  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Modbus EasyCharge Einstellungen
    2.8k
    4.9k
    4.1k
modbus-adapter
79 Beiträge 3 Kommentatoren 9.4k Aufrufe 2 Beobachtet
  • M Mark
    @homoran said in Modbus EasyCharge Einstellungen:
    @mark sagte in Modbus EasyCharge Einstellungen:
    Error response for FCx3: Illegal Data Address
    hast du noch Leichen auf snderen Tabs des Adapters?
    Ich hab nur den einen modbus adapter und auch nur eine Instanz. Angeschlossen ist auch nur das Board.
    mit den Einstellungen 8,1,even kommt
    modbus.0
    	2025-02-09 21:31:35.192	debug	Cleaning up request fifo.
    modbus.0
    	2025-02-09 21:31:35.190	debug	Clearing timeout of the current request.
    modbus.0
    	2025-02-09 21:31:35.185	info	Disconnected from slave
    modbus.0
    	2025-02-09 21:31:34.178	warn	[DevID_2] Poll error count: 1 code: {"err":"timeout","timeout":5000}
    modbus.0
    	2025-02-09 21:31:34.173	error	Request timed out.
    modbus.0
    	2025-02-09 21:31:34.171	warn	Error: undefined
    modbus.0
    	2025-02-09 21:31:29.155	debug	[DevID_2/holdingRegs] Poll address 40035 - 1 registers
    modbus.0
    	2025-02-09 21:31:29.153	debug	Initialization of scale factors done!
    modbus.0
    	2025-02-09 21:31:29.148	debug	[DevID_2] Poll start ---------------------
    modbus.0
    	2025-02-09 21:31:29.145	info	Connected to slave
    modbus.0
    	2025-02-09 21:31:29.116	debug	connect to serial /dev/ttyUSB0 with 9600
    modbus.0
    	2025-02-09 21:31:28.545	debug	Add holdingRegisters.40035_Temperatur: {"_id":"holdingRegisters.40035_Temperatur","type":"state","common":{"name":"Temperatur","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40035,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.0
    	2025-02-09 21:31:28.543	debug	Initialize Objects for holdingRegs: [{"_address":"40035","name":"Temperatur","description":"Temperatur","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40035,"deviceId":2,"id":"holdingRegisters.40035_Temperatur"}]
    modbus.0
    	2025-02-09 21:31:28.542	debug	Initialize Objects for inputRegs: []
    modbus.0
    	2025-02-09 21:31:28.539	debug	Initialize Objects for coils: []
    modbus.0
    	2025-02-09 21:31:28.537	debug	Initialize Objects for disInputs: []
    modbus.0
    	2025-02-09 21:31:28.216	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 7.0.6
    modbus.0
    	2025-02-09 21:31:27.245	debug	Plugin sentry Initialize Plugin (enabled=true)
    host.michi
    	2025-02-09 21:31:22.951	info	instance system.adapter.modbus.0 in version "6.3.2" started with pid 1209
    host.michi
    	2025-02-09 21:31:21.925	info	"system.adapter.modbus.0" enabled
    admin.0
    	2025-02-09 21:31:15.087	info	<== Disconnect system.user.admin from ::ffff:192.168.188.158 modbus
    admin.0
    	2025-02-09 21:30:59.851	info	==> Connected system.user.admin from ::ffff:192.168.188.158
    und da steht nur unter holding nur der eine Eintrag?
    • wendy2702W wendy2702
      @mark Probier mal ein anderes Register. Vielleicht geht das eine gerade nicht
      Mark
      @wendy2702 said in Modbus EasyCharge Einstellungen:
      Hab schon 40155 probiert. Da müsste eigentlich eine 5 zurückkommen. Geht aber auch nicht
        Stop!
        ihr hängt mich ab 😁
        zuerst kam illegal address
        in Verbindung mit function code 3.
        Das ist read holding register
        also "eigentlich" alles richtig
        mit even statt none war das weg
        richtig?
        M HomoranH 2 Antworten Letzte Antwort
        • M Mark
          @mark steht das eine Register jetzt bei Holding?
          Wenn ja stelle es mal bei Eingangs Register ein
          kommt genau das selbe.
          Egal ob mit none oder even, egal ob als Eingang oder Holding
          eben nicht!
            Stop!
            ihr hängt mich ab 😁
            richtig?
            Mark
            Stop!
            ihr hängt mich ab 😁
            richtig?
            Ja, richtig.
            Mit dem egal meinte ich, dass bei even immer das selbe kommt (egal welches Register) und bei none kommt auch das selbe (egal welches Register). Aber even und none produzieren unterschiedliche Fehler
            wendy2702W HomoranH 2 Antworten Letzte Antwort
            • M Mark
              Stop!
              ihr hängt mich ab 😁
              richtig?
              Ja, richtig.
              wendy2702W Offline
              wendy2702W Offline
              @mark laut deiner Beschreibung ist „none“ richtig.
              Also damit mal ein Register bei Holding eintragen und log zeigen oder mal a/b tauschen und testen
              • M Mark
                Stop!
                ihr hängt mich ab 😁
                richtig?
