  3. Off Topic
  4. Tasmota - Visual Studio Code - IR remote
    2.4k
tasmotair remote
35 Beiträge 6 Kommentatoren 3.6k Aufrufe 4 Beobachtet
  • bahnuhrB Offline
    bahnuhrB Offline
    bahnuhr
    zum compilieren der Tasmota bin benutze ich Visual Studio Code.
    Wenn ich IR einbinde in: user_config_override.h
    mit
    #define USE_IR_REMOTE // Send IR remote commands using library IRremoteESP8266 and ArduinoJson (+4k3 code, 0k3 mem, 48 iram)
    bekomme ich dann beim build die Fehlermeldungen:
    c:/users/dieter/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\tasmota\src\tasmota.ino.cpp.o:(.text._Z24IrReceiveUpdateThresholdv+0x4): undefined reference to `IRrecv::setUnknownThreshold(unsigned short)'
    c:/users/dieter/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\tasmota\src\tasmota.ino.cpp.o: in function `IrReceiveUpdateThreshold()':
    tasmota.ino.cpp:(.text._Z24IrReceiveUpdateThresholdv+0x2b): undefined reference to `IRrecv::setUnknownThreshold(unsigned short)'
    c:/users/dieter/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\tasmota\src\tasmota.ino.cpp.o: in function `IrReceiveInit()':
    tasmota.ino.cpp:(.text._Z13IrReceiveInitv+0x3c): undefined reference to `IRrecv::setUnknownThreshold(unsigned short)'
    c:/users/dieter/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\tasmota\src\tasmota.ino.cpp.o:(.text._Z14IrRemoteSendGCPPcjj+0x0): undefined reference to `IRsend::sendGC(unsigned short*, unsigned short)'
    c:/users/dieter/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\tasmota\src\tasmota.ino.cpp.o: in function `IrRemoteSendGC(char**, unsigned int, unsigned int)':
    tasmota.ino.cpp:(.text._Z14IrRemoteSendGCPPcjj+0x9b): undefined reference to `IRsend::sendGC(unsigned short*, unsigned short)'
    c:/users/dieter/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\tasmota\src\tasmota.ino.cpp.o:(.text._Z23IrRemoteSendRawStandardPPctjj+0x0): undefined reference to `IRsend::sendRaw(unsigned short const*, unsigned short, unsigned short)'
    c:/users/dieter/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\tasmota\src\tasmota.ino.cpp.o: in function `IrRemoteSendRawStandard(char**, unsigned short, unsigned int, unsigned int)':
    tasmota.ino.cpp:(.text._Z23IrRemoteSendRawStandardPPctjj+0x93): undefined reference to `IRsend::sendRaw(unsigned short const*, unsigned short, unsigned short)'
    c:/users/dieter/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\tasmota\src\tasmota.ino.cpp.o: in function `IrRemoteSendRawFormatted(char**, unsigned int, unsigned int)':
    tasmota.ino.cpp:(.text._Z24IrRemoteSendRawFormattedPPcjj+0x131): undefined reference to `IRsend::sendRaw(unsigned short const*, unsigned short, unsigned short)'
    c:/users/dieter/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: tasmota.ino.cpp:(.text._Z24IrRemoteSendRawFormattedPPcjj+0x22e): undefined reference to `IRsend::sendRaw(unsigned short const*, unsigned short, unsigned short)'
    Habe schon gegoogelt nach: undefined reference to `IRrecv
    aber so richtig gefunden habe ich nichts
    (oder ich habe es nicht verstanden).
    Hat jemand mal ne Info oder Link für mich was ich da nun falsch mache.
    mfg
    Dieter
    Danke.
    BananaJoeB CodierknechtC J 3 Antworten Letzte Antwort
    • bahnuhrB bahnuhr
      mit
      mfg
      Dieter
      BananaJoeB Offline
      BananaJoeB Offline
      BananaJoe
      @bahnuhr kompilierst du für ESP8266 oder ESP32?
