6.3.0" started with pid 74904
            2025-02-24 16:42:07.705 - info: web.0 (74904) starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:42:07.770 - info: web.0 (74904) socket.io server listening on port 8082
            2025-02-24 16:42:07.772 - info: web.0 (74904) simpleAPI server listening on port 8082
            2025-02-24 16:42:07.773 - info: web.0 (74904) Allow states only when user is owner: false
            2025-02-24 16:42:07.782 - info: web.0 (74904) http server listening on port 8082
            2025-02-24 16:42:10.640 - info: host.iobroker instance system.adapter.wled.0 in version "0.7.2" started with pid 74919
            2025-02-24 16:42:11.505 - info: wled.0 (74919) starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.wled, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:42:11.585 - info: wled.0 (74919) Try to contact 2 known devices
            2025-02-24 16:42:11.586 - info: wled.0 (74919) Try to contact : "WLED" on IP : 192.168.1.182
            2025-02-24 16:42:11.826 - info: wled.0 (74919) Initialising : " WLED" on IP : 192.168.1.182
            2025-02-24 16:42:12.165 - info: wled.0 (74919) Try to contact : "WLED" on IP : 192.168.1.185
            2025-02-24 16:42:12.191 - info: wled.0 (74919) WLED connected
            2025-02-24 16:42:12.247 - info: wled.0 (74919) Initialising : " WLED" on IP : 192.168.1.185
            2025-02-24 16:42:12.866 - info: wled.0 (74919) Bonjour service started, new devices will be detected automatically
            2025-02-24 16:42:12.905 - info: wled.0 (74919) WLED connected
            2025-02-24 16:42:16.109 - warn: zigbee.0 (74858) DeviceConfigure: 0x804b50fffe68f934 TRADFRI remote control Failed to configure. When device works is all fine when not wake up the device and check again
            2025-02-24 16:42:22.868 - info: wled.0 (74919) WLED initialisation finalized, ready to do my job have fun !
            2025-02-24 16:42:46.878 - info: fullybrowser.0 (74874) 🔑 MQTT Client 192.168.1.144 (192.168.1.144) successfully authenticated.
            2025-02-24 16:42:46.879 - info: fullybrowser.0 (74874) 🔗 MQTT Client 192.168.1.144 (192.168.1.144) successfully connected.
            2025-02-24 16:42:46.880 - warn: fullybrowser.0 (74874) 192.168.1.144 is connected (MQTT: client connected)
            2025-02-24 16:42:57.374 - warn: host.iobroker instance system.adapter.shelly.1 terminated due to SIGSEGV
            2025-02-24 16:42:57.374 - info: host.iobroker instance system.adapter.shelly.1 terminated with code null ()
            2025-02-24 16:42:57.374 - info: host.iobroker Restart adapter system.adapter.shelly.1 because enabled
            2025-02-24 16:43:27.680 - info: host.iobroker instance system.adapter.shelly.1 in version "8.5.1" started with pid 74934
            2025-02-24 16:43:28.630 - info: shelly.1 (74934) starting. Version 8.5.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:43:28.793 - info: shelly.1 (74934) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
            2025-02-24 16:43:56.192 - info: shelly.1 (74934) [MQTT] Device with client id "shellyplusplugs-30c922870570" connected!
            2025-02-24 16:43:56.888 - warn: host.iobroker instance system.adapter.shelly.1 terminated due to SIGSEGV
            2025-02-24 16:43:56.889 - info: host.iobroker instance system.adapter.shelly.1 terminated with code null ()
            2025-02-24 16:43:56.889 - info: host.iobroker Restart adapter system.adapter.shelly.1 because enabled
            2025-02-24 16:44:27.200 - info: host.iobroker instance system.adapter.shelly.1 in version "8.5.1" started with pid 74950
            2025-02-24 16:44:28.149 - info: shelly.1 (74950) starting. Version 8.5.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:44:28.299 - info: shelly.1 (74950) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
            2025-02-24 16:44:46.015 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 74967
            2025-02-24 16:44:46.872 - info: dwd.0 (74967) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.3, js-controller: 7.0.6
            2025-02-24 16:44:47.351 - info: dwd.0 (74967) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-02-24 16:44:47.865 - info: host.iobroker instance system.adapter.dwd.0 having pid 74967 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-02-24 16:44:52.942 - info: shelly.1 (74950) [MQTT] Device with client id "shellyplusplugs-30c922870570" connected!
            2025-02-24 16:44:54.669 - info: shelly.1 (74950) [MQTT] Device with client id "shellyplus2pm-c82e18087dc0" connected!
            2025-02-24 16:44:58.958 - info: shelly.1 (74950) [MQTT] Device with client id "shellypro3em-fce8c0d96134" connected!
            2025-02-24 16:44:59.183 - info: shelly.1 (74950) [MQTT] Device with client id "shellyplus2pm-b48a0a22690c" connected!
            2025-02-24 16:45:00.638 - info: shelly.1 (74950) [MQTT] Device with client id "shellyplus2pm-30c922819fe0" connected!
            2025-02-24 16:46:33.700 - info: web.0 (74904) ==> Connected system.user.admin from ::ffff:192.168.1.144
            2025-02-24 16:46:33.819 - info: fullybrowser.0 (74874) 🗸 192.168.1.144: Command screenOn successfully set to true
            crunchipC Abwesend
            crunchipC Abwesend
            @matrose65 sagte in IOBroker stürzt ab und alle Adapter starten neu:
            bind: 192.168.1.13, run as: admin
            da würd ich mal ansetzen
            • M matrose65
              @jleg sagte in IOBroker stürzt ab und alle Adapter starten neu:
              sudo dmesg
              hier nun die Ausgabe von sudo dmesg
              uwe@iobroker:~$ sudo dmesg
              [    0.000000] Linux version 6.1.0-30-amd64 (debian-kernel@lists.debian.org) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC Debian 6.1.124-1 (2025-01-12)
              [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-amd64 root=UUID=27157ade-289f-4c85-9942-840201a0ed72 ro quiet
              [    0.000000] BIOS-provided physical RAM map:
              [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
              [    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
              [    0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
              [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bffd9fff] usable
              [    0.000000] BIOS-e820: [mem 0x00000000bffda000-0x00000000bfffffff] reserved
              [    0.000000] BIOS-e820: [mem 0x00000000feffc000-0x00000000feffffff] reserved
              [    0.000000] BIOS-e820: [mem 0x00000000fffc0000-0x00000000ffffffff] reserved
              [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000043fffffff] usable
              [    0.000000] NX (Execute Disable) protection: active
              [    0.000000] SMBIOS 2.8 present.
              [    0.000000] DMI: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org 04/01/2014
              [    0.000000] Hypervisor detected: KVM
              [    0.000000] kvm-clock: Using msrs 4b564d01 and 4b564d00
              [    0.000001] kvm-clock: using sched offset of 10887319567 cycles
              [    0.000002] clocksource: kvm-clock: mask: 0xffffffffffffffff max_cycles: 0x1cd42e4dffb, max_idle_ns: 881590591483 ns
              [    0.000005] tsc: Detected 2999.998 MHz processor
              [    0.001000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
              [    0.001003] e820: remove [mem 0x000a0000-0x000fffff] usable
              [    0.001007] last_pfn = 0x440000 max_arch_pfn = 0x400000000
              [    0.001050] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
              [    0.001057] last_pfn = 0xbffda max_arch_pfn = 0x400000000
              [    0.009584] found SMP MP-table at [mem 0x000f5450-0x000f545f]
              [    0.010289] RAMDISK: [mem 0x334f3000-0x35a70fff]
              [    0.010299] ACPI: Early table checksum verification disabled
              [    0.010302] ACPI: RSDP 0x00000000000F5250 000014 (v00 BOCHS )
              [    0.010307] ACPI: RSDT 0x00000000BFFE3048 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
              [    0.010312] ACPI: FACP 0x00000000BFFE2E1A 000074 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
              [    0.010320] ACPI: DSDT 0x00000000BFFDF040 003DDA (v01 BOCHS  BXPC     00000001 BXPC 00000001)
              [    0.010324] ACPI: FACS 0x00000000BFFDF000 000040
              [    0.010327] ACPI: APIC 0x00000000BFFE2E8E 000090 (v03 BOCHS  BXPC     00000001 BXPC 00000001)
              [    0.010330] ACPI: SSDT 0x00000000BFFE2F1E 0000CA (v01 BOCHS  VMGENID  00000001 BXPC 00000001)
              [    0.010334] ACPI: HPET 0x00000000BFFE2FE8 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
              [    0.010337] ACPI: WAET 0x00000000BFFE3020 000028 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
              [    0.010340] ACPI: Reserving FACP table memory at [mem 0xbffe2e1a-0xbffe2e8d]
              [    0.010341] ACPI: Reserving DSDT table memory at [mem 0xbffdf040-0xbffe2e19]
              [    0.010342] ACPI: Reserving FACS table memory at [mem 0xbffdf000-0xbffdf03f]
              [    0.010342] ACPI: Reserving APIC table memory at [mem 0xbffe2e8e-0xbffe2f1d]
              [    0.010343] ACPI: Reserving SSDT table memory at [mem 0xbffe2f1e-0xbffe2fe7]
              [    0.010343] ACPI: Reserving HPET table memory at [mem 0xbffe2fe8-0xbffe301f]
              [    0.010344] ACPI: Reserving WAET table memory at [mem 0xbffe3020-0xbffe3047]
              [    0.010658] No NUMA configuration found
              [    0.010660] Faking a node at [mem 0x0000000000000000-0x000000043fffffff]
              [    0.010668] NODE_DATA(0) allocated [mem 0x43ffc9000-0x43fff3fff]
              [    0.010976] Zone ranges:
              [    0.010978]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
              [    0.010980]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
              [    0.010982]   Normal   [mem 0x0000000100000000-0x000000043fffffff]
              [    0.010984]   Device   empty
              [    0.010985] Movable zone start for each node
              [    0.010987] Early memory node ranges
              [    0.010988]   node   0: [mem 0x0000000000001000-0x000000000009efff]
              [    0.010989]   node   0: [mem 0x0000000000100000-0x00000000bffd9fff]
              [    0.010991]   node   0: [mem 0x0000000100000000-0x000000043fffffff]
              [    0.010995] Initmem setup node 0 [mem 0x0000000000001000-0x000000043fffffff]
              [    0.011185] On node 0, zone DMA: 1 pages in unavailable ranges
              [    0.011206] On node 0, zone DMA: 97 pages in unavailable ranges
              [    0.019824] On node 0, zone Normal: 38 pages in unavailable ranges
              [    0.021118] ACPI: PM-Timer IO Port: 0x608
              [    0.021130] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
              [    0.021163] IOAPIC[0]: apic_id 0, version 17, address 0xfec00000, GSI 0-23
              [    0.021166] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
              [    0.021168] ACPI: INT_SRC_OVR (bus 0 bus_irq 5 global_irq 5 high level)
              [    0.021169] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
              [    0.021169] ACPI: INT_SRC_OVR (bus 0 bus_irq 10 global_irq 10 high level)
              [    0.021170] ACPI: INT_SRC_OVR (bus 0 bus_irq 11 global_irq 11 high level)
              [    0.021174] ACPI: Using ACPI (MADT) for SMP configuration information
              [    0.021176] ACPI: HPET id: 0x8086a201 base: 0xfed00000
              [    0.021186] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
              [    0.021204] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
              [    0.021206] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
              [    0.021207] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000effff]
              [    0.021207] PM: hibernation: Registered nosave memory: [mem 0x000f0000-0x000fffff]
              [    0.021208] PM: hibernation: Registered nosave memory: [mem 0xbffda000-0xbfffffff]
              [    0.021209] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xfeffbfff]
              [    0.021209] PM: hibernation: Registered nosave memory: [mem 0xfeffc000-0xfeffffff]
              [    0.021210] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xfffbffff]
              [    0.021210] PM: hibernation: Registered nosave memory: [mem 0xfffc0000-0xffffffff]
              [    0.021212] [mem 0xc0000000-0xfeffbfff] available for PCI devices
              [    0.021213] Booting paravirtualized kernel on KVM
              [    0.021214] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
              [    0.025175] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
              [    0.025410] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
              [    0.025417] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
              [    0.025420] pcpu-alloc: [0] 0 1 2 3
              [    0.025455] kvm-guest: PV spinlocks enabled
              [    0.025458] PV qspinlock hash table entries: 256 (order: 0, 4096 bytes, linear)
              [    0.025467] Fallback order for Node 0: 0
              [    0.025469] Built 1 zonelists, mobility grouping on.  Total pages: 4128474
              [    0.025471] Policy zone: Normal
              [    0.025472] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-amd64 root=UUID=27157ade-289f-4c85-9942-840201a0ed72 ro quiet
              [    0.025517] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-amd64", will be passed to user space.
              [    0.027249] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
              [    0.028138] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
              [    0.028210] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
              [    0.028214] software IO TLB: area num 4.
              [    0.050518] Memory: 3171436K/16776672K available (14342K kernel code, 2336K rwdata, 9084K rodata, 2796K init, 17392K bss, 446644K reserved, 0K cma-reserved)
              [    0.050715] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
              [    0.050727] Kernel/User page tables isolation: enabled
              [    0.050751] ftrace: allocating 40305 entries in 158 pages
              [    0.056622] ftrace: allocated 158 pages with 5 groups
              [    0.057186] Dynamic Preempt: voluntary
              [    0.057374] rcu: Preemptible hierarchical RCU implementation.
              [    0.057376] rcu:     RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
              [    0.057377]  Trampoline variant of Tasks RCU enabled.
              [    0.057378]  Rude variant of Tasks RCU enabled.
              [    0.057379]  Tracing variant of Tasks RCU enabled.
              [    0.057380] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
              [    0.057381] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
              [    0.061445] NR_IRQS: 524544, nr_irqs: 456, preallocated irqs: 16
              [    0.061644] rcu: srcu_init: Setting srcu_struct sizes based on contention.
              [    0.077150] Console: colour VGA+ 80x25
              [    0.077161] printk: console [tty0] enabled
              [    0.077182] ACPI: Core revision 20220331
              [    0.077325] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604467 ns
              [    0.077454] APIC: Switch to symmetric I/O mode setup
              [    0.077696] x2apic enabled
              [    0.077952] Switched APIC routing to physical x2apic.
              [    0.079115] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
              [    0.079143] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b3e43c8763, max_idle_ns: 440795360101 ns
              [    0.079148] Calibrating delay loop (skipped) preset value.. 5999.99 BogoMIPS (lpj=11999992)
              [    0.079283] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
              [    0.079284] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
              [    0.079286] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
              [    0.079288] Spectre V2 : Mitigation: Retpolines
              [    0.079288] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
              [    0.079289] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
              [    0.079290] Speculative Store Bypass: Vulnerable
              [    0.079291] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
              [    0.079291] MMIO Stale Data: Unknown: No mitigations
              [    0.079293] x86/fpu: x87 FPU will use FXSAVE
              [    0.092525] Freeing SMP alternatives memory: 36K
              [    0.092529] pid_max: default: 32768 minimum: 301
              [    0.092576] LSM: Security Framework initializing
              [    0.092590] landlock: Up and running.
              [    0.092591] Yama: disabled by default; enable with sysctl kernel.yama.*
              [    0.092615] AppArmor: AppArmor initialized
              [    0.092617] TOMOYO Linux initialized
              [    0.092621] LSM support for eBPF active
              [    0.092832] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
              [    0.092848] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
              [    0.201244] smpboot: CPU0: Intel QEMU Virtual CPU version 2.5+ (family: 0xf, model: 0x6b, stepping: 0x1)
              [    0.201380] cblist_init_generic: Setting adjustable number of callback queues.
              [    0.201381] cblist_init_generic: Setting shift to 2 and lim to 1.
              [    0.201396] cblist_init_generic: Setting adjustable number of callback queues.
              [    0.201397] cblist_init_generic: Setting shift to 2 and lim to 1.
              [    0.201408] cblist_init_generic: Setting adjustable number of callback queues.
              [    0.201409] cblist_init_generic: Setting shift to 2 and lim to 1.
              [    0.201419] Performance Events: unsupported Netburst CPU model 107 no PMU driver, software events only.
              [    0.201434] signal: max sigframe size: 1440
              [    0.201452] rcu: Hierarchical SRCU implementation.
              [    0.201453] rcu:     Max phase no-delay instances is 1000.
              [    0.201639] NMI watchdog: Perf NMI watchdog permanently disabled
              [    0.201703] smp: Bringing up secondary CPUs ...
              [    0.201785] x86: Booting SMP configuration:
              [    0.201786] .... node  #0, CPUs:      #1 #2 #3
              [    0.239196] smp: Brought up 1 node, 4 CPUs
              [    0.239200] smpboot: Max logical packages: 1
              [    0.239201] smpboot: Total of 4 processors activated (23999.98 BogoMIPS)
              [    0.265816] node 0 deferred pages initialised in 24ms
              [    0.265816] devtmpfs: initialized
              [    0.265816] x86/mm: Memory block size: 128MB
              [    0.268265] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
              [    0.268265] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
              [    0.268265] pinctrl core: initialized pinctrl subsystem
              [    0.268265] NET: Registered PF_NETLINK/PF_ROUTE protocol family
              [    0.268516] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
              [    0.268675] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
              [    0.268871] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
              [    0.268887] audit: initializing netlink subsys (disabled)
              [    0.268919] audit: type=2000 audit(1739606050.013:1): state=initialized audit_enabled=0 res=1
              [    0.268919] thermal_sys: Registered thermal governor 'fair_share'
              [    0.268919] thermal_sys: Registered thermal governor 'bang_bang'
              [    0.268919] thermal_sys: Registered thermal governor 'step_wise'
              [    0.268919] thermal_sys: Registered thermal governor 'user_space'
              [    0.268919] thermal_sys: Registered thermal governor 'power_allocator'
              [    0.268919] cpuidle: using governor ladder
              [    0.268919] cpuidle: using governor menu
              [    0.268919] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
              [    0.268919] PCI: Using configuration type 1 for base access
              [    0.271569] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
              [    0.271725] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
              [    0.271727] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
              [    0.271847] ACPI: Added _OSI(Module Device)
              [    0.271847] ACPI: Added _OSI(Processor Device)
              [    0.271847] ACPI: Added _OSI(3.0 _SCP Extensions)
              [    0.271847] ACPI: Added _OSI(Processor Aggregator Device)
              [    0.271847] ACPI: 2 ACPI AML tables successfully acquired and loaded
              [    0.275707] ACPI: Interpreter enabled
              [    0.275707] ACPI: PM: (supports S0 S3 S4 S5)
              [    0.275707] ACPI: Using IOAPIC for interrupt routing
              [    0.275707] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
              [    0.275707] PCI: Using E820 reservations for host bridge windows
              [    0.275707] ACPI: Enabled 3 GPEs in block 00 to 0F
              [    0.278778] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
              [    0.278784] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI HPX-Type3]
              [    0.278787] acpi PNP0A03:00: _OSC: not requesting OS control; OS requires [ExtendedConfig ASPM ClockPM MSI]
              [    0.278793] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
              [    0.279273] acpiphp: Slot [3] registered
              [    0.279309] acpiphp: Slot [8] registered
              [    0.279323] acpiphp: Slot [18] registered
              [    0.279355] acpiphp: Slot [4] registered
              [    0.279367] acpiphp: Slot [6] registered
              [    0.279379] acpiphp: Slot [7] registered
              [    0.279391] acpiphp: Slot [9] registered
              [    0.279403] acpiphp: Slot [10] registered
              [    0.279417] acpiphp: Slot [11] registered
              [    0.279430] acpiphp: Slot [12] registered
              [    0.279442] acpiphp: Slot [13] registered
              [    0.279454] acpiphp: Slot [14] registered
              [    0.279466] acpiphp: Slot [15] registered
              [    0.279478] acpiphp: Slot [16] registered
              [    0.279494] acpiphp: Slot [17] registered
              [    0.279508] acpiphp: Slot [19] registered
              [    0.279521] acpiphp: Slot [20] registered
              [    0.279533] acpiphp: Slot [21] registered
              [    0.279545] acpiphp: Slot [22] registered
              [    0.279557] acpiphp: Slot [23] registered
              [    0.279570] acpiphp: Slot [24] registered
              [    0.279583] acpiphp: Slot [25] registered
              [    0.279595] acpiphp: Slot [26] registered
              [    0.279607] acpiphp: Slot [27] registered
              [    0.279619] acpiphp: Slot [28] registered
              [    0.279631] acpiphp: Slot [29] registered
              [    0.279641] PCI host bridge to bus 0000:00
              [    0.279642] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
              [    0.279644] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
              [    0.279645] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
              [    0.279646] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfebfffff window]
              [    0.279647] pci_bus 0000:00: root bus resource [mem 0x440000000-0x4bfffffff window]
              [    0.279649] pci_bus 0000:00: root bus resource [bus 00-ff]
              [    0.279690] pci 0000:00:00.0: [8086:1237] type 00 class 0x060000
              [    0.280103] pci 0000:00:01.0: [8086:7000] type 00 class 0x060100
              [    0.280736] pci 0000:00:01.1: [8086:7010] type 00 class 0x010180
              [    0.285511] pci 0000:00:01.1: reg 0x20: [io  0xf0c0-0xf0cf]
              [    0.287173] pci 0000:00:01.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
              [    0.287176] pci 0000:00:01.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
              [    0.287177] pci 0000:00:01.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
              [    0.287178] pci 0000:00:01.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
              [    0.287361] pci 0000:00:01.2: [8086:7020] type 00 class 0x0c0300
              [    0.292066] pci 0000:00:01.2: reg 0x20: [io  0xf080-0xf09f]
              [    0.295601] pci 0000:00:01.3: [8086:7113] type 00 class 0x068000
              [    0.296100] pci 0000:00:01.3: quirk: [io  0x0600-0x063f] claimed by PIIX4 ACPI
              [    0.296110] pci 0000:00:01.3: quirk: [io  0x0700-0x070f] claimed by PIIX4 SMB
              [    0.296306] pci 0000:00:02.0: [1234:1111] type 00 class 0x030000
              [    0.299189] pci 0000:00:02.0: reg 0x10: [mem 0xfc000000-0xfcffffff pref]
              [    0.301758] pci 0000:00:02.0: reg 0x18: [mem 0xfea50000-0xfea50fff]
              [    0.307756] pci 0000:00:02.0: reg 0x30: [mem 0xfea40000-0xfea4ffff pref]
              [    0.307890] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
              [    0.308336] pci 0000:00:03.0: [1af4:1002] type 00 class 0x00ff00
              [    0.309202] pci 0000:00:03.0: reg 0x10: [io  0xf000-0xf03f]
              [    0.313488] pci 0000:00:03.0: reg 0x20: [mem 0xfd600000-0xfd603fff 64bit pref]
              [    0.315511] pci 0000:00:05.0: [1b36:0001] type 01 class 0x060400
              [    0.318767] pci 0000:00:05.0: reg 0x10: [mem 0xfea51000-0xfea510ff 64bit]
              [    0.321983] pci 0000:00:08.0: [1af4:1003] type 00 class 0x078000
              [    0.324178] pci 0000:00:08.0: reg 0x10: [io  0xf040-0xf07f]
              [    0.325327] pci 0000:00:08.0: reg 0x14: [mem 0xfea52000-0xfea52fff]
              [    0.329041] pci 0000:00:08.0: reg 0x20: [mem 0xfd604000-0xfd607fff 64bit pref]
              [    0.332810] pci 0000:00:12.0: [1af4:1000] type 00 class 0x020000
              [    0.335150] pci 0000:00:12.0: reg 0x10: [io  0xf0a0-0xf0bf]
              [    0.336154] pci 0000:00:12.0: reg 0x14: [mem 0xfea53000-0xfea53fff]
              [    0.339150] pci 0000:00:12.0: reg 0x20: [mem 0xfd608000-0xfd60bfff 64bit pref]
              [    0.340040] pci 0000:00:12.0: reg 0x30: [mem 0xfea00000-0xfea3ffff pref]
              [    0.341005] pci 0000:00:1e.0: [1b36:0001] type 01 class 0x060400
              [    0.343548] pci 0000:00:1e.0: reg 0x10: [mem 0xfea54000-0xfea540ff 64bit]
              [    0.345209] pci 0000:00:1f.0: [1b36:0001] type 01 class 0x060400
              [    0.347850] pci 0000:00:1f.0: reg 0x10: [mem 0xfea55000-0xfea550ff 64bit]
              [    0.349783] pci_bus 0000:01: extended config space not accessible
              [    0.350015] acpiphp: Slot [1-2] registered
              [    0.350034] acpiphp: Slot [0] registered
              [    0.350047] acpiphp: Slot [2] registered
              [    0.350064] acpiphp: Slot [3-2] registered
              [    0.350079] acpiphp: Slot [4-2] registered
              [    0.350092] acpiphp: Slot [5] registered
              [    0.350107] acpiphp: Slot [6-2] registered
              [    0.350121] acpiphp: Slot [7-2] registered
              [    0.350135] acpiphp: Slot [8-2] registered
              [    0.350152] acpiphp: Slot [9-2] registered
              [    0.350167] acpiphp: Slot [10-2] registered
              [    0.350181] acpiphp: Slot [11-2] registered
              [    0.350196] acpiphp: Slot [12-2] registered
              [    0.350210] acpiphp: Slot [13-2] registered
              [    0.350227] acpiphp: Slot [14-2] registered
              [    0.350245] acpiphp: Slot [15-2] registered
              [    0.350260] acpiphp: Slot [16-2] registered
              [    0.350275] acpiphp: Slot [17-2] registered
              [    0.350289] acpiphp: Slot [18-2] registered
              [    0.350304] acpiphp: Slot [19-2] registered
              [    0.350318] acpiphp: Slot [20-2] registered
              [    0.350333] acpiphp: Slot [21-2] registered
              [    0.350349] acpiphp: Slot [22-2] registered
              [    0.350364] acpiphp: Slot [23-2] registered
              [    0.350378] acpiphp: Slot [24-2] registered
              [    0.350393] acpiphp: Slot [25-2] registered
              [    0.350407] acpiphp: Slot [26-2] registered
              [    0.350422] acpiphp: Slot [27-2] registered
              [    0.350438] acpiphp: Slot [28-2] registered
              [    0.350453] acpiphp: Slot [29-2] registered
              [    0.350466] acpiphp: Slot [30] registered
              [    0.350478] acpiphp: Slot [31] registered
              [    0.350584] pci 0000:01:01.0: [1af4:1004] type 00 class 0x010000
              [    0.351763] pci 0000:01:01.0: reg 0x10: [io  0xe000-0xe03f]
              [    0.353106] pci 0000:01:01.0: reg 0x14: [mem 0xfe800000-0xfe800fff]
              [    0.359151] pci 0000:01:01.0: reg 0x20: [mem 0xfd400000-0xfd403fff 64bit pref]
              [    0.361889] pci 0000:00:05.0: PCI bridge to [bus 01]
              [    0.361907] pci 0000:00:05.0:   bridge window [io  0xe000-0xefff]
              [    0.361923] pci 0000:00:05.0:   bridge window [mem 0xfe800000-0xfe9fffff]
              [    0.361951] pci 0000:00:05.0:   bridge window [mem 0xfd400000-0xfd5fffff 64bit pref]
              [    0.362481] pci_bus 0000:02: extended config space not accessible
              [    0.363152] acpiphp: Slot [27-3] registered
              [    0.363173] acpiphp: Slot [0-2] registered
              [    0.363189] acpiphp: Slot [1-3] registered
              [    0.363204] acpiphp: Slot [2-2] registered
              [    0.363219] acpiphp: Slot [3-3] registered
              [    0.363233] acpiphp: Slot [4-3] registered
              [    0.363250] acpiphp: Slot [5-2] registered
              [    0.363265] acpiphp: Slot [6-3] registered
              [    0.363280] acpiphp: Slot [7-3] registered
              [    0.363295] acpiphp: Slot [8-3] registered
              [    0.363311] acpiphp: Slot [9-3] registered
              [    0.363326] acpiphp: Slot [10-3] registered
              [    0.363343] acpiphp: Slot [11-3] registered
              [    0.363358] acpiphp: Slot [12-3] registered