                Ja, richtig.
                ja das passt!
                even war laut Registertanelle fettgedruckt = Werkseinstellumg!?
                Also bleiben wir erst mal dabei.
                dieses dämliche
                hatten wir in einem anderen Fall schon mal.
                Ich kann mich nur nicht erinnern warum, und ob das gelöst wurde
                  ja das passt!
                  dieses dämliche
                  wendy2702W Offline
                  wendy2702W Offline
                  @homoran nö, nix Even.
                  Laut seiner Beschreibung—> keine parität
                    Mark
                    Einstellung: none, Holding 40035 mit Abfrage:
                    modbus.0
                    	2025-02-09 21:55:26.201	debug	Cleaning up request fifo.
                    modbus.0
                    	2025-02-09 21:55:26.199	debug	Clearing timeout of the current request.
                    modbus.0
                    	2025-02-09 21:55:26.193	info	Disconnected from slave
                    modbus.0
                    	2025-02-09 21:55:25.193	warn	[DevID_2] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                    modbus.0
                    	2025-02-09 21:55:25.187	error	Request timed out.
                    modbus.0
                    	2025-02-09 21:55:25.184	warn	Error: undefined
                    modbus.0
                    	2025-02-09 21:55:20.219	error	Error response: Data address of some or all the required entities are not allowed or do not exist in slave
                    modbus.0
                    	2025-02-09 21:55:20.217	error	Error response for FCx3: Illegal Data Address
                    modbus.0
                    	2025-02-09 21:55:20.169	debug	[DevID_2/holdingRegs] Poll address 40035 - 1 registers
                    modbus.0
                    	2025-02-09 21:55:20.166	debug	Initialization of scale factors done!
                    modbus.0
                    	2025-02-09 21:55:20.161	debug	[DevID_2] Poll start ---------------------
                    modbus.0
                    	2025-02-09 21:55:20.159	info	Connected to slave
                    modbus.0
                    	2025-02-09 21:55:20.141	debug	connect to serial /dev/ttyUSB0 with 9600
                    modbus.0
                    	2025-02-09 21:55:19.578	debug	Add holdingRegisters.40035_Temp: {"_id":"holdingRegisters.40035_Temp","type":"state","common":{"name":"Temp","role":"level","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40035,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                    modbus.0
                    	2025-02-09 21:55:19.576	debug	Initialize Objects for holdingRegs: [{"_address":"40035","name":"Temp","description":"Temp","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40035,"deviceId":2,"id":"holdingRegisters.40035_Temp"}]
                    modbus.0
                    	2025-02-09 21:55:19.575	debug	Initialize Objects for inputRegs: []
                    modbus.0
                    	2025-02-09 21:55:19.572	debug	Initialize Objects for coils: []
                    modbus.0
                    	2025-02-09 21:55:19.570	debug	Initialize Objects for disInputs: []
                    modbus.0
                    	2025-02-09 21:55:19.249	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 7.0.6
                    modbus.0
                    	2025-02-09 21:55:18.308	debug	Plugin sentry Initialize Plugin (enabled=true)
                    modbus.0
                    	2025-02-09 21:55:18.241	debug	States connected to redis: 127.0.0.1:9000
                    modbus.0
                    	2025-02-09 21:55:18.213	debug	States create User PubSub Client
                    modbus.0
                    	2025-02-09 21:55:18.211	debug	States create System PubSub Client
                    modbus.0
                    	2025-02-09 21:55:18.195	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                    modbus.0
                    	2025-02-09 21:55:18.158	debug	Objects connected to redis: 127.0.0.1:9001
                    modbus.0
                    	2025-02-09 21:55:18.139	debug	Objects client initialize lua scripts
                    modbus.0
                    	2025-02-09 21:55:18.095	debug	Objects create User PubSub Client
                    modbus.0
                    	2025-02-09 21:55:18.092	debug	Objects create System PubSub Client
                    modbus.0
                    	2025-02-09 21:55:18.086	debug	Objects client ready ... initialize now
                    modbus.0
                    	2025-02-09 21:55:18.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                    host.michi
                    	2025-02-09 21:55:14.149	info	instance system.adapter.modbus.0 in version "6.3.2" started with pid 1477
                    host.michi
                    	2025-02-09 21:55:13.101	info	"system.adapter.modbus.0" enabled
                    admin.0
                    	2025-02-09 21:55:05.799	info	<== Disconnect system.user.admin from ::ffff:192.168.188.158 modbus
                    admin.0
                    	2025-02-09 21:54:13.438	info	==> Connected system.user.admin from ::ffff:192.168.188.158
                      @wendy2702 sagte in Modbus EasyCharge Einstellungen:
                      aber in der Registerbeschreibung ist die Zeile mit even fettgedruckt = Werkseinstellung
                      und einen Fall mit undefined hatte ich gerade über die Suche gefunden.
                      Da war der Stick defekt :-(
                        wendy2702W Offline
                        wendy2702W Offline
                        @homoran tolle Dokumentation wenn mal none und mal even angegeben ist.
                        Vielleicht ist der Stick auch gegrillt nachdem er falsch angeschlossen war.