      • BananaJoeB BananaJoe
        bahnuhrB Offline
        bahnuhrB Offline
        bahnuhr
        @bananajoe sagte in Tasmota - Visual Studio Code - IR remote:
        esp8266
        Wemos D1 mini
        Danke.
        BananaJoeB M 2 Antworten Letzte Antwort
        • bahnuhrB bahnuhr
          esp8266
          Wemos D1 mini
          BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          @bahnuhr bei der Arduino IDE müsste man die Library einbinden / herunterladen.
          Gibt es so etwas auch bei dem Visual Studio Code?
          • bahnuhrB bahnuhr
            esp8266
            Wemos D1 mini
            MCU
            @bahnuhr
            Es gibt doch eine fertige bin?
            https://ota.tasmota.com/tasmota/release/tasmota-ir.bin
            • M MCU
              @bahnuhr
              bahnuhrB Offline
              bahnuhrB Offline
              bahnuhr
              @mcu
              Nützt mir nichts.
              Da ist nicht alles enthalten was ich brauche.
              Danke.
              • bahnuhrB bahnuhr
                mit
                mfg
                Dieter
                CodierknechtC Offline
                Codierknecht
                @bahnuhr
                Ich nehme dafür den Tasmocompiler. Läuft bei mir als Docker-Container.
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                • CodierknechtC Codierknecht
                  @bahnuhr
                  bahnuhrB Offline
                  bahnuhrB Offline
                  bahnuhr
                  @codierknecht sagte in Tasmota - Visual Studio Code - IR remote:
                  @bahnuhr
                  wollte ich auch mal probieren.
                  Hab ich aber nicht hinbekommen.
                  Danke.
                  • bahnuhrB bahnuhr
                    @bahnuhr
                    Codierknecht
                    @bahnuhr
                    Läuft unter Portainer mit folgendem Stack:
                    services:
                      tasmocompiler:
                        image: benzino77/tasmocompiler
                        container_name: Tasmocompiler
                        network_mode: "bridge"
                        ports:
                          - "8300:3000"
                        restart: unless-stopped
                      @bahnuhr
                      services:
                        tasmocompiler:
                          ports:
                            - "8300:3000"
                      bahnuhrB Offline
                      bahnuhrB Offline
                      bahnuhr
                      @codierknecht
                      Danke für die Info.
                      Hab aber kein Docker.
                      Kann man dies auch in proxmox in einer lxc oder vm laufen lassen.
                      Hast du einen Linkn ?
                      Danke.
                      • bahnuhrB bahnuhr
                        @codierknecht
                        Danke für die Info.
                        Codierknecht
                        @bahnuhr sagte in Tasmota - Visual Studio Code - IR remote:
                        Das alles in einem LXC oder VM selbst hochzuziehen dürfte auch nicht einfacher sein, als das in VS korrekt einzurichten.
                        Das ist ja der Vorteil von Docker: Da hat sich bereits jemand die Mühe gemacht, das einsatzbereit aufzusetzen. Ready to use.
                        Setz doch 'nen kleinen LXC dafür auf und installiere dort Docker. Der Container kann ja schlafen, solange er nicht benötigt wird.
                        • bahnuhrB bahnuhr
                          mit
                          mfg
                          Dieter
                          Jan1
                          @bahnuhr
                          Da steht Bei Dir wohl noch default, stell mal um , dann geht das ohne weiteres Gefummel.
                          @MCU
                          warum nimmt man wohl keine fertigen bins?
                          • J Jan1
                            @bahnuhr
                            @MCU
                            bahnuhrB Offline
                            bahnuhrB Offline
                            bahnuhr
                            @jan1
                            Danke für den Input.
                            Wo ist dies enthalten ?
                            Und auf was umstellen ?
                            Danke schonmal.
                            Danke.
                            • bahnuhrB bahnuhr
                              @jan1
                              Danke schonmal.