              [    0.363376] acpiphp: Slot [13-3] registered
              [    0.363391] acpiphp: Slot [14-3] registered
              [    0.363406] acpiphp: Slot [15-3] registered
              [    0.363420] acpiphp: Slot [16-3] registered
              [    0.363435] acpiphp: Slot [17-3] registered
              [    0.363452] acpiphp: Slot [18-3] registered
              [    0.363467] acpiphp: Slot [19-3] registered
              [    0.363482] acpiphp: Slot [20-3] registered
              [    0.363500] acpiphp: Slot [21-3] registered
              [    0.363515] acpiphp: Slot [22-3] registered
              [    0.363530] acpiphp: Slot [23-3] registered
              [    0.363547] acpiphp: Slot [24-3] registered
              [    0.363562] acpiphp: Slot [25-3] registered
              [    0.363578] acpiphp: Slot [26-3] registered
              [    0.363593] acpiphp: Slot [28-3] registered
              [    0.363608] acpiphp: Slot [29-3] registered
              [    0.363623] acpiphp: Slot [30-2] registered
              [    0.363638] acpiphp: Slot [31-2] registered
              [    0.363882] pci 0000:02:1b.0: [1b36:000d] type 00 class 0x0c0330
              [    0.364345] pci 0000:02:1b.0: reg 0x10: [mem 0xfe600000-0xfe603fff 64bit]
              [    0.366749] pci 0000:00:1e.0: PCI bridge to [bus 02]
              [    0.366767] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
              [    0.366783] pci 0000:00:1e.0:   bridge window [mem 0xfe600000-0xfe7fffff]
              [    0.366811] pci 0000:00:1e.0:   bridge window [mem 0xfd200000-0xfd3fffff 64bit pref]
              [    0.368655] pci_bus 0000:03: extended config space not accessible
              [    0.368889] acpiphp: Slot [0-3] registered
              [    0.368912] acpiphp: Slot [1-4] registered
              [    0.368928] acpiphp: Slot [2-3] registered
              [    0.368951] acpiphp: Slot [3-4] registered
              [    0.368972] acpiphp: Slot [4-4] registered
              [    0.368996] acpiphp: Slot [5-3] registered
              [    0.369028] acpiphp: Slot [6-4] registered
              [    0.369058] acpiphp: Slot [7-4] registered
              [    0.369095] acpiphp: Slot [8-4] registered
              [    0.369126] acpiphp: Slot [9-4] registered
              [    0.369149] acpiphp: Slot [10-4] registered
              [    0.369168] acpiphp: Slot [11-4] registered
              [    0.369187] acpiphp: Slot [12-4] registered
              [    0.369208] acpiphp: Slot [13-4] registered
              [    0.369227] acpiphp: Slot [14-4] registered
              [    0.369246] acpiphp: Slot [15-4] registered
              [    0.369266] acpiphp: Slot [16-4] registered
              [    0.369286] acpiphp: Slot [17-4] registered
              [    0.369309] acpiphp: Slot [18-4] registered
              [    0.369331] acpiphp: Slot [19-4] registered
              [    0.369350] acpiphp: Slot [20-4] registered
              [    0.369370] acpiphp: Slot [21-4] registered
              [    0.369391] acpiphp: Slot [22-4] registered
              [    0.369410] acpiphp: Slot [23-4] registered
              [    0.369429] acpiphp: Slot [24-4] registered
              [    0.369448] acpiphp: Slot [25-4] registered
              [    0.369466] acpiphp: Slot [26-4] registered
              [    0.369485] acpiphp: Slot [27-4] registered
              [    0.369504] acpiphp: Slot [28-4] registered
              [    0.369528] acpiphp: Slot [29-4] registered
              [    0.369547] acpiphp: Slot [30-3] registered
              [    0.369566] acpiphp: Slot [31-3] registered
              [    0.369807] pci 0000:00:1f.0: PCI bridge to [bus 03]
              [    0.369824] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
              [    0.369841] pci 0000:00:1f.0:   bridge window [mem 0xfe400000-0xfe5fffff]
              [    0.369880] pci 0000:00:1f.0:   bridge window [mem 0xfd000000-0xfd1fffff 64bit pref]
              [    0.372063] ACPI: PCI: Interrupt link LNKA configured for IRQ 10
              [    0.372184] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
              [    0.372289] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
              [    0.372397] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
              [    0.372463] ACPI: PCI: Interrupt link LNKS configured for IRQ 9
              [    0.372937] iommu: Default domain type: Translated
              [    0.372937] iommu: DMA domain TLB invalidation policy: lazy mode
              [    0.372937] pps_core: LinuxPPS API ver. 1 registered
              [    0.372937] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
              [    0.372937] PTP clock support registered
              [    0.372937] EDAC MC: Ver: 3.0.0
              [    0.375431] NetLabel: Initializing
              [    0.375432] NetLabel:  domain hash size = 128
              [    0.375433] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
              [    0.375471] NetLabel:  unlabeled traffic allowed by default
              [    0.375472] PCI: Using ACPI for IRQ routing
              [    0.375474] PCI: pci_cache_line_size set to 64 bytes
              [    0.375704] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
              [    0.375707] e820: reserve RAM buffer [mem 0xbffda000-0xbfffffff]
              [    0.375730] pci 0000:00:02.0: vgaarb: setting as boot VGA device
              [    0.375730] pci 0000:00:02.0: vgaarb: bridge control possible
              [    0.375730] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
              [    0.375730] vgaarb: loaded
              [    0.375859] hpet: 3 channels of 0 reserved for per-cpu timers
              [    0.375874] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
              [    0.375878] hpet0: 3 comparators, 64-bit 100.000000 MHz counter
              [    0.379165] clocksource: Switched to clocksource kvm-clock
              [    0.387497] VFS: Disk quotas dquot_6.6.0
              [    0.387512] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
              [    0.387636] AppArmor: AppArmor Filesystem Enabled
              [    0.387651] pnp: PnP ACPI init
              [    0.387743] pnp 00:02: [dma 2]
              [    0.387955] pnp: PnP ACPI: found 4 devices
              [    0.395485] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
              [    0.395611] NET: Registered PF_INET protocol family
              [    0.395997] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
              [    0.399804] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
              [    0.399833] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
              [    0.399901] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
              [    0.400341] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
              [    0.400572] TCP: Hash tables configured (established 131072 bind 65536)
              [    0.400895] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
              [    0.400960] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
              [    0.401021] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
              [    0.401103] NET: Registered PF_UNIX/PF_LOCAL protocol family
              [    0.401116] NET: Registered PF_XDP protocol family
              [    0.401138] pci 0000:00:05.0: PCI bridge to [bus 01]
              [    0.401184] pci 0000:00:05.0:   bridge window [io  0xe000-0xefff]
              [    0.402079] pci 0000:00:05.0:   bridge window [mem 0xfe800000-0xfe9fffff]
              [    0.402555] pci 0000:00:05.0:   bridge window [mem 0xfd400000-0xfd5fffff 64bit pref]
              [    0.403561] pci 0000:00:1e.0: PCI bridge to [bus 02]
              [    0.403618] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
              [    0.404326] pci 0000:00:1e.0:   bridge window [mem 0xfe600000-0xfe7fffff]
              [    0.404847] pci 0000:00:1e.0:   bridge window [mem 0xfd200000-0xfd3fffff 64bit pref]
              [    0.405865] pci 0000:00:1f.0: PCI bridge to [bus 03]
              [    0.406197] pci 0000:00:1f.0:   bridge window [io  0xc000-0xcfff]
              [    0.406889] pci 0000:00:1f.0:   bridge window [mem 0xfe400000-0xfe5fffff]
              [    0.407373] pci 0000:00:1f.0:   bridge window [mem 0xfd000000-0xfd1fffff 64bit pref]
              [    0.408136] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
              [    0.408139] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
              [    0.408140] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
              [    0.408141] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xfebfffff window]
              [    0.408142] pci_bus 0000:00: resource 8 [mem 0x440000000-0x4bfffffff window]
              [    0.408144] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
              [    0.408145] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe9fffff]
              [    0.408146] pci_bus 0000:01: resource 2 [mem 0xfd400000-0xfd5fffff 64bit pref]
              [    0.408148] pci_bus 0000:02: resource 0 [io  0xd000-0xdfff]
              [    0.408157] pci_bus 0000:02: resource 1 [mem 0xfe600000-0xfe7fffff]
              [    0.408158] pci_bus 0000:02: resource 2 [mem 0xfd200000-0xfd3fffff 64bit pref]
              [    0.408159] pci_bus 0000:03: resource 0 [io  0xc000-0xcfff]
              [    0.408159] pci_bus 0000:03: resource 1 [mem 0xfe400000-0xfe5fffff]
              [    0.408160] pci_bus 0000:03: resource 2 [mem 0xfd000000-0xfd1fffff 64bit pref]
              [    0.408368] pci 0000:00:01.0: PIIX3: Enabling Passive Release
              [    0.408396] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
              [    0.427766] ACPI: \_SB_.LNKD: Enabled at IRQ 11
              [    0.443426] pci 0000:00:01.2: quirk_usb_early_handoff+0x0/0x750 took 34135 usecs
              [    0.457985] ACPI: \_SB_.LNKB: Enabled at IRQ 10
              [    0.474115] ACPI: \_SB_.LNKA: Enabled at IRQ 10
              [    0.490455] pci 0000:02:1b.0: quirk_usb_early_handoff+0x0/0x750 took 45816 usecs
              [    0.490493] PCI: CLS 0 bytes, default 64
              [    0.490572] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
              [    0.490573] software IO TLB: mapped [mem 0x00000000bbfda000-0x00000000bffda000] (64MB)
              [    0.490619] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b3e43c8763, max_idle_ns: 440795360101 ns
              [    0.490729] Trying to unpack rootfs image as initramfs...
              [    0.491184] Initialise system trusted keyrings
              [    0.491214] Key type blacklist registered
              [    0.491521] workingset: timestamp_bits=36 max_order=22 bucket_order=0
              [    0.493302] zbud: loaded
              [    0.494194] integrity: Platform Keyring initialized
              [    0.494203] integrity: Machine keyring initialized
              [    0.494205] Key type asymmetric registered
              [    0.494212] Asymmetric key parser 'x509' registered
              [    0.751606] Freeing initrd memory: 38392K
              [    0.757062] alg: self-tests for CTR-KDF (hmac(sha256)) passed
              [    0.757091] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
              [    0.757177] io scheduler mq-deadline registered
              [    0.758043] shpchp 0000:00:05.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.S28_)
              [    0.758049] shpchp 0000:00:05.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
              [    0.758055] shpchp 0000:00:05.0: Cannot get control of SHPC hotplug
              [    0.758109] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.SF0_)
              [    0.758113] shpchp 0000:00:1e.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
              [    0.758115] shpchp 0000:00:1e.0: Cannot get control of SHPC hotplug
              [    0.758158] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0.SF8_)
              [    0.758161] shpchp 0000:00:1f.0: Requesting control of SHPC hotplug via OSHP (\_SB_.PCI0)
              [    0.758163] shpchp 0000:00:1f.0: Cannot get control of SHPC hotplug
              [    0.758170] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
              [    0.758536] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
              [    0.759230] Linux agpgart interface v0.103
              [    0.759320] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
              [    0.759716] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
              [    0.760553] serio: i8042 KBD port at 0x60,0x64 irq 1
              [    0.760560] serio: i8042 AUX port at 0x60,0x64 irq 12
              [    0.760682] mousedev: PS/2 mouse device common for all mice
              [    0.760703] rtc_cmos 00:03: RTC can wake from S4
              [    0.761478] rtc_cmos 00:03: registered as rtc0
              [    0.761606] rtc_cmos 00:03: setting system clock to 2025-02-15T07:54:09 UTC (1739606049)
              [    0.761750] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
              [    0.761765] rtc_cmos 00:03: alarms up to one day, y3k, 242 bytes nvram, hpet irqs
              [    0.761776] intel_pstate: CPU model not supported
              [    0.762111] ledtrig-cpu: registered to indicate activity on CPUs
              [    0.772716] NET: Registered PF_INET6 protocol family
              [    0.777466] Segment Routing with IPv6
              [    0.777484] In-situ OAM (IOAM) with IPv6
              [    0.777575] mip6: Mobile IPv6
              [    0.777584] NET: Registered PF_PACKET protocol family
              [    0.777693] mpls_gso: MPLS GSO support
              [    0.778028] IPI shorthand broadcast: enabled
              [    0.778046] sched_clock: Marking stable (764457814, 13494714)->(779962800, -2010272)
              [    0.778261] registered taskstats version 1
              [    0.778268] Loading compiled-in X.509 certificates
              [    0.791980] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
              [    0.792004] Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f'
              [    0.792411] zswap: loaded using pool lzo/zbud
              [    0.792779] Key type .fscrypt registered
              [    0.792781] Key type fscrypt-provisioning registered
              [    0.797455] Key type encrypted registered
              [    0.797460] AppArmor: AppArmor sha1 policy hashing enabled
              [    0.797473] ima: No TPM chip found, activating TPM-bypass!
              [    0.797475] ima: Allocated hash algorithm: sha256
              [    0.797488] ima: No architecture policies found
              [    0.797522] evm: Initialising EVM extended attributes:
              [    0.797523] evm: security.selinux
              [    0.797525] evm: security.SMACK64 (disabled)
              [    0.797526] evm: security.SMACK64EXEC (disabled)
              [    0.797527] evm: security.SMACK64TRANSMUTE (disabled)
              [    0.797527] evm: security.SMACK64MMAP (disabled)
              [    0.797528] evm: security.apparmor
              [    0.797529] evm: security.ima
              [    0.797530] evm: security.capability
              [    0.797530] evm: HMAC attrs: 0x1
              [    0.868352] clk: Disabling unused clocks
              [    0.869384] Freeing unused decrypted memory: 2036K
              [    0.869752] Freeing unused kernel image (initmem) memory: 2796K
              [    0.869813] Write protecting the kernel read-only data: 26624k
              [    0.871234] Freeing unused kernel image (text/rodata gap) memory: 2040K
              [    0.871513] Freeing unused kernel image (rodata/data gap) memory: 1156K
              [    0.916635] x86/mm: Checked W+X mappings: passed, no W+X pages found.
              [    0.916677] x86/mm: Checking user space page tables
              [    0.962237] x86/mm: Checked W+X mappings: passed, no W+X pages found.
              [    0.962245] Run /init as init process
              [    0.962254]   with arguments:
              [    0.962256]     /init
              [    0.962256]   with environment:
              [    0.962257]     HOME=/
              [    0.962257]     TERM=linux
              [    0.962258]     BOOT_IMAGE=/boot/vmlinuz-6.1.0-30-amd64
              [    1.087798] piix4_smbus 0000:00:01.3: SMBus Host Controller at 0x700, revision 0
              [    1.093928] FDC 0 is a S82078B
              [    1.096955] SCSI subsystem initialized
              [    1.132836] ACPI: bus type USB registered
              [    1.132868] usbcore: registered new interface driver usbfs
              [    1.132876] usbcore: registered new interface driver hub
              [    1.132888] usbcore: registered new device driver usb
              [    1.146313] libata version 3.00 loaded.
              [    1.146660] ACPI: bus type drm_connector registered
              [    1.175371] uhci_hcd 0000:00:01.2: UHCI Host Controller
              [    1.175401] uhci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
              [    1.175423] uhci_hcd 0000:00:01.2: detected 2 ports
              [    1.175724] uhci_hcd 0000:00:01.2: irq 11, io port 0x0000f080
              [    1.176000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
              [    1.176004] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              [    1.176006] usb usb1: Product: UHCI Host Controller
              [    1.176007] usb usb1: Manufacturer: Linux 6.1.0-30-amd64 uhci_hcd
              [    1.176009] usb usb1: SerialNumber: 0000:00:01.2
              [    1.176215] hub 1-0:1.0: USB hub found
              [    1.176221] hub 1-0:1.0: 2 ports detected
              [    1.178108] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input3
              [    1.178390] input: VirtualPS/2 VMware VMMouse as /devices/platform/i8042/serio1/input/input2
              [    1.179683] ata_piix 0000:00:01.1: version 2.13
              [    1.181702] bochs-drm 0000:00:02.0: vgaarb: deactivate vga console
              [    1.184692] Console: switching to colour dummy device 80x25
              [    1.195412] [drm] Found bochs VGA, ID 0xb0c5.
              [    1.195415] [drm] Framebuffer size 16384 kB @ 0xfc000000, mmio @ 0xfea50000.
              [    1.195657] scsi host0: ata_piix
              [    1.196014] scsi host1: ata_piix
              [    1.196055] ata1: PATA max MWDMA2 cmd 0x1f0 ctl 0x3f6 bmdma 0xf0c0 irq 14
              [    1.196057] ata2: PATA max MWDMA2 cmd 0x170 ctl 0x376 bmdma 0xf0c8 irq 15
              [    1.197185] [drm] Found EDID data blob.
              [    1.197301] [drm] Initialized bochs-drm 1.0.0 20130925 for 0000:00:02.0 on minor 0
              [    1.198407] fbcon: bochs-drmdrmfb (fb0) is primary device
              [    1.201846] Console: switching to colour frame buffer device 160x50
              [    1.203490] bochs-drm 0000:00:02.0: [drm] fb0: bochs-drmdrmfb frame buffer device
              [    1.213303] ACPI: \_SB_.LNKC: Enabled at IRQ 11
              [    1.214017] xhci_hcd 0000:02:1b.0: xHCI Host Controller
              [    1.214031] xhci_hcd 0000:02:1b.0: new USB bus registered, assigned bus number 2
              [    1.214521] xhci_hcd 0000:02:1b.0: hcc params 0x00087001 hci version 0x100 quirks 0x0000000000000010
              [    1.216125] xhci_hcd 0000:02:1b.0: xHCI Host Controller
              [    1.216133] xhci_hcd 0000:02:1b.0: new USB bus registered, assigned bus number 3
              [    1.216138] xhci_hcd 0000:02:1b.0: Host supports USB 3.0 SuperSpeed
              [    1.216220] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
              [    1.216223] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              [    1.216225] usb usb2: Product: xHCI Host Controller
              [    1.216227] usb usb2: Manufacturer: Linux 6.1.0-30-amd64 xhci-hcd
              [    1.216228] usb usb2: SerialNumber: 0000:02:1b.0
              [    1.216369] hub 2-0:1.0: USB hub found
              [    1.216478] hub 2-0:1.0: 15 ports detected
              [    1.217224] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
              [    1.217245] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
              [    1.217247] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
              [    1.217249] usb usb3: Product: xHCI Host Controller
              [    1.217250] usb usb3: Manufacturer: Linux 6.1.0-30-amd64 xhci-hcd
              [    1.217252] usb usb3: SerialNumber: 0000:02:1b.0
              [    1.217372] hub 3-0:1.0: USB hub found
              [    1.217470] hub 3-0:1.0: 15 ports detected
              [    1.586455] ata2: found unknown device (class 0)
              [    1.587417] ata2.00: ATAPI: QEMU DVD-ROM, 2.5+, max UDMA/100
              [    1.588809] scsi 1:0:0:0: CD-ROM            QEMU     QEMU DVD-ROM     2.5+ PQ: 0 ANSI: 5
              [    1.645618] usb 1-1: new full-speed USB device number 2 using uhci_hcd
              [    1.665884] scsi host2: Virtio SCSI HBA
              [    1.666949] scsi 2:0:0:0: Direct-Access     QEMU     QEMU HARDDISK    2.5+ PQ: 0 ANSI: 5
              [    1.684572] sr 1:0:0:0: [sr0] scsi3-mmc drive: 4x/4x cd/rw xa/form2 tray
              [    1.684581] cdrom: Uniform CD-ROM driver Revision: 3.20
              [    1.713629] usb 2-1: new full-speed USB device number 2 using xhci_hcd
              [    1.713693] virtio_net virtio2 ens18: renamed from eth0
              [    1.746632] sr 1:0:0:0: Attached scsi CD-ROM sr0
              [    1.758654] sd 2:0:0:0: Power-on or device reset occurred
              [    1.758786] sd 2:0:0:0: [sda] 83886080 512-byte logical blocks: (42.9 GB/40.0 GiB)
              [    1.758826] sd 2:0:0:0: [sda] Write Protect is off
              [    1.758828] sd 2:0:0:0: [sda] Mode Sense: 63 00 00 08
              [    1.758889] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
              [    1.761230]  sda: sda1 sda2 < sda5 >
              [    1.761488] sd 2:0:0:0: [sda] Attached SCSI disk
              [    1.806559] usb 1-1: not running at top speed; connect to a high speed hub
              [    1.840379] usb 1-1: New USB device found, idVendor=0627, idProduct=0001, bcdDevice= 0.00
              [    1.840385] usb 1-1: New USB device strings: Mfr=1, Product=3, SerialNumber=10
              [    1.840387] usb 1-1: Product: QEMU USB Tablet
              [    1.840389] usb 1-1: Manufacturer: QEMU
              [    1.840390] usb 1-1: SerialNumber: 28754-0000:00:01.2-1
              [    1.850201] hid: raw HID events driver (C) Jiri Kosina
              [    1.855850] usbcore: registered new interface driver usbhid
              [    1.855853] usbhid: USB HID core driver
              [    1.857706] input: QEMU QEMU USB Tablet as /devices/pci0000:00/0000:00:01.2/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input4
              [    1.857920] hid-generic 0003:0627:0001.0001: input,hidraw0: USB HID v0.01 Mouse [QEMU QEMU USB Tablet] on usb-0000:00:01.2-1/input0
              [    1.869020] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
              [    1.869024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
              [    1.869026] usb 2-1: Product: Sonoff Zigbee 3.0 USB Dongle Plus
              [    1.869027] usb 2-1: Manufacturer: Silicon Labs
              [    1.869028] usb 2-1: SerialNumber: 0001
              [    1.926293] PM: Image not found (code -22)
              [    2.070625] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
              [    2.117299] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
              [    2.166113] systemd[1]: Inserted module 'autofs4'
              [    2.184221] systemd[1]: systemd 252.33-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
              [    2.184227] systemd[1]: Detected virtualization kvm.
              [    2.184231] systemd[1]: Detected architecture x86-64.
              [    2.185854] systemd[1]: Hostname set to <iobroker>.
              [    2.370152] systemd[1]: Queued start job for default target multi-user.target.
              [    2.386544] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
              [    2.386860] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
              [    2.387132] systemd[1]: Created slice user.slice - User and Session Slice.
              [    2.387216] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
              [    2.387288] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
              [    2.387503] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
              [    2.387528] systemd[1]: Expecting device dev-disk-by\x2duuid-3fa31c5f\x2d0f90\x2d49c4\x2dadef\x2dfcadb0a838fa.device - /dev/disk/by-uuid/3fa31c5f-0f90-49c4-adef-fcadb0a838fa...
              [    2.387543] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
              [    2.387560] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
              [    2.387585] systemd[1]: Reached target paths.target - Path Units.
              [    2.387609] systemd[1]: Reached target slices.target - Slice Units.
              [    2.387633] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
              [    2.391335] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
              [    2.391626] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
              [    2.391736] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
              [    2.392183] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
              [    2.392334] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
              [    2.392487] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
              [    2.393071] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
              [    2.393199] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
              [    2.394224] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
              [    2.395412] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
              [    2.396725] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
              [    2.398250] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
              [    2.398354] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
              [    2.399669] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
              [    2.400971] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
              [    2.402416] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
              [    2.403840] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
              [    2.405380] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
              [    2.406964] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
              [    2.408334] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
              [    2.409896] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
              [    2.410032] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
              [    2.412278] systemd[1]: Starting systemd-journald.service - Journal Service...
              [    2.417451] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
              [    2.418582] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
              [    2.419778] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
              [    2.423214] loop: module loaded
              [    2.424981] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
              [    2.425013] device-mapper: uevent: version 1.0.3
              [    2.425121] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
              [    2.425235] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
              [    2.425390] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
              [    2.425662] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
              [    2.425863] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
              [    2.426206] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
              [    2.426645] systemd[1]: modprobe@configfs.service: Deactivated successfully.
              [    2.426857] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
              [    2.427310] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
              [    2.427492] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
              [    2.427883] systemd[1]: modprobe@drm.service: Deactivated successfully.
              [    2.428079] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
              [    2.428730] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
              [    2.429509] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
              [    2.430121] systemd[1]: modprobe@loop.service: Deactivated successfully.
              [    2.430332] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
              [    2.432343] fuse: init (API version 7.38)
              [    2.435075] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
              [    2.435286] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
              [    2.435926] systemd[1]: modprobe@fuse.service: Deactivated successfully.
              [    2.436176] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
              [    2.438059] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
              [    2.439296] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
              [    2.440159] EXT4-fs (sda1): re-mounted. Quota mode: none.
              [    2.443270] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
              [    2.443833] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
              [    2.444123] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
              [    2.444276] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
              [    2.444357] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
              [    2.445633] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
              [    2.446855] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
              [    2.448118] systemd[1]: Starting systemd-sysusers.service - Create System Users...
              [    2.471236] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
              [    2.485259] systemd[1]: Finished systemd-sysusers.service - Create System Users.
              [    2.487170] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
              [    2.492907] systemd[1]: Started systemd-journald.service - Journal Service.
              [    2.510452] systemd-journald[250]: Received client request to flush runtime journal.
