  3. Einsteigerfragen
  4. Backitup meldet Fehler einer eslintrc.json
    5.4k
12 Beiträge 4 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • Basti17683B Offline
    Basti17683B Offline
    Basti17683
    Liebe Community,
    ich finde den Fehler nicht. Mein Backitup Adapter macht alle 2 Tage Nachts ein Backup auf das lokale NAS. Seit einiger Zeit bekomme ich Meldungen dass in einem temporären Ordner "corrupted Files" liegen.
    Ich habe mal die Logstufe auf Debüt gesetzt und manuell ein Backup gestartet.
    2025-02-22 13:48:39.214 - info: backitup.0 (280) cleaned everything up...
    2025-02-22 13:48:39.214 - info: backitup.0 (280) terminating
    2025-02-22 13:48:39.215 - info: backitup.0 (280) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-02-22 13:48:39.716 - info: backitup.0 (280) terminating
    2025-02-22 13:48:39.761 - info: host.IOHost instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-02-22 13:48:43.103 - info: host.IOHost instance system.adapter.backitup.0 in version "3.0.31" started with pid 25120
    2025-02-22 13:48:44.419 - info: backitup.0 (25120) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 7.0.6
    2025-02-22 13:48:44.533 - info: backitup.0 (25120) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2025-02-22 13:49:10.765 - error: backitup.0 (25120) [iobroker/iobroker] host.IOHost One or more optional files are corrupted: host.IOHost /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/widgets/.eslintrc.json is not a valid json file
    2025-02-22 13:49:10.766 - error: backitup.0 (25120) [iobroker/iobroker] host.IOHost Please ensure that self-created JSON files are valid
    2025-02-22 13:49:22.229 - warn: backitup.0 (25120) [iobroker/clean] No older backup files are deleted, because this backup was started manually
    2025-02-22 13:49:49.581 - info: host.IOHost stopInstance system.adapter.backitup.0 (force=false, process=true)
    2025-02-22 13:49:49.584 - info: host.IOHost stopInstance system.adapter.backitup.0 send kill signal
    2025-02-22 13:49:49.584 - info: backitup.0 (25120) Got terminate signal TERMINATE_YOURSELF
    2025-02-22 13:49:49.584 - info: backitup.0 (25120) cleaned everything up...
    2025-02-22 13:49:49.585 - info: backitup.0 (25120) terminating
    2025-02-22 13:49:49.586 - info: backitup.0 (25120) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-02-22 13:49:50.087 - info: backitup.0 (25120) terminating
    2025-02-22 13:49:50.129 - info: host.IOHost instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-02-22 13:49:53.430 - info: host.IOHost instance system.adapter.backitup.0 in version "3.0.31" started with pid 25240
    2025-02-22 13:49:54.453 - info: backitup.0 (25240) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 7.0.6
    2025-02-22 13:49:54.484 - info: backitup.0 (25240) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2025-02-22 13:50:55.808 - info: host.IOHost stopInstance system.adapter.backitup.0 (force=false, process=true)
    2025-02-22 13:50:55.811 - info: host.IOHost stopInstance system.adapter.backitup.0 send kill signal
    2025-02-22 13:50:55.811 - info: backitup.0 (25240) Got terminate signal TERMINATE_YOURSELF
    2025-02-22 13:50:55.812 - info: backitup.0 (25240) cleaned everything up...