                              Jan1
                              @bahnuhr
                              bei VSCode unten mittig in der Taskleist, da stellst das ein was Du haben möchtest und ich habe eben mal zum Testen von "default" einfach auf "tasmota-De" umgeschaltet und ohne weiter was zu ändern lief es durch mit einer neuen Auswahlmöglichkeit "IR" bei den GPIO unter Geräte in der Tasmota GUI ;)
                              • J Jan1
                                @bahnuhr
                                bahnuhrB Offline
                                bahnuhrB Offline
                                bahnuhr
                                @jan1 sagte in Tasmota - Visual Studio Code - IR remote:
                                @bahnuhr
                                Keine Veränderung bei mir.
                                Immer noch das gleiche.
                                Danke.
                                • bahnuhrB bahnuhr
                                  @bahnuhr
                                  Jan1
                                  @bahnuhr
                                  wie hast das in der override eingetragen?
                                  • J Jan1
                                    @bahnuhr
                                    bahnuhrB Offline
                                    bahnuhrB Offline
                                    bahnuhr
                                    @jan1
                                    #undef USE_BMP
                                    #define USE_BMP                                  // [I2cDriver10] Enable BMP085/BMP180/BMP280/BME280 sensors (I2C addresses 0x76 and 0x77) (+4k4 code)
                                    #undef USE_BMP68X
                                    #define USE_BME68X                            // Enable support for BME680/BME688 sensor using Bosch BME68x library (+6k9 code)
                                    #undef USE_BH1750
                                    #define USE_BH1750                               // [I2cDriver11] Enable BH1750 sensor (I2C address 0x23 or 0x5C) (+0k5 code)
                                    #undef USE_SR04
                                    //#define USE_SR04                                 // Add support for HC-SR04 ultrasonic devices (+1k code)
                                    #undef USE_ADS1115
                                    //#define USE_ADS1115                            // [I2cDriver13] Enable ADS1115 16 bit A/D converter (I2C address 0x48, 0x49, 0x4A or 0x4B) based on Adafruit ADS1x15 library (no library needed) (+0k7 code)
                                    #undef USE_SENSEAIR
                                    #define USE_SENSEAIR                             // Add support for SenseAir K30, K70 and S8 CO2 sensor (+2k3 code)
                                    #undef USE_IR_REMOTE
                                    #undef USE_IR_RECEIVE
                                    #define USE_IR_RECEIVE                           // Support for IR receiver (+7k2 code, 264 iram)
                                    #undef USE_DISPLAY
                                    //#define USE_DISPLAY                            // Add I2C/TM1637/MAX7219 Display Support (+2k code)
                                    Die define bräuchte ich alle.
                                    Danke.
                                    J CodierknechtC 2 Antworten Letzte Antwort
                                    • bahnuhrB bahnuhr
                                      @jan1
                                      #undef USE_BMP
                                      #undef USE_BMP68X
                                      #undef USE_BH1750
                                      #undef USE_SR04
                                      #undef USE_ADS1115
                                      #undef USE_SENSEAIR
                                      #undef USE_DISPLAY
                                      Jan1
                                      @bahnuhr
                                      hier läufts:
                                      • bahnuhrB bahnuhr
                                        @jan1
                                        #undef USE_BMP
                                        #undef USE_BMP68X
                                        #undef USE_BH1750
                                        #undef USE_SR04
                                        #undef USE_ADS1115
                                        #undef USE_SENSEAIR
                                        #undef USE_DISPLAY
                                        Codierknecht
                                        @bahnuhr
                                        Probier mal die hier: tasmota_8266_ir.bin
                                          @bahnuhr
                                          bahnuhrB Offline
                                          bahnuhrB Offline
                                          bahnuhr
                                          @codierknecht
                                          S8 und IR gehen
                                          BME680 und LH1750 gehen nicht.
                                          Danke.
                                          83.2k