              [    2.659651] audit: type=1400 audit(1739606051.392:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=317 comm="apparmor_parser"
              [    2.659657] audit: type=1400 audit(1739606051.392:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=317 comm="apparmor_parser"
              [    2.664298] audit: type=1400 audit(1739606051.396:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=320 comm="apparmor_parser"
              [    2.664305] audit: type=1400 audit(1739606051.396:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=320 comm="apparmor_parser"
              [    2.664307] audit: type=1400 audit(1739606051.396:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=320 comm="apparmor_parser"
              [    2.739911] sr 1:0:0:0: Attached scsi generic sg0 type 5
              [    2.739937] audit: type=1400 audit(1739606051.472:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=316 comm="apparmor_parser"
              [    2.740786] sd 2:0:0:0: Attached scsi generic sg1 type 0
              [    2.753237] audit: type=1400 audit(1739606051.484:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=319 comm="apparmor_parser"
              [    2.753243] audit: type=1400 audit(1739606051.484:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=319 comm="apparmor_parser"
              [    2.753246] audit: type=1400 audit(1739606051.484:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=319 comm="apparmor_parser"
              [    2.828160] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
              [    2.849727] ACPI: button: Power Button [PWRF]
              [    2.869094] Free page reporting enabled
              [    2.875218] input: PC Speaker as /devices/platform/pcspkr/input/input6
              [    2.925086] usbcore: registered new interface driver usbserial_generic
              [    2.925100] usbserial: USB Serial support registered for generic
              [    2.952656] usbcore: registered new interface driver cp210x
              [    2.952671] usbserial: USB Serial support registered for cp210x
              [    2.952760] cp210x 2-1:1.0: cp210x converter detected
              [    2.960137] Adding 998396k swap on /dev/sda5.  Priority:-2 extents:1 across:998396k FS
              [    2.961777] usb 2-1: cp210x converter now attached to ttyUSB0
              [    2.965891] cryptd: max_cpu_qlen set to 1000
              [    3.005439] SSE version of gcm_enc/dec engaged.
              [    3.433518] random: crng init done
              [    3.505324] RPC: Registered named UNIX socket transport module.
              [    3.505327] RPC: Registered udp transport module.
              [    3.505328] RPC: Registered tcp transport module.
              [    3.505329] RPC: Registered tcp NFSv4.1 backchannel transport module.
              [  147.473410] usb 2-1: USB disconnect, device number 2
              [  147.473647] cp210x ttyUSB0: failed set request 0x7 status: -19
              [  147.473683] cp210x ttyUSB0: failed set request 0x12 status: -19
              [  147.473694] cp210x ttyUSB0: failed set request 0x0 status: -19
              [  147.475966] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
              [  147.475982] cp210x 2-1:1.0: device disconnected
              [  147.992398] usb 2-1: new full-speed USB device number 3 using xhci_hcd
              [  148.142653] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
              [  148.142658] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
              [  148.142659] usb 2-1: Product: Sonoff Zigbee 3.0 USB Dongle Plus
              [  148.142660] usb 2-1: Manufacturer: Silicon Labs
              [  148.142662] usb 2-1: SerialNumber: 0001
              [  148.143292] usb 2-1: can't set config #1, error -32
              [11507.277732] usb 2-1: USB disconnect, device number 3
              [11517.758624] usb 2-1: new full-speed USB device number 4 using xhci_hcd
              [11517.909063] usb 2-1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
              [11517.909067] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
              [11517.909068] usb 2-1: Product: Sonoff Zigbee 3.0 USB Dongle Plus
              [11517.909069] usb 2-1: Manufacturer: Silicon Labs
              [11517.909070] usb 2-1: SerialNumber: 0001
              [11517.910370] cp210x 2-1:1.0: cp210x converter detected
              [11517.913438] usb 2-1: cp210x converter now attached to ttyUSB0
              [173398.417895] show_signal_msg: 1 callbacks suppressed
              [173398.417902] apt[25770]: segfault at 7fe23931be08 ip 00007fe23e6b7eca sp 00007ffcd8822c00 error 4 in libc.so.6[7fe23e645000+155000] likely on CPU 3 (core 3, socket 0)
              [173398.417914] Code: dc 2c 10 00 e8 27 63 fe ff 0f 1f 80 00 00 00 00 48 85 ff 0f 84 bf 00 00 00 55 48 8d 77 f0 53 48 83 ec 18 48 8b 1d 16 8f 13 00 <48> 8b 47 f8 64 8b 2b a8 02 75 5b 48 8b 15 9c 8e 13 00 64 48 83 3a
              [180105.147372] traps: node[29654] trap int3 ip:2197c92 sp:7f58af21bc20 error:0 in node[b82000+1abe000]
              [682690.774115] traps: node[65308] trap invalid opcode ip:2197c92 sp:7f4869d3b5f0 error:0 in node[b82000+1abe000]
              JLegJ Offline
              JLegJ Offline
              JLeg
              schrieb am zuletzt editiert von JLeg
              dein Problem könnte dieses hier sein - prüft der admin-Adapter nicht ab und zu per apt die OS Updates? Jedenfalls stürzt apt offenbar hart ab - ich würde mal nicht ausschliessen, dass das den Admin mitreissen könnte. Auf jeden Fall ist das nicht normal...
              (mit "dmesg -e" bekommst du noch Zeitangaben, ggf. kannst du mal schauen, ob das mit deinem Absturzzeitpunkt hinkommt)
                web.0 (73732) setTimeout called, but adapter is shutting down
                matrose65
                @crunchip
                bind: 192.168.1.13, run as: admin habe ich abgestellt
                Adapter State
                + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                  system.adapter.devices.0                : devices               : iobroker                                 - disabled
                  system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                  system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                  system.adapter.history.0                : history               : iobroker                                 - disabled
                + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled
                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                  system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                  system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
                  system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
                  system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
                + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shelly.2                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                  system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
                  system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 - disabled
                  system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
                  system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                • JLegJ JLeg
                  matrose65
                  @jleg
                  Ja der Admin prüft auf updates. Das kann ich auf manuell schalten und es lassen.
                  Der Auszug ist vom 17.02 09:04 da kann ich kein Log mehr aufrufen
                  [Feb17 09:04] show_signal_msg: 1 callbacks suppressed
                  [  +0,000007] apt[25770]: segfault at 7fe23931be08 ip 00007fe23e6b7eca sp 00007ffcd8822c00 error 4 in libc.so.6[7fe23e645000+155000] likely on CPU 3 (core 3, socket 0)
                  [  +0,000012] Code: dc 2c 10 00 e8 27 63 fe ff 0f 1f 80 00 00 00 00 48 85 ff 0f 84 bf 00 00 00 55 48 8d 77 f0 53 48 83 ec 18 48 8b 1d 16 8f 13 00 <48> 8b 47 f8 64 8b 2b a8 02 75 5b 48 8b 15 9c 8e 13 00 64 48 83 3a
                  [Feb17 10:55] traps: node[29654] trap int3 ip:2197c92 sp:7f58af21bc20 error:0 in node[b82000+1abe000]
                  [Feb23 06:32] traps: node[65308] trap invalid opcode ip:2197c92 sp:7f4869d3b5f0 error:0 in node[b82000+1abe000]
                  JLegJ 1 Antwort Letzte Antwort
                  • M matrose65
                    @jleg
                    JLegJ Offline
                    JLegJ Offline
                    JLeg
                    @matrose65 ok, aber wenn der letzte Absturz gestern war, wird dieser "Segfault" nicht die Ursache gewesen sein.
                    • JLegJ JLeg
                      matrose65
                      schrieb am zuletzt editiert von matrose65
                      @jleg
                      ja das stimmt. aber zur Zeile 5 Feb23 06:32 habe ich folgendes Log
                      2025-02-23 06:32:34.849 - error: host.iobroker Caught by controller[0]: #
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[0]: # Fatal error in , line 0
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[0]: # Check failed: addr + aligned_size <= chunk_->area_end().
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[0]: #FailureMessage Object: 0x7f4869d3b620
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[0]: ----- Native stack trace -----
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[0]: 1: 0xd41421 [io.unifi.0]
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[0]: 2: 0x218caa1 V8_Fatal(char const*, ...) [io.unifi.0]
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[0]: 3: 0x11c39e1 v8::internal::Sweeper::RawSweep(v8::internal::Page*, v8::internal::FreeSpaceTreatmentMode, v8::internal::Sweeper::SweepingMode) [io.unifi.0]
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[0]: 4: 0x11c5496 [io.unifi.0]
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[1]: 5: 0x11c6e8c v8::internal::Sweeper::SweeperJob::RunImpl(v8::JobDelegate*, bool) [io.unifi.0]
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[2]: 6: 0x1d73538 v8::platform::DefaultJobWorker::Run() [io.unifi.0]
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[3]: 7: 0xd415c1 [io.unifi.0]
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[3]: 8: 0x7f486b5c91c4 [/lib/x86_64-linux-gnu/libc.so.6]
                      2025-02-23 06:32:34.850 - error: host.iobroker Caught by controller[3]: 9: 0x7f486b64985c [/lib/x86_64-linux-gnu/libc.so.6]
                      2025-02-23 06:32:34.850 - warn: host.iobroker instance system.adapter.unifi.0 terminated due to SIGILL
                      2025-02-23 06:32:34.851 - info: host.iobroker instance system.adapter.unifi.0 terminated with code null ()
                      2025-02-23 06:32:34.851 - info: host.iobroker Restart adapter system.adapter.unifi.0 because enabled
                      2025-02-23 06:32:36.262 - info: host.iobroker instance system.adapter.unifi.0 in version "0.7.0" started with pid 65661
                      2025-02-23 06:32:37.179 - info: unifi.0 (65661) starting. Version 0.7.0 in /opt/iobroker/node_modules/iobroker.unifi, node: v20.18.3, js-controller: 7.0.6
                      2025-02-23 06:32:37.233 - info: unifi.0 (65661) UniFi adapter is ready
                      und um 06:44 beginnt ein neuer Absturz
                      • M matrose65
                        @jleg
                        JLegJ Offline
                        JLegJ Offline
                        JLeg
                        SIGILL
                        ui, ein SIGILL - nicht gut; bedeutet "ungültiger Maschinencode" (der CPU!). Ist das zufällig ein älterer Prozessor, auf dem deine VM läuft?
                        (ich muss mich auch damit anfreunden, meinen guten alten "AMD Turion" durch was Neues zu ersetzen - ich bekomme diesen Fehler beim Ausführen des neuesten "Energiefluss-Erweitert"-Adapters, der inzwischen eine NPM-Lib zieht, die meine CPU nicht mehr "kann"; Downgrade (der Lib) hat zwar geholfen, ist aber nix auf Dauer...)
                        • JLegJ JLeg
                          SIGILL
                          matrose65
                          @jleg
                          das ist ein Intel NUC Kit NUC8i3BEH2 mit einem Intel i3-8109U,
                          • M matrose65
                            @jleg
                            JLegJ Offline
                            JLegJ Offline
                            JLeg
                            i3-8109U
                            hm, sollte neu genug sein - kann jedenfalls SSE4.2; das war bei mir zumindest das Problem.
                            Dann hilft nur "weiter suchen" ;-) - zu warm wird die Kiste (CPU) aber nicht? Die sollten dann zwar runtertakten, nach meiner Erfahrung tun sie das aber nicht immer ausreichend...
                            Vielleicht mal CPU-Temperaturen beobachten?
                              matrose65
                              @jleg
                              zu warm ist es nicht
                              coretemp-isa-0000
                              Adapter: ISA adapter
                              Package id 0:  +35.0°C  (high = +100.0°C, crit = +100.0°C)
                              Core 0:        +35.0°C  (high = +100.0°C, crit = +100.0°C)
                              Core 1:        +34.0°C  (high = +100.0°C, crit = +100.0°C)
                              • M matrose65
                                @jleg
                                coretemp-isa-0000
                                JLegJ Offline
                                JLegJ Offline
                                JLeg
                                @matrose65 was ich vergessen hatte - ist das dmesg oben aus der vm, oder vom host? Falls vm, am besten nochmal im Host schauen…
                                • JLegJ JLeg
                                  matrose65
                                  @jleg
                                  hier nun die dmesg -e vom Host ( ich kann da nicht viel verstehen)
                                  root@pve:~# dmesg -e
                                  [Feb27 18:36] Linux version 6.8.12-8-pve (build@proxmox) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-8 (2025-01-24T12:32Z) ()
                                  [  +0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.8.12-8-pve root=/dev/mapper/pve-root ro quiet
                                  [  +0.000000] KERNEL supported cpus:
                                  [  +0.000000]   Intel GenuineIntel
                                  [  +0.000000]   AMD AuthenticAMD
                                  [  +0.000000]   Hygon HygonGenuine
                                  [  +0.000000]   Centaur CentaurHauls
                                  [  +0.000000]   zhaoxin   Shanghai
                                  [  +0.000000] BIOS-provided physical RAM map:
                                  [  +0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000005efff] usable
                                  [  +0.000000] BIOS-e820: [mem 0x000000000005f000-0x000000000005ffff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x0000000000060000-0x000000000009ffff] usable
                                  [  +0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007babffff] usable
                                  [  +0.000000] BIOS-e820: [mem 0x000000007bac0000-0x000000007bf20fff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x000000007bf21000-0x000000007bf9dfff] ACPI data
                                  [  +0.000000] BIOS-e820: [mem 0x000000007bf9e000-0x000000007c3e6fff] ACPI NVS
                                  [  +0.000000] BIOS-e820: [mem 0x000000007c3e7000-0x000000007cc52fff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x000000007cc53000-0x000000007cd0dfff] type 20
                                  [  +0.000000] BIOS-e820: [mem 0x000000007cd0e000-0x000000007cd0efff] usable
                                  [  +0.000000] BIOS-e820: [mem 0x000000007cd0f000-0x000000007fffffff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
                                  [  +0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000087effffff] usable
                                  [  +0.000000] NX (Execute Disable) protection: active
                                  [  +0.000000] APIC: Static calls initialized
                                  [  +0.000000] efi: EFI v2.7 by American Megatrends
                                  [  +0.000000] efi: ACPI 2.0=0x7bf3a000 ACPI=0x7bf3a000 TPMFinalLog=0x7c391000 SMBIOS=0x7caa7000 SMBIOS 3.0=0x7caa6000 MEMATTR=0x79bea018 ESRT=0x7caaa518 MOKvar=0x7cad6000
                                  [  +0.000000] efi: Remove mem47: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
                                  [  +0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
                                  [  +0.000000] efi: Not removing mem48: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
                                  [  +0.000000] efi: Not removing mem49: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
                                  [  +0.000000] efi: Not removing mem50: MMIO range=[0xfed00000-0xfed03fff] (16KB) from e820 map
                                  [  +0.000000] efi: Not removing mem51: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
                                  [  +0.000000] efi: Remove mem52: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
                                  [  +0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
                                  [  +0.000000] secureboot: Secure boot disabled
                                  [  +0.000000] SMBIOS 3.2.1 present.
                                  [  +0.000000] DMI: Intel(R) Client Systems NUC8i3BEH/NUC8BEB, BIOS BECFL357.86A.0085.2020.1007.1917 10/07/2020
                                  [  +0.000000] tsc: Detected 3000.000 MHz processor
                                  [  +0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
                                  [  +0.000003] e820: remove [mem 0x000a0000-0x000fffff] usable
                                  [  +0.000008] last_pfn = 0x87f000 max_arch_pfn = 0x400000000
                                  [  +0.000004] MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
                                  [  +0.000002] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
                                  [  +0.000522] last_pfn = 0x7cd0f max_arch_pfn = 0x400000000
                                  [  +0.007344] found SMP MP-table at [mem 0x000fcd40-0x000fcd4f]
                                  [  +0.000013] esrt: Reserving ESRT space from 0x000000007caaa518 to 0x000000007caaa550.
                                  [  +0.000009] Using GB pages for direct mapping
                                  [  +0.000253] secureboot: Secure boot disabled
                                  [  +0.000000] RAMDISK: [mem 0x30af7000-0x34572fff]
                                  [  +0.000004] ACPI: Early table checksum verification disabled
                                  [  +0.000003] ACPI: RSDP 0x000000007BF3A000 000024 (v02 INTEL )
                                  [  +0.000005] ACPI: XSDT 0x000000007BF3A0A8 0000CC (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                  [  +0.000006] ACPI: FACP 0x000000007BF78BF8 000114 (v06 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                  [  +0.000005] ACPI: DSDT 0x000000007BF3A200 03E9F7 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                  [  +0.000004] ACPI: FACS 0x000000007C3E6080 000040
                                  [  +0.000003] ACPI: APIC 0x000000007BF78D10 000084 (v04 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                  [  +0.000003] ACPI: FPDT 0x000000007BF78D98 000044 (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                  [  +0.000004] ACPI: FIDT 0x000000007BF78DE0 00009C (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                  [  +0.000003] ACPI: MCFG 0x000000007BF78E80 00003C (v01 INTEL  NUC8i3BE 00000055 MSFT 00000097)
                                  [  +0.000003] ACPI: SSDT 0x000000007BF78EC0 001B1C (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                  [  +0.000004] ACPI: SSDT 0x000000007BF7A9E0 0031C6 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                  [  +0.000003] ACPI: HPET 0x000000007BF7DBA8 000038 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                  [  +0.000003] ACPI: SSDT 0x000000007BF7DBE0 000FAE (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                  [  +0.000004] ACPI: SSDT 0x000000007BF7EB90 003048 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                  [  +0.000003] ACPI: UEFI 0x000000007BF81BD8 000042 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                  [  +0.000003] ACPI: LPIT 0x000000007BF81C20 000094 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                  [  +0.000004] ACPI: SSDT 0x000000007BF81CB8 0027DE (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                  [  +0.000003] ACPI: SSDT 0x000000007BF84498 0008B8 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                  [  +0.000003] ACPI: DBGP 0x000000007BF84D50 000034 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                  [  +0.000004] ACPI: DBG2 0x000000007BF84D88 000054 (v00 INTEL  NUC8i3BE 00000055      01000013)
                                  [  +0.000003] ACPI: SSDT 0x000000007BF84DE0 000144 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                  [  +0.000003] ACPI: BGRT 0x000000007BF84F28 000038 (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                  [  +0.000004] ACPI: TPM2 0x000000007BF84F60 000034 (v04 INTEL  NUC8i3BE 00000055 AMI  00000000)
                                  [  +0.000003] ACPI: DMAR 0x000000007BF84F98 0000A8 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                  [  +0.000003] ACPI: WSMT 0x000000007BF85040 000028 (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                  [  +0.000003] ACPI: Reserving FACP table memory at [mem 0x7bf78bf8-0x7bf78d0b]
                                  [  +0.000002] ACPI: Reserving DSDT table memory at [mem 0x7bf3a200-0x7bf78bf6]
                                  [  +0.000001] ACPI: Reserving FACS table memory at [mem 0x7c3e6080-0x7c3e60bf]
                                  [  +0.000001] ACPI: Reserving APIC table memory at [mem 0x7bf78d10-0x7bf78d93]
                                  [  +0.000000] ACPI: Reserving FPDT table memory at [mem 0x7bf78d98-0x7bf78ddb]
                                  [  +0.000001] ACPI: Reserving FIDT table memory at [mem 0x7bf78de0-0x7bf78e7b]
                                  [  +0.000001] ACPI: Reserving MCFG table memory at [mem 0x7bf78e80-0x7bf78ebb]
                                  [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf78ec0-0x7bf7a9db]
                                  [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf7a9e0-0x7bf7dba5]
                                  [  +0.000001] ACPI: Reserving HPET table memory at [mem 0x7bf7dba8-0x7bf7dbdf]
                                  [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf7dbe0-0x7bf7eb8d]
                                  [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf7eb90-0x7bf81bd7]
                                  [  +0.000000] ACPI: Reserving UEFI table memory at [mem 0x7bf81bd8-0x7bf81c19]
                                  [  +0.000001] ACPI: Reserving LPIT table memory at [mem 0x7bf81c20-0x7bf81cb3]
                                  [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf81cb8-0x7bf84495]
                                  [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf84498-0x7bf84d4f]
                                  [  +0.000001] ACPI: Reserving DBGP table memory at [mem 0x7bf84d50-0x7bf84d83]
                                  [  +0.000001] ACPI: Reserving DBG2 table memory at [mem 0x7bf84d88-0x7bf84ddb]
                                  [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf84de0-0x7bf84f23]
                                  [  +0.000001] ACPI: Reserving BGRT table memory at [mem 0x7bf84f28-0x7bf84f5f]
                                  [  +0.000001] ACPI: Reserving TPM2 table memory at [mem 0x7bf84f60-0x7bf84f93]
                                  [  +0.000001] ACPI: Reserving DMAR table memory at [mem 0x7bf84f98-0x7bf8503f]
                                  [  +0.000000] ACPI: Reserving WSMT table memory at [mem 0x7bf85040-0x7bf85067]
                                  [  +0.000169] No NUMA configuration found
                                  [  +0.000002] Faking a node at [mem 0x0000000000000000-0x000000087effffff]
                                  [  +0.000008] NODE_DATA(0) allocated [mem 0x87efd5000-0x87effffff]
                                  [  +0.000214] Zone ranges:
                                  [  +0.000001]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
                                  [  +0.000002]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
                                  [  +0.000002]   Normal   [mem 0x0000000100000000-0x000000087effffff]
                                  [  +0.000001]   Device   empty
                                  [  +0.000001] Movable zone start for each node
                                  [  +0.000003] Early memory node ranges
                                  [  +0.000001]   node   0: [mem 0x0000000000001000-0x000000000005efff]
                                  [  +0.000001]   node   0: [mem 0x0000000000060000-0x000000000009ffff]
                                  [  +0.000001]   node   0: [mem 0x0000000000100000-0x000000007babffff]
                                  [  +0.000002]   node   0: [mem 0x000000007cd0e000-0x000000007cd0efff]
                                  [  +0.000000]   node   0: [mem 0x0000000100000000-0x000000087effffff]
                                  [  +0.000004] Initmem setup node 0 [mem 0x0000000000001000-0x000000087effffff]
                                  [  +0.000004] On node 0, zone DMA: 1 pages in unavailable ranges
                                  [  +0.000002] On node 0, zone DMA: 1 pages in unavailable ranges
                                  [  +0.000023] On node 0, zone DMA: 96 pages in unavailable ranges
                                  [  +0.002966] On node 0, zone DMA32: 4686 pages in unavailable ranges
                                  [  +0.038058] On node 0, zone Normal: 13041 pages in unavailable ranges
                                  [  +0.000042] On node 0, zone Normal: 4096 pages in unavailable ranges
                                  [  +0.000016] Reserving Intel graphics memory at [mem 0x7e000000-0x7fffffff]
                                  [  +0.000356] ACPI: PM-Timer IO Port: 0x1808
                                  [  +0.000008] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
                                  [  +0.000002] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
                                  [  +0.000001] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
                                  [  +0.000001] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
                                  [  +0.000052] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
                                  [  +0.000003] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
                                  [  +0.000002] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
                                  [  +0.000004] ACPI: Using ACPI (MADT) for SMP configuration information
                                  [  +0.000002] ACPI: HPET id: 0x8086a201 base: 0xfed00000
                                  [  +0.000007] e820: update [mem 0x77b7b000-0x77c14fff] usable ==> reserved
                                  [  +0.000010] TSC deadline timer available
                                  [  +0.000001] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
                                  [  +0.000015] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
                                  [  +0.000002] PM: hibernation: Registered nosave memory: [mem 0x0005f000-0x0005ffff]
                                  [  +0.000002] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0x77b7b000-0x77c14fff]
                                  [  +0.000002] PM: hibernation: Registered nosave memory: [mem 0x7bac0000-0x7bf20fff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0x7bf21000-0x7bf9dfff]
                                  [  +0.000000] PM: hibernation: Registered nosave memory: [mem 0x7bf9e000-0x7c3e6fff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0x7c3e7000-0x7cc52fff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0x7cc53000-0x7cd0dfff]
                                  [  +0.000002] PM: hibernation: Registered nosave memory: [mem 0x7cd0f000-0x7fffffff]
                                  [  +0.000000] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xfdffffff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
                                  [  +0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
                                  [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
                                  [  +0.000001] [mem 0x80000000-0xfdffffff] available for PCI devices
                                  [  +0.000001] Booting paravirtualized kernel on bare hardware
                                  [  +0.000002] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
                                  [  +0.000006] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
                                  [  +0.000236] percpu: Embedded 86 pages/cpu s229376 r8192 d114688 u524288
                                  [  +0.000006] pcpu-alloc: s229376 r8192 d114688 u524288 alloc=1*2097152
                                  [  +0.000002] pcpu-alloc: [0] 0 1 2 3
                                  [  +0.000019] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.12-8-pve root=/dev/mapper/pve-root ro quiet
                                  [  +0.000046] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.8.12-8-pve", will be passed to user space.
                                  [  +0.000027] random: crng init done
                                  [  +0.002257] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
                                  [  +0.001140] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
                                  [  +0.000069] Fallback order for Node 0: 0
                                  [  +0.000003] Built 1 zonelists, mobility grouping on.  Total pages: 8235797
                                  [  +0.000001] Policy zone: Normal
                                  [  +0.000005] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
                                  [  +0.000008] software IO TLB: area num 4.
                                  [  +0.069158] Memory: 32665912K/33466748K available (20480K kernel code, 3642K rwdata, 13456K rodata, 4816K init, 5692K bss, 800576K reserved, 0K cma-reserved)
                                  [  +0.000972] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                  [  +0.000013] Kernel/User page tables isolation: enabled
                                  [  +0.000026] ftrace: allocating 55402 entries in 217 pages
                                  [  +0.009193] ftrace: allocated 217 pages with 5 groups
                                  [  +0.000772] Dynamic Preempt: voluntary
                                  [  +0.000058] rcu: Preemptible hierarchical RCU implementation.
                                  [  +0.000001] rcu:      RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
                                  [  +0.000001]   Trampoline variant of Tasks RCU enabled.
                                  [  +0.000001]   Rude variant of Tasks RCU enabled.
                                  [  +0.000000]   Tracing variant of Tasks RCU enabled.
                                  [  +0.000001] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
                                  [  +0.000001] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                                  [  +0.002950] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
                                  [  +0.000295] rcu: srcu_init: Setting srcu_struct sizes based on contention.
                                  [  +0.000290] Console: colour dummy device 80x25
                                  [  +0.000003] printk: legacy console [tty0] enabled
                                  [  +0.000042] ACPI: Core revision 20230628
                                  [  +0.000219] hpet: HPET dysfunctional in PC10. Force disabled.