    2025-02-22 13:50:55.813 - info: backitup.0 (25240) terminating
    2025-02-22 13:50:55.814 - info: backitup.0 (25240) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-02-22 13:50:56.316 - info: backitup.0 (25240) terminating
    2025-02-22 13:50:56.355 - info: host.IOHost instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-02-22 13:50:59.684 - info: host.IOHost instance system.adapter.backitup.0 in version "3.0.31" started with pid 25316
    2025-02-22 13:51:00.465 - debug: backitup.0 (25316) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2025-02-22 13:51:00.486 - debug: backitup.0 (25316) Objects client ready ... initialize now
    2025-02-22 13:51:00.487 - debug: backitup.0 (25316) Objects create System PubSub Client
    2025-02-22 13:51:00.487 - debug: backitup.0 (25316) Objects create User PubSub Client
    2025-02-22 13:51:00.513 - debug: backitup.0 (25316) Objects client initialize lua scripts
    2025-02-22 13:51:00.517 - debug: backitup.0 (25316) Objects connected to redis: 127.0.0.1:9001
    2025-02-22 13:51:00.535 - debug: backitup.0 (25316) Redis States: Use Redis connection: 127.0.0.1:9000
    2025-02-22 13:51:00.543 - debug: backitup.0 (25316) States create System PubSub Client
    2025-02-22 13:51:00.544 - debug: backitup.0 (25316) States create User PubSub Client
    2025-02-22 13:51:00.558 - debug: backitup.0 (25316) States connected to redis: 127.0.0.1:9000
    2025-02-22 13:51:00.580 - debug: backitup.0 (25316) Plugin sentry Do not initialize Plugin (enabled=false)
    2025-02-22 13:51:00.673 - info: backitup.0 (25316) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 7.0.6
    2025-02-22 13:51:00.684 - debug: backitup.0 (25316) BackItUp has recognized a Docker system
    2025-02-22 13:51:00.724 - info: backitup.0 (25316) [iobroker] backup will be activated at 02:48 every 1 day(s)
    2025-02-22 13:51:00.764 - debug: backitup.0 (25316) [iobroker] 10 48 02 */1 * *
    2025-02-22 13:51:00.770 - debug: backitup.0 (25316) cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.10.100/Public/IOBackup /opt/iobroker/backups"
    2025-02-22 13:51:01.048 - debug: backitup.0 (25316) mount successfully completed
    2025-02-22 13:51:03.057 - debug: backitup.0 (25316) detect backup file 1 from NAS: iobroker_2025_02_13-02_48_21_backupiobroker.tar.gz
    2025-02-22 13:51:03.057 - debug: backitup.0 (25316) detect backup file 2 from NAS: iobroker_2025_02_14-02_48_21_backupiobroker.tar.gz
    2025-02-22 13:51:03.058 - debug: backitup.0 (25316) detect backup file 3 from NAS: iobroker_2025_02_15-02_48_21_backupiobroker.tar.gz
    2025-02-22 13:51:03.058 - debug: backitup.0 (25316) detect backup file 4 from NAS: iobroker_2025_02_16-02_48_22_backupiobroker.tar.gz
    2025-02-22 13:51:03.058 - debug: backitup.0 (25316) detect backup file 5 from NAS: iobroker_2025_02_17-02_48_21_backupiobroker.tar.gz
    2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 6 from NAS: iobroker_2025_02_18-02_48_21_backupiobroker.tar.gz
    2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 7 from NAS: iobroker_2025_02_19-02_48_21_backupiobroker.tar.gz
    2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 8 from NAS: iobroker_2025_02_20-02_48_21_backupiobroker.tar.gz
    2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 9 from NAS: iobroker_2025_02_21-02_48_21_backupiobroker.tar.gz
    2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 10 from NAS: iobroker_2025_02_22-02_48_21_backupiobroker.tar.gz
    2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 11 from NAS: iobroker_2025_02_22-13_49_05_backupiobroker.tar.gz
    2025-02-22 13:51:03.060 - debug: backitup.0 (25316) detect last backup file: iobroker_2025_02_22-13_49_05_backupiobroker.tar.gz
    2025-02-22 13:51:10.711 - debug: backitup.0 (25316) mount activ... umount in 2 Seconds!!
    2025-02-22 13:51:10.747 - debug: backitup.0 (25316) Backup has started ...
    2025-02-22 13:51:10.750 - debug: backitup.0 (25316) [iobroker/mount] mount activ... umount is started before mount!!
    2025-02-22 13:51:10.763 - debug: backitup.0 (25316) [iobroker/mount] umount successfully completed
    2025-02-22 13:51:12.721 - debug: backitup.0 (25316) umount: device is busy... wait 5 Minutes!!