                          Man könnte noch
                          • Leitungen A/B tauschen
                          • Die Anzahl auf einmal gelesene Register begrenzen
                            • einige Geräte brauchen das
                            Mark
                            Würde ich ausschließen. Hab gerade einen 2. (selbe Marke) getestet. Gleiches Ergebnis.
                            • M Mark
                              @mark ne Kontrollleuchte hat der nicht?
                                Mark
                                nein.
                                • M Mark
                                  nein.
                                  @mark Dann bleibt nur Kontakt zum Hersteller der Karte aufnehmrn und dediziert nach den Parametern fragen, und/oder due genannten Möglichkeiten in allen Variationen durchprobierrn.
                                  • M Mark
                                    @mark abgesehen davon, dass du ein twisted pair nehmrn solltest, kann ich hier nicht die Anschlüsse erkennen.
                                    A/B ->??
                                    Da hast du völlig recht, das hier ist aber nur mein VersuchsPi, den ich im Zimmer habe und sobald das funktioniert wird alles an den richtigen in der Garage angeschlossen, aber da ist es mir momentan viel zu kalt.
                                    Shit, ich bin tatsächlich bei den Anschlüssen verrutscht.
                                    So, hab es jetzt hoffentlich richtig angeschlossen:
                                    So, bei Einstellung 8,1,none kommt folgender Log:
                                    modbus.0
                                    	2025-02-09 21:23:58.423	debug	Cleaning up request fifo.
                                    modbus.0
                                    	2025-02-09 21:23:58.422	debug	Clearing timeout of the current request.
                                    modbus.0
                                    	2025-02-09 21:23:58.419	info	Disconnected from slave
                                    modbus.0
                                    	2025-02-09 21:23:57.421	warn	[DevID_2] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                    modbus.0
                                    	2025-02-09 21:23:57.414	error	Request timed out.
                                    modbus.0
                                    	2025-02-09 21:23:57.412	warn	Error: undefined
                                    modbus.0
                                    	2025-02-09 21:23:52.451	error	Error response: Data address of some or all the required entities are not allowed or do not exist in slave
                                    modbus.0
                                    	2025-02-09 21:23:52.450	error	Error response for FCx3: Illegal Data Address
                                    modbus.0
                                    	2025-02-09 21:23:52.388	debug	[DevID_2/holdingRegs] Poll address 40035 - 1 registers
                                    modbus.0
                                    	2025-02-09 21:23:52.386	debug	Initialization of scale factors done!
                                    modbus.0
                                    	2025-02-09 21:23:52.381	debug	[DevID_2] Poll start ---------------------
                                    modbus.0
                                    	2025-02-09 21:23:52.379	info	Connected to slave
                                    modbus.0
                                    	2025-02-09 21:23:52.362	debug	connect to serial /dev/ttyUSB0 with 9600
                                    modbus.0
                                    	2025-02-09 21:23:51.790	debug	Add holdingRegisters.40035_Temperatur: {"_id":"holdingRegisters.40035_Temperatur","type":"state","common":{"name":"Temperatur","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40035,"deviceId":2,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
                                    modbus.0
                                    	2025-02-09 21:23:51.788	debug	Initialize Objects for holdingRegs: [{"_address":"40035","name":"Temperatur","description":"Temperatur","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40035,"deviceId":2,"id":"holdingRegisters.40035_Temperatur"}]
                                    modbus.0
                                    	2025-02-09 21:23:51.787	debug	Initialize Objects for inputRegs: []
                                    modbus.0
                                    	2025-02-09 21:23:51.784	debug	Initialize Objects for coils: []
                                    modbus.0
                                    	2025-02-09 21:23:51.782	debug	Initialize Objects for disInputs: []
                                    modbus.0
                                    	2025-02-09 21:23:51.460	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v18.17.1, js-controller: 7.0.6
                                    heisst das, dass der Platine der Kontakt zur Wallbox fehlt und daher möglicherweise gar keine Daten zum abfragen hat?
                                      Mark
                                      Mach ich, schreib gleich mal eine Mail
                                        Mark
                                        Es gibt keine Wallbox. Die Platine wurde mit einem vorkonfektionierten Typ2 Ladestecker verdrahtet und dieser wird dann direkt am Fahrzeug angeschlossen (die Platine ersetzt Quasi die Wallbox).
                                        Die Platine selbst hat eine Status-LED, welche aktuell die Bereitschaft zum Laden signalisiert. Somit sollte ein Abfragen der Werte möglich sein. (Z.b. 40027: 0=getrennt, 1=eingesteckt, 2=undefiniert). Aber egal welches Register ich nehme, es kommen immer die selben Fehler.
                                        Ich werde wie geschrieben den Hersteller kontaktieren und morgen mal am Fahrzeug einstecken. Dann melde ich mich wieder.
                                        Bis hierher erstmal vielen Dank für Eure Hilfe!
                                        • M Mark
                                          @mark hab gerade noch etwas gefunden
                                          Was immer das genau bedeutet.
                                          ggf. musst du tatsächlich die Anzahl zeitgleich ausgelesene Register auf 1 oder einen sehr niedrigen Wert stellen.