                                  [  +0.000001] APIC: Switch to symmetric I/O mode setup
                                  [  +0.000002] DMAR: Host address width 39
                                  [  +0.000002] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
                                  [  +0.000009] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
                                  [  +0.000003] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
                                  [  +0.000004] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
                                  [  +0.000002] DMAR: RMRR base: 0x0000007bed4000 end: 0x0000007bef3fff
                                  [  +0.000002] DMAR: RMRR base: 0x0000007d800000 end: 0x0000007fffffff
                                  [  +0.000002] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
                                  [  +0.000002] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
                                  [  +0.000001] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
                                  [  +0.002353] DMAR-IR: Enabled IRQ remapping in x2apic mode
                                  [  +0.000002] x2apic enabled
                                  [  +0.000073] APIC: Switched APIC routing to: cluster x2apic
                                  [  +0.005847] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b3e459bf4c, max_idle_ns: 440795289890 ns
                                  [  +0.000006] Calibrating delay loop (skipped), value calculated using timer frequency.. 6000.00 BogoMIPS (lpj=3000000)
                                  [  +0.000026] x86/cpu: SGX disabled by BIOS.
                                  [  +0.000007] CPU0: Thermal monitoring enabled (TM1)
                                  [  +0.000044] process: using mwait in idle threads
                                  [  +0.000003] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
                                  [  +0.000002] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
                                  [  +0.000003] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
                                  [  +0.000002] Spectre V2 : Mitigation: IBRS
                                  [  +0.000001] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
                                  [  +0.000001] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
                                  [  +0.000001] RETBleed: Mitigation: IBRS
                                  [  +0.000001] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
                                  [  +0.000002] Spectre V2 : User space: Mitigation: STIBP via prctl
                                  [  +0.000001] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
                                  [  +0.000006] MDS: Mitigation: Clear CPU buffers
                                  [  +0.000001] MMIO Stale Data: Mitigation: Clear CPU buffers
                                  [  +0.000004] SRBDS: Mitigation: Microcode
                                  [  +0.000001] GDS: Vulnerable: No microcode
                                  [  +0.000006] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
                                  [  +0.000001] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
                                  [  +0.000002] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
                                  [  +0.000001] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
                                  [  +0.000001] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
                                  [  +0.000002] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
                                  [  +0.000002] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
                                  [  +0.000002] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
                                  [  +0.000001] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
                                  [  +0.000873] Freeing SMP alternatives memory: 48K
                                  [  +0.000000] pid_max: default: 32768 minimum: 301
                                  [  +0.000000] LSM: initializing lsm=lockdown,capability,yama,apparmor,integrity
                                  [  +0.000000] Yama: becoming mindful.
                                  [  +0.000000] AppArmor: AppArmor initialized
                                  [  +0.000000] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
                                  [  +0.000000] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
                                  [  +0.000000] smpboot: CPU0: Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz (family: 0x6, model: 0x8e, stepping: 0xa)
                                  [  +0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
                                  [  +0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
                                  [  +0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
                                  [  +0.000000] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
                                  [  +0.000000] ... version:                4
                                  [  +0.000000] ... bit width:              48
                                  [  +0.000000] ... generic registers:      4
                                  [  +0.000000] ... value mask:             0000ffffffffffff
                                  [  +0.000000] ... max period:             00007fffffffffff
                                  [  +0.000000] ... fixed-purpose events:   3
                                  [  +0.000000] ... event mask:             000000070000000f
                                  [  +0.000000] signal: max sigframe size: 2032
                                  [  +0.000000] Estimated ratio of average max frequency by base frequency (times 1024): 1228
                                  [  +0.000000] rcu: Hierarchical SRCU implementation.
                                  [  +0.000000] rcu:      Max phase no-delay instances is 400.
                                  [  +0.000000] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
                                  [  +0.000000] smp: Bringing up secondary CPUs ...
                                  [  +0.000108] smpboot: x86: Booting SMP configuration:
                                  [  +0.000001] .... node  #0, CPUs:      #1 #2 #3
                                  [  +0.001127] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
                                  [  +0.000000] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
                                  [  +0.000000] smp: Brought up 1 node, 4 CPUs
                                  [  +0.000000] smpboot: Max logical packages: 1
                                  [  +0.000000] smpboot: Total of 4 processors activated (24000.00 BogoMIPS)
                                  [  +0.001816] devtmpfs: initialized
                                  [  +0.000000] x86/mm: Memory block size: 128MB
                                  [  +0.003226] ACPI: PM: Registering ACPI NVS region [mem 0x7bf9e000-0x7c3e6fff] (4493312 bytes)
                                  [  +0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
                                  [  +0.000000] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                                  [  +0.000000] pinctrl core: initialized pinctrl subsystem
                                  [  +0.000224] PM: RTC time: 17:36:06, date: 2025-02-27
                                  [  +0.000822] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                                  [  +0.000379] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
                                  [  +0.000247] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                                  [  +0.000253] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
                                  [  +0.000024] audit: initializing netlink subsys (disabled)
                                  [  +0.000012] audit: type=2000 audit(1740677766.009:1): state=initialized audit_enabled=0 res=1
                                  [  +0.000000] thermal_sys: Registered thermal governor 'fair_share'
                                  [  +0.000000] thermal_sys: Registered thermal governor 'bang_bang'
                                  [  +0.000000] thermal_sys: Registered thermal governor 'step_wise'
                                  [  +0.000000] thermal_sys: Registered thermal governor 'user_space'
                                  [  +0.000000] thermal_sys: Registered thermal governor 'power_allocator'
                                  [  +0.000000] EISA bus registered
                                  [  +0.000000] cpuidle: using governor ladder
                                  [  +0.000000] cpuidle: using governor menu
                                  [  +0.000008] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
                                  [  +0.000000] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
                                  [  +0.000000] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
                                  [  +0.000000] PCI: Using configuration type 1 for base access
                                  [  +0.000057] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
                                  [  +0.000721] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
                                  [  +0.000003] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
                                  [  +0.000003] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
                                  [  +0.000001] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
                                  [  +0.000128] ACPI: Added _OSI(Module Device)
                                  [  +0.000003] ACPI: Added _OSI(Processor Device)
                                  [  +0.000002] ACPI: Added _OSI(3.0 _SCP Extensions)
                                  [  +0.000001] ACPI: Added _OSI(Processor Aggregator Device)
                                  [  +0.095577] ACPI: 8 ACPI AML tables successfully acquired and loaded
                                  [  +0.012648] ACPI: Dynamic OEM Table Load:
                                  [  +0.000009] ACPI: SSDT 0xFFFF98A8417E3C00 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
                                  [  +0.001858] ACPI: Dynamic OEM Table Load:
                                  [  +0.000006] ACPI: SSDT 0xFFFF98A841D5A000 000689 (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
                                  [  +0.001947] ACPI: Dynamic OEM Table Load:
                                  [  +0.000005] ACPI: SSDT 0xFFFF98A841CCF800 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160527)
                                  [  +0.002177] ACPI: Dynamic OEM Table Load:
                                  [  +0.000007] ACPI: SSDT 0xFFFF98A841D59000 0005FC (v02 PmRef  ApIst    00003000 INTL 20160527)
                                  [  +0.001931] ACPI: Dynamic OEM Table Load:
                                  [  +0.000007] ACPI: SSDT 0xFFFF98A8417E3800 000317 (v02 PmRef  ApHwp    00003000 INTL 20160527)
                                  [  +0.001993] ACPI: Dynamic OEM Table Load:
                                  [  +0.000007] ACPI: SSDT 0xFFFF98A841D69000 000AB0 (v02 PmRef  ApPsd    00003000 INTL 20160527)
                                  [  +0.002765] ACPI: Dynamic OEM Table Load:
                                  [  +0.000005] ACPI: SSDT 0xFFFF98A8417E0000 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
                                  [  +0.004387] ACPI: _OSC evaluated successfully for all CPUs
                                  [  +0.000114] ACPI: EC: EC started
                                  [  +0.000002] ACPI: EC: interrupt blocked
                                  [  +0.001139] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
                                  [  +0.000003] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC used to handle transactions
                                  [  +0.000002] ACPI: Interpreter enabled
                                  [  +0.000047] ACPI: PM: (supports S0 S3 S4 S5)
                                  [  +0.000002] ACPI: Using IOAPIC for interrupt routing
                                  [  +0.002288] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
                                  [  +0.000002] PCI: Using E820 reservations for host bridge windows
                                  [  +0.001848] ACPI: Enabled 8 GPEs in block 00 to 7F
                                  [  +0.020305] ACPI: \_SB_.PCI0.XDCI.USBC: New power resource
                                  [  +0.004809] ACPI: \_SB_.PCI0.SAT0.VOL0.V0PR: New power resource
                                  [  +0.000570] ACPI: \_SB_.PCI0.SAT0.VOL1.V1PR: New power resource
                                  [  +0.000564] ACPI: \_SB_.PCI0.SAT0.VOL2.V2PR: New power resource
                                  [  +0.016857] ACPI: \_SB_.PCI0.CNVW.WRST: New power resource
                                  [  +0.006638] ACPI: \_TZ_.FN00: New power resource
                                  [  +0.000109] ACPI: \_TZ_.FN01: New power resource
                                  [  +0.000111] ACPI: \_TZ_.FN02: New power resource
                                  [  +0.000117] ACPI: \_TZ_.FN03: New power resource
                                  [  +0.000110] ACPI: \_TZ_.FN04: New power resource
                                  [  +0.000917] ACPI: \PIN_: New power resource
                                  [  +0.001337] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
                                  [  +0.000009] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
                                  [  +0.001531] acpi PNP0A08:00: _OSC: platform does not support [AER]
                                  [  +0.003020] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
                                  [  +0.000002] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
                                  [  +0.001772] PCI host bridge to bus 0000:00
                                  [  +0.000003] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
                                  [  +0.000003] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
                                  [  +0.000001] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
                                  [  +0.000002] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
                                  [  +0.000002] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
                                  [  +0.000002] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
                                  [  +0.000002] pci_bus 0000:00: root bus resource [bus 00-fe]
                                  [  +0.000112] pci 0000:00:00.0: [8086:3ecc] type 00 class 0x060000 conventional PCI endpoint
                                  [  +0.000098] pci 0000:00:02.0: [8086:3ea5] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
                                  [  +0.000011] pci 0000:00:02.0: BAR 0 [mem 0x90000000-0x90ffffff 64bit]
                                  [  +0.000007] pci 0000:00:02.0: BAR 2 [mem 0x80000000-0x8fffffff 64bit pref]
                                  [  +0.000005] pci 0000:00:02.0: BAR 4 [io  0x3000-0x303f]
                                  [  +0.000020] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
                                  [  +0.000268] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000 conventional PCI endpoint
                                  [  +0.000013] pci 0000:00:08.0: BAR 0 [mem 0x4000016000-0x4000016fff 64bit]
                                  [  +0.000140] pci 0000:00:12.0: [8086:9df9] type 00 class 0x118000 conventional PCI endpoint
                                  [  +0.000023] pci 0000:00:12.0: BAR 0 [mem 0x4000015000-0x4000015fff 64bit]
                                  [  +0.000176] pci 0000:00:14.0: [8086:9ded] type 00 class 0x0c0330 conventional PCI endpoint
                                  [  +0.000019] pci 0000:00:14.0: BAR 0 [mem 0x4000000000-0x400000ffff 64bit]
                                  [  +0.000067] pci 0000:00:14.0: PME# supported from D3hot D3cold
                                  [  +0.002214] pci 0000:00:14.2: [8086:9def] type 00 class 0x050000 conventional PCI endpoint
                                  [  +0.000021] pci 0000:00:14.2: BAR 0 [mem 0x4000010000-0x4000011fff 64bit]
                                  [  +0.000014] pci 0000:00:14.2: BAR 2 [mem 0x4000014000-0x4000014fff 64bit]
                                  [  +0.000154] pci 0000:00:16.0: [8086:9de0] type 00 class 0x078000 conventional PCI endpoint
                                  [  +0.000024] pci 0000:00:16.0: BAR 0 [mem 0x4000013000-0x4000013fff 64bit]
                                  [  +0.000082] pci 0000:00:16.0: PME# supported from D3hot
                                  [  +0.000647] pci 0000:00:17.0: [8086:9dd3] type 00 class 0x010601 conventional PCI endpoint
                                  [  +0.000018] pci 0000:00:17.0: BAR 0 [mem 0x91120000-0x91121fff]
                                  [  +0.000011] pci 0000:00:17.0: BAR 1 [mem 0x91123000-0x911230ff]
                                  [  +0.000009] pci 0000:00:17.0: BAR 2 [io  0x3090-0x3097]
                                  [  +0.000012] pci 0000:00:17.0: BAR 3 [io  0x3080-0x3083]
                                  [  +0.000008] pci 0000:00:17.0: BAR 4 [io  0x3060-0x307f]
                                  [  +0.000009] pci 0000:00:17.0: BAR 5 [mem 0x91122000-0x911227ff]
                                  [  +0.000049] pci 0000:00:17.0: PME# supported from D3hot
                                  [  +0.000560] pci 0000:00:1d.0: [8086:9db0] type 01 class 0x060400 PCIe Root Port
                                  [  +0.000041] pci 0000:00:1d.0: PCI bridge to [bus 01]
                                  [  +0.000008] pci 0000:00:1d.0:   bridge window [mem 0x91000000-0x910fffff]
                                  [  +0.000096] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
                                  [  +0.000048] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
                                  [  +0.001070] pci 0000:00:1f.0: [8086:9d84] type 00 class 0x060100 conventional PCI endpoint
                                  [  +0.000529] pci 0000:00:1f.4: [8086:9da3] type 00 class 0x0c0500 conventional PCI endpoint
                                  [  +0.000028] pci 0000:00:1f.4: BAR 0 [mem 0x4000012000-0x40000120ff 64bit]
                                  [  +0.000030] pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
                                  [  +0.000338] pci 0000:00:1f.5: [8086:9da4] type 00 class 0x0c8000 conventional PCI endpoint
                                  [  +0.000019] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
                                  [  +0.000142] pci 0000:00:1f.6: [8086:15be] type 00 class 0x020000 conventional PCI endpoint
                                  [  +0.000038] pci 0000:00:1f.6: BAR 0 [mem 0x91100000-0x9111ffff]
                                  [  +0.000202] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
                                  [  +0.000430] pci 0000:01:00.0: [15b7:5017] type 00 class 0x010802 PCIe Endpoint
                                  [  +0.000022] pci 0000:01:00.0: BAR 0 [mem 0x91000000-0x91003fff 64bit]
                                  [  +0.000195] pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:1d.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
                                  [  +0.000140] pci 0000:00:1d.0: PCI bridge to [bus 01]
                                  [  +0.002607] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
                                  [  +0.000110] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
                                  [  +0.000108] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
                                  [  +0.000107] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
                                  [  +0.000107] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
                                  [  +0.000112] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
                                  [  +0.000109] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
                                  [  +0.000107] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
                                  [  +0.006614] ACPI: EC: interrupt unblocked
                                  [  +0.000002] ACPI: EC: event unblocked
                                  [  +0.000013] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
                                  [  +0.000001] ACPI: EC: GPE=0x14
                                  [  +0.000002] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC initialization complete
                                  [  +0.000002] ACPI: \_SB_.PCI0.LPCB.H_EC: EC: Used to handle transactions and events
                                  [  +0.000128] iommu: Default domain type: Translated
                                  [  +0.000000] iommu: DMA domain TLB invalidation policy: lazy mode
                                  [  +0.001128] SCSI subsystem initialized
                                  [  +0.000006] libata version 3.00 loaded.
                                  [  +0.000000] ACPI: bus type USB registered
                                  [  +0.000000] usbcore: registered new interface driver usbfs
                                  [  +0.000000] usbcore: registered new interface driver hub
                                  [  +0.000000] usbcore: registered new device driver usb
                                  [  +0.000000] pps_core: LinuxPPS API ver. 1 registered
                                  [  +0.000000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                                  [  +0.000000] PTP clock support registered
                                  [  +0.000000] EDAC MC: Ver: 3.0.0
                                  [  +0.000065] efivars: Registered efivars operations
                                  [  +0.000000] NetLabel: Initializing
                                  [  +0.000000] NetLabel:  domain hash size = 128
                                  [  +0.000000] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
                                  [  +0.000000] NetLabel:  unlabeled traffic allowed by default
                                  [  +0.000797] mctp: management component transport protocol core
                                  [  +0.000000] NET: Registered PF_MCTP protocol family
                                  [  +0.000000] PCI: Using ACPI for IRQ routing
                                  [  +0.041329] PCI: pci_cache_line_size set to 64 bytes
                                  [  +0.000209] e820: reserve RAM buffer [mem 0x0005f000-0x0005ffff]
                                  [  +0.000002] e820: reserve RAM buffer [mem 0x77b7b000-0x77ffffff]
                                  [  +0.000002] e820: reserve RAM buffer [mem 0x7bac0000-0x7bffffff]
                                  [  +0.000001] e820: reserve RAM buffer [mem 0x7cd0f000-0x7fffffff]
                                  [  +0.000001] e820: reserve RAM buffer [mem 0x87f000000-0x87fffffff]
                                  [  +0.000045] pci 0000:00:02.0: vgaarb: setting as boot VGA device
                                  [  +0.000000] pci 0000:00:02.0: vgaarb: bridge control possible
                                  [  +0.000000] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
                                  [  +0.000000] vgaarb: loaded
                                  [  +0.000000] clocksource: Switched to clocksource tsc-early
                                  [  +0.000188] VFS: Disk quotas dquot_6.6.0
                                  [  +0.000015] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                                  [  +0.000137] AppArmor: AppArmor Filesystem Enabled
                                  [  +0.000030] pnp: PnP ACPI init
                                  [  +0.000116] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
                                  [  +0.000497] system 00:01: [io  0x0a00-0x0a1f] has been reserved
                                  [  +0.000003] system 00:01: [io  0x0a20-0x0a2f] has been reserved
                                  [  +0.000002] system 00:01: [io  0x0a30-0x0a3f] has been reserved
                                  [  +0.000002] system 00:01: [io  0x0a40-0x0a4f] has been reserved
                                  [  +0.000002] system 00:01: [io  0x0a50-0x0a5f] has been reserved
                                  [  +0.000002] system 00:01: [io  0x0a60-0x0a6f] has been reserved
                                  [  +0.000283] system 00:02: [io  0x0680-0x069f] has been reserved
                                  [  +0.000003] system 00:02: [io  0x164e-0x164f] has been reserved
                                  [  +0.000144] system 00:03: [io  0x1854-0x1857] has been reserved
                                  [  +0.000285] system 00:04: [mem 0xfed10000-0xfed17fff] has been reserved
                                  [  +0.000003] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
                                  [  +0.000002] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
                                  [  +0.000002] system 00:04: [mem 0xe0000000-0xefffffff] has been reserved
                                  [  +0.000002] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
                                  [  +0.000002] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
                                  [  +0.000002] system 00:04: [mem 0xfed45000-0xfed8ffff] has been reserved
                                  [  +0.000002] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
                                  [  +0.000271] system 00:05: [io  0x1800-0x18fe] could not be reserved
                                  [  +0.000003] system 00:05: [mem 0xfd000000-0xfd69ffff] has been reserved
                                  [  +0.000002] system 00:05: [mem 0xfd6b0000-0xfd6cffff] has been reserved
                                  [  +0.000002] system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
                                  [  +0.000002] system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
                                  [  +0.000002] system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
                                  [  +0.000002] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
                                  [  +0.000370] system 00:06: [io  0x2000-0x20fe] has been reserved
                                  [  +0.002626] pnp: PnP ACPI: found 8 devices
                                  [  +0.006195] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
                                  [  +0.000073] NET: Registered PF_INET protocol family
                                  [  +0.000128] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
                                  [  +0.018063] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
                                  [  +0.000035] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
                                  [  +0.000108] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
                                  [  +0.000391] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
                                  [  +0.000227] TCP: Hash tables configured (established 262144 bind 65536)
                                  [  +0.000119] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
                                  [  +0.000083] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
                                  [  +0.000075] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
                                  [  +0.000096] NET: Registered PF_UNIX/PF_LOCAL protocol family
                                  [  +0.000008] NET: Registered PF_XDP protocol family
                                  [  +0.000012] pci 0000:00:1d.0: PCI bridge to [bus 01]
                                  [  +0.000018] pci 0000:00:1d.0:   bridge window [mem 0x91000000-0x910fffff]
                                  [  +0.000036] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
                                  [  +0.000003] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
                                  [  +0.000002] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
                                  [  +0.000002] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
                                  [  +0.000001] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
                                  [  +0.000002] pci_bus 0000:00: resource 9 [mem 0xfc800000-0xfe7fffff window]
                                  [  +0.000002] pci_bus 0000:01: resource 1 [mem 0x91000000-0x910fffff]
                                  [  +0.000799] PCI: CLS 64 bytes, default 64
                                  [  +0.000049] DMAR: No ATSR found
                                  [  +0.000001] DMAR: No SATC found
                                  [  +0.000001] DMAR: IOMMU feature fl1gp_support inconsistent
                                  [  +0.000001] DMAR: IOMMU feature pgsel_inv inconsistent
                                  [  +0.000001] DMAR: IOMMU feature nwfs inconsistent
                                  [  +0.000001] DMAR: IOMMU feature pasid inconsistent
                                  [  +0.000001] DMAR: IOMMU feature eafs inconsistent
                                  [  +0.000001] DMAR: IOMMU feature prs inconsistent
                                  [  +0.000001] DMAR: IOMMU feature nest inconsistent
                                  [  +0.000001] DMAR: IOMMU feature mts inconsistent
                                  [  +0.000001] DMAR: IOMMU feature sc_support inconsistent
                                  [  +0.000001] DMAR: IOMMU feature dev_iotlb_support inconsistent
                                  [  +0.000001] DMAR: dmar0: Using Queued invalidation
                                  [  +0.000004] DMAR: dmar1: Using Queued invalidation
                                  [  +0.000027] Trying to unpack rootfs image as initramfs...
                                  [  +0.000195] pci 0000:00:02.0: Adding to iommu group 0
                                  [  +0.000454] pci 0000:00:00.0: Adding to iommu group 1
                                  [  +0.000010] pci 0000:00:08.0: Adding to iommu group 2
                                  [  +0.000015] pci 0000:00:12.0: Adding to iommu group 3
                                  [  +0.000014] pci 0000:00:14.0: Adding to iommu group 4
                                  [  +0.000008] pci 0000:00:14.2: Adding to iommu group 4
                                  [  +0.000011] pci 0000:00:16.0: Adding to iommu group 5
                                  [  +0.000010] pci 0000:00:17.0: Adding to iommu group 6
                                  [  +0.000013] pci 0000:00:1d.0: Adding to iommu group 7
                                  [  +0.000020] pci 0000:00:1f.0: Adding to iommu group 8
                                  [  +0.000009] pci 0000:00:1f.4: Adding to iommu group 8
                                  [  +0.000009] pci 0000:00:1f.5: Adding to iommu group 8
                                  [  +0.000009] pci 0000:00:1f.6: Adding to iommu group 8
                                  [  +0.000012] pci 0000:01:00.0: Adding to iommu group 9
                                  [  +0.000668] DMAR: Intel(R) Virtualization Technology for Directed I/O
                                  [  +0.000002] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
                                  [  +0.000002] software IO TLB: mapped [mem 0x000000006d9f1000-0x00000000719f1000] (64MB)
                                  [  +0.000165] platform rtc_cmos: registered platform RTC device (no PNP device found)
                                  [  +0.000454] Initialise system trusted keyrings
                                  [  +0.000007] Key type blacklist registered
                                  [  +0.000049] workingset: timestamp_bits=36 max_order=23 bucket_order=0
                                  [  +0.000018] zbud: loaded
                                  [  +0.000393] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                                  [  +0.000126] fuse: init (API version 7.39)
                                  [  +0.000144] integrity: Platform Keyring initialized
                                  [  +0.000006] integrity: Machine keyring initialized
                                  [  +0.021652] Key type asymmetric registered
                                  [  +0.000006] Asymmetric key parser 'x509' registered
                                  [  +0.000033] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
                                  [  +0.000063] io scheduler mq-deadline registered
                                  [  +0.003263] pcieport 0000:00:1d.0: PME: Signaling with IRQ 122
                                  [  +0.000149] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
                                  [  +0.000579] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
                                  [  +0.000028] ACPI: button: Sleep Button [SLPB]
                                  [  +0.000033] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
                                  [  +0.000017] ACPI: button: Power Button [PWRB]
                                  [  +0.000033] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
                                  [  +0.000042] ACPI: button: Power Button [PWRF]
                                  [  +0.000442] ACPI: thermal: [Firmware Bug]: No valid trip points!
                                  [  +0.000775] thermal LNXTHERM:01: registered as thermal_zone0
                                  [  +0.000004] ACPI: thermal: Thermal Zone [TZ00] (28 C)
                                  [  +0.000350] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
                                  [  +0.003432] hpet_acpi_add: no address or irqs in _CRS
                                  [  +0.000060] Linux agpgart interface v0.103
                                  [  +0.009358] loop: module loaded
                                  [  +0.000309] ACPI: bus type drm_connector registered
                                  [  +0.000356] tun: Universal TUN/TAP device driver, 1.6
                                  [  +0.000078] PPP generic driver version 2.4.2
                                  [  +0.000120] i8042: PNP: No PS/2 controller found.
                                  [  +0.000002] i8042: Probing ports directly.