    2025-02-22 13:51:20.748 - debug: backitup.0 (25316) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.10.100/Public/IOBackup /opt/iobroker/backups"
    2025-02-22 13:51:20.865 - debug: backitup.0 (25316) [iobroker/mount] mount successfully completed
    2025-02-22 13:51:20.866 - debug: backitup.0 (25316) [iobroker/mount] done
    2025-02-22 13:51:25.208 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost 5397 objects saved
    2025-02-22 13:51:25.448 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost 4668 states saved
    2025-02-22 13:51:25.449 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost Validating backup ...
    2025-02-22 13:51:25.450 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost "config.json" is valid
    2025-02-22 13:51:25.451 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost "objects.jsonl" exists
    2025-02-22 13:51:25.451 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost "states.jsonl" exists
    2025-02-22 13:51:25.743 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost JSONL lines are valid
    2025-02-22 13:51:25.750 - error: backitup.0 (25316) [iobroker/iobroker] host.IOHost One or more optional files are corrupted: host.IOHost /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/widgets/.eslintrc.json is not a valid json file
    2025-02-22 13:51:25.751 - error: backitup.0 (25316) [iobroker/iobroker] host.IOHost Please ensure that self-created JSON files are valid
    2025-02-22 13:51:25.751 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost The backup is valid!
    2025-02-22 13:51:32.914 - debug: backitup.0 (25316) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2025_02_22-13_51_21_backupiobroker.tar.gz
    2025-02-22 13:51:32.916 - debug: backitup.0 (25316) [iobroker/iobroker] This backup can only be restored with js-controller version 7.0 or higher
    2025-02-22 13:51:33.939 - debug: backitup.0 (25316) [iobroker/iobroker] done
    2025-02-22 13:51:35.908 - debug: backitup.0 (25316) [iobroker/yahka] found yahka database: yahka.0
    2025-02-22 13:51:35.909 - debug: backitup.0 (25316) [iobroker/yahka] done
    2025-02-22 13:51:36.061 - debug: backitup.0 (25316) [iobroker/nodered] Created nodered tmp directory
    2025-02-22 13:51:36.151 - debug: backitup.0 (25316) [iobroker/nodered] Node-Red tmp copy finish
    2025-02-22 13:51:36.196 - debug: backitup.0 (25316) [iobroker/nodered] Backup created: /opt/iobroker/backups/nodered.0_2025_02_22-13_51_36_backupiobroker.tar.gz
    2025-02-22 13:51:36.197 - debug: backitup.0 (25316) [iobroker/nodered] Try deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
    2025-02-22 13:51:36.254 - debug: backitup.0 (25316) [iobroker/nodered] node-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
    2025-02-22 13:51:36.254 - debug: backitup.0 (25316) [iobroker/nodered] found node-red database: node-red.0
    2025-02-22 13:51:36.255 - debug: backitup.0 (25316) [iobroker/nodered] done
    2025-02-22 13:51:36.856 - debug: backitup.0 (25316) [iobroker/cifs] used copy path: /Public/IOBackup
    2025-02-22 13:51:36.857 - debug: backitup.0 (25316) [iobroker/cifs] done
    2025-02-22 13:51:37.459 - warn: backitup.0 (25316) [iobroker/clean] No older backup files are deleted, because this backup was started manually
    2025-02-22 13:51:37.459 - debug: backitup.0 (25316) [iobroker/clean] done
    2025-02-22 13:51:37.615 - debug: backitup.0 (25316) [iobroker/historyHTML] new history html values created
    2025-02-22 13:51:37.660 - debug: backitup.0 (25316) [iobroker/historyHTML] done
    2025-02-22 13:51:37.821 - debug: backitup.0 (25316) [iobroker/historyJSON] new history json values created
    2025-02-22 13:51:37.821 - debug: backitup.0 (25316) [iobroker/historyJSON] done
    2025-02-22 13:51:37.977 - debug: backitup.0 (25316) [iobroker/umount] mount active, umount is started ...
