  4. [gelöst] Mehrere Fehler in der Log *javascript/cloud/admin*
    1.9k
4 Beiträge 2 Kommentatoren 478 Aufrufe
  • E Offline
    el-lutschi
    meine ioBroker Log wirft immer und immer wieder folgende Fehlermeldungen aus.
    cloud.0 2018-01-22 10:42:47.370 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    javascript.0 2018-01-22 10:42:47.367 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0 2018-01-22 10:42:47.365 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0 2018-01-22 10:42:46.851 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    cloud.0 2018-01-22 10:42:46.813 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    javascript.0 2018-01-22 10:42:46.810 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    javascript.0 2018-01-22 10:42:46.773 error change ID is empty: {"common":{"enabled":true},"_id":null,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    Und ich weiß einfach nicht woran es liegt.
    Außerdem erhalte ich beim Ausführen eines Blockly Skripts immer folgenden Fehler:
    javascript.0	2018-01-22 10:42:46.756	warn	at Object. (script.js.Custom_Scripts.Automationen.Heizung_An/Aus_Hin:9:5)
    javascript.0	2018-01-22 10:42:46.746	warn	Wrong type of hm-rpc.0.OEQ0243547.4.SET_TEMPERATURE: "string". Please fix, while deprecated and will not work in next versions.
    Skript:
    Kann mir jemand weiterhelfen?
    Danke und Gruß
    Chris
    • C Offline
      cernst1980
      Du weist der Temperature einen String ("20") zu, es wird aber eine Zahl (20) erwartet.
      Unter Mathematik findest du die Zahlen.
      • E Offline
        el-lutschi
        @cernst1980:
        Unter Mathematik findest du die Zahlen. `
        Vielen Dank! Das hat Problem Nummer 2 gelöst!
        Gerade ist mir auch aufgefallen, dass Problem 1 auftritt, wenn das Heizung An/Aus Skript ausgeführt wird.
        • E Offline
          el-lutschi
          Problem 1 konnte ich nun auch lösen!
          Wie, findet ihr hier:
          http://ww.iobroker.com/forum/viewtopic.php?f=22&t=9701