                                  [  +0.001176] i8042: No controller found
                                  [  +0.000121] mousedev: PS/2 mouse device common for all mice
                                  [  +0.000252] rtc_cmos rtc_cmos: RTC can wake from S4
                                  [  +0.001201] rtc_cmos rtc_cmos: registered as rtc0
                                  [  +0.000231] rtc_cmos rtc_cmos: setting system clock to 2025-02-27T17:36:06 UTC (1740677766)
                                  [  +0.000040] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
                                  [  +0.000013] i2c_dev: i2c /dev entries driver
                                  [  +0.000266] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
                                  [  +0.000018] device-mapper: uevent: version 1.0.3
                                  [  +0.000085] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
                                  [  +0.000031] platform eisa.0: Probing EISA bus 0
                                  [  +0.000006] platform eisa.0: EISA: Cannot allocate resource for mainboard
                                  [  +0.000003] platform eisa.0: Cannot allocate resource for EISA slot 1
                                  [  +0.000003] platform eisa.0: Cannot allocate resource for EISA slot 2
                                  [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 3
                                  [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 4
                                  [  +0.000003] platform eisa.0: Cannot allocate resource for EISA slot 5
                                  [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 6
                                  [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 7
                                  [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 8
                                  [  +0.000002] platform eisa.0: EISA: Detected 0 cards
                                  [  +0.000005] intel_pstate: Intel P-state driver initializing
                                  [  +0.000229] intel_pstate: HWP enabled
                                  [  +0.000174] ledtrig-cpu: registered to indicate activity on CPUs
                                  [  +0.000185] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
                                  [  +0.000232] fbcon: Deferring console take-over
                                  [  +0.000003] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
                                  [  +0.000079] drop_monitor: Initializing network drop monitor service
                                  [  +0.000113] NET: Registered PF_INET6 protocol family
                                  [  +0.326773] Freeing initrd memory: 59888K
                                  [  +0.006651] Segment Routing with IPv6
                                  [  +0.000014] In-situ OAM (IOAM) with IPv6
                                  [  +0.000025] NET: Registered PF_PACKET protocol family
                                  [  +0.000017] Bridge firewalling registered
                                  [  +0.000027] Key type dns_resolver registered
                                  [  +0.000340] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
                                  [  +0.000074] microcode: Current revision: 0x000000d6
                                  [  +0.000139] IPI shorthand broadcast: enabled
                                  [  +0.001600] sched_clock: Marking stable (816001173, 8636385)->(870583955, -45946397)
                                  [  +0.000156] registered taskstats version 1
                                  [  +0.000176] Loading compiled-in X.509 certificates
                                  [  +0.000454] Loaded X.509 cert 'Build time autogenerated kernel key: 1337ca12f22f1729e731a6737b914ad4e01db977'
                                  [  +0.003566] Key type .fscrypt registered
                                  [  +0.000002] Key type fscrypt-provisioning registered
                                  [  +0.000041] Key type trusted registered
                                  [  +0.015393] Key type encrypted registered
                                  [  +0.000006] AppArmor: AppArmor sha256 policy hashing enabled
                                  [  +0.000695] integrity: Loading X.509 certificate: UEFI:db
                                  [  +0.000032] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
                                  [  +0.000001] integrity: Loading X.509 certificate: UEFI:db
                                  [  +0.000016] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
                                  [  +0.000327] integrity: Loaded X.509 cert 'CISD FW Update - Certificate: 068268b4a41c93854262d49b4f788f13'
                                  [  +0.000610] Loading compiled-in module X.509 certificates
                                  [  +0.000417] Loaded X.509 cert 'Build time autogenerated kernel key: 1337ca12f22f1729e731a6737b914ad4e01db977'
                                  [  +0.000003] ima: Allocated hash algorithm: sha256
                                  [  +0.017344] ima: No architecture policies found
                                  [  +0.000013] evm: Initialising EVM extended attributes:
                                  [  +0.000001] evm: security.selinux
                                  [  +0.000002] evm: security.SMACK64
                                  [  +0.000000] evm: security.SMACK64EXEC
                                  [  +0.000001] evm: security.SMACK64TRANSMUTE
                                  [  +0.000001] evm: security.SMACK64MMAP
                                  [  +0.000001] evm: security.apparmor
                                  [  +0.000000] evm: security.ima
                                  [  +0.000001] evm: security.capability
                                  [  +0.000001] evm: HMAC attrs: 0x1
                                  [  +0.000230] PM:   Magic number: 13:389:644
                                  [  +0.005253] RAS: Correctable Errors collector initialized.
                                  [  +0.000065] clk: Disabling unused clocks
                                  [  +0.000914] Freeing unused decrypted memory: 2028K
                                  [  +0.000356] Freeing unused kernel image (initmem) memory: 4816K
                                  [  +0.000044] Write protecting the kernel read-only data: 34816k
                                  [  +0.000358] Freeing unused kernel image (rodata/data gap) memory: 880K
                                  [  +0.043280] x86/mm: Checked W+X mappings: passed, no W+X pages found.
                                  [  +0.000003] x86/mm: Checking user space page tables
                                  [  +0.041640] x86/mm: Checked W+X mappings: passed, no W+X pages found.
                                  [  +0.000005] Run /init as init process
                                  [  +0.000001]   with arguments:
                                  [  +0.000002]     /init
                                  [  +0.000001]   with environment:
                                  [  +0.000001]     HOME=/
                                  [  +0.000000]     TERM=linux
                                  [  +0.000001]     BOOT_IMAGE=/boot/vmlinuz-6.8.12-8-pve
                                  [  +0.204928] i801_smbus 0000:00:1f.4: SPD Write Disable is set
                                  [  +0.000057] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
                                  [  +0.000109] ahci 0000:00:17.0: version 3.0
                                  [  +0.000331] e1000e: Intel(R) PRO/1000 Network Driver
                                  [  +0.000002] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
                                  [  +0.000012] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x4 impl SATA mode
                                  [  +0.000006] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds apst
                                  [  +0.001148] nvme nvme0: pci function 0000:01:00.0
                                  [  +0.000373] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
                                  [  +0.000159] scsi host0: ahci
                                  [  +0.000628] scsi host1: ahci
                                  [  +0.001023] i2c i2c-0: 2/2 memory slots populated (from DMI)
                                  [  +0.000447] i2c i2c-0: Successfully instantiated SPD at 0x50
                                  [  +0.002647] scsi host2: ahci
                                  [  +0.010720] ata1: DUMMY
                                  [  +0.000004] ata2: DUMMY
                                  [  +0.000006] ata3: SATA max UDMA/133 abar m2048@0x91122000 port 0x91122200 irq 123 lpm-pol 3
                                  [  +0.021614] nvme nvme0: allocated 32 MiB host memory buffer.
                                  [  +0.001032] nvme nvme0: 4/0/0 default/read/poll queues
                                  [  +0.003394]  nvme0n1: p1 p2 p3
                                  [  +0.189501] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
                                  [  +0.064409] tsc: Refined TSC clocksource calibration: 2999.999 MHz
                                  [  +0.000007] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b3e44b2357, max_idle_ns: 440795324996 ns
                                  [  +0.000037] clocksource: Switched to clocksource tsc
                                  [  +0.001417] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 1c:69:7a:6d:9d:d2
                                  [  +0.000007] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
                                  [  +0.000089] e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
                                  [  +0.029179] ata3: SATA link down (SStatus 4 SControl 300)
                                  [  +0.003150] xhci_hcd 0000:00:14.0: xHCI Host Controller
                                  [  +0.000038] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
                                  [  +0.001161] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
                                  [  +0.000239] xhci_hcd 0000:00:14.0: xHCI Host Controller
                                  [  +0.000004] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
                                  [  +0.000004] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
                                  [  +0.000038] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
                                  [  +0.000002] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                  [  +0.000002] usb usb1: Product: xHCI Host Controller
                                  [  +0.000001] usb usb1: Manufacturer: Linux 6.8.12-8-pve xhci-hcd
                                  [  +0.000001] usb usb1: SerialNumber: 0000:00:14.0
                                  [  +0.000133] hub 1-0:1.0: USB hub found
                                  [  +0.000019] hub 1-0:1.0: 12 ports detected
                                  [  +0.002069] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
                                  [  +0.000003] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                  [  +0.000002] usb usb2: Product: xHCI Host Controller
                                  [  +0.000001] usb usb2: Manufacturer: Linux 6.8.12-8-pve xhci-hcd
                                  [  +0.000002] usb usb2: SerialNumber: 0000:00:14.0
                                  [  +0.000088] hub 2-0:1.0: USB hub found
                                  [  +0.000015] hub 2-0:1.0: 6 ports detected
                                  [  +0.005275] e1000e 0000:00:1f.6 eno1: renamed from eth0
                                  [  +0.230977] usb 1-1: new full-speed USB device number 2 using xhci_hcd
                                  [  +0.092237] fbcon: Taking over console
                                  [  +0.000979] Console: switching to colour frame buffer device 100x37
                                  [  +0.034768] usb 1-1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
                                  [  +0.000004] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                  [  +0.000002] usb 1-1: Product: Sonoff Zigbee 3.0 USB Dongle Plus
                                  [  +0.000004] usb 1-1: Manufacturer: Silicon Labs
                                  [  +0.000002] usb 1-1: SerialNumber: 0001
                                  [  +0.036028] raid6: avx2x4   gen() 39780 MB/s
                                  [  +0.017000] raid6: avx2x2   gen() 40432 MB/s
                                  [  +0.017002] raid6: avx2x1   gen() 32501 MB/s
                                  [  +0.000001] raid6: using algorithm avx2x2 gen() 40432 MB/s
                                  [  +0.017004] raid6: .... xor() 22858 MB/s, rmw enabled
                                  [  +0.000001] raid6: using avx2x2 recovery algorithm
                                  [  +0.000766] xor: automatically using best checksumming function   avx
                                  [  +0.027203] usb 1-3: new full-speed USB device number 3 using xhci_hcd
                                  [  +0.063600] Btrfs loaded, zoned=yes, fsverity=yes
                                  [  +0.047801] EXT4-fs (dm-1): mounted filesystem 60c771ed-5eba-4502-8f33-6cf0612844c7 ro with ordered data mode. Quota mode: none.
                                  [  +0.022049] usb 1-3: New USB device found, idVendor=0403, idProduct=6f70, bcdDevice= 6.00
                                  [  +0.000004] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                  [  +0.000002] usb 1-3: Product: HB-RF-USB
                                  [  +0.000001] usb 1-3: Manufacturer: Alexander Reinert
                                  [  +0.000002] usb 1-3: SerialNumber: A94VBWDX
                                  [  +0.059967] systemd[1]: Inserted module 'autofs4'
                                  [  +0.052982] systemd[1]: systemd 252.33-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
                                  [  +0.000006] systemd[1]: Detected architecture x86-64.
                                  [  +0.001004] systemd[1]: Hostname set to <pve>.
                                  [  +0.121614] systemd[1]: Queued start job for default target graphical.target.
                                  [  +0.013031] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
                                  [  +0.000525] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
                                  [  +0.000465] systemd[1]: Created slice system-postfix.slice - Slice /system/postfix.
                                  [  +0.000324] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
                                  [  +0.000264] systemd[1]: Created slice user.slice - User and Session Slice.
                                  [  +0.000062] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
                                  [  +0.000046] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
                                  [  +0.000145] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
                                  [  +0.000020] systemd[1]: Expecting device dev-disk-by\x2duuid-71C7\x2d73FA.device - /dev/disk/by-uuid/71C7-73FA...
                                  [  +0.000008] systemd[1]: Expecting device dev-pve-swap.device - /dev/pve/swap...
                                  [  +0.000013] systemd[1]: Reached target ceph-fuse.target - ceph target allowing to start/stop all ceph-fuse@.service instances at once.
                                  [  +0.000010] systemd[1]: Reached target ceph.target - ceph target allowing to start/stop all ceph*@.service instances at once.
                                  [  +0.000010] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
                                  [  +0.000018] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
                                  [  +0.000033] systemd[1]: Reached target paths.target - Path Units.
                                  [  +0.000026] systemd[1]: Reached target slices.target - Slice Units.
                                  [  +0.000018] systemd[1]: Reached target time-set.target - System Time Set.
                                  [  +0.000028] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
                                  [  +0.000070] systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
                                  [  +0.000100] systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
                                  [  +0.003069] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
                                  [  +0.000153] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
                                  [  +0.000064] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
                                  [  +0.000272] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
                                  [  +0.000144] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
                                  [  +0.000155] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
                                  [  +0.000245] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
                                  [  +0.000085] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
                                  [  +0.000787] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
                                  [  +0.000805] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
                                  [  +0.001293] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
                                  [  +0.001102] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
                                  [  +0.000099] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
                                  [  +0.001187] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
                                  [  +0.001207] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
                                  [  +0.001449] systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
                                  [  +0.001250] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
                                  [  +0.001215] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
                                  [  +0.001302] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
                                  [  +0.001376] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
                                  [  +0.001250] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
                                  [  +0.001345] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
                                  [  +0.000385] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
                                  [  +0.002122] systemd[1]: Starting systemd-journald.service - Journal Service...
                                  [  +0.000335] pstore: Using crash dump compression: deflate
                                  [  +0.003005] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
                                  [  +0.008397] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
                                  [  +0.009429] pstore: Registered efi_pstore as persistent store backend
                                  [  +0.000699] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
                                  [  +0.002516] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
                                  [  +0.000177] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
                                  [  +0.000131] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
                                  [  +0.000126] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
                                  [  +0.000314] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
                                  [  +0.000406] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
                                  [  +0.000341] systemd[1]: modprobe@configfs.service: Deactivated successfully.
                                  [  +0.000166] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
                                  [  +0.000365] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
                                  [  +0.000189] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
                                  [  +0.000348] systemd[1]: modprobe@drm.service: Deactivated successfully.
                                  [  +0.000150] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
                                  [  +0.000328] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
                                  [  +0.000168] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
                                  [  +0.000301] systemd[1]: modprobe@fuse.service: Deactivated successfully.
                                  [  +0.000161] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
                                  [  +0.000342] systemd[1]: modprobe@loop.service: Deactivated successfully.
                                  [  +0.000145] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
                                  [  +0.001699] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
                                  [  +0.001733] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
                                  [  +0.000102] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
                                  [  +0.002115] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
                                  [  +0.001642] systemd[1]: Started dm-event.service - Device-mapper event daemon.
                                  [  +0.001019] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
                                  [  +0.001952] spl: loading out-of-tree module taints kernel.
                                  [  +0.001643] EXT4-fs (dm-1): re-mounted 60c771ed-5eba-4502-8f33-6cf0612844c7 r/w. Quota mode: none.
                                  [  +0.001568] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
                                  [  +0.000174] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
                                  [  +0.000049] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
                                  [  +0.001943] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
                                  [  +0.001829] systemd[1]: Starting systemd-sysusers.service - Create System Users...
                                  [  +0.032841] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
                                  [  +0.000319] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
                                  [  +0.004085] systemd[1]: Finished systemd-sysusers.service - Create System Users.
                                  [  +0.008321] zfs: module license 'CDDL' taints kernel.
                                  [  +0.000003] Disabling lock debugging due to kernel taint
                                  [  +0.000019] zfs: module license taints kernel.
                                  [  +0.006140] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
                                  [  +0.000152] systemd[1]: Started systemd-journald.service - Journal Service.
                                  [  +0.011678] systemd-journald[328]: Received client request to flush runtime journal.
                                  [  +0.777840] Adding 8388604k swap on /dev/mapper/pve-swap.  Priority:-2 extents:1 across:8388604k SS
                                  [  +0.033649] intel_pmc_core INT33A1:00:  initialized
                                  [  +0.043927] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
                                  [  +0.006824] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
                                  [  +0.008765] usbcore: registered new interface driver usbserial_generic
                                  [  +0.000011] usbserial: USB Serial support registered for generic
                                  [  +0.000427] input: PC Speaker as /devices/platform/pcspkr/input/input3
                                  [  +0.004241] usbcore: registered new interface driver cp210x
                                  [  +0.000016] usbserial: USB Serial support registered for cp210x
                                  [  +0.000017] cp210x 1-1:1.0: cp210x converter detected
                                  [  +0.004312] usb 1-1: cp210x converter now attached to ttyUSB0
                                  [  +0.000723] Creating 1 MTD partitions on "0000:00:1f.5":
                                  [  +0.000005] 0x000000000000-0x000001000000 : "BIOS"
                                  [  +0.509544] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
                                  [  +0.000003] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
                                  [  +0.000002] RAPL PMU: hw unit of domain package 2^-14 Joules
                                  [  +0.000002] RAPL PMU: hw unit of domain dram 2^-14 Joules
                                  [  +0.000001] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
                                  [  +0.000001] RAPL PMU: hw unit of domain psys 2^-14 Joules
                                  [  +0.144206] i915 0000:00:02.0: [drm] Found 128MB of eDRAM
                                  [  +0.000036] i915 0000:00:02.0: [drm] VT-d active for gfx access
                                  [  +0.000814] cryptd: max_cpu_qlen set to 1000
                                  [  +0.002566] Console: switching to colour dummy device 80x25
                                  [  +0.002663] AVX2 version of gcm_enc/dec engaged.
                                  [  +0.000034] AES CTR mode by8 optimization enabled
                                  [  +0.107633] i915 0000:00:02.0: vgaarb: deactivate vga console
                                  [  +0.000075] i915 0000:00:02.0: [drm] Using Transparent Hugepages
                                  [  +0.002024] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
                                  [  +0.001146] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
                                  [  +0.000792] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
                                  [  +0.047049] intel_tcc_cooling: Programmable TCC Offset detected
                                  [  +0.265514] ZFS: Loaded module v2.2.7-pve1, ZFS pool version 5000, ZFS filesystem version 5
                                  [  +0.002725] intel_rapl_common: Found RAPL domain package
                                  [  +0.000004] intel_rapl_common: Found RAPL domain core
                                  [  +0.000001] intel_rapl_common: Found RAPL domain uncore
                                  [  +0.000001] intel_rapl_common: Found RAPL domain dram
                                  [  +0.000001] intel_rapl_common: Found RAPL domain psys
                                  [  +0.037231] i915 0000:00:02.0: [drm] [ENCODER:94:DDI A/PHY A] failed to retrieve link info, disabling eDP
                                  [  +0.034148] [drm] Initialized i915 1.6.0 20230929 for 0000:00:02.0 on minor 1
                                  [  +0.002495] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
                                  [  +0.000433] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
                                  [  +0.000163] i915 display info: display version: 9
                                  [  +0.000003] i915 display info: cursor_needs_physical: no
                                  [  +0.000002] i915 display info: has_cdclk_crawl: no
                                  [  +0.000001] i915 display info: has_cdclk_squash: no
                                  [  +0.000002] i915 display info: has_ddi: yes
                                  [  +0.000001] i915 display info: has_dp_mst: yes
                                  [  +0.000002] i915 display info: has_dsb: no
                                  [  +0.000001] i915 display info: has_fpga_dbg: yes
                                  [  +0.000001] i915 display info: has_gmch: no
                                  [  +0.000002] i915 display info: has_hotplug: yes
                                  [  +0.000001] i915 display info: has_hti: no
                                  [  +0.000001] i915 display info: has_ipc: yes
                                  [  +0.000001] i915 display info: has_overlay: no
                                  [  +0.000002] i915 display info: has_psr: yes
                                  [  +0.000001] i915 display info: has_psr_hw_tracking: yes
                                  [  +0.000002] i915 display info: overlay_needs_physical: no
                                  [  +0.000001] i915 display info: supports_tv: no
                                  [  +0.000001] i915 display info: has_hdcp: yes
                                  [  +0.000002] i915 display info: has_dmc: yes
                                  [  +0.000001] i915 display info: has_dsc: no
                                  [  +0.036090] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
                                  [  +0.034927] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
                                  [  +0.035743] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
                                  [  +0.022956] audit: type=1400 audit(1740677770.674:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="pve-container-mounthotplug" pid=536 comm="apparmor_parser"
                                  [  +0.003493] audit: type=1400 audit(1740677770.677:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=533 comm="apparmor_parser"
                                  [  +0.001701] audit: type=1400 audit(1740677770.680:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-copy" pid=539 comm="apparmor_parser"
                                  [  +0.000111] audit: type=1400 audit(1740677770.680:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=535 comm="apparmor_parser"
                                  [  +0.000004] audit: type=1400 audit(1740677770.680:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=535 comm="apparmor_parser"
                                  [  +0.003646] audit: type=1400 audit(1740677770.683:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=540 comm="apparmor_parser"
                                  [  +0.001377] audit: type=1400 audit(1740677770.685:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=537 comm="apparmor_parser"
                                  [  +0.000007] audit: type=1400 audit(1740677770.685:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=537 comm="apparmor_parser"
                                  [  +0.000004] audit: type=1400 audit(1740677770.685:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=537 comm="apparmor_parser"
                                  [  +0.065124] RPC: Registered named UNIX socket transport module.
                                  [  +0.000005] RPC: Registered udp transport module.
                                  [  +0.000001] RPC: Registered tcp transport module.
                                  [  +0.000001] RPC: Registered tcp-with-tls transport module.
                                  [  +0.000001] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                  [  +0.042592] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
                                  [  +0.000005] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
                                  [  +0.638003] vmbr0: port 1(eno1) entered blocking state
                                  [  +0.000005] vmbr0: port 1(eno1) entered disabled state
                                  [  +0.000016] e1000e 0000:00:1f.6 eno1: entered allmulticast mode
                                  [  +0.000043] e1000e 0000:00:1f.6 eno1: entered promiscuous mode
                                  [  +0.705546] kauditd_printk_skb: 11 callbacks suppressed
                                  [  +0.000003] audit: type=1400 audit(1740677772.136:22): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/bin/lxc-copy" pid=682 comm="apparmor_parser"
                                  [  +0.010221] audit: type=1400 audit(1740677772.146:23): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/bin/lxc-start" pid=689 comm="apparmor_parser"
                                  [  +0.014489] audit: type=1400 audit(1740677772.161:24): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default" pid=694 comm="apparmor_parser"
                                  [  +0.000007] audit: type=1400 audit(1740677772.161:25): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-cgns" pid=694 comm="apparmor_parser"
                                  [  +0.000004] audit: type=1400 audit(1740677772.161:26): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-mounting" pid=694 comm="apparmor_parser"
                                  [  +0.000003] audit: type=1400 audit(1740677772.161:27): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-nesting" pid=694 comm="apparmor_parser"
                                  [  +2.488175] e1000e 0000:00:1f.6 eno1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
                                  [  +0.000032] vmbr0: port 1(eno1) entered blocking state
                                  [  +0.000005] vmbr0: port 1(eno1) entered forwarding state
                                  [  +9.731558] kvm_intel: L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html for details.
                                  [Feb27 18:37] audit: type=1400 audit(1740677824.803:28): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="pve-container-mounthotplug" pid=2277 comm="apparmor_parser"
                                  [ +46.150728] tap200i0: entered promiscuous mode
                                  [  +0.051460] vmbr0: port 2(fwpr200p0) entered blocking state
                                  [  +0.000004] vmbr0: port 2(fwpr200p0) entered disabled state
                                  [  +0.000013] fwpr200p0: entered allmulticast mode
                                  [  +0.000036] fwpr200p0: entered promiscuous mode
                                  [  +0.000028] vmbr0: port 2(fwpr200p0) entered blocking state
                                  [  +0.000001] vmbr0: port 2(fwpr200p0) entered forwarding state
                                  [  +0.009386] fwbr200i0: port 1(fwln200i0) entered blocking state
                                  [  +0.000004] fwbr200i0: port 1(fwln200i0) entered disabled state
                                  [  +0.000015] fwln200i0: entered allmulticast mode
                                  [  +0.000036] fwln200i0: entered promiscuous mode
                                  [  +0.000030] fwbr200i0: port 1(fwln200i0) entered blocking state
                                  [  +0.000001] fwbr200i0: port 1(fwln200i0) entered forwarding state
                                  [  +0.009431] fwbr200i0: port 2(tap200i0) entered blocking state
                                  [  +0.000004] fwbr200i0: port 2(tap200i0) entered disabled state
                                  [  +0.000011] tap200i0: entered allmulticast mode
                                  [  +0.000054] fwbr200i0: port 2(tap200i0) entered blocking state
                                  [  +0.000002] fwbr200i0: port 2(tap200i0) entered forwarding state
                                  [Feb27 18:38] usb 1-3: reset full-speed USB device number 3 using xhci_hcd
                                  [Feb27 18:39] tap100i0: entered promiscuous mode
                                  [  +0.050383] vmbr0: port 3(fwpr100p0) entered blocking state
                                  [  +0.000004] vmbr0: port 3(fwpr100p0) entered disabled state
                                  [  +0.000016] fwpr100p0: entered allmulticast mode
                                  [  +0.000037] fwpr100p0: entered promiscuous mode
                                  [  +0.000022] vmbr0: port 3(fwpr100p0) entered blocking state
                                  [  +0.000003] vmbr0: port 3(fwpr100p0) entered forwarding state
                                  [  +0.009775] fwbr100i0: port 1(fwln100i0) entered blocking state
                                  [  +0.000004] fwbr100i0: port 1(fwln100i0) entered disabled state
                                  [  +0.000024] fwln100i0: entered allmulticast mode
                                  [  +0.000038] fwln100i0: entered promiscuous mode
                                  [  +0.000039] fwbr100i0: port 1(fwln100i0) entered blocking state
                                  [  +0.000004] fwbr100i0: port 1(fwln100i0) entered forwarding state
                                  [  +0.010007] fwbr100i0: port 2(tap100i0) entered blocking state
                                  [  +0.000004] fwbr100i0: port 2(tap100i0) entered disabled state
                                  [  +0.000012] tap100i0: entered allmulticast mode
                                  [  +0.000060] fwbr100i0: port 2(tap100i0) entered blocking state
                                  [  +0.000003] fwbr100i0: port 2(tap100i0) entered forwarding state
                                  [  +0.080460] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
                                  [  +0.000014] cp210x 1-1:1.0: device disconnected
                                  [ +11.194126] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
                                  root@pve:~#
                                  JLegJ 1 Antwort Letzte Antwort
                                  • M matrose65
                                    @jleg
                                    hier nun die dmesg -e vom Host ( ich kann da nicht viel verstehen)
                                    root@pve:~# dmesg -e
                                    [Feb27 18:36] Linux version 6.8.12-8-pve (build@proxmox) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-8 (2025-01-24T12:32Z) ()
                                    [  +0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.8.12-8-pve root=/dev/mapper/pve-root ro quiet
                                    [  +0.000000] KERNEL supported cpus:
                                    [  +0.000000]   Intel GenuineIntel
                                    [  +0.000000]   AMD AuthenticAMD
                                    [  +0.000000]   Hygon HygonGenuine
                                    [  +0.000000]   Centaur CentaurHauls
                                    [  +0.000000]   zhaoxin   Shanghai
                                    [  +0.000000] BIOS-provided physical RAM map:
                                    [  +0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000005efff] usable
                                    [  +0.000000] BIOS-e820: [mem 0x000000000005f000-0x000000000005ffff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x0000000000060000-0x000000000009ffff] usable
                                    [  +0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007babffff] usable
                                    [  +0.000000] BIOS-e820: [mem 0x000000007bac0000-0x000000007bf20fff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x000000007bf21000-0x000000007bf9dfff] ACPI data
                                    [  +0.000000] BIOS-e820: [mem 0x000000007bf9e000-0x000000007c3e6fff] ACPI NVS
                                    [  +0.000000] BIOS-e820: [mem 0x000000007c3e7000-0x000000007cc52fff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x000000007cc53000-0x000000007cd0dfff] type 20
                                    [  +0.000000] BIOS-e820: [mem 0x000000007cd0e000-0x000000007cd0efff] usable
                                    [  +0.000000] BIOS-e820: [mem 0x000000007cd0f000-0x000000007fffffff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
                                    [  +0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000087effffff] usable
                                    [  +0.000000] NX (Execute Disable) protection: active
                                    [  +0.000000] APIC: Static calls initialized
                                    [  +0.000000] efi: EFI v2.7 by American Megatrends
                                    [  +0.000000] efi: ACPI 2.0=0x7bf3a000 ACPI=0x7bf3a000 TPMFinalLog=0x7c391000 SMBIOS=0x7caa7000 SMBIOS 3.0=0x7caa6000 MEMATTR=0x79bea018 ESRT=0x7caaa518 MOKvar=0x7cad6000
                                    [  +0.000000] efi: Remove mem47: MMIO range=[0xe0000000-0xefffffff] (256MB) from e820 map
                                    [  +0.000000] e820: remove [mem 0xe0000000-0xefffffff] reserved
                                    [  +0.000000] efi: Not removing mem48: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
                                    [  +0.000000] efi: Not removing mem49: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
                                    [  +0.000000] efi: Not removing mem50: MMIO range=[0xfed00000-0xfed03fff] (16KB) from e820 map
                                    [  +0.000000] efi: Not removing mem51: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
                                    [  +0.000000] efi: Remove mem52: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
                                    [  +0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
                                    [  +0.000000] secureboot: Secure boot disabled
                                    [  +0.000000] SMBIOS 3.2.1 present.