    2025-02-22 13:51:42.989 - debug: backitup.0 (25316) [iobroker/umount] umount successfully completed
    2025-02-22 13:51:42.990 - debug: backitup.0 (25316) [iobroker/umount] done
    2025-02-22 13:51:44.046 - debug: backitup.0 (25316) [iobroker/telegram] done
    2025-02-22 13:51:45.351 - debug: backitup.0 (25316) [iobroker/notification] done
    2025-02-22 13:51:45.613 - debug: backitup.0 (25316) [iobroker] exec: done
    Nach dem File habe ich im gesamten System unter /opt/iobroker gesucht. Das existiert nicht. Hat einer einen Anhaltspunkt was ich da noch probieren kann damit meine Backups wieder ohne Fehler durchlaufen?
    Vielen Dank
    • Basti17683B Basti17683
      Liebe Community,
      Vielen Dank
      simatecS Online
      simatecS Online
      simatec
      @basti17683 Hast du auch mit dem Punkt vorm Dateinamen gesucht? Das ist sehr wichtig
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
        Basti17683B Offline
        Basti17683
        @simatec
        Hallo und danke dass du dich dem ganzen so schnell angenommen hast.
        Ich habe mit dem Punkt voran gesucht.
        Mit "find / .eslintrc.json" sucht er ja das gesamte System durch
        Ergebnis nachdem er 5 Minuten Dateien über den Bildschirm hat fliegen lassen:
        Das ganze läuft auf einem QNAP Nas in einem Docker Container. Und das seit 2 Jahren echt stabil ohne Probleme
        Fällt dir sonst noch was ein?
          @simatec
          simatecS Online
          simatecS Online
          simatec
          @basti17683 durchsuche mal nur das iob Volume und dann am besten mit Rechten, die auch Zugriff auf das Volume gewähren
          Basti17683B 1 Antwort Letzte Antwort
          • simatecS simatec
            Basti17683B Offline
            Basti17683B Offline
            Basti17683
            @simatec
            Da bringt er einige aus dem gesamten Container Ordner in welchem IoBroker und InfluxDB laufen.
            Aber keines davon befindet sich in einem tmp Backup Ordner. Gesucht wurde mit dem einzigen Benutzer auf der Station der selbstverständlich Admin Rechte hat
              @simatec
              simatecS Online
              simatecS Online
              simatec
              @basti17683 die ist es...
              • simatecS simatec
                Basti17683B Offline
                Basti17683B Offline
                Basti17683
                schrieb am zuletzt editiert von Basti17683
                @simatec
                Die kann ich bedenkenlos raus löschen? Mehr als das etwas in der Visu nicht mehr funktioniert kann nicht passieren oder?
                PS: Die Datei ist in meiner Vis2 Instanz ebenfalls vorhanden, mit der gab es aber beim Backup scheinbar keine Probleme
                  @simatec
                  @basti17683 sagte in Backitup meldet Fehler einer eslintrc.json:
                  wenn du dich nicht traust, dann benenn sie doch um
                    Basti17683B Offline
                    Basti17683B Offline
                    Basti17683
                    @homoran Wenn man sich lang genug mit Dingen beschäftigt kann es passieren dass man den Wald vor lauter Bäumen icht mehr sieht.
                    Danke, Datei umbenannt und manuell ein Backup ausgeführt -> keinen Fehler mehr bekommen.
                    Kann jemand etwas zum Hintergrund sagen? Warum ist diese exakt gleiche Datei im Ordner VIS2/Widgets kein Problem beim speichern, aber im Ordner VIS/Widgets schon?
                      Ist sie das? Hast du mal einen hash über beide Dateien gezogen?
                        Basti17683B Offline
                        Basti17683B Offline
                        Basti17683
                        @thomas-braun said in Backitup meldet Fehler einer eslintrc.json:
                        Nein noch nicht - aber ich werde mal schauen wie man das macht, dann hole ich das nach :) Wichtig ist dass es jetzt scheinbar ohne Fehler wieder funktioniert. :)
                          @basti17683
                          So zum Beispiel:
                          https://de.simeononsecurity.com/guides/how-to-get-hashes-of-files-on-linux/