                                    [  +0.000000] DMI: Intel(R) Client Systems NUC8i3BEH/NUC8BEB, BIOS BECFL357.86A.0085.2020.1007.1917 10/07/2020
                                    [  +0.000000] tsc: Detected 3000.000 MHz processor
                                    [  +0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
                                    [  +0.000003] e820: remove [mem 0x000a0000-0x000fffff] usable
                                    [  +0.000008] last_pfn = 0x87f000 max_arch_pfn = 0x400000000
                                    [  +0.000004] MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
                                    [  +0.000002] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
                                    [  +0.000522] last_pfn = 0x7cd0f max_arch_pfn = 0x400000000
                                    [  +0.007344] found SMP MP-table at [mem 0x000fcd40-0x000fcd4f]
                                    [  +0.000013] esrt: Reserving ESRT space from 0x000000007caaa518 to 0x000000007caaa550.
                                    [  +0.000009] Using GB pages for direct mapping
                                    [  +0.000253] secureboot: Secure boot disabled
                                    [  +0.000000] RAMDISK: [mem 0x30af7000-0x34572fff]
                                    [  +0.000004] ACPI: Early table checksum verification disabled
                                    [  +0.000003] ACPI: RSDP 0x000000007BF3A000 000024 (v02 INTEL )
                                    [  +0.000005] ACPI: XSDT 0x000000007BF3A0A8 0000CC (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                    [  +0.000006] ACPI: FACP 0x000000007BF78BF8 000114 (v06 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                    [  +0.000005] ACPI: DSDT 0x000000007BF3A200 03E9F7 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                    [  +0.000004] ACPI: FACS 0x000000007C3E6080 000040
                                    [  +0.000003] ACPI: APIC 0x000000007BF78D10 000084 (v04 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                    [  +0.000003] ACPI: FPDT 0x000000007BF78D98 000044 (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                    [  +0.000004] ACPI: FIDT 0x000000007BF78DE0 00009C (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                    [  +0.000003] ACPI: MCFG 0x000000007BF78E80 00003C (v01 INTEL  NUC8i3BE 00000055 MSFT 00000097)
                                    [  +0.000003] ACPI: SSDT 0x000000007BF78EC0 001B1C (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                    [  +0.000004] ACPI: SSDT 0x000000007BF7A9E0 0031C6 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                    [  +0.000003] ACPI: HPET 0x000000007BF7DBA8 000038 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                    [  +0.000003] ACPI: SSDT 0x000000007BF7DBE0 000FAE (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                    [  +0.000004] ACPI: SSDT 0x000000007BF7EB90 003048 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                    [  +0.000003] ACPI: UEFI 0x000000007BF81BD8 000042 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                    [  +0.000003] ACPI: LPIT 0x000000007BF81C20 000094 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                    [  +0.000004] ACPI: SSDT 0x000000007BF81CB8 0027DE (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                    [  +0.000003] ACPI: SSDT 0x000000007BF84498 0008B8 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                    [  +0.000003] ACPI: DBGP 0x000000007BF84D50 000034 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                    [  +0.000004] ACPI: DBG2 0x000000007BF84D88 000054 (v00 INTEL  NUC8i3BE 00000055      01000013)
                                    [  +0.000003] ACPI: SSDT 0x000000007BF84DE0 000144 (v02 INTEL  NUC8i3BE 00000055 INTL 20160527)
                                    [  +0.000003] ACPI: BGRT 0x000000007BF84F28 000038 (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                    [  +0.000004] ACPI: TPM2 0x000000007BF84F60 000034 (v04 INTEL  NUC8i3BE 00000055 AMI  00000000)
                                    [  +0.000003] ACPI: DMAR 0x000000007BF84F98 0000A8 (v01 INTEL  NUC8i3BE 00000055      01000013)
                                    [  +0.000003] ACPI: WSMT 0x000000007BF85040 000028 (v01 INTEL  NUC8i3BE 00000055 AMI  00010013)
                                    [  +0.000003] ACPI: Reserving FACP table memory at [mem 0x7bf78bf8-0x7bf78d0b]
                                    [  +0.000002] ACPI: Reserving DSDT table memory at [mem 0x7bf3a200-0x7bf78bf6]
                                    [  +0.000001] ACPI: Reserving FACS table memory at [mem 0x7c3e6080-0x7c3e60bf]
                                    [  +0.000001] ACPI: Reserving APIC table memory at [mem 0x7bf78d10-0x7bf78d93]
                                    [  +0.000000] ACPI: Reserving FPDT table memory at [mem 0x7bf78d98-0x7bf78ddb]
                                    [  +0.000001] ACPI: Reserving FIDT table memory at [mem 0x7bf78de0-0x7bf78e7b]
                                    [  +0.000001] ACPI: Reserving MCFG table memory at [mem 0x7bf78e80-0x7bf78ebb]
                                    [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf78ec0-0x7bf7a9db]
                                    [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf7a9e0-0x7bf7dba5]
                                    [  +0.000001] ACPI: Reserving HPET table memory at [mem 0x7bf7dba8-0x7bf7dbdf]
                                    [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf7dbe0-0x7bf7eb8d]
                                    [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf7eb90-0x7bf81bd7]
                                    [  +0.000000] ACPI: Reserving UEFI table memory at [mem 0x7bf81bd8-0x7bf81c19]
                                    [  +0.000001] ACPI: Reserving LPIT table memory at [mem 0x7bf81c20-0x7bf81cb3]
                                    [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf81cb8-0x7bf84495]
                                    [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf84498-0x7bf84d4f]
                                    [  +0.000001] ACPI: Reserving DBGP table memory at [mem 0x7bf84d50-0x7bf84d83]
                                    [  +0.000001] ACPI: Reserving DBG2 table memory at [mem 0x7bf84d88-0x7bf84ddb]
                                    [  +0.000001] ACPI: Reserving SSDT table memory at [mem 0x7bf84de0-0x7bf84f23]
                                    [  +0.000001] ACPI: Reserving BGRT table memory at [mem 0x7bf84f28-0x7bf84f5f]
                                    [  +0.000001] ACPI: Reserving TPM2 table memory at [mem 0x7bf84f60-0x7bf84f93]
                                    [  +0.000001] ACPI: Reserving DMAR table memory at [mem 0x7bf84f98-0x7bf8503f]
                                    [  +0.000000] ACPI: Reserving WSMT table memory at [mem 0x7bf85040-0x7bf85067]
                                    [  +0.000169] No NUMA configuration found
                                    [  +0.000002] Faking a node at [mem 0x0000000000000000-0x000000087effffff]
                                    [  +0.000008] NODE_DATA(0) allocated [mem 0x87efd5000-0x87effffff]
                                    [  +0.000214] Zone ranges:
                                    [  +0.000001]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
                                    [  +0.000002]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
                                    [  +0.000002]   Normal   [mem 0x0000000100000000-0x000000087effffff]
                                    [  +0.000001]   Device   empty
                                    [  +0.000001] Movable zone start for each node
                                    [  +0.000003] Early memory node ranges
                                    [  +0.000001]   node   0: [mem 0x0000000000001000-0x000000000005efff]
                                    [  +0.000001]   node   0: [mem 0x0000000000060000-0x000000000009ffff]
                                    [  +0.000001]   node   0: [mem 0x0000000000100000-0x000000007babffff]
                                    [  +0.000002]   node   0: [mem 0x000000007cd0e000-0x000000007cd0efff]
                                    [  +0.000000]   node   0: [mem 0x0000000100000000-0x000000087effffff]
                                    [  +0.000004] Initmem setup node 0 [mem 0x0000000000001000-0x000000087effffff]
                                    [  +0.000004] On node 0, zone DMA: 1 pages in unavailable ranges
                                    [  +0.000002] On node 0, zone DMA: 1 pages in unavailable ranges
                                    [  +0.000023] On node 0, zone DMA: 96 pages in unavailable ranges
                                    [  +0.002966] On node 0, zone DMA32: 4686 pages in unavailable ranges
                                    [  +0.038058] On node 0, zone Normal: 13041 pages in unavailable ranges
                                    [  +0.000042] On node 0, zone Normal: 4096 pages in unavailable ranges
                                    [  +0.000016] Reserving Intel graphics memory at [mem 0x7e000000-0x7fffffff]
                                    [  +0.000356] ACPI: PM-Timer IO Port: 0x1808
                                    [  +0.000008] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
                                    [  +0.000002] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
                                    [  +0.000001] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
                                    [  +0.000001] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
                                    [  +0.000052] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
                                    [  +0.000003] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
                                    [  +0.000002] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
                                    [  +0.000004] ACPI: Using ACPI (MADT) for SMP configuration information
                                    [  +0.000002] ACPI: HPET id: 0x8086a201 base: 0xfed00000
                                    [  +0.000007] e820: update [mem 0x77b7b000-0x77c14fff] usable ==> reserved
                                    [  +0.000010] TSC deadline timer available
                                    [  +0.000001] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
                                    [  +0.000015] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
                                    [  +0.000002] PM: hibernation: Registered nosave memory: [mem 0x0005f000-0x0005ffff]
                                    [  +0.000002] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0x77b7b000-0x77c14fff]
                                    [  +0.000002] PM: hibernation: Registered nosave memory: [mem 0x7bac0000-0x7bf20fff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0x7bf21000-0x7bf9dfff]
                                    [  +0.000000] PM: hibernation: Registered nosave memory: [mem 0x7bf9e000-0x7c3e6fff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0x7c3e7000-0x7cc52fff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0x7cc53000-0x7cd0dfff]
                                    [  +0.000002] PM: hibernation: Registered nosave memory: [mem 0x7cd0f000-0x7fffffff]
                                    [  +0.000000] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xfdffffff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
                                    [  +0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfedfffff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
                                    [  +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffffffff]
                                    [  +0.000001] [mem 0x80000000-0xfdffffff] available for PCI devices
                                    [  +0.000001] Booting paravirtualized kernel on bare hardware
                                    [  +0.000002] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
                                    [  +0.000006] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
                                    [  +0.000236] percpu: Embedded 86 pages/cpu s229376 r8192 d114688 u524288
                                    [  +0.000006] pcpu-alloc: s229376 r8192 d114688 u524288 alloc=1*2097152
                                    [  +0.000002] pcpu-alloc: [0] 0 1 2 3
                                    [  +0.000019] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.8.12-8-pve root=/dev/mapper/pve-root ro quiet
                                    [  +0.000046] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.8.12-8-pve", will be passed to user space.
                                    [  +0.000027] random: crng init done
                                    [  +0.002257] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
                                    [  +0.001140] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
                                    [  +0.000069] Fallback order for Node 0: 0
                                    [  +0.000003] Built 1 zonelists, mobility grouping on.  Total pages: 8235797
                                    [  +0.000001] Policy zone: Normal
                                    [  +0.000005] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
                                    [  +0.000008] software IO TLB: area num 4.
                                    [  +0.069158] Memory: 32665912K/33466748K available (20480K kernel code, 3642K rwdata, 13456K rodata, 4816K init, 5692K bss, 800576K reserved, 0K cma-reserved)
                                    [  +0.000972] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                                    [  +0.000013] Kernel/User page tables isolation: enabled
                                    [  +0.000026] ftrace: allocating 55402 entries in 217 pages
                                    [  +0.009193] ftrace: allocated 217 pages with 5 groups
                                    [  +0.000772] Dynamic Preempt: voluntary
                                    [  +0.000058] rcu: Preemptible hierarchical RCU implementation.
                                    [  +0.000001] rcu:      RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
                                    [  +0.000001]   Trampoline variant of Tasks RCU enabled.
                                    [  +0.000001]   Rude variant of Tasks RCU enabled.
                                    [  +0.000000]   Tracing variant of Tasks RCU enabled.
                                    [  +0.000001] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
                                    [  +0.000001] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
                                    [  +0.002950] NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
                                    [  +0.000295] rcu: srcu_init: Setting srcu_struct sizes based on contention.
                                    [  +0.000290] Console: colour dummy device 80x25
                                    [  +0.000003] printk: legacy console [tty0] enabled
                                    [  +0.000042] ACPI: Core revision 20230628
                                    [  +0.000219] hpet: HPET dysfunctional in PC10. Force disabled.
                                    [  +0.000001] APIC: Switch to symmetric I/O mode setup
                                    [  +0.000002] DMAR: Host address width 39
                                    [  +0.000002] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
                                    [  +0.000009] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
                                    [  +0.000003] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
                                    [  +0.000004] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
                                    [  +0.000002] DMAR: RMRR base: 0x0000007bed4000 end: 0x0000007bef3fff
                                    [  +0.000002] DMAR: RMRR base: 0x0000007d800000 end: 0x0000007fffffff
                                    [  +0.000002] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
                                    [  +0.000002] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
                                    [  +0.000001] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
                                    [  +0.002353] DMAR-IR: Enabled IRQ remapping in x2apic mode
                                    [  +0.000002] x2apic enabled
                                    [  +0.000073] APIC: Switched APIC routing to: cluster x2apic
                                    [  +0.005847] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b3e459bf4c, max_idle_ns: 440795289890 ns
                                    [  +0.000006] Calibrating delay loop (skipped), value calculated using timer frequency.. 6000.00 BogoMIPS (lpj=3000000)
                                    [  +0.000026] x86/cpu: SGX disabled by BIOS.
                                    [  +0.000007] CPU0: Thermal monitoring enabled (TM1)
                                    [  +0.000044] process: using mwait in idle threads
                                    [  +0.000003] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
                                    [  +0.000002] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
                                    [  +0.000003] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
                                    [  +0.000002] Spectre V2 : Mitigation: IBRS
                                    [  +0.000001] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
                                    [  +0.000001] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
                                    [  +0.000001] RETBleed: Mitigation: IBRS
                                    [  +0.000001] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
                                    [  +0.000002] Spectre V2 : User space: Mitigation: STIBP via prctl
                                    [  +0.000001] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
                                    [  +0.000006] MDS: Mitigation: Clear CPU buffers
                                    [  +0.000001] MMIO Stale Data: Mitigation: Clear CPU buffers
                                    [  +0.000004] SRBDS: Mitigation: Microcode
                                    [  +0.000001] GDS: Vulnerable: No microcode
                                    [  +0.000006] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
                                    [  +0.000001] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
                                    [  +0.000002] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
                                    [  +0.000001] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
                                    [  +0.000001] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
                                    [  +0.000002] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
                                    [  +0.000002] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
                                    [  +0.000002] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
                                    [  +0.000001] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
                                    [  +0.000873] Freeing SMP alternatives memory: 48K
                                    [  +0.000000] pid_max: default: 32768 minimum: 301
                                    [  +0.000000] LSM: initializing lsm=lockdown,capability,yama,apparmor,integrity
                                    [  +0.000000] Yama: becoming mindful.
                                    [  +0.000000] AppArmor: AppArmor initialized
                                    [  +0.000000] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
                                    [  +0.000000] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
                                    [  +0.000000] smpboot: CPU0: Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz (family: 0x6, model: 0x8e, stepping: 0xa)
                                    [  +0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
                                    [  +0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
                                    [  +0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
                                    [  +0.000000] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
                                    [  +0.000000] ... version:                4
                                    [  +0.000000] ... bit width:              48
                                    [  +0.000000] ... generic registers:      4
                                    [  +0.000000] ... value mask:             0000ffffffffffff
                                    [  +0.000000] ... max period:             00007fffffffffff
                                    [  +0.000000] ... fixed-purpose events:   3
                                    [  +0.000000] ... event mask:             000000070000000f
                                    [  +0.000000] signal: max sigframe size: 2032
                                    [  +0.000000] Estimated ratio of average max frequency by base frequency (times 1024): 1228
                                    [  +0.000000] rcu: Hierarchical SRCU implementation.
                                    [  +0.000000] rcu:      Max phase no-delay instances is 400.
                                    [  +0.000000] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
                                    [  +0.000000] smp: Bringing up secondary CPUs ...
                                    [  +0.000108] smpboot: x86: Booting SMP configuration:
                                    [  +0.000001] .... node  #0, CPUs:      #1 #2 #3
                                    [  +0.001127] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
                                    [  +0.000000] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
                                    [  +0.000000] smp: Brought up 1 node, 4 CPUs
                                    [  +0.000000] smpboot: Max logical packages: 1
                                    [  +0.000000] smpboot: Total of 4 processors activated (24000.00 BogoMIPS)
                                    [  +0.001816] devtmpfs: initialized
                                    [  +0.000000] x86/mm: Memory block size: 128MB
                                    [  +0.003226] ACPI: PM: Registering ACPI NVS region [mem 0x7bf9e000-0x7c3e6fff] (4493312 bytes)
                                    [  +0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
                                    [  +0.000000] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
                                    [  +0.000000] pinctrl core: initialized pinctrl subsystem
                                    [  +0.000224] PM: RTC time: 17:36:06, date: 2025-02-27
                                    [  +0.000822] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                                    [  +0.000379] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
                                    [  +0.000247] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                                    [  +0.000253] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
                                    [  +0.000024] audit: initializing netlink subsys (disabled)
                                    [  +0.000012] audit: type=2000 audit(1740677766.009:1): state=initialized audit_enabled=0 res=1
                                    [  +0.000000] thermal_sys: Registered thermal governor 'fair_share'
                                    [  +0.000000] thermal_sys: Registered thermal governor 'bang_bang'
                                    [  +0.000000] thermal_sys: Registered thermal governor 'step_wise'
                                    [  +0.000000] thermal_sys: Registered thermal governor 'user_space'
                                    [  +0.000000] thermal_sys: Registered thermal governor 'power_allocator'
                                    [  +0.000000] EISA bus registered
                                    [  +0.000000] cpuidle: using governor ladder
                                    [  +0.000000] cpuidle: using governor menu
                                    [  +0.000008] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
                                    [  +0.000000] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
                                    [  +0.000000] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
                                    [  +0.000000] PCI: Using configuration type 1 for base access
                                    [  +0.000057] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
                                    [  +0.000721] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
                                    [  +0.000003] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
                                    [  +0.000003] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
                                    [  +0.000001] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
                                    [  +0.000128] ACPI: Added _OSI(Module Device)
                                    [  +0.000003] ACPI: Added _OSI(Processor Device)
                                    [  +0.000002] ACPI: Added _OSI(3.0 _SCP Extensions)
                                    [  +0.000001] ACPI: Added _OSI(Processor Aggregator Device)
                                    [  +0.095577] ACPI: 8 ACPI AML tables successfully acquired and loaded
                                    [  +0.012648] ACPI: Dynamic OEM Table Load:
                                    [  +0.000009] ACPI: SSDT 0xFFFF98A8417E3C00 000400 (v02 PmRef  Cpu0Cst  00003001 INTL 20160527)
                                    [  +0.001858] ACPI: Dynamic OEM Table Load:
                                    [  +0.000006] ACPI: SSDT 0xFFFF98A841D5A000 000689 (v02 PmRef  Cpu0Ist  00003000 INTL 20160527)
                                    [  +0.001947] ACPI: Dynamic OEM Table Load:
                                    [  +0.000005] ACPI: SSDT 0xFFFF98A841CCF800 0000F4 (v02 PmRef  Cpu0Psd  00003000 INTL 20160527)
                                    [  +0.002177] ACPI: Dynamic OEM Table Load:
                                    [  +0.000007] ACPI: SSDT 0xFFFF98A841D59000 0005FC (v02 PmRef  ApIst    00003000 INTL 20160527)
                                    [  +0.001931] ACPI: Dynamic OEM Table Load:
                                    [  +0.000007] ACPI: SSDT 0xFFFF98A8417E3800 000317 (v02 PmRef  ApHwp    00003000 INTL 20160527)
                                    [  +0.001993] ACPI: Dynamic OEM Table Load:
                                    [  +0.000007] ACPI: SSDT 0xFFFF98A841D69000 000AB0 (v02 PmRef  ApPsd    00003000 INTL 20160527)
                                    [  +0.002765] ACPI: Dynamic OEM Table Load:
                                    [  +0.000005] ACPI: SSDT 0xFFFF98A8417E0000 00030A (v02 PmRef  ApCst    00003000 INTL 20160527)
                                    [  +0.004387] ACPI: _OSC evaluated successfully for all CPUs
                                    [  +0.000114] ACPI: EC: EC started
                                    [  +0.000002] ACPI: EC: interrupt blocked
                                    [  +0.001139] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
                                    [  +0.000003] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC used to handle transactions
                                    [  +0.000002] ACPI: Interpreter enabled
                                    [  +0.000047] ACPI: PM: (supports S0 S3 S4 S5)
                                    [  +0.000002] ACPI: Using IOAPIC for interrupt routing
                                    [  +0.002288] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
                                    [  +0.000002] PCI: Using E820 reservations for host bridge windows
                                    [  +0.001848] ACPI: Enabled 8 GPEs in block 00 to 7F
                                    [  +0.020305] ACPI: \_SB_.PCI0.XDCI.USBC: New power resource
                                    [  +0.004809] ACPI: \_SB_.PCI0.SAT0.VOL0.V0PR: New power resource
                                    [  +0.000570] ACPI: \_SB_.PCI0.SAT0.VOL1.V1PR: New power resource
                                    [  +0.000564] ACPI: \_SB_.PCI0.SAT0.VOL2.V2PR: New power resource
                                    [  +0.016857] ACPI: \_SB_.PCI0.CNVW.WRST: New power resource
                                    [  +0.006638] ACPI: \_TZ_.FN00: New power resource
                                    [  +0.000109] ACPI: \_TZ_.FN01: New power resource
                                    [  +0.000111] ACPI: \_TZ_.FN02: New power resource
                                    [  +0.000117] ACPI: \_TZ_.FN03: New power resource
                                    [  +0.000110] ACPI: \_TZ_.FN04: New power resource
                                    [  +0.000917] ACPI: \PIN_: New power resource
                                    [  +0.001337] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
                                    [  +0.000009] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
                                    [  +0.001531] acpi PNP0A08:00: _OSC: platform does not support [AER]
                                    [  +0.003020] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
                                    [  +0.000002] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
                                    [  +0.001772] PCI host bridge to bus 0000:00
                                    [  +0.000003] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
                                    [  +0.000003] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
                                    [  +0.000001] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
                                    [  +0.000002] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
                                    [  +0.000002] pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
                                    [  +0.000002] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
                                    [  +0.000002] pci_bus 0000:00: root bus resource [bus 00-fe]
                                    [  +0.000112] pci 0000:00:00.0: [8086:3ecc] type 00 class 0x060000 conventional PCI endpoint
                                    [  +0.000098] pci 0000:00:02.0: [8086:3ea5] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
                                    [  +0.000011] pci 0000:00:02.0: BAR 0 [mem 0x90000000-0x90ffffff 64bit]
                                    [  +0.000007] pci 0000:00:02.0: BAR 2 [mem 0x80000000-0x8fffffff 64bit pref]
                                    [  +0.000005] pci 0000:00:02.0: BAR 4 [io  0x3000-0x303f]
                                    [  +0.000020] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
                                    [  +0.000268] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000 conventional PCI endpoint
                                    [  +0.000013] pci 0000:00:08.0: BAR 0 [mem 0x4000016000-0x4000016fff 64bit]
                                    [  +0.000140] pci 0000:00:12.0: [8086:9df9] type 00 class 0x118000 conventional PCI endpoint
                                    [  +0.000023] pci 0000:00:12.0: BAR 0 [mem 0x4000015000-0x4000015fff 64bit]
                                    [  +0.000176] pci 0000:00:14.0: [8086:9ded] type 00 class 0x0c0330 conventional PCI endpoint
                                    [  +0.000019] pci 0000:00:14.0: BAR 0 [mem 0x4000000000-0x400000ffff 64bit]
                                    [  +0.000067] pci 0000:00:14.0: PME# supported from D3hot D3cold
                                    [  +0.002214] pci 0000:00:14.2: [8086:9def] type 00 class 0x050000 conventional PCI endpoint
                                    [  +0.000021] pci 0000:00:14.2: BAR 0 [mem 0x4000010000-0x4000011fff 64bit]
                                    [  +0.000014] pci 0000:00:14.2: BAR 2 [mem 0x4000014000-0x4000014fff 64bit]
                                    [  +0.000154] pci 0000:00:16.0: [8086:9de0] type 00 class 0x078000 conventional PCI endpoint
                                    [  +0.000024] pci 0000:00:16.0: BAR 0 [mem 0x4000013000-0x4000013fff 64bit]
                                    [  +0.000082] pci 0000:00:16.0: PME# supported from D3hot
                                    [  +0.000647] pci 0000:00:17.0: [8086:9dd3] type 00 class 0x010601 conventional PCI endpoint
                                    [  +0.000018] pci 0000:00:17.0: BAR 0 [mem 0x91120000-0x91121fff]
                                    [  +0.000011] pci 0000:00:17.0: BAR 1 [mem 0x91123000-0x911230ff]
                                    [  +0.000009] pci 0000:00:17.0: BAR 2 [io  0x3090-0x3097]
                                    [  +0.000012] pci 0000:00:17.0: BAR 3 [io  0x3080-0x3083]
                                    [  +0.000008] pci 0000:00:17.0: BAR 4 [io  0x3060-0x307f]
                                    [  +0.000009] pci 0000:00:17.0: BAR 5 [mem 0x91122000-0x911227ff]
                                    [  +0.000049] pci 0000:00:17.0: PME# supported from D3hot
                                    [  +0.000560] pci 0000:00:1d.0: [8086:9db0] type 01 class 0x060400 PCIe Root Port
                                    [  +0.000041] pci 0000:00:1d.0: PCI bridge to [bus 01]
                                    [  +0.000008] pci 0000:00:1d.0:   bridge window [mem 0x91000000-0x910fffff]
                                    [  +0.000096] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
                                    [  +0.000048] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
                                    [  +0.001070] pci 0000:00:1f.0: [8086:9d84] type 00 class 0x060100 conventional PCI endpoint
                                    [  +0.000529] pci 0000:00:1f.4: [8086:9da3] type 00 class 0x0c0500 conventional PCI endpoint
                                    [  +0.000028] pci 0000:00:1f.4: BAR 0 [mem 0x4000012000-0x40000120ff 64bit]
                                    [  +0.000030] pci 0000:00:1f.4: BAR 4 [io  0xefa0-0xefbf]
                                    [  +0.000338] pci 0000:00:1f.5: [8086:9da4] type 00 class 0x0c8000 conventional PCI endpoint
                                    [  +0.000019] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
                                    [  +0.000142] pci 0000:00:1f.6: [8086:15be] type 00 class 0x020000 conventional PCI endpoint
                                    [  +0.000038] pci 0000:00:1f.6: BAR 0 [mem 0x91100000-0x9111ffff]
                                    [  +0.000202] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
                                    [  +0.000430] pci 0000:01:00.0: [15b7:5017] type 00 class 0x010802 PCIe Endpoint
                                    [  +0.000022] pci 0000:01:00.0: BAR 0 [mem 0x91000000-0x91003fff 64bit]
                                    [  +0.000195] pci 0000:01:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:1d.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
                                    [  +0.000140] pci 0000:00:1d.0: PCI bridge to [bus 01]
                                    [  +0.002607] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
                                    [  +0.000110] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
                                    [  +0.000108] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
                                    [  +0.000107] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
                                    [  +0.000107] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
                                    [  +0.000112] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
                                    [  +0.000109] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
                                    [  +0.000107] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
                                    [  +0.006614] ACPI: EC: interrupt unblocked
                                    [  +0.000002] ACPI: EC: event unblocked
                                    [  +0.000013] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
                                    [  +0.000001] ACPI: EC: GPE=0x14
                                    [  +0.000002] ACPI: \_SB_.PCI0.LPCB.H_EC: Boot DSDT EC initialization complete
                                    [  +0.000002] ACPI: \_SB_.PCI0.LPCB.H_EC: EC: Used to handle transactions and events
                                    [  +0.000128] iommu: Default domain type: Translated
                                    [  +0.000000] iommu: DMA domain TLB invalidation policy: lazy mode
                                    [  +0.001128] SCSI subsystem initialized
                                    [  +0.000006] libata version 3.00 loaded.
                                    [  +0.000000] ACPI: bus type USB registered
                                    [  +0.000000] usbcore: registered new interface driver usbfs
                                    [  +0.000000] usbcore: registered new interface driver hub
                                    [  +0.000000] usbcore: registered new device driver usb
                                    [  +0.000000] pps_core: LinuxPPS API ver. 1 registered
                                    [  +0.000000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                                    [  +0.000000] PTP clock support registered
                                    [  +0.000000] EDAC MC: Ver: 3.0.0
                                    [  +0.000065] efivars: Registered efivars operations
                                    [  +0.000000] NetLabel: Initializing
                                    [  +0.000000] NetLabel:  domain hash size = 128
                                    [  +0.000000] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
                                    [  +0.000000] NetLabel:  unlabeled traffic allowed by default
                                    [  +0.000797] mctp: management component transport protocol core
                                    [  +0.000000] NET: Registered PF_MCTP protocol family
                                    [  +0.000000] PCI: Using ACPI for IRQ routing
                                    [  +0.041329] PCI: pci_cache_line_size set to 64 bytes
                                    [  +0.000209] e820: reserve RAM buffer [mem 0x0005f000-0x0005ffff]
                                    [  +0.000002] e820: reserve RAM buffer [mem 0x77b7b000-0x77ffffff]
                                    [  +0.000002] e820: reserve RAM buffer [mem 0x7bac0000-0x7bffffff]
                                    [  +0.000001] e820: reserve RAM buffer [mem 0x7cd0f000-0x7fffffff]
                                    [  +0.000001] e820: reserve RAM buffer [mem 0x87f000000-0x87fffffff]
                                    [  +0.000045] pci 0000:00:02.0: vgaarb: setting as boot VGA device
                                    [  +0.000000] pci 0000:00:02.0: vgaarb: bridge control possible
                                    [  +0.000000] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
                                    [  +0.000000] vgaarb: loaded
                                    [  +0.000000] clocksource: Switched to clocksource tsc-early
                                    [  +0.000188] VFS: Disk quotas dquot_6.6.0
                                    [  +0.000015] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
                                    [  +0.000137] AppArmor: AppArmor Filesystem Enabled
                                    [  +0.000030] pnp: PnP ACPI init
                                    [  +0.000116] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
                                    [  +0.000497] system 00:01: [io  0x0a00-0x0a1f] has been reserved
                                    [  +0.000003] system 00:01: [io  0x0a20-0x0a2f] has been reserved
                                    [  +0.000002] system 00:01: [io  0x0a30-0x0a3f] has been reserved
                                    [  +0.000002] system 00:01: [io  0x0a40-0x0a4f] has been reserved
                                    [  +0.000002] system 00:01: [io  0x0a50-0x0a5f] has been reserved
                                    [  +0.000002] system 00:01: [io  0x0a60-0x0a6f] has been reserved
                                    [  +0.000283] system 00:02: [io  0x0680-0x069f] has been reserved
                                    [  +0.000003] system 00:02: [io  0x164e-0x164f] has been reserved
                                    [  +0.000144] system 00:03: [io  0x1854-0x1857] has been reserved
                                    [  +0.000285] system 00:04: [mem 0xfed10000-0xfed17fff] has been reserved
                                    [  +0.000003] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
                                    [  +0.000002] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
                                    [  +0.000002] system 00:04: [mem 0xe0000000-0xefffffff] has been reserved
                                    [  +0.000002] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
                                    [  +0.000002] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
                                    [  +0.000002] system 00:04: [mem 0xfed45000-0xfed8ffff] has been reserved
                                    [  +0.000002] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
                                    [  +0.000271] system 00:05: [io  0x1800-0x18fe] could not be reserved
                                    [  +0.000003] system 00:05: [mem 0xfd000000-0xfd69ffff] has been reserved
                                    [  +0.000002] system 00:05: [mem 0xfd6b0000-0xfd6cffff] has been reserved
                                    [  +0.000002] system 00:05: [mem 0xfd6f0000-0xfdffffff] has been reserved
                                    [  +0.000002] system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
                                    [  +0.000002] system 00:05: [mem 0xfe200000-0xfe7fffff] has been reserved
                                    [  +0.000002] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
                                    [  +0.000370] system 00:06: [io  0x2000-0x20fe] has been reserved
                                    [  +0.002626] pnp: PnP ACPI: found 8 devices
                                    [  +0.006195] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
                                    [  +0.000073] NET: Registered PF_INET protocol family
                                    [  +0.000128] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
                                    [  +0.018063] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
                                    [  +0.000035] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
                                    [  +0.000108] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
                                    [  +0.000391] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
                                    [  +0.000227] TCP: Hash tables configured (established 262144 bind 65536)
                                    [  +0.000119] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
                                    [  +0.000083] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
                                    [  +0.000075] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
                                    [  +0.000096] NET: Registered PF_UNIX/PF_LOCAL protocol family
                                    [  +0.000008] NET: Registered PF_XDP protocol family
                                    [  +0.000012] pci 0000:00:1d.0: PCI bridge to [bus 01]
                                    [  +0.000018] pci 0000:00:1d.0:   bridge window [mem 0x91000000-0x910fffff]
                                    [  +0.000036] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
                                    [  +0.000003] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
                                    [  +0.000002] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
                                    [  +0.000002] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
                                    [  +0.000001] pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
                                    [  +0.000002] pci_bus 0000:00: resource 9 [mem 0xfc800000-0xfe7fffff window]
                                    [  +0.000002] pci_bus 0000:01: resource 1 [mem 0x91000000-0x910fffff]
                                    [  +0.000799] PCI: CLS 64 bytes, default 64
                                    [  +0.000049] DMAR: No ATSR found
                                    [  +0.000001] DMAR: No SATC found
                                    [  +0.000001] DMAR: IOMMU feature fl1gp_support inconsistent
                                    [  +0.000001] DMAR: IOMMU feature pgsel_inv inconsistent
                                    [  +0.000001] DMAR: IOMMU feature nwfs inconsistent
                                    [  +0.000001] DMAR: IOMMU feature pasid inconsistent
                                    [  +0.000001] DMAR: IOMMU feature eafs inconsistent
                                    [  +0.000001] DMAR: IOMMU feature prs inconsistent
                                    [  +0.000001] DMAR: IOMMU feature nest inconsistent
                                    [  +0.000001] DMAR: IOMMU feature mts inconsistent
                                    [  +0.000001] DMAR: IOMMU feature sc_support inconsistent
                                    [  +0.000001] DMAR: IOMMU feature dev_iotlb_support inconsistent
                                    [  +0.000001] DMAR: dmar0: Using Queued invalidation
                                    [  +0.000004] DMAR: dmar1: Using Queued invalidation
                                    [  +0.000027] Trying to unpack rootfs image as initramfs...
                                    [  +0.000195] pci 0000:00:02.0: Adding to iommu group 0
                                    [  +0.000454] pci 0000:00:00.0: Adding to iommu group 1
                                    [  +0.000010] pci 0000:00:08.0: Adding to iommu group 2
                                    [  +0.000015] pci 0000:00:12.0: Adding to iommu group 3
                                    [  +0.000014] pci 0000:00:14.0: Adding to iommu group 4
                                    [  +0.000008] pci 0000:00:14.2: Adding to iommu group 4
                                    [  +0.000011] pci 0000:00:16.0: Adding to iommu group 5
                                    [  +0.000010] pci 0000:00:17.0: Adding to iommu group 6
                                    [  +0.000013] pci 0000:00:1d.0: Adding to iommu group 7
                                    [  +0.000020] pci 0000:00:1f.0: Adding to iommu group 8
                                    [  +0.000009] pci 0000:00:1f.4: Adding to iommu group 8
                                    [  +0.000009] pci 0000:00:1f.5: Adding to iommu group 8
                                    [  +0.000009] pci 0000:00:1f.6: Adding to iommu group 8
                                    [  +0.000012] pci 0000:01:00.0: Adding to iommu group 9
                                    [  +0.000668] DMAR: Intel(R) Virtualization Technology for Directed I/O
                                    [  +0.000002] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
                                    [  +0.000002] software IO TLB: mapped [mem 0x000000006d9f1000-0x00000000719f1000] (64MB)
                                    [  +0.000165] platform rtc_cmos: registered platform RTC device (no PNP device found)
                                    [  +0.000454] Initialise system trusted keyrings
                                    [  +0.000007] Key type blacklist registered
                                    [  +0.000049] workingset: timestamp_bits=36 max_order=23 bucket_order=0
                                    [  +0.000018] zbud: loaded
                                    [  +0.000393] squashfs: version 4.0 (2009/01/31) Phillip Lougher
                                    [  +0.000126] fuse: init (API version 7.39)
                                    [  +0.000144] integrity: Platform Keyring initialized
                                    [  +0.000006] integrity: Machine keyring initialized
                                    [  +0.021652] Key type asymmetric registered
                                    [  +0.000006] Asymmetric key parser 'x509' registered
                                    [  +0.000033] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
                                    [  +0.000063] io scheduler mq-deadline registered
                                    [  +0.003263] pcieport 0000:00:1d.0: PME: Signaling with IRQ 122
                                    [  +0.000149] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
                                    [  +0.000579] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
                                    [  +0.000028] ACPI: button: Sleep Button [SLPB]
                                    [  +0.000033] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
                                    [  +0.000017] ACPI: button: Power Button [PWRB]
                                    [  +0.000033] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
                                    [  +0.000042] ACPI: button: Power Button [PWRF]
                                    [  +0.000442] ACPI: thermal: [Firmware Bug]: No valid trip points!
                                    [  +0.000775] thermal LNXTHERM:01: registered as thermal_zone0
                                    [  +0.000004] ACPI: thermal: Thermal Zone [TZ00] (28 C)
                                    [  +0.000350] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
                                    [  +0.003432] hpet_acpi_add: no address or irqs in _CRS
                                    [  +0.000060] Linux agpgart interface v0.103
                                    [  +0.009358] loop: module loaded
                                    [  +0.000309] ACPI: bus type drm_connector registered
                                    [  +0.000356] tun: Universal TUN/TAP device driver, 1.6
                                    [  +0.000078] PPP generic driver version 2.4.2
                                    [  +0.000120] i8042: PNP: No PS/2 controller found.
                                    [  +0.000002] i8042: Probing ports directly.
                                    [  +0.001176] i8042: No controller found
                                    [  +0.000121] mousedev: PS/2 mouse device common for all mice
                                    [  +0.000252] rtc_cmos rtc_cmos: RTC can wake from S4
                                    [  +0.001201] rtc_cmos rtc_cmos: registered as rtc0
                                    [  +0.000231] rtc_cmos rtc_cmos: setting system clock to 2025-02-27T17:36:06 UTC (1740677766)
                                    [  +0.000040] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
                                    [  +0.000013] i2c_dev: i2c /dev entries driver
                                    [  +0.000266] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
                                    [  +0.000018] device-mapper: uevent: version 1.0.3
                                    [  +0.000085] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
                                    [  +0.000031] platform eisa.0: Probing EISA bus 0
                                    [  +0.000006] platform eisa.0: EISA: Cannot allocate resource for mainboard
                                    [  +0.000003] platform eisa.0: Cannot allocate resource for EISA slot 1
                                    [  +0.000003] platform eisa.0: Cannot allocate resource for EISA slot 2
                                    [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 3
                                    [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 4
                                    [  +0.000003] platform eisa.0: Cannot allocate resource for EISA slot 5
                                    [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 6
                                    [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 7
                                    [  +0.000002] platform eisa.0: Cannot allocate resource for EISA slot 8
                                    [  +0.000002] platform eisa.0: EISA: Detected 0 cards
                                    [  +0.000005] intel_pstate: Intel P-state driver initializing
                                    [  +0.000229] intel_pstate: HWP enabled
                                    [  +0.000174] ledtrig-cpu: registered to indicate activity on CPUs
                                    [  +0.000185] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
                                    [  +0.000232] fbcon: Deferring console take-over
                                    [  +0.000003] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
                                    [  +0.000079] drop_monitor: Initializing network drop monitor service
                                    [  +0.000113] NET: Registered PF_INET6 protocol family
                                    [  +0.326773] Freeing initrd memory: 59888K
                                    [  +0.006651] Segment Routing with IPv6
                                    [  +0.000014] In-situ OAM (IOAM) with IPv6
                                    [  +0.000025] NET: Registered PF_PACKET protocol family
                                    [  +0.000017] Bridge firewalling registered
                                    [  +0.000027] Key type dns_resolver registered
                                    [  +0.000340] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
                                    [  +0.000074] microcode: Current revision: 0x000000d6
                                    [  +0.000139] IPI shorthand broadcast: enabled
                                    [  +0.001600] sched_clock: Marking stable (816001173, 8636385)->(870583955, -45946397)
                                    [  +0.000156] registered taskstats version 1
                                    [  +0.000176] Loading compiled-in X.509 certificates
                                    [  +0.000454] Loaded X.509 cert 'Build time autogenerated kernel key: 1337ca12f22f1729e731a6737b914ad4e01db977'
                                    [  +0.003566] Key type .fscrypt registered
                                    [  +0.000002] Key type fscrypt-provisioning registered
                                    [  +0.000041] Key type trusted registered
                                    [  +0.015393] Key type encrypted registered
                                    [  +0.000006] AppArmor: AppArmor sha256 policy hashing enabled
                                    [  +0.000695] integrity: Loading X.509 certificate: UEFI:db
                                    [  +0.000032] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
                                    [  +0.000001] integrity: Loading X.509 certificate: UEFI:db
                                    [  +0.000016] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
                                    [  +0.000327] integrity: Loaded X.509 cert 'CISD FW Update - Certificate: 068268b4a41c93854262d49b4f788f13'
                                    [  +0.000610] Loading compiled-in module X.509 certificates
                                    [  +0.000417] Loaded X.509 cert 'Build time autogenerated kernel key: 1337ca12f22f1729e731a6737b914ad4e01db977'
                                    [  +0.000003] ima: Allocated hash algorithm: sha256
                                    [  +0.017344] ima: No architecture policies found
                                    [  +0.000013] evm: Initialising EVM extended attributes:
                                    [  +0.000001] evm: security.selinux
                                    [  +0.000002] evm: security.SMACK64
                                    [  +0.000000] evm: security.SMACK64EXEC
                                    [  +0.000001] evm: security.SMACK64TRANSMUTE
                                    [  +0.000001] evm: security.SMACK64MMAP
                                    [  +0.000001] evm: security.apparmor
                                    [  +0.000000] evm: security.ima
                                    [  +0.000001] evm: security.capability
                                    [  +0.000001] evm: HMAC attrs: 0x1
                                    [  +0.000230] PM:   Magic number: 13:389:644
                                    [  +0.005253] RAS: Correctable Errors collector initialized.
                                    [  +0.000065] clk: Disabling unused clocks
                                    [  +0.000914] Freeing unused decrypted memory: 2028K
                                    [  +0.000356] Freeing unused kernel image (initmem) memory: 4816K
                                    [  +0.000044] Write protecting the kernel read-only data: 34816k
                                    [  +0.000358] Freeing unused kernel image (rodata/data gap) memory: 880K
                                    [  +0.043280] x86/mm: Checked W+X mappings: passed, no W+X pages found.
                                    [  +0.000003] x86/mm: Checking user space page tables
                                    [  +0.041640] x86/mm: Checked W+X mappings: passed, no W+X pages found.
                                    [  +0.000005] Run /init as init process
                                    [  +0.000001]   with arguments:
                                    [  +0.000002]     /init
                                    [  +0.000001]   with environment:
                                    [  +0.000001]     HOME=/
                                    [  +0.000000]     TERM=linux
                                    [  +0.000001]     BOOT_IMAGE=/boot/vmlinuz-6.8.12-8-pve
                                    [  +0.204928] i801_smbus 0000:00:1f.4: SPD Write Disable is set
                                    [  +0.000057] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
                                    [  +0.000109] ahci 0000:00:17.0: version 3.0
                                    [  +0.000331] e1000e: Intel(R) PRO/1000 Network Driver
                                    [  +0.000002] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
                                    [  +0.000012] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x4 impl SATA mode
                                    [  +0.000006] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part deso sadm sds apst
                                    [  +0.001148] nvme nvme0: pci function 0000:01:00.0
                                    [  +0.000373] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
                                    [  +0.000159] scsi host0: ahci
                                    [  +0.000628] scsi host1: ahci
                                    [  +0.001023] i2c i2c-0: 2/2 memory slots populated (from DMI)
                                    [  +0.000447] i2c i2c-0: Successfully instantiated SPD at 0x50
                                    [  +0.002647] scsi host2: ahci
                                    [  +0.010720] ata1: DUMMY
                                    [  +0.000004] ata2: DUMMY
                                    [  +0.000006] ata3: SATA max UDMA/133 abar m2048@0x91122000 port 0x91122200 irq 123 lpm-pol 3
                                    [  +0.021614] nvme nvme0: allocated 32 MiB host memory buffer.
                                    [  +0.001032] nvme nvme0: 4/0/0 default/read/poll queues
                                    [  +0.003394]  nvme0n1: p1 p2 p3
                                    [  +0.189501] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
                                    [  +0.064409] tsc: Refined TSC clocksource calibration: 2999.999 MHz
                                    [  +0.000007] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b3e44b2357, max_idle_ns: 440795324996 ns
                                    [  +0.000037] clocksource: Switched to clocksource tsc
                                    [  +0.001417] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) 1c:69:7a:6d:9d:d2
                                    [  +0.000007] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
                                    [  +0.000089] e1000e 0000:00:1f.6 eth0: MAC: 13, PHY: 12, PBA No: FFFFFF-0FF
                                    [  +0.029179] ata3: SATA link down (SStatus 4 SControl 300)
                                    [  +0.003150] xhci_hcd 0000:00:14.0: xHCI Host Controller
                                    [  +0.000038] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
                                    [  +0.001161] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
                                    [  +0.000239] xhci_hcd 0000:00:14.0: xHCI Host Controller
                                    [  +0.000004] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
                                    [  +0.000004] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
                                    [  +0.000038] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
                                    [  +0.000002] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                    [  +0.000002] usb usb1: Product: xHCI Host Controller
                                    [  +0.000001] usb usb1: Manufacturer: Linux 6.8.12-8-pve xhci-hcd
                                    [  +0.000001] usb usb1: SerialNumber: 0000:00:14.0
                                    [  +0.000133] hub 1-0:1.0: USB hub found
                                    [  +0.000019] hub 1-0:1.0: 12 ports detected
                                    [  +0.002069] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
                                    [  +0.000003] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                                    [  +0.000002] usb usb2: Product: xHCI Host Controller
                                    [  +0.000001] usb usb2: Manufacturer: Linux 6.8.12-8-pve xhci-hcd
                                    [  +0.000002] usb usb2: SerialNumber: 0000:00:14.0
                                    [  +0.000088] hub 2-0:1.0: USB hub found
                                    [  +0.000015] hub 2-0:1.0: 6 ports detected
                                    [  +0.005275] e1000e 0000:00:1f.6 eno1: renamed from eth0
                                    [  +0.230977] usb 1-1: new full-speed USB device number 2 using xhci_hcd
                                    [  +0.092237] fbcon: Taking over console
                                    [  +0.000979] Console: switching to colour frame buffer device 100x37
                                    [  +0.034768] usb 1-1: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
                                    [  +0.000004] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                    [  +0.000002] usb 1-1: Product: Sonoff Zigbee 3.0 USB Dongle Plus
                                    [  +0.000004] usb 1-1: Manufacturer: Silicon Labs
                                    [  +0.000002] usb 1-1: SerialNumber: 0001
                                    [  +0.036028] raid6: avx2x4   gen() 39780 MB/s
                                    [  +0.017000] raid6: avx2x2   gen() 40432 MB/s
                                    [  +0.017002] raid6: avx2x1   gen() 32501 MB/s
                                    [  +0.000001] raid6: using algorithm avx2x2 gen() 40432 MB/s
                                    [  +0.017004] raid6: .... xor() 22858 MB/s, rmw enabled
                                    [  +0.000001] raid6: using avx2x2 recovery algorithm
                                    [  +0.000766] xor: automatically using best checksumming function   avx
                                    [  +0.027203] usb 1-3: new full-speed USB device number 3 using xhci_hcd
                                    [  +0.063600] Btrfs loaded, zoned=yes, fsverity=yes
                                    [  +0.047801] EXT4-fs (dm-1): mounted filesystem 60c771ed-5eba-4502-8f33-6cf0612844c7 ro with ordered data mode. Quota mode: none.
                                    [  +0.022049] usb 1-3: New USB device found, idVendor=0403, idProduct=6f70, bcdDevice= 6.00
                                    [  +0.000004] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                    [  +0.000002] usb 1-3: Product: HB-RF-USB
                                    [  +0.000001] usb 1-3: Manufacturer: Alexander Reinert
                                    [  +0.000002] usb 1-3: SerialNumber: A94VBWDX
                                    [  +0.059967] systemd[1]: Inserted module 'autofs4'
                                    [  +0.052982] systemd[1]: systemd 252.33-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
                                    [  +0.000006] systemd[1]: Detected architecture x86-64.
                                    [  +0.001004] systemd[1]: Hostname set to <pve>.
                                    [  +0.121614] systemd[1]: Queued start job for default target graphical.target.
                                    [  +0.013031] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
                                    [  +0.000525] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
                                    [  +0.000465] systemd[1]: Created slice system-postfix.slice - Slice /system/postfix.
                                    [  +0.000324] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
                                    [  +0.000264] systemd[1]: Created slice user.slice - User and Session Slice.
                                    [  +0.000062] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
                                    [  +0.000046] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
                                    [  +0.000145] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
                                    [  +0.000020] systemd[1]: Expecting device dev-disk-by\x2duuid-71C7\x2d73FA.device - /dev/disk/by-uuid/71C7-73FA...
                                    [  +0.000008] systemd[1]: Expecting device dev-pve-swap.device - /dev/pve/swap...
                                    [  +0.000013] systemd[1]: Reached target ceph-fuse.target - ceph target allowing to start/stop all ceph-fuse@.service instances at once.
                                    [  +0.000010] systemd[1]: Reached target ceph.target - ceph target allowing to start/stop all ceph*@.service instances at once.
                                    [  +0.000010] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
                                    [  +0.000018] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
                                    [  +0.000033] systemd[1]: Reached target paths.target - Path Units.
                                    [  +0.000026] systemd[1]: Reached target slices.target - Slice Units.
                                    [  +0.000018] systemd[1]: Reached target time-set.target - System Time Set.
                                    [  +0.000028] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
                                    [  +0.000070] systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
                                    [  +0.000100] systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
                                    [  +0.003069] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
                                    [  +0.000153] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
                                    [  +0.000064] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
                                    [  +0.000272] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
                                    [  +0.000144] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
                                    [  +0.000155] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
                                    [  +0.000245] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
                                    [  +0.000085] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
                                    [  +0.000787] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
                                    [  +0.000805] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
                                    [  +0.001293] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
                                    [  +0.001102] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
                                    [  +0.000099] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
                                    [  +0.001187] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
                                    [  +0.001207] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
                                    [  +0.001449] systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
                                    [  +0.001250] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
                                    [  +0.001215] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
                                    [  +0.001302] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
                                    [  +0.001376] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
                                    [  +0.001250] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
                                    [  +0.001345] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
                                    [  +0.000385] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
                                    [  +0.002122] systemd[1]: Starting systemd-journald.service - Journal Service...
                                    [  +0.000335] pstore: Using crash dump compression: deflate
                                    [  +0.003005] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
                                    [  +0.008397] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
                                    [  +0.009429] pstore: Registered efi_pstore as persistent store backend
                                    [  +0.000699] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
                                    [  +0.002516] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
                                    [  +0.000177] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
                                    [  +0.000131] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
                                    [  +0.000126] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
                                    [  +0.000314] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
                                    [  +0.000406] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
                                    [  +0.000341] systemd[1]: modprobe@configfs.service: Deactivated successfully.
                                    [  +0.000166] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
                                    [  +0.000365] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
                                    [  +0.000189] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
                                    [  +0.000348] systemd[1]: modprobe@drm.service: Deactivated successfully.
                                    [  +0.000150] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
                                    [  +0.000328] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
                                    [  +0.000168] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
                                    [  +0.000301] systemd[1]: modprobe@fuse.service: Deactivated successfully.
                                    [  +0.000161] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
                                    [  +0.000342] systemd[1]: modprobe@loop.service: Deactivated successfully.
                                    [  +0.000145] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
                                    [  +0.001699] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
                                    [  +0.001733] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
                                    [  +0.000102] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
                                    [  +0.002115] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
                                    [  +0.001642] systemd[1]: Started dm-event.service - Device-mapper event daemon.
                                    [  +0.001019] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
                                    [  +0.001952] spl: loading out-of-tree module taints kernel.
                                    [  +0.001643] EXT4-fs (dm-1): re-mounted 60c771ed-5eba-4502-8f33-6cf0612844c7 r/w. Quota mode: none.
                                    [  +0.001568] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
                                    [  +0.000174] systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
                                    [  +0.000049] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
                                    [  +0.001943] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
                                    [  +0.001829] systemd[1]: Starting systemd-sysusers.service - Create System Users...
                                    [  +0.032841] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed.
                                    [  +0.000319] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
                                    [  +0.004085] systemd[1]: Finished systemd-sysusers.service - Create System Users.
                                    [  +0.008321] zfs: module license 'CDDL' taints kernel.
                                    [  +0.000003] Disabling lock debugging due to kernel taint
                                    [  +0.000019] zfs: module license taints kernel.
                                    [  +0.006140] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
                                    [  +0.000152] systemd[1]: Started systemd-journald.service - Journal Service.
                                    [  +0.011678] systemd-journald[328]: Received client request to flush runtime journal.
                                    [  +0.777840] Adding 8388604k swap on /dev/mapper/pve-swap.  Priority:-2 extents:1 across:8388604k SS
                                    [  +0.033649] intel_pmc_core INT33A1:00:  initialized
                                    [  +0.043927] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
                                    [  +0.006824] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
                                    [  +0.008765] usbcore: registered new interface driver usbserial_generic
                                    [  +0.000011] usbserial: USB Serial support registered for generic
                                    [  +0.000427] input: PC Speaker as /devices/platform/pcspkr/input/input3
                                    [  +0.004241] usbcore: registered new interface driver cp210x
                                    [  +0.000016] usbserial: USB Serial support registered for cp210x
                                    [  +0.000017] cp210x 1-1:1.0: cp210x converter detected
                                    [  +0.004312] usb 1-1: cp210x converter now attached to ttyUSB0
                                    [  +0.000723] Creating 1 MTD partitions on "0000:00:1f.5":
                                    [  +0.000005] 0x000000000000-0x000001000000 : "BIOS"
                                    [  +0.509544] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
                                    [  +0.000003] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
                                    [  +0.000002] RAPL PMU: hw unit of domain package 2^-14 Joules
                                    [  +0.000002] RAPL PMU: hw unit of domain dram 2^-14 Joules
                                    [  +0.000001] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
                                    [  +0.000001] RAPL PMU: hw unit of domain psys 2^-14 Joules
                                    [  +0.144206] i915 0000:00:02.0: [drm] Found 128MB of eDRAM
                                    [  +0.000036] i915 0000:00:02.0: [drm] VT-d active for gfx access
                                    [  +0.000814] cryptd: max_cpu_qlen set to 1000
                                    [  +0.002566] Console: switching to colour dummy device 80x25
                                    [  +0.002663] AVX2 version of gcm_enc/dec engaged.
                                    [  +0.000034] AES CTR mode by8 optimization enabled
                                    [  +0.107633] i915 0000:00:02.0: vgaarb: deactivate vga console
                                    [  +0.000075] i915 0000:00:02.0: [drm] Using Transparent Hugepages
                                    [  +0.002024] i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
                                    [  +0.001146] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
                                    [  +0.000792] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
                                    [  +0.047049] intel_tcc_cooling: Programmable TCC Offset detected
                                    [  +0.265514] ZFS: Loaded module v2.2.7-pve1, ZFS pool version 5000, ZFS filesystem version 5
                                    [  +0.002725] intel_rapl_common: Found RAPL domain package
                                    [  +0.000004] intel_rapl_common: Found RAPL domain core
                                    [  +0.000001] intel_rapl_common: Found RAPL domain uncore
                                    [  +0.000001] intel_rapl_common: Found RAPL domain dram
                                    [  +0.000001] intel_rapl_common: Found RAPL domain psys
                                    [  +0.037231] i915 0000:00:02.0: [drm] [ENCODER:94:DDI A/PHY A] failed to retrieve link info, disabling eDP
                                    [  +0.034148] [drm] Initialized i915 1.6.0 20230929 for 0000:00:02.0 on minor 1
                                    [  +0.002495] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
                                    [  +0.000433] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
                                    [  +0.000163] i915 display info: display version: 9
                                    [  +0.000003] i915 display info: cursor_needs_physical: no
                                    [  +0.000002] i915 display info: has_cdclk_crawl: no
                                    [  +0.000001] i915 display info: has_cdclk_squash: no
                                    [  +0.000002] i915 display info: has_ddi: yes
                                    [  +0.000001] i915 display info: has_dp_mst: yes
                                    [  +0.000002] i915 display info: has_dsb: no
                                    [  +0.000001] i915 display info: has_fpga_dbg: yes
                                    [  +0.000001] i915 display info: has_gmch: no
                                    [  +0.000002] i915 display info: has_hotplug: yes
                                    [  +0.000001] i915 display info: has_hti: no
                                    [  +0.000001] i915 display info: has_ipc: yes
                                    [  +0.000001] i915 display info: has_overlay: no
                                    [  +0.000002] i915 display info: has_psr: yes
                                    [  +0.000001] i915 display info: has_psr_hw_tracking: yes
                                    [  +0.000002] i915 display info: overlay_needs_physical: no
                                    [  +0.000001] i915 display info: supports_tv: no
                                    [  +0.000001] i915 display info: has_hdcp: yes
                                    [  +0.000002] i915 display info: has_dmc: yes
                                    [  +0.000001] i915 display info: has_dsc: no
                                    [  +0.036090] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
                                    [  +0.034927] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
                                    [  +0.035743] i915 0000:00:02.0: [drm] Cannot find any crtc or sizes
                                    [  +0.022956] audit: type=1400 audit(1740677770.674:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="pve-container-mounthotplug" pid=536 comm="apparmor_parser"
                                    [  +0.003493] audit: type=1400 audit(1740677770.677:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=533 comm="apparmor_parser"
                                    [  +0.001701] audit: type=1400 audit(1740677770.680:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-copy" pid=539 comm="apparmor_parser"
                                    [  +0.000111] audit: type=1400 audit(1740677770.680:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=535 comm="apparmor_parser"
                                    [  +0.000004] audit: type=1400 audit(1740677770.680:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=535 comm="apparmor_parser"
                                    [  +0.003646] audit: type=1400 audit(1740677770.683:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=540 comm="apparmor_parser"
                                    [  +0.001377] audit: type=1400 audit(1740677770.685:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=537 comm="apparmor_parser"
                                    [  +0.000007] audit: type=1400 audit(1740677770.685:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=537 comm="apparmor_parser"
                                    [  +0.000004] audit: type=1400 audit(1740677770.685:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=537 comm="apparmor_parser"
                                    [  +0.065124] RPC: Registered named UNIX socket transport module.
                                    [  +0.000005] RPC: Registered udp transport module.
                                    [  +0.000001] RPC: Registered tcp transport module.
                                    [  +0.000001] RPC: Registered tcp-with-tls transport module.
                                    [  +0.000001] RPC: Registered tcp NFSv4.1 backchannel transport module.
                                    [  +0.042592] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
                                    [  +0.000005] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
                                    [  +0.638003] vmbr0: port 1(eno1) entered blocking state
                                    [  +0.000005] vmbr0: port 1(eno1) entered disabled state
                                    [  +0.000016] e1000e 0000:00:1f.6 eno1: entered allmulticast mode
                                    [  +0.000043] e1000e 0000:00:1f.6 eno1: entered promiscuous mode
                                    [  +0.705546] kauditd_printk_skb: 11 callbacks suppressed
                                    [  +0.000003] audit: type=1400 audit(1740677772.136:22): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/bin/lxc-copy" pid=682 comm="apparmor_parser"
                                    [  +0.010221] audit: type=1400 audit(1740677772.146:23): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/bin/lxc-start" pid=689 comm="apparmor_parser"
                                    [  +0.014489] audit: type=1400 audit(1740677772.161:24): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default" pid=694 comm="apparmor_parser"
                                    [  +0.000007] audit: type=1400 audit(1740677772.161:25): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-cgns" pid=694 comm="apparmor_parser"
                                    [  +0.000004] audit: type=1400 audit(1740677772.161:26): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-mounting" pid=694 comm="apparmor_parser"
                                    [  +0.000003] audit: type=1400 audit(1740677772.161:27): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="lxc-container-default-with-nesting" pid=694 comm="apparmor_parser"
                                    [  +2.488175] e1000e 0000:00:1f.6 eno1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
                                    [  +0.000032] vmbr0: port 1(eno1) entered blocking state
                                    [  +0.000005] vmbr0: port 1(eno1) entered forwarding state
                                    [  +9.731558] kvm_intel: L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html for details.
                                    [Feb27 18:37] audit: type=1400 audit(1740677824.803:28): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="pve-container-mounthotplug" pid=2277 comm="apparmor_parser"
                                    [ +46.150728] tap200i0: entered promiscuous mode
                                    [  +0.051460] vmbr0: port 2(fwpr200p0) entered blocking state
                                    [  +0.000004] vmbr0: port 2(fwpr200p0) entered disabled state
                                    [  +0.000013] fwpr200p0: entered allmulticast mode
                                    [  +0.000036] fwpr200p0: entered promiscuous mode
                                    [  +0.000028] vmbr0: port 2(fwpr200p0) entered blocking state
                                    [  +0.000001] vmbr0: port 2(fwpr200p0) entered forwarding state
                                    [  +0.009386] fwbr200i0: port 1(fwln200i0) entered blocking state
                                    [  +0.000004] fwbr200i0: port 1(fwln200i0) entered disabled state
                                    [  +0.000015] fwln200i0: entered allmulticast mode
                                    [  +0.000036] fwln200i0: entered promiscuous mode
                                    [  +0.000030] fwbr200i0: port 1(fwln200i0) entered blocking state
                                    [  +0.000001] fwbr200i0: port 1(fwln200i0) entered forwarding state
                                    [  +0.009431] fwbr200i0: port 2(tap200i0) entered blocking state
                                    [  +0.000004] fwbr200i0: port 2(tap200i0) entered disabled state
                                    [  +0.000011] tap200i0: entered allmulticast mode
                                    [  +0.000054] fwbr200i0: port 2(tap200i0) entered blocking state
                                    [  +0.000002] fwbr200i0: port 2(tap200i0) entered forwarding state
                                    [Feb27 18:38] usb 1-3: reset full-speed USB device number 3 using xhci_hcd
                                    [Feb27 18:39] tap100i0: entered promiscuous mode
                                    [  +0.050383] vmbr0: port 3(fwpr100p0) entered blocking state
                                    [  +0.000004] vmbr0: port 3(fwpr100p0) entered disabled state
                                    [  +0.000016] fwpr100p0: entered allmulticast mode
                                    [  +0.000037] fwpr100p0: entered promiscuous mode
                                    [  +0.000022] vmbr0: port 3(fwpr100p0) entered blocking state
                                    [  +0.000003] vmbr0: port 3(fwpr100p0) entered forwarding state
                                    [  +0.009775] fwbr100i0: port 1(fwln100i0) entered blocking state
                                    [  +0.000004] fwbr100i0: port 1(fwln100i0) entered disabled state
                                    [  +0.000024] fwln100i0: entered allmulticast mode
                                    [  +0.000038] fwln100i0: entered promiscuous mode
                                    [  +0.000039] fwbr100i0: port 1(fwln100i0) entered blocking state
                                    [  +0.000004] fwbr100i0: port 1(fwln100i0) entered forwarding state
                                    [  +0.010007] fwbr100i0: port 2(tap100i0) entered blocking state
                                    [  +0.000004] fwbr100i0: port 2(tap100i0) entered disabled state
                                    [  +0.000012] tap100i0: entered allmulticast mode
                                    [  +0.000060] fwbr100i0: port 2(tap100i0) entered blocking state
                                    [  +0.000003] fwbr100i0: port 2(tap100i0) entered forwarding state
                                    [  +0.080460] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
                                    [  +0.000014] cp210x 1-1:1.0: device disconnected
                                    [ +11.194126] usb 1-1: reset full-speed USB device number 2 using xhci_hcd
                                    root@pve:~#
                                    JLegJ Offline
                                    JLegJ Offline
                                    JLeg
                                    @matrose65 …das sind nur normale Bootmeldungen - hast wohl vorhin frisch rebootet… (Feb27 18:36)
                                    Am besten nochmal reingucken, nachdem im iob wieder was passiert ist…
                                    Tatsächlich weiss ich nicht genau, ob sich dmesg zwischen vm und Host unterscheiden - im Fall, dass die VM mit den CPU-Model ‚host‘ (proxmox-vm-Einstellung) läuft denke ich eher nicht. Bei allem anderen hängt ja noch eine Emulation dazwischen (die du nicht bräuchtest, aber Default ist).
                                    Ich benutze LXC - da gibt‘s nur einen Kernel, und ein dmesg…
                                    • JLegJ JLeg
                                      matrose65
                                      @jleg
                                      ok danke dir.
                                      Ich habe schon immer eine bzw. zwei VM Iobroker und RaspberryMatic
                                      Ich wollte das auch schon mal umstellen, aber mit dem USB durchreichen kam ich nie so richtig klar.
                                      Ja ich habe frisch rebootet und gleich update erneuert.
                                      Wenn wieder so ein Absturz ist, mache ich nochmal ein dmesg und melde mich hier wieder
                                      Außer es hat noch jemand anderes eine Idee
                                      • M matrose65
                                        @jleg
                                        ok danke dir.
                                        matrose65
                                        Bin wieder da und habe echt langsam die Schn... voll.
                                        Heute alleine 3 mal. 00:55 11:18 15:20 Wenn ich nur wüsste was der Fehler ist. aber im Log ist immer was anderes am Anfang.
                                        Nur um 11:20 habe ich einen Log-Eintrag über bestimmt 20 Seiten mit nur Text in verschiedenen Sprachen
                                        Ich hänge mal einen kleinen Teil hier an
                                        2025-02-28 11:20:26.832 - warn: host.iobroker Cannot parse system.repositories - {"_id":"system.repositories","type":"config","common":{"name":{"en":"System repositories","de":"System-Repositories","ru":"Системные репозитории","pt":"Repositórios do sistema","nl":"Systeemrepository's","fr":"Référentiels système","it":"Repository di sistema","es":"Repositorios del sistema","pl":"Repozytoria systemowe","zh-cn":"系统资料库"},"dontDelete":true},"native":{"repositories":{"stable":{"link":"http://download.iobroker.net/sources-dist.json","json":{"_repoInfo":{"stable":true,"name":{"en":"Official stable repository","de":"Offizielles stabiles Repository","ru":"Официальный стабильный репозиторий","pt":"Repositório estável oficial","nl":"Officiële stabiliteit","fr":"Dépôt stable officiel","it":"Repository stabile ufficiale","es":"Repositorio estable oficial","pl":"Repozytorium","zh-cn":"A. 正式稳定存放处"},"repoTime":"2025-02-27T14:28:43.892Z","recommendedVersions":{"nodeJsAccepted":[18,20,22],"nodeJsRecommended":20,"npmRecommended":10}},"accuweather":{"name":"accuweather","version":"2.1.0","news":{"2.1.0":{"en":"Change: min. js-controller to 6.0.11\nChange: Outdated data is updated at startup.\nNew: Photo link added in current weather\nNew: Metric and Imperial are available for selection - Will be taken into account with the next data update.\nNew: In the event of a data retrieval error, an attempt is made again after 10 minute\nRemove admin option (restart blocking)\nRewritten in Typescript\nFor error codes from the 400 series, do not attempt any unscheduled reconnections.","de":"Änderung: min. js-controller auf 6.0.11\nÄnderung: Veraltete Daten werden beim Start aktualisiert.\nNeu: Fotolinkdp im aktuellen Wetter hinzugefügt\nNeu: Metric und Imperial stehen zur Auswahl - Wird mit dem nächsten Datenupdate berücksichtigt.\nNeu: Bei einem Datenabruffehler wird nach 10 Minuten erneut versucht\nAdmin-Option entfernen (Restart blockieren)\nNeu geschrieben in Typescript\nBei Fehlercodes aus der 400er Serie wird kein wiederverbindungsversuch gestartet, es bleibt beim normalen Zyklus.","ru":"Изменение: мин. js-контроллер до 6.0.11\nИзменение: устаревшие данные обновляются при запуске.\nНовый: Фотоссылка добавлена в текущую погоду\nНовый: Метрик и Империал доступны для выбора - будут приняты во внимание при следующем обновлении данных.\nНовое: В случае ошибки поиска данных, попытка повторяется через 10 минут\nУдалить параметр администратора (перезапуск блокировки)\nПереписанные в Typescript\nДля кодов ошибок из 400-й серии не пытайтесь каких-либо незапланированных перезаключений.","pt":"Mudança: min. js-controller para 6.0.11\nChange: Os dados desatualizados são atualizados na inicialização.\nNovo: Foto link adicionado no tempo atual\nNovo: Metric e Imperial estão disponíveis para seleção - Será levado em conta com a próxima atualização de dados.\nNovo: Em caso de erro de recuperação de dados, uma tentativa é feita novamente após 10 minutos\nRemova a opção admin (reiniciar bloqueio)\nReescrito em Typescript\nPara códigos de erro da série 400, não tente nenhuma reconexão não programada.","nl":"Wijziging: min. js-controller tot 6.0.11\nVerandering: Verouderde gegevens worden bijgewerkt bij het opstarten.\nNieuw: Foto link toegevoegd bij het huidige weer\nNieuw: Metric en Imperial zijn beschikbaar voor selectie - zal in aanmerking worden genomen bij de volgende gegevensupdate.\nNieuw: Bij een fout bij het ophalen van gegevens wordt na 10 minuten opnieuw een poging ondernomen\nAdmin optie verwijderen (opnieuw blokkeren)\nHerschreven in typescript\nVoor foutcodes uit de 400-serie, probeer geen ongeplande reconnecties.","fr":"Changement : min. js-controller à 6.0.11\nChangement : Les données périmées sont mises à jour au démarrage.\nNouveau: Lien photo ajouté dans la météo actuelle\nNouveau: Metric et Imperial sont disponibles pour la sélection - sera pris en compte avec la prochaine mise à jour des données.\nNouveau: En cas d'erreur de récupération de données, une tentative est faite après 10 minutes\nSupprimer l'option admin (redémarrer le blocage)\nRéécrit dans Typescript\nPour les codes d'erreur de la série 400, ne tentez pas de reconnections non programmées.","it":"Cambio: min. js-controller a 6.0.11\nModifica: i dati obsoleti vengono aggiornati all'avvio.\nNuovo: Collegamento foto aggiunto nel tempo corrente\nNovità: Metric e Imperial sono disponibili per la selezione - Sarà preso in considerazione con il prossimo aggiornamento dati.\nNuovo: In caso di errore di recupero dati, un tentativo viene fatto di nuovo dopo 10 minuti\nRimuovere l'opzione admin (blocco di riavvio)\nRescritto in Tipografia\nPer i codici di errore della serie 400, non tentare alcuna riconnessione non programmata.","es":"Cambio: min. js-controller a 6.0.11\nCambio: Los datos actualizados se actualizan al iniciarse.\nNuevo: Enlace fotográfico añadido en el tiempo actual\nNuevo: Métrico e Imperial están disponibles para la selección - Se tendrá en cuenta con la siguiente actualización de datos.\nNuevo: En caso de error de recuperación de datos, se vuelve a intentar después de 10 minutos\nEliminar la opción de administración (bloqueo de reinicio)\nReescrito en Tiposcript\nPara los códigos de error de la serie 400, no intenten ninguna reconexión no programada.","pl":"Zmiana: min. js- controller do 6.0.11\nZmiana: Zaległe dane są aktualizowane przy starcie.\nNowy: link fotograficzny dodany w obecnej pogodzie\nNowy: Metric i Imperial są dostępne do wyboru - zostaną uwzględnione w następnej aktualizacji danych.\nNowy: W przypadku błędu w odzyskiwaniu danych, próba jest ponownie po 10 minutach\nUsuń opcję admin (ponowne uruchomienie blokady)\nPrzepisane na maszynie\nDla kodów błędów z serii 400, nie próbuj żadnych nieplanowanych ponownych połączeń.","uk":"Зміна: хв. js-controller до 6.0.11\nЗміна: Оновлення застарілих даних при запуску.\nНова: Фото посилання, додана в поточну погоду\nНовий: Metric і Imperial доступні для вибору - Буде враховано з наступним оновленням даних.\nНова: У разі перерозподілу даних спроба повторно виконана після 10 хвилин\nВидалити опцію адміністратора (блокування місця)\nПодати заявку\nДля кодів помилок з серії 400 не намагайтеся ніяких небажаних відключень.","zh-cn":"更改:min.js控制器改为6.0.11\n更改:过期数据在启动时更新.\n新建: 在当前天气中添加图片链接\n新增:计量和帝国可供选择 -- -- 将在下一次数据更新时加以考虑.\n新建:如果出现数据检索错误,10分钟后再次尝试\n删除管理选项( 重新开始屏蔽)\n重写字体\n对于400系列的错误代码,不要尝试任何不定期的重联."},"2.1.0-alpha.0":{"en":"Change: min. js-controller to 6.0.11\nChange: Outdated data is updated at startup.\nNew: Photo link added in current weather\nNew: Metric and Imperial are available for selection - Will be taken into account with the next data update.\nNew: In the event of a data retrieval error, an attempt is made again after 10 minute\nRemove admin option (restart blocking)\nRewritten in Typescript","de":"Änderung: min. js-controller auf 6.0.11\nÄnderung: Überholte Daten werden beim Start aktualisiert.\nNeu: Fotolink im aktuellen Wetter hinzugefügt\nNeu: Metric und Imperial stehen zur Auswahl - Wird mit dem nächsten Datenupdate berücksichtigt.\nNeu: Bei einem Datenabruffehler wird nach 10 Minuten erneut versucht\nAdmin-Option entfernen (Restart blockieren)\nNeu geschrieben in Typescript","ru":"Изменение: мин. js-контроллер до 6.0.11\nИзменение: устаревшие данные обновляются при запуске.\nНовый: Фотоссылка добавлена в текущую погоду\nНовый: Метрик и Империал доступны для выбора - будут приняты во внимание при следующем обновлении данных.\nНовое: В случае ошибки поиска данных, попытка повторяется через 10 минут\nУдалить параметр администратора (перезапуск блокировки)\nПереписанные в Typescript","pt":"Mudança: min. js-controller para 6.0.11\nChange: Os dados desatualizados são atualizados na inicialização.\nNovo: Foto link adicionado no tempo atual\nNovo: Metric e Imperial estão disponíveis para seleção - Será levado em conta com a próxima atualização de dados.\nNovo: Em caso de erro de recuperação de dados, uma tentativa é feita novamente após 10 minutos\nRemova a opção admin (reiniciar bloqueio)\nReescrito em Typescript","nl":"Wijziging: min. js-controller tot 6.0.11\nVerandering: Verouderde gegevens worden bijgewerkt bij het opstarten.\nNieuw: Foto link toegevoegd bij het huidige weer\nNieuw: Metric en Imperial zijn beschikbaar voor selectie - zal in aanmerking worden genomen bij de volgende gegevensupdate.\nNieuw: Bij een fout bij het ophalen van gegevens wordt na 10 minuten opnieuw een poging ondernomen\nAdmin optie verwijderen (opnieuw blokkeren)\nHerschreven in typescript","fr":"Changement : min. js-controller à 6.0.11\nChangement : Les données périmées sont mises à jour au démarrage.\nNouveau: Lien photo ajouté dans la météo actuelle\nNouveau: Metric et Imperial sont disponibles pour la sélection - sera pris en compte avec la prochaine mise à jour des données.\nNouveau: En cas d'erreur de récupération de données, une tentative est faite après 10 minutes\nSupprimer l'option admin (redémarrer le blocage)\nRéécrit dans Typescript","it":"Cambio: min. js-controller a 6.0.11\nModifica: i dati obsoleti vengono aggiornati all'avvio.\nNuovo: Collegamento foto aggiunto nel tempo corrente\nNovità: Metric e Imperial sono disponibili per la selezione - Sarà preso in considerazione con il prossimo aggiornamento dati.\nNuovo: In caso di errore di recupero dati, un tentativo viene fatto di nuovo dopo 10 minuti\nRimuovere l'opzione admin (blocco di riavvio)\nRescritto in Tipografia","es":"Cambio: min. js-controller a 6.0.11\nCambio: Los datos actualizados se actualizan al iniciarse.\nNuevo: Enlace fotográfico añadido en el tiempo actual\nNuevo: Métrico e Imperial están disponibles para la selección - Se tendrá en cuenta con la siguiente actualización de datos.\nNuevo: En caso de error de recuperación de datos, se vuelve a intentar después de 10 minutos\nEliminar la opción de administración (bloqueo de reinicio)\nReescrito en Tiposcript","pl":"Zmiana: min. js- controller do 6.0.11\nZmiana: Zaległe dane są aktualizowane przy starcie.\nNowy: link fotograficzny dodany w obecnej pogodzie\nNowy: Metric i Imperial są dostępne do wyboru - zostaną uwzględnione w następnej aktualizacji danych.\nNowy: W przypadku błędu w odzyskiwaniu danych, próba jest ponownie po 10 minutach\nUsuń opcję admin (ponowne uruchomienie blokady)\nPrzepisane na maszynie","uk":"Зміна: хв. js-controller до 6.0.11\nЗміна: Оновлення застарілих даних при запуску.\nНова: Фото посилання, додана в поточну погоду\nНовий: Metric і Imperial доступні для вибору - Буде враховано з наступним оновленням даних.\nНова: У разі перерозподілу даних спроба повторно виконана після 10 хвилин\nВидалити опцію адміністратора (блокування місця)\nПодати заявку","zh-cn":"更改:min.js控制器改为6.0.11\n更改:过期数据在启动时更新.\n新建: 在当前天气中添加图片链接\n新增:计量和帝国可供选择 -- -- 将在下一次数据更新时加以考虑.\n新建:如果出现数据检索错误,10分钟后再次尝试\n删除管理选项( 重新开始屏蔽)\n重写字体"},"2.0.1":{"en":"BREAKING: Requires Nodejs 20 or higher\nBREAKING: Command states are now buttons and only respond to ack=false. \nadmin option: No data is updated on adapter startup (default: true). \napikey renamed and encrypted\nDependencies and eslint updated\nAdd nextHour.CloudCover","de":"BREAKING: Erfordert Nodejs 20 oder höher\nBREAKING: Befehlszustände sind jetzt Tasten und reagieren nur auf ack=false.\nadmin-Option: Beim Adapter-Startup werden keine Daten aktualisiert (Standard: true).\napikey umbenannt un
                                        das wird so gar nicht angezeigt
                                        • M matrose65
                                          matrose65
                                          hier mal als Text
